2 Replies Latest reply on Oct 18, 2012 10:10 PM by Riquez JP
    individual letter rotation information in degrees?
    choiceimport
      If you type some text on a curved path is there a way to find out each letters rotation in degrees?
      Maybe in Illustrator? Any known scripts? Besides individually adding letters then rotation them
      to the background curved text layer.
        • 1. Re: individual letter rotation information in degrees?
          It probably could be done with some sort of script. Still, would not necessarily return the value you expect depending on the font since fonts are not necessarily upright and on teh otehr hand the bounding box around a character may be at a different angle than any straight edge in teh font. As a start you might consider the protractor tools to measure angles, but anything more specific than that will probably take you into geek territory...
          Mylenium
          • 2. Re: individual letter rotation information in degrees?
            Riquez JP Level 1
            Your question contains probably the easiest answer.
            Draw a line or box, make it semi-transparent. Zoom in close & rotate the line positioning it over the letters - make a note of the angle.
            This is probably the quickest, easiest way to get what you want.
            Alternatively - if its a circle  - you can rotate the circle until the letter your interested in is at the top 12 oclock position - how much did you rotate? then just cancel.
