5 Replies Latest reply on Oct 24, 2012 7:50 AM by Paul_C_B
    Centering an animated symbol
    Paul_C_B Level 1
      I have read just about everything I can find on the subject of centering a symbol on a fluid layout and can find no solution that works for me.
      http://www.avatarea.com/blocks/
      will show you where I am at. The floating symbol which contains some 17 animated images and is 2445px wide needs to sit in the center under the banner.
      I have used this code :
      // center symbol horizontally
      sym.$("blocks").css({
         width : '2445px',
         margin : '0 auto',
         position: 'relative'
      recommended on an earlier post and it just doesnt do it.
      any suggestions would be seriously helpful.
        • 1. Re: Centering an animated symbol
          salesdigital
          aren't you trying to line the finished position of the animated blocks with your header graphic?
          try using a value of 960px for your css code - that's the width of your header
          • 2. Re: Centering an animated symbol
            Paul_C_B Level 1
            Hi Salesdigital, Well see I have several pages which need to work this way. The animation ( this is a rough version of it)  starts from beyond a basic 960px width ( = to header) and slides into its position.
            All this is done within the symbol. The symbol is 2445px wide at its start.
            The positions they rest at is of course pre determined by the animation but yes its intended to line up with the header.  It seems like it should be a simple thing to do but I cannot seem to get it to center and no using 960px didnt work.
            I have little hair left to tear out so any help would be appreciated
            Paul
            • 3. Re: Centering an animated symbol
              salesdigital Level 1
              hi paul,
              i made this sample after reading the centering post/thread you did.  http://salesdigital.com/slides/
              blue bar is being centered by the css code. clicking the top right square animates a pic in to line up with the blue box. - left top square takes it off the screen.
              seems to be similar to what you're trying to do -
              is your header graphic in the same symbol as the animation?  if you want to post your files, i can take a look.
              best,
              keith
              • 4. Re: Centering an animated symbol
                Paul_C_B Level 1
                You know what, just a few moments ago I did the same as you. Simplified
                it ala KISS
                Made a simple symbol and slowly complicated it once it was centered. I
                have no idea what was causing it to refuse to center but now, it does.
                What I did notice was that there seems to be something squirrely about
                the way symbols are named. For example in my library, a symbol is named
                Symbol_2 but, in the time line its called Symbol_22. There seems to be a
                hidden protocol that names symbols what the hell it likes I think I
                must now always keep an eye on what the symbol is called within the
                timeline and not refer to the symbol library. Probably an instance issue..
                I really appreciate your taking the time to reply. As soon as I get this
                page up in a close to finished test format Ill post again
                once again, many thanks.
                • 5. Re: Centering an animated symbol
                  Paul_C_B Level 1
                  OK got something running fine although I need to re-time the block animation, its all functioning
                  Next its button states and etc.
                  http://www.avatarea.com/snsblocks/
                  transition from Flash isnt so bad if ya keep your wits about you
                  P
