2 Replies Latest reply on Oct 26, 2012 6:22 AM by jahmer
    Will AE CS6 use all my cuda cores?
    jahmer
      I have 2 quadro cx cards. Specs for each are 1.5g memory and 192 cuda cores and have the latest drivers.
      1) Will AE use 1.5 or 3g of gddr? It is currently showing 1.5 usage.
      2) Will AE use 192 or 392 cores?
      3) Do I have to install the SLI bridge?
        • 1. Re: Will AE CS6 use all my cuda cores?
          Never. Having two cards does not double the memory because each card will redundantly store data in its local RAM.
          AE doesn't care. It will use whatever the driver makes available and that is an either/ or thing. It's all or nothing. If your driver enables both cards all 392 cores will be avialable, if foer some reason the driver goes belly up, it may only show one or none at all...
          For CUDA you shouldn't have to, as it's managed directly over the PCI bus.
          Mylenium
