All of a sudden, I am seeing the following when I try to compile an app for iOS:
[code]
Error occurred while packaging the application:
# A fatal error has been detected by the Java Runtime Environment:
# Internal Error (0xe06d7363), pid=3736, tid=7512
# JRE version: 6.0_16-b01
# Java VM: Java HotSpot(TM) Client VM (14.2-b01 mixed mode windows-x86 )
# Problematic frame:
# C [KERNELBASE.dll+0xc41f]
# An error report file with more information is saved as:
# C:\Users\GAIUSC~1\AppData\Local\Temp\AOT1351170957959\hs_err_pid3736.log
[/code]
The error log has been deleted by the time I get to it and there is no other clue, not aware of making any other changes that could affect it.
Will try restarting but...
Any clues or ideas would be welcome!
G
Ok, not sure if this is any use, I finally got to see the log before it was deleted - all it contains is the first half of my .android/adb_usb.ini:
0x54c Coffey\.android\adb_usb.ini
That is really very strange indeed, especially considering that I am packaging for iOS not Android.
G
More on this: I have restarted the machine, which made no difference, but I have managed to do a full compile of the app (for release) on iOS with no problems. So the issue _ONLY_ affects debug compile for Standard mode iOS.
G
Hmm.
I have googled the error code C [KERNELBASE.dll+0xc41f] and it is suggesting an incompatibility with 64-bit versus 32-bit systems. I did previously install the 64-bit Flash Builder 4.7 trial, and then uninstall it again because it gave too many bugs on my machine and played havoc with FB 4.6.
I will try in the 4.7 forum to see if they have any ideas.
G
Posted here: http://forums.adobe.com/thread/1088235
Could you please try removing all java entires from Windows System Properties\ Environment variables.
So that Flash Builder uses java runtime bundled in it.
I've replied in the other thread - I will treat that as the current one now so as to avoid duplicating everything everywhere.
G
