1 Reply Latest reply on Oct 23, 2012 9:04 AM by ChrisAugier
    How can I open an attachment from inside a PDF portfolio using flex 4.1?
    ChrisAugier Level 1
      I am currently developing a portfolio and have a DataGrid which lists my sorted attachments.
      I can right click on an attachment to open it but I require it to happen on the double click event.
      My code currently looks like this (taken from an old example):
      private function itemDoubleClicked(event:ListEvent):void
                                              var itemIndex:int = event.rowIndex;
                                              var item:AttachmentImpl = AttachmentImpl(sortedCurrentItems.getItemAt(itemIndex));
                                              var command:CommandImpl = collectionManager.host.commands(acrobat.collection.CommandType.PREVIEW);
                                              Alert.show("you double clicked " + item.fileName);
                                              collectionManager.host.selection = [item];
                                              command.execute(item);
      but i get a null pointer exception because command is null.
      Could anyone give me pointers or another solution?
      Chris.
      Edit:
      I would like to extend this question as follows:
      when using 'host.commands' (as i believe is correct) I get the error that host is 'write-only' and therefore can access none of its methods.
      The example I use is from here: http://pdfdevjunkie.host.adobe.com/05_sorting.shtml
      Using this method, the host is overwritten by doing the following:
      public function set host(host:INavigatorHost):void
                                                   if(host != null) {
                                                             _host = host;
                                                             startEverything();
                                                   } else {
                                                             _host = null;
                                                             //Alert.show("Navigator Ending");
      When I try to do this I recieve the error that the method is not set for override.
