2 Replies Latest reply on Oct 24, 2012 2:59 AM by DaraClare
    Missing Fonts in Packaged InDesign file
    DaraClare Level 1
      Hi, I'm trying to get an indesign file off a trainee designer in another office. He has packaged it but there are still mssing fonts, and most of the text is highlighted in pink. I will paste the instructions text file below so you can see that no fonts are missing. I have activated all the files in the font folder but it's looking for Helvetica Neue T1 in 4 different weights (35 thin, 45 Light, 55 Roman, 75 Bold), none of these are in the font folder. Apologies if I'm being dumb and missing something obvious.
      I'm on a mac using CS5 on one machine and CS6 on another, it works with neither. I think they're on a mac as far as I know.
      Thanks in advance to anyone who can help or give any advice, don't want to replace all the fonts on this huge file, much appreicated, Dara
      Instructions file below:
      ADOBE INDESIGN PRINTING INSTRUCTIONS FOR SERVICE PROVIDER REPORT
      PUBLICATION NAME: ED6-MAIN-23_10_2012.indd
      PACKAGE DATE: 23/10/2012 13:58
      Creation Date: 23/10/2012
      Modification Date: 23/10/2012
      CONTACT INFORMATION
      SPECIAL INSTRUCTIONS AND OTHER NOTES
      External Plug-ins 0
      Non Opaque Objects :On PagePB, 1, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, A, B, C, D, E, F
      FONTS
      23 Fonts Used; 0 Missing, 5 Embedded, 0 Incomplete, 0 Protected
      Fonts Packaged
      - Name: ArialMT; Type: TrueType, Status: Embedded
      - Name: ArialMT; Type: OpenType TrueType, Status: OK
      - Name: ArialRoundedMTBold; Type: TrueType, Status: Embedded
      - Name: CenturyGothic; Type: TrueType, Status: OK
      - Name: CenturyGothic-Bold; Type: TrueType, Status: OK
      - Name: EircomHeadline; Type: TrueType, Status: OK
      - Name: EircomHeadlineLite; Type: TrueType, Status: OK
      - Name: Futura-Medium; Type: TrueType, Status: OK
      - Name: HelveticaNeue; Type: TrueType, Status: OK
      - Name: HelveticaNeue-Bold; Type: OpenType Type 1, Status: OK
      - Name: HelveticaNeue-Italic; Type: TrueType, Status: OK
      - Name: HelveticaNeue-Light; Type: OpenType Type 1, Status: OK
      - Name: HelveticaNeue-Light; Type: Type 1, Status: Embedded
      - Name: HelveticaNeue-Roman; Type: OpenType Type 1, Status: OK
      - Name: HelveticaNeue-Roman; Type: Type 1, Status: Embedded
      - Name: HelveticaNeue-Thin; Type: OpenType Type 1, Status: OK
      - Name: MicrosoftSansSerif; Type: OpenType TrueType, Status: OK
      - Name: MinionPro-Regular; Type: OpenType Type 1, Status: OK
      - Name: MiraraeBT-Roman; Type: TrueType, Status: OK
      - Name: MyriadPro-Regular; Type: Type 1, Status: Embedded
      - Name: Times-Roman; Type: TrueType, Status: OK
      - Name: Verdana; Type: OpenType TrueType, Status: OK
      - Name: ZurichBT-Light; Type: TrueType, Status: OK
      COLOURS AND INKS
      4 Process Inks; 0 Spot Inks
      - Name and Type: Process Cyan; Angle: 75.000; Lines/Inch: 70.000
      - Name and Type: Process Magenta; Angle: 15.000; Lines/Inch: 70.000
      - Name and Type: Process Yellow; Angle: 0.000; Lines/Inch: 70.000
      - Name and Type: Process Black; Angle: 45.000; Lines/Inch: 70.000
      LINKS AND IMAGES
      (Missing & Embedded Links Only)
      Links and Images: 720 Links Found; 0 Modified, 0 Missing
      Images: 0 Embedded, 7 use RGB colour space
      Links/Images with Layer Overrides: 5
      PRINT SETTINGS
      PPD: Xerox WorkCentre 7665, (XEROX-7665)
      Printing To: Printer
      Number of Copies: 1
      Reader Spreads: Yes
      Even/Odd Pages: Both
      Pages: All
      Proof: No
      Tiling: None
      Scale: 100%, 100%
      Page Position: Centre
      Print Layers: Visible & Printable Layers
      Printer's Marks: None
      Bleed: 0 mm, 0 mm, 0 mm, 0 mm
      Colour: Composite CMYK
      Trapping Mode: None
      Send Image Data: All
      OPI/DCS Image Replacement: No
      Page Size: A4
      Paper Dimensions: 297.039 mm x 420.158 mm
      Orientation: Landscape
      Negative: No
      Flip Mode: Off
      FILE PACKAGE LIST
      1. ED6-MAIN-23_10_2012.indd; type: Adobe InDesign publication; size: 97128K
      2. Arial.ttf; type: Font file; size: 755K
      3. Century Gothic; type: Font file; size: 256K
      4. eirhrg.ttf; type: Font file; size: 81K
      5. eirhlt.ttf; type: Font file; size: 82K
      6. Futura.ttc; type: Font file; size: 314K
      7. HelveticaNeue.dfont; type: Font file; size: 1233K
      8. HelveticaNeue-Bold.otf; type: Font file; size: 17K
      9. HelveticaNeue-Light.otf; type: Font file; size: 17K
      10. HelveticaNeue-Roman.otf; type: Font file; size: 16K
      11. HelveticaNeue-Thin.otf; type: Font file; size: 17K
      12. Microsoft Sans Serif.ttf; type: Font file; size: 636K
      13. MinionPro-Regular.otf; type: Font file; size: 229K
      14. MIRARAEN.TTF; type: Font file; size: 52K
      15. Times.dfont; type: Font file; size: 1722K
      16. Verdana; type: Font file; size: 601K
      17. ZURCHL.TTF; type: Font file; size: 36K
