4 Replies Latest reply on Oct 21, 2012 10:45 PM by Manish-Sharma
    Split Columns Within a List
    Dylan Hamada
      Hello,
      I'm currently working on the questions page for a math textbook and have run into an impasse.
      I'm trying to place a numbered list (which is a 3-split column) within another numbered list. However, I don't know how to do this. I'm attaching a screenshot.
      Please note Questions 1-6. I am aiming to have the alphabetically numbered list sit on the same line as the numbered list. Both use paragraph styles which contain a list element, and not manual formatting with tabs, spaces, etc.
      I appreciate any help.
      Thank you.
        • 1. Re: Split Columns Within a List
          Manish-Sharma Employee Moderator
          There could be other techiniques as well but this how I did :-
          Define 2 paragraph style :-
          Paraghraph style 1 :- Under the "Bullet and numbering" section, have the Numerir Numbering at Level 1.
                                         Define the formatting you want for the Question 7, 8 and 9.
                                         Also, under "Indent and spacing" define "Space After" value.  --- This will bring the gap in the Numeric and Alphabetical section also gap between the paragraph.
          Paragraph style 2 :-  Under the "Bullet and numbering" section to have the Numeric Numbering at Level 2 , change the format to have "a,b,c,d"
                                         Define the formatting of text as you want to appear for the number in these options.
                                         Under "Span Column" , Define "Split column" , Sub Column" value to be 3 and specify the gutter space and other settings as required.
          When you want to use the Numeric numbering , say for Question 1 , 2 , 7 , 8 and 9 use the Paragraph style 1.
          Then Switch to Paragraph Style 2 and type the numbers, (no need to type the alphabet for bulleting, they will be automatically added)
          After you have typed the Third number set Ex:- C) 23,235 , press "Num Enter"(Enter key on Num Pad) for Column break , this will move the content to the next split column.
          • 2. Re: Split Columns Within a List
            Dylan Hamada Level 1
            Hi Manish,
            Thanks for your quick reply!
            I tried your suggestion. The problem is, though, that I can only reduce the "Space After" value for Paragraph Style 1 to 0, which still doesn't bring the two lines (Paragraph Style 1 on top, Paragraph Style 2 on bottom) to the same line.
            I found a work-around just now. If I adjust the baseline shift to a higher value for Paragraph Style 2, it will move it vertically higher.
            If anyone has a more "proper" fix, please let me know.
            Thanks again, Manish!
            • 3. Re: Split Columns Within a List
              After using my quick fix above, I've realized it leads to more work. Because I adjust one line's baseline, the line below that one must be adjusted to a greater degree, and the one below that, to an even greater degree, etc.
              I'm stuck. Anyone have any ideas?
              • 4. Re: Split Columns Within a List
                This statement has bit confused me.......
                As per the screen shot you provided in the OP the numbered list should look like :-
                1.   --->(Paragraph style 1 applied)
                    a) 23,325                                             d) 665,987     -->(Paragraph style 2 applied to all)
                     b) 34,980                                             e) 678,879
                     c) 64,765 (Num Pad enter)                    f) 32,768
                The 1.(Paragraph style 1) has been defined as the level 1 numbered list which make it more align to the left edge of the page however the alphabetic list (Paragraph style 2) has been defined as level 2 because of which it has moved it towards the right a bit.
                So, would appreciate if you could provide the screen shot of end result and what exactky you are looking for, so that I can help you.
