6 Replies Latest reply on Oct 29, 2012 9:52 AM by Mark_Rausch
    Trouble Installing Edge Inspect on PC
    MoonTahoe1
      The Adobe Edge Inspect .msi installation file will not open on my PC.  I have WIndows 7.  I double click the msi file and nothing happens.  Why?  I don't have a firewall running or anthing that should be getting in the way.  I have seen other people have had this problem, but no solutions were listed.
        • 2. Re: Trouble Installing Edge Inspect on PC
          MoonTahoe1 Level 1
          Hello Jeff,
          So that is where I get the MSI from.  I have the apps installed on my
          devices, and the chrome tool, I just cannot get Edge Inpsect installed on
          my PC.
          I am a technical trainer in Silicon Valley.  I am susposed to review the
          software, and if I like it recommend it to my classes and teach them how to
          use it... but I can't get it installed on any of our PC's.
          Here is where I get the file:
          image: Inline image 1
          It downloads to my download directory...
          image: Inline image 2
          When I double click the file to run... my PC works for like 2 seconds and
          then nothing happens?
          image: Inline image 3
          Do you have another file other than this MSI installation file?
          Sincerely,
          Alex Banks
          • 3. Re: Trouble Installing Edge Inspect on PC
            Jeff A Wright Adobe Employee
            Moving this discussion to the Edge Inspect forum.  The users in this forum may have additional suggestions regarding troubleshooting the installation of Edge Inspect.
            • 4. Re: Trouble Installing Edge Inspect on PC
              AllDayDev Adobe Employee
              I assume you have administrator access to the PCs on which you are trying to install?
              Can you install any other software to the system?
              Assuming you have proper permissions, try enabling Windows Installer logging, and then run the .msi for Inspect: http://support.microsoft.com/kb/223300
              The log file will be created in your temp folder with a name like MSI***.log; open it in Notepad and copy/paste it here for us to take a look. That should give us some clues as to why it's not working for you.
              • 5. Re: Trouble Installing Edge Inspect on PC
                MoonTahoe1 Level 1
                Here are the contents of the MSi log:
                === Verbose logging started: 10/27/2012  11:13:39  Build type: SHIP UNICODE 4.05.6002.00  Calling process: C:\Windows\Explorer.EXE ===
                MSI (c) (08:4C) [11:13:39:379]: Resetting cached policy values
                MSI (c) (08:4C) [11:13:39:379]: Machine policy value 'Debug' is 0
                MSI (c) (08:4C) [11:13:39:379]: ******* RunEngine:
                           ******* Product: {F2AF3E5D-9697-485C-A5AC-E2B9468C446A}
                           ******* Action:
                           ******* CommandLine: **********
                MSI (c) (08:4C) [11:13:39:379]: Client-side and UI is none or basic: Running entire install on the server.
                MSI (c) (08:4C) [11:13:39:379]: Grabbed execution mutex.
                MSI (c) (08:4C) [11:13:53:809]: Cloaking enabled.
                MSI (c) (08:4C) [11:13:53:809]: Attempting to enable all disabled privileges before calling Install on Server
                MSI (c) (08:4C) [11:13:53:824]: Incrementing counter to disable shutdown. Counter after increment: 0
                MSI (s) (A4:E4) [11:13:54:058]: Running installation inside multi-package transaction {F2AF3E5D-9697-485C-A5AC-E2B9468C446A}
                MSI (s) (A4:E4) [11:13:54:058]: Grabbed execution mutex.
                MSI (s) (A4:F8) [11:13:54:058]: Resetting cached policy values
                MSI (s) (A4:F8) [11:13:54:058]: Machine policy value 'Debug' is 0
                MSI (s) (A4:F8) [11:13:54:058]: ******* RunEngine:
                           ******* Action:
                MSI (s) (A4:F8) [11:13:54:058]: Machine policy value 'DisableUserInstalls' is 0
                MSI (s) (A4:F8) [11:13:54:058]: Setting cached product context: machine assigned for product: D5E3FA2F7969C5845ACA2E9B64C844A6
                MSI (s) (A4:F8) [11:13:54:090]: Using cached product context: machine assigned for product: D5E3FA2F7969C5845ACA2E9B64C844A6
                MSI (s) (A4:F8) [11:13:54:105]: Using cached product context: machine assigned for product: D5E3FA2F7969C5845ACA2E9B64C844A6
                MSI (s) (A4:F8) [11:13:54:121]: Using cached product context: machine assigned for product: D5E3FA2F7969C5845ACA2E9B64C844A6
                MSI (s) (A4:F8) [11:13:54:199]: Using cached product context: machine assigned for product: D5E3FA2F7969C5845ACA2E9B64C844A6
                MSI (s) (A4:F8) [11:13:54:199]: Machine policy value 'LimitSystemRestoreCheckpointing' is 0
                MSI (s) (A4:F8) [11:13:54:199]: SRSetRestorePoint skipped for this transaction.
                MSI (s) (A4:F8) [11:13:54:199]: End dialog not enabled
                MSI (s) (A4:F8) [11:13:54:199]: Original package ==> C:\Windows\Installer\1ff4ad05.msi
                MSI (s) (A4:F8) [11:13:54:199]: Package we're running from ==> C:\Windows\Installer\1ff4ad05.msi
                MSI (s) (A4:F8) [11:13:54:214]: Using cached product context: machine assigned for product: D5E3FA2F7969C5845ACA2E9B64C844A6
                MSI (s) (A4:F8) [11:13:54:230]: APPCOMPAT: looking for appcompat database entry with ProductCode '{F2AF3E5D-9697-485C-A5AC-E2B9468C446A}'.
                MSI (s) (A4:F8) [11:13:54:230]: APPCOMPAT: no matching ProductCode found in database.
                MSI (s) (A4:F8) [11:13:54:230]: Using cached product context: machine assigned for product: D5E3FA2F7969C5845ACA2E9B64C844A6
                MSI (s) (A4:F8) [11:13:54:386]: MSCOREE not loaded loading copy from system32
                MSI (s) (A4:F8) [11:13:54:433]: Using cached product context: machine assigned for product: D5E3FA2F7969C5845ACA2E9B64C844A6
                MSI (s) (A4:F8) [11:13:54:511]: Using cached product context: machine assigned for product: D5E3FA2F7969C5845ACA2E9B64C844A6
                MSI (s) (A4:F8) [11:13:54:511]: Machine policy value 'DisablePatch' is 0
                MSI (s) (A4:F8) [11:13:54:511]: Machine policy value 'AllowLockdownPatch' is 0
                MSI (s) (A4:F8) [11:13:54:511]: Machine policy value 'DisableLUAPatching' is 0
                MSI (s) (A4:F8) [11:13:54:511]: Machine policy value 'DisableFlyWeightPatching' is 0
                MSI (s) (A4:F8) [11:13:54:511]: Enabling baseline caching for this transaction since all active patches are MSI 3.0 style MSPs or at least one MSI 3.0 minor update patch is active
                MSI (s) (A4:F8) [11:13:54:526]: APPCOMPAT: looking for appcompat database entry with ProductCode '{F2AF3E5D-9697-485C-A5AC-E2B9468C446A}'.
                MSI (s) (A4:F8) [11:13:54:526]: APPCOMPAT: no matching ProductCode found in database.
                MSI (s) (A4:F8) [11:13:54:526]: Transforms are not secure.
                MSI (s) (A4:F8) [11:13:54:526]: PROPERTY CHANGE: Adding MsiLogFileLocation property. Its value is 'C:\Users\ADMINI~1\AppData\Local\Temp\MSI1f7c6.LOG'.
                MSI (s) (A4:F8) [11:13:54:526]: Command Line: REINSTALL=Safari REINSTALLMODE=pocmus CURRENTDIRECTORY=C:\Windows\system32 CLIENTUILEVEL=2 CLIENTPROCESSID=3080
                MSI (s) (A4:F8) [11:13:54:526]: PROPERTY CHANGE: Adding PackageCode property. Its value is '{5EAA9433-59D8-45B3-AA81-B816484562B1}'.
                MSI (s) (A4:F8) [11:13:54:526]: Product Code passed to Engine.Initialize:           '{F2AF3E5D-9697-485C-A5AC-E2B9468C446A}'
                MSI (s) (A4:F8) [11:13:54:526]: Product Code from property table before transforms: '{F2AF3E5D-9697-485C-A5AC-E2B9468C446A}'
                MSI (s) (A4:F8) [11:13:54:526]: Product Code from property table after transforms:  '{F2AF3E5D-9697-485C-A5AC-E2B9468C446A}'
                MSI (s) (A4:F8) [11:13:54:526]: Product registered: entering maintenance mode
                MSI (s) (A4:F8) [11:13:54:558]: Using cached product context: machine assigned for product: D5E3FA2F7969C5845ACA2E9B64C844A6
                MSI (s) (A4:F8) [11:13:54:558]: Product {F2AF3E5D-9697-485C-A5AC-E2B9468C446A} is admin assigned: LocalSystem owns the publish key.
                MSI (s) (A4:F8) [11:13:54:558]: Product {F2AF3E5D-9697-485C-A5AC-E2B9468C446A} is managed.
                MSI (s) (A4:F8) [11:13:54:558]: MSI_LUA: Credential prompt not required, user is an admin
                MSI (s) (A4:F8) [11:13:54:558]: PROPERTY CHANGE: Adding ProductState property. Its value is '5'.
                MSI (s) (A4:F8) [11:13:54:558]: PROPERTY CHANGE: Adding ProductToBeRegistered property. Its value is '1'.
                MSI (s) (A4:F8) [11:13:54:558]: Package name retrieved from configuration data: 'Safari.msi'
                MSI (s) (A4:F8) [11:13:54:558]: Determined that existing product (either this product or the product being upgraded with a patch) is installed per-machine.
                MSI (s) (A4:F8) [11:13:54:558]: Note: 1: 2262 2: AdminProperties 3: -2147287038
                MSI (s) (A4:F8) [11:13:54:558]: Machine policy value 'DisableMsi' is 0
                MSI (s) (A4:F8) [11:13:54:558]: Machine policy value 'AlwaysInstallElevated' is 0
                MSI (s) (A4:F8) [11:13:54:558]: User policy value 'AlwaysInstallElevated' is 0
                MSI (s) (A4:F8) [11:13:54:558]: Running product '{F2AF3E5D-9697-485C-A5AC-E2B9468C446A}' with elevated privileges: Product is assigned.
                MSI (s) (A4:F8) [11:13:54:558]: PROPERTY CHANGE: Adding REINSTALL property. Its value is 'Safari'.
                MSI (s) (A4:F8) [11:13:54:558]: PROPERTY CHANGE: Adding REINSTALLMODE property. Its value is 'pocmus'.
                MSI (s) (A4:F8) [11:13:54:558]: PROPERTY CHANGE: Adding CURRENTDIRECTORY property. Its value is 'C:\Windows\system32'.
                MSI (s) (A4:F8) [11:13:54:558]: PROPERTY CHANGE: Adding CLIENTUILEVEL property. Its value is '2'.
                MSI (s) (A4:F8) [11:13:54:558]: PROPERTY CHANGE: Adding CLIENTPROCESSID property. Its value is '3080'.
                MSI (s) (A4:F8) [11:13:54:558]: Machine policy value 'DisableAutomaticApplicationShutdown' is 0
                MSI (s) (A4:F8) [11:13:54:760]: PROPERTY CHANGE: Adding MsiRestartManagerSessionKey property. Its value is '41d2dce9d872a243915ad9c3828d1e7c'.
                MSI (s) (A4:F8) [11:13:54:760]: RESTART MANAGER: Session opened.
                MSI (s) (A4:F8) [11:13:54:760]: PROPERTY CHANGE: Adding MsiSystemRebootPending property. Its value is '1'.
                MSI (s) (A4:F8) [11:13:54:760]: TRANSFORMS property is now:
                MSI (s) (A4:F8) [11:13:54:760]: PROPERTY CHANGE: Adding PRODUCTLANGUAGE property. Its value is '1033'.
                MSI (s) (A4:F8) [11:13:54:760]: PROPERTY CHANGE: Adding VersionDatabase property. Its value is '300'.
                MSI (s) (A4:F8) [11:13:54:760]: SHELL32::SHGetFolderPath returned: C:\Users\Administrator\AppData\Roaming
                MSI (s) (A4:F8) [11:13:54:760]: SHELL32::SHGetFolderPath returned: C:\Users\Administrator\Favorites
                MSI (s) (A4:F8) [11:13:54:760]: SHELL32::SHGetFolderPath returned: C:\Users\Administrator\AppData\Roaming\Microsoft\Windows\Network Shortcuts
                MSI (s) (A4:F8) [11:13:54:760]: SHELL32::SHGetFolderPath returned: C:\Users\Administrator\Documents
                MSI (s) (A4:F8) [11:13:54:760]: SHELL32::SHGetFolderPath returned: C:\Users\Administrator\AppData\Roaming\Microsoft\Windows\Printer Shortcuts
                MSI (s) (A4:F8) [11:13:54:760]: SHELL32::SHGetFolderPath returned: C:\Users\Administrator\AppData\Roaming\Microsoft\Windows\Recent
                MSI (s) (A4:F8) [11:13:54:760]: SHELL32::SHGetFolderPath returned: C:\Users\Administrator\AppData\Roaming\Microsoft\Windows\SendTo
                MSI (s) (A4:F8) [11:13:54:760]: SHELL32::SHGetFolderPath returned: C:\Users\Administrator\AppData\Roaming\Microsoft\Windows\Templates
                MSI (s) (A4:F8) [11:13:54:760]: SHELL32::SHGetFolderPath returned: C:\ProgramData
                MSI (s) (A4:F8) [11:13:54:760]: SHELL32::SHGetFolderPath returned: C:\Users\Administrator\AppData\Local
                MSI (s) (A4:F8) [11:13:54:760]: SHELL32::SHGetFolderPath returned: C:\Users\Administrator\Pictures
                MSI (s) (A4:F8) [11:13:54:776]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools
                MSI (s) (A4:F8) [11:13:54:776]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup
                MSI (s) (A4:F8) [11:13:54:776]: SHELL32::SHGetFolderPath returned: C:\Users\Public\Desktop
                MSI (s) (A4:F8) [11:13:54:776]: SHELL32::SHGetFolderPath returned: C:\Users\Administrator\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Administrative Tools
                MSI (s) (A4:F8) [11:13:54:776]: SHELL32::SHGetFolderPath returned: C:\Users\Administrator\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
                MSI (s) (A4:F8) [11:13:54:776]: SHELL32::SHGetFolderPath returned: C:\Users\Administrator\Desktop
                MSI (s) (A4:F8) [11:13:54:792]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Templates
                MSI (s) (A4:F8) [11:13:54:792]: SHELL32::SHGetFolderPath returned: C:\Windows\Fonts
                MSI (s) (A4:F8) [11:13:54:792]: Note: 1: 2898 2: MS Sans Serif 3: MS Sans Serif 4: 0 5: 16
                MSI (s) (A4:F8) [11:13:54:792]: MSI_LUA: Setting AdminUser property to 1 because the product is already installed managed and per-machine
                MSI (s) (A4:F8) [11:13:54:792]: MSI_LUA: Setting MsiRunningElevated property to 1 because the install is already running elevated.
                MSI (s) (A4:F8) [11:13:54:792]: PROPERTY CHANGE: Adding MsiRunningElevated property. Its value is '1'.
                MSI (s) (A4:F8) [11:13:54:792]: PROPERTY CHANGE: Adding Privileged property. Its value is '1'.
                MSI (s) (A4:F8) [11:13:54:792]: Using cached product context: machine assigned for product: D5E3FA2F7969C5845ACA2E9B64C844A6
                MSI (s) (A4:F8) [11:13:54:792]: Note: 1: 1402 2: HKEY_CURRENT_USER\Software\Microsoft\MS Setup (ACME)\User Info 3: 2
                MSI (s) (A4:F8) [11:13:54:792]: PROPERTY CHANGE: Adding USERNAME property. Its value is 'admin'.
                MSI (s) (A4:F8) [11:13:54:792]: PROPERTY CHANGE: Adding Installed property. Its value is '00:00:00'.
                MSI (s) (A4:F8) [11:13:54:792]: PROPERTY CHANGE: Adding DATABASE property. Its value is 'C:\Windows\Installer\1ff4ad05.msi'.
                MSI (s) (A4:F8) [11:13:54:792]: PROPERTY CHANGE: Adding OriginalDatabase property. Its value is 'C:\Windows\Installer\1ff4ad05.msi'.
                MSI (s) (A4:F8) [11:13:54:792]: Machine policy value 'MsiDisableEmbeddedUI' is 0
                MSI (s) (A4:F8) [11:13:54:792]: Note: 1: 2205 2:  3: PatchPackage
                MSI (s) (A4:F8) [11:13:54:792]: Machine policy value 'DisableRollback' is 0
                MSI (s) (A4:F8) [11:13:54:792]: User policy value 'DisableRollback' is 0
                MSI (s) (A4:F8) [11:13:54:792]: PROPERTY CHANGE: Adding UILevel property. Its value is '3'.
                === Logging started: 10/27/2012  11:13:54 ===
                MSI (s) (A4:F8) [11:13:54:792]: PROPERTY CHANGE: Adding Preselected property. Its value is '1'.
                MSI (s) (A4:F8) [11:13:54:792]: PROPERTY CHANGE: Adding ACTION property. Its value is 'INSTALL'.
                MSI (s) (A4:F8) [11:13:54:792]: Doing action: INSTALL
                Action start 11:13:54: INSTALL.
                MSI (s) (A4:F8) [11:13:54:792]: Running ExecuteSequence
                MSI (s) (A4:F8) [11:13:54:823]: Skipping action: PreventDowngrade (condition is false)
                MSI (s) (A4:F8) [11:13:54:823]: Doing action: AppSearch
                Action start 11:13:54: AppSearch.
                MSI (s) (A4:F8) [11:13:54:823]: Note: 1: 2262 2: Signature 3: -2147287038
                MSI (s) (A4:F8) [11:13:54:823]: PROPERTY CHANGE: Adding EXISTINGINSTALLDIR property. Its value is 'C:\Program Files\Safari\'.
                MSI (s) (A4:F8) [11:13:54:823]: PROPERTY CHANGE: Modifying REGSRCH_DESKTOP_SHORTCUTS property. Its current value is '0'. Its new value: '1'.
                MSI (s) (A4:F8) [11:13:54:823]: PROPERTY CHANGE: Adding REGSRCH_DEFAULT_BROWSER property. Its value is '0'.
                MSI (s) (A4:F8) [11:13:54:823]: Doing action: LaunchConditions
                Action ended 11:13:54: AppSearch. Return value 1.
                Action start 11:13:54: LaunchConditions.
                MSI (s) (A4:F8) [11:13:54:823]: Doing action: FindRelatedProducts
                Action ended 11:13:54: LaunchConditions. Return value 1.
                MSI (s) (A4:F8) [11:13:54:823]: Skipping FindRelatedProducts action: not run in maintenance mode
                Action start 11:13:54: FindRelatedProducts.
                MSI (s) (A4:F8) [11:13:54:823]: Doing action: ValidateProductID
                Action ended 11:13:54: FindRelatedProducts. Return value 0.
                Action start 11:13:54: ValidateProductID.
                MSI (s) (A4:F8) [11:13:54:823]: Doing action: CostInitialize
                Action ended 11:13:54: ValidateProductID. Return value 1.
                MSI (s) (A4:F8) [11:13:54:838]: Machine policy value 'MaxPatchCacheSize' is 10
                MSI (s) (A4:F8) [11:13:54:838]: Baseline: Sorting baselines for {F2AF3E5D-9697-485C-A5AC-E2B9468C446A}.
                MSI (s) (A4:F8) [11:13:54:838]: Baseline: New baseline 5.34.52 from transaction.
                MSI (s) (A4:F8) [11:13:54:870]: Baseline: Sorted order Native: Order 0.
                MSI (s) (A4:F8) [11:13:54:870]: Baseline Data Table:
                MSI (s) (A4:F8) [11:13:54:870]: ProductCode: {F2AF3E5D-9697-485C-A5AC-E2B9468C446A} Version: 5.34.52 Attributes: 0 PatchId: Native BaselineId: -2147483648 Order: 0
                MSI (s) (A4:F8) [11:13:54:870]: Baseline File Table:
                Action start 11:13:54: CostInitialize.
                MSI (s) (A4:F8) [11:13:54:870]: PROPERTY CHANGE: Adding ROOTDRIVE property. Its value is 'C:\'.
                MSI (s) (A4:F8) [11:13:54:870]: PROPERTY CHANGE: Adding CostingComplete property. Its value is '0'.
                MSI (s) (A4:F8) [11:13:54:870]: Using cached product context: machine assigned for product: D5E3FA2F7969C5845ACA2E9B64C844A6
                MSI (s) (A4:F8) [11:13:54:870]: Note: 1: 2205 2:  3: Patch
                MSI (s) (A4:F8) [11:13:54:870]: Note: 1: 2205 2:  3: PatchPackage
                MSI (s) (A4:F8) [11:13:54:870]: Note: 1: 2205 2:  3: MsiPatchHeaders
                MSI (s) (A4:F8) [11:13:54:870]: Note: 1: 2205 2:  3: __MsiPatchFileList
                MSI (s) (A4:F8) [11:13:54:870]: Note: 1: 2228 2:  3: PatchPackage 4: SELECT `DiskId`, `PatchId`, `LastSequence` FROM `Media`, `PatchPackage` WHERE `Media`.`DiskId`=`PatchPackage`.`Media_` ORDER BY `DiskId`
                MSI (s) (A4:F8) [11:13:54:870]: Delta compression fallback method for this product transaction is 'MSI 2.0 legacy obsolescence'
                MSI (s) (A4:F8) [11:13:54:870]: Doing action: FileCost
                Action ended 11:13:54: CostInitialize. Return value 1.
                MSI (s) (A4:F8) [11:13:54:885]: Note: 1: 2205 2:  3: MsiAssembly
                MSI (s) (A4:F8) [11:13:54:885]: Note: 1: 2205 2:  3: Class
                MSI (s) (A4:F8) [11:13:54:885]: Note: 1: 2205 2:  3: Extension
                MSI (s) (A4:F8) [11:13:54:885]: Note: 1: 2205 2:  3: TypeLib
                Action start 11:13:54: FileCost.
                MSI (s) (A4:F8) [11:13:54:885]: Skipping action: Set_INSTALLDIR (condition is false)
                MSI (s) (A4:F8) [11:13:54:885]: Skipping action: Set_ARPINSTALLLOCATION (condition is false)
                MSI (s) (A4:F8) [11:13:54:885]: Doing action: Set_DESKTOP_SHORTCUTS
                Action ended 11:13:54: FileCost. Return value 1.
                MSI (s) (A4:F8) [11:13:54:885]: PROPERTY CHANGE: Adding DESKTOP_SHORTCUTS property. Its value is '1'.
                Action start 11:13:54: Set_DESKTOP_SHORTCUTS.
                MSI (s) (A4:F8) [11:13:54:885]: Doing action: Set_DEFAULT_BROWSER
                Action ended 11:13:54: Set_DESKTOP_SHORTCUTS. Return value 1.
                MSI (s) (A4:F8) [11:13:54:885]: PROPERTY CHANGE: Adding DEFAULT_BROWSER property. Its value is '0'.
                Action start 11:13:54: Set_DEFAULT_BROWSER.
                MSI (s) (A4:F8) [11:13:54:885]: Skipping action: Set_DEFAULT_BROWSER_Enable (condition is false)
                MSI (s) (A4:F8) [11:13:54:885]: Skipping action: Set_DEFAULT_BROWSER_Disable (condition is false)
                MSI (s) (A4:F8) [11:13:54:885]: Doing action: CostFinalize
                Action ended 11:13:54: Set_DEFAULT_BROWSER. Return value 1.
                MSI (s) (A4:F8) [11:13:54:885]: PROPERTY CHANGE: Adding OutOfDiskSpace property. Its value is '0'.
                MSI (s) (A4:F8) [11:13:54:885]: PROPERTY CHANGE: Adding OutOfNoRbDiskSpace property. Its value is '0'.
                MSI (s) (A4:F8) [11:13:54:885]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceAvailable property. Its value is '0'.
                MSI (s) (A4:F8) [11:13:54:885]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceRequired property. Its value is '0'.
                MSI (s) (A4:F8) [11:13:54:885]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceRemaining property. Its value is '0'.
                MSI (s) (A4:F8) [11:13:54:901]: Note: 1: 2205 2:  3: MsiAssembly
                MSI (s) (A4:F8) [11:13:54:901]: Note: 1: 2228 2:  3: MsiAssembly 4:  SELECT `MsiAssembly`.`Attributes`, `MsiAssembly`.`File_Application`, `MsiAssembly`.`File_Manifest`,  `Component`.`KeyPath` FROM `MsiAssembly`, `Component` WHERE  `MsiAssembly`.`Component_` = `Component`.`Component` AND `MsiAssembly`.`Component_` = ?
                MSI (s) (A4:F8) [11:13:54:901]: PROPERTY CHANGE: Adding INSTALLDIR property. Its value is 'C:\Program Files\Safari'.
                MSI (s) (A4:F8) [11:13:54:901]: PROPERTY CHANGE: Adding PluginsFolder property. Its value is 'C:\Program Files\Safari\Plugins'.
                MSI (s) (A4:F8) [11:13:54:916]: PROPERTY CHANGE: Adding INSTALLERCACHE property. Its value is 'C:\ProgramData\Apple Computer\Installer Cache\Safari 5.34.52.7'.
                MSI (s) (A4:F8) [11:13:54:932]: PROPERTY CHANGE: Adding Safari.resources property. Its value is 'C:\Program Files\Safari\Safari.resources'.
                Action start 11:13:54: CostFinalize.
                MSI (s) (A4:F8) [11:13:55:072]: PROPERTY CHANGE: Adding Safari.resources_BookmarkChooser property. Its value is 'C:\Program Files\Safari\Safari.resources\BookmarkChooser'.
                MSI (s) (A4:F8) [11:13:55:104]: PROPERTY CHANGE: Adding Safari.resources_da.lproj property. Its value is 'C:\Program Files\Safari\Safari.resources\da.lproj'.
                MSI (s) (A4:F8) [11:13:55:135]: PROPERTY CHANGE: Adding Safari.resources_de.lproj property. Its value is 'C:\Program Files\Safari\Safari.resources\de.lproj'.
                MSI (s) (A4:F8) [11:13:55:166]: PROPERTY CHANGE: Adding Safari.resources_en.lproj property. Its value is 'C:\Program Files\Safari\Safari.resources\en.lproj'.
                MSI (s) (A4:F8) [11:13:55:182]: PROPERTY CHANGE: Adding Safari.resources_en_AU.lproj property. Its value is 'C:\Program Files\Safari\Safari.resources\en_AU.lproj'.
                MSI (s) (A4:F8) [11:13:55:182]: PROPERTY CHANGE: Adding Safari.resources_en_CA.lproj property. Its value is 'C:\Program Files\Safari\Safari.resources\en_CA.lproj'.
                MSI (s) (A4:F8) [11:13:55:182]: PROPERTY CHANGE: Adding Safari.resources_en_GB.lproj property. Its value is 'C:\Program Files\Safari\Safari.resources\en_GB.lproj'.
                MSI (s) (A4:F8) [11:13:55:197]: PROPERTY CHANGE: Adding Safari.resources_es.lproj property. Its value is 'C:\Program Files\Safari\Safari.resources\es.lproj'.
                MSI (s) (A4:F8) [11:13:55:260]: PROPERTY CHANGE: Adding Safari.resources_fi.lproj property. Its value is 'C:\Program Files\Safari\Safari.resources\fi.lproj'.
                MSI (s) (A4:F8) [11:13:55:306]: PROPERTY CHANGE: Adding Safari.resources_fr.lproj property. Its value is 'C:\Program Files\Safari\Safari.resources\fr.lproj'.
                MSI (s) (A4:F8) [11:13:55:322]: PROPERTY CHANGE: Adding Safari.resources_Help property. Its value is 'C:\Program Files\Safari\Safari.resources\Help'.
                MSI (s) (A4:F8) [11:13:55:338]: PROPERTY CHANGE: Adding Safari.resources_Help_da.lproj property. Its value is 'C:\Program Files\Safari\Safari.resources\Help\da.lproj'.
                MSI (s) (A4:F8) [11:13:55:338]: PROPERTY CHANGE: Adding Safari.resources_Help_de.lproj property. Its value is 'C:\Program Files\Safari\Safari.resources\Help\de.lproj'.
                MSI (s) (A4:F8) [11:13:55:338]: PROPERTY CHANGE: Adding Safari.resources_Help_en.lproj property. Its value is 'C:\Program Files\Safari\Safari.resources\Help\en.lproj'.
                MSI (s) (A4:F8) [11:13:55:338]: PROPERTY CHANGE: Adding Safari.resources_Help_es.lproj property. Its value is 'C:\Program Files\Safari\Safari.resources\Help\es.lproj'.
                MSI (s) (A4:F8) [11:13:55:338]: PROPERTY CHANGE: Adding Safari.resources_Help_fi.lproj property. Its value is 'C:\Program Files\Safari\Safari.resources\Help\fi.lproj'.
                MSI (s) (A4:F8) [11:13:55:338]: PROPERTY CHANGE: Adding Safari.resources_Help_fr.lproj property. Its value is 'C:\Program Files\Safari\Safari.resources\Help\fr.lproj'.
                MSI (s) (A4:F8) [11:13:55:338]: PROPERTY CHANGE: Adding Safari.resources_Help_it.lproj property. Its value is 'C:\Program Files\Safari\Safari.resources\Help\it.lproj'.
                MSI (s) (A4:F8) [11:13:55:338]: PROPERTY CHANGE: Adding Safari.resources_Help_ja.lproj property. Its value is 'C:\Program Files\Safari\Safari.resources\Help\ja.lproj'.
                MSI (s) (A4:F8) [11:13:55:338]: PROPERTY CHANGE: Adding Safari.resources_Help_ko.lproj property. Its value is 'C:\Program Files\Safari\Safari.resources\Help\ko.lproj'.
                MSI (s) (A4:F8) [11:13:55:353]: PROPERTY CHANGE: Adding Safari.resources_Help_nb.lproj property. Its value is 'C:\Program Files\Safari\Safari.resources\Help\nb.lproj'.
                MSI (s) (A4:F8) [11:13:55:353]: PROPERTY CHANGE: Adding Safari.resources_Help_nl.lproj property. Its value is 'C:\Program Files\Safari\Safari.resources\Help\nl.lproj'.
                MSI (s) (A4:F8) [11:13:55:353]: PROPERTY CHANGE: Adding Safari.resources_Help_pl.lproj property. Its value is 'C:\Program Files\Safari\Safari.resources\Help\pl.lproj'.
                MSI (s) (A4:F8) [11:13:55:353]: PROPERTY CHANGE: Adding Safari.resources_Help_pt.lproj property. Its value is 'C:\Program Files\Safari\Safari.resources\Help\pt.lproj'.
                MSI (s) (A4:F8) [11:13:55:353]: PROPERTY CHANGE: Adding Safari.resources_Help_pt_PT.lproj property. Its value is 'C:\Program Files\Safari\Safari.resources\Help\pt_PT.lproj'.
                MSI (s) (A4:F8) [11:13:55:353]: PROPERTY CHANGE: Adding Safari.resources_Help_ru.lproj property. Its value is 'C:\Program Files\Safari\Safari.resources\Help\ru.lproj'.
                MSI (s) (A4:F8) [11:13:55:353]: PROPERTY CHANGE: Adding Safari.resources_Help_sv.lproj property. Its value is 'C:\Program Files\Safari\Safari.resources\Help\sv.lproj'.
                MSI (s) (A4:F8) [11:13:55:353]: PROPERTY CHANGE: Adding Safari.resources_Help_zh_CN.lproj property. Its value is 'C:\Program Files\Safari\Safari.resources\Help\zh_CN.lproj'.
                MSI (s) (A4:F8) [11:13:55:353]: PROPERTY CHANGE: Adding Safari.resources_Help_zh_TW.lproj property. Its value is 'C:\Program Files\Safari\Safari.resources\Help\zh_TW.lproj'.
                MSI (s) (A4:F8) [11:13:55:369]: PROPERTY CHANGE: Adding Safari.resources_it.lproj property. Its value is 'C:\Program Files\Safari\Safari.resources\it.lproj'.
                MSI (s) (A4:F8) [11:13:55:384]: PROPERTY CHANGE: Adding Safari.resources_ja.lproj property. Its value is 'C:\Program Files\Safari\Safari.resources\ja.lproj'.
                MSI (s) (A4:F8) [11:13:55:384]: PROPERTY CHANGE: Adding Safari.resources_ko.lproj property. Its value is 'C:\Program Files\Safari\Safari.resources\ko.lproj'.
                MSI (s) (A4:F8) [11:13:55:400]: PROPERTY CHANGE: Adding Safari.resources_nb.lproj property. Its value is 'C:\Program Files\Safari\Safari.resources\nb.lproj'.
                MSI (s) (A4:F8) [11:13:55:416]: PROPERTY CHANGE: Adding Safari.resources_nl.lproj property. Its value is 'C:\Program Files\Safari\Safari.resources\nl.lproj'.
                MSI (s) (A4:F8) [11:13:55:416]: PROPERTY CHANGE: Adding Safari.resources_pl.lproj property. Its value is 'C:\Program Files\Safari\Safari.resources\pl.lproj'.
                MSI (s) (A4:F8) [11:13:55:416]: PROPERTY CHANGE: Adding Safari.resources_pt.lproj property. Its value is 'C:\Program Files\Safari\Safari.resources\pt.lproj'.
                MSI (s) (A4:F8) [11:13:55:447]: PROPERTY CHANGE: Adding Safari.resources_pt_PT.lproj property. Its value is 'C:\Program Files\Safari\Safari.resources\pt_PT.lproj'.
                MSI (s) (A4:F8) [11:13:55:478]: PROPERTY CHANGE: Adding Safari.resources_ru.lproj property. Its value is 'C:\Program Files\Safari\Safari.resources\ru.lproj'.
                MSI (s) (A4:F8) [11:13:55:509]: PROPERTY CHANGE: Adding Safari.resources_SnippetEditor property. Its value is 'C:\Program Files\Safari\Safari.resources\SnippetEditor'.
                MSI (s) (A4:F8) [11:13:55:525]: PROPERTY CHANGE: Adding Safari.resources_SnippetEditor_Images property. Its value is 'C:\Program Files\Safari\Safari.resources\SnippetEditor\Images'.
                MSI (s) (A4:F8) [11:13:55:540]: PROPERTY CHANGE: Adding Safari.resources_sv.lproj property. Its value is 'C:\Program Files\Safari\Safari.resources\sv.lproj'.
                MSI (s) (A4:F8) [11:13:55:572]: PROPERTY CHANGE: Adding Safari.resources_zh_CN.lproj property. Its value is 'C:\Program Files\Safari\Safari.resources\zh_CN.lproj'.
                MSI (s) (A4:F8) [11:13:55:572]: PROPERTY CHANGE: Adding Safari.resources_zh_TW.lproj property. Its value is 'C:\Program Files\Safari\Safari.resources\zh_TW.lproj'.
                MSI (s) (A4:F8) [11:13:55:572]: PROPERTY CHANGE: Adding SafariTheme.resources property. Its value is 'C:\Program Files\Safari\SafariTheme.resources'.
                MSI (s) (A4:F8) [11:13:55:603]: PROPERTY CHANGE: Adding PubSub.resources property. Its value is 'C:\Program Files\Safari\PubSub.resources'.
                MSI (s) (A4:F8) [11:13:55:634]: PROPERTY CHANGE: Adding PubSub.resources_da.lproj property. Its value is 'C:\Program Files\Safari\PubSub.resources\da.lproj'.
                MSI (s) (A4:F8) [11:13:55:634]: PROPERTY CHANGE: Adding PubSub.resources_de.lproj property. Its value is 'C:\Program Files\Safari\PubSub.resources\de.lproj'.
                MSI (s) (A4:F8) [11:13:55:634]: PROPERTY CHANGE: Adding PubSub.resources_English.lproj property. Its value is 'C:\Program Files\Safari\PubSub.resources\English.lproj'.
                MSI (s) (A4:F8) [11:13:55:634]: PROPERTY CHANGE: Adding PubSub.resources_es.lproj property. Its value is 'C:\Program Files\Safari\PubSub.resources\es.lproj'.
                MSI (s) (A4:F8) [11:13:55:650]: PROPERTY CHANGE: Adding PubSub.resources_fi.lproj property. Its value is 'C:\Program Files\Safari\PubSub.resources\fi.lproj'.
                MSI (s) (A4:F8) [11:13:55:650]: PROPERTY CHANGE: Adding PubSub.resources_fr.lproj property. Its value is 'C:\Program Files\Safari\PubSub.resources\fr.lproj'.
                MSI (s) (A4:F8) [11:13:55:681]: PROPERTY CHANGE: Adding PubSub.resources_Framework property. Its value is 'C:\Program Files\Safari\PubSub.resources\Framework'.
                MSI (s) (A4:F8) [11:13:55:681]: PROPERTY CHANGE: Adding PubSub.resources_Framework_da.lproj property. Its value is 'C:\Program Files\Safari\PubSub.resources\Framework\da.lproj'.
                MSI (s) (A4:F8) [11:13:55:681]: PROPERTY CHANGE: Adding PubSub.resources_Framework_de.lproj property. Its value is 'C:\Program Files\Safari\PubSub.resources\Framework\de.lproj'.
                MSI (s) (A4:F8) [11:13:55:681]: PROPERTY CHANGE: Adding PubSub.resources_Framework_English.lproj property. Its value is 'C:\Program Files\Safari\PubSub.resources\Framework\English.lproj'.
                MSI (s) (A4:F8) [11:13:55:681]: PROPERTY CHANGE: Adding PubSub.resources_Framework_es.lproj property. Its value is 'C:\Program Files\Safari\PubSub.resources\Framework\es.lproj'.
                MSI (s) (A4:F8) [11:13:55:681]: PROPERTY CHANGE: Adding PubSub.resources_Framework_fi.lproj property. Its value is 'C:\Program Files\Safari\PubSub.resources\Framework\fi.lproj'.
                MSI (s) (A4:F8) [11:13:55:681]: PROPERTY CHANGE: Adding PubSub.resources_Framework_fr.lproj property. Its value is 'C:\Program Files\Safari\PubSub.resources\Framework\fr.lproj'.
                MSI (s) (A4:F8) [11:13:55:681]: PROPERTY CHANGE: Adding PubSub.resources_Framework_it.lproj property. Its value is 'C:\Program Files\Safari\PubSub.resources\Framework\it.lproj'.
                MSI (s) (A4:F8) [11:13:55:681]: PROPERTY CHANGE: Adding PubSub.resources_Framework_ja.lproj property. Its value is 'C:\Program Files\Safari\PubSub.resources\Framework\ja.lproj'.
                MSI (s) (A4:F8) [11:13:55:681]: PROPERTY CHANGE: Adding PubSub.resources_Framework_ko.lproj property. Its value is 'C:\Program Files\Safari\PubSub.resources\Framework\ko.lproj'.
                MSI (s) (A4:F8) [11:13:55:681]: PROPERTY CHANGE: Adding PubSub.resources_Framework_nb.lproj property. Its value is 'C:\Program Files\Safari\PubSub.resources\Framework\nb.lproj'.
                MSI (s) (A4:F8) [11:13:55:681]: PROPERTY CHANGE: Adding PubSub.resources_Framework_nl.lproj property. Its value is 'C:\Program Files\Safari\PubSub.resources\Framework\nl.lproj'.
                MSI (s) (A4:F8) [11:13:55:681]: PROPERTY CHANGE: Adding PubSub.resources_Framework_pl.lproj property. Its value is 'C:\Program Files\Safari\PubSub.resources\Framework\pl.lproj'.
                MSI (s) (A4:F8) [11:13:55:681]: PROPERTY CHANGE: Adding PubSub.resources_Framework_pt.lproj property. Its value is 'C:\Program Files\Safari\PubSub.resources\Framework\pt.lproj'.
                MSI (s) (A4:F8) [11:13:55:681]: PROPERTY CHANGE: Adding PubSub.resources_Framework_pt_PT.lproj property. Its value is 'C:\Program Files\Safari\PubSub.resources\Framework\pt_PT.lproj'.
                MSI (s) (A4:F8) [11:13:55:681]: PROPERTY CHANGE: Adding PubSub.resources_Framework_ru.lproj property. Its value is 'C:\Program Files\Safari\PubSub.resources\Framework\ru.lproj'.
