Howdy All,
I have created a form in LiveCycle ES2 - I added an image object field which works perfectly when you preview in LiveCycle. When the PDF Form is opened in Acrobat the field allows you to click and select your image, however the image does not display. I have tried different image formats (jpg, png, gif) and all work in the LC preview mode - but none are visible when uploaded in Acrobat. Any ideas?
if the image field works in the preview it should also work with a form opened in Acrobat.
The only thing the image doesn't support are images in CMYK-colors or color spaces above 8 Bit.
Check your form on another system to see how it behaves there.
I believe this is a problem of your Acrobat.
