5 Replies Latest reply on Oct 25, 2012 9:51 AM by rickmorton
    Card Dance acting wierd
    rickmorton Level 1
      I'm using card dance, setting key frames to start out in Z space, then having the cards come together. Typical stuff.
      I'm using photos. All is well.
      I did another comp using a Quicktime movie. Applied the same card dance effect and the cards jump all over the place.
      I've tried placing a photo in this comp and it works fine. Add a quicktime movie - any one - and it goes crazy.
      Am I missing something?
      Thanks.
      RM
        • 1. Re: Card Dance acting wierd
          BenjaminMarkus Level 4
          Can you upload some screenshots of your setup inlcuding the exact effect settings?  That might help us determine the cause of your problem?
          • 2. Re: Card Dance acting wierd
            rickmorton Level 1
            I can try that. However, it's pretty simple.
            I set a key frame to spread out the cards, then 6 seconds later, set a key frame to bring them together.
            This is the same setting for each comp I'm using.
            As long as there is a still photo, the effect works fine.
            If I put a QT movie in instead, the cards, between the two key frames,
            jump all over the place. Put the photo back in and everything is fine.
            Have tried different movies - same thing.
            • 3. Re: Card Dance acting wierd
              Well, if it jumps, the movie is used as a gradient input layer somewhere and the behavior would be perfectly normal, given that the pixel values change with every frame then. To be honest, I think you'r simply trying to do it the lazy man's way and have used your clip both as the layer the effect is applied to and then self-referenced it as the gradient, which won't work. You need a separate static gradient map.
              Mylenium
              • 4. Re: Card Dance acting wierd
                rickmorton Level 1
                Nope. Not the lazy way. I also tried this with a separate gradient layer and couldn't get anything to happen. The image simply got bigger when I increased to z value, it didn't break apart.
                I also tried this on another Mac, using a different OS and the same thing happened. I need to use this for QT movies.. and I'm stumped. If someone could try this, I'd appreciate hearing about the result.
                • 5. Re: Card Dance acting wierd
                  rickmorton Level 1
                  Maybe I did something wrong using the gradient. I created a layer, addend a ramp and dropped into the comp. Used that as the "gradient layer". As I said, when I then tried to increase the z position, the image simply got bigger... didn't break up. ???
