1 Reply Latest reply on Oct 22, 2012 7:07 PM by Peter Spier
    Placing a PDF and it doesn't place the entire document
    tiffanylea
      I feel like there must be a really simple solution to this, but occasionally I will export an InDesign document as a PDF, and if I open the PDF I see the entire document. But then if I go to place the PDF in an InDesign document, the object only shows the portion of the PDF that has elements on it. Any white space is cut. Every time this happens, I end up putting a blank white box behind the original .indd file just to fill the entire document so that when I export it and then place that PDF, InDesign will then recognize the entire document. Is there an easier way to fix this?
