If go to the CTV website and select a video to watch, nothing happens, the "screen" is blanik. This doesn't happen when I visit other websites. I have followed all of the steps listed in the Adobe troubleshooting - nothing. Would I be better off to just uninstall/reinstall Flashplayer?
Recently i had a similar issue. I update firefox to version 16.0 and flash player to 11.4.402.278. After that i still could view some flash videos like on you tube, but some other sites didn't worked. (e.g. myvdieo.de) Even the version check on adobe's own side didn't showed anything. Where the version flash file usually showed up, only a white space appeared. However the right click menu was still available, it just don't let you enter the settings menu.
(http://helpx.adobe.com/flash-player.html)
So far i couldn't fix this by updating or reinstalling older versions of flash player. I tried 10.3.183.29 and 10.2r152. All showed the same strange bug.
Even disabling the hardware acceleration inside the flash player menu won't helped. (This menu could be accesed on working sites like youtube)
But i found another solution. My notebook has two graphic cards. A nvidia geforce 520M and a the CPU integrated GPU of a Intel i5-2410M. Nvidia calls this optimus technology. In System settings (Nvidia Control Panel) i can choose which graphic card is used for what program. By default i've set it to use the nvidia card for all programs by default. Thus it is used for rendering firefox as well.
As soon as i forced firfox to use the Intel graphics card everything works fine. All videos are working and adobes version check worked too.
So basically this optimus technology doesn't seems to work with the latest firefox - adobe flash combination.
(Blocks firefoxs rendering the output from flash player, when beeing rendered on nvidia ??)
Maybe you have a similiar configuration.
@flybythough - That's interesting. Did you happen to try another browser (or an earlier version of Firefox) to see if it was a specific Firefox 16 bug that you were encountering? Since the same issue occurred with 10.3/10.2, the likely hood of it being a Flash bug is lower. You might also want to try updating your nvidia drivers.
@Chris: Ok played a bit around with following configurations.
Adobe Flash Player is kept untouched and is always 11.4.402.278 for mozilla and co.
My Video Test:
http://www.myvideo.de/watch/8374132/Pirates_of_Ghost_Island
HTML5 Test:
http://www.w3schools.com/html/html5_video.asp
Youtube Test:
http://www.youtube.com/watch?v=Xju9yDOKQuQ&feature=g-logo-xit
Firefox Ver. 10.0b6 - Youtube works with Intel i5 and Nvidia
Myvideo works with Intel i5 and Nvidia
Firefox Ver. 12.0 - Youtube works with Intel i5 and Nvidia
Firefox Ver. 16.0 - Youtube works with Intel i5 and Nvidia
Myvideo works with Intel i5 but not with Nvidia
Youtube works with Intel i5 but not with Nvidia
Firefox Ver. 16.02 - Youtube works with Intel i5 and Nvidia
My Nvidia drivers mightn ot be the latest from Nvidia, but they are the latest from MSI. (8.17.12.6901_v764) My notebook is from them, so i haven't tried any desktop drivers.
Anyhow it really seems to be some incompatibility in firefox 😕 But i don't know how this can have such a heavy influence on flash player ...?
@flybythough - Thanks for the thorough tests that you made. Any chance we could get a copy of your system's dxdiag report?
Why not, here it goes:
Note: The Nvidia card is only listed as PCI device.
(Might has somthing to do with the system configuration, as Nvidia don't has direct access to monitor, but uses the Intel as intermediate controller - you probably know that already
System Information
Time of this report: 11/14/2012, 21:04:58
Machine name: MO-LAP2
Operating System: Windows 7 Home Premium 64-bit (6.1, Build 7600) (7600.win7_gdr.100618-1621)
Language: German (Regional Setting: German)
System Manufacturer: MICRO-STAR INTERNATIONAL CO.,LTD
System Model: MS-16Y1
BIOS: BIOS Date: 02/17/11 11:36:54 Ver: 04.06.03
Processor: Intel(R) Core(TM) i5-2410M CPU @ 2.30GHz (4 CPUs), ~2.3GHz
Memory: 4096MB RAM
Available OS Memory: 4008MB RAM
Page File: 1756MB used, 8260MB available
Windows Dir: C:\windows
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: Using System DPI
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
DxDiag Version: 6.01.7600.16385 64bit Unicode
DxDiag Notes
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Input Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: Intel(R) HD Graphics Family
Manufacturer: Intel Corporation
Chip type: Intel(R) HD Graphics Family
DAC type: Internal
Device Key: Enum\PCI\VEN_8086&DEV_0116&SUBSYS_109C1462&REV_09
Display Memory: 1696 MB
Dedicated Memory: 64 MB
Shared Memory: 1632 MB
Current Mode: 1366 x 768 (32 bit) (60Hz)
Monitor Name: Generic PnP Monitor
Monitor Model: LFP_NAME
Monitor Id: SEC3651
Native Mode: 1366 x 768(p) (60.031Hz)
Output Type: Internal
Driver Name: igdumd64.dll,igd10umd64.dll,igd10umd64.dll,igdumdx32,igd10umd32,igd10umd32
Driver File Version: 8.15.0010.2372 (English)
Driver Version: 8.15.10.2372
DDI Version: 10.1
Driver Model: WDDM 1.1
