0 Replies Latest reply on Oct 24, 2012 2:54 AM by Phildsb
    Crashes - re-parenting and empty text boxes
    Phildsb Level 1
      Using v1.0 I'm experiencing repeated crashes when re-parenting more than one element at the same time in the Elements palette. Its quite a large project which pulls in data from an xml or json source which it uses to draw a couple of svg maps, so I won't post it here although I believe I've seen it with other projects also.
      I'm also getting a warning message whenever I attempt to add text to an empty text box (I have multiple empty text boxes which are filled using values from an xml or json): "An error occurred. Please save your work and restart Edge Animate"
      Hope you can sort thes issues out for the next release.
