Hello
I would like to know if there is a way to stop the transformation that Robohelp does in the html code.
For example:
I write in the html editor :
<div id="footer">
bla bla bla
</div>
I go back to the Conception editor to work, then, when I go back to the html editor, the code became :
<?rh-region_start id="footer" style="x-right: -1240px; x-bottom: -110px; " ?>
bla bla bla
<?rh-region_end ?>
Is there a way to stop it ?
Hi there
I suspect what is happening is that you are trying to use the term "footer" to identify a div and because RoboHelp offers its own footer and header, these are "reserved" words that RoboHelp will insist on using.
It's no different than what you encounter when scripting or programming.
The only suggestion I can make is to perhaps use a variant on the name. Perhaps insert a zero for one or both of the letter o in footer so it looks like this: f00ter.
Cheers... Rick
Yes you right ! Thanks.
It works in the case of the footer. The div stay but style="x-right: -1240px; x-bottom: -110px; " continue to comes back !
I don't want this part because it's already in the css, but different.