Driver Attributes: Final Retail
Driver Date/Size: 4/15/2011 19:07:51, 8244224 bytes
WHQL Logo'd: n/a
WHQL Date Stamp: n/a
Device Identifier: {D7B78E66-4256-11CF-967E-9630A9C2C535}
Vendor ID: 0x8086
Device ID: 0x0116
SubSys ID: 0x109C1462
Revision ID: 0x0009
Driver Strong Name: oem29.inf:Intel.Mfg.NTamd64:iSNBM0:8.15.10.2372:pci\ven_8086&dev_0116
Rank Of Driver: 00E62001
Video Accel: ModeMPEG2_A ModeMPEG2_C ModeWMV9_C ModeVC1_C
Deinterlace Caps: {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC3,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC3,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC3,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC4,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC4,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC4,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
D3D9 Overlay: Supported
DXVA-HD: Supported
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
Sound Devices
Description: Speakers (Conexant SmartAudio HD)
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: HDAUDIO\FUNC_01&VEN_14F1&DEV_5069&SUBSYS_1462109C&REV_1003
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: CHDRT64.sys
Driver Version: 8.54.0000.0000 (German)
WHQL Logo'd: n/a
Date and Size: 1/28/2011 02:44:24, 1581184 bytes
Other Files:
Driver Provider: Conexant
HW Accel Level: Basic
Cap Flags: 0x0
Min/Max Sample Rate: 0, 0
Static/Strm HW Mix Bufs: 0, 0
Static/Strm HW 3D Bufs: 0, 0
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: No, No
I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
Sound Capture Devices
Description: Internal Microphone (Conexant SmartAudio HD)
Default Sound Capture: Yes
Default Voice Capture: Yes
Cap Flags: 0x0
Format Flags: 0x0
DirectInput Devices
Device Name: Maus
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Tastatur
Attached: 1
Controller ID: n/a
FF Driver: n/a
Poll w/ Interrupt: No
USB Devices
+ USB-Root-Hub
| Vendor/Product ID: 0x8086, 0x1C26
| Matching Device ID: usb\root_hub20
| Service: usbhub
+-+ Generic USB Hub
| | Vendor/Product ID: 0x8087, 0x0024
| | Matching Device ID: usb\class_09
| | Service: usbhub
| | Driver: usbhub.sys, 7/14/2009 01:07:09, 343040 bytes
| +-+ USB-Eingabegerät
| | | Vendor/Product ID: 0x046D, 0xC03F
| | | Matching Device ID: generic_hid_device
| | | Service: HidUsb
| | | Driver: hidusb.sys, 7/14/2009 01:06:22, 30208 bytes
| | | Driver: hidclass.sys, 7/14/2009 01:06:21, 76288 bytes
| | | Driver: hidparse.sys, 7/14/2009 01:06:17, 32896 bytes
| | +-+ HID-konforme Maus
| | | | Matching Device ID: hid_device_system_mouse
| | | | Service: mouhid
| | | | Driver: mouhid.sys, 7/14/2009 01:00:20, 31232 bytes
| | | | Driver: mouclass.sys, 7/14/2009 02:48:27, 49216 bytes
Gameport Devices
PS/2 Devices
+ Erweiterte PC/AT-PS/2-Tastatur (101/102 Tasten)
| Matching Device ID: *pnp030b
| Service: i8042prt
| Driver: i8042prt.sys, 7/14/2009 00:19:57, 105472 bytes
| Driver: kbdclass.sys, 7/14/2009 02:48:04, 50768 bytes
+ Terminalserver-Tastaturtreiber
| Matching Device ID: root\rdp_kbd
| Upper Filters: kbdclass
| Service: TermDD
+ Finger Sensing Pad
| Matching Device ID: *stlc060
| Upper Filters: fspad_wlh64
| Service: i8042prt
| Driver: fspad_wlh64.sys, 11/8/2010 07:52:14, 68608 bytes
| Driver: StlFspAPI64.dll, 11/8/2010 07:56:34, 245760 bytes
| Driver: StlFspAPI32.dll, 11/8/2010 07:56:40, 210432 bytes
| Driver: FspAppCtrl.dll, 11/8/2010 07:50:26, 333824 bytes
| Driver: FspCpe.dll, 11/8/2010 07:55:30, 489472 bytes
| Driver: FspCpeCHS.dll, 11/8/2010 07:54:58, 185344 bytes
| Driver: FspCpeCHT.dll, 11/8/2010 07:54:58, 185344 bytes
| Driver: FspCpeDEU.dll, 11/8/2010 07:54:56, 185344 bytes
| Driver: FspCpeESP.dll, 11/8/2010 07:55:30, 185344 bytes
| Driver: FspCpeESN.dll, 11/8/2010 07:55:02, 185344 bytes
| Driver: FspCpeFRA.dll, 11/8/2010 07:54:54, 185344 bytes
| Driver: FspCpeITA.dll, 11/8/2010 07:54:52, 185344 bytes
| Driver: FspCpeJPN.dll, 11/8/2010 07:54:52, 185344 bytes
| Driver: FspCpeKOR.dll, 11/8/2010 07:54:50, 185344 bytes
| Driver: FspCpeNLD.dll, 11/8/2010 07:54:48, 185344 bytes
| Driver: FspCpeRUS.dll, 11/8/2010 07:54:48, 185344 bytes
| Driver: FspCpePTB.dll, 11/8/2010 07:54:42, 185344 bytes
| Driver: FspCpeCSY.dll, 11/8/2010 07:54:42, 185344 bytes
| Driver: FspCpeDAN.dll, 11/8/2010 07:54:40, 185344 bytes
| Driver: FspCpeFIN.dll, 11/8/2010 07:54:46, 185344 bytes
| Driver: FspCpeELL.dll, 11/8/2010 07:54:38, 185344 bytes
| Driver: FspCpeHUN.dll, 11/8/2010 07:55:00, 185344 bytes
| Driver: FspCpeHEB.dll, 11/8/2010 07:54:38, 185344 bytes
| Driver: FspCpeNOR.dll, 11/8/2010 07:54:44, 185344 bytes
| Driver: FspCpePLK.dll, 11/8/2010 07:54:36, 185344 bytes
| Driver: FspCpePTG.dll, 11/8/2010 07:54:36, 185344 bytes
| Driver: FspCpeARA.dll, 11/8/2010 07:54:34, 185344 bytes
| Driver: FspCpeSVE.dll, 11/8/2010 07:54:32, 185344 bytes
| Driver: FspCpeTRK.dll, 11/8/2010 07:54:44, 185344 bytes
| Driver: FspLib.dll, 11/8/2010 07:51:02, 70656 bytes
| Driver: FspUip.exe, 11/8/2010 07:52:52, 4055552 bytes
| Driver: FspUipCHS.dll, 11/8/2010 07:52:14, 3125760 bytes
| Driver: FspUipCHT.dll, 11/8/2010 07:52:24, 3125248 bytes
