1. Re: Changing dpi changes resolution
conroy Oct 18, 2012 3:00 PM (in response to lnllakewood)First, DPI (dots per inch) is different to PPI (pixels per inch) despite the terms very often being wrongly interchanged. Photoshop works with pixels, not printer output dots.
http://www.google.com/search?q=dpi+v+ppi
Changing resolution with "Resample" enabled will result in changed pixels, but no change in the physical size (inches/cm/etc.) of the document.
Changing resolution with "Resample" disabled will result in unchanged pixels, but there will be a change to the physical size of the document.
You will not increase the clarity of an image by enlarging it.
The best way to learn what happens is to try things and observe the results.
2. Re: Changing dpi changes resolution
Silkrooster Oct 18, 2012 9:07 PM (in response to lnllakewood)To help you understand, take a look at these formulas...
1) width in pixels / ppi = width in inches {Ex. 1200 px/300 ppi = 4"}
2) width in inches x ppi = width in pixels {Ex. 6" x 300 ppi = 1800 px}
3) width in pixels / width in inches = ppi {Ex. 1000 px /8 " = 125 ppi}
Exchange Width with Height and repeat for the rest of the equation...
The resample enabled box allows the pixels to be altered
If the pixels are changed then the quality will be effected.
With resample disabled, the pixels are lock so they can not be changed.
So the quality can not be effected.
3. Re: Changing dpi changes resolution
station_two Oct 18, 2012 9:14 PM (in response to Silkrooster)Silkrooster wrote:
The quality will definitely be affected, always adversely.
Silkrooster wrote:
...With resample disabled, the pixels are lock so they can not be changed.
So the quality can not be effected...
Again, you mean affected. It's a meaningful typo.
4. Re: Changing dpi changes resolution
Silkrooster Oct 19, 2012 12:30 AM (in response to station_two)Oops, sorry about that.