                MSI (s) (A4:F8) [11:13:55:681]: PROPERTY CHANGE: Adding PubSub.resources_Framework_sv.lproj property. Its value is 'C:\Program Files\Safari\PubSub.resources\Framework\sv.lproj'.
                MSI (s) (A4:F8) [11:13:55:681]: PROPERTY CHANGE: Adding PubSub.resources_Framework_zh_CN.lproj property. Its value is 'C:\Program Files\Safari\PubSub.resources\Framework\zh_CN.lproj'.
                MSI (s) (A4:F8) [11:13:55:681]: PROPERTY CHANGE: Adding PubSub.resources_Framework_zh_TW.lproj property. Its value is 'C:\Program Files\Safari\PubSub.resources\Framework\zh_TW.lproj'.
                MSI (s) (A4:F8) [11:13:55:681]: PROPERTY CHANGE: Adding PubSub.resources_it.lproj property. Its value is 'C:\Program Files\Safari\PubSub.resources\it.lproj'.
                MSI (s) (A4:F8) [11:13:55:681]: PROPERTY CHANGE: Adding PubSub.resources_ja.lproj property. Its value is 'C:\Program Files\Safari\PubSub.resources\ja.lproj'.
                MSI (s) (A4:F8) [11:13:55:681]: PROPERTY CHANGE: Adding PubSub.resources_ko.lproj property. Its value is 'C:\Program Files\Safari\PubSub.resources\ko.lproj'.
                MSI (s) (A4:F8) [11:13:55:681]: PROPERTY CHANGE: Adding PubSub.resources_nb.lproj property. Its value is 'C:\Program Files\Safari\PubSub.resources\nb.lproj'.
                MSI (s) (A4:F8) [11:13:55:681]: PROPERTY CHANGE: Adding PubSub.resources_nl.lproj property. Its value is 'C:\Program Files\Safari\PubSub.resources\nl.lproj'.
                MSI (s) (A4:F8) [11:13:55:681]: PROPERTY CHANGE: Adding PubSub.resources_pl.lproj property. Its value is 'C:\Program Files\Safari\PubSub.resources\pl.lproj'.
                MSI (s) (A4:F8) [11:13:55:696]: PROPERTY CHANGE: Adding PubSub.resources_pt.lproj property. Its value is 'C:\Program Files\Safari\PubSub.resources\pt.lproj'.
                MSI (s) (A4:F8) [11:13:55:696]: PROPERTY CHANGE: Adding PubSub.resources_pt_PT.lproj property. Its value is 'C:\Program Files\Safari\PubSub.resources\pt_PT.lproj'.
                MSI (s) (A4:F8) [11:13:55:696]: PROPERTY CHANGE: Adding PubSub.resources_ru.lproj property. Its value is 'C:\Program Files\Safari\PubSub.resources\ru.lproj'.
                MSI (s) (A4:F8) [11:13:55:696]: PROPERTY CHANGE: Adding PubSub.resources_sv.lproj property. Its value is 'C:\Program Files\Safari\PubSub.resources\sv.lproj'.
                MSI (s) (A4:F8) [11:13:55:696]: PROPERTY CHANGE: Adding PubSub.resources_zh_CN.lproj property. Its value is 'C:\Program Files\Safari\PubSub.resources\zh_CN.lproj'.
                MSI (s) (A4:F8) [11:13:55:696]: PROPERTY CHANGE: Adding PubSub.resources_zh_TW.lproj property. Its value is 'C:\Program Files\Safari\PubSub.resources\zh_TW.lproj'.
                MSI (s) (A4:F8) [11:13:55:696]: Note: 1: 2205 2:  3: Patch
                MSI (s) (A4:F8) [11:13:55:696]: Note: 1: 2205 2:  3: Condition
                MSI (s) (A4:F8) [11:13:55:696]: Using cached product context: machine assigned for product: D5E3FA2F7969C5845ACA2E9B64C844A6
                MSI (s) (A4:F8) [11:13:55:696]: PROPERTY CHANGE: Adding TARGETDIR property. Its value is 'C:\'.
                MSI (s) (A4:F8) [11:13:55:696]: PROPERTY CHANGE: Adding SafariProgramMenuFolder property. Its value is 'C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Safari\'.
                MSI (s) (A4:F8) [11:13:55:696]: PROPERTY CHANGE: Adding MicrosoftAppDataFolder property. Its value is 'C:\Users\Administrator\AppData\Roaming\Microsoft\'.
                MSI (s) (A4:F8) [11:13:55:696]: PROPERTY CHANGE: Adding InternetExplorerAppDataFolder property. Its value is 'C:\Users\Administrator\AppData\Roaming\Microsoft\Internet Explorer\'.
                MSI (s) (A4:F8) [11:13:55:696]: PROPERTY CHANGE: Adding QuickLaunchFolder property. Its value is 'C:\Users\Administrator\AppData\Roaming\Microsoft\Internet Explorer\Quick Launch\'.
                MSI (s) (A4:F8) [11:13:55:696]: PROPERTY CHANGE: Adding AppleCommonAppDataFolder property. Its value is 'C:\ProgramData\Apple Computer\'.
                MSI (s) (A4:F8) [11:13:55:696]: PROPERTY CHANGE: Adding CachedInstallationsFolder property. Its value is 'C:\ProgramData\Apple Computer\Installer Cache\'.
                MSI (s) (A4:F8) [11:13:55:696]: PROPERTY CHANGE: Modifying INSTALLERCACHE property. Its current value is 'C:\ProgramData\Apple Computer\Installer Cache\Safari 5.34.52.7'. Its new value: 'C:\ProgramData\Apple Computer\Installer Cache\Safari 5.34.52.7\'.
                MSI (s) (A4:F8) [11:13:55:696]: PROPERTY CHANGE: Adding SafariFolder property. Its value is 'C:\Program Files\Safari\'.
                MSI (s) (A4:F8) [11:13:55:696]: PROPERTY CHANGE: Modifying INSTALLDIR property. Its current value is 'C:\Program Files\Safari'. Its new value: 'C:\Program Files\Safari\'.
                MSI (s) (A4:F8) [11:13:55:696]: PROPERTY CHANGE: Modifying PubSub.resources property. Its current value is 'C:\Program Files\Safari\PubSub.resources'. Its new value: 'C:\Program Files\Safari\PubSub.resources\'.
                MSI (s) (A4:F8) [11:13:55:696]: PROPERTY CHANGE: Modifying PubSub.resources_zh_TW.lproj property. Its current value is 'C:\Program Files\Safari\PubSub.resources\zh_TW.lproj'. Its new value: 'C:\Program Files\Safari\PubSub.resources\zh_TW.lproj\'.
                MSI (s) (A4:F8) [11:13:55:696]: PROPERTY CHANGE: Modifying PubSub.resources_zh_CN.lproj property. Its current value is 'C:\Program Files\Safari\PubSub.resources\zh_CN.lproj'. Its new value: 'C:\Program Files\Safari\PubSub.resources\zh_CN.lproj\'.
                MSI (s) (A4:F8) [11:13:55:696]: PROPERTY CHANGE: Modifying PubSub.resources_sv.lproj property. Its current value is 'C:\Program Files\Safari\PubSub.resources\sv.lproj'. Its new value: 'C:\Program Files\Safari\PubSub.resources\sv.lproj\'.
                MSI (s) (A4:F8) [11:13:55:696]: PROPERTY CHANGE: Modifying PubSub.resources_ru.lproj property. Its current value is 'C:\Program Files\Safari\PubSub.resources\ru.lproj'. Its new value: 'C:\Program Files\Safari\PubSub.resources\ru.lproj\'.
                MSI (s) (A4:F8) [11:13:55:696]: PROPERTY CHANGE: Modifying PubSub.resources_pt_PT.lproj property. Its current value is 'C:\Program Files\Safari\PubSub.resources\pt_PT.lproj'. Its new value: 'C:\Program Files\Safari\PubSub.resources\pt_PT.lproj\'.
                MSI (s) (A4:F8) [11:13:55:696]: PROPERTY CHANGE: Modifying PubSub.resources_pt.lproj property. Its current value is 'C:\Program Files\Safari\PubSub.resources\pt.lproj'. Its new value: 'C:\Program Files\Safari\PubSub.resources\pt.lproj\'.
                MSI (s) (A4:F8) [11:13:55:696]: PROPERTY CHANGE: Modifying PubSub.resources_pl.lproj property. Its current value is 'C:\Program Files\Safari\PubSub.resources\pl.lproj'. Its new value: 'C:\Program Files\Safari\PubSub.resources\pl.lproj\'.
                MSI (s) (A4:F8) [11:13:55:696]: PROPERTY CHANGE: Modifying PubSub.resources_nl.lproj property. Its current value is 'C:\Program Files\Safari\PubSub.resources\nl.lproj'. Its new value: 'C:\Program Files\Safari\PubSub.resources\nl.lproj\'.
                MSI (s) (A4:F8) [11:13:55:696]: PROPERTY CHANGE: Modifying PubSub.resources_nb.lproj property. Its current value is 'C:\Program Files\Safari\PubSub.resources\nb.lproj'. Its new value: 'C:\Program Files\Safari\PubSub.resources\nb.lproj\'.
                MSI (s) (A4:F8) [11:13:55:696]: PROPERTY CHANGE: Modifying PubSub.resources_ko.lproj property. Its current value is 'C:\Program Files\Safari\PubSub.resources\ko.lproj'. Its new value: 'C:\Program Files\Safari\PubSub.resources\ko.lproj\'.
                MSI (s) (A4:F8) [11:13:55:696]: PROPERTY CHANGE: Modifying PubSub.resources_ja.lproj property. Its current value is 'C:\Program Files\Safari\PubSub.resources\ja.lproj'. Its new value: 'C:\Program Files\Safari\PubSub.resources\ja.lproj\'.
                MSI (s) (A4:F8) [11:13:55:696]: PROPERTY CHANGE: Modifying PubSub.resources_it.lproj property. Its current value is 'C:\Program Files\Safari\PubSub.resources\it.lproj'. Its new value: 'C:\Program Files\Safari\PubSub.resources\it.lproj\'.
                MSI (s) (A4:F8) [11:13:55:696]: PROPERTY CHANGE: Modifying PubSub.resources_Framework property. Its current value is 'C:\Program Files\Safari\PubSub.resources\Framework'. Its new value: 'C:\Program Files\Safari\PubSub.resources\Framework\'.
                MSI (s) (A4:F8) [11:13:55:696]: PROPERTY CHANGE: Modifying PubSub.resources_Framework_zh_TW.lproj property. Its current value is 'C:\Program Files\Safari\PubSub.resources\Framework\zh_TW.lproj'. Its new value: 'C:\Program Files\Safari\PubSub.resources\Framework\zh_TW.lproj\'.
                MSI (s) (A4:F8) [11:13:55:696]: PROPERTY CHANGE: Modifying PubSub.resources_Framework_zh_CN.lproj property. Its current value is 'C:\Program Files\Safari\PubSub.resources\Framework\zh_CN.lproj'. Its new value: 'C:\Program Files\Safari\PubSub.resources\Framework\zh_CN.lproj\'.
                MSI (s) (A4:F8) [11:13:55:696]: PROPERTY CHANGE: Modifying PubSub.resources_Framework_sv.lproj property. Its current value is 'C:\Program Files\Safari\PubSub.resources\Framework\sv.lproj'. Its new value: 'C:\Program Files\Safari\PubSub.resources\Framework\sv.lproj\'.
                MSI (s) (A4:F8) [11:13:55:696]: PROPERTY CHANGE: Modifying PubSub.resources_Framework_ru.lproj property. Its current value is 'C:\Program Files\Safari\PubSub.resources\Framework\ru.lproj'. Its new value: 'C:\Program Files\Safari\PubSub.resources\Framework\ru.lproj\'.
                MSI (s) (A4:F8) [11:13:55:696]: PROPERTY CHANGE: Modifying PubSub.resources_Framework_pt_PT.lproj property. Its current value is 'C:\Program Files\Safari\PubSub.resources\Framework\pt_PT.lproj'. Its new value: 'C:\Program Files\Safari\PubSub.resources\Framework\pt_PT.lproj\'.
                MSI (s) (A4:F8) [11:13:55:696]: PROPERTY CHANGE: Modifying PubSub.resources_Framework_pt.lproj property. Its current value is 'C:\Program Files\Safari\PubSub.resources\Framework\pt.lproj'. Its new value: 'C:\Program Files\Safari\PubSub.resources\Framework\pt.lproj\'.
                MSI (s) (A4:F8) [11:13:55:696]: PROPERTY CHANGE: Modifying PubSub.resources_Framework_pl.lproj property. Its current value is 'C:\Program Files\Safari\PubSub.resources\Framework\pl.lproj'. Its new value: 'C:\Program Files\Safari\PubSub.resources\Framework\pl.lproj\'.
                MSI (s) (A4:F8) [11:13:55:696]: PROPERTY CHANGE: Modifying PubSub.resources_Framework_nl.lproj property. Its current value is 'C:\Program Files\Safari\PubSub.resources\Framework\nl.lproj'. Its new value: 'C:\Program Files\Safari\PubSub.resources\Framework\nl.lproj\'.
                MSI (s) (A4:F8) [11:13:55:696]: PROPERTY CHANGE: Modifying PubSub.resources_Framework_nb.lproj property. Its current value is 'C:\Program Files\Safari\PubSub.resources\Framework\nb.lproj'. Its new value: 'C:\Program Files\Safari\PubSub.resources\Framework\nb.lproj\'.
                MSI (s) (A4:F8) [11:13:55:696]: PROPERTY CHANGE: Modifying PubSub.resources_Framework_ko.lproj property. Its current value is 'C:\Program Files\Safari\PubSub.resources\Framework\ko.lproj'. Its new value: 'C:\Program Files\Safari\PubSub.resources\Framework\ko.lproj\'.
                MSI (s) (A4:F8) [11:13:55:696]: PROPERTY CHANGE: Modifying PubSub.resources_Framework_ja.lproj property. Its current value is 'C:\Program Files\Safari\PubSub.resources\Framework\ja.lproj'. Its new value: 'C:\Program Files\Safari\PubSub.resources\Framework\ja.lproj\'.
                MSI (s) (A4:F8) [11:13:55:696]: PROPERTY CHANGE: Modifying PubSub.resources_Framework_it.lproj property. Its current value is 'C:\Program Files\Safari\PubSub.resources\Framework\it.lproj'. Its new value: 'C:\Program Files\Safari\PubSub.resources\Framework\it.lproj\'.
                MSI (s) (A4:F8) [11:13:55:696]: PROPERTY CHANGE: Modifying PubSub.resources_Framework_fr.lproj property. Its current value is 'C:\Program Files\Safari\PubSub.resources\Framework\fr.lproj'. Its new value: 'C:\Program Files\Safari\PubSub.resources\Framework\fr.lproj\'.
                MSI (s) (A4:F8) [11:13:55:696]: PROPERTY CHANGE: Modifying PubSub.resources_Framework_fi.lproj property. Its current value is 'C:\Program Files\Safari\PubSub.resources\Framework\fi.lproj'. Its new value: 'C:\Program Files\Safari\PubSub.resources\Framework\fi.lproj\'.
                MSI (s) (A4:F8) [11:13:55:696]: PROPERTY CHANGE: Modifying PubSub.resources_Framework_es.lproj property. Its current value is 'C:\Program Files\Safari\PubSub.resources\Framework\es.lproj'. Its new value: 'C:\Program Files\Safari\PubSub.resources\Framework\es.lproj\'.
                MSI (s) (A4:F8) [11:13:55:696]: PROPERTY CHANGE: Modifying PubSub.resources_Framework_English.lproj property. Its current value is 'C:\Program Files\Safari\PubSub.resources\Framework\English.lproj'. Its new value: 'C:\Program Files\Safari\PubSub.resources\Framework\English.lproj\'.
                MSI (s) (A4:F8) [11:13:55:696]: PROPERTY CHANGE: Modifying PubSub.resources_Framework_de.lproj property. Its current value is 'C:\Program Files\Safari\PubSub.resources\Framework\de.lproj'. Its new value: 'C:\Program Files\Safari\PubSub.resources\Framework\de.lproj\'.
                MSI (s) (A4:F8) [11:13:55:696]: PROPERTY CHANGE: Modifying PubSub.resources_Framework_da.lproj property. Its current value is 'C:\Program Files\Safari\PubSub.resources\Framework\da.lproj'. Its new value: 'C:\Program Files\Safari\PubSub.resources\Framework\da.lproj\'.
                MSI (s) (A4:F8) [11:13:55:696]: PROPERTY CHANGE: Modifying PubSub.resources_fr.lproj property. Its current value is 'C:\Program Files\Safari\PubSub.resources\fr.lproj'. Its new value: 'C:\Program Files\Safari\PubSub.resources\fr.lproj\'.
                MSI (s) (A4:F8) [11:13:55:696]: PROPERTY CHANGE: Modifying PubSub.resources_fi.lproj property. Its current value is 'C:\Program Files\Safari\PubSub.resources\fi.lproj'. Its new value: 'C:\Program Files\Safari\PubSub.resources\fi.lproj\'.
                MSI (s) (A4:F8) [11:13:55:696]: PROPERTY CHANGE: Modifying PubSub.resources_es.lproj property. Its current value is 'C:\Program Files\Safari\PubSub.resources\es.lproj'. Its new value: 'C:\Program Files\Safari\PubSub.resources\es.lproj\'.
                MSI (s) (A4:F8) [11:13:55:696]: PROPERTY CHANGE: Modifying PubSub.resources_English.lproj property. Its current value is 'C:\Program Files\Safari\PubSub.resources\English.lproj'. Its new value: 'C:\Program Files\Safari\PubSub.resources\English.lproj\'.
                MSI (s) (A4:F8) [11:13:55:712]: PROPERTY CHANGE: Modifying PubSub.resources_de.lproj property. Its current value is 'C:\Program Files\Safari\PubSub.resources\de.lproj'. Its new value: 'C:\Program Files\Safari\PubSub.resources\de.lproj\'.
                MSI (s) (A4:F8) [11:13:55:712]: PROPERTY CHANGE: Modifying PubSub.resources_da.lproj property. Its current value is 'C:\Program Files\Safari\PubSub.resources\da.lproj'. Its new value: 'C:\Program Files\Safari\PubSub.resources\da.lproj\'.
                MSI (s) (A4:F8) [11:13:55:712]: PROPERTY CHANGE: Modifying SafariTheme.resources property. Its current value is 'C:\Program Files\Safari\SafariTheme.resources'. Its new value: 'C:\Program Files\Safari\SafariTheme.resources\'.
                MSI (s) (A4:F8) [11:13:55:712]: PROPERTY CHANGE: Modifying Safari.resources property. Its current value is 'C:\Program Files\Safari\Safari.resources'. Its new value: 'C:\Program Files\Safari\Safari.resources\'.
                MSI (s) (A4:F8) [11:13:55:712]: PROPERTY CHANGE: Modifying Safari.resources_zh_TW.lproj property. Its current value is 'C:\Program Files\Safari\Safari.resources\zh_TW.lproj'. Its new value: 'C:\Program Files\Safari\Safari.resources\zh_TW.lproj\'.
                MSI (s) (A4:F8) [11:13:55:712]: PROPERTY CHANGE: Modifying Safari.resources_zh_CN.lproj property. Its current value is 'C:\Program Files\Safari\Safari.resources\zh_CN.lproj'. Its new value: 'C:\Program Files\Safari\Safari.resources\zh_CN.lproj\'.
                MSI (s) (A4:F8) [11:13:55:712]: PROPERTY CHANGE: Modifying Safari.resources_sv.lproj property. Its current value is 'C:\Program Files\Safari\Safari.resources\sv.lproj'. Its new value: 'C:\Program Files\Safari\Safari.resources\sv.lproj\'.
                MSI (s) (A4:F8) [11:13:55:712]: PROPERTY CHANGE: Modifying Safari.resources_SnippetEditor property. Its current value is 'C:\Program Files\Safari\Safari.resources\SnippetEditor'. Its new value: 'C:\Program Files\Safari\Safari.resources\SnippetEditor\'.
                MSI (s) (A4:F8) [11:13:55:712]: PROPERTY CHANGE: Modifying Safari.resources_SnippetEditor_Images property. Its current value is 'C:\Program Files\Safari\Safari.resources\SnippetEditor\Images'. Its new value: 'C:\Program Files\Safari\Safari.resources\SnippetEditor\Images\'.
                MSI (s) (A4:F8) [11:13:55:712]: PROPERTY CHANGE: Modifying Safari.resources_ru.lproj property. Its current value is 'C:\Program Files\Safari\Safari.resources\ru.lproj'. Its new value: 'C:\Program Files\Safari\Safari.resources\ru.lproj\'.
                MSI (s) (A4:F8) [11:13:55:712]: PROPERTY CHANGE: Modifying Safari.resources_pt_PT.lproj property. Its current value is 'C:\Program Files\Safari\Safari.resources\pt_PT.lproj'. Its new value: 'C:\Program Files\Safari\Safari.resources\pt_PT.lproj\'.
                MSI (s) (A4:F8) [11:13:55:712]: PROPERTY CHANGE: Modifying Safari.resources_pt.lproj property. Its current value is 'C:\Program Files\Safari\Safari.resources\pt.lproj'. Its new value: 'C:\Program Files\Safari\Safari.resources\pt.lproj\'.
                MSI (s) (A4:F8) [11:13:55:712]: PROPERTY CHANGE: Modifying Safari.resources_pl.lproj property. Its current value is 'C:\Program Files\Safari\Safari.resources\pl.lproj'. Its new value: 'C:\Program Files\Safari\Safari.resources\pl.lproj\'.
                MSI (s) (A4:F8) [11:13:55:712]: PROPERTY CHANGE: Modifying Safari.resources_nl.lproj property. Its current value is 'C:\Program Files\Safari\Safari.resources\nl.lproj'. Its new value: 'C:\Program Files\Safari\Safari.resources\nl.lproj\'.
                MSI (s) (A4:F8) [11:13:55:712]: PROPERTY CHANGE: Modifying Safari.resources_nb.lproj property. Its current value is 'C:\Program Files\Safari\Safari.resources\nb.lproj'. Its new value: 'C:\Program Files\Safari\Safari.resources\nb.lproj\'.
                MSI (s) (A4:F8) [11:13:55:712]: PROPERTY CHANGE: Modifying Safari.resources_ko.lproj property. Its current value is 'C:\Program Files\Safari\Safari.resources\ko.lproj'. Its new value: 'C:\Program Files\Safari\Safari.resources\ko.lproj\'.
                MSI (s) (A4:F8) [11:13:55:712]: PROPERTY CHANGE: Modifying Safari.resources_ja.lproj property. Its current value is 'C:\Program Files\Safari\Safari.resources\ja.lproj'. Its new value: 'C:\Program Files\Safari\Safari.resources\ja.lproj\'.
                MSI (s) (A4:F8) [11:13:55:712]: PROPERTY CHANGE: Modifying Safari.resources_it.lproj property. Its current value is 'C:\Program Files\Safari\Safari.resources\it.lproj'. Its new value: 'C:\Program Files\Safari\Safari.resources\it.lproj\'.
                MSI (s) (A4:F8) [11:13:55:712]: PROPERTY CHANGE: Modifying Safari.resources_Help property. Its current value is 'C:\Program Files\Safari\Safari.resources\Help'. Its new value: 'C:\Program Files\Safari\Safari.resources\Help\'.
                MSI (s) (A4:F8) [11:13:55:712]: PROPERTY CHANGE: Modifying Safari.resources_Help_zh_TW.lproj property. Its current value is 'C:\Program Files\Safari\Safari.resources\Help\zh_TW.lproj'. Its new value: 'C:\Program Files\Safari\Safari.resources\Help\zh_TW.lproj\'.
                MSI (s) (A4:F8) [11:13:55:712]: PROPERTY CHANGE: Modifying Safari.resources_Help_zh_CN.lproj property. Its current value is 'C:\Program Files\Safari\Safari.resources\Help\zh_CN.lproj'. Its new value: 'C:\Program Files\Safari\Safari.resources\Help\zh_CN.lproj\'.
                MSI (s) (A4:F8) [11:13:55:712]: PROPERTY CHANGE: Modifying Safari.resources_Help_sv.lproj property. Its current value is 'C:\Program Files\Safari\Safari.resources\Help\sv.lproj'. Its new value: 'C:\Program Files\Safari\Safari.resources\Help\sv.lproj\'.
                MSI (s) (A4:F8) [11:13:55:712]: PROPERTY CHANGE: Modifying Safari.resources_Help_ru.lproj property. Its current value is 'C:\Program Files\Safari\Safari.resources\Help\ru.lproj'. Its new value: 'C:\Program Files\Safari\Safari.resources\Help\ru.lproj\'.
                MSI (s) (A4:F8) [11:13:55:712]: PROPERTY CHANGE: Modifying Safari.resources_Help_pt_PT.lproj property. Its current value is 'C:\Program Files\Safari\Safari.resources\Help\pt_PT.lproj'. Its new value: 'C:\Program Files\Safari\Safari.resources\Help\pt_PT.lproj\'.
                MSI (s) (A4:F8) [11:13:55:712]: PROPERTY CHANGE: Modifying Safari.resources_Help_pt.lproj property. Its current value is 'C:\Program Files\Safari\Safari.resources\Help\pt.lproj'. Its new value: 'C:\Program Files\Safari\Safari.resources\Help\pt.lproj\'.
                MSI (s) (A4:F8) [11:13:55:712]: PROPERTY CHANGE: Modifying Safari.resources_Help_pl.lproj property. Its current value is 'C:\Program Files\Safari\Safari.resources\Help\pl.lproj'. Its new value: 'C:\Program Files\Safari\Safari.resources\Help\pl.lproj\'.
                MSI (s) (A4:F8) [11:13:55:712]: PROPERTY CHANGE: Modifying Safari.resources_Help_nl.lproj property. Its current value is 'C:\Program Files\Safari\Safari.resources\Help\nl.lproj'. Its new value: 'C:\Program Files\Safari\Safari.resources\Help\nl.lproj\'.
                MSI (s) (A4:F8) [11:13:55:712]: PROPERTY CHANGE: Modifying Safari.resources_Help_nb.lproj property. Its current value is 'C:\Program Files\Safari\Safari.resources\Help\nb.lproj'. Its new value: 'C:\Program Files\Safari\Safari.resources\Help\nb.lproj\'.
                MSI (s) (A4:F8) [11:13:55:712]: PROPERTY CHANGE: Modifying Safari.resources_Help_ko.lproj property. Its current value is 'C:\Program Files\Safari\Safari.resources\Help\ko.lproj'. Its new value: 'C:\Program Files\Safari\Safari.resources\Help\ko.lproj\'.
                MSI (s) (A4:F8) [11:13:55:712]: PROPERTY CHANGE: Modifying Safari.resources_Help_ja.lproj property. Its current value is 'C:\Program Files\Safari\Safari.resources\Help\ja.lproj'. Its new value: 'C:\Program Files\Safari\Safari.resources\Help\ja.lproj\'.
                MSI (s) (A4:F8) [11:13:55:712]: PROPERTY CHANGE: Modifying Safari.resources_Help_it.lproj property. Its current value is 'C:\Program Files\Safari\Safari.resources\Help\it.lproj'. Its new value: 'C:\Program Files\Safari\Safari.resources\Help\it.lproj\'.
                MSI (s) (A4:F8) [11:13:55:712]: PROPERTY CHANGE: Modifying Safari.resources_Help_fr.lproj property. Its current value is 'C:\Program Files\Safari\Safari.resources\Help\fr.lproj'. Its new value: 'C:\Program Files\Safari\Safari.resources\Help\fr.lproj\'.
                MSI (s) (A4:F8) [11:13:55:712]: PROPERTY CHANGE: Modifying Safari.resources_Help_fi.lproj property. Its current value is 'C:\Program Files\Safari\Safari.resources\Help\fi.lproj'. Its new value: 'C:\Program Files\Safari\Safari.resources\Help\fi.lproj\'.
                MSI (s) (A4:F8) [11:13:55:712]: PROPERTY CHANGE: Modifying Safari.resources_Help_es.lproj property. Its current value is 'C:\Program Files\Safari\Safari.resources\Help\es.lproj'. Its new value: 'C:\Program Files\Safari\Safari.resources\Help\es.lproj\'.
                MSI (s) (A4:F8) [11:13:55:712]: PROPERTY CHANGE: Modifying Safari.resources_Help_en.lproj property. Its current value is 'C:\Program Files\Safari\Safari.resources\Help\en.lproj'. Its new value: 'C:\Program Files\Safari\Safari.resources\Help\en.lproj\'.
                MSI (s) (A4:F8) [11:13:55:712]: PROPERTY CHANGE: Modifying Safari.resources_Help_de.lproj property. Its current value is 'C:\Program Files\Safari\Safari.resources\Help\de.lproj'. Its new value: 'C:\Program Files\Safari\Safari.resources\Help\de.lproj\'.
                MSI (s) (A4:F8) [11:13:55:712]: PROPERTY CHANGE: Modifying Safari.resources_Help_da.lproj property. Its current value is 'C:\Program Files\Safari\Safari.resources\Help\da.lproj'. Its new value: 'C:\Program Files\Safari\Safari.resources\Help\da.lproj\'.
                MSI (s) (A4:F8) [11:13:55:712]: PROPERTY CHANGE: Modifying Safari.resources_fr.lproj property. Its current value is 'C:\Program Files\Safari\Safari.resources\fr.lproj'. Its new value: 'C:\Program Files\Safari\Safari.resources\fr.lproj\'.
                MSI (s) (A4:F8) [11:13:55:712]: PROPERTY CHANGE: Modifying Safari.resources_fi.lproj property. Its current value is 'C:\Program Files\Safari\Safari.resources\fi.lproj'. Its new value: 'C:\Program Files\Safari\Safari.resources\fi.lproj\'.
                MSI (s) (A4:F8) [11:13:55:712]: PROPERTY CHANGE: Modifying Safari.resources_es.lproj property. Its current value is 'C:\Program Files\Safari\Safari.resources\es.lproj'. Its new value: 'C:\Program Files\Safari\Safari.resources\es.lproj\'.
                MSI (s) (A4:F8) [11:13:55:712]: PROPERTY CHANGE: Modifying Safari.resources_en_GB.lproj property. Its current value is 'C:\Program Files\Safari\Safari.resources\en_GB.lproj'. Its new value: 'C:\Program Files\Safari\Safari.resources\en_GB.lproj\'.
                MSI (s) (A4:F8) [11:13:55:712]: PROPERTY CHANGE: Modifying Safari.resources_en_CA.lproj property. Its current value is 'C:\Program Files\Safari\Safari.resources\en_CA.lproj'. Its new value: 'C:\Program Files\Safari\Safari.resources\en_CA.lproj\'.
                MSI (s) (A4:F8) [11:13:55:712]: PROPERTY CHANGE: Modifying Safari.resources_en_AU.lproj property. Its current value is 'C:\Program Files\Safari\Safari.resources\en_AU.lproj'. Its new value: 'C:\Program Files\Safari\Safari.resources\en_AU.lproj\'.
                MSI (s) (A4:F8) [11:13:55:712]: PROPERTY CHANGE: Modifying Safari.resources_en.lproj property. Its current value is 'C:\Program Files\Safari\Safari.resources\en.lproj'. Its new value: 'C:\Program Files\Safari\Safari.resources\en.lproj\'.
                MSI (s) (A4:F8) [11:13:55:712]: PROPERTY CHANGE: Modifying Safari.resources_de.lproj property. Its current value is 'C:\Program Files\Safari\Safari.resources\de.lproj'. Its new value: 'C:\Program Files\Safari\Safari.resources\de.lproj\'.
                MSI (s) (A4:F8) [11:13:55:712]: PROPERTY CHANGE: Modifying Safari.resources_da.lproj property. Its current value is 'C:\Program Files\Safari\Safari.resources\da.lproj'. Its new value: 'C:\Program Files\Safari\Safari.resources\da.lproj\'.
                MSI (s) (A4:F8) [11:13:55:712]: PROPERTY CHANGE: Modifying Safari.resources_BookmarkChooser property. Its current value is 'C:\Program Files\Safari\Safari.resources\BookmarkChooser'. Its new value: 'C:\Program Files\Safari\Safari.resources\BookmarkChooser\'.
                MSI (s) (A4:F8) [11:13:55:712]: PROPERTY CHANGE: Modifying PluginsFolder property. Its current value is 'C:\Program Files\Safari\Plugins'. Its new value: 'C:\Program Files\Safari\Plugins\'.
                MSI (s) (A4:F8) [11:13:55:712]: Target path resolution complete. Dumping Directory table...