| Driver: FspUipDEU.dll, 11/8/2010 07:52:04, 3129344 bytes
| Driver: FspUipESP.dll, 11/8/2010 07:51:56, 3130880 bytes
| Driver: FspUipESN.dll, 11/8/2010 07:53:16, 3130880 bytes
| Driver: FspUipFRA.dll, 11/8/2010 07:51:54, 3130368 bytes
| Driver: FspUipITA.dll, 11/8/2010 07:51:52, 3131392 bytes
| Driver: FspUipJPN.dll, 11/8/2010 07:51:50, 3127296 bytes
| Driver: FspUipKOR.dll, 11/8/2010 07:51:48, 3126784 bytes
| Driver: FspUipNLD.dll, 11/8/2010 07:51:46, 3130368 bytes
| Driver: FspUipRUS.dll, 11/8/2010 07:51:44, 3130368 bytes
| Driver: FspUipPTB.dll, 11/8/2010 07:51:34, 3130880 bytes
| Driver: FspUipCSY.dll, 11/8/2010 07:51:30, 3129856 bytes
| Driver: FspUipDAN.dll, 11/8/2010 07:51:22, 3129856 bytes
| Driver: FspUipFIN.dll, 11/8/2010 07:52:28, 3129344 bytes
| Driver: FspUipELL.dll, 11/8/2010 07:51:20, 3131904 bytes
| Driver: FspUipHUN.dll, 11/8/2010 07:51:38, 3130880 bytes
| Driver: FspUipHEB.dll, 11/8/2010 07:51:40, 3128832 bytes
| Driver: FspUipNOR.dll, 11/8/2010 07:51:36, 3128832 bytes
| Driver: FspUipPLK.dll, 11/8/2010 07:52:26, 3128832 bytes
| Driver: FspUipPTG.dll, 11/8/2010 07:51:32, 3130880 bytes
| Driver: FspUipARA.dll, 11/8/2010 07:51:24, 3129856 bytes
| Driver: FspUipSVE.dll, 11/8/2010 07:51:26, 3129856 bytes
| Driver: FspUipTRK.dll, 11/8/2010 07:51:28, 3130368 bytes
| Driver: KbdHook.dll, 11/8/2010 07:50:52, 44032 bytes
| Driver: OpiRes.dll, 4/8/2010 02:36:58, 121856 bytes
| Driver: gstconf.ini, 10/27/2010 11:44:36, 69136 bytes
| Driver: gstconf_sgs83.ini, 10/27/2010 11:44:36, 45144 bytes
| Driver: gstconf_sgs91.ini, 10/27/2010 11:44:36, 55077 bytes
| Driver: gstbasic.ini, 10/27/2010 11:44:36, 63530 bytes
| Driver: gstadvance.ini, 10/27/2010 11:44:36, 74903 bytes
| Driver: gstbasicII.ini, 10/27/2010 11:44:36, 33586 bytes
| Driver: gstexecfile.ini, 10/27/2010 11:44:36, 42 bytes
| Driver: HelpText.rtf, 10/7/2010 11:23:20, 1676096 bytes
| Driver: 0x11.wmv, 4/8/2010 02:37:04, 134127 bytes
| Driver: 0x12.wmv, 4/8/2010 02:37:04, 126907 bytes
| Driver: 0x18.wmv, 8/23/2010 10:00:26, 99204 bytes
| Driver: 0x19.wmv, 4/8/2010 02:37:04, 138459 bytes
| Driver: 0x1A.wmv, 4/8/2010 02:37:04, 128351 bytes
| Driver: 0x28.wmv, 4/8/2010 02:37:04, 184673 bytes
| Driver: 0x2A.wmv, 4/8/2010 02:37:04, 168789 bytes
| Driver: 0x2C.wmv, 4/8/2010 02:37:04, 177453 bytes
| Driver: 0x2E.wmv, 4/8/2010 02:37:04, 183229 bytes
| Driver: 0x80.wmv, 4/8/2010 02:37:04, 196225 bytes
| Driver: 0x82.wmv, 4/8/2010 02:37:04, 189005 bytes
| Driver: 0x84.wmv, 4/8/2010 02:37:04, 176009 bytes
| Driver: 0x86.wmv, 4/8/2010 02:37:04, 187561 bytes
| Driver: 0x8B.wmv, 4/8/2010 02:37:04, 255441 bytes
| Driver: 0x8F.wmv, 4/8/2010 02:37:04, 186117 bytes
| Driver: 0xA4.wmv, 4/8/2010 02:37:04, 186117 bytes
| Driver: 0xAC.wmv, 4/8/2010 02:37:04, 210671 bytes
| Driver: 0xC0.wmv, 4/8/2010 02:37:04, 145679 bytes
| Driver: 0xC4.wmv, 4/8/2010 02:37:04, 128351 bytes
| Driver: 0xD4.wmv, 4/8/2010 02:37:04, 202001 bytes
| Driver: 0xD6.wmv, 4/8/2010 02:37:04, 138459 bytes
| Driver: 0x09.wmv, 7/19/2010 09:31:00, 91692 bytes
| Driver: 0x0A.wmv, 7/19/2010 09:31:00, 95442 bytes
| Driver: 0xF0.wmv, 4/8/2010 02:37:04, 264105 bytes
| Driver: 0xF1.wmv, 4/8/2010 02:37:04, 311763 bytes
| Driver: 0xF2.wmv, 4/8/2010 02:37:04, 184673 bytes
| Driver: 0xF8.wmv, 4/8/2010 02:37:04, 277101 bytes
| Driver: 0xF9.wmv, 4/8/2010 02:37:04, 272769 bytes
| Driver: 0xFA.wmv, 4/8/2010 02:37:04, 189005 bytes
| Driver: 0x38.wmv, 4/8/2010 02:37:04, 236663 bytes
| Driver: HSCRM0.wmv, 6/30/2010 02:43:44, 496866 bytes
| Driver: HSCRM1.wmv, 6/30/2010 02:43:44, 403086 bytes
| Driver: HSCRM2.wmv, 6/30/2010 02:43:44, 589420 bytes
| Driver: VSCRM0.wmv, 6/30/2010 02:43:44, 473066 bytes
| Driver: VSCRM1.wmv, 6/30/2010 02:43:44, 480566 bytes
| Driver: VSCRM2.wmv, 6/30/2010 02:43:44, 565652 bytes
| Driver: VscrSliderPage.wmv, 11/4/2010 11:46:00, 441804 bytes
| Driver: fspadco.dll, 12/7/2010 03:25:00, 62976 bytes
+ Terminalserver-Maustreiber
| Matching Device ID: root\rdp_mou
| Upper Filters: mouclass
| Service: TermDD
Disk & DVD/CD-ROM Drives
Drive: C:
Free Space: 45.6 GB
Total Space: 204.0 GB
File System: NTFS
Model: Hitachi HTS545050B9A300
Drive: D:
Free Space: 126.9 GB
Total Space: 192.6 GB
File System: NTFS
Drive: E:
Model: PIONEER DVD-RW DVRTD10RS
Driver: c:\windows\system32\drivers\cdrom.sys, 6.01.7600.16385 (German), 7/14/2009 00:19:54, 147456 bytes
System Devices
Name: High Definition Audio-Controller
Device ID: PCI\VEN_8086&DEV_1C20&SUBSYS_109C1462&REV_05\3&11583659&1&D8
Driver: n/a
Name: Xeon E3-1200/2nd Generation Intel(R) Core(TM) Processor Family PCI Express Root Port - 0101
Device ID: PCI\VEN_8086&DEV_0101&SUBSYS_19998086&REV_09\3&11583659&1&08
Driver: C:\windows\system32\DRIVERS\pci.sys, 6.01.7600.16385 (German), 7/14/2009 02:45:45, 183872 bytes
Name: Intel(R) 6 Series/C200 Series Chipset Family PCI Express Root Port 6 - 1C1A
Device ID: PCI\VEN_8086&DEV_1C1A&SUBSYS_109C1462&REV_B5\3&11583659&1&E5
Name: Atheros AR8151 PCI-E Gigabit Ethernet Controller (NDIS 6.20)
Device ID: PCI\VEN_1969&DEV_1083&SUBSYS_109C1462&REV_C0\4&24F6719B&0&00E5
Driver: n/a
Name: Intel(R) 6 Series/C200 Series Chipset Family PCI Express Root Port 4 - 1C16
