1 Reply Latest reply on Dec 6, 2012 3:50 PM by Gaius Coffey
    Error 1009 when accessing webservice elements
    philBride
      I'm learning flex and Flash Builder 4.6 and doing a small example project.
      I've created a mobile app test using a web service. I got the web service to work, creating xml dataset. I can get the flex code to access the web service and read the file. That works so far. The code reads the whole xml file from the web service and presents it. What I don't quite see is how to read only the elements. When I specify the .LastResult.element.element I get Error #1009: Cannot access a property or method of a null object reference. during runtime.
      I can post the  webservice xml result if that helps. Thanks for any insights.
      Here's the code
      <s:View xmlns:fx="http://ns.adobe.com/mxml/2009"
              xmlns:mx="library://ns.adobe.com/flex/mx"
              creationComplete="view1_creationCompleteHandler(event)"
              xmlns:service1="services.service1.*"
              xmlns:uws_lookups="services.uws_lookups.*"
              title="HomeView">
          <fx:Script>
              <![CDATA[
                  import mx.rpc.soap.WebService;
                  import mx.collections.ArrayCollection;
                  import mx.rpc.AsyncResponder;
                  import mx.collections.XMLListCollection;
                  import mx.events.FlexEvent;
                  import mx.rpc.events.ResultEvent;
                  import spark.events.IndexChangeEvent;
                  import spark.events.TextOperationEvent;
          </fx:Script>
          <fx:Declarations>
              <s:WebService
                  id="SampleDBwebserviceCS"
                  wsdl="http://localhost:57074/Service1.asmx?WSDL"
                  showBusyCursor="true"
                  useProxy= "false"
                  makeObjectsBindable="true">
                  <s:operation  name="Getmember" resultFormat="xml">
                  </s:operation>
              </s:WebService>
              <s:CallResponder id="GetmemberResult"/>
              <service1:Service1 id="service1"/>
          </fx:Declarations>
          <s:VGroup width="60%" height="60%" color="#10851E" fontFamily="Arial" fontSize="10"
                    fontWeight="normal" horizontalAlign="center" verticalAlign="middle">
              <s:TextArea id="lblResult" x="2" y="0" width="188" height="234"
                          text="{GetmemberResult.lastResult}">
              </s:TextArea>
              <!-- Returns the whole xml result - all fields  all xml definitions -->
              <!-- Want to return GetmemberResult.lastResult.Sales.FirstName -->
              <!-- however this causes a 1009 error on Sales-->
              <s:Button
                  label="Get Data"
                  click="SampleDBwebserviceCS.Getmember.send(); lblResult.text = SampleDBwebserviceCS.Getmember.lastResult"
                  x="10"
                  y="568">
              </s:Button>
          </s:VGroup>
      </s:View>
      1009 error when I insert this property in the <s:Button   tag:
      click="SampleDBwebserviceCS.Getmember.send(); lblResult.text = SampleDBwebserviceCS.Getmember.lastResult.Sales.FirstName"
      TypeError: Error #1009: Cannot access a property or method of a null object reference.
          at views::SampleSQLHomeView/___SampleSQLHomeView_Button1_click()[C:\Users\phillip\Adobe Flash Builder 4.6\SampleSQL\src\views\SampleSQLHomeView.mxml:121]