                MSI (s) (A4:F8) [11:13:55:712]: Note: target paths subject to change (via custom actions or browsing)
                MSI (s) (A4:F8) [11:13:55:712]: Dir (target): Key: TARGETDIR          , Object: C:\
                MSI (s) (A4:F8) [11:13:55:712]: Dir (target): Key: SourceDir          , Object: NULL
                MSI (s) (A4:F8) [11:13:55:712]: Dir (target): Key: WindowsFolder          , Object: C:\Windows\
                MSI (s) (A4:F8) [11:13:55:712]: Dir (target): Key: ProgramMenuFolder          , Object: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\
                MSI (s) (A4:F8) [11:13:55:712]: Dir (target): Key: SafariProgramMenuFolder          , Object: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Safari\
                MSI (s) (A4:F8) [11:13:55:712]: Dir (target): Key: AppDataFolder          , Object: C:\Users\Administrator\AppData\Roaming\
                MSI (s) (A4:F8) [11:13:55:712]: Dir (target): Key: MicrosoftAppDataFolder          , Object: C:\Users\Administrator\AppData\Roaming\Microsoft\
                MSI (s) (A4:F8) [11:13:55:712]: Dir (target): Key: InternetExplorerAppDataFolder          , Object: C:\Users\Administrator\AppData\Roaming\Microsoft\Internet Explorer\
                MSI (s) (A4:F8) [11:13:55:712]: Dir (target): Key: QuickLaunchFolder          , Object: C:\Users\Administrator\AppData\Roaming\Microsoft\Internet Explorer\Quick Launch\
                MSI (s) (A4:F8) [11:13:55:712]: Dir (target): Key: CommonAppDataFolder          , Object: C:\ProgramData\
                MSI (s) (A4:F8) [11:13:55:712]: Dir (target): Key: AppleCommonAppDataFolder          , Object: C:\ProgramData\Apple Computer\
                MSI (s) (A4:F8) [11:13:55:712]: Dir (target): Key: CachedInstallationsFolder          , Object: C:\ProgramData\Apple Computer\Installer Cache\
                MSI (s) (A4:F8) [11:13:55:712]: Dir (target): Key: INSTALLERCACHE          , Object: C:\ProgramData\Apple Computer\Installer Cache\Safari 5.34.52.7\
                MSI (s) (A4:F8) [11:13:55:712]: Dir (target): Key: DesktopFolder          , Object: C:\Users\Public\Desktop\
                MSI (s) (A4:F8) [11:13:55:712]: Dir (target): Key: ProgramFilesFolder          , Object: C:\Program Files\
                MSI (s) (A4:F8) [11:13:55:712]: Dir (target): Key: SafariFolder          , Object: C:\Program Files\Safari\
                MSI (s) (A4:F8) [11:13:55:712]: Dir (target): Key: INSTALLDIR          , Object: C:\Program Files\Safari\
                MSI (s) (A4:F8) [11:13:55:712]: Dir (target): Key: PubSub.resources          , Object: C:\Program Files\Safari\PubSub.resources\
                MSI (s) (A4:F8) [11:13:55:712]: Dir (target): Key: PubSub.resources_zh_TW.lproj          , Object: C:\Program Files\Safari\PubSub.resources\zh_TW.lproj\
                MSI (s) (A4:F8) [11:13:55:712]: Dir (target): Key: PubSub.resources_zh_CN.lproj          , Object: C:\Program Files\Safari\PubSub.resources\zh_CN.lproj\
                MSI (s) (A4:F8) [11:13:55:712]: Dir (target): Key: PubSub.resources_sv.lproj          , Object: C:\Program Files\Safari\PubSub.resources\sv.lproj\
                MSI (s) (A4:F8) [11:13:55:712]: Dir (target): Key: PubSub.resources_ru.lproj          , Object: C:\Program Files\Safari\PubSub.resources\ru.lproj\
                MSI (s) (A4:F8) [11:13:55:712]: Dir (target): Key: PubSub.resources_pt_PT.lproj          , Object: C:\Program Files\Safari\PubSub.resources\pt_PT.lproj\
                MSI (s) (A4:F8) [11:13:55:712]: Dir (target): Key: PubSub.resources_pt.lproj          , Object: C:\Program Files\Safari\PubSub.resources\pt.lproj\
                MSI (s) (A4:F8) [11:13:55:712]: Dir (target): Key: PubSub.resources_pl.lproj          , Object: C:\Program Files\Safari\PubSub.resources\pl.lproj\
                MSI (s) (A4:F8) [11:13:55:712]: Dir (target): Key: PubSub.resources_nl.lproj          , Object: C:\Program Files\Safari\PubSub.resources\nl.lproj\
                MSI (s) (A4:F8) [11:13:55:712]: Dir (target): Key: PubSub.resources_nb.lproj          , Object: C:\Program Files\Safari\PubSub.resources\nb.lproj\
                MSI (s) (A4:F8) [11:13:55:712]: Dir (target): Key: PubSub.resources_ko.lproj          , Object: C:\Program Files\Safari\PubSub.resources\ko.lproj\
                MSI (s) (A4:F8) [11:13:55:712]: Dir (target): Key: PubSub.resources_ja.lproj          , Object: C:\Program Files\Safari\PubSub.resources\ja.lproj\
                MSI (s) (A4:F8) [11:13:55:712]: Dir (target): Key: PubSub.resources_it.lproj          , Object: C:\Program Files\Safari\PubSub.resources\it.lproj\
                MSI (s) (A4:F8) [11:13:55:712]: Dir (target): Key: PubSub.resources_Framework          , Object: C:\Program Files\Safari\PubSub.resources\Framework\
                MSI (s) (A4:F8) [11:13:55:712]: Dir (target): Key: PubSub.resources_Framework_zh_TW.lproj          , Object: C:\Program Files\Safari\PubSub.resources\Framework\zh_TW.lproj\
                MSI (s) (A4:F8) [11:13:55:712]: Dir (target): Key: PubSub.resources_Framework_zh_CN.lproj          , Object: C:\Program Files\Safari\PubSub.resources\Framework\zh_CN.lproj\
                MSI (s) (A4:F8) [11:13:55:712]: Dir (target): Key: PubSub.resources_Framework_sv.lproj          , Object: C:\Program Files\Safari\PubSub.resources\Framework\sv.lproj\
                MSI (s) (A4:F8) [11:13:55:712]: Dir (target): Key: PubSub.resources_Framework_ru.lproj          , Object: C:\Program Files\Safari\PubSub.resources\Framework\ru.lproj\
                MSI (s) (A4:F8) [11:13:55:712]: Dir (target): Key: PubSub.resources_Framework_pt_PT.lproj          , Object: C:\Program Files\Safari\PubSub.resources\Framework\pt_PT.lproj\
                MSI (s) (A4:F8) [11:13:55:712]: Dir (target): Key: PubSub.resources_Framework_pt.lproj          , Object: C:\Program Files\Safari\PubSub.resources\Framework\pt.lproj\
                MSI (s) (A4:F8) [11:13:55:712]: Dir (target): Key: PubSub.resources_Framework_pl.lproj          , Object: C:\Program Files\Safari\PubSub.resources\Framework\pl.lproj\
                MSI (s) (A4:F8) [11:13:55:712]: Dir (target): Key: PubSub.resources_Framework_nl.lproj          , Object: C:\Program Files\Safari\PubSub.resources\Framework\nl.lproj\
                MSI (s) (A4:F8) [11:13:55:712]: Dir (target): Key: PubSub.resources_Framework_nb.lproj          , Object: C:\Program Files\Safari\PubSub.resources\Framework\nb.lproj\
                MSI (s) (A4:F8) [11:13:55:712]: Dir (target): Key: PubSub.resources_Framework_ko.lproj          , Object: C:\Program Files\Safari\PubSub.resources\Framework\ko.lproj\
                MSI (s) (A4:F8) [11:13:55:712]: Dir (target): Key: PubSub.resources_Framework_ja.lproj          , Object: C:\Program Files\Safari\PubSub.resources\Framework\ja.lproj\
                MSI (s) (A4:F8) [11:13:55:712]: Dir (target): Key: PubSub.resources_Framework_it.lproj          , Object: C:\Program Files\Safari\PubSub.resources\Framework\it.lproj\
                MSI (s) (A4:F8) [11:13:55:712]: Dir (target): Key: PubSub.resources_Framework_fr.lproj          , Object: C:\Program Files\Safari\PubSub.resources\Framework\fr.lproj\
                MSI (s) (A4:F8) [11:13:55:712]: Dir (target): Key: PubSub.resources_Framework_fi.lproj          , Object: C:\Program Files\Safari\PubSub.resources\Framework\fi.lproj\
                MSI (s) (A4:F8) [11:13:55:712]: Dir (target): Key: PubSub.resources_Framework_es.lproj          , Object: C:\Program Files\Safari\PubSub.resources\Framework\es.lproj\
                MSI (s) (A4:F8) [11:13:55:712]: Dir (target): Key: PubSub.resources_Framework_English.lproj          , Object: C:\Program Files\Safari\PubSub.resources\Framework\English.lproj\
                MSI (s) (A4:F8) [11:13:55:712]: Dir (target): Key: PubSub.resources_Framework_de.lproj          , Object: C:\Program Files\Safari\PubSub.resources\Framework\de.lproj\
                MSI (s) (A4:F8) [11:13:55:712]: Dir (target): Key: PubSub.resources_Framework_da.lproj          , Object: C:\Program Files\Safari\PubSub.resources\Framework\da.lproj\
                MSI (s) (A4:F8) [11:13:55:712]: Dir (target): Key: PubSub.resources_fr.lproj          , Object: C:\Program Files\Safari\PubSub.resources\fr.lproj\
                MSI (s) (A4:F8) [11:13:55:712]: Dir (target): Key: PubSub.resources_fi.lproj          , Object: C:\Program Files\Safari\PubSub.resources\fi.lproj\
                MSI (s) (A4:F8) [11:13:55:712]: Dir (target): Key: PubSub.resources_es.lproj          , Object: C:\Program Files\Safari\PubSub.resources\es.lproj\
                MSI (s) (A4:F8) [11:13:55:712]: Dir (target): Key: PubSub.resources_English.lproj          , Object: C:\Program Files\Safari\PubSub.resources\English.lproj\
                MSI (s) (A4:F8) [11:13:55:712]: Dir (target): Key: PubSub.resources_de.lproj          , Object: C:\Program Files\Safari\PubSub.resources\de.lproj\
                MSI (s) (A4:F8) [11:13:55:712]: Dir (target): Key: PubSub.resources_da.lproj          , Object: C:\Program Files\Safari\PubSub.resources\da.lproj\
                MSI (s) (A4:F8) [11:13:55:712]: Dir (target): Key: SafariTheme.resources          , Object: C:\Program Files\Safari\SafariTheme.resources\
                MSI (s) (A4:F8) [11:13:55:712]: Dir (target): Key: Safari.resources          , Object: C:\Program Files\Safari\Safari.resources\
                MSI (s) (A4:F8) [11:13:55:712]: Dir (target): Key: Safari.resources_zh_TW.lproj          , Object: C:\Program Files\Safari\Safari.resources\zh_TW.lproj\
                MSI (s) (A4:F8) [11:13:55:712]: Dir (target): Key: Safari.resources_zh_CN.lproj          , Object: C:\Program Files\Safari\Safari.resources\zh_CN.lproj\
                MSI (s) (A4:F8) [11:13:55:712]: Dir (target): Key: Safari.resources_sv.lproj          , Object: C:\Program Files\Safari\Safari.resources\sv.lproj\
                MSI (s) (A4:F8) [11:13:55:712]: Dir (target): Key: Safari.resources_SnippetEditor          , Object: C:\Program Files\Safari\Safari.resources\SnippetEditor\
                MSI (s) (A4:F8) [11:13:55:712]: Dir (target): Key: Safari.resources_SnippetEditor_Images          , Object: C:\Program Files\Safari\Safari.resources\SnippetEditor\Images\
                MSI (s) (A4:F8) [11:13:55:712]: Dir (target): Key: Safari.resources_ru.lproj          , Object: C:\Program Files\Safari\Safari.resources\ru.lproj\
                MSI (s) (A4:F8) [11:13:55:712]: Dir (target): Key: Safari.resources_pt_PT.lproj          , Object: C:\Program Files\Safari\Safari.resources\pt_PT.lproj\
                MSI (s) (A4:F8) [11:13:55:712]: Dir (target): Key: Safari.resources_pt.lproj          , Object: C:\Program Files\Safari\Safari.resources\pt.lproj\
                MSI (s) (A4:F8) [11:13:55:712]: Dir (target): Key: Safari.resources_pl.lproj          , Object: C:\Program Files\Safari\Safari.resources\pl.lproj\
                MSI (s) (A4:F8) [11:13:55:712]: Dir (target): Key: Safari.resources_nl.lproj          , Object: C:\Program Files\Safari\Safari.resources\nl.lproj\
                MSI (s) (A4:F8) [11:13:55:712]: Dir (target): Key: Safari.resources_nb.lproj          , Object: C:\Program Files\Safari\Safari.resources\nb.lproj\
                MSI (s) (A4:F8) [11:13:55:712]: Dir (target): Key: Safari.resources_ko.lproj          , Object: C:\Program Files\Safari\Safari.resources\ko.lproj\
                MSI (s) (A4:F8) [11:13:55:712]: Dir (target): Key: Safari.resources_ja.lproj          , Object: C:\Program Files\Safari\Safari.resources\ja.lproj\
                MSI (s) (A4:F8) [11:13:55:712]: Dir (target): Key: Safari.resources_it.lproj          , Object: C:\Program Files\Safari\Safari.resources\it.lproj\
                MSI (s) (A4:F8) [11:13:55:712]: Dir (target): Key: Safari.resources_Help          , Object: C:\Program Files\Safari\Safari.resources\Help\
                MSI (s) (A4:F8) [11:13:55:712]: Dir (target): Key: Safari.resources_Help_zh_TW.lproj          , Object: C:\Program Files\Safari\Safari.resources\Help\zh_TW.lproj\
                MSI (s) (A4:F8) [11:13:55:712]: Dir (target): Key: Safari.resources_Help_zh_CN.lproj          , Object: C:\Program Files\Safari\Safari.resources\Help\zh_CN.lproj\
                MSI (s) (A4:F8) [11:13:55:712]: Dir (target): Key: Safari.resources_Help_sv.lproj          , Object: C:\Program Files\Safari\Safari.resources\Help\sv.lproj\
                MSI (s) (A4:F8) [11:13:55:712]: Dir (target): Key: Safari.resources_Help_ru.lproj          , Object: C:\Program Files\Safari\Safari.resources\Help\ru.lproj\
                MSI (s) (A4:F8) [11:13:55:712]: Dir (target): Key: Safari.resources_Help_pt_PT.lproj          , Object: C:\Program Files\Safari\Safari.resources\Help\pt_PT.lproj\
                MSI (s) (A4:F8) [11:13:55:712]: Dir (target): Key: Safari.resources_Help_pt.lproj          , Object: C:\Program Files\Safari\Safari.resources\Help\pt.lproj\
                MSI (s) (A4:F8) [11:13:55:712]: Dir (target): Key: Safari.resources_Help_pl.lproj          , Object: C:\Program Files\Safari\Safari.resources\Help\pl.lproj\
                MSI (s) (A4:F8) [11:13:55:712]: Dir (target): Key: Safari.resources_Help_nl.lproj          , Object: C:\Program Files\Safari\Safari.resources\Help\nl.lproj\
                MSI (s) (A4:F8) [11:13:55:712]: Dir (target): Key: Safari.resources_Help_nb.lproj          , Object: C:\Program Files\Safari\Safari.resources\Help\nb.lproj\
                MSI (s) (A4:F8) [11:13:55:712]: Dir (target): Key: Safari.resources_Help_ko.lproj          , Object: C:\Program Files\Safari\Safari.resources\Help\ko.lproj\
                MSI (s) (A4:F8) [11:13:55:712]: Dir (target): Key: Safari.resources_Help_ja.lproj          , Object: C:\Program Files\Safari\Safari.resources\Help\ja.lproj\
                MSI (s) (A4:F8) [11:13:55:712]: Dir (target): Key: Safari.resources_Help_it.lproj          , Object: C:\Program Files\Safari\Safari.resources\Help\it.lproj\
                MSI (s) (A4:F8) [11:13:55:712]: Dir (target): Key: Safari.resources_Help_fr.lproj          , Object: C:\Program Files\Safari\Safari.resources\Help\fr.lproj\
                MSI (s) (A4:F8) [11:13:55:712]: Dir (target): Key: Safari.resources_Help_fi.lproj          , Object: C:\Program Files\Safari\Safari.resources\Help\fi.lproj\
                MSI (s) (A4:F8) [11:13:55:712]: Dir (target): Key: Safari.resources_Help_es.lproj          , Object: C:\Program Files\Safari\Safari.resources\Help\es.lproj\
                MSI (s) (A4:F8) [11:13:55:712]: Dir (target): Key: Safari.resources_Help_en.lproj          , Object: C:\Program Files\Safari\Safari.resources\Help\en.lproj\
                MSI (s) (A4:F8) [11:13:55:712]: Dir (target): Key: Safari.resources_Help_de.lproj          , Object: C:\Program Files\Safari\Safari.resources\Help\de.lproj\
                MSI (s) (A4:F8) [11:13:55:712]: Dir (target): Key: Safari.resources_Help_da.lproj          , Object: C:\Program Files\Safari\Safari.resources\Help\da.lproj\
                MSI (s) (A4:F8) [11:13:55:712]: Dir (target): Key: Safari.resources_fr.lproj          , Object: C:\Program Files\Safari\Safari.resources\fr.lproj\
                MSI (s) (A4:F8) [11:13:55:712]: Dir (target): Key: Safari.resources_fi.lproj          , Object: C:\Program Files\Safari\Safari.resources\fi.lproj\
                MSI (s) (A4:F8) [11:13:55:712]: Dir (target): Key: Safari.resources_es.lproj          , Object: C:\Program Files\Safari\Safari.resources\es.lproj\
                MSI (s) (A4:F8) [11:13:55:712]: Dir (target): Key: Safari.resources_en_GB.lproj          , Object: C:\Program Files\Safari\Safari.resources\en_GB.lproj\
                MSI (s) (A4:F8) [11:13:55:712]: Dir (target): Key: Safari.resources_en_CA.lproj          , Object: C:\Program Files\Safari\Safari.resources\en_CA.lproj\
                MSI (s) (A4:F8) [11:13:55:712]: Dir (target): Key: Safari.resources_en_AU.lproj          , Object: C:\Program Files\Safari\Safari.resources\en_AU.lproj\
                MSI (s) (A4:F8) [11:13:55:712]: Dir (target): Key: Safari.resources_en.lproj          , Object: C:\Program Files\Safari\Safari.resources\en.lproj\
                MSI (s) (A4:F8) [11:13:55:712]: Dir (target): Key: Safari.resources_de.lproj          , Object: C:\Program Files\Safari\Safari.resources\de.lproj\
                MSI (s) (A4:F8) [11:13:55:712]: Dir (target): Key: Safari.resources_da.lproj          , Object: C:\Program Files\Safari\Safari.resources\da.lproj\
                MSI (s) (A4:F8) [11:13:55:712]: Dir (target): Key: Safari.resources_BookmarkChooser          , Object: C:\Program Files\Safari\Safari.resources\BookmarkChooser\
                MSI (s) (A4:F8) [11:13:55:712]: Dir (target): Key: PluginsFolder          , Object: C:\Program Files\Safari\Plugins\
                MSI (s) (A4:F8) [11:13:55:712]: PROPERTY CHANGE: Adding INSTALLLEVEL property. Its value is '1'.
                MSI (s) (A4:F8) [11:14:42:543]: Skipping action: Set_SOURCELIST (condition is false)
                MSI (s) (A4:F8) [11:14:42:543]: Doing action: MigrateFeatureStates
                Action ended 11:14:42: CostFinalize. Return value 1.
                MSI (s) (A4:F8) [11:14:42:543]: Skipping MigrateFeatureStates action: not run in maintenance mode
                Action start 11:14:42: MigrateFeatureStates.
                MSI (s) (A4:F8) [11:14:42:543]: Doing action: InstallValidate
                Action ended 11:14:42: MigrateFeatureStates. Return value 0.
                MSI (s) (A4:F8) [11:14:42:543]: PROPERTY CHANGE: Deleting MsiRestartManagerSessionKey property. Its current value is '41d2dce9d872a243915ad9c3828d1e7c'.
                MSI (s) (A4:F8) [11:14:42:543]: Feature: Safari; Installed: Local;   Request: Reinstall;   Action: Reinstall
                MSI (s) (A4:F8) [11:14:42:543]: Component: Safari.dll; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:543]: Component: RemoveBallotCookie; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:543]: Component: PubSubDLL.dll; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:543]: Component: Search.dll; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:543]: Component: SpellChecker.dll; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:543]: Component: Safari.exe; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:543]: Component: SafariClassesRegistry; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:543]: Component: SafariStartMenuRegistry; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:543]: Component: SafariTheme.dll; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:543]: Component: npJavaPlugin.dll; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:543]: Component: SafariDesktopShortcuts; Installed: Local;   Request: Local;   Action: Local;   Client State: Absent
                MSI (s) (A4:F8) [11:14:42:543]: Component: SafariInstallerCache; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:543]: Component: Safari.resources_ABAddressFormats.plist; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:543]: Component: Safari.resources_About.html; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:543]: Component: Safari.resources_AddButtonGlyph.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:543]: Component: Safari.resources_AddressBookEntryView.html; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:543]: Component: Safari.resources_AddressCard.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:543]: Component: Safari.resources_AdvancedPreferences.html; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:543]: Component: Safari.resources_AlertDialog.html; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:543]: Component: Safari.resources_aol666.pltsuite; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:543]: Component: Safari.resources_AppearancePreferences.html; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:543]: Component: Safari.resources_AutoFill.js; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:543]: Component: Safari.resources_AutoFillPreferences.html; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:543]: Component: Safari.resources_badgeFill.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:543]: Component: Safari.resources_badgeFillInactive.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:543]: Component: Safari.resources_badgeLeftCap.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:543]: Component: Safari.resources_badgeLeftCapInactive.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:543]: Component: Safari.resources_badgeRightCap.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:543]: Component: Safari.resources_badgeRightCapInactive.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:543]: Component: Safari.resources_BlackSearchField.html; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:543]: Component: Safari.resources_BlackSearchFieldCancel.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:543]: Component: Safari.resources_BlackSearchFieldCancelPressed.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:543]: Component: Safari.resources_BlackSearchFieldCell.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:543]: Component: Safari.resources_BonjourLarge_win.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:543]: Component: Safari.resources_BookmarkChooser.html; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:543]: Component: Safari.resources_BookmarkPreferences.html; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:543]: Component: Safari.resources_BookmarkTitleChange.html; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:543]: Component: Safari.resources_BugReport.html; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:543]: Component: Safari.resources_CachesWindow.html; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:543]: Component: Safari.resources_Certificate.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:543]: Component: Safari.resources_compass.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:543]: Component: Safari.resources_compass64.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:543]: Component: Safari.resources_CoverflowScrollThumb_Pressed.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:543]: Component: Safari.resources_CoverflowScrollThumbFill.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:543]: Component: Safari.resources_CoverflowScrollThumbLeft_Pressed.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:543]: Component: Safari.resources_CoverflowScrollThumbLeft.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:543]: Component: Safari.resources_CoverflowScrollThumbRight_Pressed.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:543]: Component: Safari.resources_CoverflowScrollThumbRight.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:543]: Component: Safari.resources_CoverflowScrollTrackFill.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:543]: Component: Safari.resources_CoverflowScrollTrackLeft.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:543]: Component: Safari.resources_CoverflowScrollTrackRight.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:543]: Component: Safari.resources_CustomizeToolbar.html; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:543]: Component: Safari.resources_cvs_base.pltsuite; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:543]: Component: Safari.resources_cvs_js_ibench.pltsuite; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:543]: Component: Safari.resources_cvs_js_performance.pltsuite; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:543]: Component: Safari.resources_cvs_static_urls.pltsuite; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:543]: Component: Safari.resources_cvs_torture_test.pltsuite; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:543]: Component: Safari.resources_Defaults.plist; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:543]: Component: Safari.resources_Dialog.css; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:543]: Component: Safari.resources_DownloadPromptDialog.html; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:543]: Component: Safari.resources_epoxy_base.pltsuite; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:543]: Component: Safari.resources_Error.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:543]: Component: Safari.resources_ErrorPageBackgroundTile.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:543]: Component: Safari.resources_ErrorPageCompass.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:543]: Component: Safari.resources_ErrorPageDividerLine.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:543]: Component: Safari.resources_ErrorSmall.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:543]: Component: Safari.resources_EVRoots.plist; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:543]: Component: Safari.resources_ExtensionBar.css; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:543]: Component: Safari.resources_ExtensionBarWin.css; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:543]: Component: Safari.resources_ExtensionBuilder.css; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_ExtensionBuilder.html; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_ExtensionBuilder.js; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_ExtensionClose.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_ExtensionCloseHovered.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_ExtensionClosePressed.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_ExtensionDefaultIcon32.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_ExtensionDefaultIcon48.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_ExtensionDefaultIcon64.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_ExtensionSettings.css; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_ExtensionSettings.js; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_ExtensionsView.css; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_ExtensionsView.html; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_ExtensionsView.js; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_FindBanner.html; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_FlowViewFindBanner.css; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_FlowViewFindBanner.html; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_FlowViewSearchField.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_FlowViewSplitter.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_FontPicker.html; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_forbes_top_150.pltsuite; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_FTPDirectoryTemplate.html; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_GeneralPreferences.html; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_GenericFolderIcon.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_glossyHeader.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_glossyHeaderPressed.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_glossyHeaderSelected.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_glossyHeaderSelectedPressed.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_HelpButton.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_HelpButtonPressed.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_HideReaderButtonCapLeft.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_HideReaderButtonCapLeftPressed.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_HideReaderButtonCapRight.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_HideReaderButtonCapRightPressed.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_HideReaderButtonStretch.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_HideReaderButtonStretchPressed.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_HighContrastDarkButtonDiv_Selected.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_HighContrastDarkButtonFill_Pressed.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_HighContrastDarkButtonFill_Selected.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_HighContrastDarkButtonFill_SelectedPressed.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_HighContrastDarkButtonFill_Unselected.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_HighContrastDarkButtonLeft_Pressed.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_HighContrastDarkButtonLeft_Selected.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_HighContrastDarkButtonLeft_SelectedPressed.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_HighContrastDarkButtonLeft_Unselected.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_HighContrastDarkButtonRight_Pressed.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_HighContrastDarkButtonRight_Selected.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_HighContrastDarkButtonRight_SelectedPressed.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_HighContrastDarkButtonRight_Unselected.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_HTMLViewController.js; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_http_base.pltsuite; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_http_js_ibench.pltsuite; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_http_js_performance.pltsuite; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_http_static_urls.pltsuite; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_http_torture_test.pltsuite; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_ibench5_html.pltsuite; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_IDNScriptWhiteList.txt; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_Info.plist; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_jPeuro.pltsuite; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_java.pltsuite; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_LoadingCornerInactive.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_LoadingCornerInactiveWhite.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_LoadingCornerNormal.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_LoadingCornerNormalWhite.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_LoadingCornerPressed.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_LoadingCornerPressedWhite.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_macneilsen.pltsuite; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_macneilsen200.pltsuite; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_MediumSiteIcon_snowleopard.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_MobileTest.css; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_MobileTest.js; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_MobileTestIPad.html; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_MobileTestIPadBack.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_MobileTestIPadForward.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_MobileTestIPadRotate.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_MobileTestIPhone.html; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_MobileTestIPhoneBack.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_MobileTestIPhoneForward.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_MobileTestIPhoneRetina.html; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_MobileTestIPhoneRetinaBack.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_MobileTestIPhoneRetinaForward.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_MobileTestIPhoneRetinaRotate.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_MobileTestIPhoneRotate.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_nesting.pltsuite; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_NetworkDiagnosticsErrorPage.html; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_NewBookmark.html; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_page_load_errors.css; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_PageIcon.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_PhishingAlert.html; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_PhishingAlertBase.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_PhishingAlertTitlebar.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_plugin_test.pltsuite; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_Preferences.win.css; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_PreferencesView.css; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_PrivacyView.css; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_PrivacyView.html; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_PrivateBrowsingButtonCapLeft.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_PrivateBrowsingButtonCapLeftPressed.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_PrivateBrowsingButtonCapRight.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_PrivateBrowsingButtonCapRightPressed.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_PrivateBrowsingButtonStretch.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_PrivateBrowsingButtonStretchPressed.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_Reader.html; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_ReaderDropShadow.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_ReaderDropShadow_at_2x.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_ReaderFadeBottom.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_ReaderFadeBottom_at_2x.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_ReaderFadeTop.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_ReaderFadeTop_at_2x.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_ReaderGrowBox.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_ReaderHUDCloseActive.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_ReaderHUDCloseActive_at_2x.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_ReaderHUDCloseInactive.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_ReaderHUDCloseInactive_at_2x.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_ReaderHUDMailContentsActive.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_ReaderHUDMailContentsActive_at_2x.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_ReaderHUDMailContentsInactive.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_ReaderHUDMailContentsInactive_at_2x.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_ReaderHUDPrintActive.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_ReaderHUDPrintActive_at_2x.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_ReaderHUDPrintInactive.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_ReaderHUDPrintInactive_at_2x.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_ReaderHUDZoomInActive.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_ReaderHUDZoomInActive_at_2x.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_ReaderHUDZoomInInactive.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_ReaderHUDZoomInInactive_at_2x.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_ReaderHUDZoomOutActive.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_ReaderHUDZoomOutActive_at_2x.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_ReaderHUDZoomOutInactive.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_ReaderHUDZoomOutInactive_at_2x.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_ReaderSpinner.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_ReaderThumb.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_ReaderThumb_at_2x.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_ReaderThumbFaded.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_ReaderTrack.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_ReaderTrack_at_2x.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_ReadingList_AddButtonGlyph.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_ReadingList_BGLinen.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_ReadingList_BGSideShadow.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_ReadingList_CompThumb.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_ReadingList_CompTrack.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_ReadingList_DeleteButton.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_ReadingList_DeleteButtonPressed.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_ReadingList_DeleteButtonSelection.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_ReadingList_DeleteButtonSelectionPressed.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_ReadingList_FavIconMask_36.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_ReadingList_FavIconMask.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_ReadingList_FavIconShadow_36.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_ReadingList_FavIconShadow.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_ReadingList_Glasses.pdf; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_ReadingList_IconLarge.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_ReadingList_PushButtonActiveBorderImage.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_ReadingList_PushButtonPressedBorderImage.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_ReadingList_RowDividers.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_ReadingList_SegmentButtonSelectedBorderImage.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_ReadingList_SegmentButtonSelectedPressedBorderImage.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_ReadingList_SegmentButtonSeparator.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_ReadingList_Selection.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_ReadingList_ShiftClickAnimatedIcon.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_ReadingList_TopBar.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_ReadingList.html; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_ReadingList.js; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_ResetDialog.html; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_RSSPreferences.html; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_Safari.css; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_SafariAlert.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_SafariRegistry.dll; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_SafeAutoFillConfirmationPopover.html; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_SafeBrowsingUnavailable.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_ScopeSelectCombined.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_ScopeSelectCombinedPressed.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_SearchField.html; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_SecurityAlert.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_SecurityPreferences.html; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_ServerNotFoundErrorPage.html; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_ShowReaderButtonCapLeft.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_ShowReaderButtonCapLeftPressed.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_ShowReaderButtonCapRight.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_ShowReaderButtonCapRightPressed.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_ShowReaderButtonStretch.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_ShowReaderButtonStretchPressed.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_SlidingAlert.html; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_SnapshotPlaceholderCompass.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_SnapshotPlaceholderGradient.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_SnapshotPlaceholderPadlock.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_SoftwareUpdateIcon.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_Spelling.html; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_ssl_base.pltsuite; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_StandardErrorPage.html; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_Syndication.js; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_tabActiveFill.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_tabActiveLeft.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_tabActiveMask.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_tabActiveRight.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_tabBarFill.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_tabDragLeft.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_tabDragRight.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_tabInactiveLeft.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_tabInactiveRight.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_TabsPreferences.html; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_ToolbarBookmarksBarTemplate.pdf; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_ToolbarBookmarksTemplate.pdf; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_ToolbarDownloadsTemplate.pdf; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_ToolbarEmailTemplate.pdf; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_ToolbarHistoryTemplate.pdf; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_ToolbarNewTabTemplate.pdf; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_ToolbarTopSitesTemplate.pdf; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_ToolbarWebInspectorTemplate.pdf; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_TopLevelDomains.plist; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_TopSitesDarkButtonDiv_N.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_TopSitesDarkButtonDiv_P.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_TopSitesDarkButtonFill_N.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_TopSitesDarkButtonFill_P.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_TopSitesDarkButtonFill_Pressed.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_TopSitesDarkButtonLeft_N.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_TopSitesDarkButtonLeft_P.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_TopSitesDarkButtonLeft_Pressed.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_TopSitesDarkButtonRight_N.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_TopSitesDarkButtonRight_P.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_TopSitesDarkButtonRight_Pressed.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_TopSitesKeepButtonOff.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_TopSitesKeepButtonOffPressed.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_TopSitesKeepButtonOn.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_TopSitesKeepButtonOnPressed.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_TopSitesKeepRemoveDivider.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_TopSitesRemoveButton.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_TopSitesRemoveButtonPressed.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_TopSitesUpdatedPageCurl.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_Trackers.plist; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_TrackingBlocker.js; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_treeDownTriangleBlack.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_treeUpTriangleBlack.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_URLFieldCapLeft.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_URLFieldCapLeftFocused.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_URLFieldCapLeftHoveredButton.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_URLFieldCapLeftHoveredButtonProgress.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_URLFieldCapLeftPressedButton.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_URLFieldCapLeftPressedButtonProgress.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_URLFieldCapLeftProgress.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_URLFieldCapLeftRounded.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_URLFieldCapLeftRoundedFocused.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_URLFieldCapLeftRoundedProgress.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_URLFieldCapRight.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_URLFieldCapRightFocused.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_URLFieldCapRightProgress.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_URLFieldMiddle.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_URLFieldMiddleFocused.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_URLFieldMiddleProgress.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_UserAgents.plist; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_Utilities.js; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_WebAuthenticationSheet.html; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_WhiteSearchField.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_BookmarkChooser_BookmarkChooser.js; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_BookmarkChooser_disclosureTriangleSmallDown.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_BookmarkChooser_disclosureTriangleSmallRight.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_BookmarkChooser_GenericFolderIcon_16.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_BookmarkChooser_TreeView.css; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_BookmarkChooser_TreeView.js; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_da.lproj_ABAutoCompleteMappings.plist; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_da.lproj_BuiltInBookmarks.plist; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_da.lproj_Localizable.strings; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_da.lproj_localizedStrings.js; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_de.lproj_ABAutoCompleteMappings.plist; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_de.lproj_bindict; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_de.lproj_BuiltInBookmarks.plist; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_de.lproj_Dictionary.dat; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_de.lproj_Localizable.strings; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_de.lproj_localizedStrings.js; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_en.lproj_ABAutoCompleteMappings.plist; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_en.lproj_bindict; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_en.lproj_bindict1; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_en.lproj_bindict2; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_en.lproj_bindict3; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_en.lproj_BuiltInBookmarks.plist; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_en.lproj_Dictionary.dat; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_en.lproj_Localizable.strings; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_en.lproj_localizedStrings.js; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_en_AU.lproj_bindict; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_en_CA.lproj_bindict; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_en_GB.lproj_bindict; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_es.lproj_ABAutoCompleteMappings.plist; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_es.lproj_bindict; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_es.lproj_BuiltInBookmarks.plist; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_es.lproj_Dictionary.dat; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_es.lproj_Localizable.strings; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_es.lproj_localizedStrings.js; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_fi.lproj_ABAutoCompleteMappings.plist; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_fi.lproj_BuiltInBookmarks.plist; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_fi.lproj_Localizable.strings; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_fi.lproj_localizedStrings.js; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_fr.lproj_ABAutoCompleteMappings.plist; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_fr.lproj_bindict; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_fr.lproj_BuiltInBookmarks.plist; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_fr.lproj_Dictionary.dat; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_fr.lproj_Localizable.strings; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_fr.lproj_localizedStrings.js; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_Help_Acknowledgments.html; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_Help_da.lproj_Plug_ins.html; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_Help_da.lproj_Safari.chm; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_Help_de.lproj_Plug_ins.html; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_Help_de.lproj_Safari.chm; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_Help_en.lproj_Plug_ins.html; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_Help_en.lproj_Safari.chm; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_Help_es.lproj_Plug_ins.html; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_Help_es.lproj_Safari.chm; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_Help_fi.lproj_Plug_ins.html; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_Help_fi.lproj_Safari.chm; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_Help_fr.lproj_Plug_ins.html; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_Help_fr.lproj_Safari.chm; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_Help_it.lproj_Plug_ins.html; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_Help_it.lproj_Safari.chm; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_Help_ja.lproj_Plug_ins.html; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_Help_ja.lproj_Safari.chm; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_Help_ko.lproj_Plug_ins.html; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_Help_ko.lproj_Safari.chm; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_Help_nb.lproj_Plug_ins.html; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_Help_nb.lproj_Safari.chm; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_Help_nl.lproj_Plug_ins.html; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_Help_nl.lproj_Safari.chm; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_Help_pl.lproj_Plug_ins.html; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_Help_pl.lproj_Safari.chm; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_Help_pt.lproj_Plug_ins.html; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_Help_pt.lproj_Safari.chm; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_Help_pt_PT.lproj_Plug_ins.html; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_Help_pt_PT.lproj_Safari.chm; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_Help_ru.lproj_Plug_ins.html; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_Help_ru.lproj_Safari.chm; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_Help_sv.lproj_Plug_ins.html; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_Help_sv.lproj_Safari.chm; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_Help_zh_CN.lproj_Plug_ins.html; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_Help_zh_CN.lproj_Safari.chm; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_Help_zh_TW.lproj_Plug_ins.html; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_Help_zh_TW.lproj_Safari.chm; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_it.lproj_ABAutoCompleteMappings.plist; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_it.lproj_bindict; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_it.lproj_BuiltInBookmarks.plist; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_it.lproj_Dictionary.dat; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_it.lproj_Localizable.strings; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_it.lproj_localizedStrings.js; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_ja.lproj_ABAutoCompleteMappings.plist; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_ja.lproj_BuiltInBookmarks.plist; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_ja.lproj_Localizable.strings; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_ja.lproj_localizedStrings.js; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_ko.lproj_ABAutoCompleteMappings.plist; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_ko.lproj_BuiltInBookmarks.plist; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_ko.lproj_Localizable.strings; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_ko.lproj_localizedStrings.js; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_nb.lproj_ABAutoCompleteMappings.plist; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_nb.lproj_BuiltInBookmarks.plist; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_nb.lproj_Localizable.strings; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_nb.lproj_localizedStrings.js; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_nl.lproj_ABAutoCompleteMappings.plist; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_nl.lproj_bindict; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_nl.lproj_BuiltInBookmarks.plist; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_nl.lproj_Dictionary.dat; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_nl.lproj_Localizable.strings; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_nl.lproj_localizedStrings.js; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_pl.lproj_ABAutoCompleteMappings.plist; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_pl.lproj_BuiltInBookmarks.plist; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_pl.lproj_Localizable.strings; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_pl.lproj_localizedStrings.js; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_pt.lproj_ABAutoCompleteMappings.plist; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_pt.lproj_bindict; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_pt.lproj_BuiltInBookmarks.plist; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_pt.lproj_Dictionary.dat; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_pt.lproj_Localizable.strings; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_pt.lproj_localizedStrings.js; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_pt_PT.lproj_ABAutoCompleteMappings.plist; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_pt_PT.lproj_BuiltInBookmarks.plist; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_pt_PT.lproj_Localizable.strings; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_pt_PT.lproj_localizedStrings.js; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_ru.lproj_ABAutoCompleteMappings.plist; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_ru.lproj_BuiltInBookmarks.plist; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_ru.lproj_Localizable.strings; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_ru.lproj_localizedStrings.js; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_SnippetEditor_SnippetEditor.css; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_SnippetEditor_SnippetEditor.html; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_SnippetEditor_SnippetEditor.js; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_SnippetEditor_Images_buttonBarBackground.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_SnippetEditor_Images_buttonBarBackgroundInactive.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_SnippetEditor_Images_splitterBar.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_SnippetEditor_Images_splitterBarInactive.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_SnippetEditor_Images_splitterDimple.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_SnippetEditor_Images_splitterDimpleInactive.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_SnippetEditor_Images_toolbarButton.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_SnippetEditor_Images_toolbarButtonInactive.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_SnippetEditor_Images_toolbarButtonPressed.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_sv.lproj_ABAutoCompleteMappings.plist; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_sv.lproj_bindict; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_sv.lproj_BuiltInBookmarks.plist; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_sv.lproj_Dictionary.dat; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_sv.lproj_Localizable.strings; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_sv.lproj_localizedStrings.js; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_zh_CN.lproj_ABAutoCompleteMappings.plist; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_zh_CN.lproj_BuiltInBookmarks.plist; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_zh_CN.lproj_Localizable.strings; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_zh_CN.lproj_localizedStrings.js; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_zh_TW.lproj_ABAutoCompleteMappings.plist; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_zh_TW.lproj_BuiltInBookmarks.plist; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_zh_TW.lproj_Localizable.strings; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: Safari.resources_zh_TW.lproj_localizedStrings.js; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: SafariTheme.resources_ArtFile.bin; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: SafariTheme.resources_Info.plist; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: SafariTheme.resources_SArtFile.bin; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: PubSub.resources_AlertBottom.tif; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: PubSub.resources_AlertIcon.tif; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: PubSub.resources_AlertTop.tif; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: PubSub.resources_Articles.js; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: PubSub.resources_Bigger.tif; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: PubSub.resources_BlueBanner.tif; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: PubSub.resources_default.jpg; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: PubSub.resources_Enclosure.html; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: PubSub.resources_Entries.html; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: PubSub.resources_Entry.html; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: PubSub.resources_favicon.tif; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: PubSub.resources_Feed.html; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: PubSub.resources_FeedComplete.html; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: PubSub.resources_FeedStatic.html; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: PubSub.resources_Friends.html; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: PubSub.resources_Main.css; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: PubSub.resources_NextPage.tif; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: PubSub.resources_NextPage_Disabled.tif; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: PubSub.resources_PreviousPage.tif; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: PubSub.resources_PreviousPage_Disabled.tif; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: PubSub.resources_Separator.tif; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: PubSub.resources_Smaller.tif; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: PubSub.resources_Template.png; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: PubSub.resources_unread.tif; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: PubSub.resources_da.lproj_ArticlesL10N.css; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: PubSub.resources_da.lproj_Localizable.strings; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: PubSub.resources_de.lproj_ArticlesL10N.css; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: PubSub.resources_de.lproj_Localizable.strings; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: PubSub.resources_English.lproj_ArticlesL10N.css; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: PubSub.resources_English.lproj_Localizable.strings; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: PubSub.resources_es.lproj_ArticlesL10N.css; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: PubSub.resources_es.lproj_Localizable.strings; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: PubSub.resources_fi.lproj_ArticlesL10N.css; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: PubSub.resources_fi.lproj_Localizable.strings; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: PubSub.resources_fr.lproj_ArticlesL10N.css; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: PubSub.resources_fr.lproj_Localizable.strings; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: PubSub.resources_Framework_templates.lua; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: PubSub.resources_Framework_da.lproj_Localizable.strings; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: PubSub.resources_Framework_de.lproj_Localizable.strings; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: PubSub.resources_Framework_English.lproj_Localizable.strings; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: PubSub.resources_Framework_es.lproj_Localizable.strings; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: PubSub.resources_Framework_fi.lproj_Localizable.strings; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: PubSub.resources_Framework_fr.lproj_Localizable.strings; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: PubSub.resources_Framework_it.lproj_Localizable.strings; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: PubSub.resources_Framework_ja.lproj_Localizable.strings; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: PubSub.resources_Framework_ko.lproj_Localizable.strings; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: PubSub.resources_Framework_nb.lproj_Localizable.strings; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: PubSub.resources_Framework_nl.lproj_Localizable.strings; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: PubSub.resources_Framework_pl.lproj_Localizable.strings; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: PubSub.resources_Framework_pt.lproj_Localizable.strings; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: PubSub.resources_Framework_pt_PT.lproj_Localizable.strings; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: PubSub.resources_Framework_ru.lproj_Localizable.strings; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: PubSub.resources_Framework_sv.lproj_Localizable.strings; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: PubSub.resources_Framework_zh_CN.lproj_Localizable.strings; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: PubSub.resources_Framework_zh_TW.lproj_Localizable.strings; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: PubSub.resources_it.lproj_ArticlesL10N.css; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: PubSub.resources_it.lproj_Localizable.strings; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: PubSub.resources_ja.lproj_ArticlesL10N.css; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: PubSub.resources_ja.lproj_Localizable.strings; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: PubSub.resources_ko.lproj_ArticlesL10N.css; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: PubSub.resources_ko.lproj_Localizable.strings; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: PubSub.resources_nb.lproj_ArticlesL10N.css; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: PubSub.resources_nb.lproj_Localizable.strings; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: PubSub.resources_nl.lproj_ArticlesL10N.css; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: PubSub.resources_nl.lproj_Localizable.strings; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: PubSub.resources_pl.lproj_ArticlesL10N.css; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: PubSub.resources_pl.lproj_Localizable.strings; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: PubSub.resources_pt.lproj_ArticlesL10N.css; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: PubSub.resources_pt.lproj_Localizable.strings; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: PubSub.resources_pt_PT.lproj_ArticlesL10N.css; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: PubSub.resources_pt_PT.lproj_Localizable.strings; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: PubSub.resources_ru.lproj_ArticlesL10N.css; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: PubSub.resources_ru.lproj_Localizable.strings; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: PubSub.resources_sv.lproj_ArticlesL10N.css; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: PubSub.resources_sv.lproj_Localizable.strings; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: PubSub.resources_zh_CN.lproj_ArticlesL10N.css; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: PubSub.resources_zh_CN.lproj_Localizable.strings; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: PubSub.resources_zh_TW.lproj_ArticlesL10N.css; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: PubSub.resources_zh_TW.lproj_Localizable.strings; Installed: Local;   Request: Local;   Action: Local;   Client State: Local
                MSI (s) (A4:F8) [11:14:42:559]: Component: __SafariDesktopShortcuts65; Installed: Null;   Request: Local;   Action: Local;   Client State: Null
                MSI (s) (A4:F8) [11:14:42:559]: Component: __SafariDesktopShortcuts66; Installed: Null;   Request: Local;   Action: Local;   Client State: Null
                MSI (s) (A4:F8) [11:14:42:559]: Component: __SafariDesktopShortcuts67; Installed: Null;   Request: Local;   Action: Local;   Client State: Null
                MSI (s) (A4:F8) [11:14:42:559]: Component: __Safari.exe65; Installed: Null;   Request: Local;   Action: Local;   Client State: Null
                MSI (s) (A4:F8) [11:14:42:559]: Component: __SafariStartMenuRegistry65; Installed: Null;   Request: Local;   Action: Local;   Client State: Null
                MSI (s) (A4:F8) [11:14:42:559]: Component: __SafariDesktopShortcuts68; Installed: Null;   Request: Local;   Action: Local;   Client State: Null
                MSI (s) (A4:F8) [11:14:42:559]: Component: __Safari.exe66; Installed: Null;   Request: Local;   Action: Local;   Client State: Null
                MSI (s) (A4:F8) [11:14:42:559]: Component: __SafariClassesRegistry65; Installed: Null;   Request: Local;   Action: Local;   Client State: Null
                MSI (s) (A4:F8) [11:14:42:559]: Component: __SafariInstallerCache65; Installed: Null;   Request: Local;   Action: Local;   Client State: Null
                MSI (s) (A4:F8) [11:14:42:559]: Component: __Safari.exe67; Installed: Null;   Request: Local;   Action: Local;   Client State: Null
                MSI (s) (A4:F8) [11:14:42:559]: Note: 1: 2205 2:  3: BindImage
                MSI (s) (A4:F8) [11:14:42:559]: Note: 1: 2205 2:  3: ProgId
                MSI (s) (A4:F8) [11:14:42:559]: Note: 1: 2205 2:  3: PublishComponent
                MSI (s) (A4:F8) [11:14:42:574]: Note: 1: 2205 2:  3: SelfReg
                MSI (s) (A4:F8) [11:14:42:574]: Note: 1: 2205 2:  3: Extension
                MSI (s) (A4:F8) [11:14:42:574]: Note: 1: 2205 2:  3: Font
                MSI (s) (A4:F8) [11:14:42:574]: Note: 1: 2205 2:  3: Class
                Action start 11:14:42: InstallValidate.
