• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
1
finding out where a certain colour is used
Contributor ,
Oct 18, 2012 Oct 18, 2012
Hi everyone,
is there a way to find out where a certain colour (swatch) is used inside a document, like on what page or something?
Inside a single-page document is not a big deal, in a 200+ paged document it is hell to find out…
I can search for "character colour" and search again for object fill and again for stroke and again and again.
I'm looking for an "easy" way to use.
or maybe there is a script for that?
thanks for helping me out!
Views
22.1K
Translate
Translate
Report
Report
Community guidelines
community guidelines
Mentor , Oct 18, 2012 Oct 18, 2012
following zero budget solutions...
I doubt there's a way to bypass first stage of Steve's method. However, you can avoid entering Separations Preview and manual cycling through hundreds of pages.
Just convert your color to spot, create special Preflight profile and run it:
you'll get the pages where spot colors occur, even more, ID will select it for you when you click on page number in "problem list" in Preflight pallette.
Votes
Translate
Translate
Community Expert ,
One trick is to temporarily use the Swatches panel to change the color from process to spot. Then choose Window > Output > Separations Preview, and turn on Separations. Turn off the process colors, but turn on the color you're looking for. Page through the document and you can see where it occurs.
Votes
Translate
Translate
Report
Report
Contributor ,
Steve,
your solution is an option, though, also time-consuming for large documents.
When using the "Find Font" command in Indesign, and showing "More Info", there you can see on which pages a certain font is used, that is fast and easy.
Votes
Translate
Translate
Report
Report
Mentor ,
Votes
Translate
Translate
Report
Report
Contributor ,
Hi Winterm,
you made my day!
This is the best-free-fast solution.
I have tried it and it worked real good.
Votes
Translate
Translate
Report
Report
Guest
Oct 22, 2012 Oct 22, 2012
Excellent idea thanks for the info. Will come in very handy
Votes
Translate
Translate
Report
Report
Mentor ,
jocstone_me wrote:
Hi everyone,
The commercial Blatner Tools plug-in for InDesign from dtptools.com can find colors and can create a report of all colors or only those used in the current document. There's a 14-day free trial.
I have no connection to the company other than being a satisfied user.
HTH
Regards,
Peter
_______________________
Peter Gold
KnowHow ProServices
Votes
Translate
Translate
Report
Report
Contributor ,
Hi Peter,
thanks for your idea, the plugin is only 99$, so it is to consider …
Votes
Translate
Translate
Report
Report
Community Beginner ,
Sep 03, 2014 Sep 03, 2014
This video shows you how to use the Find and Replace tool to do this, and it's the best answer, better than replacing with spot colors etc., works for me every time!!!
Find Where a Color is Used in InDesign - YouTube
Votes
Translate
Translate
Report
Report
Feb 01, 2021 Feb 01, 2021
LATEST
Latest version (Jan 2021) has Color option in the Find command
Votes
Translate
Translate
Report
Report
