1 Reply Latest reply on Nov 3, 2012 4:21 PM by Production Monkey
    Controlling sprites within a film loop
    Minds Eye Level 1
      Hi everyone.
      I have a whole load of sprites each with a ling behaviour attached. That was fine and it worked well.
      However, it was getting a bit messy as there are about 30 sprites and I need to animate the whole lot as one.
      So I thought I'd convert all of them into a single film loop.
      There general behaviour works but the bit of code to set the blend value of the individual sprite no longer works. So I need some way to access the blend value of the individual sprites of the film loop member.
      Any ideas?
      Here's the bit of code:
      on flashSprite me
        p_dir = true
        p_blend = 0
        timeout().new("flashMe" &string(me.spriteNum), 40, #setVisibility, me)
      end
      on mouseUp me
        flashSprite me
        p_textMember.text = p_textMember.text &string(p_key)
      end
      on setVisibility me
        if p_dir then
          p_blend = p_blend + 10
        else
          p_blend = p_blend - 10
        end if
        if p_blend >= 100 then
          p_dir = false
        end if
        if p_blend <= 0 and not p_dir then
          timeout("flashMe" &string(me.spriteNum)).forget()
        end if
        sprite(me.spriteNum).blend = p_blend
      end
