2 Replies Latest reply on Feb 26, 2008 12:26 PM by KenBrower
    Updating bindable property in class doesn't cause the control to update
    KenBrower
      I am having a problem with databinding. When I update a property in a class that has controls bound to it, those controls are not refreshing their display value with the new property value automatically, and I don't know how to force them to do it.
      Here's the how I have the ActionScript class set up:
      [Bindable] private var __dataSource:String;
      The getter/setter is declared as the following:
      [Bindable] public function get dataSource():String{
      return __dataSource;
      public function set dataSource(dataSource:String):void{
      __dataSource = dataSource;
      So I have an mxml application with the following variable declaration to this ActionScript class:
      [Bindable] private var __reportDefinition:ReportDefinition;
      The text control in the mxml is defined like this:
      <mx:TextInput id="txtReportTitle" text="{__reportDefinition.dataSource}" styleName="textInputStyle" width="259"/>
      Ok, going back to the ActionScript class, I have a function that executes the following line:
      __dataSource = "SomeValue";
      After that line is executed, the text input is not refreshed. I have verified that the text input control is bound to the correct instance of the action script object.
      Any hints? Thanks
