0 Replies Latest reply on Oct 24, 2012 9:45 PM by edags9
    Range component in custom item renderer
    edags9
      I am trying to put a spark Range component into the labelItemRenderer for flex mobile. Everytime I add it I get the error: "Skin for (long directory name for my range component) cannot be found". The custom item renderer is an actionscipt class because I read this is the best way to make them for mobile. I'll put the error in the bottom of the post.
      If anyone has any idea why this could be happening or if anyone knows a possible way around this it would be extremely helpful. I basicaly just need a list where each item has a label on side and then a progress bar on the other side.
      Thanks.
      Here is the full error, ill put a star on the line where the addChild method gets called in my item renderer for the range component.
      Error: Skin for HoosFit0.TabbedViewNavigatorApplicationSkin5.tabbedNavigator.TabbedViewNavigatorSkin7.con tentGroup.ViewNavigator1.ViewNavigatorSkin12.contentGroup.
      FCfacilities139.SkinnableContainerSkin141.contentGroup.Group143.facilityList.ListSkin145.S croller147.ScrollerSkin148.DataGroup146.FCfacilitiesInnerClass0_157.Range154 cannot be found.
                at spark.components.supportClasses::SkinnableComponent/attachSkin()[E:\dev\4.y\frameworks\pr ojects\spark\src\spark\components\supportClasses\SkinnableComponent.as:698]
                at spark.components.supportClasses::SkinnableComponent/validateSkinChange()[E:\dev\4.y\frame works\projects\spark\src\spark\components\supportClasses\SkinnableComponent.as:443]
                at spark.components.supportClasses::SkinnableComponent/createChildren()[E:\dev\4.y\framework s\projects\spark\src\spark\components\supportClasses\SkinnableComponent.as:406]
                at mx.core::UIComponent/initialize()[E:\dev\4.y\frameworks\projects\framework\src\mx\core\UI Component.as:7634]
                at mx.core::UIComponent/http://www.adobe.com/2006/flex/mx/internal::childAdded()[E:\dev\4.y\frameworks\projects\framework\src\mx\core\UIComponent.as:7495]
                at mx.core::UIComponent/addChild()[E:\dev\4.y\frameworks\projects\framework\src\mx\core\UICo mponent.as:7176]
      *** at views::itemRenderer2/set data()[/Users/evan/Documents/Adobe Flash Builder 4.6/HoosFit/src/views/itemRenderer2.as:73]
                at spark.components::SkinnableDataContainer/updateRenderer()[E:\dev\4.y\frameworks\projects\ spark\src\spark\components\SkinnableDataContainer.as:606]
                at spark.components.supportClasses::ListBase/updateRenderer()[E:\dev\4.y\frameworks\projects \spark\src\spark\components\supportClasses\ListBase.as:1106]
                at spark.components::DataGroup/setUpItemRenderer()[E:\dev\4.y\frameworks\projects\spark\src\ spark\components\DataGroup.as:1157]
                at spark.components::DataGroup/initializeTypicalItem()[E:\dev\4.y\frameworks\projects\spark\ src\spark\components\DataGroup.as:327]
                at spark.components::DataGroup/ensureTypicalLayoutElement()[E:\dev\4.y\frameworks\projects\s park\src\spark\components\DataGroup.as:384]
                at spark.components::DataGroup/measure()[E:\dev\4.y\frameworks\projects\spark\src\spark\comp onents\DataGroup.as:1467]
                at mx.core::UIComponent/http://www.adobe.com/2006/flex/mx/internal::measureSizes()[E:\dev\4.y\frameworks\projects\framework\src\mx\core\UIComponent.as:8506]
                at mx.core::UIComponent/validateSize()[E:\dev\4.y\frameworks\projects\framework\src\mx\core\ UIComponent.as:8430]
                at mx.managers::LayoutManager/validateSize()[E:\dev\4.y\frameworks\projects\framework\src\mx \managers\LayoutManager.as:665]
                at mx.managers::LayoutManager/doPhasedInstantiation()[E:\dev\4.y\frameworks\projects\framewo rk\src\mx\managers\LayoutManager.as:816]
                at mx.managers::LayoutManager/doPhasedInstantiationCallback()[E:\dev\4.y\frameworks\projects \framework\src\mx\managers\LayoutManager.as:1180]