Device ID: PCI\VEN_8086&DEV_1C16&SUBSYS_109C1462&REV_B5\3&11583659&1&E3
Name: Atheros AR9285 Wireless Network Adapter
Device ID: PCI\VEN_168C&DEV_002B&SUBSYS_10891A3B&REV_01\4&11DD1821&0&00E1
Driver: n/a
Name: Intel(R) HM65 Express Chipset Family LPC Interface Controller - 1C49
Device ID: PCI\VEN_8086&DEV_1C49&SUBSYS_109C1462&REV_05\3&11583659&1&F8
Driver: C:\windows\system32\DRIVERS\msisadrv.sys, 6.01.7600.16385 (English), 7/14/2009 02:48:27, 15424 bytes
Name: Intel(R) 6 Series/C200 Series Chipset Family PCI Express Root Port 2 - 1C12
Device ID: PCI\VEN_8086&DEV_1C12&SUBSYS_109C1462&REV_B5\3&11583659&1&E1
Name: AZZNR2OS IDE Controller
Device ID: PCI\VEN_1103&DEV_3520&SUBSYS_675725D2&REV_01\4&5D18F2DF&0
Driver: n/a
Name: Intel(R) Management Engine Interface
Device ID: PCI\VEN_8086&DEV_1C3A&SUBSYS_109C1462&REV_04\3&11583659&1&B0
Driver: n/a
Name: Intel(R) 6 Series/C200 Series Chipset Family PCI Express Root Port 1 - 1C10
Device ID: PCI\VEN_8086&DEV_1C10&SUBSYS_109C1462&REV_B5\3&11583659&1&E0
Name: NVIDIA GeForce GT 520M
Device ID: PCI\VEN_10DE&DEV_0DED&SUBSYS_109C1462&REV_A1\4&1D47F2D0&0&0008
Driver: C:\Program Files\NVIDIA Corporation\Drs\dbInstaller.exe, 8.17.0012.6901 (English), 6/26/2011 05:07:00, 191080 bytes
Driver: C:\Program Files\NVIDIA Corporation\Drs\nvdrsdb.bin, 6/26/2011 05:07:00, 289320 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvmi.inf_amd64_neutral_af9fb9dfe69eca04\NvCplSetupInt.exe, 14.00.0000.0162 (English), 6/26/2011 05:07:00, 56392952 bytes
Driver: C:\Program Files (x86)\NVIDIA Corporation\coprocmanager\Nvd3d9wrap.dll, 8.17.0012.6901 (English), 6/26/2011 05:07:00, 231528 bytes
Driver: C:\Program Files (x86)\NVIDIA Corporation\coprocmanager\detoured.dll, 12/24/2010 01:26:00, 4096 bytes
Driver: C:\Program Files (x86)\NVIDIA Corporation\coprocmanager\nvdxgiwrap.dll, 8.17.0012.6901 (English), 6/26/2011 05:07:00, 225384 bytes
Driver: C:\Program Files\NVIDIA Corporation\coprocmanager\Nvd3d9wrapx.dll, 8.17.0012.6901 (English), 6/26/2011 05:07:00, 256512 bytes
Driver: C:\Program Files\NVIDIA Corporation\coprocmanager\detoured.dll, 12/24/2010 01:26:00, 4096 bytes
Driver: C:\Program Files\NVIDIA Corporation\coprocmanager\nvdxgiwrapx.dll, 8.17.0012.6901 (English), 6/26/2011 05:07:00, 249856 bytes
Driver: C:\Program Files\NVIDIA Corporation\license.txt, 12/24/2010 01:26:00, 15511 bytes
Driver: C:\Program Files\NVIDIA Corporation\NVSMI\nvidia-smi.exe, 6/26/2011 05:07:00, 196200 bytes
Driver: C:\windows\system32\DRIVERS\nvBridge.kmd, 8.17.0012.6901 (English), 6/26/2011 05:07:00, 11240 bytes
Driver: C:\windows\system32\DRIVERS\nvlddmkm.sys, 8.17.0012.6901 (English), 6/26/2011 05:07:00, 13081064 bytes
Driver: C:\windows\system32\DRIVERS\nvpciflt.sys, 8.17.0012.6901 (English), 6/26/2011 05:07:00, 25960 bytes
Driver: C:\windows\system32\OpenCL.dll, 1.00.0000.0000 (English), 6/26/2011 05:07:00, 67176 bytes
Driver: C:\windows\system32\nvapi64.dll, 8.17.0012.6901 (English), 6/26/2011 05:07:00, 2209384 bytes
Driver: C:\windows\system32\nvcompiler.dll, 8.17.0012.6901 (English), 6/26/2011 05:07:00, 18580072 bytes
Driver: C:\windows\system32\nvcuda.dll, 8.17.0012.6901 (English), 6/26/2011 05:07:00, 6597736 bytes
Driver: C:\windows\system32\nvcuvenc.dll, 6.14.0012.6901 (English), 6/26/2011 05:07:00, 2871400 bytes
Driver: C:\windows\system32\nvcuvid.dll, 8.17.0012.6901 (English), 6/26/2011 05:07:00, 3182184 bytes
Driver: C:\windows\system32\nvd3dumx.dll, 8.17.0012.6901 (English), 6/26/2011 05:07:00, 12842600 bytes
Driver: C:\windows\system32\nvdecodemft.dll, 8.17.0012.6901 (English), 6/26/2011 05:07:00, 391784 bytes
Driver: C:\windows\system32\nvinfo.pb, 6/26/2011 05:07:00, 7621 bytes
Driver: C:\windows\system32\nvinitx.dll, 8.17.0012.6901 (English), 6/26/2011 05:07:00, 226920 bytes
Driver: C:\windows\system32\nvoglv64.dll, 8.17.0012.6901 (English), 6/26/2011 05:07:00, 20465768 bytes
Driver: C:\windows\system32\nvoptimusmft.dll, 8.17.0012.6901 (English), 6/26/2011 05:07:00, 446056 bytes
Driver: C:\windows\system32\nvumdshimx.dll, 8.17.0012.6901 (English), 6/26/2011 05:07:00, 764008 bytes
Driver: C:\windows\system32\nvwgf2umx.dll, 8.17.0012.6901 (English), 6/26/2011 05:07:00, 8106088 bytes
Driver: C:\windows\SysWow64\OpenCL.dll, 1.00.0000.0000 (English), 6/26/2011 05:07:00, 57960 bytes
Driver: C:\windows\SysWow64\nvapi.dll, 8.17.0012.6901 (English), 6/26/2011 05:07:00, 1971816 bytes
Driver: C:\windows\SysWow64\nvcompiler.dll, 8.17.0012.6901 (English), 6/26/2011 05:07:00, 13011560 bytes
Driver: C:\windows\SysWow64\nvcuda.dll, 8.17.0012.6901 (English), 6/26/2011 05:07:00, 4936808 bytes
Driver: C:\windows\SysWow64\nvcuvenc.dll, 6.14.0012.6901 (English), 6/26/2011 05:07:00, 2579560 bytes
Driver: C:\windows\SysWow64\nvcuvid.dll, 8.17.0012.6901 (English), 6/26/2011 05:07:00, 2954856 bytes
Driver: C:\windows\SysWow64\nvd3dum.dll, 8.17.0012.6901 (English), 6/26/2011 05:07:00, 10061416 bytes
Driver: C:\windows\SysWow64\nvdecodemft.dll, 8.17.0012.6901 (English), 6/26/2011 05:07:00, 320104 bytes
Driver: C:\windows\SysWow64\nvinit.dll, 8.17.0012.6901 (English), 6/26/2011 05:07:00, 193128 bytes
