6 Replies Latest reply on Oct 18, 2012 5:44 AM by heathrowe
    Adding fonts from Web  Fonts
    laskoman
      Here the worlkflow I'm using to add fonts to Edge Animate.
      1. Picked up a font type and its associated code as given by Web Fonts i.e:
           font-family: overlock
           code: <script src="http://use.edgefonts.net/overlock.js"></script>
      2. In Edge Animate From 'Text' tool I choose 'Text' property and add Font from the drop down menu.
           Font fallback list: overlock (Small helps says that it's the name for font family
           Embed code: <script src="http://use.edgefonts.net/overlock.js"></script> (Help suggests this code will be put into <head></head> of the HTML file
      The abovel NEVER results in the code being put ino the head section of the HTML file. The result of the above is this array in ..._edge.js file:
      var fonts = {};
         fonts['overlock']='<script src=\"http://use.edgefonts.net/overlock.js\"></script>';
      This, however, does not result in this font being available and simply put does not work.
      Sure enough, if I put the above <script> code in the head section by hand, everything works.
      May I have an explenation form somebody at Adobe, what it is going up here?
