12 Replies Latest reply on Oct 29, 2012 1:40 AM by stormsurge_77
    CS6 extension manager crashes on start up
    stormsurge_77
      I'm having issues getting my extension manger to initialise.  I haven't been able to get it to start.  It stalls trying to load extensions.  I have removed all old extensions and old adobe products from my system.
        • 1. Re: CS6 extension manager crashes on start up
          Carl Sun Level 4
          Could you provide more details about the OS platform, Extension Manager version, which products are installed?  You can generate log files to help troubleshooting.
          1. Create a file named "ExManLog.YES" in Extension Manager folder.
              Windows:
              1) Open command prompt as administrator;
              2) Change directory to "C:\Program Files (x86)\Adobe\Adobe Extension Manager CS6". (for 32bit OS, no (x86)).
              3) Run command
              echo > ExManLog.YES
              Mac:
              1) Open terminal;
              2) Change directory to"/Applications/Adobe Extension Manager CS6/Adobe Extension Manager CS6.app/Contents/MacOS";
              3) Run command
          sudo touch ExManLog.YES
              4) Input the password of administrative account.
          2. Launch Extension Manager.
          3. Extension Manager log files( *.log ) can be found in the following folder.
              Windows: "C:\Users\<UserName>\AppData\Roaming\Adobe\Extension Manager CS6\"
              Mac: "/Users/<UserName>/Library/Application Support/Adobe/Extension Manager CS6/"
          • 2. Re: CS6 extension manager crashes on start up
            stormsurge_77 Level 1
            Thanks for that Carl.  Mate i'm running on a 32 bit Windows 7 OS.  The software is brandnew CS6 Design and Web premium. the entire CS6 is installed including the extension manager.  I've tried to create the ExManLog.YES but my administrator comand prompt won't let me do anything at all...... I'm not all that technically literate when it comes to computers.  I don't think i'm changing the directory right.  the only way I can get a C:\ prompt it to use a cd\ as follows C:\windows\systems32\ cd\????  then if I type in the C:\Program Files (x86)\Adobe\Adobe Extension Manager CS6 and press enter I get a message "program not recognised"  which takes me back to the C:\ prompt.   Any idea on what i'm doing wrong?
            • 3. Re: CS6 extension manager crashes on start up
              Carl Sun Level 4
              1. Click "Start" icon, click "All Programs"->"Accessories". Right click "Command Prompt" then select "Run as administrator". Click "Yes" in the popped "User Account Control" dialog box.
              2. Input the following command then press "Enter" key:
                 cd "C:\Program Files\Adobe\Adobe Extension Manager CS6"
              3. Input the following command then press "Enter" key:
                 echo > ExManLog.YES
              4. Launch Extension Manager.
              5. After Extension Manager crashes, paste the content of log files here.
              • 4. Re: CS6 extension manager crashes on start up
                Carl  I've performed the above process.  When I open the log file all it says is "ECHO is on" nothing else recorded in the file.  Perhaps using the term crash might be misleading for you, its almost as if the program stalls.  What the extension manager does upon opeing is try and load extensions,  the progress bar loads to approximately 70% and the won't let me do anything else,  I have to start the task manager to force the program to close!
                • 5. Re: CS6 extension manager crashes on start up
                  Carl Sun Level 4
                  In which file did you see "ECHO is on"? The log file is in "C:\Users\<UserName>\AppData\Roaming\Adobe\Extension Manager CS6\" folder, and the file name is ExtensionManager.log and log0.log, log1.log, log2.log, etc. Please make sure you open the correct file.
                  Please check whether you have sufficient privilege to "C:\ProgramData\Adobe\Extension Manager CS6\Configuration\DB\ExMan.db" and "C:\Users\<UserName>\AppData\Roaming\Adobe\Extension Manager CS6\Configuration\DB\ExManUser.db". Right click these files and select "Properties", make sure the "Read-only" checkbox is unchecked, then select "Security" tab page, select your user name in upper pane, make sure "Full control" is checked in the lower pane.
                  • 6. Re: CS6 extension manager crashes on start up
                    C:\Program Files\Adobe\Adobe Extension Manager CS6\ExManLog, is wherre I found the Echo on file.  As for finding the other file paths and checking for privilidges  C:\ProgramData\Adobe\Extension Manager CS6\Configuration\DB\ExMan.db (I don't have a Folder in my C:\ called Program data )AND the other path C:\Users\<UserName>\AppData\Roaming\Adobe\Extension Manager CS6\Configuration\DB\ExManUser.db, I can access the Users directory and then I'm assuming that i open the directory that has my username but when I open it I have none of the proceeding 'AppData\Roaming\Adobe\Extension Manager CS6\Configuration\DB\ExManUser.db'  Do I need to switch to an administrator mode or something?  If so how?
                    • 7. Re: CS6 extension manager crashes on start up
                      Xiaoyi Tong Adobe Employee
                      You can try to click the "start" button, natigate to "Adobe Extension Manager CS6", and right click it, select "Run as administrator". Then check if the issue still exists.
                      Xiaoyi
                      • 8. Re: CS6 extension manager crashes on start up
                        Thanks for the idea.  hasn't worked Extension manager still stops/stalls while trying to load extensions.
                        • 9. Re: CS6 extension manager crashes on start up
                          "C:\Program Data" is a system folder, and it is hidden by default. Please click "Organize" icon in your file explorer, and select "Folder and Search Options", switch to "View" tab, and select "show hidden files, folders and drivers". Then, you should see it in your explorer, and you can check the things Carl posted above. Thanks.
                          Xiaoyi
                          • 10. Re: CS6 extension manager crashes on start up
                            Thanks mate...... that worked.  I looked at both files and permissions are both full control and the read only box is unchecked.  The extension manager file is shown below.
                            [DEBUG] Sun Oct 28 13:30:43 2012 [.133] (OWLMain.cpp,899) -APE environment initializd OK
                            [DEBUG] Sun Oct 28 13:30:43 2012 [.133] (OWLMain.cpp,902) -C:\Program Files\Adobe\Adobe Extension Manager CS6
                            [DEBUG] Sun Oct 28 13:30:43 2012 [.198] (OWLMain.cpp,937) -Create APE stage window OK
                            [INFO] Sun Oct 28 13:30:43 2012 [.335] (OWLMain.cpp,969) -Load swf file succeed.
                            [DEBUG] Sun Oct 28 13:30:44 2012 [.687] (OWLMain.cpp,143) -AIR is ready for the invocation from C++ side
                            [TRACE] Sun Oct 28 13:30:44 2012 [.687] (CommandExecutorMfc.cpp,35) -MESSAGE
                            [DEBUG] Sun Oct 28 13:30:44 2012 [.688] (..\Control\GetSupportedLocalList.cpp,56) -Sending Get Locale list request to AIR
                            [DEBUG] Sun Oct 28 13:30:44 2012 [.688] (..\Control\OWLFrontController.cpp,400) --------------------Request (C++ side To AIR part ) Start--------------------------
                            [DEBUG] Sun Oct 28 13:30:44 2012 [.688] (..\Control\OWLFrontController.cpp,403) -Method Name: airGetLocaleList
                            [DEBUG] Sun Oct 28 13:30:44 2012 [.688] (..\Control\OWLFrontController.cpp,420) --1
                            [DEBUG] Sun Oct 28 13:30:44 2012 [.688] (..\Control\OWLFrontController.cpp,446) --------------------Request (C++ side To AIR part ) End---------------------------
                            [DEBUG] Sun Oct 28 13:30:44 2012 [.773] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
                            [DEBUG] Sun Oct 28 13:30:44 2012 [.773] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalCallBack
                            [DEBUG] Sun Oct 28 13:30:44 2012 [.773] (..\Control\OWLFrontController.cpp,118) --1
                            [DEBUG] Sun Oct 28 13:30:44 2012 [.773] (..\Control\OWLFrontController.cpp,118) -0
                            [DEBUG] Sun Oct 28 13:30:44 2012 [.773] (..\Control\OWLFrontController.cpp,118) -en_US,da_DK,de_DE,cs_CZ,es_ES,fi_FI,fr_FR,hu_HU,it_IT,ja_JP,ko_KR,nb_NO,nl_NL,pl_PL,pt_B R,ru_RU,sv_SE,tr_TR,uk_UA,zh_CN,zh_TW
                            [DEBUG] Sun Oct 28 13:30:44 2012 [.773] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
                            [DEBUG] Sun Oct 28 13:30:44 2012 [.773] (..\Control\PumpBridgeTalkMessageCommand.cpp,67) -PumpBridgeTalkMessageCommand::execute(), register bridge talk message handler.
                            [DEBUG] Sun Oct 28 13:30:44 2012 [.774] (..\Control\OWLFrontController.cpp,165) -RequestId is-1. It is a request used to unlock OK/Cancel
                            [DEBUG] Sun Oct 28 13:30:44 2012 [.774] (..\Control\GetSupportedLocalList.cpp,81) -Get Locale list completed
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.3] (..\MMFC\Source\MacrOS.cpp,1692) -=====Supported locales list items:=====
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.4] (..\MMFC\Source\MacrOS.cpp,1696) -en_US
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.4] (..\MMFC\Source\MacrOS.cpp,1696) -da_DK
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.4] (..\MMFC\Source\MacrOS.cpp,1696) -de_DE
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.4] (..\MMFC\Source\MacrOS.cpp,1696) -es_ES
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.4] (..\MMFC\Source\MacrOS.cpp,1696) -fi_FI
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.4] (..\MMFC\Source\MacrOS.cpp,1696) -fr_FR
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.4] (..\MMFC\Source\MacrOS.cpp,1696) -it_IT
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.4] (..\MMFC\Source\MacrOS.cpp,1696) -nb_NO
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.4] (..\MMFC\Source\MacrOS.cpp,1696) -nl_NL
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.4] (..\MMFC\Source\MacrOS.cpp,1696) -pt_BR
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.4] (..\MMFC\Source\MacrOS.cpp,1696) -sv_SE
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.4] (..\MMFC\Source\MacrOS.cpp,1716) -The User preferred language code is en_US
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.4] (..\MMFC\Source\MacrOS.cpp,1719) -en_US
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.5] (..\Control\OWLFrontController.cpp,400) --------------------Request (C++ side To AIR part ) Start--------------------------
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.5] (..\Control\OWLFrontController.cpp,403) -Method Name: airSetLocale
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.5] (..\Control\OWLFrontController.cpp,420) --2
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.5] (..\Control\OWLFrontController.cpp,420) -en_US
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.5] (..\Control\OWLFrontController.cpp,446) --------------------Request (C++ side To AIR part ) End---------------------------
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.6] (..\MacrExtensionManager.cpp,1280) -Extension Mnaager starts initializing
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.9] (..\MMFC\Source\MacrOS.cpp,4181) -Bare version is
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.9] (..\MMFC\Source\MacrOS.cpp,4182) -6.0.0.412
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.9] (..\MMFC\Source\MacrOS.cpp,4187) -Formal version is
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.9] (..\MMFC\Source\MacrOS.cpp,4188) -6.0.0.412
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.9] (..\Products\MacrExtensionManagerProduct.cpp,193) -Application name is Adobe Extension Manager CS6.exe
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.31] (..\Control\OWLFrontController.cpp,400) --------------------Request (C++ side To AIR part ) Start--------------------------
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.31] (..\Control\OWLFrontController.cpp,403) -Method Name: airCallBack
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.31] (..\Control\OWLFrontController.cpp,420) -0
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.31] (..\Control\OWLFrontController.cpp,446) --------------------Request (C++ side To AIR part ) End---------------------------
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.78] (..\Products\MacrCommonProduct.cpp,90) -Application path is C:\Program Files\Adobe\Adobe Illustrator CS6\Support Files\Contents\Windows
                            [INFO] Sun Oct 28 13:30:45 2012 [.86] (..\MacrProductInfoFromCapsLib.cpp,232) -Got installed languages for key (C:\Program Files\Common Files\Adobe\XMP\Custom File Info Panels\4.0), with value (en_GB).
                            [INFO] Sun Oct 28 13:30:45 2012 [.92] (..\MacrProductInfoFromCapsLib.cpp,232) -Got installed languages for key (C:\Program Files\Adobe\Adobe Flash CS6), with value (en_GB).
                            [INFO] Sun Oct 28 13:30:45 2012 [.93] (..\MacrProductInfoFromCapsLib.cpp,273) -Got dummy languages for key (C:\Program Files\Adobe\Adobe Flash CS6), with value (da_DK,en_US;en_AE,en_US;en_GB,en_US;en_IL,en_US;es_MX,es_ES;fi_FI,en_US;fr_CA,fr_FR;fr_M A,fr_FR;hu_HU,en_US;nb_NO,en_US;uk_UA,en_US;).
                            [INFO] Sun Oct 28 13:30:45 2012 [.96] (..\MacrProductInfoFromCapsLib.cpp,232) -Got installed languages for key (C:\Program Files\Adobe\Adobe Illustrator CS6\Support Files\Contents\Windows), with value (en_GB).
                            [INFO] Sun Oct 28 13:30:45 2012 [.98] (..\MacrProductInfoFromCapsLib.cpp,232) -Got installed languages for key (C:\Program Files\Adobe\Adobe Extension Manager CS6), with value (en_GB).
                            [INFO] Sun Oct 28 13:30:45 2012 [.99] (..\MacrProductInfoFromCapsLib.cpp,232) -Got installed languages for key (C:\Program Files\Adobe\Adobe Photoshop CS6), with value (en_GB).
                            [INFO] Sun Oct 28 13:30:45 2012 [.101] (..\MacrProductInfoFromCapsLib.cpp,232) -Got installed languages for key (C:\Program Files\Adobe\Adobe Bridge CS6), with value (en_GB).
                            [INFO] Sun Oct 28 13:30:45 2012 [.104] (..\MacrProductInfoFromCapsLib.cpp,232) -Got installed languages for key (C:\Program Files\Adobe\Adobe Dreamweaver CS6), with value (en_GB).
                            [INFO] Sun Oct 28 13:30:45 2012 [.105] (..\MacrProductInfoFromCapsLib.cpp,273) -Got dummy languages for key (C:\Program Files\Adobe\Adobe Dreamweaver CS6), with value (da_DK,en_US;en_AE,en_US;en_GB,en_US;en_IL,en_US;en_XM,en_US;es_MX,es_ES;fi_FI,en_US;fr_C A,fr_FR;fr_MA,fr_FR;fr_XM,fr_FR;hu_HU,en_US;uk_UA,en_US;).
                            [INFO] Sun Oct 28 13:30:45 2012 [.109] (..\MacrProductInfoFromCapsLib.cpp,232) -Got installed languages for key (C:\Program Files\Adobe\Adobe Fireworks CS6), with value (en_GB).
                            [INFO] Sun Oct 28 13:30:45 2012 [.110] (..\MacrProductInfoFromCapsLib.cpp,232) -Got installed languages for key (C:\Program Files\Adobe\Adobe Media Encoder CS6), with value (en_GB).
                            [INFO] Sun Oct 28 13:30:45 2012 [.110] (..\MacrProductInfoFromCapsLib.cpp,232) -Got installed languages for key (C:\Program Files\Common Files\Adobe\SwitchBoard), with value (en_GB).
                            [INFO] Sun Oct 28 13:30:45 2012 [.111] (..\MacrProductInfoFromCapsLib.cpp,232) -Got installed languages for key (C:\Program Files\Adobe\Adobe InDesign CS6), with value (en_GB).
                            [INFO] Sun Oct 28 13:30:45 2012 [.115] (..\MacrProductInfoFromCapsLib.cpp,232) -Got installed languages for key (C:\Program Files\Adobe\Adobe Utilities - CS6\ExtendScript Toolkit CS6), with value (en_GB).