Driver: C:\windows\SysWow64\nvoglv32.dll, 8.17.0012.6901 (English), 6/26/2011 05:07:00, 15051368 bytes
Driver: C:\windows\SysWow64\nvoptimusmft.dll, 8.17.0012.6901 (English), 6/26/2011 05:07:00, 380520 bytes
Driver: C:\windows\SysWow64\nvumdshim.dll, 8.17.0012.6901 (English), 6/26/2011 05:07:00, 645736 bytes
Driver: C:\windows\SysWow64\nvwgf2um.dll, 8.17.0012.6901 (English), 6/26/2011 05:07:00, 6029928 bytes
Driver: C:\windows\system32\nvdispco6420142.dll, 2.00.0014.0002 (English), 6/26/2011 05:07:00, 1646696 bytes
Driver: C:\windows\system32\nvgenco642062.dll, 2.00.0006.0002 (English), 6/26/2011 05:07:00, 1394280 bytes
Name: Intel(R) 6 Series/C200 Series Chipset Family USB Enhanced Host Controller - 1C2D
Device ID: PCI\VEN_8086&DEV_1C2D&SUBSYS_109C1462&REV_05\3&11583659&1&D0
Driver: C:\windows\system32\drivers\usbehci.sys, 6.01.7600.16385 (English), 7/14/2009 01:06:30, 51200 bytes
Driver: C:\windows\system32\drivers\usbport.sys, 6.01.7600.16385 (German), 7/14/2009 01:06:31, 324608 bytes
Driver: C:\windows\system32\drivers\usbhub.sys, 6.01.7600.16385 (German), 7/14/2009 01:07:09, 343040 bytes
Name: Intel(R) Mobile Express Chipset SATA AHCI Controller
Device ID: PCI\VEN_8086&DEV_1C03&SUBSYS_109C1462&REV_05\3&11583659&1&FA
Driver: C:\windows\system32\DRIVERS\iaStor.sys, 10.00.0000.1046 (English), 9/13/2010 11:24:26, 437272 bytes
Name: Renesas Electronics USB 3.0 Host Controller
Device ID: PCI\VEN_1033&DEV_0194&SUBSYS_109C1462&REV_04\4&D51A89F&0&00E3
Driver: C:\windows\system32\DRIVERS\nusb3xhc.sys, 2.00.0020.0000 (English), 7/27/2010 02:45:46, 180224 bytes
Name: Intel(R) 6 Series/C200 Series Chipset Family USB Enhanced Host Controller - 1C26
Device ID: PCI\VEN_8086&DEV_1C26&SUBSYS_109C1462&REV_05\3&11583659&1&E8
Name: Intel(R) HD Graphics Family
Device ID: PCI\VEN_8086&DEV_0116&SUBSYS_109C1462&REV_09\3&11583659&1&10
Driver: C:\windows\system32\DRIVERS\igdkmd64.sys, 8.15.0010.2372 (English), 4/15/2011 19:08:27, 12228128 bytes
Driver: C:\windows\system32\igdumd64.dll, 8.15.0010.2372 (English), 4/15/2011 19:07:51, 8244224 bytes
Driver: C:\windows\system32\igd10umd64.dll, 8.15.0010.2372 (English), 4/15/2011 18:54:37, 14520832 bytes
Driver: C:\windows\system32\igfxcmrt64.dll, 1.00.0000.1007 (English), 4/15/2011 18:16:09, 136704 bytes
Driver: C:\windows\system32\IccLibDll_x64.dll, 12/16/2010 09:37:54, 94208 bytes
Driver: C:\windows\system32\igkrng600.bin, 4/15/2011 19:05:49, 963116 bytes
Driver: C:\windows\system32\igcompkrng600.bin, 12/16/2010 10:37:18, 145804 bytes
Driver: C:\windows\system32\igfcg600m.bin, 4/15/2011 19:05:50, 218304 bytes
Driver: C:\windows\SysWow64\igkrng600.bin, 4/15/2011 19:05:49, 963116 bytes
Driver: C:\windows\SysWow64\igcompkrng600.bin, 12/16/2010 10:37:18, 145804 bytes
Driver: C:\windows\SysWow64\igfcg600m.bin, 4/15/2011 19:05:50, 218304 bytes
Driver: C:\windows\system32\igdde64.dll, 4/15/2011 19:05:45, 75776 bytes
Driver: C:\windows\SysWow64\igdde32.dll, 4/15/2011 18:59:48, 56832 bytes
Driver: C:\windows\system32\iglhxs64.vp, 4/15/2011 19:38:10, 17220 bytes
Driver: C:\windows\system32\iglhxo64.vp, 4/15/2011 18:16:07, 59243 bytes
Driver: C:\windows\system32\iglhxc64.vp, 4/15/2011 18:16:07, 59062 bytes
Driver: C:\windows\system32\iglhxg64.vp, 4/15/2011 18:16:08, 59174 bytes
Driver: C:\windows\system32\iglhxa64.vp, 4/15/2011 18:16:08, 1074 bytes
Driver: C:\windows\system32\iglhxa64.cpa, 4/15/2011 18:16:07, 1981696 bytes
Driver: C:\windows\system32\iglhcp64.dll, 2.00.0002.0001 (English), 4/15/2011 18:16:08, 98304 bytes
Driver: C:\windows\system32\iglhsip64.dll, 2.00.0002.0001 (English), 4/15/2011 18:16:08, 376832 bytes
Driver: C:\windows\SysWow64\igdumd32.dll, 8.15.0010.2372 (English), 4/15/2011 19:01:51, 6278656 bytes
Driver: C:\windows\SysWow64\igdumdx32.dll, 8.15.0010.2372 (English), 4/15/2011 18:58:12, 577024 bytes
Driver: C:\windows\SysWow64\igfxdv32.dll, 8.15.0010.2372 (English), 4/15/2011 18:22:32, 288768 bytes
Driver: C:\windows\SysWow64\igd10umd32.dll, 8.15.0010.2372 (English), 4/15/2011 18:48:13, 12297216 bytes
Driver: C:\windows\SysWow64\iglhcp32.dll, 2.00.0002.0001 (English), 4/15/2011 18:16:07, 98304 bytes
Driver: C:\windows\SysWow64\iglhsip32.dll, 2.00.0002.0001 (English), 4/15/2011 18:16:07, 376832 bytes
Driver: C:\windows\SysWow64\igfxcmrt32.dll, 1.00.0000.1007 (English), 4/15/2011 18:16:09, 158208 bytes
Driver: C:\windows\system32\difx64.exe, 4/21/2011 00:32:26, 179992 bytes
Driver: C:\windows\system32\hccutils.dll, 8.15.0010.2372 (English), 4/15/2011 18:27:58, 109056 bytes
Driver: C:\windows\system32\igfxsrvc.dll, 8.15.0010.2372 (English), 4/15/2011 18:28:27, 62464 bytes
Driver: C:\windows\system32\igfxsrvc.exe, 8.15.0010.2372 (English), 4/21/2011 00:32:43, 510232 bytes
Driver: C:\windows\system32\igfxpph.dll, 8.15.0010.2372 (English), 4/15/2011 18:28:48, 335872 bytes
Driver: C:\windows\system32\igfxcpl.cpl, 8.15.0010.2372 (English), 4/15/2011 18:29:13, 126976 bytes
Driver: C:\windows\system32\igfxdev.dll, 8.15.0010.2372 (English), 4/15/2011 18:27:49, 385024 bytes
Driver: C:\windows\system32\igfxdo.dll, 8.15.0010.2372 (English), 4/15/2011 18:27:09, 142336 bytes