                MSI (s) (A4:F8) [11:14:53:713]: Note: 1: 2756 2: SourceDir
                MSI (s) (A4:F8) [11:14:53:713]: PROPERTY CHANGE: Modifying CostingComplete property. Its current value is '0'. Its new value: '1'.
                MSI (s) (A4:F8) [11:14:53:713]: Note: 1: 2205 2:  3: BindImage
                MSI (s) (A4:F8) [11:14:53:713]: Note: 1: 2205 2:  3: ProgId
                MSI (s) (A4:F8) [11:14:53:713]: Note: 1: 2205 2:  3: PublishComponent
                MSI (s) (A4:F8) [11:14:53:713]: Note: 1: 2205 2:  3: SelfReg
                MSI (s) (A4:F8) [11:14:53:713]: Note: 1: 2205 2:  3: Extension
                MSI (s) (A4:F8) [11:14:53:713]: Note: 1: 2205 2:  3: Font
                MSI (s) (A4:F8) [11:14:53:713]: Note: 1: 2205 2:  3: Class
                MSI (s) (A4:F8) [11:14:53:713]: PROPERTY CHANGE: Modifying PrimaryVolumeSpaceAvailable property. Its current value is '0'. Its new value: '17291616'.
                MSI (s) (A4:F8) [11:14:53:713]: PROPERTY CHANGE: Modifying PrimaryVolumeSpaceRequired property. Its current value is '0'. Its new value: '224'.
                MSI (s) (A4:F8) [11:14:53:713]: PROPERTY CHANGE: Modifying PrimaryVolumeSpaceRemaining property. Its current value is '0'. Its new value: '17291392'.
                MSI (s) (A4:F8) [11:14:53:713]: PROPERTY CHANGE: Adding PrimaryVolumePath property. Its value is 'C:'.
                MSI (s) (A4:F8) [11:14:54:727]: PROPERTY CHANGE: Modifying PrimaryVolumeSpaceAvailable property. Its current value is '17291616'. Its new value: '17291608'.
                MSI (s) (A4:F8) [11:14:54:727]: PROPERTY CHANGE: Modifying PrimaryVolumeSpaceRemaining property. Its current value is '17291392'. Its new value: '17291384'.
                MSI (s) (A4:F8) [11:14:54:727]: Doing action: InstallInitialize
                Action ended 11:14:54: InstallValidate. Return value 1.
                MSI (s) (A4:F8) [11:14:54:742]: Machine policy value 'AlwaysInstallElevated' is 0
                MSI (s) (A4:F8) [11:14:54:742]: User policy value 'AlwaysInstallElevated' is 0
                MSI (s) (A4:F8) [11:14:54:742]: BeginTransaction: Locking Server
                MSI (s) (A4:F8) [11:14:54:742]: SRSetRestorePoint skipped for this transaction.
                MSI (s) (A4:F8) [11:14:54:742]: Server not locked: locking for product {F2AF3E5D-9697-485C-A5AC-E2B9468C446A}
                MSI (s) (A4:F8) [11:14:56:146]: Using cached product context: machine assigned for product: D5E3FA2F7969C5845ACA2E9B64C844A6
                Action start 11:14:54: InstallInitialize.
                MSI (s) (A4:F8) [11:14:56:146]: Doing action: ProcessComponents
                Action ended 11:14:56: InstallInitialize. Return value 1.
                Action start 11:14:56: ProcessComponents.
                MSI (s) (A4:F8) [11:14:56:302]: Doing action: UnpublishFeatures
                Action ended 11:14:56: ProcessComponents. Return value 1.
                MSI (s) (A4:F8) [11:14:56:302]: Using cached product context: machine assigned for product: D5E3FA2F7969C5845ACA2E9B64C844A6
                Action start 11:14:56: UnpublishFeatures.
                MSI (s) (A4:F8) [11:14:56:302]: Doing action: RemoveRegistryValues
                Action ended 11:14:56: UnpublishFeatures. Return value 1.
                Action start 11:14:56: RemoveRegistryValues.
                MSI (s) (A4:F8) [11:14:56:302]: Doing action: AddDesktopShortcuts
                Action ended 11:14:56: RemoveRegistryValues. Return value 1.
                MSI (s) (A4:F8) [11:14:56:412]: Creating MSIHANDLE (1) of type 790542 for thread 2552
                MSI (s) (A4:F4) [11:14:56:412]: Invoking remote custom action. DLL: C:\Windows\Installer\MSI24B0.tmp, Entrypoint: AddDesktopShortcuts
                MSI (s) (A4:BC) [11:14:56:412]: Generating random cookie.
                MSI (s) (A4:BC) [11:14:56:427]: Created Custom Action Server with PID 2676 (0xA74).
                MSI (s) (A4:E8) [11:14:56:474]: Running as a service.
                MSI (s) (A4:E8) [11:14:56:474]: Hello, I'm your 32bit Impersonated custom action server.
                MSI (s) (A4!64) [11:14:56:583]: Creating MSIHANDLE (2) of type 790541 for thread 2148
                MSI (s) (A4!64) [11:14:56:583]: Creating MSIHANDLE (3) of type 790540 for thread 2148
                MSI (s) (A4!64) [11:14:56:583]: Creating MSIHANDLE (4) of type 790531 for thread 2148
                MSI (s) (A4!64) [11:14:56:614]: Closing MSIHANDLE (4) of type 790531 for thread 2148
                MSI (s) (A4!64) [11:14:56:614]: Closing MSIHANDLE (3) of type 790540 for thread 2148
                MSI (s) (A4!64) [11:14:56:614]: Closing MSIHANDLE (2) of type 790541 for thread 2148
                MSI (s) (A4:F4) [11:14:56:614]: Closing MSIHANDLE (1) of type 790542 for thread 2552
                Action start 11:14:56: AddDesktopShortcuts.
                MSI (s) (A4:F8) [11:14:56:614]: Doing action: RemoveShortcuts
                Action ended 11:14:56: AddDesktopShortcuts. Return value 1.
                Action start 11:14:56: RemoveShortcuts.
                MSI (s) (A4:F8) [11:14:56:614]: Doing action: RemoveFiles
                Action ended 11:14:56: RemoveShortcuts. Return value 1.
                Action start 11:14:56: RemoveFiles.
                MSI (s) (A4:F8) [11:14:56:614]: Doing action: RemoveFolders
                Action ended 11:14:56: RemoveFiles. Return value 1.
                Action start 11:14:56: RemoveFolders.
                MSI (s) (A4:F8) [11:14:56:614]: Doing action: CreateFolders
                Action ended 11:14:56: RemoveFolders. Return value 1.
                Action start 11:14:56: CreateFolders.
                MSI (s) (A4:F8) [11:14:56:630]: Doing action: MoveFiles
                Action ended 11:14:56: CreateFolders. Return value 1.
                Action start 11:14:56: MoveFiles.
                MSI (s) (A4:F8) [11:14:56:630]: Doing action: InstallFiles
                Action ended 11:14:56: MoveFiles. Return value 1.
                MSI (s) (A4:F8) [11:14:56:630]: The file represented by File table key 'Safari.dll' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:630]: The file represented by File table key 'PubSubDLL.dll' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:630]: The file represented by File table key 'Search.dll' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:630]: The file represented by File table key 'SpellChecker.dll' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:630]: The file represented by File table key 'Safari.exe' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:630]: The file represented by File table key 'SafariTheme.dll' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:630]: The file represented by File table key 'npJavaPlugin.dll' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:630]: The file represented by File table key 'Safari.resources_ABAddressFormats.plist' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:630]: The file represented by File table key 'Safari.resources_About.html' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:630]: The file represented by File table key 'Safari.resources_AddButtonGlyph.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:630]: The file represented by File table key 'Safari.resources_AddressBookEntryView.html' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:630]: The file represented by File table key 'Safari.resources_AddressCard.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:630]: The file represented by File table key 'Safari.resources_AdvancedPreferences.html' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:630]: The file represented by File table key 'Safari.resources_AlertDialog.html' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:630]: The file represented by File table key 'Safari.resources_aol666.pltsuite' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_AppearancePreferences.html' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_AutoFill.js' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_AutoFillPreferences.html' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_badgeFill.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_badgeFillInactive.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_badgeLeftCap.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_badgeLeftCapInactive.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_badgeRightCap.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_badgeRightCapInactive.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_BlackSearchField.html' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_BlackSearchFieldCancel.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_BlackSearchFieldCancelPressed.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_BlackSearchFieldCell.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_BonjourLarge_win.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_BookmarkChooser.html' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_BookmarkPreferences.html' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_BookmarkTitleChange.html' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_BugReport.html' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_CachesWindow.html' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_Certificate.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_compass.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_compass64.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_CoverflowScrollThumb_Pressed.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_CoverflowScrollThumbFill.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_CoverflowScrollThumbLeft_Pressed.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_CoverflowScrollThumbLeft.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_CoverflowScrollThumbRight_Pressed.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_CoverflowScrollThumbRight.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_CoverflowScrollTrackFill.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_CoverflowScrollTrackLeft.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_CoverflowScrollTrackRight.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_CustomizeToolbar.html' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_cvs_base.pltsuite' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_cvs_js_ibench.pltsuite' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_cvs_js_performance.pltsuite' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_cvs_static_urls.pltsuite' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_cvs_torture_test.pltsuite' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_Defaults.plist' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_Dialog.css' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_DownloadPromptDialog.html' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_epoxy_base.pltsuite' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_Error.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_ErrorPageBackgroundTile.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_ErrorPageCompass.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_ErrorPageDividerLine.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_ErrorSmall.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_EVRoots.plist' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_ExtensionBar.css' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_ExtensionBarWin.css' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_ExtensionBuilder.css' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_ExtensionBuilder.html' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_ExtensionBuilder.js' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_ExtensionClose.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_ExtensionCloseHovered.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_ExtensionClosePressed.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_ExtensionDefaultIcon32.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_ExtensionDefaultIcon48.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_ExtensionDefaultIcon64.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_ExtensionSettings.css' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_ExtensionSettings.js' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_ExtensionsView.css' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_ExtensionsView.html' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_ExtensionsView.js' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_FindBanner.html' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_FlowViewFindBanner.css' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_FlowViewFindBanner.html' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_FlowViewSearchField.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_FlowViewSplitter.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_FontPicker.html' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_forbes_top_150.pltsuite' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_FTPDirectoryTemplate.html' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_GeneralPreferences.html' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_GenericFolderIcon.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_glossyHeader.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_glossyHeaderPressed.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_glossyHeaderSelected.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_glossyHeaderSelectedPressed.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_HelpButton.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_HelpButtonPressed.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_HideReaderButtonCapLeft.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_HideReaderButtonCapLeftPressed.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_HideReaderButtonCapRight.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_HideReaderButtonCapRightPressed.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_HideReaderButtonStretch.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_HideReaderButtonStretchPressed.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_HighContrastDarkButtonDiv_Selected.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_HighContrastDarkButtonFill_Pressed.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_HighContrastDarkButtonFill_Selected.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_HighContrastDarkButtonFill_SelectedPressed.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_HighContrastDarkButtonFill_Unselected.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_HighContrastDarkButtonLeft_Pressed.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_HighContrastDarkButtonLeft_Selected.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_HighContrastDarkButtonLeft_SelectedPressed.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_HighContrastDarkButtonLeft_Unselected.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_HighContrastDarkButtonRight_Pressed.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_HighContrastDarkButtonRight_Selected.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_HighContrastDarkButtonRight_SelectedPressed.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_HighContrastDarkButtonRight_Unselected.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_HTMLViewController.js' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_http_base.pltsuite' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_http_js_ibench.pltsuite' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_http_js_performance.pltsuite' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_http_static_urls.pltsuite' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_http_torture_test.pltsuite' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_ibench5_html.pltsuite' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_IDNScriptWhiteList.txt' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_Info.plist' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_jPeuro.pltsuite' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_java.pltsuite' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_LoadingCornerInactive.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_LoadingCornerInactiveWhite.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_LoadingCornerNormal.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_LoadingCornerNormalWhite.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_LoadingCornerPressed.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_LoadingCornerPressedWhite.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_macneilsen.pltsuite' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_macneilsen200.pltsuite' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_MediumSiteIcon_snowleopard.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_MobileTest.css' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_MobileTest.js' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_MobileTestIPad.html' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_MobileTestIPadBack.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_MobileTestIPadForward.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_MobileTestIPadRotate.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_MobileTestIPhone.html' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_MobileTestIPhoneBack.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_MobileTestIPhoneForward.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_MobileTestIPhoneRetina.html' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_MobileTestIPhoneRetinaBack.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_MobileTestIPhoneRetinaForward.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_MobileTestIPhoneRetinaRotate.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_MobileTestIPhoneRotate.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_nesting.pltsuite' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_NetworkDiagnosticsErrorPage.html' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_NewBookmark.html' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_page_load_errors.css' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_PageIcon.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_PhishingAlert.html' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_PhishingAlertBase.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_PhishingAlertTitlebar.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_plugin_test.pltsuite' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_Preferences.win.css' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_PreferencesView.css' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_PrivacyView.css' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_PrivacyView.html' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_PrivateBrowsingButtonCapLeft.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_PrivateBrowsingButtonCapLeftPressed.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_PrivateBrowsingButtonCapRight.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_PrivateBrowsingButtonCapRightPressed.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_PrivateBrowsingButtonStretch.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_PrivateBrowsingButtonStretchPressed.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_Reader.html' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_ReaderDropShadow.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_ReaderDropShadow_at_2x.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_ReaderFadeBottom.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_ReaderFadeBottom_at_2x.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_ReaderFadeTop.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_ReaderFadeTop_at_2x.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_ReaderGrowBox.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_ReaderHUDCloseActive.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_ReaderHUDCloseActive_at_2x.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_ReaderHUDCloseInactive.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_ReaderHUDCloseInactive_at_2x.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_ReaderHUDMailContentsActive.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_ReaderHUDMailContentsActive_at_2x.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_ReaderHUDMailContentsInactive.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_ReaderHUDMailContentsInactive_at_2x.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_ReaderHUDPrintActive.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_ReaderHUDPrintActive_at_2x.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_ReaderHUDPrintInactive.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_ReaderHUDPrintInactive_at_2x.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_ReaderHUDZoomInActive.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_ReaderHUDZoomInActive_at_2x.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_ReaderHUDZoomInInactive.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_ReaderHUDZoomInInactive_at_2x.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_ReaderHUDZoomOutActive.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_ReaderHUDZoomOutActive_at_2x.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_ReaderHUDZoomOutInactive.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_ReaderHUDZoomOutInactive_at_2x.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_ReaderSpinner.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_ReaderThumb.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:646]: The file represented by File table key 'Safari.resources_ReaderThumb_at_2x.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_ReaderThumbFaded.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_ReaderTrack.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_ReaderTrack_at_2x.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_ReadingList_AddButtonGlyph.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_ReadingList_BGLinen.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_ReadingList_BGSideShadow.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_ReadingList_CompThumb.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_ReadingList_CompTrack.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_ReadingList_DeleteButton.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_ReadingList_DeleteButtonPressed.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_ReadingList_DeleteButtonSelection.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_ReadingList_DeleteButtonSelectionPressed.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_ReadingList_FavIconMask_36.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_ReadingList_FavIconMask.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_ReadingList_FavIconShadow_36.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_ReadingList_FavIconShadow.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_ReadingList_Glasses.pdf' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_ReadingList_IconLarge.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_ReadingList_PushButtonActiveBorderImage.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_ReadingList_PushButtonPressedBorderImage.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_ReadingList_RowDividers.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_ReadingList_SegmentButtonSelectedBorderImage.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_ReadingList_SegmentButtonSelectedPressedBorderImage.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_ReadingList_SegmentButtonSeparator.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_ReadingList_Selection.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_ReadingList_ShiftClickAnimatedIcon.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_ReadingList_TopBar.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_ReadingList.html' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_ReadingList.js' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_ResetDialog.html' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_RSSPreferences.html' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_Safari.css' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_SafariAlert.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_SafariRegistry.dll' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_SafeAutoFillConfirmationPopover.html' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_SafeBrowsingUnavailable.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_ScopeSelectCombined.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_ScopeSelectCombinedPressed.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_SearchField.html' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_SecurityAlert.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_SecurityPreferences.html' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_ServerNotFoundErrorPage.html' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_ShowReaderButtonCapLeft.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_ShowReaderButtonCapLeftPressed.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_ShowReaderButtonCapRight.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_ShowReaderButtonCapRightPressed.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_ShowReaderButtonStretch.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_ShowReaderButtonStretchPressed.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_SlidingAlert.html' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_SnapshotPlaceholderCompass.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_SnapshotPlaceholderGradient.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_SnapshotPlaceholderPadlock.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_SoftwareUpdateIcon.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_Spelling.html' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_ssl_base.pltsuite' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_StandardErrorPage.html' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_Syndication.js' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_tabActiveFill.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_tabActiveLeft.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_tabActiveMask.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_tabActiveRight.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_tabBarFill.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_tabDragLeft.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_tabDragRight.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_tabInactiveLeft.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_tabInactiveRight.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_TabsPreferences.html' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_ToolbarBookmarksBarTemplate.pdf' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_ToolbarBookmarksTemplate.pdf' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_ToolbarDownloadsTemplate.pdf' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_ToolbarEmailTemplate.pdf' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_ToolbarHistoryTemplate.pdf' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_ToolbarNewTabTemplate.pdf' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_ToolbarTopSitesTemplate.pdf' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_ToolbarWebInspectorTemplate.pdf' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_TopLevelDomains.plist' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_TopSitesDarkButtonDiv_N.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_TopSitesDarkButtonDiv_P.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_TopSitesDarkButtonFill_N.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_TopSitesDarkButtonFill_P.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_TopSitesDarkButtonFill_Pressed.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_TopSitesDarkButtonLeft_N.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_TopSitesDarkButtonLeft_P.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_TopSitesDarkButtonLeft_Pressed.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_TopSitesDarkButtonRight_N.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_TopSitesDarkButtonRight_P.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_TopSitesDarkButtonRight_Pressed.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_TopSitesKeepButtonOff.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_TopSitesKeepButtonOffPressed.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_TopSitesKeepButtonOn.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_TopSitesKeepButtonOnPressed.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_TopSitesKeepRemoveDivider.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_TopSitesRemoveButton.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_TopSitesRemoveButtonPressed.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_TopSitesUpdatedPageCurl.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_Trackers.plist' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_TrackingBlocker.js' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_treeDownTriangleBlack.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_treeUpTriangleBlack.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_URLFieldCapLeft.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_URLFieldCapLeftFocused.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_URLFieldCapLeftHoveredButton.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_URLFieldCapLeftHoveredButtonProgress.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_URLFieldCapLeftPressedButton.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_URLFieldCapLeftPressedButtonProgress.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_URLFieldCapLeftProgress.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_URLFieldCapLeftRounded.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_URLFieldCapLeftRoundedFocused.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_URLFieldCapLeftRoundedProgress.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_URLFieldCapRight.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_URLFieldCapRightFocused.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_URLFieldCapRightProgress.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_URLFieldMiddle.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_URLFieldMiddleFocused.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_URLFieldMiddleProgress.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_UserAgents.plist' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_Utilities.js' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_WebAuthenticationSheet.html' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_WhiteSearchField.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_BookmarkChooser_BookmarkChooser.js' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_BookmarkChooser_disclosureTriangleSmallDown.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_BookmarkChooser_disclosureTriangleSmallRight.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_BookmarkChooser_GenericFolderIcon_16.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_BookmarkChooser_TreeView.css' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_BookmarkChooser_TreeView.js' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_da.lproj_ABAutoCompleteMappings.plist' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_da.lproj_BuiltInBookmarks.plist' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_da.lproj_Localizable.strings' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_da.lproj_localizedStrings.js' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_de.lproj_ABAutoCompleteMappings.plist' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_de.lproj_bindict' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_de.lproj_BuiltInBookmarks.plist' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_de.lproj_Dictionary.dat' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_de.lproj_Localizable.strings' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_de.lproj_localizedStrings.js' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_en.lproj_ABAutoCompleteMappings.plist' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_en.lproj_bindict' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_en.lproj_bindict1' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_en.lproj_bindict2' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_en.lproj_bindict3' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_en.lproj_BuiltInBookmarks.plist' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_en.lproj_Dictionary.dat' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_en.lproj_Localizable.strings' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_en.lproj_localizedStrings.js' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_en_AU.lproj_bindict' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_en_CA.lproj_bindict' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_en_GB.lproj_bindict' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_es.lproj_ABAutoCompleteMappings.plist' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_es.lproj_bindict' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_es.lproj_BuiltInBookmarks.plist' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_es.lproj_Dictionary.dat' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_es.lproj_Localizable.strings' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_es.lproj_localizedStrings.js' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_fi.lproj_ABAutoCompleteMappings.plist' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_fi.lproj_BuiltInBookmarks.plist' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_fi.lproj_Localizable.strings' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_fi.lproj_localizedStrings.js' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_fr.lproj_ABAutoCompleteMappings.plist' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_fr.lproj_bindict' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_fr.lproj_BuiltInBookmarks.plist' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_fr.lproj_Dictionary.dat' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_fr.lproj_Localizable.strings' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_fr.lproj_localizedStrings.js' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_Help_Acknowledgments.html' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_Help_da.lproj_Plug_ins.html' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_Help_da.lproj_Safari.chm' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_Help_de.lproj_Plug_ins.html' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_Help_de.lproj_Safari.chm' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_Help_en.lproj_Plug_ins.html' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_Help_en.lproj_Safari.chm' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_Help_es.lproj_Plug_ins.html' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_Help_es.lproj_Safari.chm' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_Help_fi.lproj_Plug_ins.html' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_Help_fi.lproj_Safari.chm' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_Help_fr.lproj_Plug_ins.html' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_Help_fr.lproj_Safari.chm' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_Help_it.lproj_Plug_ins.html' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_Help_it.lproj_Safari.chm' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_Help_ja.lproj_Plug_ins.html' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_Help_ja.lproj_Safari.chm' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_Help_ko.lproj_Plug_ins.html' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:661]: The file represented by File table key 'Safari.resources_Help_ko.lproj_Safari.chm' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'Safari.resources_Help_nb.lproj_Plug_ins.html' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'Safari.resources_Help_nb.lproj_Safari.chm' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'Safari.resources_Help_nl.lproj_Plug_ins.html' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'Safari.resources_Help_nl.lproj_Safari.chm' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'Safari.resources_Help_pl.lproj_Plug_ins.html' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'Safari.resources_Help_pl.lproj_Safari.chm' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'Safari.resources_Help_pt.lproj_Plug_ins.html' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'Safari.resources_Help_pt.lproj_Safari.chm' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'Safari.resources_Help_pt_PT.lproj_Plug_ins.html' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'Safari.resources_Help_pt_PT.lproj_Safari.chm' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'Safari.resources_Help_ru.lproj_Plug_ins.html' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'Safari.resources_Help_ru.lproj_Safari.chm' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'Safari.resources_Help_sv.lproj_Plug_ins.html' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'Safari.resources_Help_sv.lproj_Safari.chm' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'Safari.resources_Help_zh_CN.lproj_Plug_ins.html' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'Safari.resources_Help_zh_CN.lproj_Safari.chm' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'Safari.resources_Help_zh_TW.lproj_Plug_ins.html' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'Safari.resources_Help_zh_TW.lproj_Safari.chm' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'Safari.resources_it.lproj_ABAutoCompleteMappings.plist' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'Safari.resources_it.lproj_bindict' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'Safari.resources_it.lproj_BuiltInBookmarks.plist' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'Safari.resources_it.lproj_Dictionary.dat' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'Safari.resources_it.lproj_Localizable.strings' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'Safari.resources_it.lproj_localizedStrings.js' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'Safari.resources_ja.lproj_ABAutoCompleteMappings.plist' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'Safari.resources_ja.lproj_BuiltInBookmarks.plist' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'Safari.resources_ja.lproj_Localizable.strings' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'Safari.resources_ja.lproj_localizedStrings.js' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'Safari.resources_ko.lproj_ABAutoCompleteMappings.plist' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'Safari.resources_ko.lproj_BuiltInBookmarks.plist' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'Safari.resources_ko.lproj_Localizable.strings' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'Safari.resources_ko.lproj_localizedStrings.js' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'Safari.resources_nb.lproj_ABAutoCompleteMappings.plist' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'Safari.resources_nb.lproj_BuiltInBookmarks.plist' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'Safari.resources_nb.lproj_Localizable.strings' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'Safari.resources_nb.lproj_localizedStrings.js' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'Safari.resources_nl.lproj_ABAutoCompleteMappings.plist' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'Safari.resources_nl.lproj_bindict' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'Safari.resources_nl.lproj_BuiltInBookmarks.plist' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'Safari.resources_nl.lproj_Dictionary.dat' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'Safari.resources_nl.lproj_Localizable.strings' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'Safari.resources_nl.lproj_localizedStrings.js' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'Safari.resources_pl.lproj_ABAutoCompleteMappings.plist' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'Safari.resources_pl.lproj_BuiltInBookmarks.plist' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'Safari.resources_pl.lproj_Localizable.strings' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'Safari.resources_pl.lproj_localizedStrings.js' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'Safari.resources_pt.lproj_ABAutoCompleteMappings.plist' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'Safari.resources_pt.lproj_bindict' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'Safari.resources_pt.lproj_BuiltInBookmarks.plist' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'Safari.resources_pt.lproj_Dictionary.dat' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'Safari.resources_pt.lproj_Localizable.strings' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'Safari.resources_pt.lproj_localizedStrings.js' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'Safari.resources_pt_PT.lproj_ABAutoCompleteMappings.plist' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'Safari.resources_pt_PT.lproj_BuiltInBookmarks.plist' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'Safari.resources_pt_PT.lproj_Localizable.strings' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'Safari.resources_pt_PT.lproj_localizedStrings.js' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'Safari.resources_ru.lproj_ABAutoCompleteMappings.plist' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'Safari.resources_ru.lproj_BuiltInBookmarks.plist' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'Safari.resources_ru.lproj_Localizable.strings' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'Safari.resources_ru.lproj_localizedStrings.js' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'Safari.resources_SnippetEditor_SnippetEditor.css' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'Safari.resources_SnippetEditor_SnippetEditor.html' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'Safari.resources_SnippetEditor_SnippetEditor.js' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'Safari.resources_SnippetEditor_Images_buttonBarBackground.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'Safari.resources_SnippetEditor_Images_buttonBarBackgroundInactive.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'Safari.resources_SnippetEditor_Images_splitterBar.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'Safari.resources_SnippetEditor_Images_splitterBarInactive.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'Safari.resources_SnippetEditor_Images_splitterDimple.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'Safari.resources_SnippetEditor_Images_splitterDimpleInactive.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'Safari.resources_SnippetEditor_Images_toolbarButton.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'Safari.resources_SnippetEditor_Images_toolbarButtonInactive.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'Safari.resources_SnippetEditor_Images_toolbarButtonPressed.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'Safari.resources_sv.lproj_ABAutoCompleteMappings.plist' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'Safari.resources_sv.lproj_bindict' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'Safari.resources_sv.lproj_BuiltInBookmarks.plist' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'Safari.resources_sv.lproj_Dictionary.dat' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'Safari.resources_sv.lproj_Localizable.strings' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'Safari.resources_sv.lproj_localizedStrings.js' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'Safari.resources_zh_CN.lproj_ABAutoCompleteMappings.plist' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'Safari.resources_zh_CN.lproj_BuiltInBookmarks.plist' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'Safari.resources_zh_CN.lproj_Localizable.strings' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'Safari.resources_zh_CN.lproj_localizedStrings.js' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'Safari.resources_zh_TW.lproj_ABAutoCompleteMappings.plist' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'Safari.resources_zh_TW.lproj_BuiltInBookmarks.plist' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'Safari.resources_zh_TW.lproj_Localizable.strings' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'Safari.resources_zh_TW.lproj_localizedStrings.js' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'SafariTheme.resources_ArtFile.bin' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'SafariTheme.resources_Info.plist' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'SafariTheme.resources_SArtFile.bin' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'PubSub.resources_AlertBottom.tif' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'PubSub.resources_AlertIcon.tif' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'PubSub.resources_AlertTop.tif' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'PubSub.resources_Articles.js' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'PubSub.resources_Bigger.tif' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'PubSub.resources_BlueBanner.tif' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'PubSub.resources_default.jpg' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'PubSub.resources_Enclosure.html' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'PubSub.resources_Entries.html' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'PubSub.resources_Entry.html' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'PubSub.resources_favicon.tif' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'PubSub.resources_Feed.html' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'PubSub.resources_FeedComplete.html' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'PubSub.resources_FeedStatic.html' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'PubSub.resources_Friends.html' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'PubSub.resources_Main.css' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'PubSub.resources_NextPage.tif' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'PubSub.resources_NextPage_Disabled.tif' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'PubSub.resources_PreviousPage.tif' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'PubSub.resources_PreviousPage_Disabled.tif' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'PubSub.resources_Separator.tif' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'PubSub.resources_Smaller.tif' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'PubSub.resources_Template.png' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'PubSub.resources_unread.tif' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'PubSub.resources_da.lproj_ArticlesL10N.css' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'PubSub.resources_da.lproj_Localizable.strings' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'PubSub.resources_de.lproj_ArticlesL10N.css' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'PubSub.resources_de.lproj_Localizable.strings' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'PubSub.resources_English.lproj_ArticlesL10N.css' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'PubSub.resources_English.lproj_Localizable.strings' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'PubSub.resources_es.lproj_ArticlesL10N.css' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'PubSub.resources_es.lproj_Localizable.strings' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'PubSub.resources_fi.lproj_ArticlesL10N.css' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'PubSub.resources_fi.lproj_Localizable.strings' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'PubSub.resources_fr.lproj_ArticlesL10N.css' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'PubSub.resources_fr.lproj_Localizable.strings' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'PubSub.resources_Framework_templates.lua' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'PubSub.resources_Framework_da.lproj_Localizable.strings' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'PubSub.resources_Framework_de.lproj_Localizable.strings' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'PubSub.resources_Framework_English.lproj_Localizable.strings' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'PubSub.resources_Framework_es.lproj_Localizable.strings' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'PubSub.resources_Framework_fi.lproj_Localizable.strings' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'PubSub.resources_Framework_fr.lproj_Localizable.strings' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'PubSub.resources_Framework_it.lproj_Localizable.strings' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'PubSub.resources_Framework_ja.lproj_Localizable.strings' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'PubSub.resources_Framework_ko.lproj_Localizable.strings' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'PubSub.resources_Framework_nb.lproj_Localizable.strings' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'PubSub.resources_Framework_nl.lproj_Localizable.strings' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'PubSub.resources_Framework_pl.lproj_Localizable.strings' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'PubSub.resources_Framework_pt.lproj_Localizable.strings' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'PubSub.resources_Framework_pt_PT.lproj_Localizable.strings' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'PubSub.resources_Framework_ru.lproj_Localizable.strings' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'PubSub.resources_Framework_sv.lproj_Localizable.strings' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'PubSub.resources_Framework_zh_CN.lproj_Localizable.strings' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'PubSub.resources_Framework_zh_TW.lproj_Localizable.strings' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'PubSub.resources_it.lproj_ArticlesL10N.css' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'PubSub.resources_it.lproj_Localizable.strings' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'PubSub.resources_ja.lproj_ArticlesL10N.css' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'PubSub.resources_ja.lproj_Localizable.strings' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'PubSub.resources_ko.lproj_ArticlesL10N.css' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'PubSub.resources_ko.lproj_Localizable.strings' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'PubSub.resources_nb.lproj_ArticlesL10N.css' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'PubSub.resources_nb.lproj_Localizable.strings' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'PubSub.resources_nl.lproj_ArticlesL10N.css' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'PubSub.resources_nl.lproj_Localizable.strings' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'PubSub.resources_pl.lproj_ArticlesL10N.css' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'PubSub.resources_pl.lproj_Localizable.strings' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'PubSub.resources_pt.lproj_ArticlesL10N.css' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'PubSub.resources_pt.lproj_Localizable.strings' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'PubSub.resources_pt_PT.lproj_ArticlesL10N.css' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'PubSub.resources_pt_PT.lproj_Localizable.strings' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'PubSub.resources_ru.lproj_ArticlesL10N.css' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'PubSub.resources_ru.lproj_Localizable.strings' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'PubSub.resources_sv.lproj_ArticlesL10N.css' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'PubSub.resources_sv.lproj_Localizable.strings' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'PubSub.resources_zh_CN.lproj_ArticlesL10N.css' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'PubSub.resources_zh_CN.lproj_Localizable.strings' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'PubSub.resources_zh_TW.lproj_ArticlesL10N.css' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'PubSub.resources_zh_TW.lproj_Localizable.strings' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: The file represented by File table key 'JavaPlugin.jar' has no eligible binary patches
                MSI (s) (A4:F8) [11:14:56:677]: Note: 1: 2205 2:  3: Patch
                MSI (s) (A4:F8) [11:14:56:677]: Note: 1: 2228 2:  3: Patch 4: SELECT `Patch`.`File_`, `Patch`.`Header`, `Patch`.`Attributes`, `Patch`.`Sequence`, `Patch`.`StreamRef_` FROM `Patch` WHERE `Patch`.`File_` = ? AND `Patch`.`#_MsiActive`=? ORDER BY `Patch`.`Sequence`
                MSI (s) (A4:F8) [11:14:56:677]: Note: 1: 2205 2:  3: MsiSFCBypass
                MSI (s) (A4:F8) [11:14:56:677]: Note: 1: 2228 2:  3: MsiSFCBypass 4: SELECT `File_` FROM `MsiSFCBypass` WHERE `File_` = ?
                MSI (s) (A4:F8) [11:14:56:677]: Note: 1: 2205 2:  3: MsiPatchHeaders
                MSI (s) (A4:F8) [11:14:56:677]: Note: 1: 2228 2:  3: MsiPatchHeaders 4: SELECT `Header` FROM `MsiPatchHeaders` WHERE `StreamRef` = ?
                Action start 11:14:56: InstallFiles.
                MSI (s) (A4:F8) [11:14:56:692]: Using cached product context: machine assigned for product: D5E3FA2F7969C5845ACA2E9B64C844A6
                MSI (s) (A4:F8) [11:14:56:692]: Note: 1: 2205 2:  3: PatchPackage
                MSI (s) (A4:F8) [11:14:56:692]: Note: 1: 2205 2:  3: MsiPatchHeaders
                MSI (s) (A4:F8) [11:14:56:708]: Using cached product context: machine assigned for product: D5E3FA2F7969C5845ACA2E9B64C844A6
                MSI (s) (A4:F8) [11:14:56:708]: Note: 1: 2205 2:  3: Patch
                MSI (s) (A4:F8) [11:14:56:708]: Note: 1: 2228 2:  3: Patch 4: SELECT `Patch`.`Sequence`, `Patch`.`PatchSize`, `Patch`.`Attributes`, `Patch`.`Header`, `Patch`.`StreamRef_` FROM `File`,`Patch`,`Component` WHERE `File`=? AND `File`=`File_` AND `Component`=`Component_` ORDER BY `Patch`.`Sequence`
                MSI (s) (A4:F8) [11:14:56:802]: Using cached product context: machine assigned for product: D5E3FA2F7969C5845ACA2E9B64C844A6
                MSI (s) (A4:F8) [11:14:56:802]: Note: 1: 2205 2:  3: Patch
                MSI (s) (A4:F8) [11:14:56:802]: Note: 1: 2228 2:  3: Patch 4: SELECT `Patch`.`Sequence`, `Patch`.`PatchSize`, `Patch`.`Attributes`, `Patch`.`Header`, `Patch`.`StreamRef_` FROM `File`,`Patch`,`Component` WHERE `File`=? AND `File`=`File_` AND `Component`=`Component_` ORDER BY `Patch`.`Sequence`
                MSI (s) (A4:F8) [11:14:57:582]: Using cached product context: machine assigned for product: D5E3FA2F7969C5845ACA2E9B64C844A6
                MSI (s) (A4:F8) [11:14:57:582]: Note: 1: 2205 2:  3: Patch
                MSI (s) (A4:F8) [11:14:57:582]: Note: 1: 2228 2:  3: Patch 4: SELECT `Patch`.`Sequence`, `Patch`.`PatchSize`, `Patch`.`Attributes`, `Patch`.`Header`, `Patch`.`StreamRef_` FROM `File`,`Patch`,`Component` WHERE `File`=? AND `File`=`File_` AND `Component`=`Component_` ORDER BY `Patch`.`Sequence`
                MSI (s) (A4:F8) [11:14:57:972]: Using cached product context: machine assigned for product: D5E3FA2F7969C5845ACA2E9B64C844A6
                MSI (s) (A4:F8) [11:14:57:972]: Note: 1: 2205 2:  3: Patch
                MSI (s) (A4:F8) [11:14:57:972]: Note: 1: 2228 2:  3: Patch 4: SELECT `Patch`.`Sequence`, `Patch`.`PatchSize`, `Patch`.`Attributes`, `Patch`.`Header`, `Patch`.`StreamRef_` FROM `File`,`Patch`,`Component` WHERE `File`=? AND `File`=`File_` AND `Component`=`Component_` ORDER BY `Patch`.`Sequence`
                MSI (s) (A4:F8) [11:14:58:065]: Using cached product context: machine assigned for product: D5E3FA2F7969C5845ACA2E9B64C844A6
                MSI (s) (A4:F8) [11:14:58:065]: Note: 1: 2205 2:  3: Patch
                MSI (s) (A4:F8) [11:14:58:065]: Note: 1: 2228 2:  3: Patch 4: SELECT `Patch`.`Sequence`, `Patch`.`PatchSize`, `Patch`.`Attributes`, `Patch`.`Header`, `Patch`.`StreamRef_` FROM `File`,`Patch`,`Component` WHERE `File`=? AND `File`=`File_` AND `Component`=`Component_` ORDER BY `Patch`.`Sequence`
                MSI (s) (A4:F8) [11:14:58:362]: Doing action: CreateShortcuts
                Action ended 11:14:58: InstallFiles. Return value 1.
                MSI (s) (A4:F8) [11:14:58:362]: Using cached product context: machine assigned for product: D5E3FA2F7969C5845ACA2E9B64C844A6
                Action start 11:14:58: CreateShortcuts.
                MSI (s) (A4:F8) [11:14:58:408]: Using cached product context: machine assigned for product: D5E3FA2F7969C5845ACA2E9B64C844A6
                MSI (s) (A4:F8) [11:14:58:424]: Doing action: WriteRegistryValues
                Action ended 11:14:58: CreateShortcuts. Return value 1.
                Action start 11:14:58: WriteRegistryValues.
                MSI (s) (A4:F8) [11:14:58:424]: Skipping action: SetMakeSafariDefaultBrowser (condition is false)
                MSI (s) (A4:F8) [11:14:58:424]: Skipping action: MakeSafariDefaultBrowser (condition is false)
                MSI (s) (A4:F8) [11:14:58:424]: Doing action: RegisterUser
                Action ended 11:14:58: WriteRegistryValues. Return value 1.
                Action start 11:14:58: RegisterUser.
                MSI (s) (A4:F8) [11:14:58:424]: Doing action: RegisterProduct
                Action ended 11:14:58: RegisterUser. Return value 0.
                MSI (s) (A4:F8) [11:14:58:424]: Using cached product context: machine assigned for product: D5E3FA2F7969C5845ACA2E9B64C844A6
                Action start 11:14:58: RegisterProduct.
                MSI (s) (A4:F8) [11:14:58:440]: Doing action: PublishFeatures
                Action ended 11:14:58: RegisterProduct. Return value 1.
                Action start 11:14:58: PublishFeatures.
                MSI (s) (A4:F8) [11:14:58:440]: Using cached product context: machine assigned for product: D5E3FA2F7969C5845ACA2E9B64C844A6
                MSI (s) (A4:F8) [11:14:58:440]: Doing action: PublishProduct
                Action ended 11:14:58: PublishFeatures. Return value 1.
                Action start 11:14:58: PublishProduct.