                            [INFO] Sun Oct 28 13:30:45 2012 [.196] (..\MacrProductInfoFromCapsLib.cpp,360) -For product (C:\Program Files\Adobe\Adobe Illustrator CS6\Support Files\Contents\Windows), the installed languages are (en_GB)
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.197] (..\MactProductInfoFromBridge.cpp,75) ----Begin to read xman configuration data file---
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.197] (..\MactProductInfoFromBridge.cpp,76) -The present xman data file is:
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.197] (..\MactProductInfoFromBridge.cpp,77) -C:\Program Files\Adobe\Adobe Illustrator CS6\Support Files\Contents\Windows\Configuration\XManConfig.xml
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.198] (..\MactProductInfoFromBridge.cpp,86) ----End to read  xman configuration data file---
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.198] (..\Control\macrgetXml_impl.cpp,68) -Sending XML contents to AIR
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.198] (..\Control\OWLFrontController.cpp,400) --------------------Request (C++ side To AIR part ) Start--------------------------
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.198] (..\Control\OWLFrontController.cpp,403) -Method Name: airParseXML
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.199] (..\Control\OWLFrontController.cpp,420) --3
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.199] (..\Control\OWLFrontController.cpp,420) -C:\Program Files\Adobe\Adobe Illustrator CS6\Support Files\Contents\Windows\Configuration\XManConfig.xml
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.199] (..\Control\OWLFrontController.cpp,420) -Configuration.VariableForExMan.Data
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.199] (..\Control\OWLFrontController.cpp,446) --------------------Request (C++ side To AIR part ) End---------------------------
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.215] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.216] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalCallBack
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.216] (..\Control\OWLFrontController.cpp,118) --3
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.216] (..\Control\OWLFrontController.cpp,118) -0
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.216] (..\Control\OWLFrontController.cpp,118) -$illustrator
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.216] (..\Control\OWLFrontController.cpp,118) -$InstallFolder/../../..
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.216] (..\Control\OWLFrontController.cpp,118) -$plugin
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.216] (..\Control\OWLFrontController.cpp,118) -$InstallFolder/../../../Plug-ins
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.216] (..\Control\OWLFrontController.cpp,118) -$scripting
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.216] (..\Control\OWLFrontController.cpp,118) -$InstallFolder/../../../Scripting
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.217] (..\Control\OWLFrontController.cpp,118) -$presets
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.217] (..\Control\OWLFrontController.cpp,118) -$InstallFolder/../../../Presets
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.217] (..\Control\OWLFrontController.cpp,118) -DisplayName
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.217] (..\Control\OWLFrontController.cpp,118) -Illustrator CS6 32
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.217] (..\Control\OWLFrontController.cpp,118) -ProductName
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.217] (..\Control\OWLFrontController.cpp,118) -Illustrator32
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.217] (..\Control\OWLFrontController.cpp,118) -FamilyName
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.218] (..\Control\OWLFrontController.cpp,118) -ProductVersion
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.218] (..\Control\OWLFrontController.cpp,118) -16.0
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.218] (..\Control\OWLFrontController.cpp,118) -HostNameForCSXS
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.218] (..\Control\OWLFrontController.cpp,118) -ILST
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.218] (..\Control\OWLFrontController.cpp,118) -IconPath
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.218] (..\Control\OWLFrontController.cpp,118) -Configuration/ai_app_24px.png
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.218] (..\Control\OWLFrontController.cpp,118) -SupportedInSuite
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.218] (..\Control\OWLFrontController.cpp,118) -CS6
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.218] (..\Control\OWLFrontController.cpp,118) -DefaultLocale
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.219] (..\Control\OWLFrontController.cpp,118) -en_US
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.219] (..\Control\OWLFrontController.cpp,118) -Bit
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.219] (..\Control\OWLFrontController.cpp,118) -32
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.219] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.219] (..\Control\OWLFrontController.cpp,165) -RequestId is-3. It is a request used to unlock OK/Cancel
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.220] (..\Control\macrgetXml_impl.cpp,111) -XML contents parse completed
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.221] (..\Products\MacrCommonProduct.cpp,401) -Product Name for illustrator-16.032 is Illustrator32
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.222] (..\MacrProduct.cpp,1317) -Display Name for illustrator-16.032 is Illustrator CS6 32
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.222] (..\Products\MacrCommonProduct.cpp,444) -Product version forIllustrator CS6 32 is 16.0
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.222] (..\Products\MacrCommonProduct.cpp,463) -Language code for Illustrator CS6 32 is en_GB
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.222] (..\Products\MacrCommonProduct.cpp,191) -Icon Path for Illustrator CS6 32 is C:\Program Files\Adobe\Adobe Illustrator CS6\Support Files\Contents\Windows\Configuration\ai_app_24px.png
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.223] (..\Products\MacrCommonProduct.cpp,382) -Product Family Name for illustrator-16.032 is Illustrator
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.297] (..\MacrProduct.cpp,203) -The product illustrator-16.032 is supported by CS6
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.298] (..\MacrProduct.cpp,1459) -EMStore path per-machine for illustrator-16.032 is C:\ProgramData\Adobe\Extension Manager CS6\EM Store\Illustrator CS6 32\
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.299] (..\MacrProduct.cpp,203) -The product illustrator-16.032 is supported by CS6
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.299] (..\MacrProduct.cpp,1528) -MxiFlag path per-machine for illustrator-16.032 is C:\ProgramData\Adobe\Extension Manager CS6\Mxi Flag\Illustrator CS6 32\
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.300] (..\MacrProduct.cpp,203) -The product illustrator-16.032 is supported by CS6
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.300] (..\MacrProduct.cpp,1283) -Preferred folder for Illustrator CS6 32 is
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.301] (..\MacrProduct.cpp,203) -The product illustrator-16.032 is supported by CS6
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.302] (..\Products\MacrCommonProduct.cpp,90) -Application path is C:\Program Files\Adobe\Adobe InDesign CS6
                            [INFO] Sun Oct 28 13:30:45 2012 [.303] (..\MacrProductInfoFromCapsLib.cpp,360) -For product (C:\Program Files\Adobe\Adobe InDesign CS6), the installed languages are (en_GB)
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.304] (..\MactProductInfoFromBridge.cpp,75) ----Begin to read xman configuration data file---
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.304] (..\MactProductInfoFromBridge.cpp,76) -The present xman data file is:
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.304] (..\MactProductInfoFromBridge.cpp,77) -C:\Program Files\Adobe\Adobe InDesign CS6\Configuration\XManConfig.xml
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.305] (..\MactProductInfoFromBridge.cpp,86) ----End to read  xman configuration data file---
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.305] (..\Control\macrgetXml_impl.cpp,68) -Sending XML contents to AIR
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.305] (..\Control\OWLFrontController.cpp,400) --------------------Request (C++ side To AIR part ) Start--------------------------
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.306] (..\Control\OWLFrontController.cpp,403) -Method Name: airParseXML
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.306] (..\Control\OWLFrontController.cpp,420) --4
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.306] (..\Control\OWLFrontController.cpp,420) -C:\Program Files\Adobe\Adobe InDesign CS6\Configuration\XManConfig.xml
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.306] (..\Control\OWLFrontController.cpp,420) -Configuration.VariableForExMan.Data
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.306] (..\Control\OWLFrontController.cpp,446) --------------------Request (C++ side To AIR part ) End---------------------------
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.327] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.327] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalCallBack
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.328] (..\Control\OWLFrontController.cpp,118) --4
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.328] (..\Control\OWLFrontController.cpp,118) -0
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.328] (..\Control\OWLFrontController.cpp,118) -$indesign
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.328] (..\Control\OWLFrontController.cpp,118) -$InstallFolder
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.328] (..\Control\OWLFrontController.cpp,118) -$indesign_user
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.328] (..\Control\OWLFrontController.cpp,118) -$UserDataFolder/Adobe/Adobe InDesign CS6
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.328] (..\Control\OWLFrontController.cpp,118) -DisplayName
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.329] (..\Control\OWLFrontController.cpp,118) -InDesign CS6
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.329] (..\Control\OWLFrontController.cpp,118) -GlobalProductName
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.329] (..\Control\OWLFrontController.cpp,118) -Adobe InDesign CS6
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.329] (..\Control\OWLFrontController.cpp,118) -ProductName
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.329] (..\Control\OWLFrontController.cpp,118) -ProductVersion
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.329] (..\Control\OWLFrontController.cpp,118) -8.0
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.330] (..\Control\OWLFrontController.cpp,118) -HostNameForCSXS
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.330] (..\Control\OWLFrontController.cpp,118) -IDSN
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.330] (..\Control\OWLFrontController.cpp,118) -IconPath
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.330] (..\Control\OWLFrontController.cpp,118) -Configuration/Icon.png
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.330] (..\Control\OWLFrontController.cpp,118) -SupportedInSuite
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.330] (..\Control\OWLFrontController.cpp,118) -CS6
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.330] (..\Control\OWLFrontController.cpp,118) -DefaultLocale
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.331] (..\Control\OWLFrontController.cpp,118) -en_GB
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.331] (..\Control\OWLFrontController.cpp,118) -NeedLockableExtension
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.331] (..\Control\OWLFrontController.cpp,118) -true
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.331] (..\Control\OWLFrontController.cpp,118) -ShowInstalledFiles
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.331] (..\Control\OWLFrontController.cpp,118) -Bit
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.331] (..\Control\OWLFrontController.cpp,118) -32
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.331] (..\Control\OWLFrontController.cpp,118) -PreExtensionFolder
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.332] (..\Control\OWLFrontController.cpp,118) -$SharedCommonDataFolder/Adobe/InDesign/Version 8.0/en_GB/Extensions
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.332] (..\Control\OWLFrontController.cpp,118) -PluginConfigFile
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.332] (..\Control\OWLFrontController.cpp,118) -$UserDataFolder/Adobe/InDesign/Version 8.0/en_GB/PlugInConfig.txt
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.332] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.332] (..\Control\OWLFrontController.cpp,165) -RequestId is-4. It is a request used to unlock OK/Cancel
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.333] (..\Control\macrgetXml_impl.cpp,111) -XML contents parse completed
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.335] (..\Products\MacrCommonProduct.cpp,401) -Product Name for indesign-8.0 is InDesign
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.336] (..\MacrProduct.cpp,1317) -Display Name for indesign-8.0 is InDesign CS6
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.336] (..\Products\MacrCommonProduct.cpp,444) -Product version forInDesign CS6 is 8.0
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.336] (..\Products\MacrCommonProduct.cpp,463) -Language code for InDesign CS6 is en_GB
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.336] (..\Products\MacrCommonProduct.cpp,191) -Icon Path for InDesign CS6 is C:\Program Files\Adobe\Adobe InDesign CS6\Configuration\Icon.png
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.336] (..\Products\MacrCommonProduct.cpp,382) -Product Family Name for indesign-8.0 is
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.338] (..\MacrProduct.cpp,203) -The product indesign-8.0 is supported by CS6
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.339] (..\MacrProduct.cpp,1459) -EMStore path per-machine for indesign-8.0 is C:\ProgramData\Adobe\Extension Manager CS6\EM Store\InDesign CS6\
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.339] (..\MacrProduct.cpp,203) -The product indesign-8.0 is supported by CS6
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.340] (..\MacrProduct.cpp,1528) -MxiFlag path per-machine for indesign-8.0 is C:\ProgramData\Adobe\Extension Manager CS6\Mxi Flag\InDesign CS6\
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.341] (..\MacrProduct.cpp,203) -The product indesign-8.0 is supported by CS6
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.341] (..\MacrProduct.cpp,1283) -Preferred folder for InDesign CS6 is C:\ProgramData\Adobe\InDesign\Version 8.0\en_GB\Extensions\
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.355] (..\MacrProduct.cpp,203) -The product indesign-8.0 is supported by CS6
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.356] (..\Products\MacrCommonProduct.cpp,90) -Application path is C:\Program Files\Adobe\Adobe Photoshop CS6
                            [INFO] Sun Oct 28 13:30:45 2012 [.356] (..\MacrProductInfoFromCapsLib.cpp,360) -For product (C:\Program Files\Adobe\Adobe Photoshop CS6), the installed languages are (en_GB)
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.356] (..\MactProductInfoFromBridge.cpp,75) ----Begin to read xman configuration data file---
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.357] (..\MactProductInfoFromBridge.cpp,76) -The present xman data file is:
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.357] (..\MactProductInfoFromBridge.cpp,77) -C:\Program Files\Adobe\Adobe Photoshop CS6\Configuration\XManConfig.xml
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.357] (..\MactProductInfoFromBridge.cpp,86) ----End to read  xman configuration data file---
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.357] (..\Control\macrgetXml_impl.cpp,68) -Sending XML contents to AIR
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.357] (..\Control\OWLFrontController.cpp,400) --------------------Request (C++ side To AIR part ) Start--------------------------
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.358] (..\Control\OWLFrontController.cpp,403) -Method Name: airParseXML
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.358] (..\Control\OWLFrontController.cpp,420) --5
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.358] (..\Control\OWLFrontController.cpp,420) -C:\Program Files\Adobe\Adobe Photoshop CS6\Configuration\XManConfig.xml
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.358] (..\Control\OWLFrontController.cpp,420) -Configuration.VariableForExMan.Data
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.358] (..\Control\OWLFrontController.cpp,446) --------------------Request (C++ side To AIR part ) End---------------------------
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.373] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.373] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalCallBack
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.373] (..\Control\OWLFrontController.cpp,118) --5
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.373] (..\Control\OWLFrontController.cpp,118) -0
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.374] (..\Control\OWLFrontController.cpp,118) -EmStorePath
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.374] (..\Control\OWLFrontController.cpp,118) -$SharedRibsDataFolder/Adobe/Extension Manager
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.374] (..\Control\OWLFrontController.cpp,118) -$photoshopappfolder
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.374] (..\Control\OWLFrontController.cpp,118) -$installfolder
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.374] (..\Control\OWLFrontController.cpp,118) -$pluginsfolder
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.374] (..\Control\OWLFrontController.cpp,118) -$photoshopappfolder/Plug-Ins
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.374] (..\Control\OWLFrontController.cpp,118) -$presetsfolder
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.374] (..\Control\OWLFrontController.cpp,118) -$photoshopappfolder/Presets
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.374] (..\Control\OWLFrontController.cpp,118) -$platform
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.374] (..\Control\OWLFrontController.cpp,118) -Win
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.374] (..\Control\OWLFrontController.cpp,118) -$actions
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.374] (..\Control\OWLFrontController.cpp,118) -$presetsfolder/Actions
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.375] (..\Control\OWLFrontController.cpp,118) -$blackandwhite
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.375] (..\Control\OWLFrontController.cpp,118) -$presetsfolder/Black and White
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.375] (..\Control\OWLFrontController.cpp,118) -$brushes
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.375] (..\Control\OWLFrontController.cpp,118) -$presetsfolder/Brushes
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.375] (..\Control\OWLFrontController.cpp,118) -$channelmixer
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.375] (..\Control\OWLFrontController.cpp,118) -$presetsfolder/Channel Mixer
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.375] (..\Control\OWLFrontController.cpp,118) -$colorbooks
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.375] (..\Control\OWLFrontController.cpp,118) -$presetsfolder/Color Books
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.375] (..\Control\OWLFrontController.cpp,118) -$colorrange
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.375] (..\Control\OWLFrontController.cpp,118) -$presetsfolder/Color Range
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.375] (..\Control\OWLFrontController.cpp,118) -$colorswatches
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.375] (..\Control\OWLFrontController.cpp,118) -$presetsfolder/Color Swatches
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.376] (..\Control\OWLFrontController.cpp,118) -$contours
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.376] (..\Control\OWLFrontController.cpp,118) -$presetsfolder/Contours
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.376] (..\Control\OWLFrontController.cpp,118) -$curves
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.376] (..\Control\OWLFrontController.cpp,118) -$presetsfolder/Curves
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.376] (..\Control\OWLFrontController.cpp,118) -$customshapes
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.376] (..\Control\OWLFrontController.cpp,118) -$presetsfolder/Custom Shapes
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.376] (..\Control\OWLFrontController.cpp,118) -$duotones
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.376] (..\Control\OWLFrontController.cpp,118) -$presetsfolder/Duotones
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.376] (..\Control\OWLFrontController.cpp,118) -$exposure
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.376] (..\Control\OWLFrontController.cpp,118) -$presetsfolder/Exposure
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.376] (..\Control\OWLFrontController.cpp,118) -$gradients
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.376] (..\Control\OWLFrontController.cpp,118) -$presetsfolder/Gradients
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.377] (..\Control\OWLFrontController.cpp,118) -$huesat
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.377] (..\Control\OWLFrontController.cpp,118) -$presetsfolder/Hue Sat
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.377] (..\Control\OWLFrontController.cpp,118) -$imagestatistics
