2 Replies Latest reply on Oct 26, 2012 7:20 AM by Kaif Akbar
    Data source problems
    community help Level 1
        • 1. Re:  Data source problems
          inkingston
          The original documentation has been incorrect since CF 8... Since 2007 and they keep rolling the incorrect documents forward to the next version.  5 years later...
          You need to create a new user in the CF Admin and assign the appropriate roles to the user to allow this to work.
          <cfscript>
          writeOutput("Installing ODBC Services...<br>");
          createObject("component","cfide.adminapi.administrator").login("password","username");
          myObj = createObject("component","cfide.adminapi.datasource");
          returnValue = myObj.installODBCservice();
          writeOutput("ODBC Services installed");
          </cfscript>
          • 2. Re:  Data source problems
            Kaif Akbar Level 1
            In such scenario, It is always better to first remove existing/corrupted odbc services through a .cfm page containing below code snippet(with admin user password):-
            <cfscript>
              //login using admin
              //createObject("component","cfide.adminapi.administrator").login("administrator_password" );
              createObject("component","cfide.adminapi.administrator").login("password");
              //instantiate datasource object
            </cfscript>
            TO REMOVE ODBC SERVICES:
            <cfscript>
                 writeOutput("Removing ODBC Services...<br>");
                 returnValue = myObj.removeODBCservice();
                 writeOutput("ODBC Services removed");
            </cfscript>
            Then install odbc services through a .cfm page containing below code snippet(with admin user password):-
            <cfscript>
              //login using admin
            </cfscript>
            TO Install ODBC Services:
            <cfscript>
            </cfscript>
            You can also put both scripts codes within single script tag for each purpose.
            Message was edited by: KaifAkbar
