1 Reply Latest reply on Oct 25, 2012 11:29 AM by Jeffrey_Smith
    Type inside a path to edge
    graph22 Level 1
      Hope you're well.
      In the attached, I would like the type inside the
      train shape to go to the edge. How do I do that?
        • 1. Re: Type inside a path to edge
          Jeffrey_Smith Most Valuable Participant
          What you see on the upper left side of shape is just a limitation, depending on the angle of frame, point size, etc. there will be nothing you can do to adjust that space. On the right side, you can justify the text to have it align closer to the edge. If you need better results, you would have to create two frames, one for text, the other for the shape, and tweak the text frame accordingly.
