1 Reply Latest reply on Oct 17, 2012 6:52 AM by Mylenium
    AE CS6 Track Mattes and Continuous Rasterising not working
    C Hardcastle Level 1
      Hello,
      I'm having an issue with After Effects CS6. I'm using some Illustrator files in a comp. Within this comp I have used Track Mattes to mask off certain objects. When I put the comp into my master comp and turn on Continuous Rasterisation
      the track mattes seem to slip out of place. None of the layers within the comp or the master comp are 3D layers so this isn't the issue. The Track Mattes are Illustrator files as are the objects being matted.
      This is the result in the master comp.
      These are the layers in the Master comp.
      And these are the layers within the comp.
      Thanks for your help
