1. Re: how to set up a multilingual website with Adobe Muse and push it live to Adobe Business Catalyst
Nicole - BCGurus.com Oct 18, 2012 7:31 AM (in response to Carla@home)Hi,
have you ever worked with Muse before? If not, I would suggest learning the basics by following a few tutorials starting here: http://www.adobekb.com/
Muse is simply design, it does help you to push a site live, but once integrated with BC it requires extended knowledge about the tags and modules in BC: http://kb.worldsecuresystems.com/134/bc_1342.html and http://kb.worldsecuresystems.com/134/bc_1345.html. Publishing with Muse: http://www.adobekb.com/launching_pt01.html
"Automatically be redirected to their languages pages based on their locale", if you mean by automatically that the site would "jump" to a specific domain once the location is detected, I assume this would require javascript on a landing page. Also this would require the set up of multiple domains or subdomains first to redirect the user to that domain.
This link here goes more in detail: http://kb.worldsecuresystems.com/521/bc_521.html
I would imagine that Muse could help you with the basic outline of the design of your site, but you would have to stop somewhere to integrate dynamic content in order for you to use the same templates with multi-language support.
2. Re: how to set up a multilingual website with Adobe Muse and push it live to Adobe Business Catalyst
Carla@home Oct 18, 2012 7:42 AM (in response to Nicole - BCGurus.com)Thanks for your help Nicole. Yes I worked with Muse before. I created my personal websiste in Dutch. But now I want to create an other site in different languages. I will look into the details you pointed out.
Carla@home
3. Re: how to set up a multilingual website with Adobe Muse and push it live to Adobe Business Catalyst
atamtan Dec 26, 2012 2:17 PM (in response to Carla@home)Hi, I have same questions, did you manage to get your multilanguage site, if so if you don't mind could please tell me how. Denis
4. Re: how to set up a multilingual website with Adobe Muse and push it live to Adobe Business Catalyst
Carla@home Dec 31, 2012 12:57 PM (in response to atamtan)Hi Denis, Sorry for not replying sooner. I actually managed to create a multilingual site. (See also my other post on http://forums.adobe.com/message/4873218#4873218 and the replies I've received)
I have created an English subfolder where the English site resides. If you want to reuse content, images or video's you have to "point to" the directories where these documents are stored.
First I made a duplicate of the Dutch Adobe Muse file and altered the text content to English. Then I exported the English site on my local hard drive.
Forms are another matter. If you use Adobe Business Catalyst (ABC) they are compiled when you publish you site within Adobe Muse. In my case the English version didn't work. I created a blank form online in ABC with the forms module. Copied the html-code and added with Adobe Dreamweaver CSS-styles. The form (all the html codes and the CSS codes) I copied as an html element in Adobe Muse.
In Adobe Dreamweaver or any HTML-editor I opened the html-pages by changing the codes that points to the directories images, assets, stylesheets and scripts.
I.e: <link rel="stylesheet" type="text/css" href="css/site_global.css?259224851"/> had to be changed in <link rel="stylesheet" type="text/css" href="../css/site_global.css?259224851"/> where the ../ "tells" that in the above directory /css the document can be found.
this works the same with images and other documents.
I.e: <img id="u8668_img" src="images/apartement.jpg" had to be changed in <img id="u8668_img" src="../images/apartement.jpg"
For a small site the above procedure works fine but if you have a large site I think it's better using Adobe Dreamweaver or any other html-editor.
5. Re: how to set up a multilingual website with Adobe Muse and push it live to Adobe Business Catalyst
atamtan Dec 31, 2012 1:14 PM (in response to Carla@home)Hi Carla,
Thank you very much for the info, certainly I will follow your instructions
and let you know the result, coincidentally, I am trying to translate
English to Dutch.
I am using outside server, hopefully it will work.
