2 Replies Latest reply on Oct 20, 2012 10:54 PM by Steven L. Gotz
    Video Render Issue.
    hanglooselh
      I have been an ameture user of Preimere for a while now and very recently, my epxorted clips are showing what I can only describe as old VHS style errors.
      I am currently trying to export a time lapse sequence and I end up with this in the program monitor.
      When I hit play, the sequence looks fine. Everything was working until a couple days ago and I don't seem to be doing anything different.
      Here is a quick example of the workflow (about 1 min in length). Any help would be totally appreciated.
        • 1. Re: Video Render Issue.
          Jim_Simon Level 8
          One thing I noticed is that you only selected the first JPG image when importing.  Normally you'd select them all.  See if that makes any difference.
          • 2. Re: Video Render Issue.
            Steven L. Gotz Level 5
            No, that is the correct way to import as a sequence. You select the first one and check the box.
            Does it make a difference if you even slightly resize the Program Monitor panel? Or, how about if you change "Fit" to some percentage? Try resetting the workspace. That might help.
            It is possibly a Mac thing, and I am a PC guy. I have never seen that before. It looks like it is trying to show you all of the stills.
