1. Re: DPS Development Certificates
Bob Bringhurst Oct 19, 2012 10:36 AM (in response to Automator21)It looks like your certificate is already created -- the Download button appears. Follow the steps to click the Download button, download the .cer file, and use the Keychain Access utility to create a .p12 cert based on the .cer file.
If that doesn't work for some reason, you can click Revoke to revoke the certificate and start over.
2. Re: DPS Development Certificates
Automator21 Oct 19, 2012 3:39 PM (in response to Bob Bringhurst)Thank you Bob, I revoked my certificates and it all works fine now. I went through the whole process of App Build and was able to download the Developer app(.ipa), but when it drag the .ipa file over to my itunes library and sync it... I can see my app loading but then as it finishes I get a error message that my app fail to install. I've restarted my ipad 2 just to make sure it wasn't that and it still dosen't want to install. I did however noticed that under the "General" settings under "Profiles" i have 2, would this be normal to have? Any trouble shooting ideas you can share would be helpful. Thanks.