                MSI (s) (A4:F8) [11:14:58:549]: Using cached product context: machine assigned for product: D5E3FA2F7969C5845ACA2E9B64C844A6
                MSI (s) (A4:F8) [11:14:58:549]: Doing action: InstallFinalize
                Action ended 11:14:58: PublishProduct. Return value 1.
                MSI (s) (A4:F8) [11:14:58:580]: Running Script: C:\Windows\Installer\MSI2413.tmp
                MSI (s) (A4:F8) [11:14:58:580]: PROPERTY CHANGE: Adding UpdateStarted property. Its value is '1'.
                MSI (s) (A4:F8) [11:14:58:580]: Machine policy value 'DisableRollback' is 0
                MSI (s) (A4:F8) [11:14:58:611]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Installer\Rollback\Scripts 3: 2
                MSI (s) (A4:F8) [11:14:58:627]: Executing op: Header(Signature=1397708873,Version=405,Timestamp=1096505821,LangId=1033,Platform=0,Scrip tType=1,ScriptMajorVersion=21,ScriptMinorVersion=4,ScriptAttributes=1)
                Action start 11:14:58: InstallFinalize.
                MSI (s) (A4:F8) [11:14:58:627]: Executing op: ProductInfo(ProductKey={F2AF3E5D-9697-485C-A5AC-E2B9468C446A},ProductName=Safari,PackageN ame=Safari.msi,Language=1033,Version=86114356,Assignment=1,ObsoleteArg=0,ProductIcon=Insta ller.ico,,PackageCode={5EAA9433-59D8-45B3-AA81-B816484562B1},,,InstanceType=0,LUASetting=0 ,RemoteURTInstalls=0,ProductDeploymentFlags=2)
                MSI (s) (A4:F8) [11:14:58:627]: Executing op: DialogInfo(Type=0,Argument=1033)
                MSI (s) (A4:F8) [11:14:58:627]: Executing op: DialogInfo(Type=1,Argument=Safari)
                MSI (s) (A4:F8) [11:14:58:627]: Executing op: RollbackInfo(,RollbackAction=Rollback,RollbackDescription=Rolling back action:,RollbackTemplate=[1],CleanupAction=RollbackCleanup,CleanupDescription=Removing backup files,CleanupTemplate=File: [1])
                MSI (s) (A4:F8) [11:14:58:627]: Executing op: SetBaseline(Baseline=0,)
                MSI (s) (A4:F8) [11:14:58:627]: Executing op: SetBaseline(Baseline=1,)
                MSI (s) (A4:F8) [11:14:58:627]: Executing op: ActionStart(Name=ProcessComponents,Description=Updating component registration,)
                MSI (s) (A4:F8) [11:14:58:627]: Executing op: ProgressTotal(Total=552,Type=1,ByteEquivalent=24000)
                MSI (s) (A4:F8) [11:14:58:627]: Executing op: ComponentRegister(ComponentId={C7285A96-10C1-412B-9D6D-4287BD4D1C7C},KeyPath=C:\Program Files\Safari\Safari.dll,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:627]: Executing op: ComponentRegister(ComponentId={E58732EE-57A2-11DF-BAAC-94D1DFD72085},KeyPath=C:\Program Files\Safari\,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:627]: Executing op: ComponentRegister(ComponentId={FBE2E758-8DF0-405B-9614-836BB47604BF},KeyPath=C:\Program Files\Safari\PubSubDLL.dll,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:627]: Executing op: ComponentRegister(ComponentId={0366B5E2-3194-11DC-8314-0800200C9A66},KeyPath=C:\Program Files\Safari\Search.dll,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:627]: Executing op: ComponentRegister(ComponentId={79693D8A-3193-11DC-8314-0800200C9A66},KeyPath=C:\Program Files\Safari\SpellChecker.dll,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:627]: Executing op: ComponentRegister(ComponentId={A67196C9-4725-4262-A2ED-41EA9AC05929},KeyPath=C:\Program Files\Safari\Safari.exe,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:627]: Executing op: ComponentRegister(ComponentId={00B13A64-3646-11DC-8314-0800200C9A66},KeyPath=C:\Program Files\Safari\,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:627]: Executing op: ComponentRegister(ComponentId={7B7F2205-1CF7-4E42-AEC7-1472F90964EA},KeyPath=02:\Software \Clients\StartMenuInternet\Safari.exe\,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:627]: Executing op: ComponentRegister(ComponentId={3072EB84-3EAE-4522-8E44-C130DBE669F2},KeyPath=C:\Program Files\Safari\SafariTheme.dll,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:627]: Executing op: ComponentRegister(ComponentId={C9D66122-C3EB-4234-85FD-F5A7561E03EC},KeyPath=C:\Program Files\Safari\Plugins\npJavaPlugin.dll,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:627]: Executing op: ComponentRegister(ComponentId={5EC31A17-CB7F-469A-AF44-F8F8EA73B762},KeyPath=01:\SOFTWARE \Apple Computer, Inc.\Safari\Shortcuts,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:627]: Executing op: ComponentRegister(ComponentId={732AA6C8-DA58-4A2F-B206-7162C4AB0B45},KeyPath=C:\ProgramDa ta\Apple Computer\Installer Cache\Safari 5.34.52.7\,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:627]: Executing op: ComponentRegister(ComponentId={288DC1C6-8C21-11E0-AA65-5CA84824019B},KeyPath=C:\Program Files\Safari\Safari.resources\ABAddressFormats.plist,State=3,,Disk=1,SharedDllRefCount=0, BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:627]: Executing op: ComponentRegister(ComponentId={8AF602E5-D4DB-4035-A5E5-CE7C81C44AEB},KeyPath=C:\Program Files\Safari\Safari.resources\About.html,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0 )
                MSI (s) (A4:F8) [11:14:58:627]: Executing op: ComponentRegister(ComponentId={16FD3283-224C-4250-A216-328E52ECF78A},KeyPath=C:\Program Files\Safari\Safari.resources\AddButtonGlyph.png,State=3,,Disk=1,SharedDllRefCount=0,Bina ryType=0)
                MSI (s) (A4:F8) [11:14:58:627]: Executing op: ComponentRegister(ComponentId={E808399F-97FE-46D6-9A01-7D091B5489ED},KeyPath=C:\Program Files\Safari\Safari.resources\AddressBookEntryView.html,State=3,,Disk=1,SharedDllRefCount =0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:627]: Executing op: ComponentRegister(ComponentId={3DE219A0-8C21-11E0-94E5-75A84824019B},KeyPath=C:\Program Files\Safari\Safari.resources\AddressCard.png,State=3,,Disk=1,SharedDllRefCount=0,BinaryT ype=0)
                MSI (s) (A4:F8) [11:14:58:642]: Executing op: ComponentRegister(ComponentId={B46AE9C6-66B1-4506-A4E6-AFC0550D682D},KeyPath=C:\Program Files\Safari\Safari.resources\AdvancedPreferences.html,State=3,,Disk=1,SharedDllRefCount= 0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:642]: Executing op: ComponentRegister(ComponentId={40672280-902F-45BC-B4B5-5A7062A8D8ED},KeyPath=C:\Program Files\Safari\Safari.resources\AlertDialog.html,State=3,,Disk=1,SharedDllRefCount=0,Binary Type=0)
                MSI (s) (A4:F8) [11:14:58:642]: Executing op: ComponentRegister(ComponentId={46124E92-8C21-11E0-8B14-79A84824019B},KeyPath=C:\Program Files\Safari\Safari.resources\aol666.pltsuite,State=3,,Disk=1,SharedDllRefCount=0,BinaryT ype=0)
                MSI (s) (A4:F8) [11:14:58:642]: Executing op: ComponentRegister(ComponentId={7A311874-B9E4-4A03-B462-264EFD473B09},KeyPath=C:\Program Files\Safari\Safari.resources\AppearancePreferences.html,State=3,,Disk=1,SharedDllRefCoun t=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:642]: Executing op: ComponentRegister(ComponentId={84EB0516-5808-4A8F-B002-651BB77CFB41},KeyPath=C:\Program Files\Safari\Safari.resources\AutoFill.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType= 0)
                MSI (s) (A4:F8) [11:14:58:642]: Executing op: ComponentRegister(ComponentId={0C2CC9E7-AB10-4123-8DF5-9079D112C64A},KeyPath=C:\Program Files\Safari\Safari.resources\AutoFillPreferences.html,State=3,,Disk=1,SharedDllRefCount= 0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:642]: Executing op: ComponentRegister(ComponentId={08E9BE4F-240A-407F-8F9F-BBF2199A66BB},KeyPath=C:\Program Files\Safari\Safari.resources\badgeFill.png,State=3,,Disk=1,SharedDllRefCount=0,BinaryTyp e=0)
                MSI (s) (A4:F8) [11:14:58:642]: Executing op: ComponentRegister(ComponentId={F31B4944-16EF-409F-9AA3-8267BDEA8FCE},KeyPath=C:\Program Files\Safari\Safari.resources\badgeFillInactive.png,State=3,,Disk=1,SharedDllRefCount=0,B inaryType=0)
                MSI (s) (A4:F8) [11:14:58:642]: Executing op: ComponentRegister(ComponentId={CFA2B9A3-CA0D-4FD2-842B-88E7ABAA478A},KeyPath=C:\Program Files\Safari\Safari.resources\badgeLeftCap.png,State=3,,Disk=1,SharedDllRefCount=0,Binary Type=0)
                MSI (s) (A4:F8) [11:14:58:642]: Executing op: ComponentRegister(ComponentId={783F053A-9E77-4932-866B-3940E26F9964},KeyPath=C:\Program Files\Safari\Safari.resources\badgeLeftCapInactive.png,State=3,,Disk=1,SharedDllRefCount= 0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:642]: Executing op: ComponentRegister(ComponentId={BAAAB3C6-0B9B-45BB-8C25-7BA5FC247C97},KeyPath=C:\Program Files\Safari\Safari.resources\badgeRightCap.png,State=3,,Disk=1,SharedDllRefCount=0,Binar yType=0)
                MSI (s) (A4:F8) [11:14:58:642]: Executing op: ComponentRegister(ComponentId={C0E1DE6C-E158-4A5A-8B31-25C943949698},KeyPath=C:\Program Files\Safari\Safari.resources\badgeRightCapInactive.png,State=3,,Disk=1,SharedDllRefCount =0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:642]: Executing op: ComponentRegister(ComponentId={7614A5B3-B503-4643-9466-BF3200D5E454},KeyPath=C:\Program Files\Safari\Safari.resources\BlackSearchField.html,State=3,,Disk=1,SharedDllRefCount=0,B inaryType=0)
                MSI (s) (A4:F8) [11:14:58:642]: Executing op: ComponentRegister(ComponentId={D9DD6329-D0EC-423A-92E0-92E6897A5C77},KeyPath=C:\Program Files\Safari\Safari.resources\BlackSearchFieldCancel.png,State=3,,Disk=1,SharedDllRefCoun t=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:642]: Executing op: ComponentRegister(ComponentId={8B62143A-ADAF-421C-831C-6E08B41A6253},KeyPath=C:\Program Files\Safari\Safari.resources\BlackSearchFieldCancelPressed.png,State=3,,Disk=1,SharedDll RefCount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:642]: Executing op: ComponentRegister(ComponentId={43DB3739-156F-4AB8-A71D-8ACFB79C491C},KeyPath=C:\Program Files\Safari\Safari.resources\BlackSearchFieldCell.png,State=3,,Disk=1,SharedDllRefCount= 0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:642]: Executing op: ComponentRegister(ComponentId={9C313802-CF5A-11E0-A8A4-888E4824019B},KeyPath=C:\Program Files\Safari\Safari.resources\BonjourLarge~win.png,State=3,,Disk=1,SharedDllRefCount=0,Bi naryType=0)
                MSI (s) (A4:F8) [11:14:58:642]: Executing op: ComponentRegister(ComponentId={D5EAC41E-37E8-40B5-8306-88A20FAB4919},KeyPath=C:\Program Files\Safari\Safari.resources\BookmarkChooser.html,State=3,,Disk=1,SharedDllRefCount=0,Bi naryType=0)
                MSI (s) (A4:F8) [11:14:58:642]: Executing op: ComponentRegister(ComponentId={E9BA8B47-CEA0-4CC3-B9F1-6F9821E88B1A},KeyPath=C:\Program Files\Safari\Safari.resources\BookmarkPreferences.html,State=3,,Disk=1,SharedDllRefCount= 0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:642]: Executing op: ComponentRegister(ComponentId={98327E7B-40FB-49BD-ADC3-01E95809D358},KeyPath=C:\Program Files\Safari\Safari.resources\BookmarkTitleChange.html,State=3,,Disk=1,SharedDllRefCount= 0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:642]: Executing op: ComponentRegister(ComponentId={9644D921-C969-4C07-B027-94C3165B8C15},KeyPath=C:\Program Files\Safari\Safari.resources\BugReport.html,State=3,,Disk=1,SharedDllRefCount=0,BinaryTy pe=0)
                MSI (s) (A4:F8) [11:14:58:642]: Executing op: ComponentRegister(ComponentId={FF7DBF25-7D1C-4682-960B-ACE1E4EB5F1A},KeyPath=C:\Program Files\Safari\Safari.resources\CachesWindow.html,State=3,,Disk=1,SharedDllRefCount=0,Binar yType=0)
                MSI (s) (A4:F8) [11:14:58:642]: Executing op: ComponentRegister(ComponentId={EE83BEC5-5CDF-4733-8DB6-8F8D652425CF},KeyPath=C:\Program Files\Safari\Safari.resources\Certificate.png,State=3,,Disk=1,SharedDllRefCount=0,BinaryT ype=0)
                MSI (s) (A4:F8) [11:14:58:642]: Executing op: ComponentRegister(ComponentId={B37FBF13-9E1F-4E51-A257-963AF321B044},KeyPath=C:\Program Files\Safari\Safari.resources\compass.png,State=3,,Disk=1,SharedDllRefCount=0,BinaryType= 0)
                MSI (s) (A4:F8) [11:14:58:642]: Executing op: ComponentRegister(ComponentId={F90CF23B-ECEA-4EFA-B72A-C7884B55476E},KeyPath=C:\Program Files\Safari\Safari.resources\compass64.png,State=3,,Disk=1,SharedDllRefCount=0,BinaryTyp e=0)
                MSI (s) (A4:F8) [11:14:58:658]: Executing op: ComponentRegister(ComponentId={3E740ACE-7B00-45D9-841D-80491FC3904A},KeyPath=C:\Program Files\Safari\Safari.resources\CoverflowScrollThumb-Pressed.png,State=3,,Disk=1,SharedDllR efCount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:658]: Executing op: ComponentRegister(ComponentId={B9A7C3A5-D5D8-46BD-B1BE-5901279E2138},KeyPath=C:\Program Files\Safari\Safari.resources\CoverflowScrollThumbFill.png,State=3,,Disk=1,SharedDllRefCo unt=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:658]: Executing op: ComponentRegister(ComponentId={C3736CF9-AF98-410D-9D7A-FC6CEB8275BD},KeyPath=C:\Program Files\Safari\Safari.resources\CoverflowScrollThumbLeft-Pressed.png,State=3,,Disk=1,Shared DllRefCount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:658]: Executing op: ComponentRegister(ComponentId={D33928C4-9A75-46DE-AADF-395D16393D64},KeyPath=C:\Program Files\Safari\Safari.resources\CoverflowScrollThumbLeft.png,State=3,,Disk=1,SharedDllRefCo unt=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:658]: Executing op: ComponentRegister(ComponentId={8DA3A58C-047C-453B-BE4C-3A394A237F9D},KeyPath=C:\Program Files\Safari\Safari.resources\CoverflowScrollThumbRight-Pressed.png,State=3,,Disk=1,Share dDllRefCount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:658]: Executing op: ComponentRegister(ComponentId={D1BE66F6-CE5D-422D-A05C-5EB3F0E347F1},KeyPath=C:\Program Files\Safari\Safari.resources\CoverflowScrollThumbRight.png,State=3,,Disk=1,SharedDllRefC ount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:658]: Executing op: ComponentRegister(ComponentId={31F00C9A-0899-453D-B2EA-7EFB5C68E98C},KeyPath=C:\Program Files\Safari\Safari.resources\CoverflowScrollTrackFill.png,State=3,,Disk=1,SharedDllRefCo unt=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:658]: Executing op: ComponentRegister(ComponentId={9F812634-8A7C-44FF-9203-B44FBCD78D0A},KeyPath=C:\Program Files\Safari\Safari.resources\CoverflowScrollTrackLeft.png,State=3,,Disk=1,SharedDllRefCo unt=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:658]: Executing op: ComponentRegister(ComponentId={7DC7944A-01FF-4257-B8F9-D9DDFBCAE8C3},KeyPath=C:\Program Files\Safari\Safari.resources\CoverflowScrollTrackRight.png,State=3,,Disk=1,SharedDllRefC ount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:658]: Executing op: ComponentRegister(ComponentId={1CB8E89C-4E37-4F6F-8C87-A6DAD0E76CD7},KeyPath=C:\Program Files\Safari\Safari.resources\CustomizeToolbar.html,State=3,,Disk=1,SharedDllRefCount=0,B inaryType=0)
                MSI (s) (A4:F8) [11:14:58:658]: Executing op: ComponentRegister(ComponentId={4AEDFBD2-8C21-11E0-92EF-7EA84824019B},KeyPath=C:\Program Files\Safari\Safari.resources\cvs-base.pltsuite,State=3,,Disk=1,SharedDllRefCount=0,Binar yType=0)
                MSI (s) (A4:F8) [11:14:58:658]: Executing op: ComponentRegister(ComponentId={504AFE4A-8C21-11E0-AC09-80A84824019B},KeyPath=C:\Program Files\Safari\Safari.resources\cvs-js-ibench.pltsuite,State=3,,Disk=1,SharedDllRefCount=0, BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:658]: Executing op: ComponentRegister(ComponentId={557DC62C-8C21-11E0-BCC4-87A84824019B},KeyPath=C:\Program Files\Safari\Safari.resources\cvs-js-performance.pltsuite,State=3,,Disk=1,SharedDllRefCou nt=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:658]: Executing op: ComponentRegister(ComponentId={59E4A820-8C21-11E0-BA25-91A84824019B},KeyPath=C:\Program Files\Safari\Safari.resources\cvs-static-urls.pltsuite,State=3,,Disk=1,SharedDllRefCount= 0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:658]: Executing op: ComponentRegister(ComponentId={5E7C392A-8C21-11E0-BFA2-95A84824019B},KeyPath=C:\Program Files\Safari\Safari.resources\cvs-torture-test.pltsuite,State=3,,Disk=1,SharedDllRefCount =0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:658]: Executing op: ComponentRegister(ComponentId={2688DC76-657C-46E2-8AAD-9347FD775801},KeyPath=C:\Program Files\Safari\Safari.resources\Defaults.plist,State=3,,Disk=1,SharedDllRefCount=0,BinaryTy pe=0)
                MSI (s) (A4:F8) [11:14:58:658]: Executing op: ComponentRegister(ComponentId={01064DBA-076A-4B34-87D1-090CA81F585F},KeyPath=C:\Program Files\Safari\Safari.resources\Dialog.css,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0 )
                MSI (s) (A4:F8) [11:14:58:658]: Executing op: ComponentRegister(ComponentId={F39D91C0-8BF7-4DA0-9745-CB82FD00A02E},KeyPath=C:\Program Files\Safari\Safari.resources\DownloadPromptDialog.html,State=3,,Disk=1,SharedDllRefCount =0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:658]: Executing op: ComponentRegister(ComponentId={63E41FFE-8C21-11E0-B254-B3A84824019B},KeyPath=C:\Program Files\Safari\Safari.resources\epoxy-base.pltsuite,State=3,,Disk=1,SharedDllRefCount=0,Bin aryType=0)
                MSI (s) (A4:F8) [11:14:58:658]: Executing op: ComponentRegister(ComponentId={40331728-9784-4402-A71B-987BA45A889D},KeyPath=C:\Program Files\Safari\Safari.resources\Error.png,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:658]: Executing op: ComponentRegister(ComponentId={68118602-8C21-11E0-9556-B7A84824019B},KeyPath=C:\Program Files\Safari\Safari.resources\ErrorPageBackgroundTile.png,State=3,,Disk=1,SharedDllRefCou nt=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:658]: Executing op: ComponentRegister(ComponentId={6C1BB59C-8C21-11E0-8AAB-BBA84824019B},KeyPath=C:\Program Files\Safari\Safari.resources\ErrorPageCompass.png,State=3,,Disk=1,SharedDllRefCount=0,Bi naryType=0)
                MSI (s) (A4:F8) [11:14:58:658]: Executing op: ComponentRegister(ComponentId={6FE45A58-8C21-11E0-82DC-BFA84824019B},KeyPath=C:\Program Files\Safari\Safari.resources\ErrorPageDividerLine.png,State=3,,Disk=1,SharedDllRefCount= 0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:658]: Executing op: ComponentRegister(ComponentId={73F4EFB5-3DF7-4223-9122-3786721CB2E5},KeyPath=C:\Program Files\Safari\Safari.resources\ErrorSmall.png,State=3,,Disk=1,SharedDllRefCount=0,BinaryTy pe=0)
                MSI (s) (A4:F8) [11:14:58:658]: Executing op: ComponentRegister(ComponentId={7A8ED2EB-72CF-4424-A89F-9057ECAC2B1A},KeyPath=C:\Program Files\Safari\Safari.resources\EVRoots.plist,State=3,,Disk=1,SharedDllRefCount=0,BinaryTyp e=0)
                MSI (s) (A4:F8) [11:14:58:658]: Executing op: ComponentRegister(ComponentId={313288B4-FB64-48F3-AEA8-DB342BB46755},KeyPath=C:\Program Files\Safari\Safari.resources\ExtensionBar.css,State=3,,Disk=1,SharedDllRefCount=0,Binary Type=0)
                MSI (s) (A4:F8) [11:14:58:674]: Executing op: ComponentRegister(ComponentId={72F34B50-0A67-4E7E-B323-04D082DF7102},KeyPath=C:\Program Files\Safari\Safari.resources\ExtensionBarWin.css,State=3,,Disk=1,SharedDllRefCount=0,Bin aryType=0)
                MSI (s) (A4:F8) [11:14:58:674]: Executing op: ComponentRegister(ComponentId={2F5ECC9C-706A-4EB8-9FD0-BF9D8FEFF9FE},KeyPath=C:\Program Files\Safari\Safari.resources\ExtensionBuilder.css,State=3,,Disk=1,SharedDllRefCount=0,Bi naryType=0)
                MSI (s) (A4:F8) [11:14:58:674]: Executing op: ComponentRegister(ComponentId={8DE0F32D-5C81-4821-B452-72456115E699},KeyPath=C:\Program Files\Safari\Safari.resources\ExtensionBuilder.html,State=3,,Disk=1,SharedDllRefCount=0,B inaryType=0)
                MSI (s) (A4:F8) [11:14:58:674]: Executing op: ComponentRegister(ComponentId={8851445F-719D-4F32-B9AD-7D6C3D056C8E},KeyPath=C:\Program Files\Safari\Safari.resources\ExtensionBuilder.js,State=3,,Disk=1,SharedDllRefCount=0,Bin aryType=0)
                MSI (s) (A4:F8) [11:14:58:674]: Executing op: ComponentRegister(ComponentId={FE6B4D6A-AAE2-4A81-9390-084DEF0829BE},KeyPath=C:\Program Files\Safari\Safari.resources\ExtensionClose.png,State=3,,Disk=1,SharedDllRefCount=0,Bina ryType=0)
                MSI (s) (A4:F8) [11:14:58:674]: Executing op: ComponentRegister(ComponentId={486A718D-38B8-4CC6-A008-A01BBD90A2C0},KeyPath=C:\Program Files\Safari\Safari.resources\ExtensionCloseHovered.png,State=3,,Disk=1,SharedDllRefCount =0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:674]: Executing op: ComponentRegister(ComponentId={D706DF61-17C8-4166-96B5-A5F9CAB92589},KeyPath=C:\Program Files\Safari\Safari.resources\ExtensionClosePressed.png,State=3,,Disk=1,SharedDllRefCount =0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:674]: Executing op: ComponentRegister(ComponentId={2C176613-F29D-4529-9CC6-691539E480EB},KeyPath=C:\Program Files\Safari\Safari.resources\ExtensionDefaultIcon32.png,State=3,,Disk=1,SharedDllRefCoun t=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:674]: Executing op: ComponentRegister(ComponentId={5C55D995-9BE1-45D7-9F0A-6DAE6E5CE0D0},KeyPath=C:\Program Files\Safari\Safari.resources\ExtensionDefaultIcon48.png,State=3,,Disk=1,SharedDllRefCoun t=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:674]: Executing op: ComponentRegister(ComponentId={A5EE9E47-4154-4021-9617-B7B4327F5263},KeyPath=C:\Program Files\Safari\Safari.resources\ExtensionDefaultIcon64.png,State=3,,Disk=1,SharedDllRefCoun t=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:674]: Executing op: ComponentRegister(ComponentId={08DFEF0C-A123-49B6-8FCB-183A3E383C64},KeyPath=C:\Program Files\Safari\Safari.resources\ExtensionSettings.css,State=3,,Disk=1,SharedDllRefCount=0,B inaryType=0)
                MSI (s) (A4:F8) [11:14:58:674]: Executing op: ComponentRegister(ComponentId={313931E6-2ED4-435A-81D7-42CAC9344057},KeyPath=C:\Program Files\Safari\Safari.resources\ExtensionSettings.js,State=3,,Disk=1,SharedDllRefCount=0,Bi naryType=0)
                MSI (s) (A4:F8) [11:14:58:674]: Executing op: ComponentRegister(ComponentId={174E89D5-F6D8-40A7-B6E9-9658A7CB9AC2},KeyPath=C:\Program Files\Safari\Safari.resources\ExtensionsView.css,State=3,,Disk=1,SharedDllRefCount=0,Bina ryType=0)
                MSI (s) (A4:F8) [11:14:58:674]: Executing op: ComponentRegister(ComponentId={03A4961F-5CAE-4A3E-9E2A-1623F8B17E30},KeyPath=C:\Program Files\Safari\Safari.resources\ExtensionsView.html,State=3,,Disk=1,SharedDllRefCount=0,Bin aryType=0)
                MSI (s) (A4:F8) [11:14:58:674]: Executing op: ComponentRegister(ComponentId={2322D10B-4CD0-4E41-AD8E-6CF1A5D286CD},KeyPath=C:\Program Files\Safari\Safari.resources\ExtensionsView.js,State=3,,Disk=1,SharedDllRefCount=0,Binar yType=0)
                MSI (s) (A4:F8) [11:14:58:674]: Executing op: ComponentRegister(ComponentId={55068F4E-50BD-4DB5-AA73-6119EDAD2672},KeyPath=C:\Program Files\Safari\Safari.resources\FindBanner.html,State=3,,Disk=1,SharedDllRefCount=0,BinaryT ype=0)
                MSI (s) (A4:F8) [11:14:58:674]: Executing op: ComponentRegister(ComponentId={FED9B488-7BE8-4F08-A090-850ABF4A75B0},KeyPath=C:\Program Files\Safari\Safari.resources\FlowViewFindBanner.css,State=3,,Disk=1,SharedDllRefCount=0, BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:674]: Executing op: ComponentRegister(ComponentId={5E567EFA-D616-46BD-AFDF-A7B1F4F2E0FC},KeyPath=C:\Program Files\Safari\Safari.resources\FlowViewFindBanner.html,State=3,,Disk=1,SharedDllRefCount=0 ,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:674]: Executing op: ComponentRegister(ComponentId={C5A446E6-8DB9-438E-8B8C-EBCBD82720F3},KeyPath=C:\Program Files\Safari\Safari.resources\FlowViewSearchField.png,State=3,,Disk=1,SharedDllRefCount=0 ,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:674]: Executing op: ComponentRegister(ComponentId={95472A21-B804-4C6A-83F0-B17D328F0C03},KeyPath=C:\Program Files\Safari\Safari.resources\FlowViewSplitter.png,State=3,,Disk=1,SharedDllRefCount=0,Bi naryType=0)
                MSI (s) (A4:F8) [11:14:58:674]: Executing op: ComponentRegister(ComponentId={6836C784-D0B8-48B4-95B8-B7C99E5C7FA3},KeyPath=C:\Program Files\Safari\Safari.resources\FontPicker.html,State=3,,Disk=1,SharedDllRefCount=0,BinaryT ype=0)
                MSI (s) (A4:F8) [11:14:58:674]: Executing op: ComponentRegister(ComponentId={73BD75C4-8C21-11E0-957B-C0A84824019B},KeyPath=C:\Program Files\Safari\Safari.resources\forbes-top-150.pltsuite,State=3,,Disk=1,SharedDllRefCount=0 ,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:674]: Executing op: ComponentRegister(ComponentId={7B4E56CD-87F1-44D5-BFD7-59A1ACE1DE0B},KeyPath=C:\Program Files\Safari\Safari.resources\FTPDirectoryTemplate.html,State=3,,Disk=1,SharedDllRefCount =0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:689]: Executing op: ComponentRegister(ComponentId={6672A128-EF73-46E3-A217-66EF2EB62BBC},KeyPath=C:\Program Files\Safari\Safari.resources\GeneralPreferences.html,State=3,,Disk=1,SharedDllRefCount=0 ,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:689]: Executing op: ComponentRegister(ComponentId={09A874E3-D579-4C03-96F3-B6B11DE871E0},KeyPath=C:\Program Files\Safari\Safari.resources\GenericFolderIcon.png,State=3,,Disk=1,SharedDllRefCount=0,B inaryType=0)
                MSI (s) (A4:F8) [11:14:58:689]: Executing op: ComponentRegister(ComponentId={71BB1F96-1CCA-412D-B53D-E5FC7D6B4F10},KeyPath=C:\Program Files\Safari\Safari.resources\glossyHeader.png,State=3,,Disk=1,SharedDllRefCount=0,Binary Type=0)
                MSI (s) (A4:F8) [11:14:58:689]: Executing op: ComponentRegister(ComponentId={3946139B-D134-4CC4-B304-5F283721D489},KeyPath=C:\Program Files\Safari\Safari.resources\glossyHeaderPressed.png,State=3,,Disk=1,SharedDllRefCount=0 ,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:689]: Executing op: ComponentRegister(ComponentId={26C0D554-E885-48F7-B3A1-8AAD6A815108},KeyPath=C:\Program Files\Safari\Safari.resources\glossyHeaderSelected.png,State=3,,Disk=1,SharedDllRefCount= 0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:689]: Executing op: ComponentRegister(ComponentId={D342AB2F-BFD3-4E3A-999E-743D7CBEBD66},KeyPath=C:\Program Files\Safari\Safari.resources\glossyHeaderSelectedPressed.png,State=3,,Disk=1,SharedDllRe fCount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:689]: Executing op: ComponentRegister(ComponentId={A0E295FA-6ACB-4B07-8A22-7AA271823B3B},KeyPath=C:\Program Files\Safari\Safari.resources\HelpButton.png,State=3,,Disk=1,SharedDllRefCount=0,BinaryTy pe=0)
                MSI (s) (A4:F8) [11:14:58:689]: Executing op: ComponentRegister(ComponentId={09FCAF94-E919-438E-A039-E7E6DBBB9106},KeyPath=C:\Program Files\Safari\Safari.resources\HelpButtonPressed.png,State=3,,Disk=1,SharedDllRefCount=0,B inaryType=0)
                MSI (s) (A4:F8) [11:14:58:689]: Executing op: ComponentRegister(ComponentId={0F93F89A-58C5-407B-B82E-7240ED13F170},KeyPath=C:\Program Files\Safari\Safari.resources\HideReaderButtonCapLeft.png,State=3,,Disk=1,SharedDllRefCou nt=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:689]: Executing op: ComponentRegister(ComponentId={9911B816-24EF-4EB6-B4AC-2EDF4D952A1A},KeyPath=C:\Program Files\Safari\Safari.resources\HideReaderButtonCapLeftPressed.png,State=3,,Disk=1,SharedDl lRefCount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:689]: Executing op: ComponentRegister(ComponentId={053AC1AD-5C7F-4E52-8B05-C668F087017A},KeyPath=C:\Program Files\Safari\Safari.resources\HideReaderButtonCapRight.png,State=3,,Disk=1,SharedDllRefCo unt=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:689]: Executing op: ComponentRegister(ComponentId={0F916BEF-10F5-457D-A37C-ED2C77952E9F},KeyPath=C:\Program Files\Safari\Safari.resources\HideReaderButtonCapRightPressed.png,State=3,,Disk=1,SharedD llRefCount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:689]: Executing op: ComponentRegister(ComponentId={E2D159DE-0B59-4C41-BEFF-D318AE15CFFA},KeyPath=C:\Program Files\Safari\Safari.resources\HideReaderButtonStretch.png,State=3,,Disk=1,SharedDllRefCou nt=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:689]: Executing op: ComponentRegister(ComponentId={5A62FD5D-BBC8-4A9C-8FAF-1B7D17A6DE3E},KeyPath=C:\Program Files\Safari\Safari.resources\HideReaderButtonStretchPressed.png,State=3,,Disk=1,SharedDl lRefCount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:689]: Executing op: ComponentRegister(ComponentId={155224EB-EF25-4A03-9012-390A221538CB},KeyPath=C:\Program Files\Safari\Safari.resources\HighContrastDarkButtonDiv-Selected.png,State=3,,Disk=1,Shar edDllRefCount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:689]: Executing op: ComponentRegister(ComponentId={5E950E7F-51F4-48FB-8040-F91654BB961F},KeyPath=C:\Program Files\Safari\Safari.resources\HighContrastDarkButtonFill-Pressed.png,State=3,,Disk=1,Shar edDllRefCount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:689]: Executing op: ComponentRegister(ComponentId={B64FD87D-D59A-47F5-A4D2-D8D938027B23},KeyPath=C:\Program Files\Safari\Safari.resources\HighContrastDarkButtonFill-Selected.png,State=3,,Disk=1,Sha redDllRefCount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:689]: Executing op: ComponentRegister(ComponentId={86E33FC8-BE72-4FF5-9B9D-187B83237CDE},KeyPath=C:\Program Files\Safari\Safari.resources\HighContrastDarkButtonFill-SelectedPressed.png,State=3,,Dis k=1,SharedDllRefCount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:689]: Executing op: ComponentRegister(ComponentId={EEC31066-4F1C-4296-9B06-B0320BD4A9E8},KeyPath=C:\Program Files\Safari\Safari.resources\HighContrastDarkButtonFill-Unselected.png,State=3,,Disk=1,S haredDllRefCount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:689]: Executing op: ComponentRegister(ComponentId={8B5A1E16-A1E6-45C1-A11F-5F6B16CF47BE},KeyPath=C:\Program Files\Safari\Safari.resources\HighContrastDarkButtonLeft-Pressed.png,State=3,,Disk=1,Shar edDllRefCount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:689]: Executing op: ComponentRegister(ComponentId={E0F8944B-789E-41AF-8910-753FF49C08DC},KeyPath=C:\Program Files\Safari\Safari.resources\HighContrastDarkButtonLeft-Selected.png,State=3,,Disk=1,Sha redDllRefCount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:689]: Executing op: ComponentRegister(ComponentId={C147B695-ECD3-43C6-87EB-1A992D309A3C},KeyPath=C:\Program Files\Safari\Safari.resources\HighContrastDarkButtonLeft-SelectedPressed.png,State=3,,Dis k=1,SharedDllRefCount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:689]: Executing op: ComponentRegister(ComponentId={9CB7BE59-0D28-4066-BF45-48155F089701},KeyPath=C:\Program Files\Safari\Safari.resources\HighContrastDarkButtonLeft-Unselected.png,State=3,,Disk=1,S haredDllRefCount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:689]: Executing op: ComponentRegister(ComponentId={44DDE6F8-B577-4245-8C4E-D430E73C50BD},KeyPath=C:\Program Files\Safari\Safari.resources\HighContrastDarkButtonRight-Pressed.png,State=3,,Disk=1,Sha redDllRefCount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:705]: Executing op: ComponentRegister(ComponentId={AE3460AE-68A4-48FB-8618-5473582F64E6},KeyPath=C:\Program Files\Safari\Safari.resources\HighContrastDarkButtonRight-Selected.png,State=3,,Disk=1,Sh aredDllRefCount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:705]: Executing op: ComponentRegister(ComponentId={03BFA7D9-6538-4ED2-B1E7-920E11F31359},KeyPath=C:\Program Files\Safari\Safari.resources\HighContrastDarkButtonRight-SelectedPressed.png,State=3,,Di sk=1,SharedDllRefCount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:705]: Executing op: ComponentRegister(ComponentId={DD1F5BFA-23CA-487F-9687-9010C8FA7D94},KeyPath=C:\Program Files\Safari\Safari.resources\HighContrastDarkButtonRight-Unselected.png,State=3,,Disk=1, SharedDllRefCount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:705]: Executing op: ComponentRegister(ComponentId={2EF75D10-BBCB-4DB6-B323-3C175C3F739D},KeyPath=C:\Program Files\Safari\Safari.resources\HTMLViewController.js,State=3,,Disk=1,SharedDllRefCount=0,B inaryType=0)
                MSI (s) (A4:F8) [11:14:58:705]: Executing op: ComponentRegister(ComponentId={78E14896-8C21-11E0-BF01-C5A84824019B},KeyPath=C:\Program Files\Safari\Safari.resources\http-base.pltsuite,State=3,,Disk=1,SharedDllRefCount=0,Bina ryType=0)
                MSI (s) (A4:F8) [11:14:58:705]: Executing op: ComponentRegister(ComponentId={7CF9C322-8C21-11E0-B770-C6A84824019B},KeyPath=C:\Program Files\Safari\Safari.resources\http-js-ibench.pltsuite,State=3,,Disk=1,SharedDllRefCount=0 ,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:705]: Executing op: ComponentRegister(ComponentId={83338502-8C21-11E0-B0DA-C7A84824019B},KeyPath=C:\Program Files\Safari\Safari.resources\http-js-performance.pltsuite,State=3,,Disk=1,SharedDllRefCo unt=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:705]: Executing op: ComponentRegister(ComponentId={89D3DBDC-8C21-11E0-B83F-2FA94824019B},KeyPath=C:\Program Files\Safari\Safari.resources\http-static-urls.pltsuite,State=3,,Disk=1,SharedDllRefCount =0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:705]: Executing op: ComponentRegister(ComponentId={8E58620E-8C21-11E0-A7CA-30A94824019B},KeyPath=C:\Program Files\Safari\Safari.resources\http-torture-test.pltsuite,State=3,,Disk=1,SharedDllRefCoun t=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:705]: Executing op: ComponentRegister(ComponentId={923C2536-8C21-11E0-AAB4-34A94824019B},KeyPath=C:\Program Files\Safari\Safari.resources\ibench5-html.pltsuite,State=3,,Disk=1,SharedDllRefCount=0,B inaryType=0)
                MSI (s) (A4:F8) [11:14:58:705]: Executing op: ComponentRegister(ComponentId={4E98FF00-6756-45D5-BD7D-28A6A88EBCF2},KeyPath=C:\Program Files\Safari\Safari.resources\IDNScriptWhiteList.txt,State=3,,Disk=1,SharedDllRefCount=0, BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:705]: Executing op: ComponentRegister(ComponentId={CC4EDF9B-CBC7-4ABC-AC41-53229697BA41},KeyPath=C:\Program Files\Safari\Safari.resources\Info.plist,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0 )
                MSI (s) (A4:F8) [11:14:58:705]: Executing op: ComponentRegister(ComponentId={963D2FD6-8C21-11E0-9126-35A94824019B},KeyPath=C:\Program Files\Safari\Safari.resources\j+euro.pltsuite,State=3,,Disk=1,SharedDllRefCount=0,BinaryT ype=0)
                MSI (s) (A4:F8) [11:14:58:705]: Executing op: ComponentRegister(ComponentId={9C57D61E-8C21-11E0-80E9-39A94824019B},KeyPath=C:\Program Files\Safari\Safari.resources\java.pltsuite,State=3,,Disk=1,SharedDllRefCount=0,BinaryTyp e=0)
                MSI (s) (A4:F8) [11:14:58:705]: Executing op: ComponentRegister(ComponentId={46C8CACE-8ECC-4CDF-BEAA-ACF4F390A935},KeyPath=C:\Program Files\Safari\Safari.resources\LoadingCornerInactive.png,State=3,,Disk=1,SharedDllRefCount =0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:705]: Executing op: ComponentRegister(ComponentId={B8FEE4C3-CCDC-43EE-B736-A3380256902A},KeyPath=C:\Program Files\Safari\Safari.resources\LoadingCornerInactiveWhite.png,State=3,,Disk=1,SharedDllRef Count=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:705]: Executing op: ComponentRegister(ComponentId={F12D218D-B0C3-4D6D-82BC-12216B47C9CC},KeyPath=C:\Program Files\Safari\Safari.resources\LoadingCornerNormal.png,State=3,,Disk=1,SharedDllRefCount=0 ,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:705]: Executing op: ComponentRegister(ComponentId={6DA07203-13E6-46FD-8C93-318EF965011A},KeyPath=C:\Program Files\Safari\Safari.resources\LoadingCornerNormalWhite.png,State=3,,Disk=1,SharedDllRefCo unt=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:705]: Executing op: ComponentRegister(ComponentId={5E699330-71CF-4630-9D6F-354EBF3E4E44},KeyPath=C:\Program Files\Safari\Safari.resources\LoadingCornerPressed.png,State=3,,Disk=1,SharedDllRefCount= 0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:705]: Executing op: ComponentRegister(ComponentId={93090A6B-14E9-47FA-940A-91B437D33740},KeyPath=C:\Program Files\Safari\Safari.resources\LoadingCornerPressedWhite.png,State=3,,Disk=1,SharedDllRefC ount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:705]: Executing op: ComponentRegister(ComponentId={A1DDCC1A-8C21-11E0-917F-3AA94824019B},KeyPath=C:\Program Files\Safari\Safari.resources\macneilsen.pltsuite,State=3,,Disk=1,SharedDllRefCount=0,Bin aryType=0)
