1 Reply Latest reply on Oct 24, 2012 2:36 AM by Gaius Coffey
    Can I call a web app and load a specific state (not the defeult state) within the url?
    cfortin14 Level 1
      I have a web app with many states, can I load the app and activate a specific state (not the default) from the url?
      Thank you in advanced,
      Carlos
        • 1. Re: Can I call a web app and load a specific state (not the defeult state) within the url?
          Gaius Coffey Level 2
          Yes, but you need to implement it yourself.
          There are two methods.
          1. You can set a flashvars parameter in your HTML launch code for Flash. This will be available in the parameters property of your application.
          2. You can implement a BrowserManager listener to read the url fragment.
          For example, you could do something like this:
          [code]
                xmlns:mx="library://ns.adobe.com/flex/mx" minWidth="955" minHeight="600"
                creationComplete="application1_creationCompleteHandler(event)">
          <fx:Script>
            <![CDATA[
             import mx.events.BrowserChangeEvent;
             import mx.events.FlexEvent;
             import mx.managers.BrowserManager;
             import mx.managers.IBrowserManager;
             // Set a constant for arg name to prevent typos!
             public const SELECT_STATE_ARG:String = "selectState";
              * Initialise app to use either flashvars parameters or BrowserManager to set state.
              * Will respond to selectState value in either fragment or flashvars.
             protected function application1_creationCompleteHandler(event:FlexEvent):void
              // Method 1: This tries to load based on value of selectState in flashvars in your launch code.
              if(parameters && parameters[SELECT_STATE_ARG]) {
               tryState(parameters[SELECT_STATE_ARG].toString());
              // Method 2: Set up browser manager to listen.
              // 1. Get instance
              var bm:IBrowserManager = BrowserManager.getInstance();
              // 2. Init to get current url
              bm.init();
              // 3. Add event listener for hash tag changes
              bm.addEventListener(BrowserChangeEvent.URL_CHANGE,processBrowserChange);
              // 4. Call listener once to set initial state.
              processBrowserChange(null);
              * Try going to the specified state or go to errored state with details if it fails.
             protected function tryState(tryLoadState:String):void {
              try {
               currentState = tryLoadState;
              } catch(e:Error) {
               errorDetails  = "State not found: "+tryLoadState+"\n"+e.toString();
               currentState = "errored";
             [Bindable] protected var errorDetails:String;
              * Look for a fragment and search for selectState - try loading that state if found.
             protected function processBrowserChange(event:BrowserChangeEvent):void {
              var tryLoadState:String;
              var fragment:String = bm.fragment;
              if(fragment) {
               try {
                var uv:URLVariables = new URLVariables(fragment);
                tryLoadState = uv[SELECT_STATE_ARG];
               } catch(e:Error) {
                errorDetails  = "Could not parse: "+fragment+" as URLVariables\n"+e.toString();
                return;
               if(tryLoadState) tryState(tryLoadState);
          </fx:Script>
          <fx:Declarations>
            <!-- Place non-visual elements (e.g., services, value objects) here -->
          </fx:Declarations>
          <s:states>
            <s:State name="aState" />
            <s:State name="aNotherState" />
            <s:State name="yetANotherState" />
            <s:State name="errored" />
          </s:states>
          <s:VGroup horizontalCenter="0" verticalCenter="0">
            <s:Label text="currentState is {currentState}" />
            <s:Label text="{errorDetails}" color="#ff0000" includeIn="errored" />
          </s:VGroup>
          </s:Application>
          [/code]
          That will allow you to change the state of your app on demand by linking to, for example:
          http://<myUrl>/myapp.html#selectState=aNotherState
          Cheers,
          G