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.377] (..\Control\OWLFrontController.cpp,118) -$presetsfolder/Image Statistics
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.377] (..\Control\OWLFrontController.cpp,118) -$keyboardshortcuts
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.377] (..\Control\OWLFrontController.cpp,118) -$presetsfolder/Keyboard Shortcuts
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.377] (..\Control\OWLFrontController.cpp,118) -$layouts
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.377] (..\Control\OWLFrontController.cpp,118) -$presetsfolder/Layouts
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.377] (..\Control\OWLFrontController.cpp,118) -$lenscorrection
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.377] (..\Control\OWLFrontController.cpp,118) -$presetsfolder/Lens Correction
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.377] (..\Control\OWLFrontController.cpp,118) -$levels
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.378] (..\Control\OWLFrontController.cpp,118) -$presetsfolder/Levels
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.378] (..\Control\OWLFrontController.cpp,118) -$liquifymeshes
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.378] (..\Control\OWLFrontController.cpp,118) -$presetsfolder/Liquify Meshes
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.378] (..\Control\OWLFrontController.cpp,118) -$menucustomization
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.378] (..\Control\OWLFrontController.cpp,118) -$presetsfolder/Menu Customization
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.378] (..\Control\OWLFrontController.cpp,118) -$optimizedcolors
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.378] (..\Control\OWLFrontController.cpp,118) -$presetsfolder/Optimized Colors
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.378] (..\Control\OWLFrontController.cpp,118) -$optimizedoutputSettings
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.378] (..\Control\OWLFrontController.cpp,118) -$presetsfolder/Optimized Output Settings
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.378] (..\Control\OWLFrontController.cpp,118) -$optimizedsettings
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.378] (..\Control\OWLFrontController.cpp,118) -$presetsfolder/Optimized Settings
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.379] (..\Control\OWLFrontController.cpp,118) -$patterns
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.379] (..\Control\OWLFrontController.cpp,118) -$presetsfolder/Patterns
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.379] (..\Control\OWLFrontController.cpp,118) -$reducenoise
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.379] (..\Control\OWLFrontController.cpp,118) -$presetsfolder/Reduce Noise
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.379] (..\Control\OWLFrontController.cpp,118) -$replacecolor
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.379] (..\Control\OWLFrontController.cpp,118) -$presetsfolder/Replace Color
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.379] (..\Control\OWLFrontController.cpp,118) -$scripts
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.379] (..\Control\OWLFrontController.cpp,118) -$presetsfolder/Scripts
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.379] (..\Control\OWLFrontController.cpp,118) -$selectivecolor
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.379] (..\Control\OWLFrontController.cpp,118) -$presetsfolder/Selective Color
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.379] (..\Control\OWLFrontController.cpp,118) -$shadowhighlight
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.380] (..\Control\OWLFrontController.cpp,118) -$presetsfolder/Shadow Highlight
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.380] (..\Control\OWLFrontController.cpp,118) -$smartsharpen
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.380] (..\Control\OWLFrontController.cpp,118) -$presetsfolder/Smart Sharpen
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.380] (..\Control\OWLFrontController.cpp,118) -$styles
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.380] (..\Control\OWLFrontController.cpp,118) -$presetsfolder/Styles
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.380] (..\Control\OWLFrontController.cpp,118) -$textures
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.380] (..\Control\OWLFrontController.cpp,118) -$presetsfolder/Textures
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.380] (..\Control\OWLFrontController.cpp,118) -$tools
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.380] (..\Control\OWLFrontController.cpp,118) -$presetsfolder/Tools
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.380] (..\Control\OWLFrontController.cpp,118) -$variations
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.381] (..\Control\OWLFrontController.cpp,118) -$presetsfolder/Variations
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.381] (..\Control\OWLFrontController.cpp,118) -$webphotogallery
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.381] (..\Control\OWLFrontController.cpp,118) -$presetsfolder/Web Photo Gallery
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.381] (..\Control\OWLFrontController.cpp,118) -$workspaces
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.381] (..\Control\OWLFrontController.cpp,118) -$presetsfolder/Workspaces
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.381] (..\Control\OWLFrontController.cpp,118) -$zoomify
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.381] (..\Control\OWLFrontController.cpp,118) -$presetsfolder/Zoomify
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.381] (..\Control\OWLFrontController.cpp,118) -$hueandsaturation
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.381] (..\Control\OWLFrontController.cpp,118) -$presetsfolder/Hue and Saturation
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.381] (..\Control\OWLFrontController.cpp,118) -$lights
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.381] (..\Control\OWLFrontController.cpp,118) -$presetsfolder/Lights
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.381] (..\Control\OWLFrontController.cpp,118) -$materials
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.382] (..\Control\OWLFrontController.cpp,118) -$presetsfolder/Materials
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.382] (..\Control\OWLFrontController.cpp,118) -$meshes
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.382] (..\Control\OWLFrontController.cpp,118) -$presetsfolder/Meshes
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.382] (..\Control\OWLFrontController.cpp,118) -$rendersettings
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.382] (..\Control\OWLFrontController.cpp,118) -$presetsfolder/Render Settings
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.382] (..\Control\OWLFrontController.cpp,118) -$volumes
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.382] (..\Control\OWLFrontController.cpp,118) -$presetsfolder/Volumes
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.382] (..\Control\OWLFrontController.cpp,118) -$widgets
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.382] (..\Control\OWLFrontController.cpp,118) -$presetsfolder/Widgets
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.382] (..\Control\OWLFrontController.cpp,118) -$localesfolder
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.382] (..\Control\OWLFrontController.cpp,118) -$photoshopappfolder/Locales
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.382] (..\Control\OWLFrontController.cpp,118) -$additionalplugins
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.383] (..\Control\OWLFrontController.cpp,118) -$localesfolder/$LOCALE/Additional Plug-ins
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.383] (..\Control\OWLFrontController.cpp,118) -$additionalpresets
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.383] (..\Control\OWLFrontController.cpp,118) -$localesfolder/$LOCALE/Additional Presets
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.383] (..\Control\OWLFrontController.cpp,118) -$localeskeyboardshortcuts
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.383] (..\Control\OWLFrontController.cpp,118) -$localesfolder/$LOCALE/Additional Presets/$platform/Keyboard Shortcuts
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.383] (..\Control\OWLFrontController.cpp,118) -$localesmenucustomization
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.383] (..\Control\OWLFrontController.cpp,118) -$localesfolder/$LOCALE/Additional Presets/$platform/Menu Customization
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.383] (..\Control\OWLFrontController.cpp,118) -$localesworkspaces
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.383] (..\Control\OWLFrontController.cpp,118) -$localesfolder/$LOCALE/Additional Presets/$platform/Workspaces
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.383] (..\Control\OWLFrontController.cpp,118) -$automate
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.383] (..\Control\OWLFrontController.cpp,118) -$pluginsfolder/Automate
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.384] (..\Control\OWLFrontController.cpp,118) -$digimarc
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.384] (..\Control\OWLFrontController.cpp,118) -$pluginsfolder/Digimarc
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.384] (..\Control\OWLFrontController.cpp,118) -$displacementmaps
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.384] (..\Control\OWLFrontController.cpp,118) -$pluginsfolder/Displacement Maps
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.384] (..\Control\OWLFrontController.cpp,118) -$effects
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.384] (..\Control\OWLFrontController.cpp,118) -$pluginsfolder/Effects
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.384] (..\Control\OWLFrontController.cpp,118) -$extensions
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.384] (..\Control\OWLFrontController.cpp,118) -$pluginsfolder/Extensions
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.384] (..\Control\OWLFrontController.cpp,118) -$fileformats
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.384] (..\Control\OWLFrontController.cpp,118) -$pluginsfolder/File Formats
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.384] (..\Control\OWLFrontController.cpp,118) -$filters
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.384] (..\Control\OWLFrontController.cpp,118) -$pluginsfolder/Filters
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.385] (..\Control\OWLFrontController.cpp,118) -$imagestacks
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.385] (..\Control\OWLFrontController.cpp,118) -$pluginsfolder/Image Stacks
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.385] (..\Control\OWLFrontController.cpp,118) -$importexport
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.385] (..\Control\OWLFrontController.cpp,118) -$pluginsfolder/Import-Export
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.385] (..\Control\OWLFrontController.cpp,118) -$measurements
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.385] (..\Control\OWLFrontController.cpp,118) -$pluginsfolder/Measurements
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.385] (..\Control\OWLFrontController.cpp,118) -$panels
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.385] (..\Control\OWLFrontController.cpp,118) -$pluginsfolder/Panels
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.385] (..\Control\OWLFrontController.cpp,118) -$parser
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.385] (..\Control\OWLFrontController.cpp,118) -$pluginsfolder/Parser
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.386] (..\Control\OWLFrontController.cpp,118) -$3dengines
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.386] (..\Control\OWLFrontController.cpp,118) -$pluginsfolder/3D Engines
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.386] (..\Control\OWLFrontController.cpp,118) -$lightingstyles
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.386] (..\Control\OWLFrontController.cpp,118) -$pluginsfolder/Filters/Lighting Styles
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.386] (..\Control\OWLFrontController.cpp,118) -$matlab
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.386] (..\Control\OWLFrontController.cpp,118) -$photoshopappfolder/MATLAB
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.386] (..\Control\OWLFrontController.cpp,118) -UserExtensionFolder
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.386] (..\Control\OWLFrontController.cpp,118) -$UserDataFolder/Adobe/Adobe Photoshop CS6/Configuration
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.386] (..\Control\OWLFrontController.cpp,118) -DisplayName
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.386] (..\Control\OWLFrontController.cpp,118) -Photoshop CS6 32
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.387] (..\Control\OWLFrontController.cpp,118) -ProductName
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.387] (..\Control\OWLFrontController.cpp,118) -Photoshop32
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.387] (..\Control\OWLFrontController.cpp,118) -FamilyName
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.387] (..\Control\OWLFrontController.cpp,118) -ProductVersion
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.387] (..\Control\OWLFrontController.cpp,118) -13.0
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.387] (..\Control\OWLFrontController.cpp,118) -IconPath
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.387] (..\Control\OWLFrontController.cpp,118) -Configuration/PS_exman_24px.png
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.387] (..\Control\OWLFrontController.cpp,118) -SupportedInSuite
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.387] (..\Control\OWLFrontController.cpp,118) -CS6
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.387] (..\Control\OWLFrontController.cpp,118) -HostNameForCSXS
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.387] (..\Control\OWLFrontController.cpp,118) -PHSP
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.388] (..\Control\OWLFrontController.cpp,118) -Bit
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.388] (..\Control\OWLFrontController.cpp,118) -32
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.388] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.388] (..\Control\OWLFrontController.cpp,165) -RequestId is-5. It is a request used to unlock OK/Cancel
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.390] (..\Control\macrgetXml_impl.cpp,111) -XML contents parse completed
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.392] (..\Products\MacrCommonProduct.cpp,401) -Product Name for photoshop-60.032 is Photoshop32
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.392] (..\MacrProduct.cpp,1317) -Display Name for photoshop-60.032 is Photoshop CS6 32
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.392] (..\Products\MacrCommonProduct.cpp,444) -Product version forPhotoshop CS6 32 is 13.0
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.393] (..\Products\MacrCommonProduct.cpp,463) -Language code for Photoshop CS6 32 is en_GB
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.393] (..\Products\MacrCommonProduct.cpp,191) -Icon Path for Photoshop CS6 32 is C:\Program Files\Adobe\Adobe Photoshop CS6\Configuration\PS_exman_24px.png
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.393] (..\Products\MacrCommonProduct.cpp,382) -Product Family Name for photoshop-60.032 is Photoshop
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.426] (..\MacrProduct.cpp,203) -The product photoshop-60.032 is supported by CS6
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.426] (..\MacrProduct.cpp,1459) -EMStore path per-machine for photoshop-60.032 is C:\ProgramData\Adobe\Extension Manager CS6\EM Store\Photoshop CS6 32\
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.427] (..\MacrProduct.cpp,1528) -MxiFlag path per-machine for photoshop-60.032 is C:\ProgramData\Adobe\Extension Manager CS6\Mxi Flag\Photoshop CS6 32\
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.431] (..\MacrProduct.cpp,203) -The product photoshop-60.032 is supported by CS6
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.431] (..\MacrProduct.cpp,1283) -Preferred folder for Photoshop CS6 32 is
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.433] (..\Products\MacrDreamweaver11_5.cpp,93) -Application path is
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.433] (..\MMFC\Source\MacrOS.cpp,1692) -=====Supported locales list items:=====
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.433] (..\MMFC\Source\MacrOS.cpp,1696) -en_US
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.433] (..\MMFC\Source\MacrOS.cpp,1696) -da_DK
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.433] (..\MMFC\Source\MacrOS.cpp,1696) -de_DE
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.433] (..\MMFC\Source\MacrOS.cpp,1696) -es_ES
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.433] (..\MMFC\Source\MacrOS.cpp,1696) -fi_FI
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.433] (..\MMFC\Source\MacrOS.cpp,1696) -fr_FR
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.434] (..\MMFC\Source\MacrOS.cpp,1696) -it_IT
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.434] (..\MMFC\Source\MacrOS.cpp,1696) -nb_NO
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.434] (..\MMFC\Source\MacrOS.cpp,1696) -nl_NL
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.434] (..\MMFC\Source\MacrOS.cpp,1696) -pt_BR
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.434] (..\MMFC\Source\MacrOS.cpp,1696) -sv_SE
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.435] (..\MMFC\Source\MacrOS.cpp,1716) -The User preferred language code is en_US
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.435] (..\MMFC\Source\MacrOS.cpp,1719) -en_US
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.435] (..\Products\MacrDreamweaver9.cpp,237) -Language code for Dreamweaver is en_US
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.435] (..\MacrProduct.cpp,211) -The product dreamweaver-11.5 is not supported by CS6
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.435] (..\MacrProduct.cpp,182) -The product dreamweaver-11.5 is not supported by CS5.5
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.436] (..\MacrProduct.cpp,1283) -Preferred folder for Dreamweaver CS5.5 is
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.436] (..\Products\MacrDreamweaver12.cpp,95) -Application path is C:\Program Files\Adobe\Adobe Dreamweaver CS6
                            [INFO] Sun Oct 28 13:30:45 2012 [.437] (..\MacrProductInfoFromCapsLib.cpp,389) -For product (C:\Program Files\Adobe\Adobe Dreamweaver CS6), replace the dummy language (en_GB) with primary language (en_US)
                            [INFO] Sun Oct 28 13:30:45 2012 [.437] (..\MacrProductInfoFromCapsLib.cpp,398) -For product (C:\Program Files\Adobe\Adobe Dreamweaver CS6), the installed languages are (en_US)
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.438] (..\MactProductInfoFromBridge.cpp,75) ----Begin to read xman configuration data file---
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.438] (..\MactProductInfoFromBridge.cpp,76) -The present xman data file is:
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.438] (..\MactProductInfoFromBridge.cpp,77) -C:\Program Files\Adobe\Adobe Dreamweaver CS6\Configuration\XManConfig.xml
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.439] (..\MactProductInfoFromBridge.cpp,86) ----End to read  xman configuration data file---
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.439] (..\Control\macrgetXml_impl.cpp,68) -Sending XML contents to AIR
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.439] (..\Control\OWLFrontController.cpp,400) --------------------Request (C++ side To AIR part ) Start--------------------------
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.439] (..\Control\OWLFrontController.cpp,403) -Method Name: airParseXML
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.439] (..\Control\OWLFrontController.cpp,420) --6
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.439] (..\Control\OWLFrontController.cpp,420) -C:\Program Files\Adobe\Adobe Dreamweaver CS6\Configuration\XManConfig.xml
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.440] (..\Control\OWLFrontController.cpp,420) -Configuration.VariableForExMan.Data
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.440] (..\Control\OWLFrontController.cpp,446) --------------------Request (C++ side To AIR part ) End---------------------------
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.446] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.447] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalCallBack
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.447] (..\Control\OWLFrontController.cpp,118) --6
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.447] (..\Control\OWLFrontController.cpp,118) -0
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.447] (..\Control\OWLFrontController.cpp,118) -$sharedextensionfolder
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.447] (..\Control\OWLFrontController.cpp,118) -$shareddatafolder/Adobe/Dreamweaver CS6/$LOCALE/Configuration/Extensions
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.447] (..\Control\OWLFrontController.cpp,118) -$dreamweaver
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.447] (..\Control\OWLFrontController.cpp,118) -$installfolder
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.447] (..\Control\OWLFrontController.cpp,118) -$dreamweaver/Configuration
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.448] (..\Control\OWLFrontController.cpp,118) -$userdatafolder/Adobe/Dreamweaver CS6/$LOCALE/Configuration
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.448] (..\Control\OWLFrontController.cpp,118) -$UserBinfolder
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.448] (..\Control\OWLFrontController.cpp,118) -NeedOperationNotification
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.448] (..\Control\OWLFrontController.cpp,118) -true