                MSI (s) (A4:F8) [11:14:58:705]: Executing op: ComponentRegister(ComponentId={A5BDE13A-8C21-11E0-9BAD-3BA94824019B},KeyPath=C:\Program Files\Safari\Safari.resources\macneilsen200.pltsuite,State=3,,Disk=1,SharedDllRefCount=0, BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:705]: Executing op: ComponentRegister(ComponentId={DD86E59C-D52A-11E0-9CA6-7B684824019B},KeyPath=C:\Program Files\Safari\Safari.resources\MediumSiteIcon~snowleopard.png,State=3,,Disk=1,SharedDllRef Count=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:705]: Executing op: ComponentRegister(ComponentId={6FE78CA0-1AAA-4221-A7D9-82AA1E1DE3DF},KeyPath=C:\Program Files\Safari\Safari.resources\MobileTest.css,State=3,,Disk=1,SharedDllRefCount=0,BinaryTy pe=0)
                MSI (s) (A4:F8) [11:14:58:705]: Executing op: ComponentRegister(ComponentId={761B9425-6469-42F4-941D-B36A139D2EF8},KeyPath=C:\Program Files\Safari\Safari.resources\MobileTest.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryTyp e=0)
                MSI (s) (A4:F8) [11:14:58:705]: Executing op: ComponentRegister(ComponentId={10D72F9D-1367-4499-A13B-77D4F2B3C1CD},KeyPath=C:\Program Files\Safari\Safari.resources\MobileTestIPad.html,State=3,,Disk=1,SharedDllRefCount=0,Bin aryType=0)
                MSI (s) (A4:F8) [11:14:58:720]: Executing op: ComponentRegister(ComponentId={907953D8-E407-4ACF-A18F-E0376C3351BA},KeyPath=C:\Program Files\Safari\Safari.resources\MobileTestIPadBack.png,State=3,,Disk=1,SharedDllRefCount=0, BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:720]: Executing op: ComponentRegister(ComponentId={C19077A4-179F-44EE-BE16-FAF4DF67808F},KeyPath=C:\Program Files\Safari\Safari.resources\MobileTestIPadForward.png,State=3,,Disk=1,SharedDllRefCount =0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:720]: Executing op: ComponentRegister(ComponentId={972FB27A-ECAD-4FFB-9E63-DCD5544748E7},KeyPath=C:\Program Files\Safari\Safari.resources\MobileTestIPadRotate.png,State=3,,Disk=1,SharedDllRefCount= 0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:720]: Executing op: ComponentRegister(ComponentId={63AD3502-F2AE-4550-97E2-BD241BC2C5B7},KeyPath=C:\Program Files\Safari\Safari.resources\MobileTestIPhone.html,State=3,,Disk=1,SharedDllRefCount=0,B inaryType=0)
                MSI (s) (A4:F8) [11:14:58:720]: Executing op: ComponentRegister(ComponentId={DE89F714-A123-4B88-A562-2F03C88F9AB5},KeyPath=C:\Program Files\Safari\Safari.resources\MobileTestIPhoneBack.png,State=3,,Disk=1,SharedDllRefCount= 0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:720]: Executing op: ComponentRegister(ComponentId={EF557813-C892-4D79-A0DE-6312DD912DB0},KeyPath=C:\Program Files\Safari\Safari.resources\MobileTestIPhoneForward.png,State=3,,Disk=1,SharedDllRefCou nt=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:720]: Executing op: ComponentRegister(ComponentId={BE644B99-091D-4E29-B141-ABF9DFF49A2D},KeyPath=C:\Program Files\Safari\Safari.resources\MobileTestIPhoneRetina.html,State=3,,Disk=1,SharedDllRefCou nt=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:720]: Executing op: ComponentRegister(ComponentId={3257566C-14E3-40F1-ACCC-92DB20FC7A88},KeyPath=C:\Program Files\Safari\Safari.resources\MobileTestIPhoneRetinaBack.png,State=3,,Disk=1,SharedDllRef Count=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:720]: Executing op: ComponentRegister(ComponentId={D60AFC57-E834-4485-9550-186ACABACC13},KeyPath=C:\Program Files\Safari\Safari.resources\MobileTestIPhoneRetinaForward.png,State=3,,Disk=1,SharedDll RefCount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:720]: Executing op: ComponentRegister(ComponentId={1B8D0ADE-389E-4169-A11D-1850A4E7ECC6},KeyPath=C:\Program Files\Safari\Safari.resources\MobileTestIPhoneRetinaRotate.png,State=3,,Disk=1,SharedDllR efCount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:720]: Executing op: ComponentRegister(ComponentId={CC5A2C4F-02BD-4B7E-8B38-221DCE7A6694},KeyPath=C:\Program Files\Safari\Safari.resources\MobileTestIPhoneRotate.png,State=3,,Disk=1,SharedDllRefCoun t=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:720]: Executing op: ComponentRegister(ComponentId={AF25FECE-8C21-11E0-9355-68A94824019B},KeyPath=C:\Program Files\Safari\Safari.resources\nesting.pltsuite,State=3,,Disk=1,SharedDllRefCount=0,Binary Type=0)
                MSI (s) (A4:F8) [11:14:58:720]: Executing op: ComponentRegister(ComponentId={F878EF3F-C410-4689-B0AB-43B772285F62},KeyPath=C:\Program Files\Safari\Safari.resources\NetworkDiagnosticsErrorPage.html,State=3,,Disk=1,SharedDllR efCount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:720]: Executing op: ComponentRegister(ComponentId={A4285CFA-A3B3-40F1-8F27-01236806A49D},KeyPath=C:\Program Files\Safari\Safari.resources\NewBookmark.html,State=3,,Disk=1,SharedDllRefCount=0,Binary Type=0)
                MSI (s) (A4:F8) [11:14:58:720]: Executing op: ComponentRegister(ComponentId={01045777-FDAA-4F9E-90AE-41A17B1CB528},KeyPath=C:\Program Files\Safari\Safari.resources\page-load-errors.css,State=3,,Disk=1,SharedDllRefCount=0,Bi naryType=0)
                MSI (s) (A4:F8) [11:14:58:720]: Executing op: ComponentRegister(ComponentId={DCDFAFFB-A147-4682-A586-F4557ADF5E88},KeyPath=C:\Program Files\Safari\Safari.resources\PageIcon.png,State=3,,Disk=1,SharedDllRefCount=0,BinaryType =0)
                MSI (s) (A4:F8) [11:14:58:720]: Executing op: ComponentRegister(ComponentId={692B47DB-4239-4857-9BA6-4A2D30943824},KeyPath=C:\Program Files\Safari\Safari.resources\PhishingAlert.html,State=3,,Disk=1,SharedDllRefCount=0,Bina ryType=0)
                MSI (s) (A4:F8) [11:14:58:720]: Executing op: ComponentRegister(ComponentId={16063508-BE20-4635-A0EC-D2233C7E56E3},KeyPath=C:\Program Files\Safari\Safari.resources\PhishingAlertBase.png,State=3,,Disk=1,SharedDllRefCount=0,B inaryType=0)
                MSI (s) (A4:F8) [11:14:58:720]: Executing op: ComponentRegister(ComponentId={56F0D596-00D4-4A24-AB58-DED8AAF1E52C},KeyPath=C:\Program Files\Safari\Safari.resources\PhishingAlertTitlebar.png,State=3,,Disk=1,SharedDllRefCount =0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:720]: Executing op: ComponentRegister(ComponentId={B3689D52-8C21-11E0-B8EE-69A94824019B},KeyPath=C:\Program Files\Safari\Safari.resources\plugin-test.pltsuite,State=3,,Disk=1,SharedDllRefCount=0,Bi naryType=0)
                MSI (s) (A4:F8) [11:14:58:720]: Executing op: ComponentRegister(ComponentId={7BEE03C9-6365-4BD5-BE1E-6F682FA8EF89},KeyPath=C:\Program Files\Safari\Safari.resources\Preferences.win.css,State=3,,Disk=1,SharedDllRefCount=0,Bin aryType=0)
                MSI (s) (A4:F8) [11:14:58:720]: Executing op: ComponentRegister(ComponentId={9DBA1D37-62E7-4E57-AA51-2191F00BF338},KeyPath=C:\Program Files\Safari\Safari.resources\PreferencesView.css,State=3,,Disk=1,SharedDllRefCount=0,Bin aryType=0)
                MSI (s) (A4:F8) [11:14:58:720]: Executing op: ComponentRegister(ComponentId={CAD5556E-4F0C-4E59-AD9C-6A39E6F1EEA7},KeyPath=C:\Program Files\Safari\Safari.resources\PrivacyView.css,State=3,,Disk=1,SharedDllRefCount=0,BinaryT ype=0)
                MSI (s) (A4:F8) [11:14:58:720]: Executing op: ComponentRegister(ComponentId={66F305C4-951F-4E04-B6F5-75556D0108AA},KeyPath=C:\Program Files\Safari\Safari.resources\PrivacyView.html,State=3,,Disk=1,SharedDllRefCount=0,Binary Type=0)
                MSI (s) (A4:F8) [11:14:58:720]: Executing op: ComponentRegister(ComponentId={A51EDC7E-5837-4E08-AD15-C9BBDB13C4B6},KeyPath=C:\Program Files\Safari\Safari.resources\PrivateBrowsingButtonCapLeft.png,State=3,,Disk=1,SharedDllR efCount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:736]: Executing op: ComponentRegister(ComponentId={5FFB4C9D-084B-422C-B801-B0AB056FF26B},KeyPath=C:\Program Files\Safari\Safari.resources\PrivateBrowsingButtonCapLeftPressed.png,State=3,,Disk=1,Sha redDllRefCount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:736]: Executing op: ComponentRegister(ComponentId={5EC3BA57-613F-4BCE-ADEF-2EA2648F2A4A},KeyPath=C:\Program Files\Safari\Safari.resources\PrivateBrowsingButtonCapRight.png,State=3,,Disk=1,SharedDll RefCount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:736]: Executing op: ComponentRegister(ComponentId={22D8EF31-4D0D-484D-A46C-5FEB3BE65D5E},KeyPath=C:\Program Files\Safari\Safari.resources\PrivateBrowsingButtonCapRightPressed.png,State=3,,Disk=1,Sh aredDllRefCount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:736]: Executing op: ComponentRegister(ComponentId={01F5964F-E03D-4D6C-92FA-75DFEFF5F1A0},KeyPath=C:\Program Files\Safari\Safari.resources\PrivateBrowsingButtonStretch.png,State=3,,Disk=1,SharedDllR efCount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:736]: Executing op: ComponentRegister(ComponentId={50A9A42B-3FB7-43C1-840B-5DFF20791B97},KeyPath=C:\Program Files\Safari\Safari.resources\PrivateBrowsingButtonStretchPressed.png,State=3,,Disk=1,Sha redDllRefCount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:736]: Executing op: ComponentRegister(ComponentId={58D4FA5A-5E2C-42B8-AADA-F2AF79B59CA1},KeyPath=C:\Program Files\Safari\Safari.resources\Reader.html,State=3,,Disk=1,SharedDllRefCount=0,BinaryType= 0)
                MSI (s) (A4:F8) [11:14:58:736]: Executing op: ComponentRegister(ComponentId={3FB65C46-A3D7-425B-AFF1-95BF71AFB9C6},KeyPath=C:\Program Files\Safari\Safari.resources\ReaderDropShadow.png,State=3,,Disk=1,SharedDllRefCount=0,Bi naryType=0)
                MSI (s) (A4:F8) [11:14:58:736]: Executing op: ComponentRegister(ComponentId={A780A40B-750E-4B97-B110-54FA0A1B49F0},KeyPath=C:\Program Files\Safari\Safari.resources\ReaderDropShadow@2x.png,State=3,,Disk=1,SharedDllRefCount=0 ,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:736]: Executing op: ComponentRegister(ComponentId={793F9774-CF6E-4335-8B70-F3729DDDE493},KeyPath=C:\Program Files\Safari\Safari.resources\ReaderFadeBottom.png,State=3,,Disk=1,SharedDllRefCount=0,Bi naryType=0)
                MSI (s) (A4:F8) [11:14:58:736]: Executing op: ComponentRegister(ComponentId={F6C0F0E7-456F-48B1-B5CA-9CC9DC64D7F6},KeyPath=C:\Program Files\Safari\Safari.resources\ReaderFadeBottom@2x.png,State=3,,Disk=1,SharedDllRefCount=0 ,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:736]: Executing op: ComponentRegister(ComponentId={40362232-A9D1-4637-B2C5-23EC3A8670D6},KeyPath=C:\Program Files\Safari\Safari.resources\ReaderFadeTop.png,State=3,,Disk=1,SharedDllRefCount=0,Binar yType=0)
                MSI (s) (A4:F8) [11:14:58:736]: Executing op: ComponentRegister(ComponentId={D01FDBC4-B373-4E20-B3E2-ABFC1ED903B8},KeyPath=C:\Program Files\Safari\Safari.resources\ReaderFadeTop@2x.png,State=3,,Disk=1,SharedDllRefCount=0,Bi naryType=0)
                MSI (s) (A4:F8) [11:14:58:736]: Executing op: ComponentRegister(ComponentId={9CBCB2C8-0F22-497D-8E4C-82E918418AAE},KeyPath=C:\Program Files\Safari\Safari.resources\ReaderGrowBox.png,State=3,,Disk=1,SharedDllRefCount=0,Binar yType=0)
                MSI (s) (A4:F8) [11:14:58:736]: Executing op: ComponentRegister(ComponentId={CB8F5715-548A-482F-8C88-22C8C3459DA7},KeyPath=C:\Program Files\Safari\Safari.resources\ReaderHUDCloseActive.png,State=3,,Disk=1,SharedDllRefCount= 0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:736]: Executing op: ComponentRegister(ComponentId={8BE5DF6A-0539-4DDB-BBC8-65A6675659EF},KeyPath=C:\Program Files\Safari\Safari.resources\ReaderHUDCloseActive@2x.png,State=3,,Disk=1,SharedDllRefCou nt=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:736]: Executing op: ComponentRegister(ComponentId={8AE21238-B7AA-42E9-85D7-1F89192C867D},KeyPath=C:\Program Files\Safari\Safari.resources\ReaderHUDCloseInactive.png,State=3,,Disk=1,SharedDllRefCoun t=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:736]: Executing op: ComponentRegister(ComponentId={EA117C66-DBAD-416E-8973-B2198E3B1505},KeyPath=C:\Program Files\Safari\Safari.resources\ReaderHUDCloseInactive@2x.png,State=3,,Disk=1,SharedDllRefC ount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:736]: Executing op: ComponentRegister(ComponentId={24E6832B-AF7A-4930-9F4C-72692590F633},KeyPath=C:\Program Files\Safari\Safari.resources\ReaderHUDMailContentsActive.png,State=3,,Disk=1,SharedDllRe fCount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:736]: Executing op: ComponentRegister(ComponentId={5FF26793-E896-4315-9E7F-DDFD049D737A},KeyPath=C:\Program Files\Safari\Safari.resources\ReaderHUDMailContentsActive@2x.png,State=3,,Disk=1,SharedDl lRefCount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:736]: Executing op: ComponentRegister(ComponentId={81030069-1051-4A52-B060-02EE232E350F},KeyPath=C:\Program Files\Safari\Safari.resources\ReaderHUDMailContentsInactive.png,State=3,,Disk=1,SharedDll RefCount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:736]: Executing op: ComponentRegister(ComponentId={DC16907C-308D-444D-AD40-16147C5DE203},KeyPath=C:\Program Files\Safari\Safari.resources\ReaderHUDMailContentsInactive@2x.png,State=3,,Disk=1,Shared DllRefCount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:736]: Executing op: ComponentRegister(ComponentId={53779097-2584-49F4-9C15-0C0B494CD251},KeyPath=C:\Program Files\Safari\Safari.resources\ReaderHUDPrintActive.png,State=3,,Disk=1,SharedDllRefCount= 0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:736]: Executing op: ComponentRegister(ComponentId={C9497C55-C6CD-487E-8A91-DA76C1349966},KeyPath=C:\Program Files\Safari\Safari.resources\ReaderHUDPrintActive@2x.png,State=3,,Disk=1,SharedDllRefCou nt=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:736]: Executing op: ComponentRegister(ComponentId={F2BAEB9F-3306-47FE-9335-916C70A62192},KeyPath=C:\Program Files\Safari\Safari.resources\ReaderHUDPrintInactive.png,State=3,,Disk=1,SharedDllRefCoun t=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:736]: Executing op: ComponentRegister(ComponentId={955009A0-F001-43FE-8BCC-D59577B5C0F0},KeyPath=C:\Program Files\Safari\Safari.resources\ReaderHUDPrintInactive@2x.png,State=3,,Disk=1,SharedDllRefC ount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:752]: Executing op: ComponentRegister(ComponentId={630991CC-9593-4213-AD1A-A8DA15D732F1},KeyPath=C:\Program Files\Safari\Safari.resources\ReaderHUDZoomInActive.png,State=3,,Disk=1,SharedDllRefCount =0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:752]: Executing op: ComponentRegister(ComponentId={B362D9BE-E691-4DB2-A625-54F58DDD5BFB},KeyPath=C:\Program Files\Safari\Safari.resources\ReaderHUDZoomInActive@2x.png,State=3,,Disk=1,SharedDllRefCo unt=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:752]: Executing op: ComponentRegister(ComponentId={44282104-8C29-442C-8881-EED4E695DC0E},KeyPath=C:\Program Files\Safari\Safari.resources\ReaderHUDZoomInInactive.png,State=3,,Disk=1,SharedDllRefCou nt=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:752]: Executing op: ComponentRegister(ComponentId={7022E2C0-FEB0-41CA-9435-715DA7D8B3E3},KeyPath=C:\Program Files\Safari\Safari.resources\ReaderHUDZoomInInactive@2x.png,State=3,,Disk=1,SharedDllRef Count=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:752]: Executing op: ComponentRegister(ComponentId={2DE34A7B-4465-4CF0-A2BD-C15CFBBA21FE},KeyPath=C:\Program Files\Safari\Safari.resources\ReaderHUDZoomOutActive.png,State=3,,Disk=1,SharedDllRefCoun t=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:752]: Executing op: ComponentRegister(ComponentId={D898A874-E6C7-4C78-9346-E305371FCDD5},KeyPath=C:\Program Files\Safari\Safari.resources\ReaderHUDZoomOutActive@2x.png,State=3,,Disk=1,SharedDllRefC ount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:752]: Executing op: ComponentRegister(ComponentId={CCC16784-827F-4AFE-BE30-0DC2251D54A3},KeyPath=C:\Program Files\Safari\Safari.resources\ReaderHUDZoomOutInactive.png,State=3,,Disk=1,SharedDllRefCo unt=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:752]: Executing op: ComponentRegister(ComponentId={F04FDB22-AD13-4681-B2D7-646E275A2A7C},KeyPath=C:\Program Files\Safari\Safari.resources\ReaderHUDZoomOutInactive@2x.png,State=3,,Disk=1,SharedDllRe fCount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:752]: Executing op: ComponentRegister(ComponentId={52571197-A03C-453E-A9EE-8CCC029D17E2},KeyPath=C:\Program Files\Safari\Safari.resources\ReaderSpinner.png,State=3,,Disk=1,SharedDllRefCount=0,Binar yType=0)
                MSI (s) (A4:F8) [11:14:58:752]: Executing op: ComponentRegister(ComponentId={D0C0B793-00B1-4A09-9745-863846D61153},KeyPath=C:\Program Files\Safari\Safari.resources\ReaderThumb.png,State=3,,Disk=1,SharedDllRefCount=0,BinaryT ype=0)
                MSI (s) (A4:F8) [11:14:58:752]: Executing op: ComponentRegister(ComponentId={2DA4FBED-C7E2-4F4B-83BF-FB890B37E9FA},KeyPath=C:\Program Files\Safari\Safari.resources\ReaderThumb@2x.png,State=3,,Disk=1,SharedDllRefCount=0,Bina ryType=0)
                MSI (s) (A4:F8) [11:14:58:752]: Executing op: ComponentRegister(ComponentId={8D94B779-1CB6-416B-BB83-A7360ED9FB78},KeyPath=C:\Program Files\Safari\Safari.resources\ReaderThumbFaded.png,State=3,,Disk=1,SharedDllRefCount=0,Bi naryType=0)
                MSI (s) (A4:F8) [11:14:58:752]: Executing op: ComponentRegister(ComponentId={6E61A96F-C537-4B99-9FE7-290D7CF2A341},KeyPath=C:\Program Files\Safari\Safari.resources\ReaderTrack.png,State=3,,Disk=1,SharedDllRefCount=0,BinaryT ype=0)
                MSI (s) (A4:F8) [11:14:58:752]: Executing op: ComponentRegister(ComponentId={8969FF03-45D3-4009-AD4A-22156FDD832C},KeyPath=C:\Program Files\Safari\Safari.resources\ReaderTrack@2x.png,State=3,,Disk=1,SharedDllRefCount=0,Bina ryType=0)
                MSI (s) (A4:F8) [11:14:58:752]: Executing op: ComponentRegister(ComponentId={B74AE4E8-8C21-11E0-A8C8-6DA94824019B},KeyPath=C:\Program Files\Safari\Safari.resources\ReadingList-AddButtonGlyph.png,State=3,,Disk=1,SharedDllRef Count=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:752]: Executing op: ComponentRegister(ComponentId={BC35A79A-8C21-11E0-9199-6FA94824019B},KeyPath=C:\Program Files\Safari\Safari.resources\ReadingList-BGLinen.png,State=3,,Disk=1,SharedDllRefCount=0 ,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:752]: Executing op: ComponentRegister(ComponentId={C1024B20-8C21-11E0-B0CA-73A94824019B},KeyPath=C:\Program Files\Safari\Safari.resources\ReadingList-BGSideShadow.png,State=3,,Disk=1,SharedDllRefCo unt=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:752]: Executing op: ComponentRegister(ComponentId={C52904E6-8C21-11E0-8442-75A94824019B},KeyPath=C:\Program Files\Safari\Safari.resources\ReadingList-CompThumb.png,State=3,,Disk=1,SharedDllRefCount =0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:752]: Executing op: ComponentRegister(ComponentId={C9A46092-8C21-11E0-BCD1-78A94824019B},KeyPath=C:\Program Files\Safari\Safari.resources\ReadingList-CompTrack.png,State=3,,Disk=1,SharedDllRefCount =0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:752]: Executing op: ComponentRegister(ComponentId={CDEB7532-8C21-11E0-B607-8AA94824019B},KeyPath=C:\Program Files\Safari\Safari.resources\ReadingList-DeleteButton.png,State=3,,Disk=1,SharedDllRefCo unt=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:752]: Executing op: ComponentRegister(ComponentId={D7E6FE44-8C21-11E0-AD1A-90A94824019B},KeyPath=C:\Program Files\Safari\Safari.resources\ReadingList-DeleteButtonPressed.png,State=3,,Disk=1,SharedD llRefCount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:752]: Executing op: ComponentRegister(ComponentId={DD7D6C94-8C21-11E0-BB9F-95A94824019B},KeyPath=C:\Program Files\Safari\Safari.resources\ReadingList-DeleteButtonSelection.png,State=3,,Disk=1,Share dDllRefCount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:752]: Executing op: ComponentRegister(ComponentId={E19703C6-8C21-11E0-A66D-96A94824019B},KeyPath=C:\Program Files\Safari\Safari.resources\ReadingList-DeleteButtonSelectionPressed.png,State=3,,Disk= 1,SharedDllRefCount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:752]: Executing op: ComponentRegister(ComponentId={E5676DCE-8C21-11E0-A520-9BA94824019B},KeyPath=C:\Program Files\Safari\Safari.resources\ReadingList-FavIconMask-36.png,State=3,,Disk=1,SharedDllRef Count=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:752]: Executing op: ComponentRegister(ComponentId={EC6B3632-8C21-11E0-BB9B-A1A94824019B},KeyPath=C:\Program Files\Safari\Safari.resources\ReadingList-FavIconMask.png,State=3,,Disk=1,SharedDllRefCou nt=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:767]: Executing op: ComponentRegister(ComponentId={F066CB84-8C21-11E0-BAF1-ADA94824019B},KeyPath=C:\Program Files\Safari\Safari.resources\ReadingList-FavIconShadow-36.png,State=3,,Disk=1,SharedDllR efCount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:767]: Executing op: ComponentRegister(ComponentId={F4B0B2EA-8C21-11E0-A923-B1A94824019B},KeyPath=C:\Program Files\Safari\Safari.resources\ReadingList-FavIconShadow.png,State=3,,Disk=1,SharedDllRefC ount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:767]: Executing op: ComponentRegister(ComponentId={F858070E-8C21-11E0-BE89-B2A94824019B},KeyPath=C:\Program Files\Safari\Safari.resources\ReadingList-Glasses.pdf,State=3,,Disk=1,SharedDllRefCount=0 ,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:767]: Executing op: ComponentRegister(ComponentId={FC64712A-8C21-11E0-B374-B3A94824019B},KeyPath=C:\Program Files\Safari\Safari.resources\ReadingList-IconLarge.png,State=3,,Disk=1,SharedDllRefCount =0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:767]: Executing op: ComponentRegister(ComponentId={00F0A75E-8C22-11E0-B0E2-B8A94824019B},KeyPath=C:\Program Files\Safari\Safari.resources\ReadingList-PushButtonActiveBorderImage.png,State=3,,Disk=1 ,SharedDllRefCount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:767]: Executing op: ComponentRegister(ComponentId={0553D4F6-8C22-11E0-99F6-B9A94824019B},KeyPath=C:\Program Files\Safari\Safari.resources\ReadingList-PushButtonPressedBorderImage.png,State=3,,Disk= 1,SharedDllRefCount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:767]: Executing op: ComponentRegister(ComponentId={0942F182-8C22-11E0-A316-C7A94824019B},KeyPath=C:\Program Files\Safari\Safari.resources\ReadingList-RowDividers.png,State=3,,Disk=1,SharedDllRefCou nt=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:767]: Executing op: ComponentRegister(ComponentId={0E6258F6-8C22-11E0-8F71-CEA94824019B},KeyPath=C:\Program Files\Safari\Safari.resources\ReadingList-SegmentButtonSelectedBorderImage.png,State=3,,D isk=1,SharedDllRefCount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:767]: Executing op: ComponentRegister(ComponentId={14484ABE-8C22-11E0-BB55-DEA94824019B},KeyPath=C:\Program Files\Safari\Safari.resources\ReadingList-SegmentButtonSelectedPressedBorderImage.png,Sta te=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:767]: Executing op: ComponentRegister(ComponentId={1964C572-8C22-11E0-A91D-E2A94824019B},KeyPath=C:\Program Files\Safari\Safari.resources\ReadingList-SegmentButtonSeparator.png,State=3,,Disk=1,Shar edDllRefCount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:767]: Executing op: ComponentRegister(ComponentId={1DCAE54C-8C22-11E0-88D5-E5A94824019B},KeyPath=C:\Program Files\Safari\Safari.resources\ReadingList-Selection.png,State=3,,Disk=1,SharedDllRefCount =0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:767]: Executing op: ComponentRegister(ComponentId={21EDFD44-8C22-11E0-9164-E9A94824019B},KeyPath=C:\Program Files\Safari\Safari.resources\ReadingList-ShiftClickAnimatedIcon.png,State=3,,Disk=1,Shar edDllRefCount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:767]: Executing op: ComponentRegister(ComponentId={26169B56-8C22-11E0-AB24-EAA94824019B},KeyPath=C:\Program Files\Safari\Safari.resources\ReadingList-TopBar.png,State=3,,Disk=1,SharedDllRefCount=0, BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:767]: Executing op: ComponentRegister(ComponentId={06C3CA34-851C-44E8-B4A9-39A587F408F6},KeyPath=C:\Program Files\Safari\Safari.resources\ReadingList.html,State=3,,Disk=1,SharedDllRefCount=0,Binary Type=0)
                MSI (s) (A4:F8) [11:14:58:767]: Executing op: ComponentRegister(ComponentId={3BE18B99-E325-4CB2-A341-6285848C35D7},KeyPath=C:\Program Files\Safari\Safari.resources\ReadingList.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryTy pe=0)
                MSI (s) (A4:F8) [11:14:58:767]: Executing op: ComponentRegister(ComponentId={17F29A6E-AFDA-4FBF-9363-8E4BFDEA9FF8},KeyPath=C:\Program Files\Safari\Safari.resources\ResetDialog.html,State=3,,Disk=1,SharedDllRefCount=0,Binary Type=0)
                MSI (s) (A4:F8) [11:14:58:767]: Executing op: ComponentRegister(ComponentId={81DF4C86-7B6A-4630-8A49-39F960A97826},KeyPath=C:\Program Files\Safari\Safari.resources\RSSPreferences.html,State=3,,Disk=1,SharedDllRefCount=0,Bin aryType=0)
                MSI (s) (A4:F8) [11:14:58:767]: Executing op: ComponentRegister(ComponentId={7E2A50DD-E74C-4C4C-98F0-D764A44248D7},KeyPath=C:\Program Files\Safari\Safari.resources\Safari.css,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0 )
                MSI (s) (A4:F8) [11:14:58:767]: Executing op: ComponentRegister(ComponentId={204315EE-ABDE-4871-AC02-BF38617028EA},KeyPath=C:\Program Files\Safari\Safari.resources\SafariAlert.png,State=3,,Disk=1,SharedDllRefCount=0,BinaryT ype=0)
                MSI (s) (A4:F8) [11:14:58:767]: Executing op: ComponentRegister(ComponentId={AAD0E0E4-D907-11DC-ADF1-5D7F55D89593},KeyPath=C:\Program Files\Safari\Safari.resources\SafariRegistry.dll,State=3,,Disk=1,SharedDllRefCount=0,Bina ryType=0)
                MSI (s) (A4:F8) [11:14:58:767]: Executing op: ComponentRegister(ComponentId={315E9914-8C22-11E0-8925-EEA94824019B},KeyPath=C:\Program Files\Safari\Safari.resources\SafeAutoFillConfirmationPopover.html,State=3,,Disk=1,Shared DllRefCount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:767]: Executing op: ComponentRegister(ComponentId={EED9EABE-8C45-4223-9FC7-830598670A13},KeyPath=C:\Program Files\Safari\Safari.resources\SafeBrowsingUnavailable.png,State=3,,Disk=1,SharedDllRefCou nt=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:767]: Executing op: ComponentRegister(ComponentId={33A37663-526F-4E3C-9303-7FF3408348F7},KeyPath=C:\Program Files\Safari\Safari.resources\ScopeSelectCombined.png,State=3,,Disk=1,SharedDllRefCount=0 ,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:767]: Executing op: ComponentRegister(ComponentId={88B42668-A0EB-4FD5-9F41-C5370E287D05},KeyPath=C:\Program Files\Safari\Safari.resources\ScopeSelectCombinedPressed.png,State=3,,Disk=1,SharedDllRef Count=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:767]: Executing op: ComponentRegister(ComponentId={3965F97B-9EEB-48AF-8742-19F96B2B0D1C},KeyPath=C:\Program Files\Safari\Safari.resources\SearchField.html,State=3,,Disk=1,SharedDllRefCount=0,Binary Type=0)
                MSI (s) (A4:F8) [11:14:58:783]: Executing op: ComponentRegister(ComponentId={E74C459A-1089-4CE2-844D-0CF16392C8D8},KeyPath=C:\Program Files\Safari\Safari.resources\SecurityAlert.png,State=3,,Disk=1,SharedDllRefCount=0,Binar yType=0)
                MSI (s) (A4:F8) [11:14:58:783]: Executing op: ComponentRegister(ComponentId={801A053B-3359-4202-88D5-1D2B18E22A9D},KeyPath=C:\Program Files\Safari\Safari.resources\SecurityPreferences.html,State=3,,Disk=1,SharedDllRefCount= 0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:783]: Executing op: ComponentRegister(ComponentId={83D3AA09-AB1C-4CD1-A94E-9A2FE00ABD58},KeyPath=C:\Program Files\Safari\Safari.resources\ServerNotFoundErrorPage.html,State=3,,Disk=1,SharedDllRefCo unt=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:783]: Executing op: ComponentRegister(ComponentId={E2E8BD26-605E-4B02-9485-CFD4241382D5},KeyPath=C:\Program Files\Safari\Safari.resources\ShowReaderButtonCapLeft.png,State=3,,Disk=1,SharedDllRefCou nt=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:783]: Executing op: ComponentRegister(ComponentId={AFB2D65E-C6A9-4F56-AE95-9F4F09221E85},KeyPath=C:\Program Files\Safari\Safari.resources\ShowReaderButtonCapLeftPressed.png,State=3,,Disk=1,SharedDl lRefCount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:783]: Executing op: ComponentRegister(ComponentId={85B0BA36-CEAB-4A3B-B931-917A6FF70EB7},KeyPath=C:\Program Files\Safari\Safari.resources\ShowReaderButtonCapRight.png,State=3,,Disk=1,SharedDllRefCo unt=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:783]: Executing op: ComponentRegister(ComponentId={102B73C6-8AE4-491F-8A18-3BC056603E15},KeyPath=C:\Program Files\Safari\Safari.resources\ShowReaderButtonCapRightPressed.png,State=3,,Disk=1,SharedD llRefCount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:783]: Executing op: ComponentRegister(ComponentId={82108AC7-37FF-4AE5-B0E8-B6BC97DE1C09},KeyPath=C:\Program Files\Safari\Safari.resources\ShowReaderButtonStretch.png,State=3,,Disk=1,SharedDllRefCou nt=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:783]: Executing op: ComponentRegister(ComponentId={4896E674-9D6D-45D2-B2A5-A7803145FCB7},KeyPath=C:\Program Files\Safari\Safari.resources\ShowReaderButtonStretchPressed.png,State=3,,Disk=1,SharedDl lRefCount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:783]: Executing op: ComponentRegister(ComponentId={87755418-18BF-4339-A58C-80662D4F2594},KeyPath=C:\Program Files\Safari\Safari.resources\SlidingAlert.html,State=3,,Disk=1,SharedDllRefCount=0,Binar yType=0)
                MSI (s) (A4:F8) [11:14:58:783]: Executing op: ComponentRegister(ComponentId={C844D659-6365-4E2E-8D11-A5DC14A7347B},KeyPath=C:\Program Files\Safari\Safari.resources\SnapshotPlaceholderCompass.png,State=3,,Disk=1,SharedDllRef Count=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:783]: Executing op: ComponentRegister(ComponentId={0580A261-6163-40B9-90C9-9EA74C7D3C7A},KeyPath=C:\Program Files\Safari\Safari.resources\SnapshotPlaceholderGradient.png,State=3,,Disk=1,SharedDllRe fCount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:783]: Executing op: ComponentRegister(ComponentId={287D0810-9141-442B-B93E-C542DF5EB581},KeyPath=C:\Program Files\Safari\Safari.resources\SnapshotPlaceholderPadlock.png,State=3,,Disk=1,SharedDllRef Count=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:783]: Executing op: ComponentRegister(ComponentId={EDB85FBD-F5F9-4C84-9341-1CFC8FE477C9},KeyPath=C:\Program Files\Safari\Safari.resources\SoftwareUpdateIcon.png,State=3,,Disk=1,SharedDllRefCount=0, BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:783]: Executing op: ComponentRegister(ComponentId={7A12BCC5-BA5F-4AED-944D-95B93D59884B},KeyPath=C:\Program Files\Safari\Safari.resources\Spelling.html,State=3,,Disk=1,SharedDllRefCount=0,BinaryTyp e=0)
                MSI (s) (A4:F8) [11:14:58:783]: Executing op: ComponentRegister(ComponentId={39DC192C-8C22-11E0-8A86-02AA4824019B},KeyPath=C:\Program Files\Safari\Safari.resources\ssl-base.pltsuite,State=3,,Disk=1,SharedDllRefCount=0,Binar yType=0)
                MSI (s) (A4:F8) [11:14:58:783]: Executing op: ComponentRegister(ComponentId={A10EF1C1-D2EF-45EE-A3D8-4A916FCA6CDD},KeyPath=C:\Program Files\Safari\Safari.resources\StandardErrorPage.html,State=3,,Disk=1,SharedDllRefCount=0, BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:783]: Executing op: ComponentRegister(ComponentId={18DF5CD1-085F-4AA9-A6BD-6142A22B6F0C},KeyPath=C:\Program Files\Safari\Safari.resources\Syndication.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryTy pe=0)
                MSI (s) (A4:F8) [11:14:58:783]: Executing op: ComponentRegister(ComponentId={1B6F8AEA-1549-45F9-B2FB-4125AC351ED7},KeyPath=C:\Program Files\Safari\Safari.resources\tabActiveFill.png,State=3,,Disk=1,SharedDllRefCount=0,Binar yType=0)
                MSI (s) (A4:F8) [11:14:58:783]: Executing op: ComponentRegister(ComponentId={0322BE49-B479-441D-91C0-99588BFE0891},KeyPath=C:\Program Files\Safari\Safari.resources\tabActiveLeft.png,State=3,,Disk=1,SharedDllRefCount=0,Binar yType=0)
                MSI (s) (A4:F8) [11:14:58:783]: Executing op: ComponentRegister(ComponentId={47DF6188-25B7-4770-AE14-368C783D264A},KeyPath=C:\Program Files\Safari\Safari.resources\tabActiveMask.png,State=3,,Disk=1,SharedDllRefCount=0,Binar yType=0)
                MSI (s) (A4:F8) [11:14:58:783]: Executing op: ComponentRegister(ComponentId={35F89926-ADDF-4BAA-898C-6A2712C59101},KeyPath=C:\Program Files\Safari\Safari.resources\tabActiveRight.png,State=3,,Disk=1,SharedDllRefCount=0,Bina ryType=0)
                MSI (s) (A4:F8) [11:14:58:783]: Executing op: ComponentRegister(ComponentId={3BBDBF9F-C523-4ED6-9B2C-5E7993123CD4},KeyPath=C:\Program Files\Safari\Safari.resources\tabBarFill.png,State=3,,Disk=1,SharedDllRefCount=0,BinaryTy pe=0)
                MSI (s) (A4:F8) [11:14:58:783]: Executing op: ComponentRegister(ComponentId={B732852C-28C8-4C75-B5FB-6B7F7C65573C},KeyPath=C:\Program Files\Safari\Safari.resources\tabDragLeft.png,State=3,,Disk=1,SharedDllRefCount=0,BinaryT ype=0)
                MSI (s) (A4:F8) [11:14:58:783]: Executing op: ComponentRegister(ComponentId={3647BA7C-8011-4072-A40D-DFE0E84AECC3},KeyPath=C:\Program Files\Safari\Safari.resources\tabDragRight.png,State=3,,Disk=1,SharedDllRefCount=0,Binary Type=0)
                MSI (s) (A4:F8) [11:14:58:798]: Executing op: ComponentRegister(ComponentId={103886CC-EBC3-4681-995F-B83A1B8DA2CE},KeyPath=C:\Program Files\Safari\Safari.resources\tabInactiveLeft.png,State=3,,Disk=1,SharedDllRefCount=0,Bin aryType=0)
                MSI (s) (A4:F8) [11:14:58:798]: Executing op: ComponentRegister(ComponentId={CFE78CF9-8F6A-4DB9-B620-217E08CB6A02},KeyPath=C:\Program Files\Safari\Safari.resources\tabInactiveRight.png,State=3,,Disk=1,SharedDllRefCount=0,Bi naryType=0)
                MSI (s) (A4:F8) [11:14:58:798]: Executing op: ComponentRegister(ComponentId={A6D49FF0-CFB2-4853-84DA-9D52183EAEAF},KeyPath=C:\Program Files\Safari\Safari.resources\TabsPreferences.html,State=3,,Disk=1,SharedDllRefCount=0,Bi naryType=0)
