6 Replies Latest reply on Oct 23, 2012 11:06 PM by BongoBongo
    InDesign CS5 won’t launch - missing plug-ins
    BongoBongo
      InDesign CS5 won’t launch on Windows 7. I get the following error messages:
      Cannot load the LINKS.RPLN plug-in
      Cannot load the FONT USAGE DIALOG.RPLN plug-in
      Cannot load the XMEDIA UI.RPLN plug-in
      After these error messages InDesign crashes.
      Do I need to reinstall the plug-ins?
      If yes, how do I do that?
        • 1. Re: InDesign CS5 won’t launch - missing plug-ins
          Those are required plugins that should have been instaalled with the application. Did it ever run?
          I would uniinstall, run the clean tool (CS Cleaner Tool for installation problems | CCM, CS6, CS5.5, CS5, CS4, CS3) then restart Windows. Run MSconfig to turn off non-essential startup programs and services -- especially anti-virus and malware scanners, browser helpers and toolbars, iTunes and instant messengers -- then run the installer again. You can re-run MSconfig afterward to restore normal startup.
          • 2. Re: InDesign CS5 won’t launch - missing plug-ins
            BongoBongo Level 1
            Hi Peter,
            Thanks for your reply to my question. The initial installation of CS5 was quite a hassle and took a while to get done with the help of Adobe Help Centre. Got it working smooth for the last 3 months, no plug-in errors at all. However yesterday out of the blue InDesign stop working. At the beginning of your  reply you’ve mentioned to uninstall, then run CS Cleaner. Do you mean uninstall CS5. As it was a hassle to get CS5 going in the beginning I was hoping there would be another solution, such as re-installing the missing plug-ins.
            • 3. Re: InDesign CS5 won’t launch - missing plug-ins
              I did mean uninstall and reinstall the whole thing, but you can try just running the installer again without uninstalling first, and in your shoes I probably would. Youu should see an option to "repair" the original install, and you might get lucky and it will work. In theory I suppose you could copy the plugins from another machine, but I doubt it will work, and it's just masking the underlying problem.
              Don't forget to run the updater again after whatever repair/reinstall you do.
              • 4. Re: InDesign CS5 won’t launch - missing plug-ins
                BongoBongo Level 1
                I couldn't find a repair option so tried to reinstall InDesign as you've suggested. This doesen't seem to work either, as I received the following installation error:
                Exit Code: 7
                   -------------------------------------- Summary --------------------------------------
                - 1 fatal error(s), 2 error(s), 15 warning(s)
                WARNING: OS requirements not met for {694213D7-1E0E-4C8F-B822-E2E3680C0FCE}
                WARNING: OS requirements not met for {A1BC7068-C1BA-410F-8B9A-DB807C803DE2}
                WARNING: OS requirements not met for {F9766AC1-1461-1033-B862-DF8FE1C033BE}
                WARNING: Payload:{2EBE92C3-F9D8-48B5-A32B-04FA5D1709FA} Adobe XMP Panels CS5 has been updated and has been selected for repair. The patch {0061DED1-0204-44C5-B6E0-FAD6AA00E320} Adobe XMP Panels CS5_3.1_AdobeXMPPanelsAll will be uninstalled now.
                WARNING: Payload:{E995AC53-954A-48D2-A861-613B8D42A9BE} Adobe ExtendScript Toolkit CS5 has been updated and has been selected for repair. The patch {187A7A38-6DD4-4549-AECD-22BA6BC2F002} Adobe ExtendScript Toolkit CS5_3.5.0_AdobeExtendScriptToolkit3.5.0-mul will be uninstalled now.
                WARNING: Payload:{26B63C3A-0BFF-1033-B389-A7ACEC31657E} Adobe InDesign CS5 Application Language Files_AdobeInDesign7AppLang-en_GB has been updated and has been selected for repair. The patch {45B0CD86-8ED5-1014-BB61-85ABAB41C57B} Adobe InDesign CS5 Application Language Files_7.0.4.553_AdobeInDesign7AppLang-en_GB will be uninstalled now.