Thank you again and have a wonderful new year,
Denis
6. Re: how to set up a multilingual website with Adobe Muse and push it live to Adobe Business Catalyst
rohsafi Oct 14, 2013 3:55 PM (in response to Carla@home)i was able to create a multilingual site after much sweat. adobe info on the same is quite vague but i was able to to go around it by creating first the "mother" language then creating additional page of each of pages in the prefered language. then *important: pages having the same content but in difrent language i created a common link for them, say a flag one in english and the other in spanish, then i linked the appropriate language to its appropriate flag.
i hope it helps, a great software indeed.
shared knowleage is great
7. Re: how to set up a multilingual website with Adobe Muse and push it live to Adobe Business Catalyst
Carla@home Oct 15, 2013 3:49 AM (in response to rohsafi)Hi Rohsafi,
In the latest version of Adobe Muse it is possible to publish multiple sites in sub-folders.
I've created a bilingual site (Dutch/English) in Adobe Business Catalyst. The Dutch site resides in the root folder and the English site in the sub folder /en.
Please note that when you publish the site via Muse the already existing BC webforms are overwritten (this was or still is a minor bug (I haven't tested it if the bug was solved)). Make sure that you have submitted a webform from the front end and that would create a case so this will not be overwritten or deleted when you publish the site again via Muse.
So first publish the first muse site and then fill the form from the front end and then publish the other.
Insert an absolute URL on the webform instead just selecting the page from the list of the pages when setting up the redirect in Muse.
The above answer was a reply from Adobe Support.
Krgds Carla@home
8. Re: how to set up a multilingual website with Adobe Muse and push it live to Adobe Business Catalyst
BoxerKiro Apr 1, 2014 3:04 AM (in response to Carla@home)Hi Rohsafi,
I am trying a multilingualwebsite, take a look so we can share som ideas. I am new in Muse but I am testing new features
http://multilanguagewebsite.businesscatalyst.com/
Regards,
9. Re: how to set up a multilingual website with Adobe Muse and push it live to Adobe Business Catalyst
il May 13, 2014 9:42 PM (in response to Carla@home)Hi there,U can also use GTranslate.It works perfectly,it's cheap ,and it's easy to apply.it has a 30-day money back guarantee.U do not lose anything,in case of not being satisfied,they will do money back. here is the link
10. Re: how to set up a multilingual website with Adobe Muse and push it live to Adobe Business Catalyst
spsachosJLL Jun 10, 2014 2:03 PM (in response to il)I tried Google Translate on my site. It works great but something is messed up with how it looks on the page. I tried the Muse forums to get help but was never able to fix. Still looking for a solution.
11. Re: how to set up a multilingual website with Adobe Muse and push it live to Adobe Business Catalyst
JorgeGP Jul 8, 2014 2:37 PM (in response to Carla@home)hello, excuse me but I do not speak English, I use google translator, thanks for trying to understand ...
know as multi-lingual publishing sites to muse, my PROBLEM is that I find as by Busines Catalys can edit that second language
example
www.sitie.com / admin URL --- OK
www.sitie.com/en/ ----?????? URL does not work
what is the url to edit the languages
I'M IN TROUBLE, I HAVE A CUSTOMER WAITING FOR THE SOLUTION, ANY HELP THANKS
12. Re: how to set up a multilingual website with Adobe Muse and push it live to Adobe Business Catalyst
Carla@home Jul 9, 2014 9:54 AM (in response to spsachosJLL)Hi spsachosJLL,
I've looked at your site in English. And everything looked good. No, messed up text or what so ever.
I've an other question. How did you make the scrolling effects with the large background images? Did you use Muse for it or did you add your own CSS3 styles. When you scroll down the site, everything scrolls smoothly. Nice job:)
Can you give me some hints and tips?
Thanks.
Carla@home
13. Re: how to set up a multilingual website with Adobe Muse and push it live to Adobe Business Catalyst
BoxerKiro Aug 27, 2014 1:38 AM (in response to JorgeGP)Hi,
Here is a multilanguage site that I created with Adobe Muse and without the google translator. The site is possible to see it in three languages English, Norwegian and Spanish.
Take a look and give me your opinions please!
www.boxerkiro.com
Thanks.
Diego