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.448] (..\Control\OWLFrontController.cpp,118) -QuitScript
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.448] (..\Control\OWLFrontController.cpp,118) -dw.quitApplication()
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.448] (..\Control\OWLFrontController.cpp,118) -SupportedInSuite
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.448] (..\Control\OWLFrontController.cpp,118) -CS6
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.449] (..\Control\OWLFrontController.cpp,118) -HostNameForCSXS
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.449] (..\Control\OWLFrontController.cpp,118) -DRWV
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.449] (..\Control\OWLFrontController.cpp,118) -ProductVersion
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.449] (..\Control\OWLFrontController.cpp,118) -12.0
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.449] (..\Control\OWLFrontController.cpp,118) -Bit
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.449] (..\Control\OWLFrontController.cpp,118) -32
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.449] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.449] (..\Control\OWLFrontController.cpp,165) -RequestId is-6. It is a request used to unlock OK/Cancel
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.450] (..\Control\macrgetXml_impl.cpp,111) -XML contents parse completed
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.451] (..\Products\MacrDreamweaver9.cpp,237) -Language code for Dreamweaver is en_US
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.451] (..\Products\MacrDreamweaver9.cpp,264) -Shared extension folder for Dreamweaver is C:\ProgramData\Adobe\Dreamweaver CS6\en_US\Configuration\Extensions\
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.452] (..\Products\MacrDreamweaver9.cpp,284) -User bin folder for Dreamweaver is C:\Users\***************\AppData\Roaming\Adobe\Dreamweaver CS6\en_US\
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.452] (..\Products\MacrDreamweaver9.cpp,297) -App configuration folder for Dreamweaver is C:\Program Files\Adobe\Adobe Dreamweaver CS6\Configuration
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.452] (..\MacrProduct.cpp,203) -The product dreamweaver-12.0 is supported by CS6
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.453] (..\MacrProduct.cpp,1459) -EMStore path per-machine for dreamweaver-12.0 is C:\ProgramData\Adobe\Extension Manager CS6\EM Store\Dreamweaver CS6\
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.453] (..\MacrProduct.cpp,203) -The product dreamweaver-12.0 is supported by CS6
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.453] (..\MacrProduct.cpp,1528) -MxiFlag path per-machine for dreamweaver-12.0 is C:\ProgramData\Adobe\Extension Manager CS6\Mxi Flag\Dreamweaver CS6\
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.454] (..\MacrProduct.cpp,1283) -Preferred folder for Dreamweaver CS6 is
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.455] (..\Products\MacrFireworks11_5.cpp,100) -Application path is
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.455] (..\MMFC\Source\MacrOS.cpp,1692) -=====Supported locales list items:=====
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.455] (..\MMFC\Source\MacrOS.cpp,1696) -en_US
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.455] (..\MMFC\Source\MacrOS.cpp,1696) -da_DK
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.455] (..\MMFC\Source\MacrOS.cpp,1696) -de_DE
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.456] (..\MMFC\Source\MacrOS.cpp,1696) -es_ES
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.456] (..\MMFC\Source\MacrOS.cpp,1696) -fi_FI
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.456] (..\MMFC\Source\MacrOS.cpp,1696) -fr_FR
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.456] (..\MMFC\Source\MacrOS.cpp,1696) -it_IT
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.456] (..\MMFC\Source\MacrOS.cpp,1696) -nb_NO
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.456] (..\MMFC\Source\MacrOS.cpp,1696) -nl_NL
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.456] (..\MMFC\Source\MacrOS.cpp,1696) -pt_BR
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.456] (..\MMFC\Source\MacrOS.cpp,1696) -sv_SE
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.457] (..\MMFC\Source\MacrOS.cpp,1716) -The User preferred language code is en_US
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.457] (..\MMFC\Source\MacrOS.cpp,1719) -en_US
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.457] (..\Products\MacrFireworks9.cpp,375) -Language code for Fireworks CS4 is en
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.457] (..\MacrProduct.cpp,211) -The product fireworks-11.1 is not supported by CS6
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.457] (..\MacrProduct.cpp,182) -The product fireworks-11.1 is not supported by CS5.5
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.458] (..\MacrProduct.cpp,211) -The product fireworks-11.1 is not supported by CS6
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.458] (..\MacrProduct.cpp,1283) -Preferred folder for Fireworks CS5.1 is
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.459] (..\Products\MacrFireworks12.cpp,100) -Application path is C:\Program Files\Adobe\Adobe Fireworks CS6
                            [INFO] Sun Oct 28 13:30:45 2012 [.459] (..\MacrProductInfoFromCapsLib.cpp,360) -For product (C:\Program Files\Adobe\Adobe Fireworks CS6), the installed languages are (en_GB)
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.460] (..\MactProductInfoFromBridge.cpp,75) ----Begin to read xman configuration data file---
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.460] (..\MactProductInfoFromBridge.cpp,76) -The present xman data file is:
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.460] (..\MactProductInfoFromBridge.cpp,77) -C:\Program Files\Adobe\Adobe Fireworks CS6\Configuration\XManConfig.xml
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.460] (..\MactProductInfoFromBridge.cpp,86) ----End to read  xman configuration data file---
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.461] (..\Control\macrgetXml_impl.cpp,68) -Sending XML contents to AIR
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.461] (..\Control\OWLFrontController.cpp,400) --------------------Request (C++ side To AIR part ) Start--------------------------
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.461] (..\Control\OWLFrontController.cpp,403) -Method Name: airParseXML
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.461] (..\Control\OWLFrontController.cpp,420) --7
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.461] (..\Control\OWLFrontController.cpp,420) -C:\Program Files\Adobe\Adobe Fireworks CS6\Configuration\XManConfig.xml
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.461] (..\Control\OWLFrontController.cpp,420) -Configuration.VariableForExMan.Data
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.461] (..\Control\OWLFrontController.cpp,446) --------------------Request (C++ side To AIR part ) End---------------------------
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.485] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.485] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalCallBack
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.485] (..\Control\OWLFrontController.cpp,118) --7
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.485] (..\Control\OWLFrontController.cpp,118) -0
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.485] (..\Control\OWLFrontController.cpp,118) -HostNameForCSXS
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.485] (..\Control\OWLFrontController.cpp,118) -FWKS
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.485] (..\Control\OWLFrontController.cpp,118) -ProductVersion
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.486] (..\Control\OWLFrontController.cpp,118) -12.0
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.486] (..\Control\OWLFrontController.cpp,118) -PreExtensionFolder
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.486] (..\Control\OWLFrontController.cpp,118) -$SharedCommonDataFolder/Adobe/Fireworks CS6/PreInstall
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.486] (..\Control\OWLFrontController.cpp,118) -$fireworks
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.486] (..\Control\OWLFrontController.cpp,118) -$installfolder
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.486] (..\Control\OWLFrontController.cpp,118) -$fireworksuser
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.486] (..\Control\OWLFrontController.cpp,118) -$userdatafolder/adobe/Fireworks CS6
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.486] (..\Control\OWLFrontController.cpp,118) -SupportedInSuite
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.486] (..\Control\OWLFrontController.cpp,118) -CS6
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.486] (..\Control\OWLFrontController.cpp,118) -Bit
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.486] (..\Control\OWLFrontController.cpp,118) -32
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.486] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.486] (..\Control\OWLFrontController.cpp,165) -RequestId is-7. It is a request used to unlock OK/Cancel
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.486] (..\Control\macrgetXml_impl.cpp,111) -XML contents parse completed
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.487] (..\MMFC\Source\MacrOS.cpp,1692) -=====Supported locales list items:=====
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.487] (..\MMFC\Source\MacrOS.cpp,1696) -en_US
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.487] (..\MMFC\Source\MacrOS.cpp,1696) -da_DK
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.487] (..\MMFC\Source\MacrOS.cpp,1696) -de_DE
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.487] (..\MMFC\Source\MacrOS.cpp,1696) -es_ES
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.487] (..\MMFC\Source\MacrOS.cpp,1696) -fi_FI
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.487] (..\MMFC\Source\MacrOS.cpp,1696) -fr_FR
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.487] (..\MMFC\Source\MacrOS.cpp,1696) -it_IT
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.487] (..\MMFC\Source\MacrOS.cpp,1696) -nb_NO
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.487] (..\MMFC\Source\MacrOS.cpp,1696) -nl_NL
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.487] (..\MMFC\Source\MacrOS.cpp,1696) -pt_BR
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.487] (..\MMFC\Source\MacrOS.cpp,1696) -sv_SE
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.488] (..\MMFC\Source\MacrOS.cpp,1716) -The User preferred language code is en_US
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.488] (..\MMFC\Source\MacrOS.cpp,1719) -en_US
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.488] (..\Products\MacrFireworks9.cpp,375) -Language code for Fireworks CS4 is en
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.488] (..\MacrProduct.cpp,203) -The product fireworks-12.0 is supported by CS6
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.489] (..\MacrProduct.cpp,1459) -EMStore path per-machine for fireworks-12.0 is C:\ProgramData\Adobe\Extension Manager CS6\EM Store\Fireworks CS6\
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.489] (..\MacrProduct.cpp,203) -The product fireworks-12.0 is supported by CS6
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.489] (..\MacrProduct.cpp,1528) -MxiFlag path per-machine for fireworks-12.0 is C:\ProgramData\Adobe\Extension Manager CS6\Mxi Flag\Fireworks CS6\
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.489] (..\MacrProduct.cpp,1283) -Preferred folder for Fireworks CS6 is C:\ProgramData\Adobe\Fireworks CS6\PreInstall\
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.490] (..\MMFC\Source\MacrOS.cpp,4285) -The current operating system is 2,major version is 6,minor version is 1***********
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.491] (..\MMFC\Source\MacrOS.cpp,1692) -=====Supported locales list items:=====
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.491] (..\MMFC\Source\MacrOS.cpp,1696) -en_US
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.491] (..\MMFC\Source\MacrOS.cpp,1696) -da_DK
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.491] (..\MMFC\Source\MacrOS.cpp,1696) -de_DE
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.491] (..\MMFC\Source\MacrOS.cpp,1696) -es_ES
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.492] (..\MMFC\Source\MacrOS.cpp,1696) -fi_FI
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.492] (..\MMFC\Source\MacrOS.cpp,1696) -fr_FR
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.492] (..\MMFC\Source\MacrOS.cpp,1696) -it_IT
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.492] (..\MMFC\Source\MacrOS.cpp,1696) -nb_NO
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.492] (..\MMFC\Source\MacrOS.cpp,1696) -nl_NL
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.492] (..\MMFC\Source\MacrOS.cpp,1696) -pt_BR
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.492] (..\MMFC\Source\MacrOS.cpp,1696) -sv_SE
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.492] (..\MMFC\Source\MacrOS.cpp,1716) -The User preferred language code is en_US
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.492] (..\MMFC\Source\MacrOS.cpp,1719) -en_US
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.492] (..\Products\MacrFlash11_5.cpp,580) -The User perferred language code is en_US
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.492] (..\Products\MacrFlash11_5.cpp,449) -The present language code for Flash CS5 is en_US
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.493] (..\Products\MacrFlash11_5.cpp,472) -Application path is
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.493] (..\MMFC\Source\MacrOS.cpp,1692) -=====Supported locales list items:=====
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.493] (..\MMFC\Source\MacrOS.cpp,1696) -en_US
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.493] (..\MMFC\Source\MacrOS.cpp,1696) -da_DK
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.493] (..\MMFC\Source\MacrOS.cpp,1696) -de_DE
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.493] (..\MMFC\Source\MacrOS.cpp,1696) -es_ES
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.493] (..\MMFC\Source\MacrOS.cpp,1696) -fi_FI
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.493] (..\MMFC\Source\MacrOS.cpp,1696) -fr_FR
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.493] (..\MMFC\Source\MacrOS.cpp,1696) -it_IT
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.493] (..\MMFC\Source\MacrOS.cpp,1696) -nb_NO
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.493] (..\MMFC\Source\MacrOS.cpp,1696) -nl_NL
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.493] (..\MMFC\Source\MacrOS.cpp,1696) -pt_BR
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.493] (..\MMFC\Source\MacrOS.cpp,1696) -sv_SE
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.493] (..\MMFC\Source\MacrOS.cpp,1716) -The User preferred language code is en_US
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.494] (..\MMFC\Source\MacrOS.cpp,1719) -en_US
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.494] (..\Products\MacrFlash11_5.cpp,580) -The User perferred language code is en_US
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.494] (..\Products\MacrFlash9.cpp,183) -Language code for Flash is en_US
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.494] (..\MacrProduct.cpp,211) -The product flash-11.5 is not supported by CS6
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.494] (..\MacrProduct.cpp,182) -The product flash-11.5 is not supported by CS5.5
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.494] (..\MMFC\Source\MacrOS.cpp,4285) -The current operating system is 2,major version is 6,minor version is 1***********
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.495] (..\Products\MacrFlash12.cpp,464) -Application path is C:\Program Files\Adobe\Adobe Flash CS6
                            [INFO] Sun Oct 28 13:30:45 2012 [.495] (..\MacrProductInfoFromCapsLib.cpp,389) -For product (C:\Program Files\Adobe\Adobe Flash CS6), replace the dummy language (en_GB) with primary language (en_US)
                            [INFO] Sun Oct 28 13:30:45 2012 [.495] (..\MacrProductInfoFromCapsLib.cpp,398) -For product (C:\Program Files\Adobe\Adobe Flash CS6), the installed languages are (en_US)
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.495] (..\MactProductInfoFromBridge.cpp,75) ----Begin to read xman configuration data file---
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.495] (..\MactProductInfoFromBridge.cpp,76) -The present xman data file is:
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.495] (..\MactProductInfoFromBridge.cpp,77) -C:\Program Files\Adobe\Adobe Flash CS6\XManConfig.xml
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.496] (..\MactProductInfoFromBridge.cpp,86) ----End to read  xman configuration data file---
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.496] (..\Control\macrgetXml_impl.cpp,68) -Sending XML contents to AIR
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.496] (..\Control\OWLFrontController.cpp,400) --------------------Request (C++ side To AIR part ) Start--------------------------
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.496] (..\Control\OWLFrontController.cpp,403) -Method Name: airParseXML
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.496] (..\Control\OWLFrontController.cpp,420) --8
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.496] (..\Control\OWLFrontController.cpp,420) -C:\Program Files\Adobe\Adobe Flash CS6\XManConfig.xml
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.496] (..\Control\OWLFrontController.cpp,420) -Configuration.VariableForExMan.Data
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.496] (..\Control\OWLFrontController.cpp,446) --------------------Request (C++ side To AIR part ) End---------------------------
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.527] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.527] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalCallBack
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.527] (..\Control\OWLFrontController.cpp,118) --8
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.527] (..\Control\OWLFrontController.cpp,118) -0
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.527] (..\Control\OWLFrontController.cpp,118) -$UserExtensionFolder
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.528] (..\Control\OWLFrontController.cpp,118) -$UserDataFolder/Adobe/Flash CS6/$Locale/Configuration/Extensions
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.528] (..\Control\OWLFrontController.cpp,118) -SupportedInSuite
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.528] (..\Control\OWLFrontController.cpp,118) -CS6
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.528] (..\Control\OWLFrontController.cpp,118) -HostNameForCSXS
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.528] (..\Control\OWLFrontController.cpp,118) -FLPR
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.528] (..\Control\OWLFrontController.cpp,118) -Bit
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.528] (..\Control\OWLFrontController.cpp,118) -32
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.529] (..\Control\OWLFrontController.cpp,118) -$RootFolder
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.529] (..\Control\OWLFrontController.cpp,118) -$InstallFolder
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.529] (..\Control\OWLFrontController.cpp,118) -$RootFolderLocal
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.529] (..\Control\OWLFrontController.cpp,118) -$InstallFolder/$LOCALE
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.529] (..\Control\OWLFrontController.cpp,118) -$flash
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.529] (..\Control\OWLFrontController.cpp,118) -$userdatafolder/Adobe/Flash CS6/$LOCALE/Configuration
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.529] (..\Control\OWLFrontController.cpp,118) -$UserBinfolder
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.530] (..\Control\OWLFrontController.cpp,118) -$userdatafolder/Adobe/Flash CS6/$LOCALE/Configuration
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.530] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.530] (..\Control\OWLFrontController.cpp,165) -RequestId is-8. It is a request used to unlock OK/Cancel
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.531] (..\Control\macrgetXml_impl.cpp,111) -XML contents parse completed
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.531] (..\Products\MacrFlash9.cpp,183) -Language code for Flash is en_US
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.533] (..\Products\MacrFlash9.cpp,215) -User bin folder for Flash is C:\Users\***************\AppData\Local\Adobe\Flash CS6\en_US\Configuration\
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.533] (..\MacrProduct.cpp,203) -The product flash-12.0 is supported by CS6
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.534] (..\MacrProduct.cpp,1459) -EMStore path per-machine for flash-12.0 is C:\ProgramData\Adobe\Extension Manager CS6\EM Store\Flash CS6\
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.534] (..\MacrProduct.cpp,203) -The product flash-12.0 is supported by CS6
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.535] (..\MacrProduct.cpp,1528) -MxiFlag path per-machine for flash-12.0 is C:\ProgramData\Adobe\Extension Manager CS6\Mxi Flag\Flash CS6\
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.535] (..\MacrProduct.cpp,1283) -Preferred folder for Flash CS6 is
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.570] (..\MMFC\Source\MacrOS.cpp,2289) -Going to change the permission of folder [C:\ProgramData\Adobe\Extension Manager CS6\EM Store\Illustrator CS6 32], with command: [cacls.exe], parameter: ["C:\ProgramData\Adobe\Extension Manager CS6\EM Store\Illustrator CS6 32" /T /E /C /G BUILTIN\Users:F]
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.645] (..\MMFC\Source\MacrOS.cpp,2294) -Succeed to make this folder writable for all users.