Driver: C:\windows\system32\igfxtray.exe, 8.15.0010.2372 (English), 4/21/2011 00:32:47, 168216 bytes
Driver: C:\windows\system32\hkcmd.exe, 8.15.0010.2372 (English), 4/21/2011 00:32:31, 392472 bytes
Driver: C:\windows\system32\igfxress.dll, 8.15.0010.2372 (English), 4/15/2011 18:27:09, 9014784 bytes
Driver: C:\windows\system32\igfxpers.exe, 8.15.0010.2372 (English), 4/21/2011 00:32:39, 416024 bytes
Driver: C:\windows\system32\igfxTMM.dll, 8.15.0010.2372 (English), 4/15/2011 18:28:45, 378368 bytes
Driver: C:\windows\system32\gfxSrvc.dll, 8.15.0010.2372 (German), 4/15/2011 18:27:50, 146432 bytes
Driver: C:\windows\system32\GfxUI.exe, 8.15.0010.2372 (German), 4/21/2011 00:32:29, 4378392 bytes
Driver: C:\windows\system32\GfxUI.exe.config, 12/16/2010 09:40:50, 151 bytes
Driver: C:\windows\system32\IGFXDEVLib.dll, 1.00.0000.0000 (Invariant Language), 4/15/2011 18:27:49, 4096 bytes
Driver: C:\windows\system32\igfxext.exe, 8.15.0010.2372 (English), 4/21/2011 00:32:35, 239384 bytes
Driver: C:\windows\system32\igfxexps.dll, 8.15.0010.2372 (English), 4/15/2011 18:28:47, 28672 bytes
Driver: C:\windows\SysWow64\igfxexps32.dll, 8.15.0010.2372 (English), 4/15/2011 18:23:18, 24576 bytes
Driver: C:\windows\system32\igfxrara.lrc, 8.15.0010.2372 (English), 4/15/2011 18:29:16, 285184 bytes
Driver: C:\windows\system32\igfxrchs.lrc, 8.15.0010.2372 (English), 4/15/2011 18:29:16, 282624 bytes
Driver: C:\windows\system32\igfxrcht.lrc, 8.15.0010.2372 (English), 4/15/2011 18:29:17, 282624 bytes
Driver: C:\windows\system32\igfxrdan.lrc, 8.15.0010.2372 (English), 4/15/2011 18:29:18, 285696 bytes
Driver: C:\windows\system32\igfxrdeu.lrc, 8.15.0010.2372 (English), 4/15/2011 18:29:20, 286720 bytes
Driver: C:\windows\system32\igfxrenu.lrc, 8.15.0010.2372 (English), 4/15/2011 18:27:16, 285696 bytes
Driver: C:\windows\system32\igfxresn.lrc, 8.15.0010.2372 (English), 4/15/2011 18:29:28, 287232 bytes
Driver: C:\windows\system32\igfxrfin.lrc, 8.15.0010.2372 (English), 4/15/2011 18:29:19, 286208 bytes
Driver: C:\windows\system32\igfxrfra.lrc, 8.15.0010.2372 (English), 4/15/2011 18:29:20, 287232 bytes
Driver: C:\windows\system32\igfxrheb.lrc, 8.15.0010.2372 (English), 4/15/2011 18:29:22, 285184 bytes
Driver: C:\windows\system32\igfxrhrv.lrc, 8.15.0010.2372 (English), 4/15/2011 18:29:32, 286720 bytes
Driver: C:\windows\system32\igfxrita.lrc, 8.15.0010.2372 (English), 4/15/2011 18:29:23, 286720 bytes
Driver: C:\windows\system32\igfxrjpn.lrc, 8.15.0010.2372 (English), 4/15/2011 18:29:23, 283648 bytes
Driver: C:\windows\system32\igfxrkor.lrc, 8.15.0010.2372 (English), 4/15/2011 18:29:24, 283136 bytes
Driver: C:\windows\system32\igfxrnld.lrc, 8.15.0010.2372 (English), 4/15/2011 18:29:19, 286720 bytes
Driver: C:\windows\system32\igfxrnor.lrc, 8.15.0010.2372 (English), 4/15/2011 18:29:25, 286208 bytes
Driver: C:\windows\system32\igfxrplk.lrc, 8.15.0010.2372 (English), 4/15/2011 18:29:25, 286720 bytes
Driver: C:\windows\system32\igfxrptb.lrc, 8.15.0010.2372 (English), 4/15/2011 18:29:26, 286208 bytes
Driver: C:\windows\system32\igfxrptg.lrc, 8.15.0010.2372 (English), 4/15/2011 18:29:26, 286720 bytes
Driver: C:\windows\system32\igfxrrom.lrc, 8.15.0010.2372 (English), 4/15/2011 18:29:32, 286720 bytes
Driver: C:\windows\system32\igfxrrus.lrc, 8.15.0010.2372 (English), 4/15/2011 18:29:27, 286720 bytes
Driver: C:\windows\system32\igfxrsky.lrc, 8.15.0010.2372 (English), 4/15/2011 18:29:31, 286720 bytes
Driver: C:\windows\system32\igfxrslv.lrc, 8.15.0010.2372 (English), 4/15/2011 18:29:31, 286208 bytes
Driver: C:\windows\system32\igfxrsve.lrc, 8.15.0010.2372 (English), 4/15/2011 18:29:29, 286208 bytes
Driver: C:\windows\system32\igfxrtha.lrc, 8.15.0010.2372 (English), 4/15/2011 18:29:29, 285696 bytes
Driver: C:\windows\system32\igfxrcsy.lrc, 8.15.0010.2372 (English), 4/15/2011 18:29:18, 286720 bytes
Driver: C:\windows\system32\igfxrell.lrc, 8.15.0010.2372 (English), 4/15/2011 18:29:21, 287232 bytes
Driver: C:\windows\system32\igfxrhun.lrc, 8.15.0010.2372 (English), 4/15/2011 18:29:22, 286208 bytes
Driver: C:\windows\system32\igfxrtrk.lrc, 8.15.0010.2372 (English), 4/15/2011 18:29:30, 286208 bytes
Driver: C:\windows\system32\Gfxres.ar-SA.resources, 4/15/2011 18:29:34, 156057 bytes
Driver: C:\windows\system32\Gfxres.cs-CZ.resources, 4/15/2011 18:29:35, 133246 bytes
Driver: C:\windows\system32\Gfxres.da-DK.resources, 4/15/2011 18:29:36, 128407 bytes
Driver: C:\windows\system32\Gfxres.de-DE.resources, 4/15/2011 18:29:38, 137705 bytes
Driver: C:\windows\system32\Gfxres.el-GR.resources, 4/15/2011 18:29:39, 197902 bytes
Driver: C:\windows\system32\Gfxres.es-ES.resources, 4/15/2011 18:29:40, 137506 bytes
Driver: C:\windows\system32\Gfxres.en-US.resources, 4/15/2011 18:29:15, 123921 bytes
Driver: C:\windows\system32\Gfxres.fi-FI.resources, 4/15/2011 18:29:42, 132752 bytes
Driver: C:\windows\system32\Gfxres.fr-FR.resources, 4/15/2011 18:29:43, 135519 bytes
Driver: C:\windows\system32\Gfxres.he-IL.resources, 4/15/2011 18:29:44, 148846 bytes
Driver: C:\windows\system32\Gfxres.hr-HR.resources, 4/15/2011 18:30:08, 131705 bytes
Driver: C:\windows\system32\Gfxres.hu-HU.resources, 4/15/2011 18:29:45, 134238 bytes
