5 Replies Latest reply on Nov 1, 2012 3:18 AM by c.pfaffenbichler
    auto copy one pixel row from image....
    dejansuc
      Can someone help me write a script that:
      - from my selection (1 pixel row)
      - auto copy selected area to next row into new layer (up or down)... and so on (into the same second layer)... until it reaches the end of the image
      - the result is a photos with two layers; in the first is my image and in second is multicolored pattern
        • 1. Re: auto copy one pixel row from image....
          c.pfaffenbichler Level 9
          You could try this, but from a certain height on simply transforming might be considerably quicker:
          // 2012, use it at your own risk;
          #target photoshop
          if (app.documents.length > 0) {
          var originalRulerUnits = app.preferences.rulerUnits;
          app.preferences.rulerUnits = Units.PIXELS;
          myDocument = app.activeDocument;
          // new layer;
          var id14 = charIDToTypeID( "CpTL" );
          executeAction( id14, undefined, DialogModes.NO );
          var theLayer = myDocument.activeLayer;
          var theHeight = theLayer.bounds[3]-theLayer.bounds[1];
          var theCheck = false;
          var theCounter = 1;
          // duplicate, move and merge the layer;
          while (theCheck == false) {
          if (theLayer.bounds[3] < myDocument.height) {
          var theCopy = theLayer.duplicate();
          theCopy.translate(0, theLayer.bounds[3] - theLayer.bounds[1]);
          theCounter++;
          var theLayer = theCopy.merge();
          //$.writeln(theCounter);
          else {theCheck = true};
          // reset;
          app.preferences.rulerUnits = originalRulerUnits;
          • 2. Re: auto copy one pixel row from image....
            dejansuc Level 1
            Exactly what I was looking for...
            What should I change in this script:
            1. to copy selected line horizontaly UP
            2. to copy selected line verticaly LEFT
            3. to copy selected line verticaly RIGHT
            Thnx!!
            • 3. Re: auto copy one pixel row from image....
              To duplicate the selected part up changing the if-clause and the line that tranlate (moves)
              if (theLayer.bounds[1] > 0) {
              theCopy.translate(0, theLayer.bounds[1] - theLayer.bounds[3]);
              should do it.
              For left
              if (theLayer.bounds[0] > 0) {
              theCopy.translate(theLayer.bounds[0] - theLayer.bounds[2], 0);
              • 4. Re: auto copy one pixel row from image....
                dejansuc Level 1
                hmm... not working for left...
                • 5. Re: auto copy one pixel row from image....
                  I don’t see a problem; naturally the Selection should be a vertical column.
                  One should include a check for this condition, I guess.
                  #target photoshop
                  // new layer;
                  var theCounter = 1;
                  theCounter++;
                  // reset;