                MSI (s) (A4:F8) [11:14:58:798]: Executing op: ComponentRegister(ComponentId={CA75AE0B-511A-43B7-B8EF-9711AF0344FF},KeyPath=C:\Program Files\Safari\Safari.resources\ToolbarBookmarksBarTemplate.pdf,State=3,,Disk=1,SharedDllRe fCount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:798]: Executing op: ComponentRegister(ComponentId={D357C345-8CF5-4E79-BDF7-80C9F7D2AC21},KeyPath=C:\Program Files\Safari\Safari.resources\ToolbarBookmarksTemplate.pdf,State=3,,Disk=1,SharedDllRefCo unt=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:798]: Executing op: ComponentRegister(ComponentId={92570BF8-607F-4E52-8E7B-E798A99BE2A9},KeyPath=C:\Program Files\Safari\Safari.resources\ToolbarDownloadsTemplate.pdf,State=3,,Disk=1,SharedDllRefCo unt=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:798]: Executing op: ComponentRegister(ComponentId={89C37311-B7AE-49F1-844E-4188390643D9},KeyPath=C:\Program Files\Safari\Safari.resources\ToolbarEmailTemplate.pdf,State=3,,Disk=1,SharedDllRefCount= 0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:798]: Executing op: ComponentRegister(ComponentId={C7381645-0511-4C61-8E78-73B24CAD7030},KeyPath=C:\Program Files\Safari\Safari.resources\ToolbarHistoryTemplate.pdf,State=3,,Disk=1,SharedDllRefCoun t=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:798]: Executing op: ComponentRegister(ComponentId={2A98540B-A550-4C73-8B8A-9DA791BB3793},KeyPath=C:\Program Files\Safari\Safari.resources\ToolbarNewTabTemplate.pdf,State=3,,Disk=1,SharedDllRefCount =0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:798]: Executing op: ComponentRegister(ComponentId={A7AB30A6-3928-41FF-81FB-1EC1661236A7},KeyPath=C:\Program Files\Safari\Safari.resources\ToolbarTopSitesTemplate.pdf,State=3,,Disk=1,SharedDllRefCou nt=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:798]: Executing op: ComponentRegister(ComponentId={B67C3738-BC23-4148-A6D3-C662865C9684},KeyPath=C:\Program Files\Safari\Safari.resources\ToolbarWebInspectorTemplate.pdf,State=3,,Disk=1,SharedDllRe fCount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:798]: Executing op: ComponentRegister(ComponentId={0BC63267-3816-4D0B-A23A-A12982DAC37B},KeyPath=C:\Program Files\Safari\Safari.resources\TopLevelDomains.plist,State=3,,Disk=1,SharedDllRefCount=0,B inaryType=0)
                MSI (s) (A4:F8) [11:14:58:798]: Executing op: ComponentRegister(ComponentId={87B39B8A-8548-4ED4-B7B4-A5E93D5E7094},KeyPath=C:\Program Files\Safari\Safari.resources\TopSitesDarkButtonDiv-N.png,State=3,,Disk=1,SharedDllRefCou nt=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:798]: Executing op: ComponentRegister(ComponentId={42F30F74-D101-438B-AC86-7C8851A99321},KeyPath=C:\Program Files\Safari\Safari.resources\TopSitesDarkButtonDiv-P.png,State=3,,Disk=1,SharedDllRefCou nt=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:798]: Executing op: ComponentRegister(ComponentId={CCBDD07F-F899-4E52-909B-2BB324C53EDD},KeyPath=C:\Program Files\Safari\Safari.resources\TopSitesDarkButtonFill-N.png,State=3,,Disk=1,SharedDllRefCo unt=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:798]: Executing op: ComponentRegister(ComponentId={D15C9CFA-2F93-4C31-861A-45D3B874EA88},KeyPath=C:\Program Files\Safari\Safari.resources\TopSitesDarkButtonFill-P.png,State=3,,Disk=1,SharedDllRefCo unt=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:798]: Executing op: ComponentRegister(ComponentId={FB893483-B599-4E9A-A490-6B6AC0C8E4E6},KeyPath=C:\Program Files\Safari\Safari.resources\TopSitesDarkButtonFill-Pressed.png,State=3,,Disk=1,SharedDl lRefCount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:798]: Executing op: ComponentRegister(ComponentId={3FADD5C7-C8E7-4F2F-828B-A2C709068300},KeyPath=C:\Program Files\Safari\Safari.resources\TopSitesDarkButtonLeft-N.png,State=3,,Disk=1,SharedDllRefCo unt=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:798]: Executing op: ComponentRegister(ComponentId={422ABB5C-7EE9-439B-954F-DC1FE67B449F},KeyPath=C:\Program Files\Safari\Safari.resources\TopSitesDarkButtonLeft-P.png,State=3,,Disk=1,SharedDllRefCo unt=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:798]: Executing op: ComponentRegister(ComponentId={F7CF61B6-75A2-4526-A01A-0866306F1107},KeyPath=C:\Program Files\Safari\Safari.resources\TopSitesDarkButtonLeft-Pressed.png,State=3,,Disk=1,SharedDl lRefCount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:798]: Executing op: ComponentRegister(ComponentId={C8BA4CEA-4804-497F-995F-94319523E6DA},KeyPath=C:\Program Files\Safari\Safari.resources\TopSitesDarkButtonRight-N.png,State=3,,Disk=1,SharedDllRefC ount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:798]: Executing op: ComponentRegister(ComponentId={1984CC22-3141-40DC-B48F-DC08893322F1},KeyPath=C:\Program Files\Safari\Safari.resources\TopSitesDarkButtonRight-P.png,State=3,,Disk=1,SharedDllRefC ount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:798]: Executing op: ComponentRegister(ComponentId={5F177343-5BC1-4A76-AAB7-4BCBD236FD56},KeyPath=C:\Program Files\Safari\Safari.resources\TopSitesDarkButtonRight-Pressed.png,State=3,,Disk=1,SharedD llRefCount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:798]: Executing op: ComponentRegister(ComponentId={827BC596-DC7B-4B50-A349-6FF62487BB0A},KeyPath=C:\Program Files\Safari\Safari.resources\TopSitesKeepButtonOff.png,State=3,,Disk=1,SharedDllRefCount =0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:798]: Executing op: ComponentRegister(ComponentId={3C0566C1-548A-40B2-B69C-EE31373845E1},KeyPath=C:\Program Files\Safari\Safari.resources\TopSitesKeepButtonOffPressed.png,State=3,,Disk=1,SharedDllR efCount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:798]: Executing op: ComponentRegister(ComponentId={CC49EBFB-D904-4353-B386-360AE0658344},KeyPath=C:\Program Files\Safari\Safari.resources\TopSitesKeepButtonOn.png,State=3,,Disk=1,SharedDllRefCount= 0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:814]: Executing op: ComponentRegister(ComponentId={5B0BDB4B-CFC4-4510-9810-023E9DE1D61D},KeyPath=C:\Program Files\Safari\Safari.resources\TopSitesKeepButtonOnPressed.png,State=3,,Disk=1,SharedDllRe fCount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:814]: Executing op: ComponentRegister(ComponentId={9CA54A08-D2F9-4B78-A467-FF6BF12D160F},KeyPath=C:\Program Files\Safari\Safari.resources\TopSitesKeepRemoveDivider.png,State=3,,Disk=1,SharedDllRefC ount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:814]: Executing op: ComponentRegister(ComponentId={B9047BB9-483F-4E31-89F2-D9FEABAB031B},KeyPath=C:\Program Files\Safari\Safari.resources\TopSitesRemoveButton.png,State=3,,Disk=1,SharedDllRefCount= 0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:814]: Executing op: ComponentRegister(ComponentId={720D205D-23C4-41CB-832B-2679C2DA28F5},KeyPath=C:\Program Files\Safari\Safari.resources\TopSitesRemoveButtonPressed.png,State=3,,Disk=1,SharedDllRe fCount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:814]: Executing op: ComponentRegister(ComponentId={A546382D-5BBD-47CC-BC6B-03A5081A5F50},KeyPath=C:\Program Files\Safari\Safari.resources\TopSitesUpdatedPageCurl.png,State=3,,Disk=1,SharedDllRefCou nt=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:814]: Executing op: ComponentRegister(ComponentId={F21EBE68-019F-4304-9B75-D965FB5DECCD},KeyPath=C:\Program Files\Safari\Safari.resources\Trackers.plist,State=3,,Disk=1,SharedDllRefCount=0,BinaryTy pe=0)
                MSI (s) (A4:F8) [11:14:58:814]: Executing op: ComponentRegister(ComponentId={F47BE76D-A14C-445C-BDA4-4594A377084D},KeyPath=C:\Program Files\Safari\Safari.resources\TrackingBlocker.js,State=3,,Disk=1,SharedDllRefCount=0,Bina ryType=0)
                MSI (s) (A4:F8) [11:14:58:814]: Executing op: ComponentRegister(ComponentId={60C61162-DD57-4DC1-8453-A32F08269376},KeyPath=C:\Program Files\Safari\Safari.resources\treeDownTriangleBlack.png,State=3,,Disk=1,SharedDllRefCount =0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:814]: Executing op: ComponentRegister(ComponentId={B899C063-B306-4A9D-A89E-562E91BA4171},KeyPath=C:\Program Files\Safari\Safari.resources\treeUpTriangleBlack.png,State=3,,Disk=1,SharedDllRefCount=0 ,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:814]: Executing op: ComponentRegister(ComponentId={254CD71B-017D-4156-A99C-4581B7659EAC},KeyPath=C:\Program Files\Safari\Safari.resources\URLFieldCapLeft.png,State=3,,Disk=1,SharedDllRefCount=0,Bin aryType=0)
                MSI (s) (A4:F8) [11:14:58:814]: Executing op: ComponentRegister(ComponentId={35C6004A-422E-4A93-A845-E3182C1D9C09},KeyPath=C:\Program Files\Safari\Safari.resources\URLFieldCapLeftFocused.png,State=3,,Disk=1,SharedDllRefCoun t=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:814]: Executing op: ComponentRegister(ComponentId={9C40641A-8F9F-4923-B71C-3D11A1315F5A},KeyPath=C:\Program Files\Safari\Safari.resources\URLFieldCapLeftHoveredButton.png,State=3,,Disk=1,SharedDllR efCount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:814]: Executing op: ComponentRegister(ComponentId={F9F8E10E-6D51-4671-9AFC-77E4119005B8},KeyPath=C:\Program Files\Safari\Safari.resources\URLFieldCapLeftHoveredButtonProgress.png,State=3,,Disk=1,Sh aredDllRefCount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:814]: Executing op: ComponentRegister(ComponentId={CDCED453-2386-4A95-BF8C-508A3EE3E0E6},KeyPath=C:\Program Files\Safari\Safari.resources\URLFieldCapLeftPressedButton.png,State=3,,Disk=1,SharedDllR efCount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:814]: Executing op: ComponentRegister(ComponentId={0448570F-A14B-4139-A17D-4B239FEC5D11},KeyPath=C:\Program Files\Safari\Safari.resources\URLFieldCapLeftPressedButtonProgress.png,State=3,,Disk=1,Sh aredDllRefCount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:814]: Executing op: ComponentRegister(ComponentId={3C474348-DC8C-4C15-A4A7-9E40E5F6C814},KeyPath=C:\Program Files\Safari\Safari.resources\URLFieldCapLeftProgress.png,State=3,,Disk=1,SharedDllRefCou nt=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:814]: Executing op: ComponentRegister(ComponentId={7A0DCAA8-5E83-49EC-B7A0-A9943653FE9D},KeyPath=C:\Program Files\Safari\Safari.resources\URLFieldCapLeftRounded.png,State=3,,Disk=1,SharedDllRefCoun t=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:814]: Executing op: ComponentRegister(ComponentId={3E6F9273-2649-41CD-82FC-F1F5C90AEF6D},KeyPath=C:\Program Files\Safari\Safari.resources\URLFieldCapLeftRoundedFocused.png,State=3,,Disk=1,SharedDll RefCount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:814]: Executing op: ComponentRegister(ComponentId={17DCC324-E101-466E-B153-A3FB337E1B81},KeyPath=C:\Program Files\Safari\Safari.resources\URLFieldCapLeftRoundedProgress.png,State=3,,Disk=1,SharedDl lRefCount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:814]: Executing op: ComponentRegister(ComponentId={BA920865-6945-4581-8536-25BDCAE6799B},KeyPath=C:\Program Files\Safari\Safari.resources\URLFieldCapRight.png,State=3,,Disk=1,SharedDllRefCount=0,Bi naryType=0)
                MSI (s) (A4:F8) [11:14:58:814]: Executing op: ComponentRegister(ComponentId={1D1BA338-39DF-427C-A60B-BB1C5E016B4A},KeyPath=C:\Program Files\Safari\Safari.resources\URLFieldCapRightFocused.png,State=3,,Disk=1,SharedDllRefCou nt=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:814]: Executing op: ComponentRegister(ComponentId={90D872EA-0DD6-4649-8C09-A42526B0AFD1},KeyPath=C:\Program Files\Safari\Safari.resources\URLFieldCapRightProgress.png,State=3,,Disk=1,SharedDllRefCo unt=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:814]: Executing op: ComponentRegister(ComponentId={88F9F630-84FE-4A42-AAC7-67A9B3088DB9},KeyPath=C:\Program Files\Safari\Safari.resources\URLFieldMiddle.png,State=3,,Disk=1,SharedDllRefCount=0,Bina ryType=0)
                MSI (s) (A4:F8) [11:14:58:814]: Executing op: ComponentRegister(ComponentId={71B4222F-CCF2-4E55-92CC-0BF6AF8C057B},KeyPath=C:\Program Files\Safari\Safari.resources\URLFieldMiddleFocused.png,State=3,,Disk=1,SharedDllRefCount =0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:830]: Executing op: ComponentRegister(ComponentId={0A96F634-844F-4A01-9ED1-3B14430A768E},KeyPath=C:\Program Files\Safari\Safari.resources\URLFieldMiddleProgress.png,State=3,,Disk=1,SharedDllRefCoun t=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:830]: Executing op: ComponentRegister(ComponentId={EDDB415F-3A84-4CD0-9F05-4F4DFA162D65},KeyPath=C:\Program Files\Safari\Safari.resources\UserAgents.plist,State=3,,Disk=1,SharedDllRefCount=0,Binary Type=0)
                MSI (s) (A4:F8) [11:14:58:830]: Executing op: ComponentRegister(ComponentId={7531924F-2F2E-4328-8420-7EB11E394A53},KeyPath=C:\Program Files\Safari\Safari.resources\Utilities.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType =0)
                MSI (s) (A4:F8) [11:14:58:830]: Executing op: ComponentRegister(ComponentId={0F1183D6-043F-4A22-9A17-A822D801F9BE},KeyPath=C:\Program Files\Safari\Safari.resources\WebAuthenticationSheet.html,State=3,,Disk=1,SharedDllRefCou nt=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:830]: Executing op: ComponentRegister(ComponentId={3D6E1A29-7137-4A51-ABAA-983D2CB7AAC0},KeyPath=C:\Program Files\Safari\Safari.resources\WhiteSearchField.png,State=3,,Disk=1,SharedDllRefCount=0,Bi naryType=0)
                MSI (s) (A4:F8) [11:14:58:830]: Executing op: ComponentRegister(ComponentId={37E956C5-0FD8-4E64-94F3-8140F8CC6F30},KeyPath=C:\Program Files\Safari\Safari.resources\BookmarkChooser\BookmarkChooser.js,State=3,,Disk=1,SharedDl lRefCount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:830]: Executing op: ComponentRegister(ComponentId={78C9A4CA-0FBA-4AA4-983C-073320BE232E},KeyPath=C:\Program Files\Safari\Safari.resources\BookmarkChooser\disclosureTriangleSmallDown.png,State=3,,Di sk=1,SharedDllRefCount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:830]: Executing op: ComponentRegister(ComponentId={0855BF70-2320-46D7-B262-AC5C47F54820},KeyPath=C:\Program Files\Safari\Safari.resources\BookmarkChooser\disclosureTriangleSmallRight.png,State=3,,D isk=1,SharedDllRefCount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:830]: Executing op: ComponentRegister(ComponentId={B95E4628-E6BB-4D52-BB82-E8C8745A3068},KeyPath=C:\Program Files\Safari\Safari.resources\BookmarkChooser\GenericFolderIcon_16.png,State=3,,Disk=1,Sh aredDllRefCount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:830]: Executing op: ComponentRegister(ComponentId={C355B07F-5F2B-46A9-97B7-9287D273982B},KeyPath=C:\Program Files\Safari\Safari.resources\BookmarkChooser\TreeView.css,State=3,,Disk=1,SharedDllRefCo unt=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:830]: Executing op: ComponentRegister(ComponentId={96FE8CC2-1097-43A7-AB7A-2C0A55825914},KeyPath=C:\Program Files\Safari\Safari.resources\BookmarkChooser\TreeView.js,State=3,,Disk=1,SharedDllRefCou nt=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:830]: Executing op: ComponentRegister(ComponentId={B2DF815A-2A9D-4D88-AACD-7462E25A918E},KeyPath=C:\Program Files\Safari\Safari.resources\da.lproj\ABAutoCompleteMappings.plist,State=3,,Disk=1,Share dDllRefCount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:830]: Executing op: ComponentRegister(ComponentId={37ABBD53-332C-45C3-A53D-2FB16A8315C2},KeyPath=C:\Program Files\Safari\Safari.resources\da.lproj\BuiltInBookmarks.plist,State=3,,Disk=1,SharedDllRe fCount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:830]: Executing op: ComponentRegister(ComponentId={4059DF1D-54EB-494C-B15F-51E6A002F3F3},KeyPath=C:\Program Files\Safari\Safari.resources\da.lproj\Localizable.strings,State=3,,Disk=1,SharedDllRefCo unt=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:830]: Executing op: ComponentRegister(ComponentId={D78B2CCC-FDCA-4594-876C-509F6071A523},KeyPath=C:\Program Files\Safari\Safari.resources\da.lproj\localizedStrings.js,State=3,,Disk=1,SharedDllRefCo unt=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:830]: Executing op: ComponentRegister(ComponentId={95B1A860-D9B1-43B3-B399-9FBDE15D08CB},KeyPath=C:\Program Files\Safari\Safari.resources\de.lproj\ABAutoCompleteMappings.plist,State=3,,Disk=1,Share dDllRefCount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:830]: Executing op: ComponentRegister(ComponentId={927901ED-FD92-4ACE-B86A-8C8AF548CD53},KeyPath=C:\Program Files\Safari\Safari.resources\de.lproj\bindict,State=3,,Disk=1,SharedDllRefCount=0,Binary Type=0)
                MSI (s) (A4:F8) [11:14:58:830]: Executing op: ComponentRegister(ComponentId={F2AE32F1-305A-424C-B975-96F919E4217A},KeyPath=C:\Program Files\Safari\Safari.resources\de.lproj\BuiltInBookmarks.plist,State=3,,Disk=1,SharedDllRe fCount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:830]: Executing op: ComponentRegister(ComponentId={55DC84EB-8874-4B15-AA89-FC7DC88E673C},KeyPath=C:\Program Files\Safari\Safari.resources\de.lproj\Dictionary.dat,State=3,,Disk=1,SharedDllRefCount=0 ,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:830]: Executing op: ComponentRegister(ComponentId={CDF585AD-0E76-4065-8A3B-C2B1D48C93AB},KeyPath=C:\Program Files\Safari\Safari.resources\de.lproj\Localizable.strings,State=3,,Disk=1,SharedDllRefCo unt=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:830]: Executing op: ComponentRegister(ComponentId={6D509F48-6593-41E7-974A-C143B718DAB4},KeyPath=C:\Program Files\Safari\Safari.resources\de.lproj\localizedStrings.js,State=3,,Disk=1,SharedDllRefCo unt=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:830]: Executing op: ComponentRegister(ComponentId={1FA7C4D2-84C5-4699-989E-CEB339F8F6EA},KeyPath=C:\Program Files\Safari\Safari.resources\en.lproj\ABAutoCompleteMappings.plist,State=3,,Disk=1,Share dDllRefCount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:830]: Executing op: ComponentRegister(ComponentId={15E98042-9D21-474B-8BA0-B3C9DC33E50E},KeyPath=C:\Program Files\Safari\Safari.resources\en.lproj\bindict,State=3,,Disk=1,SharedDllRefCount=0,Binary Type=0)
                MSI (s) (A4:F8) [11:14:58:830]: Executing op: ComponentRegister(ComponentId={E40F5893-01D5-411B-9312-2224D1EB5C4E},KeyPath=C:\Program Files\Safari\Safari.resources\en.lproj\bindict1,State=3,,Disk=1,SharedDllRefCount=0,Binar yType=0)
                MSI (s) (A4:F8) [11:14:58:830]: Executing op: ComponentRegister(ComponentId={C0FBC570-1B98-457F-A002-7E3BDF1DD689},KeyPath=C:\Program Files\Safari\Safari.resources\en.lproj\bindict2,State=3,,Disk=1,SharedDllRefCount=0,Binar yType=0)
                MSI (s) (A4:F8) [11:14:58:845]: Executing op: ComponentRegister(ComponentId={2F01632C-C108-46EC-B229-189B5D1646C0},KeyPath=C:\Program Files\Safari\Safari.resources\en.lproj\bindict3,State=3,,Disk=1,SharedDllRefCount=0,Binar yType=0)
                MSI (s) (A4:F8) [11:14:58:845]: Executing op: ComponentRegister(ComponentId={871D9D65-668C-4C0C-8F88-77AA17EBE1A8},KeyPath=C:\Program Files\Safari\Safari.resources\en.lproj\BuiltInBookmarks.plist,State=3,,Disk=1,SharedDllRe fCount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:845]: Executing op: ComponentRegister(ComponentId={43AB27E3-1E52-4F2A-A2CC-712279246CD0},KeyPath=C:\Program Files\Safari\Safari.resources\en.lproj\Dictionary.dat,State=3,,Disk=1,SharedDllRefCount=0 ,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:845]: Executing op: ComponentRegister(ComponentId={AD276BD5-BEDC-44B0-9A6C-921D3BE9B53D},KeyPath=C:\Program Files\Safari\Safari.resources\en.lproj\Localizable.strings,State=3,,Disk=1,SharedDllRefCo unt=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:845]: Executing op: ComponentRegister(ComponentId={BF744223-743D-441C-9763-09281A55BDDA},KeyPath=C:\Program Files\Safari\Safari.resources\en.lproj\localizedStrings.js,State=3,,Disk=1,SharedDllRefCo unt=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:845]: Executing op: ComponentRegister(ComponentId={115EEE44-53B1-4D6E-8D6C-8E6B7E979A14},KeyPath=C:\Program Files\Safari\Safari.resources\en_AU.lproj\bindict,State=3,,Disk=1,SharedDllRefCount=0,Bin aryType=0)
                MSI (s) (A4:F8) [11:14:58:845]: Executing op: ComponentRegister(ComponentId={D93B638B-4BA1-4002-A748-4B0111A0B374},KeyPath=C:\Program Files\Safari\Safari.resources\en_CA.lproj\bindict,State=3,,Disk=1,SharedDllRefCount=0,Bin aryType=0)
                MSI (s) (A4:F8) [11:14:58:845]: Executing op: ComponentRegister(ComponentId={D3A01FF4-363D-45AF-BEFA-499B0AA3A3E4},KeyPath=C:\Program Files\Safari\Safari.resources\en_GB.lproj\bindict,State=3,,Disk=1,SharedDllRefCount=0,Bin aryType=0)
                MSI (s) (A4:F8) [11:14:58:845]: Executing op: ComponentRegister(ComponentId={71F61626-0D8E-46B8-9527-012EDD668985},KeyPath=C:\Program Files\Safari\Safari.resources\es.lproj\ABAutoCompleteMappings.plist,State=3,,Disk=1,Share dDllRefCount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:845]: Executing op: ComponentRegister(ComponentId={C6831E02-41E1-40B9-B9B0-26216584D171},KeyPath=C:\Program Files\Safari\Safari.resources\es.lproj\bindict,State=3,,Disk=1,SharedDllRefCount=0,Binary Type=0)
                MSI (s) (A4:F8) [11:14:58:845]: Executing op: ComponentRegister(ComponentId={FA2331BA-250D-4A54-803D-B915DCAD7452},KeyPath=C:\Program Files\Safari\Safari.resources\es.lproj\BuiltInBookmarks.plist,State=3,,Disk=1,SharedDllRe fCount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:845]: Executing op: ComponentRegister(ComponentId={6519AE46-DF0A-4826-A9BC-2F51742D07D5},KeyPath=C:\Program Files\Safari\Safari.resources\es.lproj\Dictionary.dat,State=3,,Disk=1,SharedDllRefCount=0 ,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:845]: Executing op: ComponentRegister(ComponentId={B8D0C533-78BE-43F0-AA5A-AE3C079A5953},KeyPath=C:\Program Files\Safari\Safari.resources\es.lproj\Localizable.strings,State=3,,Disk=1,SharedDllRefCo unt=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:845]: Executing op: ComponentRegister(ComponentId={8E54E9E3-4C5E-4D94-8839-397916A9F3A3},KeyPath=C:\Program Files\Safari\Safari.resources\es.lproj\localizedStrings.js,State=3,,Disk=1,SharedDllRefCo unt=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:845]: Executing op: ComponentRegister(ComponentId={5BAFA5FA-A05F-4FC6-8B6E-7EEE7FA9DEE3},KeyPath=C:\Program Files\Safari\Safari.resources\fi.lproj\ABAutoCompleteMappings.plist,State=3,,Disk=1,Share dDllRefCount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:845]: Executing op: ComponentRegister(ComponentId={3B1FA5EB-7A7B-4DE8-9CBC-D25E923D2566},KeyPath=C:\Program Files\Safari\Safari.resources\fi.lproj\BuiltInBookmarks.plist,State=3,,Disk=1,SharedDllRe fCount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:845]: Executing op: ComponentRegister(ComponentId={E15EEA7B-118A-464A-A840-F4605BA7B447},KeyPath=C:\Program Files\Safari\Safari.resources\fi.lproj\Localizable.strings,State=3,,Disk=1,SharedDllRefCo unt=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:58:845]: Executing op: ComponentRegister(ComponentId={58A8AF33-B8E5-4CAD-BA6B-6A480DFC0442},KeyPath=C:\Program Files\Safari\Safari.resources\fi.lproj\localizedStrings.js,State=3,,Disk=1,SharedDllRefCo unt=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:095]: Executing op: ComponentRegister(ComponentId={B4D6C7B4-30D8-4B77-AA67-D2521CE214CE},KeyPath=C:\Program Files\Safari\Safari.resources\fr.lproj\ABAutoCompleteMappings.plist,State=3,,Disk=1,Share dDllRefCount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:095]: Executing op: ComponentRegister(ComponentId={592C9633-3339-4C48-BC5C-9E8520945B2D},KeyPath=C:\Program Files\Safari\Safari.resources\fr.lproj\bindict,State=3,,Disk=1,SharedDllRefCount=0,Binary Type=0)
                MSI (s) (A4:F8) [11:14:59:095]: Executing op: ComponentRegister(ComponentId={5C345288-75BC-42CB-9206-5558D28470D8},KeyPath=C:\Program Files\Safari\Safari.resources\fr.lproj\BuiltInBookmarks.plist,State=3,,Disk=1,SharedDllRe fCount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:095]: Executing op: ComponentRegister(ComponentId={0ED6E1C4-1278-411B-855D-B2B5D252D8BF},KeyPath=C:\Program Files\Safari\Safari.resources\fr.lproj\Dictionary.dat,State=3,,Disk=1,SharedDllRefCount=0 ,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:095]: Executing op: ComponentRegister(ComponentId={4852E400-FEFC-45D1-A2C1-7358D166A404},KeyPath=C:\Program Files\Safari\Safari.resources\fr.lproj\Localizable.strings,State=3,,Disk=1,SharedDllRefCo unt=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:095]: Executing op: ComponentRegister(ComponentId={7E884271-B006-4BCC-8E80-DDFE4FC2A7BF},KeyPath=C:\Program Files\Safari\Safari.resources\fr.lproj\localizedStrings.js,State=3,,Disk=1,SharedDllRefCo unt=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:095]: Executing op: ComponentRegister(ComponentId={E2D47B89-3626-4E0C-874B-FF0C07D6DD35},KeyPath=C:\Program Files\Safari\Safari.resources\Help\Acknowledgments.html,State=3,,Disk=1,SharedDllRefCount =0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:095]: Executing op: ComponentRegister(ComponentId={690D71BF-C3F2-428F-8F29-89B07960FFEC},KeyPath=C:\Program Files\Safari\Safari.resources\Help\da.lproj\Plug-ins.html,State=3,,Disk=1,SharedDllRefCou nt=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:110]: Executing op: ComponentRegister(ComponentId={7B5F30E7-0B1C-4225-8CC2-63609F9634D7},KeyPath=C:\Program Files\Safari\Safari.resources\Help\da.lproj\Safari.chm,State=3,,Disk=1,SharedDllRefCount= 0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:110]: Executing op: ComponentRegister(ComponentId={C8AC60BB-00B4-4AD8-9522-C976667B2E0C},KeyPath=C:\Program Files\Safari\Safari.resources\Help\de.lproj\Plug-ins.html,State=3,,Disk=1,SharedDllRefCou nt=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:110]: Executing op: ComponentRegister(ComponentId={004C56FA-DAC8-40CA-A015-5BA75E1FDCC0},KeyPath=C:\Program Files\Safari\Safari.resources\Help\de.lproj\Safari.chm,State=3,,Disk=1,SharedDllRefCount= 0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:110]: Executing op: ComponentRegister(ComponentId={2BEB3C30-723A-4FBF-8B67-0A86523571BB},KeyPath=C:\Program Files\Safari\Safari.resources\Help\en.lproj\Plug-ins.html,State=3,,Disk=1,SharedDllRefCou nt=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:110]: Executing op: ComponentRegister(ComponentId={A8693B65-C833-4C0E-8B97-F4B9856F7FB6},KeyPath=C:\Program Files\Safari\Safari.resources\Help\en.lproj\Safari.chm,State=3,,Disk=1,SharedDllRefCount= 0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:110]: Executing op: ComponentRegister(ComponentId={51DFBC50-2DB8-4091-9642-77D0EA369270},KeyPath=C:\Program Files\Safari\Safari.resources\Help\es.lproj\Plug-ins.html,State=3,,Disk=1,SharedDllRefCou nt=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:110]: Executing op: ComponentRegister(ComponentId={32E0AF59-D30C-4300-A1CD-8BE561EA06A0},KeyPath=C:\Program Files\Safari\Safari.resources\Help\es.lproj\Safari.chm,State=3,,Disk=1,SharedDllRefCount= 0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:110]: Executing op: ComponentRegister(ComponentId={527A1889-85BC-4D62-B68F-CD005C7CF56C},KeyPath=C:\Program Files\Safari\Safari.resources\Help\fi.lproj\Plug-ins.html,State=3,,Disk=1,SharedDllRefCou nt=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:110]: Executing op: ComponentRegister(ComponentId={F13FBCE8-53E7-44EB-B767-9A7BACCA7689},KeyPath=C:\Program Files\Safari\Safari.resources\Help\fi.lproj\Safari.chm,State=3,,Disk=1,SharedDllRefCount= 0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:110]: Executing op: ComponentRegister(ComponentId={DB4AA96A-19B5-40CC-B119-58C071D3D771},KeyPath=C:\Program Files\Safari\Safari.resources\Help\fr.lproj\Plug-ins.html,State=3,,Disk=1,SharedDllRefCou nt=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:110]: Executing op: ComponentRegister(ComponentId={9CA6BDE5-A431-4B27-935D-4E71C0BF72E6},KeyPath=C:\Program Files\Safari\Safari.resources\Help\fr.lproj\Safari.chm,State=3,,Disk=1,SharedDllRefCount= 0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:110]: Executing op: ComponentRegister(ComponentId={705064EF-E165-4C51-801A-21CF6C832624},KeyPath=C:\Program Files\Safari\Safari.resources\Help\it.lproj\Plug-ins.html,State=3,,Disk=1,SharedDllRefCou nt=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:110]: Executing op: ComponentRegister(ComponentId={B98D5B28-DABD-446D-9A9F-2B030F9A48BB},KeyPath=C:\Program Files\Safari\Safari.resources\Help\it.lproj\Safari.chm,State=3,,Disk=1,SharedDllRefCount= 0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:110]: Executing op: ComponentRegister(ComponentId={C013913C-B1E0-4EF7-B5A6-FA9A4C686428},KeyPath=C:\Program Files\Safari\Safari.resources\Help\ja.lproj\Plug-ins.html,State=3,,Disk=1,SharedDllRefCou nt=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:110]: Executing op: ComponentRegister(ComponentId={C841BDBB-7795-4E4C-BB10-B444DAEBCB93},KeyPath=C:\Program Files\Safari\Safari.resources\Help\ja.lproj\Safari.chm,State=3,,Disk=1,SharedDllRefCount= 0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:110]: Executing op: ComponentRegister(ComponentId={E48265EA-A517-4C5B-BDF1-93356893AAE1},KeyPath=C:\Program Files\Safari\Safari.resources\Help\ko.lproj\Plug-ins.html,State=3,,Disk=1,SharedDllRefCou nt=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:110]: Executing op: ComponentRegister(ComponentId={F56509A4-96F5-4C36-AB5D-240510774CEC},KeyPath=C:\Program Files\Safari\Safari.resources\Help\ko.lproj\Safari.chm,State=3,,Disk=1,SharedDllRefCount= 0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:110]: Executing op: ComponentRegister(ComponentId={5C004CFA-3716-4A4C-B7AE-20EB96CD8DA1},KeyPath=C:\Program Files\Safari\Safari.resources\Help\nb.lproj\Plug-ins.html,State=3,,Disk=1,SharedDllRefCou nt=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:110]: Executing op: ComponentRegister(ComponentId={C6C685AB-79AF-47C3-8C89-66C48367D578},KeyPath=C:\Program Files\Safari\Safari.resources\Help\nb.lproj\Safari.chm,State=3,,Disk=1,SharedDllRefCount= 0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:110]: Executing op: ComponentRegister(ComponentId={B6E9C806-4F68-4B04-BA66-356AB4D91FBD},KeyPath=C:\Program Files\Safari\Safari.resources\Help\nl.lproj\Plug-ins.html,State=3,,Disk=1,SharedDllRefCou nt=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:110]: Executing op: ComponentRegister(ComponentId={7ED25B27-6B8C-4229-AF65-BD0851D03250},KeyPath=C:\Program Files\Safari\Safari.resources\Help\nl.lproj\Safari.chm,State=3,,Disk=1,SharedDllRefCount= 0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:110]: Executing op: ComponentRegister(ComponentId={9753436A-8092-4CFB-8FF6-4CEC8AE6EB95},KeyPath=C:\Program Files\Safari\Safari.resources\Help\pl.lproj\Plug-ins.html,State=3,,Disk=1,SharedDllRefCou nt=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:110]: Executing op: ComponentRegister(ComponentId={3912BC10-03E0-4A3D-84D4-76865851889C},KeyPath=C:\Program Files\Safari\Safari.resources\Help\pl.lproj\Safari.chm,State=3,,Disk=1,SharedDllRefCount= 0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:110]: Executing op: ComponentRegister(ComponentId={B0FD33C8-5843-44CF-9424-BB8F49DDC1C5},KeyPath=C:\Program Files\Safari\Safari.resources\Help\pt.lproj\Plug-ins.html,State=3,,Disk=1,SharedDllRefCou nt=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:126]: Executing op: ComponentRegister(ComponentId={7CFCCB89-AFB2-4F82-B82E-381959476DAE},KeyPath=C:\Program Files\Safari\Safari.resources\Help\pt.lproj\Safari.chm,State=3,,Disk=1,SharedDllRefCount= 0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:126]: Executing op: ComponentRegister(ComponentId={81F342BE-A341-4BD0-9398-E6F4BBE8DAD1},KeyPath=C:\Program Files\Safari\Safari.resources\Help\pt_PT.lproj\Plug-ins.html,State=3,,Disk=1,SharedDllRef Count=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:126]: Executing op: ComponentRegister(ComponentId={938FACB5-DAD4-495F-83F0-17FDB729F289},KeyPath=C:\Program Files\Safari\Safari.resources\Help\pt_PT.lproj\Safari.chm,State=3,,Disk=1,SharedDllRefCou nt=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:126]: Executing op: ComponentRegister(ComponentId={9D108368-1574-47F3-A5A4-7172C9D5B34F},KeyPath=C:\Program Files\Safari\Safari.resources\Help\ru.lproj\Plug-ins.html,State=3,,Disk=1,SharedDllRefCou nt=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:126]: Executing op: ComponentRegister(ComponentId={49B08F9A-D289-467D-991F-3C046E185F7C},KeyPath=C:\Program Files\Safari\Safari.resources\Help\ru.lproj\Safari.chm,State=3,,Disk=1,SharedDllRefCount= 0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:126]: Executing op: ComponentRegister(ComponentId={7650FAEF-1A2B-4E5A-AF40-802CEFE3DD11},KeyPath=C:\Program Files\Safari\Safari.resources\Help\sv.lproj\Plug-ins.html,State=3,,Disk=1,SharedDllRefCou nt=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:126]: Executing op: ComponentRegister(ComponentId={AA0A091D-7F40-4EF3-A57D-4965D569F51D},KeyPath=C:\Program Files\Safari\Safari.resources\Help\sv.lproj\Safari.chm,State=3,,Disk=1,SharedDllRefCount= 0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:126]: Executing op: ComponentRegister(ComponentId={12F00611-F6BD-4838-A32F-117F482D618C},KeyPath=C:\Program Files\Safari\Safari.resources\Help\zh_CN.lproj\Plug-ins.html,State=3,,Disk=1,SharedDllRef Count=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:126]: Executing op: ComponentRegister(ComponentId={388624B9-A185-477B-B5C1-5058B758DA3E},KeyPath=C:\Program Files\Safari\Safari.resources\Help\zh_CN.lproj\Safari.chm,State=3,,Disk=1,SharedDllRefCou nt=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:126]: Executing op: ComponentRegister(ComponentId={97054E05-5AD7-4A7B-A51D-471A2E632A45},KeyPath=C:\Program Files\Safari\Safari.resources\Help\zh_TW.lproj\Plug-ins.html,State=3,,Disk=1,SharedDllRef Count=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:126]: Executing op: ComponentRegister(ComponentId={A8F59354-81E4-4EC9-81A5-DBF58079D9BC},KeyPath=C:\Program Files\Safari\Safari.resources\Help\zh_TW.lproj\Safari.chm,State=3,,Disk=1,SharedDllRefCou nt=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:126]: Executing op: ComponentRegister(ComponentId={9B315F8E-4094-4F3B-9EAC-CFF2CBD438E0},KeyPath=C:\Program Files\Safari\Safari.resources\it.lproj\ABAutoCompleteMappings.plist,State=3,,Disk=1,Share dDllRefCount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:126]: Executing op: ComponentRegister(ComponentId={5C7A43E8-86BE-48A6-BDC8-50181BC0F771},KeyPath=C:\Program Files\Safari\Safari.resources\it.lproj\bindict,State=3,,Disk=1,SharedDllRefCount=0,Binary Type=0)
