3 Replies Latest reply on Oct 17, 2012 2:43 PM by kglad
    Get All instance names in the stage
    alaStickman
      hi,
      is there any way to get all instance name of the objects presents on the stage ? trace them for example
      thank you
        • 1. Re: Get All instance names in the stage
          traceF(this);
          function traceF(mc:MovieClip):Void{
          for(s in mc){
          if(mc[s]._parent==mc){
          trace(s+" : "+mc[s]);
          // if you want to check for children add:
          if(typeof(mc[s])=="movieclip"){
          traceF(mc[s]);
          • 2. Re: Get All instance names in the stage
            alaStickman Level 1
            thank you, it's the correct answer but i still can't solve my problem ,
            the thing is that am using a code from http://www.freeactionscript.com that make enemie follow the player, but i need to do some modification, i need to detect collision between enemies so they will not get the one into the other and the thing that i cannot found their instance name, even when i used your function i only get "player_mc : _level0.player_mc" at the output,
            here is the code, i will be really greatful if you can find a way to help me solve this problem .
            ps :
            am trying to write my own code that make enemie follow the player, coz this one looks very complicated
            thank you
            the code :
            * Game Enemy AI Behavior - Run Away & Follow Player
            * Version:           1.0
            * Author:           Philip Radvan
            * URL:                     http://www.freeactionscript.com
            var enemiesArray:Array = new Array();
            var radians:Number = 180/Math.PI;
            createEnemies(5, "typeA", "e1");
            createEnemies(5, "typeB", "e2");
            createEnemies(5, "typeC", "e3");
            // createEnemies(number of enemies, behavior)
            // use ex: createEnemies(10, "slow", "myLinkedMovieClip);
            function createEnemies(enemyAmount:Number, enemyBehavior:String, enemyLibraryClip:String):Void
                      //run a for loop based on the amount of enemies
                      for(var i = 0; i < enemyAmount; i++)
                                //set temporary variable that will hold the new enemy attributes
                                var tempEnemy:MovieClip = _root.attachMovie(enemyLibraryClip, "enemy"+_root.getNextHighestDepth(),_root.getNextHighestDepth())
                                //give new enemy a random x/y position based on stage width/height
                                tempEnemy._x = random(Stage.width);
                                tempEnemy._y = random(Stage.height);
                                tempEnemy._rotation = random(360);
                                //set enemy behavior
                                if(enemyBehavior == "typeA")
                                          //define enemy characteristics
                                          tempEnemy.speed = 1
                                          tempEnemy.turnRate = .05
                                          tempEnemy.agroRange = 200;
                                          tempEnemy.mode = "follow"
                                else if(enemyBehavior == "typeB")
                                          tempEnemy.speed = 4
                                          tempEnemy.turnRate = .5
                                else if(enemyBehavior == "typeC")
                                          tempEnemy.speed = 1
                                          tempEnemy.turnRate = .2
                                          tempEnemy.agroRange = 100;
                                          tempEnemy.mode = "run"
                                //define variables that are used to calculate following
                                //*don't change these*
                                tempEnemy.distanceX = 0;
                                tempEnemy.distanceY = 0;
                                tempEnemy.distanceTotal = 0;
                                tempEnemy.moveDistanceX = 0;
                                tempEnemy.moveDistanceY = 0;
                                tempEnemy.moveX = 0;
                                tempEnemy.moveY = 0;
                                tempEnemy.totalmove = 0;
                                //add new enemy to array
                                enemiesArray.push(tempEnemy)
            //Update enemies function
            function updateEnemies():Void {
                      for(var i = 0; i < enemiesArray.length; i++)
                                var tempEnemy:MovieClip = enemiesArray[i];
                                //run follow function with temporary enemy as the follower
                                updatePosition(tempEnemy, player_mc);
            // updatePosition(follower, target)
            // use ex: updatePosition(myEnemyMovieClip, playerMovieClip)
            function updatePosition(follower:MovieClip, target:MovieClip) {
                      //calculate distance between follower and target
                      follower.distanceX = target._x-follower._x;
                      follower.distanceY = target._y-follower._y;
                      //get total distance as one number
                      follower.distanceTotal = Math.sqrt(follower.distanceX * follower.distanceX + follower.distanceY * follower.distanceY);
                      //check if target is within agro range
                      if(follower.distanceTotal <= follower.agroRange){
                                //calculate how much to move
                                follower.moveDistanceX = follower.turnRate * follower.distanceX / follower.distanceTotal;
                                follower.moveDistanceY = follower.turnRate * follower.distanceY / follower.distanceTotal;
                                //increase current speed
                                follower.moveX += follower.moveDistanceX;
                                follower.moveY += follower.moveDistanceY;
                                //get total move distance
                                follower.totalmove = Math.sqrt(follower.moveX * follower.moveX + follower.moveY * follower.moveY);
                                //apply easing
                                follower.moveX = follower.speed * follower.moveX / follower.totalmove;
                                follower.moveY = follower.speed * follower.moveY / follower.totalmove;
                                //move & rotate follower
                                if(follower.mode == "follow")
                                          follower._x += follower.moveX;
                                          follower._y += follower.moveY;
                                          follower._rotation = Math.atan2(follower.moveY, follower.moveX) * radians;
                                else if(follower.mode == "run")
                                          follower._x -= follower.moveX;
                                          follower._y -= follower.moveY;
                                          follower._rotation = (Math.atan2(follower.moveY, follower.moveX) * radians)+180;
            //onEnterFrame that executes the updatePosition updateEnemies every frame
            _root.onEnterFrame = function(){
                      updateEnemies();
            //start/stop drag for player_mc
            player_mc.onPress = function(){
                      startDrag(this);
            player_mc.onRelease = function(){
                      stopDrag();
            • 3. Re: Get All instance names in the stage
              the trace output before the colon IS the instance name.  the trace output after the colon is the instance's path and name.
              you enemies are named enemyN where N is a non-negative integer.  all your enemies are stored in enemiesArray.  you can use the following to loop through your enemies:
              for(var i:Number=0;i<enemiesArray.length;i++){
              trace(enemiesArray[i]);
              p.s.  please mark helpful/correct responses.