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.661] (..\MMFC\Source\MacrOS.cpp,2289) -Going to change the permission of folder [C:\ProgramData\Adobe\Extension Manager CS6\Mxi Flag\Illustrator CS6 32], with command: [cacls.exe], parameter: ["C:\ProgramData\Adobe\Extension Manager CS6\Mxi Flag\Illustrator CS6 32" /T /E /C /G BUILTIN\Users:F]
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.669] (..\MMFC\Source\MacrOS.cpp,2294) -Succeed to make this folder writable for all users.
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.669] (..\MMFC\Source\MacrOS.cpp,2289) -Going to change the permission of folder [C:\ProgramData\Adobe\Extension Manager CS6\Configuration], with command: [cacls.exe], parameter: ["C:\ProgramData\Adobe\Extension Manager CS6\Configuration" /T /E /C /G BUILTIN\Users:F]
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.679] (..\MMFC\Source\MacrOS.cpp,2294) -Succeed to make this folder writable for all users.
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.680] (..\MMFC\Source\MacrOS.cpp,2289) -Going to change the permission of folder [C:\ProgramData\Adobe\Extension Manager CS6\Configuration\DB], with command: [cacls.exe], parameter: ["C:\ProgramData\Adobe\Extension Manager CS6\Configuration\DB" /T /E /C /G BUILTIN\Users:F]
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.708] (..\MMFC\Source\MacrOS.cpp,2294) -Succeed to make this folder writable for all users.
                            [INFO] Sun Oct 28 13:30:45 2012 [.709] (..\DBWrapper.cpp,2118) -Database connection is established successfully.
                            [ERROR] Sun Oct 28 13:30:45 2012 [.714] (..\DBWrapper.cpp,2217) -Failed to attach user database, returned error message is:
                            [ERROR] Sun Oct 28 13:30:45 2012 [.714] (..\DBWrapper.cpp,2218) -near "s": syntax error
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.715] (..\MMFC\Source\MacrOS.cpp,2289) -Going to change the permission of folder [C:\ProgramData\Adobe\Extension Manager CS6\EM Store\InDesign CS6], with command: [cacls.exe], parameter: ["C:\ProgramData\Adobe\Extension Manager CS6\EM Store\InDesign CS6" /T /E /C /G BUILTIN\Users:F]
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.721] (..\MMFC\Source\MacrOS.cpp,2294) -Succeed to make this folder writable for all users.
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.735] (..\MMFC\Source\MacrOS.cpp,2289) -Going to change the permission of folder [C:\ProgramData\Adobe\Extension Manager CS6\Mxi Flag\InDesign CS6], with command: [cacls.exe], parameter: ["C:\ProgramData\Adobe\Extension Manager CS6\Mxi Flag\InDesign CS6" /T /E /C /G BUILTIN\Users:F]
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.742] (..\MMFC\Source\MacrOS.cpp,2294) -Succeed to make this folder writable for all users.
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.744] (..\MMFC\Source\MacrOS.cpp,2289) -Going to change the permission of folder [C:\ProgramData\Adobe\Extension Manager CS6\EM Store\Photoshop CS6 32], with command: [cacls.exe], parameter: ["C:\ProgramData\Adobe\Extension Manager CS6\EM Store\Photoshop CS6 32" /T /E /C /G BUILTIN\Users:F]
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.752] (..\MMFC\Source\MacrOS.cpp,2294) -Succeed to make this folder writable for all users.
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.753] (..\MMFC\Source\MacrOS.cpp,2289) -Going to change the permission of folder [C:\ProgramData\Adobe\Extension Manager CS6\Mxi Flag\Photoshop CS6 32], with command: [cacls.exe], parameter: ["C:\ProgramData\Adobe\Extension Manager CS6\Mxi Flag\Photoshop CS6 32" /T /E /C /G BUILTIN\Users:F]
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.763] (..\MMFC\Source\MacrOS.cpp,2294) -Succeed to make this folder writable for all users.
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.765] (..\MMFC\Source\MacrOS.cpp,2289) -Going to change the permission of folder [C:\ProgramData\Adobe\Extension Manager CS6\EM Store\Dreamweaver CS6], with command: [cacls.exe], parameter: ["C:\ProgramData\Adobe\Extension Manager CS6\EM Store\Dreamweaver CS6" /T /E /C /G BUILTIN\Users:F]
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.773] (..\MMFC\Source\MacrOS.cpp,2294) -Succeed to make this folder writable for all users.
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.774] (..\MMFC\Source\MacrOS.cpp,2289) -Going to change the permission of folder [C:\ProgramData\Adobe\Extension Manager CS6\Mxi Flag\Dreamweaver CS6], with command: [cacls.exe], parameter: ["C:\ProgramData\Adobe\Extension Manager CS6\Mxi Flag\Dreamweaver CS6" /T /E /C /G BUILTIN\Users:F]
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.780] (..\MMFC\Source\MacrOS.cpp,2294) -Succeed to make this folder writable for all users.
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.782] (..\MMFC\Source\MacrOS.cpp,2289) -Going to change the permission of folder [C:\ProgramData\Adobe\Extension Manager CS6\EM Store\Fireworks CS6], with command: [cacls.exe], parameter: ["C:\ProgramData\Adobe\Extension Manager CS6\EM Store\Fireworks CS6" /T /E /C /G BUILTIN\Users:F]
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.788] (..\MMFC\Source\MacrOS.cpp,2294) -Succeed to make this folder writable for all users.
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.789] (..\MMFC\Source\MacrOS.cpp,2289) -Going to change the permission of folder [C:\ProgramData\Adobe\Extension Manager CS6\Mxi Flag\Fireworks CS6], with command: [cacls.exe], parameter: ["C:\ProgramData\Adobe\Extension Manager CS6\Mxi Flag\Fireworks CS6" /T /E /C /G BUILTIN\Users:F]
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.800] (..\MMFC\Source\MacrOS.cpp,2294) -Succeed to make this folder writable for all users.
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.802] (..\MMFC\Source\MacrOS.cpp,2289) -Going to change the permission of folder [C:\ProgramData\Adobe\Extension Manager CS6\EM Store\Flash CS6], with command: [cacls.exe], parameter: ["C:\ProgramData\Adobe\Extension Manager CS6\EM Store\Flash CS6" /T /E /C /G BUILTIN\Users:F]
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.810] (..\MMFC\Source\MacrOS.cpp,2294) -Succeed to make this folder writable for all users.
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.812] (..\MMFC\Source\MacrOS.cpp,2289) -Going to change the permission of folder [C:\ProgramData\Adobe\Extension Manager CS6\Mxi Flag\Flash CS6], with command: [cacls.exe], parameter: ["C:\ProgramData\Adobe\Extension Manager CS6\Mxi Flag\Flash CS6" /T /E /C /G BUILTIN\Users:F]
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.819] (..\MMFC\Source\MacrOS.cpp,2294) -Succeed to make this folder writable for all users.
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.820] (..\MacrExtensionManager.cpp,1385) -All products hav been processed and saved in DB
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.821] (..\MacrExtensionManager.cpp,1486) -Extension Manager initialization finished.
