1 返信 最新の回答 日時: Nov 30, 2012 1:41 AM ユーザー:Ezo
    Initial folder path in the Save As AcrobatXI
    nomalg
      In an environment that has been installed AcrobatXI on Windows7, when opened by double-clicking the PDF,
      If I try to "Save As", the initial folder path of the save-file-dialog is to "folder selected earlier in Acrobat" instead of "folder of the PDF that is currently open".
      For example, after I opened by double-clicking the PDF, when I inserted the image file to PDF from open-file-dialog,
      the initial folder path of the save-file-dialog is image file's parent folder. If I want to save the original file's folder, I must be sure to change the folder. It is very inconvenient.
      In AcrobatX, the initial folder path of the save-file-dialog is the original file's folder. And I tried to experiment, If the environment that has been installed AcrobatXI on WindowsXP, You seem to behave the same as AcrobatX.
      Even in an environment of Windows7, By changing the setting, is it possible to operate using WindowsXP or equivalent AcrobatX?