                WARNING: Payload:{37AB3C65-E02C-4DCF-B0E0-4C2E253D8FA3} Photoshop Camera Raw has been updated and has been selected for repair. The patch {4E1B59A1-029E-4C16-BBB3-F10D40EBB6EE} Photoshop Camera Raw_6.7_AdobeCameraRaw6.0All will be uninstalled now.
                WARNING: Payload:{2F6B67F4-A2BB-45D7-A80C-25FF646CC1C5} Adobe Player for Embedding has been updated and has been selected for repair. The patch {55516693-25E2-4620-BF94-6BA66B00419F} Adobe Player for Embedding_3.1_AdobeAPE3-mul will be uninstalled now.
                WARNING: Payload:{F9766AC1-1461-1033-B862-DF8FE1C033BE} Adobe InDesign CS5 Application Base Files has been updated and has been selected for repair. The patch {719E1C04-9031-1014-8D2D-8FA57837B53E} Adobe InDesign CS5 Application Base Files_7.0.4.553_AdobeInDesign7AppBase-mul will be uninstalled now.
                WARNING: Payload:{DEC9BB26-1381-1033-A965-E3BD5F2EF8BC} Adobe InDesign CS5 Application Base Files2 has been updated and has been selected for repair. The patch {7EF51537-90FE-1014-9767-B6100F0B1115} Adobe InDesign CS5 Application Base Files2_7.0.4.553_AdobeInDesign7AppBase2-mul will be uninstalled now.
                WARNING: Payload:{0D067D13-C3D7-4EA6-B346-740CD91FD547} Adobe Bridge CS5 has been updated and has been selected for repair. The patch {7F7421AA-3A80-49B2-B88B-611A50C23D30} Adobe Bridge CS5_4.0.5_AdobeBridge4-mul will be uninstalled now.
                WARNING: Payload:{E4E188D2-27D5-4E4C-92CE-87F9D24AD2F6} Adobe Extension Manager CS5 has been updated and has been selected for repair. The patch {9AF7B703-B806-4C74-94E5-82963EFC0188} Adobe Extension Manager CS5_5.0.1_AdobeExtensionManager5.0All will be uninstalled now.
                WARNING: Payload:{3F023875-4A52-4605-9DB6-A88D4A813E8D} Camera Profiles Installer has been updated and has been selected for repair. The patch {CC43F132-5096-41FC-A5C2-69E4202AC114} Camera Profiles Installer_6.7_AdobeCameraRawProfile6.0All will be uninstalled now.
                WARNING: Payload:{68CEA5C9-2964-4ECB-84A4-D77C511332BC} Adobe Media Encoder CS5 X64 has been updated and has been selected for repair. The patch {D8676884-2C59-41BB-B315-486D98A20867} Adobe Media Encoder CS5 X64_5.0.1_AMECore5All_x64 will be uninstalled now.
                WARNING: Payload:{02731921-5711-4E7A-A898-D6BCF0F2A1CD} Adobe CSXS Infrastructure CS5 has been updated and has been selected for repair. The patch {FA2A2592-3F40-456D-ACEC-166CB79D4F98} Adobe CSXS Infrastructure CS5_2.0.1_AdobeCSXSInfrastructure2-mul will be uninstalled now.
                ERROR: Found payload conflicts and errors:
                ERROR:  - Adobe Photoshop CS5 Core_x64 depends on Required Common Fonts Installation x64 to be installed.
                FATAL ERROR: Conflicts were found in the selected payloads. Halting installation.
                Any suggestion?????????????
                • 5. Re: InDesign CS5 won’t launch - missing plug-ins
                  Something is TERRIBLY wrong. CS5 is certainly supported on Windows 7.
                  Are you installing to the default directories? Did you run the clean tool?
                  • 6. Re: InDesign CS5 won’t launch - missing plug-ins
                    BongoBongo Level 1
                    Hi Peter,
                    Thanks for your help. I've tried a few other options and it just seems to create a few more problems.
                    It looks like the initial installation was not done correctly despite the help from Adobe Help Centre. So it looks like the best options would be to clear the HD and start form scratch.