Driver: C:\windows\system32\Gfxres.it-IT.resources, 4/15/2011 18:29:47, 140077 bytes
Driver: C:\windows\system32\Gfxres.ja-JP.resources, 4/15/2011 18:29:48, 152994 bytes
Driver: C:\windows\system32\Gfxres.ko-KR.resources, 4/15/2011 18:29:49, 138572 bytes
Driver: C:\windows\system32\Gfxres.nb-NO.resources, 4/15/2011 18:29:51, 128667 bytes
Driver: C:\windows\system32\Gfxres.nl-NL.resources, 4/15/2011 18:29:52, 134272 bytes
Driver: C:\windows\system32\Gfxres.pl-PL.resources, 4/15/2011 18:29:53, 133014 bytes
Driver: C:\windows\system32\Gfxres.pt-BR.resources, 4/15/2011 18:29:55, 134686 bytes
Driver: C:\windows\system32\Gfxres.pt-PT.resources, 4/15/2011 18:29:56, 133548 bytes
Driver: C:\windows\system32\Gfxres.ro-RO.resources, 4/15/2011 18:30:09, 136449 bytes
Driver: C:\windows\system32\Gfxres.ru-RU.resources, 4/15/2011 18:29:57, 182514 bytes
Driver: C:\windows\system32\Gfxres.sk-SK.resources, 4/15/2011 18:29:59, 132650 bytes
Driver: C:\windows\system32\Gfxres.sl-SI.resources, 4/15/2011 18:30:00, 128863 bytes
Driver: C:\windows\system32\Gfxres.sv-SE.resources, 4/15/2011 18:30:01, 133706 bytes
Driver: C:\windows\system32\Gfxres.th-TH.resources, 4/15/2011 18:30:03, 211082 bytes
Driver: C:\windows\system32\Gfxres.tr-TR.resources, 4/15/2011 18:30:04, 135222 bytes
Driver: C:\windows\system32\Gfxres.zh-CN.resources, 4/15/2011 18:30:05, 116233 bytes
Driver: C:\windows\system32\Gfxres.zh-TW.resources, 4/15/2011 18:30:07, 117522 bytes
Driver: C:\windows\system32\ig4icd64.dll, 8.15.0010.2372 (English), 4/15/2011 18:40:42, 17901568 bytes
Driver: C:\windows\SysWow64\ig4icd32.dll, 4/15/2011 18:33:41, 13359616 bytes
Driver: C:\windows\system32\igfxCoIn_v2372.dll, 1.02.0030.0000 (English), 4/15/2011 19:14:21, 90112 bytes
Name: Intel(R) 6 Series/C200 Series Chipset Family SMBus Controller - 1C22
Device ID: PCI\VEN_8086&DEV_1C22&SUBSYS_109C1462&REV_05\3&11583659&1&FB
Driver: n/a
Name: 2nd Generation Intel(R) Core(TM) Processor Family DRAM Controller - 0104
Device ID: PCI\VEN_8086&DEV_0104&SUBSYS_109C1462&REV_09\3&11583659&1&00
Driver: n/a
DirectShow Filters
DirectShow Filters:
WMAudio Decoder DMO,0x00800800,1,1,WMADMOD.DLL,6.01.7600.16385
WMAPro over S/PDIF DMO,0x00600800,1,1,WMADMOD.DLL,6.01.7600.16385
WMSpeech Decoder DMO,0x00600800,1,1,WMSPDMOD.DLL,6.01.7600.16385
MP3 Decoder DMO,0x00600800,1,1,mp3dmod.dll,6.01.7600.16385
Mpeg4s Decoder DMO,0x00800001,1,1,mp4sdecd.dll,6.01.7600.16385
WMV Screen decoder DMO,0x00600800,1,1,wmvsdecd.dll,6.01.7600.16385
WMVideo Decoder DMO,0x00800001,1,1,wmvdecod.dll,6.01.7600.16385
Mpeg43 Decoder DMO,0x00800001,1,1,mp43decd.dll,6.01.7600.16385
Mpeg4 Decoder DMO,0x00800001,1,1,mpg4decd.dll,6.01.7600.16385
DV Muxer,0x00400000,0,0,qdv.dll,6.06.7600.16385
Color Space Converter,0x00400001,1,1,quartz.dll,6.06.7600.16490
WM ASF Reader,0x00400000,0,0,qasf.dll,12.00.7600.16385
AVI Splitter,0x00600000,1,1,quartz.dll,6.06.7600.16490
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.06.7600.16490
SBE2MediaTypeProfile,0x00200000,0,0,sbe.dll,6.06.7600.16385
Microsoft DTV-DVD Video Decoder,0x005fffff,2,4,msmpeg2vdec.dll,6.01.7140.0000
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.06.7600.16648
StreamBufferSink,0x00200000,0,0,sbe.dll,6.06.7600.16385
MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.06.7600.16490
MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.06.7600.16490
SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.06.7600.16490
VBI Codec,0x00600000,1,4,VBICodec.ax,6.06.7600.16385
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.06.7600.16648
Closed Captions Analysis Filter,0x00200000,2,5,cca.dll,6.06.7600.16385
SBE2FileScan,0x00200000,0,0,sbe.dll,6.06.7600.16385
Microsoft MPEG-2 Video Encoder,0x00200000,1,1,msmpeg2enc.dll,6.01.7600.16385
Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.06.7600.16490
MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.06.7600.16490
DV Splitter,0x00600000,1,2,qdv.dll,6.06.7600.16385
Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,6.06.7600.16490
Microsoft MPEG-2 Encoder,0x00200000,2,1,msmpeg2enc.dll,6.01.7600.16385
ACM Wrapper,0x00600000,1,1,quartz.dll,6.06.7600.16490
Video Renderer,0x00800001,1,0,quartz.dll,6.06.7600.16490
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,6.06.7600.16385
Line 21 Decoder,0x00600000,1,1,,
Video Port Manager,0x00600000,2,1,quartz.dll,6.06.7600.16490
Video Renderer,0x00400000,1,0,quartz.dll,6.06.7600.16490
VPS Decoder,0x00200000,0,0,WSTPager.ax,6.06.7600.16385
WM ASF Writer,0x00400000,0,0,qasf.dll,12.00.7600.16385
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,6.01.7600.16385
File writer,0x00200000,1,0,qcap.dll,6.06.7600.16385
DVD Navigator,0x00200000,0,3,qdvd.dll,6.06.7600.16385
Overlay Mixer2,0x00200000,1,1,,
RDP DShow Redirection Filter,0xffffffff,1,0,DShowRdpFilter.dll,
Microsoft MPEG-2 Audio Encoder,0x00200000,1,1,msmpeg2enc.dll,6.01.7600.16385
WST Pager,0x00200000,1,1,WSTPager.ax,6.06.7600.16385
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.06.7600.16648
DV Video Decoder,0x00800000,1,1,qdv.dll,6.06.7600.16385
SampleGrabber,0x00200000,1,1,qedit.dll,6.06.7600.16385