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.821] (..\Control\commandExecutor.cpp,40) -OWL Controller initialized succeed
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.821] (..\Control\OWLFrontController.cpp,400) --------------------Request (C++ side To AIR part ) Start--------------------------
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.822] (..\Control\OWLFrontController.cpp,403) -Method Name: airNotifyReady
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.822] (..\Control\OWLFrontController.cpp,420) --9
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.822] (..\Control\OWLFrontController.cpp,446) --------------------Request (C++ side To AIR part ) End---------------------------
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.831] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.831] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalGetExManConfigPath
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.831] (..\Control\OWLFrontController.cpp,118) -2
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.831] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.831] (..\Control\getExManConfigPathCommand.cpp,66) -ExMan machine EMStore path: C:\ProgramData\Adobe\Extension Manager CS6\EM Store\
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.831] (..\Control\getExManConfigPathCommand.cpp,85) -ExMan my EMStore path: C:\Users\***************\AppData\Roaming\Adobe\Extension Manager CS6\EM Store\
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.831] (..\Control\getExManConfigPathCommand.cpp,92) -Version number is:
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.832] (..\Control\getExManConfigPathCommand.cpp,93) -6.0.412
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.832] (..\Control\OWLFrontController.cpp,400) --------------------Request (C++ side To AIR part ) Start--------------------------
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.832] (..\Control\OWLFrontController.cpp,403) -Method Name: airCallBack
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.832] (..\Control\OWLFrontController.cpp,420) -2
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.832] (..\Control\OWLFrontController.cpp,420[) -DEBUG0]
                            Sun Oct 28 13:30:45 2012 [.832] ([..\Control\OWLFrontController.cppDEBUG,] 95Sun Oct 28 13:30:45 2012 [.833]) - (-----------------AIR request To C++ Start-----------------------------------------------
                            ..\Control\OWLFrontController.cpp,420) -C:\ProgramData\Adobe\Extension Manager CS6\EM Store\[
                            DEBUG] Sun Oct 28 13:30:45 2012 [.833] (..\Control\OWLFrontController.cpp[,DEBUG98] ) -Sun Oct 28 13:30:45 2012 [.833]Receive the request from AIR, Request name is externalGetSupportedProducts (
                            ..\Control\OWLFrontController.cpp,420) -C:\Users\***************\AppData\Roaming\Adobe\Extension Manager CS6\EM Store\
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.833][ (DEBUG..\Control\OWLFrontController.cpp] ,Sun Oct 28 13:30:45 2012 [.833]118 () -..\Control\OWLFrontController.cpp3,
                            420) -6.0.412
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.833][ (DEBUG..\Control\OWLFrontController.cpp] ,Sun Oct 28 13:30:45 2012 [.833]142 () -..\Control\OWLFrontController.cpp----------------AIR request To C++ End--------------------------------------------------
                            ,420) -C:\Users\***************\AppData\Roaming\Adobe\Extension Manager CS5.5\Configuration\Extensions\
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.833] (..\Control\OWLFrontController.cpp,420) -C:\ProgramData\Adobe\Extension Manager CS6\
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.833] (..\Control\OWLFrontController.cpp,420) -C:\ProgramData\Adobe\Extension Manager CS5.5\
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.834] (..\Control\OWLFrontController.cpp,420) -C:\Program Files
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.834] (..\Control\OWLFrontController.cpp,446) --------------------Request (C++ side To AIR part ) End---------------------------
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.835] (..\Control\GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : 0
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.835] (..\Control\GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : Flash CS6
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.835] (..\Control\GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : 12.0.0
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.835] (..\Control\GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : C:\ProgramData\Adobe\Extension Manager CS6\Mxi Flag\Flash CS6\
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.836] (..\Control\GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : C:\Users\***************\AppData\Roaming\Adobe\Extension Manager CS6\Mxi Flag\Flash CS6\
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.836] (..\Control\GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : http://www.adobe.com/go/exchange
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.836] (..\Control\GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : NoDefined
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.836] (..\Control\GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : http://www.adobe.com/cfusion/exchange/upload/index.cfm
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.836] (..\Control\GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : Flash
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.836] (..\Control\GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : C:\ProgramData\Adobe\Extension Manager CS6\EM Store\Flash CS6\
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.837] (..\Control\GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : C:\Users\***************\AppData\Roaming\Adobe\Extension Manager CS6\EM Store\Flash CS6\
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.837] (..\Control\GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : 0
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.837] (..\Control\GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : FLPR
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.838] (..\Control\GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter :
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.838] (..\Control\GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : 1
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.838] (..\Control\GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : C:\Program Files\Adobe\Adobe Flash CS6\
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.841] (..\Control\GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : 0
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.841] (..\Control\GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : Fireworks CS6
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.841] (..\Control\GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : 12.0.0
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.841] (..\Control\GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : C:\ProgramData\Adobe\Extension Manager CS6\Mxi Flag\Fireworks CS6\
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.842] (..\Control\GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : C:\Users\***************\AppData\Roaming\Adobe\Extension Manager CS6\Mxi Flag\Fireworks CS6\
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.842] (..\Control\GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : http://www.adobe.com/go/exchange
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.842] (..\Control\GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : NoDefined
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.842] (..\Control\GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : http://www.adobe.com/cfusion/exchange/upload/index.cfm
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.842] (..\Control\GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : Fireworks
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.843] (..\Control\GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : C:\ProgramData\Adobe\Extension Manager CS6\EM Store\Fireworks CS6\
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.843] (..\Control\GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : C:\Users\***************\AppData\Roaming\Adobe\Extension Manager CS6\EM Store\Fireworks CS6\
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.843] (..\Control\GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : 0
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.843] (..\Control\GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : FWKS
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.844] (..\Control\GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter :
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.844] (..\Control\GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : 1
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.844] (..\Control\GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : C:\Program Files\Adobe\Adobe Fireworks CS6\Configuration\
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.845] (..\Control\GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : 0
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.845] (..\Control\GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : Dreamweaver CS6
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.845] (..\Control\GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : 12.0.0
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.846] (..\Control\GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : C:\ProgramData\Adobe\Extension Manager CS6\Mxi Flag\Dreamweaver CS6\
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.846] (..\Control\GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : C:\Users\***************\AppData\Roaming\Adobe\Extension Manager CS6\Mxi Flag\Dreamweaver CS6\
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.846] (..\Control\GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : http://www.adobe.com/go/exchange
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.846] (..\Control\GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : NoDefined
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.847] (..\Control\GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : http://www.adobe.com/cfusion/exchange/upload/index.cfm
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.847] (..\Control\GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : Dreamweaver
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.847] (..\Control\GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : C:\ProgramData\Adobe\Extension Manager CS6\EM Store\Dreamweaver CS6\
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.847] (..\Control\GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : C:\Users\***************\AppData\Roaming\Adobe\Extension Manager CS6\EM Store\Dreamweaver CS6\
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.847] (..\Control\GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : 0
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.848] (..\Control\GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : DRWV
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.848] (..\Control\GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : 1
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.848] (..\Control\GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : C:\Program Files\Adobe\Adobe Dreamweaver CS6\Configuration\
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.851] (..\Control\GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : 0
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.851] (..\Control\GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : Photoshop CS6 32
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.851] (..\Control\GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : Photoshop32
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.851] (..\Control\GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : 13.0.0
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.851] (..\Control\GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : C:\ProgramData\Adobe\Extension Manager CS6\Mxi Flag\Photoshop CS6 32\
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.851] (..\Control\GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : C:\Users\***************\AppData\Roaming\Adobe\Extension Manager CS6\Mxi Flag\Photoshop CS6 32\
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.852] (..\Control\GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : C:\Users\***************\AppData\Roaming\Adobe\Extension Manager CS6\Mxi Flag\Photoshop CS6 32\
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.852] (..\Control\GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : http://www.adobe.com/go/exchange
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.852] (..\Control\GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : C:\Program Files\Adobe\Adobe Photoshop CS6\Configuration\PS_exman_24px.png
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.852] (..\Control\GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : http://www.adobe.com/cfusion/exchange/upload/index.cfm
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.852] (..\Control\GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : Photoshop
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.852] (..\Control\GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : C:\ProgramData\Adobe\Extension Manager CS6\EM Store\Photoshop CS6 32\
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.853] (..\Control\GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : C:\Users\***************\AppData\Roaming\Adobe\Extension Manager CS6\EM Store\Photoshop CS6 32\
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.853] (..\Control\GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : 0
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.853] (..\Control\GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : PHSP
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.854] (..\Control\GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : 1
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.854] (..\Control\GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : C:\Program Files\Adobe\Adobe Photoshop CS6\Configuration\
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.855] (..\Control\GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : 0
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.855] (..\Control\GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : InDesign CS6
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.855] (..\Control\GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : 8.0.0
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.855] (..\Control\GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : C:\ProgramData\Adobe\Extension Manager CS6\Mxi Flag\InDesign CS6\
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.856] (..\Control\GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : C:\Users\***************\AppData\Roaming\Adobe\Extension Manager CS6\Mxi Flag\InDesign CS6\
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.856] (..\Control\GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : http://www.adobe.com/go/exchange
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.856] (..\Control\GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : C:\Program Files\Adobe\Adobe InDesign CS6\Configuration\Icon.png
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.856] (..\Control\GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : http://www.adobe.com/cfusion/exchange/upload/index.cfm
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.857] (..\Control\GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : C:\ProgramData\Adobe\Extension Manager CS6\EM Store\InDesign CS6\
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.857] (..\Control\GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : C:\Users\***************\AppData\Roaming\Adobe\Extension Manager CS6\EM Store\InDesign CS6\
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.857] (..\Control\GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : 1
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.857] (..\Control\GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : IDSN
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.858] (..\Control\GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : C:\Users\***************\AppData\Roaming\Adobe\InDesign\Version 8.0\en_GB\PlugInConfig.txt
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.858] (..\Control\GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : Adobe InDesign CS6
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.858] (..\Control\GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : 1
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.858] (..\Control\GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : C:\Program Files\Adobe\Adobe InDesign CS6\Configuration\
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.859] (..\Control\GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : 0
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.859] (..\Control\GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : Illustrator CS6 32
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.859] (..\Control\GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : Illustrator32
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.859] (..\Control\GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : 16.0.0
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.860] (..\Control\GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : C:\ProgramData\Adobe\Extension Manager CS6\Mxi Flag\Illustrator CS6 32\
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.860] (..\Control\GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : C:\Users\***************\AppData\Roaming\Adobe\Extension Manager CS6\Mxi Flag\Illustrator CS6 32\
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.860] (..\Control\GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : http://www.adobe.com/go/exchange
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.860] (..\Control\GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : C:\Program Files\Adobe\Adobe Illustrator CS6\Support Files\Contents\Windows\Configuration\ai_app_24px.png
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.861] (..\Control\GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : http://www.adobe.com/cfusion/exchange/upload/index.cfm
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.861] (..\Control\GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : Illustrator
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.861] (..\Control\GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : C:\ProgramData\Adobe\Extension Manager CS6\EM Store\Illustrator CS6 32\
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.861] (..\Control\GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : C:\Users\***************\AppData\Roaming\Adobe\Extension Manager CS6\EM Store\Illustrator CS6 32\
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.861] (..\Control\GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : 0
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.862] (..\Control\GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : 0
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.862] (..\Control\GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : ILST
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.862] (..\Control\GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : 1
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.862] (..\Control\GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : C:\Program Files\Adobe\Adobe Illustrator CS6\Support Files\Contents\Windows\Configuration\
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.862] (..\Control\OWLFrontController.cpp,400) --------------------Request (C++ side To AIR part ) Start--------------------------
