• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
RH9 - Crashes when making Printed Docs
Explorer ,
Oct 19, 2012 Oct 19, 2012
I have a small project that I want to make into a PDF file. RoboHelp just crashes. Does anybody have any thoughts? Is there something obvious that I might have forgotten to do?
Views
806
Translate
Translate
Report
Report
Community guidelines
community guidelines
Explorer , Oct 25, 2012 Oct 25, 2012
Well, after a lot of testing, it turned out that the problem was one line that somehow sneaked into my stylesheet:
    mso-bookmark: _Toc152401062;
After I removed this line, everything worked.
~Margaret
Votes
Translate
Translate
Community Expert ,
Oct 21, 2012 Oct 21, 2012
Do you really mean it crashes or does it hang? Any error messages?
Does it crash if you try to generate a Word document instead of a PDF?
Have you tried using one of the sample project?
@petergrainge
Votes
Translate
Translate
Report
Report
Explorer ,
Oct 23, 2012 Oct 23, 2012
Hi, Peter, It actually crashes. I have attached a screen shot of what happens. So far, this only happens on this particular project. I have another project that works fine. I have Word 2010 installed. It doesn't matter whether I try to make a doc or a pdf. Both crash.
~M Becker
Votes
Translate
Translate
Report
Report
Community Expert ,
Oct 24, 2012 Oct 24, 2012
First have you tried creating a new print layout, not a duplicate as that will just copy any corruption there?
After that I am thinking perhaps the quickest troubleshooter in the long run would be divide and conquer.
Zip up the project so you have a copy that cannot accidentally be opened and worked on. That gives you a copy that you can safely revert to later if needed. Save the zip file somewhere safe.
Then create another copy of the project so that you have two copies that can be worked on.
Open Copy 1 and delete half the topics. Ignore any broken links reported. Generate the document from that copy.
Open Copy 2 and delete the other half of the topics. Generate the document from that copy.
It should be the case that one copy is now OK and one still has the problem.
Trash the good copy and then create a second copy of the copy with the problem.
Repeat the process until you have located the topic that is causing the problem.
The process takes less time than you might think.
@petergrainge
Votes
Translate
Translate
Report
Report
Explorer ,
I'll give it a go and report. Thanks.
Votes
Translate
Translate
Report
Report
Explorer ,
~Margaret
Votes
Translate
Translate
Report
Report
Community Expert ,
Oct 26, 2012 Oct 26, 2012
Clearly a topic created from importing or pasting from Word.
@petergrainge
Votes
Translate
Translate
Report
Report
Explorer ,
LATEST
Yes, damn their eyes.
Thanks, as always for your suggestions.
Margaret
Votes
Translate
Translate
Report
Report
Resources
RoboHelp Documentation
Download Adobe RoboHelp