Null Renderer,0x00200000,1,0,qedit.dll,6.06.7600.16385
MPEG-2 Sections and Tables,0x005fffff,1,0,Mpeg2Data.ax,6.06.7600.16385
Microsoft AC3 Encoder,0x00200000,1,1,msac3enc.dll,6.01.7600.16385
StreamBufferSource,0x00200000,0,0,sbe.dll,6.06.7600.16385
Smart Tee,0x00200000,1,2,qcap.dll,6.06.7600.16385
Overlay Mixer,0x00200000,0,0,,
AVI Decompressor,0x00600000,1,1,quartz.dll,6.06.7600.16490
AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.06.7600.16490
Wave Parser,0x00400000,1,1,quartz.dll,6.06.7600.16490
MIDI Parser,0x00400000,1,1,quartz.dll,6.06.7600.16490
Multi-file Parser,0x00400000,1,1,quartz.dll,6.06.7600.16490
File stream renderer,0x00400000,1,1,quartz.dll,6.06.7600.16490
Microsoft DTV-DVD Audio Decoder,0x005fffff,1,1,msmpeg2adec.dll,6.01.7140.0000
StreamBufferSink2,0x00200000,0,0,sbe.dll,6.06.7600.16385
AVI Mux,0x00200000,1,0,qcap.dll,6.06.7600.16385
Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.06.7600.16490
File Source (Async.),0x00400000,0,1,quartz.dll,6.06.7600.16490
File Source (URL),0x00400000,0,1,quartz.dll,6.06.7600.16490
AudioRecorder WAV Dest,0x00200000,0,0,WavDest.dll,
AudioRecorder Wave Form,0x00200000,0,0,WavDest.dll,
SoundRecorder Null Renderer,0x00200000,0,0,WavDest.dll,
Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.06.7600.16385
Enhanced Video Renderer,0x00200000,1,0,evr.dll,6.01.7600.16385
BDA MPEG2 Transport Information Filter,0x00200000,2,0,psisrndr.ax,6.06.7600.16385
MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.06.7600.16490
WDM Streaming Tee/Splitter Devices:
Tee/Sink-to-Sink-Konvertierung,0x00200000,1,1,ksproxy.ax,6.01.7600.16385
Video Compressors:
WMVideo8 Encoder DMO,0x00600800,1,1,wmvxencd.dll,6.01.7600.16385
WMVideo9 Encoder DMO,0x00600800,1,1,wmvencod.dll,6.01.7600.16385
MSScreen 9 encoder DMO,0x00600800,1,1,wmvsencd.dll,6.01.7600.16385
DV Video Encoder,0x00200000,0,0,qdv.dll,6.06.7600.16385
MJPEG Compressor,0x00200000,0,0,quartz.dll,6.06.7600.16490
Audio Compressors:
WM Speech Encoder DMO,0x00600800,1,1,WMSPDMOE.DLL,6.01.7600.16385
WMAudio Encoder DMO,0x00600800,1,1,WMADMOE.DLL,6.01.7600.16385
IMA ADPCM,0x00200000,1,1,quartz.dll,6.06.7600.16490
Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.06.7600.16490
GSM 6.10,0x00200000,1,1,quartz.dll,6.06.7600.16490
CCITT A-Law,0x00200000,1,1,quartz.dll,6.06.7600.16490
CCITT u-Law,0x00200000,1,1,quartz.dll,6.06.7600.16490
MPEG Layer-3,0x00200000,1,1,quartz.dll,6.06.7600.16490
Audio Capture Sources:
Internal Microphone (Conexant S,0x00200000,0,0,qcap.dll,6.06.7600.16385
PBDA CP Filters:
PBDA DTFilter,0x00600000,1,1,CPFilters.dll,6.06.7600.16648
PBDA ETFilter,0x00200000,0,0,CPFilters.dll,6.06.7600.16648
PBDA PTFilter,0x00200000,0,0,CPFilters.dll,6.06.7600.16648
Midi Renderers:
Default MidiOut Device,0x00800000,1,0,quartz.dll,6.06.7600.16490
Microsoft GS Wavetable Synth,0x00200000,1,0,quartz.dll,6.06.7600.16490
WDM Streaming Capture Devices:
Conexant HD Audio capture,0x00200000,1,1,ksproxy.ax,6.01.7600.16385
,0x00000000,0,0,,
,0x00000000,0,0,,
USB2.0 UVC 1.3M Webcam,0x00200000,1,2,ksproxy.ax,6.01.7600.16385
WDM Streaming Rendering Devices:
,0x00000000,0,0,,
,0x00000000,0,0,,
,0x00000000,0,0,,
Conexant HD Audio headphone,0x00200000,1,1,ksproxy.ax,6.01.7600.16385
Conexant HD Audio output,0x00200000,1,1,ksproxy.ax,6.01.7600.16385
BDA Network Providers:
Microsoft ATSC Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7600.16385
Microsoft DVBC Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7600.16385
Microsoft DVBS Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7600.16385
Microsoft DVBT Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7600.16385
Microsoft Network Provider,0x00200000,0,1,MSNP.ax,6.06.7600.16648
Video Capture Sources:
Multi-Instance Capable VBI Codecs:
BDA Transport Information Renderers:
BDA MPEG2 Transport Information Filter,0x00600000,2,0,psisrndr.ax,6.06.7600.16385
MPEG-2 Sections and Tables,0x00600000,1,0,Mpeg2Data.ax,6.06.7600.16385
BDA CP/CA Filters:
Decrypt/Tag,0x00600000,1,1,EncDec.dll,6.06.7600.16385
Encrypt/Tag,0x00200000,0,0,EncDec.dll,6.06.7600.16385
PTFilter,0x00200000,0,0,EncDec.dll,6.06.7600.16385
XDS Codec,0x00200000,0,0,EncDec.dll,6.06.7600.16385
WDM Streaming Communication Transforms:
Audio Renderers:
Speakers (Conexant SmartAudio H,0x00200000,1,0,quartz.dll,6.06.7600.16490
Default DirectSound Device,0x00800000,1,0,quartz.dll,6.06.7600.16490
Default WaveOut Device,0x00200000,1,0,quartz.dll,6.06.7600.16490
DirectSound: Speakers (Conexant SmartAudio HD),0x00200000,1,0,quartz.dll,6.06.7600.16490
EVR Power Information
Current Setting: {5C67A112-A4C9-483F-B4A7-1D473BECAFDC} (Quality)
Quality Flags: 2576
Enabled:
Force throttling
Allow half deinterlace
Allow scaling
Decode Power Usage: 100
Balanced Flags: 1424
Enabled:
Force throttling
Allow batching
Force half deinterlace
Force scaling
Decode Power Usage: 50
PowerFlags: 1424
Enabled:
Force throttling
Allow batching
Force scaling
Decode Power Usage: 0
I didn't try Firefox, this was Google Chrome. The only other browser I
tried was Explorer. I'll try Firefox and see what happens, and update my
drivers. Thanks