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.862] (..\Control\OWLFrontController.cpp,403) -Method Name: airCallBack
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.863] (..\Control\OWLFrontController.cpp,420) -3
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.863] (..\Control\OWLFrontController.cpp,420) -0
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.863] (..\Control\OWLFrontController.cpp,420) -Flash CS6
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.863] (..\Control\OWLFrontController.cpp,420) -12.0.0
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.863] (..\Control\OWLFrontController.cpp,420) -C:\ProgramData\Adobe\Extension Manager CS6\Mxi Flag\Flash CS6\
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.863] (..\Control\OWLFrontController.cpp,420) -C:\Users\***************\AppData\Roaming\Adobe\Extension Manager CS6\Mxi Flag\Flash CS6\
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.864] (..\Control\OWLFrontController.cpp,420) -C:\Users\***************\AppData\Roaming\Adobe\Extension Manager CS6\Mxi Flag\Flash CS6\
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.864] (..\Control\OWLFrontController.cpp,420) -http://www.adobe.com/go/exchange
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.864] (..\Control\OWLFrontController.cpp,420) -NoDefined
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.864] (..\Control\OWLFrontController.cpp,420) -http://www.adobe.com/cfusion/exchange/upload/index.cfm
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.864] (..\Control\OWLFrontController.cpp,420) -Flash
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.864] (..\Control\OWLFrontController.cpp,420) -C:\ProgramData\Adobe\Extension Manager CS6\EM Store\Flash CS6\
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.864] (..\Control\OWLFrontController.cpp,420) -C:\Users\***************\AppData\Roaming\Adobe\Extension Manager CS6\EM Store\Flash CS6\
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.865] (..\Control\OWLFrontController.cpp,420) -0
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.865] (..\Control\OWLFrontController.cpp,420) -FLPR
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.865] (..\Control\OWLFrontController.cpp,420) -1
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.865] (..\Control\OWLFrontController.cpp,420) -C:\Program Files\Adobe\Adobe Flash CS6\
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.865] (..\Control\OWLFrontController.cpp,420) -Fireworks CS6
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.866] (..\Control\OWLFrontController.cpp,420) -12.0.0
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.866] (..\Control\OWLFrontController.cpp,420) -C:\ProgramData\Adobe\Extension Manager CS6\Mxi Flag\Fireworks CS6\
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.866] (..\Control\OWLFrontController.cpp,420) -C:\Users\***************\AppData\Roaming\Adobe\Extension Manager CS6\Mxi Flag\Fireworks CS6\
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.866] (..\Control\OWLFrontController.cpp,420) -http://www.adobe.com/go/exchange
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.866] (..\Control\OWLFrontController.cpp,420) -NoDefined
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.866] (..\Control\OWLFrontController.cpp,420) -http://www.adobe.com/cfusion/exchange/upload/index.cfm
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.866] (..\Control\OWLFrontController.cpp,420) -Fireworks
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.867] (..\Control\OWLFrontController.cpp,420) -C:\ProgramData\Adobe\Extension Manager CS6\EM Store\Fireworks CS6\
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.867] (..\Control\OWLFrontController.cpp,420) -C:\Users\***************\AppData\Roaming\Adobe\Extension Manager CS6\EM Store\Fireworks CS6\
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.867] (..\Control\OWLFrontController.cpp,420) -0
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.867] (..\Control\OWLFrontController.cpp,420) -FWKS
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.867] (..\Control\OWLFrontController.cpp,420) -1
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.867] (..\Control\OWLFrontController.cpp,420) -C:\Program Files\Adobe\Adobe Fireworks CS6\Configuration\
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.868] (..\Control\OWLFrontController.cpp,420) -0
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.868] (..\Control\OWLFrontController.cpp,420) -Dreamweaver CS6
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.868] (..\Control\OWLFrontController.cpp,420) -12.0.0
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.868] (..\Control\OWLFrontController.cpp,420) -C:\ProgramData\Adobe\Extension Manager CS6\Mxi Flag\Dreamweaver CS6\
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.868] (..\Control\OWLFrontController.cpp,420) -C:\Users\***************\AppData\Roaming\Adobe\Extension Manager CS6\Mxi Flag\Dreamweaver CS6\
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.868] (..\Control\OWLFrontController.cpp,420) -http://www.adobe.com/go/exchange
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.868] (..\Control\OWLFrontController.cpp,420) -NoDefined
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.869] (..\Control\OWLFrontController.cpp,420) -http://www.adobe.com/cfusion/exchange/upload/index.cfm
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.869] (..\Control\OWLFrontController.cpp,420) -Dreamweaver
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.869] (..\Control\OWLFrontController.cpp,420) -C:\ProgramData\Adobe\Extension Manager CS6\EM Store\Dreamweaver CS6\
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.869] (..\Control\OWLFrontController.cpp,420) -C:\Users\***************\AppData\Roaming\Adobe\Extension Manager CS6\EM Store\Dreamweaver CS6\
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.869] (..\Control\OWLFrontController.cpp,420) -0
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.869] (..\Control\OWLFrontController.cpp,420) -DRWV
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.870] (..\Control\OWLFrontController.cpp,420) -1
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.870] (..\Control\OWLFrontController.cpp,420) -C:\Program Files\Adobe\Adobe Dreamweaver CS6\Configuration\
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.870] (..\Control\OWLFrontController.cpp,420) -0
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.870] (..\Control\OWLFrontController.cpp,420) -Photoshop CS6 32
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.870] (..\Control\OWLFrontController.cpp,420) -Photoshop32
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.870] (..\Control\OWLFrontController.cpp,420) -13.0.0
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.870] (..\Control\OWLFrontController.cpp,420) -C:\ProgramData\Adobe\Extension Manager CS6\Mxi Flag\Photoshop CS6 32\
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.870] (..\Control\OWLFrontController.cpp,420) -C:\Users\***************\AppData\Roaming\Adobe\Extension Manager CS6\Mxi Flag\Photoshop CS6 32\
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.871] (..\Control\OWLFrontController.cpp,420) -http://www.adobe.com/go/exchange
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.871] (..\Control\OWLFrontController.cpp,420) -C:\Program Files\Adobe\Adobe Photoshop CS6\Configuration\PS_exman_24px.png
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.871] (..\Control\OWLFrontController.cpp,420) -http://www.adobe.com/cfusion/exchange/upload/index.cfm
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.871] (..\Control\OWLFrontController.cpp,420) -Photoshop
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.871] (..\Control\OWLFrontController.cpp,420) -C:\ProgramData\Adobe\Extension Manager CS6\EM Store\Photoshop CS6 32\
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.871] (..\Control\OWLFrontController.cpp,420) -C:\Users\***************\AppData\Roaming\Adobe\Extension Manager CS6\EM Store\Photoshop CS6 32\
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.872] (..\Control\OWLFrontController.cpp,420) -0
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.872] (..\Control\OWLFrontController.cpp,420) -PHSP
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.872] (..\Control\OWLFrontController.cpp,420) -1
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.872] (..\Control\OWLFrontController.cpp,420) -C:\Program Files\Adobe\Adobe Photoshop CS6\Configuration\
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.872] (..\Control\OWLFrontController.cpp,420) -InDesign CS6
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.872] (..\Control\OWLFrontController.cpp,420) -8.0.0
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.873] (..\Control\OWLFrontController.cpp,420) -C:\ProgramData\Adobe\Extension Manager CS6\Mxi Flag\InDesign CS6\
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.873] (..\Control\OWLFrontController.cpp,420) -C:\Users\***************\AppData\Roaming\Adobe\Extension Manager CS6\Mxi Flag\InDesign CS6\
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.873] (..\Control\OWLFrontController.cpp,420) -http://www.adobe.com/go/exchange
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.873] (..\Control\OWLFrontController.cpp,420) -C:\Program Files\Adobe\Adobe InDesign CS6\Configuration\Icon.png
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.873] (..\Control\OWLFrontController.cpp,420) -http://www.adobe.com/cfusion/exchange/upload/index.cfm
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.873] (..\Control\OWLFrontController.cpp,420) -C:\ProgramData\Adobe\Extension Manager CS6\EM Store\InDesign CS6\
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.873] (..\Control\OWLFrontController.cpp,420) -C:\Users\***************\AppData\Roaming\Adobe\Extension Manager CS6\EM Store\InDesign CS6\
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.874] (..\Control\OWLFrontController.cpp,420) -C:\Users\***************\AppData\Roaming\Adobe\Extension Manager CS6\EM Store\InDesign CS6
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.874] (..\Control\OWLFrontController.cpp,420) -1
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.874] (..\Control\OWLFrontController.cpp,420) -IDSN
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.874] (..\Control\OWLFrontController.cpp,420) -C:\Users\***************\AppData\Roaming\Adobe\InDesign\Version 8.0\en_GB\PlugInConfig.txt
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.874] (..\Control\OWLFrontController.cpp,420) -Adobe InDesign CS6
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.874] (..\Control\OWLFrontController.cpp,420) -C:\Program Files\Adobe\Adobe InDesign CS6\Configuration\
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.874] (..\Control\OWLFrontController.cpp,420) -0
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.875] (..\Control\OWLFrontController.cpp,420) -Illustrator CS6 32
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.875] (..\Control\OWLFrontController.cpp,420) -Illustrator32
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.875] (..\Control\OWLFrontController.cpp,420) -16.0.0
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.875] (..\Control\OWLFrontController.cpp,420) -C:\ProgramData\Adobe\Extension Manager CS6\Mxi Flag\Illustrator CS6 32\
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.875] (..\Control\OWLFrontController.cpp,420) -C:\Users\***************\AppData\Roaming\Adobe\Extension Manager CS6\Mxi Flag\Illustrator CS6 32\
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.875] (..\Control\OWLFrontController.cpp,420) -http://www.adobe.com/go/exchange
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.875] (..\Control\OWLFrontController.cpp,420) -C:\Program Files\Adobe\Adobe Illustrator CS6\Support Files\Contents\Windows\Configuration\ai_app_24px.png
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.876] (..\Control\OWLFrontController.cpp,420) -http://www.adobe.com/cfusion/exchange/upload/index.cfm
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.876] (..\Control\OWLFrontController.cpp,420) -Illustrator
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.876] (..\Control\OWLFrontController.cpp,420) -C:\ProgramData\Adobe\Extension Manager CS6\EM Store\Illustrator CS6 32\
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.876] (..\Control\OWLFrontController.cpp,420) -C:\Users\***************\AppData\Roaming\Adobe\Extension Manager CS6\EM Store\Illustrator CS6 32\
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.876] (..\Control\OWLFrontController.cpp,420) -0
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.876] (..\Control\OWLFrontController.cpp,420) -ILST
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.877] (..\Control\OWLFrontController.cpp,420) -
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.877] (..\Control\OWLFrontController.cpp,420) -1
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.877] (..\Control\OWLFrontController.cpp,420) -C:\Program Files\Adobe\Adobe Illustrator CS6\Support Files\Contents\Windows\Configuration\
                            [DEBUG] Sun Oct 28 13:30:45 2012 [.877] (..\Control\OWLFrontController.cpp,446) --------------------Request (C++ side To AIR part ) End---------------------------
                            [DEBUG] Sun Oct 28 13:30:46 2012 [.9] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
                            [DEBUG] Sun Oct 28 13:30:46 2012 [.9] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is airNotifyOperationBeginOrEnd
                            [DEBUG] Sun Oct 28 13:30:46 2012 [.9] (..\Control\OWLFrontController.cpp,118) -7
                            [DEBUG] Sun Oct 28 13:30:46 2012 [.9] (..\Control\OWLFrontController.cpp,118) -preinstall
                            [DEBUG] Sun Oct 28 13:30:46 2012 [.10] (..\Control\OWLFrontController.cpp,118) -1
                            [DEBUG] Sun Oct 28 13:30:46 2012 [.10] (..\Control\OWLFrontController.cpp,118) -0
                            [DEBUG] Sun Oct 28 13:30:46 2012 [.10] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
                            [DEBUG] Sun Oct 28 13:30:46 2012 [.11] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
                            [DEBUG] Sun Oct 28 13:30:46 2012 [.12] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalMigratePreferredExtension
                            [DEBUG] Sun Oct 28 13:30:46 2012 [.12] (..\Control\OWLFrontController.cpp,118) -4
                            [DEBUG] Sun Oct 28 13:30:46 2012 [.12] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
                            [DEBUG] Sun Oct 28 13:30:46 2012 [.13] (..\Control\OWLExtensionMgrUI.cpp,244) -SetProgressCount:200
                            [DEBUG] Sun Oct 28 13:30:46 2012 [.39] (..\Control\OWLFrontController.cpp,400) --------------------Request (C++ side To AIR part ) Start--------------------------
                            [DEBUG] Sun Oct 28 13:30:46 2012 [.39] (..\Control\OWLFrontController.cpp,403) -Method Name: airCallBack
                            [DEBUG] Sun Oct 28 13:30:46 2012 [.39] (..\Control\OWLFrontController.cpp,420) -4
                            [DEBUG] Sun Oct 28 13:30:46 2012 [.39] (..\Control\OWLFrontController.cpp,420) -0
                            [DEBUG] Sun Oct 28 13:30:46 2012 [.39] (..\Control\OWLFrontController.cpp,446) --------------------Request (C++ side To AIR part ) End---------------------------
                            [DEBUG] Sun Oct 28 13:30:46 2012 [.43] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
                            [DEBUG] Sun Oct 28 13:30:46 2012 [.44] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is airNotifyOperationBeginOrEnd
                            [DEBUG] Sun Oct 28 13:30:46 2012 [.44] (..\Control\OWLFrontController.cpp,118) -8
                            [DEBUG] Sun Oct 28 13:30:46 2012 [.44] (..\Control\OWLFrontController.cpp,118) -preinstall
                            [DEBUG] Sun Oct 28 13:30:46 2012 [.44] (..\Control\OWLFrontController.cpp,118) -0
                            [DEBUG] Sun Oct 28 13:30:46 2012 [.44] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
                            [DEBUG] Sun Oct 28 13:30:46 2012 [.60] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
                            [DEBUG] Sun Oct 28 13:30:46 2012 [.60] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalGetLastVersionPointProducts
                            [DEBUG] Sun Oct 28 13:30:46 2012 [.60] (..\Control\OWLFrontController.cpp,118) -9
                            [DEBUG] Sun Oct 28 13:30:46 2012 [.60] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
                            [DEBUG] Sun Oct 28 13:30:46 2012 [.62] (..\MacrProduct.cpp,182) -The product flash-12.0 is not supported by CS5.5
                            [DEBUG] Sun Oct 28 13:30:46 2012 [.62] (..\MacrProduct.cpp,182) -The product fireworks-12.0 is not supported by CS5.5
                            [DEBUG] Sun Oct 28 13:30:46 2012 [.62] (..\MacrProduct.cpp,182) -The product dreamweaver-12.0 is not supported by CS5.5
                            [DEBUG] Sun Oct 28 13:30:46 2012 [.63] (..\MacrProduct.cpp,182) -The product photoshop-60.032 is not supported by CS5.5
                            [DEBUG] Sun Oct 28 13:30:46 2012 [.63] (..\MacrProduct.cpp,182) -The product indesign-8.0 is not supported by CS5.5
                            [DEBUG] Sun Oct 28 13:30:46 2012 [.63] (..\MacrProduct.cpp,182) -The product illustrator-16.032 is not supported by CS5.5
                            [DEBUG] Sun Oct 28 13:30:46 2012 [.63] (..\Control\OWLFrontController.cpp,400) --------------------Request (C++ side To AIR part ) Start--------------------------
                            [DEBUG] Sun Oct 28 13:30:46 2012 [.63] (..\Control\OWLFrontController.cpp,403) -Method Name: airCallBack
                            [DEBUG] Sun Oct 28 13:30:46 2012 [.63] (..\Control\OWLFrontController.cpp,420) -9
                            [DEBUG] Sun Oct 28 13:30:46 2012 [.63] (..\Control\OWLFrontController.cpp,420) -0
                            [DEBUG] Sun Oct 28 13:30:46 2012 [.63] (..\Control\OWLFrontController.cpp,446) --------------------Request (C++ side To AIR part ) End---------------------------
                            [DEBUG] Sun Oct 28 13:30:46 2012 [.84] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
                            [DEBUG] Sun Oct 28 13:30:46 2012 [.84] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalLoadExtension
                            [DEBUG] Sun Oct 28 13:30:46 2012 [.84] (..\Control\OWLFrontController.cpp,118) -12
                            [DEBUG] Sun Oct 28 13:30:46 2012 [.84] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
                            [DEBUG] Sun Oct 28 13:30:46 2012 [.87] (..\MacrExtensionManager.cpp,1787) -Begin to load extensions...
                            [DEBUG] Sun Oct 28 13:30:46 2012 [.87] (..\Control\OWLExtensionMgrUI.cpp,244) -SetProgressCount:120
                            [DEBUG] Sun Oct 28 13:30:46 2012 [.88] (..\Control\OWLFrontController.cpp,400) --------------------Request (C++ side To AIR part ) Start--------------------------
                            [DEBUG] Sun Oct 28 13:30:46 2012 [.88] (..\Control\OWLFrontController.cpp,403) -Method Name: airCallBack
                            [DEBUG] Sun Oct 28 13:30:46 2012 [.88] (..\Control\OWLFrontController.cpp,420) -12
                            [DEBUG] Sun Oct 28 13:30:46 2012 [.88] (..\Control\OWLFrontController.cpp,420) -9
                            [DEBUG] Sun Oct 28 13:30:46 2012 [.89] (..\Control\OWLFrontController.cpp,420) -8
                            [DEBUG] Sun Oct 28 13:30:46 2012 [.89] (..\Control\OWLFrontController.cpp,446) --------------------Request (C++ side To AIR part ) End---------------------------
                            [DEBUG] Sun Oct 28 13:30:46 2012 [.534] (..\Control\OWLFrontController.cpp,400) --------------------Request (C++ side To AIR part ) Start--------------------------
