5 Replies Latest reply on Oct 23, 2012 3:05 PM by kglad
    Crosshair not over enemies, sound delayed?
    gabessdsp Level 1
      That is where you can see and listen to exampels of my problem. When you start off there's a good couple of seconds before the music starts for the title and after you hit play. When you fire a bullet there's a very minute but noticable pause before you hear the gunshot go off as well. How can I fix that problem? this is what I'm doing with my sounds:
      var gameSounds:Sound = new Sound(new URLRequest("inGame.mp3"));
      and how come the crosshair won;t fire if it's located above a bullet object, and for some reason it's hidden behind the enemies and won;t fire if under them either. Here is my main code for that frame(take note I am using classes but there is nothing in the classes file yet):
      var gunShotSound:Sound = new Sound(new URLRequest("gunshot.mp3"));
      import flash.events.MouseEvent;
      import flash.display.MovieClip;
      import flash.geom.Point;
      main_crosshair.addEventListener(MouseEvent.MOUSE_DOWN, crosshairFX);
      function crosshairFX (e:MouseEvent):void{
                var projectile:bullet = new bullet();
                projectile.x = parent.mouseX;
                projectile.y = parent.mouseY;
      for (var i = 0; i < 10; i++){
                var enemies:enemy = new enemy();
                enemies.x = stage.stageWidth * Math.random();
                enemies.y = stage.stageHeight * Math.random();