                            [DEBUG] Sun Oct 28 13:30:46 2012 [.535] (..\Control\OWLFrontController.cpp,403) -Method Name: airCallBack
                            [DEBUG] Sun Oct 28 13:30:46 2012 [.535] (..\Control\OWLFrontController.cpp,420) -12
                            [DEBUG] Sun Oct 28 13:30:46 2012 [.535] (..\Control\OWLFrontController.cpp,420) -9
                            [DEBUG] Sun Oct 28 13:30:46 2012 [.535] (..\Control\OWLFrontController.cpp,446) --------------------Request (C++ side To AIR part ) End---------------------------
                            [DEBUG] Sun Oct 28 13:30:46 2012 [.658] (..\Control\OWLFrontController.cpp,400) --------------------Request (C++ side To AIR part ) Start--------------------------
                            [DEBUG] Sun Oct 28 13:30:46 2012 [.658] (..\Control\OWLFrontController.cpp,403) -Method Name: airCallBack
                            [DEBUG] Sun Oct 28 13:30:46 2012 [.658] (..\Control\OWLFrontController.cpp,420) -12
                            [DEBUG] Sun Oct 28 13:30:46 2012 [.658] (..\Control\OWLFrontController.cpp,420) -9
                            [DEBUG] Sun Oct 28 13:30:46 2012 [.658] (..\Control\OWLFrontController.cpp,420) -10
                            [DEBUG] Sun Oct 28 13:30:46 2012 [.658] (..\Control\OWLFrontController.cpp,446) --------------------Request (C++ side To AIR part ) End---------------------------
                            [DEBUG] Sun Oct 28 13:30:47 2012 [.26] (..\Control\OWLFrontController.cpp,400) --------------------Request (C++ side To AIR part ) Start--------------------------
                            [DEBUG] Sun Oct 28 13:30:47 2012 [.27] (..\Control\OWLFrontController.cpp,403) -Method Name: airCallBack
                            [DEBUG] Sun Oct 28 13:30:47 2012 [.27] (..\Control\OWLFrontController.cpp,420) -12
                            [DEBUG] Sun Oct 28 13:30:47 2012 [.27] (..\Control\OWLFrontController.cpp,420) -9
                            [DEBUG] Sun Oct 28 13:30:47 2012 [.27] (..\Control\OWLFrontController.cpp,420) -11
                            [DEBUG] Sun Oct 28 13:30:47 2012 [.27] (..\Control\OWLFrontController.cpp,446) --------------------Request (C++ side To AIR part ) End---------------------------
                            [DEBUG] Sun Oct 28 13:30:47 2012 [.140] (..\Control\OWLFrontController.cpp,400) --------------------Request (C++ side To AIR part ) Start--------------------------
                            [DEBUG] Sun Oct 28 13:30:47 2012 [.140] (..\Control\OWLFrontController.cpp,403) -Method Name: airCallBack
                            [DEBUG] Sun Oct 28 13:30:47 2012 [.140] (..\Control\OWLFrontController.cpp,420) -12
                            [DEBUG] Sun Oct 28 13:30:47 2012 [.140] (..\Control\OWLFrontController.cpp,420) -9
                            [DEBUG] Sun Oct 28 13:30:47 2012 [.140] (..\Control\OWLFrontController.cpp,446) --------------------Request (C++ side To AIR part ) End---------------------------
                            [DEBUG] Sun Oct 28 13:30:47 2012 [.298] (..\Control\OWLFrontController.cpp,400) --------------------Request (C++ side To AIR part ) Start--------------------------
                            [DEBUG] Sun Oct 28 13:30:47 2012 [.298] (..\Control\OWLFrontController.cpp,403) -Method Name: airCallBack
                            [DEBUG] Sun Oct 28 13:30:47 2012 [.298] (..\Control\OWLFrontController.cpp,420) -12
                            [DEBUG] Sun Oct 28 13:30:47 2012 [.298] (..\Control\OWLFrontController.cpp,420) -9
                            [DEBUG] Sun Oct 28 13:30:47 2012 [.298] (..\Control\OWLFrontController.cpp,420) -13
                            [DEBUG] Sun Oct 28 13:30:47 2012 [.298] (..\Control\OWLFrontController.cpp,446) --------------------Request (C++ side To AIR part ) End---------------------------
                            [DEBUG] Sun Oct 28 13:30:47 2012 [.435] (..\Control\OWLFrontController.cpp,400) --------------------Request (C++ side To AIR part ) Start--------------------------
                            [DEBUG] Sun Oct 28 13:30:47 2012 [.436] (..\Control\OWLFrontController.cpp,403) -Method Name: airCallBack
                            [DEBUG] Sun Oct 28 13:30:47 2012 [.436] (..\Control\OWLFrontController.cpp,420) -12
                            [DEBUG] Sun Oct 28 13:30:47 2012 [.436] (..\Control\OWLFrontController.cpp,420) -9
                            [DEBUG] Sun Oct 28 13:30:47 2012 [.436] (..\Control\OWLFrontController.cpp,420) -14
                            [DEBUG] Sun Oct 28 13:30:47 2012 [.436] (..\Control\OWLFrontController.cpp,446) --------------------Request (C++ side To AIR part ) End---------------------------
                            [DEBUG] Sun Oct 28 13:30:47 2012 [.560] (..\Control\OWLFrontController.cpp,400) --------------------Request (C++ side To AIR part ) Start--------------------------
                            [DEBUG] Sun Oct 28 13:30:47 2012 [.560] (..\Control\OWLFrontController.cpp,403) -Method Name: airCallBack
                            [DEBUG] Sun Oct 28 13:30:47 2012 [.561] (..\Control\OWLFrontController.cpp,420) -12
                            [DEBUG] Sun Oct 28 13:30:47 2012 [.561] (..\Control\OWLFrontController.cpp,420) -9
                            [DEBUG] Sun Oct 28 13:30:47 2012 [.561] (..\Control\OWLFrontController.cpp,420) -15
                            [DEBUG] Sun Oct 28 13:30:47 2012 [.561] (..\Control\OWLFrontController.cpp,446) --------------------Request (C++ side To AIR part ) End---------------------------
                            [DEBUG] Sun Oct 28 13:30:47 2012 [.746] (..\Control\OWLFrontController.cpp,400) --------------------Request (C++ side To AIR part ) Start--------------------------
                            [DEBUG] Sun Oct 28 13:30:47 2012 [.747] (..\Control\OWLFrontController.cpp,403) -Method Name: airCallBack
                            [DEBUG] Sun Oct 28 13:30:47 2012 [.747] (..\Control\OWLFrontController.cpp,420) -12
                            [DEBUG] Sun Oct 28 13:30:47 2012 [.747] (..\Control\OWLFrontController.cpp,420) -9
                            [DEBUG] Sun Oct 28 13:30:47 2012 [.747] (..\Control\OWLFrontController.cpp,420) -16
                            [DEBUG] Sun Oct 28 13:30:47 2012 [.747] (..\Control\OWLFrontController.cpp,446) --------------------Request (C++ side To AIR part ) End---------------------------
                            [INFO] Sun Oct 28 13:30:49 2012 [.248] (..\MacrExtensionManager.cpp,1971) -The enabled_EnableAllExt file is C:\Users\***************\AppData\Roaming\Adobe\Extension Manager CS6\Mxi Flag\InDesign CS6\InDesign CS6.enabled_EnableAllExt
                            [DEBUG] Sun Oct 28 13:30:49 2012 [.268] (..\MacrExtensionManager.cpp,1772) -Load: InDesign CS6 firstLaunch is true
                            [DEBUG] Sun Oct 28 13:30:49 2012 [.275] (..\Control\OWLFrontController.cpp,400) --------------------Request (C++ side To AIR part ) Start--------------------------
                            [DEBUG] Sun Oct 28 13:30:49 2012 [.275] (..\Control\OWLFrontController.cpp,403) -Method Name: airCallBack
                            [DEBUG] Sun Oct 28 13:30:49 2012 [.275] (..\Control\OWLFrontController.cpp,420) -12
                            [DEBUG] Sun Oct 28 13:30:49 2012 [.275] (..\Control\OWLFrontController.cpp,420) -9
                            [DEBUG] Sun Oct 28 13:30:49 2012 [.275] (..\Control\OWLFrontController.cpp,420) -25
                            [DEBUG] Sun Oct 28 13:30:49 2012 [.275] (..\Control\OWLFrontController.cpp,446) --------------------Request (C++ side To AIR part ) End---------------------------
                            [DEBUG] Sun Oct 28 13:30:49 2012 [.276] (..\Control\OWLFrontController.cpp,400) --------------------Request (C++ side To AIR part ) Start--------------------------
                            [DEBUG] Sun Oct 28 13:30:49 2012 [.276] (..\Control\OWLFrontController.cpp,403) -Method Name: airCallBack
                            [DEBUG] Sun Oct 28 13:30:49 2012 [.276] (..\Control\OWLFrontController.cpp,420) -12
                            [DEBUG] Sun Oct 28 13:30:49 2012 [.276] (..\Control\OWLFrontController.cpp,420) -9
                            [DEBUG] Sun Oct 28 13:30:49 2012 [.276] (..\Control\OWLFrontController.cpp,420) -33
                            [DEBUG] Sun Oct 28 13:30:49 2012 [.276] (..\Control\OWLFrontController.cpp,446) --------------------Request (C++ side To AIR part ) End---------------------------
                            [DEBUG] Sun Oct 28 13:30:49 2012 [.311] (..\Control\OWLFrontController.cpp,400) --------------------Request (C++ side To AIR part ) Start--------------------------
                            [DEBUG] Sun Oct 28 13:30:49 2012 [.311] (..\Control\OWLFrontController.cpp,403) -Method Name: airCallBack
                            [DEBUG] Sun Oct 28 13:30:49 2012 [.311] (..\Control\OWLFrontController.cpp,420) -12
                            [DEBUG] Sun Oct 28 13:30:49 2012 [.311] (..\Control\OWLFrontController.cpp,420) -9
                            [DEBUG] Sun Oct 28 13:30:49 2012 [.311] (..\Control\OWLFrontController.cpp,420) -34
                            [DEBUG] Sun Oct 28 13:30:49 2012 [.311] (..\Control\OWLFrontController.cpp,446) --------------------Request (C++ side To AIR part ) End---------------------------
                            [DEBUG] Sun Oct 28 13:30:49 2012 [.330] (..\Control\OWLFrontController.cpp,400) --------------------Request (C++ side To AIR part ) Start--------------------------
                            [DEBUG] Sun Oct 28 13:30:49 2012 [.330] (..\Control\OWLFrontController.cpp,403) -Method Name: airCallBack
                            [DEBUG] Sun Oct 28 13:30:49 2012 [.330] (..\Control\OWLFrontController.cpp,420) -12
                            [DEBUG] Sun Oct 28 13:30:49 2012 [.330] (..\Control\OWLFrontController.cpp,420) -9
                            [DEBUG] Sun Oct 28 13:30:49 2012 [.330] (..\Control\OWLFrontController.cpp,420) -35
                            [DEBUG] Sun Oct 28 13:30:49 2012 [.330] (..\Control\OWLFrontController.cpp,446) --------------------Request (C++ side To AIR part ) End---------------------------
                            [DEBUG] Sun Oct 28 13:30:49 2012 [.356] (..\Control\OWLFrontController.cpp,400) --------------------Request (C++ side To AIR part ) Start--------------------------
                            [DEBUG] Sun Oct 28 13:30:49 2012 [.356] (..\Control\OWLFrontController.cpp,403) -Method Name: airCallBack
                            [DEBUG] Sun Oct 28 13:30:49 2012 [.356] (..\Control\OWLFrontController.cpp,420) -12
                            [DEBUG] Sun Oct 28 13:30:49 2012 [.356] (..\Control\OWLFrontController.cpp,420) -9
                            [DEBUG] Sun Oct 28 13:30:49 2012 [.356] (..\Control\OWLFrontController.cpp,420) -36
                            [DEBUG] Sun Oct 28 13:30:49 2012 [.356] (..\Control\OWLFrontController.cpp,446) --------------------Request (C++ side To AIR part ) End---------------------------
                            [DEBUG] Sun Oct 28 13:30:49 2012 [.364] (..\Control\OWLFrontController.cpp,400) --------------------Request (C++ side To AIR part ) Start--------------------------
                            [DEBUG] Sun Oct 28 13:30:49 2012 [.364] (..\Control\OWLFrontController.cpp,403) -Method Name: airCallBack
                            [DEBUG] Sun Oct 28 13:30:49 2012 [.364] (..\Control\OWLFrontController.cpp,420) -12
                            [DEBUG] Sun Oct 28 13:30:49 2012 [.364] (..\Control\OWLFrontController.cpp,420) -9
                            [DEBUG] Sun Oct 28 13:30:49 2012 [.364] (..\Control\OWLFrontController.cpp,420) -37
                            [DEBUG] Sun Oct 28 13:30:49 2012 [.364] (..\Control\OWLFrontController.cpp,446) --------------------Request (C++ side To AIR part ) End---------------------------
                            [DEBUG] Sun Oct 28 13:30:49 2012 [.376] (..\Control\OWLFrontController.cpp,400) --------------------Request (C++ side To AIR part ) Start--------------------------
                            [DEBUG] Sun Oct 28 13:30:49 2012 [.376] (..\Control\OWLFrontController.cpp,403) -Method Name: airCallBack
                            [DEBUG] Sun Oct 28 13:30:49 2012 [.376] (..\Control\OWLFrontController.cpp,420) -12
                            [DEBUG] Sun Oct 28 13:30:49 2012 [.376] (..\Control\OWLFrontController.cpp,420) -9
                            [DEBUG] Sun Oct 28 13:30:49 2012 [.376] (..\Control\OWLFrontController.cpp,420) -38
                            [DEBUG] Sun Oct 28 13:30:49 2012 [.377] (..\Control\OWLFrontController.cpp,446) --------------------Request (C++ side To AIR part ) End---------------------------
                            [DEBUG] Sun Oct 28 13:30:49 2012 [.417] (..\Control\OWLFrontController.cpp,400) --------------------Request (C++ side To AIR part ) Start--------------------------
                            [DEBUG] Sun Oct 28 13:30:49 2012 [.418] (..\Control\OWLFrontController.cpp,403) -Method Name: airCallBack
                            [DEBUG] Sun Oct 28 13:30:49 2012 [.418] (..\Control\OWLFrontController.cpp,420) -12
                            [DEBUG] Sun Oct 28 13:30:49 2012 [.418] (..\Control\OWLFrontController.cpp,420) -9
                            [DEBUG] Sun Oct 28 13:30:49 2012 [.418] (..\Control\OWLFrontController.cpp,420) -39
                            [DEBUG] Sun Oct 28 13:30:49 2012 [.418] (..\Control\OWLFrontController.cpp,446) --------------------Request (C++ side To AIR part ) End---------------------------
                            [DEBUG] Sun Oct 28 13:30:49 2012 [.423] (..\Control\OWLFrontController.cpp,400) --------------------Request (C++ side To AIR part ) Start--------------------------
                            [DEBUG] Sun Oct 28 13:30:49 2012 [.423] (..\Control\OWLFrontController.cpp,403) -Method Name: airCallBack
                            [DEBUG] Sun Oct 28 13:30:49 2012 [.423] (..\Control\OWLFrontController.cpp,420) -12
                            [DEBUG] Sun Oct 28 13:30:49 2012 [.423] (..\Control\OWLFrontController.cpp,420) -9
                            [DEBUG] Sun Oct 28 13:30:49 2012 [.423] (..\Control\OWLFrontController.cpp,420) -40
                            [DEBUG] Sun Oct 28 13:30:49 2012 [.423] (..\Control\OWLFrontController.cpp,446) --------------------Request (C++ side To AIR part ) End---------------------------
                            [DEBUG] Sun Oct 28 13:30:49 2012 [.459] (..\Control\OWLFrontController.cpp,400) --------------------Request (C++ side To AIR part ) Start--------------------------
                            [DEBUG] Sun Oct 28 13:30:49 2012 [.459] (..\Control\OWLFrontController.cpp,403) -Method Name: airCallBack
                            [DEBUG] Sun Oct 28 13:30:49 2012 [.459] (..\Control\OWLFrontController.cpp,420) -12
                            [DEBUG] Sun Oct 28 13:30:49 2012 [.459] (..\Control\OWLFrontController.cpp,420) -9
                            [DEBUG] Sun Oct 28 13:30:49 2012 [.460] (..\Control\OWLFrontController.cpp,420) -41
                            [DEBUG] Sun Oct 28 13:30:49 2012 [.460] (..\Control\OWLFrontController.cpp,446) --------------------Request (C++ side To AIR part ) End---------------------------
                            [DEBUG] Sun Oct 28 13:30:49 2012 [.463] (..\MacrExtensionManager.cpp,1772) -Load: Fireworks CS6 firstLaunch is true
                            [DEBUG] Sun Oct 28 13:30:49 2012 [.465] (..\Control\OWLFrontController.cpp,400) --------------------Request (C++ side To AIR part ) Start--------------------------
                            [DEBUG] Sun Oct 28 13:30:49 2012 [.465] (..\Control\OWLFrontController.cpp,403) -Method Name: airCallBack
                            [DEBUG] Sun Oct 28 13:30:49 2012 [.465] (..\Control\OWLFrontController.cpp,420) -12
                            [DEBUG] Sun Oct 28 13:30:49 2012 [.465] (..\Control\OWLFrontController.cpp,420) -9
                            [DEBUG] Sun Oct 28 13:30:49 2012 [.465] (..\Control\OWLFrontController.cpp,420) -50
                            [DEBUG] Sun Oct 28 13:30:49 2012 [.465] (..\Control\OWLFrontController.cpp,446) --------------------Request (C++ side To AIR part ) End---------------------------
                            [DEBUG] Sun Oct 28 13:30:49 2012 [.466] (..\Control\OWLFrontController.cpp,420) -12
                            [DEBUG] Sun Oct 28 13:30:49 2012 [.466] (..\Control\OWLFrontController.cpp,420) -9
                            [DEBUG] Sun Oct 28 13:30:49 2012 [.466] (..\Control\OWLFrontController.cpp,420) -60
                            [DEBUG] Sun Oct 28 13:30:49 2012 [.466] (..\Control\OWLFrontController.cpp,446) --------------------Request (C++ side To AIR part ) End---------------------------
                            [DEBUG] Sun Oct 28 13:30:49 2012 [.466] (..\DBWrapper.cpp,2572) -InitPredefinedExtensionSetTbl: clean up dirty table
                            [DEBUG] Sun Oct 28 13:30:49 2012 [.466] (..\Control\OWLFrontController.cpp,400) --------------------Request (C++ side To AIR part ) Start--------------------------
                            [DEBUG] Sun Oct 28 13:30:49 2012 [.466] (..\Control\OWLFrontController.cpp,403) -Method Name: airCallBack
                            [DEBUG] Sun Oct 28 13:30:49 2012 [.466] (..\Control\OWLFrontController.cpp,420) -70
                            [DEBUG] Sun Oct 28 13:30:49 2012 [.467] (..\MacrExtensionManager.cpp,1890) -End to load extensions...
                            [INFO] Sun Oct 28 13:30:49 2012 [.467] (..\Control\LoadExtensionCommand.cpp,46) -Load extension finished
                            [DEBUG] Sun Oct 28 13:30:49 2012 [.467] (..\Control\OWLFrontController.cpp,400) --------------------Request (C++ side To AIR part ) Start--------------------------
                            [DEBUG] Sun Oct 28 13:30:49 2012 [.467] (..\Control\OWLFrontController.cpp,403) -Method Name: airCallBack
                            [DEBUG] Sun Oct 28 13:30:49 2012 [.467] (..\Control\OWLFrontController.cpp,420) -12
                            [DEBUG] Sun Oct 28 13:30:49 2012 [.467] (..\Control\OWLFrontController.cpp,420) -0
                            [DEBUG] Sun Oct 28 13:30:49 2012 [.467] (..\Control\OWLFrontController.cpp,446) --------------------Request (C++ side To AIR part ) End---------------------------
                            [DEBUG] Sun Oct 28 15:06:56 2012 [.55] (..\Control\OWLFrontController.cpp,400) --------------------Request (C++ side To AIR part ) Start--------------------------
                            [DEBUG] Sun Oct 28 15:06:56 2012 [.55] (..\Control\OWLFrontController.cpp,403) -Method Name: airPostExit
                            [DEBUG] Sun Oct 28 15:06:56 2012 [.55] (..\Control\OWLFrontController.cpp,420) --10
                            [DEBUG] Sun Oct 28 15:06:56 2012 [.55] (..\Control\OWLFrontController.cpp,446) --------------------Request (C++ side To AIR part ) End---------------------------
                            • 11. Re: CS6 extension manager crashes on start up
                              Carl Sun Level 4
                              Does your user name contains an apostrophe? Haven't you updated Extension Manager to the latest version? Extension Manager CS6 will hang on the message "Loading extensions" if the user name contains an apostrophe. This issue has been fiexed with 6.0.2 update. Please download
                              http://download.macromedia.com/pub/dw_exchange/extension_manager/win/AdobeExtensionManager -6_0_3-mul-AdobeUpdate.zip and install it to update Extension Manager to the latest version. You can also use Adobe Application Manager to update all Adobe products including Extension Manager.
                              • 12. Re: CS6 extension manager crashes on start up
                                stormsurge_77 Level 1
                                Thanks for your help Carl..... It looks like the update has fixed it.  I don't have an apostrophe in my username though......