                MSI (s) (A4:F8) [11:14:59:126]: Executing op: ComponentRegister(ComponentId={810C7314-73E3-47C4-B566-1098A75B7478},KeyPath=C:\Program Files\Safari\Safari.resources\it.lproj\BuiltInBookmarks.plist,State=3,,Disk=1,SharedDllRe fCount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:126]: Executing op: ComponentRegister(ComponentId={3F3ABEC2-825C-44AD-A69F-33E53271D2D1},KeyPath=C:\Program Files\Safari\Safari.resources\it.lproj\Dictionary.dat,State=3,,Disk=1,SharedDllRefCount=0 ,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:126]: Executing op: ComponentRegister(ComponentId={4AB481BD-8AD0-49DD-9942-1C6D53B5601C},KeyPath=C:\Program Files\Safari\Safari.resources\it.lproj\Localizable.strings,State=3,,Disk=1,SharedDllRefCo unt=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:126]: Executing op: ComponentRegister(ComponentId={5C288D19-9768-455C-BA29-4C906CEBBCE7},KeyPath=C:\Program Files\Safari\Safari.resources\it.lproj\localizedStrings.js,State=3,,Disk=1,SharedDllRefCo unt=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:126]: Executing op: ComponentRegister(ComponentId={3AEACBCD-B0D1-4AF9-9BA5-59A4E00042C6},KeyPath=C:\Program Files\Safari\Safari.resources\ja.lproj\ABAutoCompleteMappings.plist,State=3,,Disk=1,Share dDllRefCount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:126]: Executing op: ComponentRegister(ComponentId={1B0E602E-F941-4F27-9477-47C6FEF04071},KeyPath=C:\Program Files\Safari\Safari.resources\ja.lproj\BuiltInBookmarks.plist,State=3,,Disk=1,SharedDllRe fCount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:126]: Executing op: ComponentRegister(ComponentId={E0852F9E-12CF-4D62-948C-A5F1813EF367},KeyPath=C:\Program Files\Safari\Safari.resources\ja.lproj\Localizable.strings,State=3,,Disk=1,SharedDllRefCo unt=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:126]: Executing op: ComponentRegister(ComponentId={1BF16AC0-8E88-4E76-BDBF-1FFB727E10ED},KeyPath=C:\Program Files\Safari\Safari.resources\ja.lproj\localizedStrings.js,State=3,,Disk=1,SharedDllRefCo unt=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:126]: Executing op: ComponentRegister(ComponentId={D5105E8C-BCA1-46DB-8084-B3F57588EF39},KeyPath=C:\Program Files\Safari\Safari.resources\ko.lproj\ABAutoCompleteMappings.plist,State=3,,Disk=1,Share dDllRefCount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:126]: Executing op: ComponentRegister(ComponentId={D85891A6-6C41-4C2D-A018-1022E2641399},KeyPath=C:\Program Files\Safari\Safari.resources\ko.lproj\BuiltInBookmarks.plist,State=3,,Disk=1,SharedDllRe fCount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:126]: Executing op: ComponentRegister(ComponentId={DE287B5A-1DBC-4A37-BA75-EC6E0E56761D},KeyPath=C:\Program Files\Safari\Safari.resources\ko.lproj\Localizable.strings,State=3,,Disk=1,SharedDllRefCo unt=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:142]: Executing op: ComponentRegister(ComponentId={51A765C6-FB7F-4C3A-A540-43059BB0A5FD},KeyPath=C:\Program Files\Safari\Safari.resources\ko.lproj\localizedStrings.js,State=3,,Disk=1,SharedDllRefCo unt=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:142]: Executing op: ComponentRegister(ComponentId={16B986B2-3FFC-44F1-A172-E329577CD6C0},KeyPath=C:\Program Files\Safari\Safari.resources\nb.lproj\ABAutoCompleteMappings.plist,State=3,,Disk=1,Share dDllRefCount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:142]: Executing op: ComponentRegister(ComponentId={B4A367A7-0C99-4242-A1A3-D226DA4F1D03},KeyPath=C:\Program Files\Safari\Safari.resources\nb.lproj\BuiltInBookmarks.plist,State=3,,Disk=1,SharedDllRe fCount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:142]: Executing op: ComponentRegister(ComponentId={BC1F67F0-EE67-495C-A413-F07FA9842E4A},KeyPath=C:\Program Files\Safari\Safari.resources\nb.lproj\Localizable.strings,State=3,,Disk=1,SharedDllRefCo unt=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:142]: Executing op: ComponentRegister(ComponentId={467A1C97-EA95-4385-A317-92224F2BD6CA},KeyPath=C:\Program Files\Safari\Safari.resources\nb.lproj\localizedStrings.js,State=3,,Disk=1,SharedDllRefCo unt=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:142]: Executing op: ComponentRegister(ComponentId={1E6790D1-C97D-4965-A883-03D7C05724B3},KeyPath=C:\Program Files\Safari\Safari.resources\nl.lproj\ABAutoCompleteMappings.plist,State=3,,Disk=1,Share dDllRefCount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:142]: Executing op: ComponentRegister(ComponentId={98657F2E-5501-4A29-B536-A1D8B6C380DE},KeyPath=C:\Program Files\Safari\Safari.resources\nl.lproj\bindict,State=3,,Disk=1,SharedDllRefCount=0,Binary Type=0)
                MSI (s) (A4:F8) [11:14:59:142]: Executing op: ComponentRegister(ComponentId={4DCCF517-778B-4A23-BEEA-E8656902432D},KeyPath=C:\Program Files\Safari\Safari.resources\nl.lproj\BuiltInBookmarks.plist,State=3,,Disk=1,SharedDllRe fCount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:142]: Executing op: ComponentRegister(ComponentId={7CBF1FB5-0502-4B35-ACC0-75AC9EBA36B9},KeyPath=C:\Program Files\Safari\Safari.resources\nl.lproj\Dictionary.dat,State=3,,Disk=1,SharedDllRefCount=0 ,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:142]: Executing op: ComponentRegister(ComponentId={286C997E-52FF-4505-B645-C5B081A0C694},KeyPath=C:\Program Files\Safari\Safari.resources\nl.lproj\Localizable.strings,State=3,,Disk=1,SharedDllRefCo unt=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:142]: Executing op: ComponentRegister(ComponentId={0AE01C59-C842-4A00-BEF3-4836CD0D9740},KeyPath=C:\Program Files\Safari\Safari.resources\nl.lproj\localizedStrings.js,State=3,,Disk=1,SharedDllRefCo unt=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:142]: Executing op: ComponentRegister(ComponentId={13EACBD8-559A-4398-992A-ED2916B988BA},KeyPath=C:\Program Files\Safari\Safari.resources\pl.lproj\ABAutoCompleteMappings.plist,State=3,,Disk=1,Share dDllRefCount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:142]: Executing op: ComponentRegister(ComponentId={486C4D97-EB59-4ADE-9BE1-15800315B3A5},KeyPath=C:\Program Files\Safari\Safari.resources\pl.lproj\BuiltInBookmarks.plist,State=3,,Disk=1,SharedDllRe fCount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:142]: Executing op: ComponentRegister(ComponentId={C2496BB6-CCCC-43B4-B87F-E95B4315A6FF},KeyPath=C:\Program Files\Safari\Safari.resources\pl.lproj\Localizable.strings,State=3,,Disk=1,SharedDllRefCo unt=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:142]: Executing op: ComponentRegister(ComponentId={A4738C16-14EB-4957-B6EC-8E93594E7432},KeyPath=C:\Program Files\Safari\Safari.resources\pl.lproj\localizedStrings.js,State=3,,Disk=1,SharedDllRefCo unt=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:142]: Executing op: ComponentRegister(ComponentId={8BCCA427-488C-46D8-8DF0-89A372A2FD53},KeyPath=C:\Program Files\Safari\Safari.resources\pt.lproj\ABAutoCompleteMappings.plist,State=3,,Disk=1,Share dDllRefCount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:142]: Executing op: ComponentRegister(ComponentId={F482C279-B5AB-48D3-A2D1-C3266A3CB707},KeyPath=C:\Program Files\Safari\Safari.resources\pt.lproj\bindict,State=3,,Disk=1,SharedDllRefCount=0,Binary Type=0)
                MSI (s) (A4:F8) [11:14:59:142]: Executing op: ComponentRegister(ComponentId={1257054A-1D4F-45FF-9345-BD89CFC9FF6E},KeyPath=C:\Program Files\Safari\Safari.resources\pt.lproj\BuiltInBookmarks.plist,State=3,,Disk=1,SharedDllRe fCount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:142]: Executing op: ComponentRegister(ComponentId={D9B92A33-2A31-49B6-A4D1-030E8866FB2E},KeyPath=C:\Program Files\Safari\Safari.resources\pt.lproj\Dictionary.dat,State=3,,Disk=1,SharedDllRefCount=0 ,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:142]: Executing op: ComponentRegister(ComponentId={2E877D3C-5762-4747-913B-0EE9539B0F99},KeyPath=C:\Program Files\Safari\Safari.resources\pt.lproj\Localizable.strings,State=3,,Disk=1,SharedDllRefCo unt=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:142]: Executing op: ComponentRegister(ComponentId={7C82B3C3-CF9C-4D79-A94D-4BD48AAC6DD4},KeyPath=C:\Program Files\Safari\Safari.resources\pt.lproj\localizedStrings.js,State=3,,Disk=1,SharedDllRefCo unt=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:142]: Executing op: ComponentRegister(ComponentId={F4CE1F0C-2E91-4F7C-B536-027981D7B8FF},KeyPath=C:\Program Files\Safari\Safari.resources\pt_PT.lproj\ABAutoCompleteMappings.plist,State=3,,Disk=1,Sh aredDllRefCount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:142]: Executing op: ComponentRegister(ComponentId={E91636B1-6F8B-4774-8CA8-4AFE905597E4},KeyPath=C:\Program Files\Safari\Safari.resources\pt_PT.lproj\BuiltInBookmarks.plist,State=3,,Disk=1,SharedDl lRefCount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:142]: Executing op: ComponentRegister(ComponentId={F1053F1D-D0AA-4C68-8BAF-26EE1C0ACC6B},KeyPath=C:\Program Files\Safari\Safari.resources\pt_PT.lproj\Localizable.strings,State=3,,Disk=1,SharedDllRe fCount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:157]: Executing op: ComponentRegister(ComponentId={A730C5EF-959B-4D3F-AF6D-0213524FC3E8},KeyPath=C:\Program Files\Safari\Safari.resources\pt_PT.lproj\localizedStrings.js,State=3,,Disk=1,SharedDllRe fCount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:157]: Executing op: ComponentRegister(ComponentId={2EB8E0C6-EBDF-40B4-B6A9-FA5A2131D3E1},KeyPath=C:\Program Files\Safari\Safari.resources\ru.lproj\ABAutoCompleteMappings.plist,State=3,,Disk=1,Share dDllRefCount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:157]: Executing op: ComponentRegister(ComponentId={FD8BEF67-F027-47A7-8511-9C33084A2D4F},KeyPath=C:\Program Files\Safari\Safari.resources\ru.lproj\BuiltInBookmarks.plist,State=3,,Disk=1,SharedDllRe fCount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:157]: Executing op: ComponentRegister(ComponentId={64674C26-76DC-4594-9734-7111BBDA66CE},KeyPath=C:\Program Files\Safari\Safari.resources\ru.lproj\Localizable.strings,State=3,,Disk=1,SharedDllRefCo unt=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:157]: Executing op: ComponentRegister(ComponentId={54DE539B-EE25-47D8-9579-1FF84C39AC17},KeyPath=C:\Program Files\Safari\Safari.resources\ru.lproj\localizedStrings.js,State=3,,Disk=1,SharedDllRefCo unt=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:157]: Executing op: ComponentRegister(ComponentId={DA6990B7-F6E9-4340-A61D-323176C988E4},KeyPath=C:\Program Files\Safari\Safari.resources\SnippetEditor\SnippetEditor.css,State=3,,Disk=1,SharedDllRe fCount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:157]: Executing op: ComponentRegister(ComponentId={D37D34B5-BC0A-4965-888D-1EB58C2CEFFE},KeyPath=C:\Program Files\Safari\Safari.resources\SnippetEditor\SnippetEditor.html,State=3,,Disk=1,SharedDllR efCount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:157]: Executing op: ComponentRegister(ComponentId={DCE1319A-9499-49D1-80A4-416F246CF399},KeyPath=C:\Program Files\Safari\Safari.resources\SnippetEditor\SnippetEditor.js,State=3,,Disk=1,SharedDllRef Count=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:157]: Executing op: ComponentRegister(ComponentId={D7B7E548-7026-4476-8D50-8E7E64955A9E},KeyPath=C:\Program Files\Safari\Safari.resources\SnippetEditor\Images\buttonBarBackground.png,State=3,,Disk= 1,SharedDllRefCount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:157]: Executing op: ComponentRegister(ComponentId={4F260669-A880-4B84-BA79-CF35616D5E7C},KeyPath=C:\Program Files\Safari\Safari.resources\SnippetEditor\Images\buttonBarBackgroundInactive.png,State= 3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:157]: Executing op: ComponentRegister(ComponentId={9213685C-0067-46C3-83CB-C70D5D3DDBBF},KeyPath=C:\Program Files\Safari\Safari.resources\SnippetEditor\Images\splitterBar.png,State=3,,Disk=1,Shared DllRefCount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:157]: Executing op: ComponentRegister(ComponentId={65AE12C8-39B5-4B96-BA78-E5A5F1C04808},KeyPath=C:\Program Files\Safari\Safari.resources\SnippetEditor\Images\splitterBarInactive.png,State=3,,Disk= 1,SharedDllRefCount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:157]: Executing op: ComponentRegister(ComponentId={AE2B22BA-60D7-49C8-AAE2-AB181DF72838},KeyPath=C:\Program Files\Safari\Safari.resources\SnippetEditor\Images\splitterDimple.png,State=3,,Disk=1,Sha redDllRefCount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:157]: Executing op: ComponentRegister(ComponentId={28A58F9E-902E-4AB7-BD84-484B53582AC6},KeyPath=C:\Program Files\Safari\Safari.resources\SnippetEditor\Images\splitterDimpleInactive.png,State=3,,Di sk=1,SharedDllRefCount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:157]: Executing op: ComponentRegister(ComponentId={38EE49A1-12B1-437A-9385-D97C7B4CEACD},KeyPath=C:\Program Files\Safari\Safari.resources\SnippetEditor\Images\toolbarButton.png,State=3,,Disk=1,Shar edDllRefCount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:157]: Executing op: ComponentRegister(ComponentId={2D932236-F384-45B3-BBA1-4BE5F86062D8},KeyPath=C:\Program Files\Safari\Safari.resources\SnippetEditor\Images\toolbarButtonInactive.png,State=3,,Dis k=1,SharedDllRefCount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:157]: Executing op: ComponentRegister(ComponentId={2B8EA0A0-597F-411B-A3BC-17E58FBA9EB3},KeyPath=C:\Program Files\Safari\Safari.resources\SnippetEditor\Images\toolbarButtonPressed.png,State=3,,Disk =1,SharedDllRefCount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:157]: Executing op: ComponentRegister(ComponentId={E6936742-AB13-4790-9777-2215B1DAB806},KeyPath=C:\Program Files\Safari\Safari.resources\sv.lproj\ABAutoCompleteMappings.plist,State=3,,Disk=1,Share dDllRefCount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:157]: Executing op: ComponentRegister(ComponentId={D5EB4478-8780-442A-A421-503C196E790D},KeyPath=C:\Program Files\Safari\Safari.resources\sv.lproj\bindict,State=3,,Disk=1,SharedDllRefCount=0,Binary Type=0)
                MSI (s) (A4:F8) [11:14:59:157]: Executing op: ComponentRegister(ComponentId={69374CDA-8E10-4B48-89A4-62850120B9F0},KeyPath=C:\Program Files\Safari\Safari.resources\sv.lproj\BuiltInBookmarks.plist,State=3,,Disk=1,SharedDllRe fCount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:157]: Executing op: ComponentRegister(ComponentId={1E6EC71F-9AC2-454E-A949-4496BAEB5BFA},KeyPath=C:\Program Files\Safari\Safari.resources\sv.lproj\Dictionary.dat,State=3,,Disk=1,SharedDllRefCount=0 ,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:157]: Executing op: ComponentRegister(ComponentId={026E264C-9EC5-433F-8339-AF78248DEF79},KeyPath=C:\Program Files\Safari\Safari.resources\sv.lproj\Localizable.strings,State=3,,Disk=1,SharedDllRefCo unt=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:157]: Executing op: ComponentRegister(ComponentId={C8A7ED80-9A01-4DAD-A371-AC2EF6BEB2BC},KeyPath=C:\Program Files\Safari\Safari.resources\sv.lproj\localizedStrings.js,State=3,,Disk=1,SharedDllRefCo unt=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:157]: Executing op: ComponentRegister(ComponentId={F763E92C-6D7B-41DF-9CFE-1D48FC60AABF},KeyPath=C:\Program Files\Safari\Safari.resources\zh_CN.lproj\ABAutoCompleteMappings.plist,State=3,,Disk=1,Sh aredDllRefCount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:157]: Executing op: ComponentRegister(ComponentId={0C194768-3BCC-44FA-85C5-5661712FC86D},KeyPath=C:\Program Files\Safari\Safari.resources\zh_CN.lproj\BuiltInBookmarks.plist,State=3,,Disk=1,SharedDl lRefCount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:173]: Executing op: ComponentRegister(ComponentId={0D71182A-1892-4FEE-A0B0-2CBE6809B36F},KeyPath=C:\Program Files\Safari\Safari.resources\zh_CN.lproj\Localizable.strings,State=3,,Disk=1,SharedDllRe fCount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:173]: Executing op: ComponentRegister(ComponentId={F7C17EEA-13ED-47BF-977F-A96A8F8E60FA},KeyPath=C:\Program Files\Safari\Safari.resources\zh_CN.lproj\localizedStrings.js,State=3,,Disk=1,SharedDllRe fCount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:173]: Executing op: ComponentRegister(ComponentId={9B16FBAD-875F-417C-8B1F-D7E224051CCF},KeyPath=C:\Program Files\Safari\Safari.resources\zh_TW.lproj\ABAutoCompleteMappings.plist,State=3,,Disk=1,Sh aredDllRefCount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:173]: Executing op: ComponentRegister(ComponentId={34DF87C3-7900-467B-ACF3-5833CEAB6B35},KeyPath=C:\Program Files\Safari\Safari.resources\zh_TW.lproj\BuiltInBookmarks.plist,State=3,,Disk=1,SharedDl lRefCount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:173]: Executing op: ComponentRegister(ComponentId={F5807399-A727-4E17-95A5-637B9B2B331E},KeyPath=C:\Program Files\Safari\Safari.resources\zh_TW.lproj\Localizable.strings,State=3,,Disk=1,SharedDllRe fCount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:173]: Executing op: ComponentRegister(ComponentId={D6992876-4551-4092-AAA0-BA16C90B0C52},KeyPath=C:\Program Files\Safari\Safari.resources\zh_TW.lproj\localizedStrings.js,State=3,,Disk=1,SharedDllRe fCount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:173]: Executing op: ComponentRegister(ComponentId={9550A57B-2A36-4E3F-92F6-7660EC7CA26A},KeyPath=C:\Program Files\Safari\SafariTheme.resources\ArtFile.bin,State=3,,Disk=1,SharedDllRefCount=0,Binary Type=0)
                MSI (s) (A4:F8) [11:14:59:173]: Executing op: ComponentRegister(ComponentId={6CA67AEA-C7A9-4149-B423-00357C75E34E},KeyPath=C:\Program Files\Safari\SafariTheme.resources\Info.plist,State=3,,Disk=1,SharedDllRefCount=0,BinaryT ype=0)
                MSI (s) (A4:F8) [11:14:59:173]: Executing op: ComponentRegister(ComponentId={FDE0D078-B2F8-4B9F-881C-AB77DF576738},KeyPath=C:\Program Files\Safari\SafariTheme.resources\SArtFile.bin,State=3,,Disk=1,SharedDllRefCount=0,Binar yType=0)
                MSI (s) (A4:F8) [11:14:59:173]: Executing op: ComponentRegister(ComponentId={77766AAF-BA7C-4261-B1CC-DE8100AE4A29},KeyPath=C:\Program Files\Safari\PubSub.resources\AlertBottom.tif,State=3,,Disk=1,SharedDllRefCount=0,BinaryT ype=0)
                MSI (s) (A4:F8) [11:14:59:173]: Executing op: ComponentRegister(ComponentId={1A8938E7-BB2B-4AB3-8F5A-8FE8658193A6},KeyPath=C:\Program Files\Safari\PubSub.resources\AlertIcon.tif,State=3,,Disk=1,SharedDllRefCount=0,BinaryTyp e=0)
                MSI (s) (A4:F8) [11:14:59:173]: Executing op: ComponentRegister(ComponentId={A5D35E9C-F443-4BC5-861B-307F42105A7B},KeyPath=C:\Program Files\Safari\PubSub.resources\AlertTop.tif,State=3,,Disk=1,SharedDllRefCount=0,BinaryType =0)
                MSI (s) (A4:F8) [11:14:59:173]: Executing op: ComponentRegister(ComponentId={514CEDCB-6D94-4E3A-8492-60C350FCA25A},KeyPath=C:\Program Files\Safari\PubSub.resources\Articles.js,State=3,,Disk=1,SharedDllRefCount=0,BinaryType= 0)
                MSI (s) (A4:F8) [11:14:59:173]: Executing op: ComponentRegister(ComponentId={9492FE06-8279-4CDE-A3DA-70656ED532C2},KeyPath=C:\Program Files\Safari\PubSub.resources\Bigger.tif,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0 )
                MSI (s) (A4:F8) [11:14:59:173]: Executing op: ComponentRegister(ComponentId={B29B964C-5D75-47E9-8678-9C14CEA5009A},KeyPath=C:\Program Files\Safari\PubSub.resources\BlueBanner.tif,State=3,,Disk=1,SharedDllRefCount=0,BinaryTy pe=0)
                MSI (s) (A4:F8) [11:14:59:173]: Executing op: ComponentRegister(ComponentId={CE00B8C5-90BE-4A01-A5FB-6E9CA4D0D836},KeyPath=C:\Program Files\Safari\PubSub.resources\default.jpg,State=3,,Disk=1,SharedDllRefCount=0,BinaryType= 0)
                MSI (s) (A4:F8) [11:14:59:173]: Executing op: ComponentRegister(ComponentId={64187E96-0C1B-43B7-A0A8-7D725BF75622},KeyPath=C:\Program Files\Safari\PubSub.resources\Enclosure.html,State=3,,Disk=1,SharedDllRefCount=0,BinaryTy pe=0)
                MSI (s) (A4:F8) [11:14:59:173]: Executing op: ComponentRegister(ComponentId={641FE004-D9B1-432C-96CA-3BD4E25AAD11},KeyPath=C:\Program Files\Safari\PubSub.resources\Entries.html,State=3,,Disk=1,SharedDllRefCount=0,BinaryType =0)
                MSI (s) (A4:F8) [11:14:59:173]: Executing op: ComponentRegister(ComponentId={61C89B04-0EEF-4A1E-B974-7FD19FE2F71F},KeyPath=C:\Program Files\Safari\PubSub.resources\Entry.html,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0 )
                MSI (s) (A4:F8) [11:14:59:173]: Executing op: ComponentRegister(ComponentId={037A1CD6-CEA7-4D89-93EE-1258D1FBCE98},KeyPath=C:\Program Files\Safari\PubSub.resources\favicon.tif,State=3,,Disk=1,SharedDllRefCount=0,BinaryType= 0)
                MSI (s) (A4:F8) [11:14:59:173]: Executing op: ComponentRegister(ComponentId={A6D04902-EAC3-47CC-9E07-4F34C27B8F44},KeyPath=C:\Program Files\Safari\PubSub.resources\Feed.html,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:173]: Executing op: ComponentRegister(ComponentId={55494DBE-5D83-4F3A-BF1A-1A30A74FB5E4},KeyPath=C:\Program Files\Safari\PubSub.resources\FeedComplete.html,State=3,,Disk=1,SharedDllRefCount=0,Binar yType=0)
                MSI (s) (A4:F8) [11:14:59:173]: Executing op: ComponentRegister(ComponentId={CD261A27-EA75-49C2-ACD1-E77F306B1A03},KeyPath=C:\Program Files\Safari\PubSub.resources\FeedStatic.html,State=3,,Disk=1,SharedDllRefCount=0,BinaryT ype=0)
                MSI (s) (A4:F8) [11:14:59:173]: Executing op: ComponentRegister(ComponentId={3AF25BE1-ADF7-4E67-B8F5-F17EBBA996CC},KeyPath=C:\Program Files\Safari\PubSub.resources\Friends.html,State=3,,Disk=1,SharedDllRefCount=0,BinaryType =0)
                MSI (s) (A4:F8) [11:14:59:173]: Executing op: ComponentRegister(ComponentId={C02B3C9F-86D2-4670-8D5A-3FD41CD3E784},KeyPath=C:\Program Files\Safari\PubSub.resources\Main.css,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:173]: Executing op: ComponentRegister(ComponentId={B8B30CC5-813F-4AE3-84F1-06D22E886111},KeyPath=C:\Program Files\Safari\PubSub.resources\NextPage.tif,State=3,,Disk=1,SharedDllRefCount=0,BinaryType =0)
                MSI (s) (A4:F8) [11:14:59:188]: Executing op: ComponentRegister(ComponentId={623DBCBD-595E-4DB7-B279-61B2E5169FDD},KeyPath=C:\Program Files\Safari\PubSub.resources\NextPage_Disabled.tif,State=3,,Disk=1,SharedDllRefCount=0,B inaryType=0)
                MSI (s) (A4:F8) [11:14:59:188]: Executing op: ComponentRegister(ComponentId={49E694C9-0733-44BE-BF78-10102E1B6B6D},KeyPath=C:\Program Files\Safari\PubSub.resources\PreviousPage.tif,State=3,,Disk=1,SharedDllRefCount=0,Binary Type=0)
                MSI (s) (A4:F8) [11:14:59:188]: Executing op: ComponentRegister(ComponentId={66977E50-0E5E-4838-BCD1-A4AFB2337798},KeyPath=C:\Program Files\Safari\PubSub.resources\PreviousPage_Disabled.tif,State=3,,Disk=1,SharedDllRefCount =0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:188]: Executing op: ComponentRegister(ComponentId={58E8D482-850B-404F-B133-FAC36AF7D0B1},KeyPath=C:\Program Files\Safari\PubSub.resources\Separator.tif,State=3,,Disk=1,SharedDllRefCount=0,BinaryTyp e=0)
                MSI (s) (A4:F8) [11:14:59:188]: Executing op: ComponentRegister(ComponentId={2087E5B3-123E-4033-862D-B51221AA6247},KeyPath=C:\Program Files\Safari\PubSub.resources\Smaller.tif,State=3,,Disk=1,SharedDllRefCount=0,BinaryType= 0)
                MSI (s) (A4:F8) [11:14:59:188]: Executing op: ComponentRegister(ComponentId={E4EE3394-8E52-4ADF-985A-171678E7D75D},KeyPath=C:\Program Files\Safari\PubSub.resources\Template.png,State=3,,Disk=1,SharedDllRefCount=0,BinaryType =0)
                MSI (s) (A4:F8) [11:14:59:188]: Executing op: ComponentRegister(ComponentId={14151EA0-5872-4ADE-B805-F1C1484413DC},KeyPath=C:\Program Files\Safari\PubSub.resources\unread.tif,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0 )
                MSI (s) (A4:F8) [11:14:59:188]: Executing op: ComponentRegister(ComponentId={C9DDC8DA-DB08-492B-AD2D-E54C4297D367},KeyPath=C:\Program Files\Safari\PubSub.resources\da.lproj\ArticlesL10N.css,State=3,,Disk=1,SharedDllRefCount =0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:188]: Executing op: ComponentRegister(ComponentId={7457ABBF-78E3-4C19-B2E2-DC3B7773B912},KeyPath=C:\Program Files\Safari\PubSub.resources\da.lproj\Localizable.strings,State=3,,Disk=1,SharedDllRefCo unt=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:188]: Executing op: ComponentRegister(ComponentId={20DBF422-3960-4F3E-8CED-606231AC5B11},KeyPath=C:\Program Files\Safari\PubSub.resources\de.lproj\ArticlesL10N.css,State=3,,Disk=1,SharedDllRefCount =0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:188]: Executing op: ComponentRegister(ComponentId={2CF63A19-6F13-4604-A780-6B764C4158E0},KeyPath=C:\Program Files\Safari\PubSub.resources\de.lproj\Localizable.strings,State=3,,Disk=1,SharedDllRefCo unt=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:188]: Executing op: ComponentRegister(ComponentId={2A868C94-403D-45AA-AF3D-A84EE3B445FA},KeyPath=C:\Program Files\Safari\PubSub.resources\English.lproj\ArticlesL10N.css,State=3,,Disk=1,SharedDllRef Count=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:188]: Executing op: ComponentRegister(ComponentId={57CC997A-352E-4876-A5E4-BC0275D3D574},KeyPath=C:\Program Files\Safari\PubSub.resources\English.lproj\Localizable.strings,State=3,,Disk=1,SharedDll RefCount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:188]: Executing op: ComponentRegister(ComponentId={E8C0153C-473A-48A0-942E-685FACFA25AB},KeyPath=C:\Program Files\Safari\PubSub.resources\es.lproj\ArticlesL10N.css,State=3,,Disk=1,SharedDllRefCount =0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:188]: Executing op: ComponentRegister(ComponentId={D72DFA36-1833-45F7-B814-BB1C8FC0E1C8},KeyPath=C:\Program Files\Safari\PubSub.resources\es.lproj\Localizable.strings,State=3,,Disk=1,SharedDllRefCo unt=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:188]: Executing op: ComponentRegister(ComponentId={D98FE533-B8DC-4FCA-8FA9-E166363E81DB},KeyPath=C:\Program Files\Safari\PubSub.resources\fi.lproj\ArticlesL10N.css,State=3,,Disk=1,SharedDllRefCount =0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:188]: Executing op: ComponentRegister(ComponentId={3E9561BB-0745-4704-B01D-3CB5BA144D4F},KeyPath=C:\Program Files\Safari\PubSub.resources\fi.lproj\Localizable.strings,State=3,,Disk=1,SharedDllRefCo unt=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:188]: Executing op: ComponentRegister(ComponentId={5EBC06E8-5964-44BC-B410-A81B6E0F2914},KeyPath=C:\Program Files\Safari\PubSub.resources\fr.lproj\ArticlesL10N.css,State=3,,Disk=1,SharedDllRefCount =0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:188]: Executing op: ComponentRegister(ComponentId={898339F0-28B8-4BC6-A6DD-948BA1F17D80},KeyPath=C:\Program Files\Safari\PubSub.resources\fr.lproj\Localizable.strings,State=3,,Disk=1,SharedDllRefCo unt=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:188]: Executing op: ComponentRegister(ComponentId={8FAA258A-551A-4BA6-BBE1-ACB5CE2866D5},KeyPath=C:\Program Files\Safari\PubSub.resources\Framework\templates.lua,State=3,,Disk=1,SharedDllRefCount=0 ,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:188]: Executing op: ComponentRegister(ComponentId={C64259D9-962D-4408-A287-F48E1522413C},KeyPath=C:\Program Files\Safari\PubSub.resources\Framework\da.lproj\Localizable.strings,State=3,,Disk=1,Shar edDllRefCount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:188]: Executing op: ComponentRegister(ComponentId={675C864A-942F-4A74-93A8-C1CA98779189},KeyPath=C:\Program Files\Safari\PubSub.resources\Framework\de.lproj\Localizable.strings,State=3,,Disk=1,Shar edDllRefCount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:188]: Executing op: ComponentRegister(ComponentId={2889FF24-DE4E-41CE-97FB-EEE25A510D92},KeyPath=C:\Program Files\Safari\PubSub.resources\Framework\English.lproj\Localizable.strings,State=3,,Disk=1 ,SharedDllRefCount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:188]: Executing op: ComponentRegister(ComponentId={8CF8BC49-E796-46FE-A2DA-3ABD1A8C2B18},KeyPath=C:\Program Files\Safari\PubSub.resources\Framework\es.lproj\Localizable.strings,State=3,,Disk=1,Shar edDllRefCount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:188]: Executing op: ComponentRegister(ComponentId={CC9C1F14-1150-4C58-8337-9D80B9EB2B9F},KeyPath=C:\Program Files\Safari\PubSub.resources\Framework\fi.lproj\Localizable.strings,State=3,,Disk=1,Shar edDllRefCount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:204]: Executing op: ComponentRegister(ComponentId={1CB95511-C478-4E46-9BA3-7F7C17A0E30F},KeyPath=C:\Program Files\Safari\PubSub.resources\Framework\fr.lproj\Localizable.strings,State=3,,Disk=1,Shar edDllRefCount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:204]: Executing op: ComponentRegister(ComponentId={376AB08F-80C5-4D74-820A-7A9D82459E69},KeyPath=C:\Program Files\Safari\PubSub.resources\Framework\it.lproj\Localizable.strings,State=3,,Disk=1,Shar edDllRefCount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:204]: Executing op: ComponentRegister(ComponentId={9F54366E-3EDE-4D9C-BDD0-5A59FE5882C8},KeyPath=C:\Program Files\Safari\PubSub.resources\Framework\ja.lproj\Localizable.strings,State=3,,Disk=1,Shar edDllRefCount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:204]: Executing op: ComponentRegister(ComponentId={3803FF54-1310-41CB-933B-6A31448CFA2A},KeyPath=C:\Program Files\Safari\PubSub.resources\Framework\ko.lproj\Localizable.strings,State=3,,Disk=1,Shar edDllRefCount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:204]: Executing op: ComponentRegister(ComponentId={03A88D83-53D1-4BF8-BAA2-91A79A8297D2},KeyPath=C:\Program Files\Safari\PubSub.resources\Framework\nb.lproj\Localizable.strings,State=3,,Disk=1,Shar edDllRefCount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:204]: Executing op: ComponentRegister(ComponentId={CDE661C7-842E-4BB8-B8F2-23470C5F9280},KeyPath=C:\Program Files\Safari\PubSub.resources\Framework\nl.lproj\Localizable.strings,State=3,,Disk=1,Shar edDllRefCount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:204]: Executing op: ComponentRegister(ComponentId={5C555782-E7D5-468D-9E22-2D4D8A9639FB},KeyPath=C:\Program Files\Safari\PubSub.resources\Framework\pl.lproj\Localizable.strings,State=3,,Disk=1,Shar edDllRefCount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:204]: Executing op: ComponentRegister(ComponentId={DB62BD34-F30D-4021-809F-06754D43E306},KeyPath=C:\Program Files\Safari\PubSub.resources\Framework\pt.lproj\Localizable.strings,State=3,,Disk=1,Shar edDllRefCount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:204]: Executing op: ComponentRegister(ComponentId={AAEB1028-96AD-4A8E-B5CA-01B5CE738A7F},KeyPath=C:\Program Files\Safari\PubSub.resources\Framework\pt_PT.lproj\Localizable.strings,State=3,,Disk=1,S haredDllRefCount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:204]: Executing op: ComponentRegister(ComponentId={7DE6352D-EEA8-4865-83D8-D3E636076BA7},KeyPath=C:\Program Files\Safari\PubSub.resources\Framework\ru.lproj\Localizable.strings,State=3,,Disk=1,Shar edDllRefCount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:204]: Executing op: ComponentRegister(ComponentId={5EB7198E-856B-4CCC-9BAC-B20D6058A3A2},KeyPath=C:\Program Files\Safari\PubSub.resources\Framework\sv.lproj\Localizable.strings,State=3,,Disk=1,Shar edDllRefCount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:204]: Executing op: ComponentRegister(ComponentId={E614F1E8-A905-4A69-A34F-9780466A9009},KeyPath=C:\Program Files\Safari\PubSub.resources\Framework\zh_CN.lproj\Localizable.strings,State=3,,Disk=1,S haredDllRefCount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:204]: Executing op: ComponentRegister(ComponentId={A331DD1C-5955-43BF-BF8A-7F731C0EF244},KeyPath=C:\Program Files\Safari\PubSub.resources\Framework\zh_TW.lproj\Localizable.strings,State=3,,Disk=1,S haredDllRefCount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:204]: Executing op: ComponentRegister(ComponentId={3B7A243C-4479-4BEA-BCCE-DDF6B53F8251},KeyPath=C:\Program Files\Safari\PubSub.resources\it.lproj\ArticlesL10N.css,State=3,,Disk=1,SharedDllRefCount =0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:204]: Executing op: ComponentRegister(ComponentId={92972052-D243-4457-A4D7-B3192FAEC683},KeyPath=C:\Program Files\Safari\PubSub.resources\it.lproj\Localizable.strings,State=3,,Disk=1,SharedDllRefCo unt=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:204]: Executing op: ComponentRegister(ComponentId={FC416D96-75FB-4564-90D3-F98EDC306737},KeyPath=C:\Program Files\Safari\PubSub.resources\ja.lproj\ArticlesL10N.css,State=3,,Disk=1,SharedDllRefCount =0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:204]: Executing op: ComponentRegister(ComponentId={95499402-D380-44D0-BD0A-44F113F65C97},KeyPath=C:\Program Files\Safari\PubSub.resources\ja.lproj\Localizable.strings,State=3,,Disk=1,SharedDllRefCo unt=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:204]: Executing op: ComponentRegister(ComponentId={9D768861-26F2-41CC-8A8F-3E0B03292204},KeyPath=C:\Program Files\Safari\PubSub.resources\ko.lproj\ArticlesL10N.css,State=3,,Disk=1,SharedDllRefCount =0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:204]: Executing op: ComponentRegister(ComponentId={73291BFB-6907-4362-9D8D-5D5CF48F8356},KeyPath=C:\Program Files\Safari\PubSub.resources\ko.lproj\Localizable.strings,State=3,,Disk=1,SharedDllRefCo unt=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:204]: Executing op: ComponentRegister(ComponentId={D6B4E106-21D1-44A0-B2F3-04B74B71F0D7},KeyPath=C:\Program Files\Safari\PubSub.resources\nb.lproj\ArticlesL10N.css,State=3,,Disk=1,SharedDllRefCount =0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:204]: Executing op: ComponentRegister(ComponentId={BD1C8BBA-9503-412C-85D4-63C3E4113E17},KeyPath=C:\Program Files\Safari\PubSub.resources\nb.lproj\Localizable.strings,State=3,,Disk=1,SharedDllRefCo unt=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:204]: Executing op: ComponentRegister(ComponentId={2F8F5C80-B8B5-495A-9690-BAB2AFBEE3B8},KeyPath=C:\Program Files\Safari\PubSub.resources\nl.lproj\ArticlesL10N.css,State=3,,Disk=1,SharedDllRefCount =0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:204]: Executing op: ComponentRegister(ComponentId={B67CCD0A-AA29-4570-BD0A-F19D0ED1330E},KeyPath=C:\Program Files\Safari\PubSub.resources\nl.lproj\Localizable.strings,State=3,,Disk=1,SharedDllRefCo unt=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:204]: Executing op: ComponentRegister(ComponentId={E46C831F-2345-4DF7-A7B0-45FCD7FD0CDF},KeyPath=C:\Program Files\Safari\PubSub.resources\pl.lproj\ArticlesL10N.css,State=3,,Disk=1,SharedDllRefCount =0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:204]: Executing op: ComponentRegister(ComponentId={ABD19D19-52A0-4934-8D9D-1EED7D32F2A2},KeyPath=C:\Program Files\Safari\PubSub.resources\pl.lproj\Localizable.strings,State=3,,Disk=1,SharedDllRefCo unt=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:220]: Executing op: ComponentRegister(ComponentId={95555BBD-73FB-4DE2-9C03-4F099AA6BA4C},KeyPath=C:\Program Files\Safari\PubSub.resources\pt.lproj\ArticlesL10N.css,State=3,,Disk=1,SharedDllRefCount =0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:220]: Executing op: ComponentRegister(ComponentId={AA07A0AC-71FD-45A1-AA59-71A331269430},KeyPath=C:\Program Files\Safari\PubSub.resources\pt.lproj\Localizable.strings,State=3,,Disk=1,SharedDllRefCo unt=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:220]: Executing op: ComponentRegister(ComponentId={52E25D1C-80A8-41CC-9789-D7D2D571C6B8},KeyPath=C:\Program Files\Safari\PubSub.resources\pt_PT.lproj\ArticlesL10N.css,State=3,,Disk=1,SharedDllRefCo unt=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:220]: Executing op: ComponentRegister(ComponentId={AF89800F-E11B-4E95-85CE-B403D244C81E},KeyPath=C:\Program Files\Safari\PubSub.resources\pt_PT.lproj\Localizable.strings,State=3,,Disk=1,SharedDllRe fCount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:220]: Executing op: ComponentRegister(ComponentId={54FA08B0-AE4E-45C5-9FEC-B75E70CA0F2A},KeyPath=C:\Program Files\Safari\PubSub.resources\ru.lproj\ArticlesL10N.css,State=3,,Disk=1,SharedDllRefCount =0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:220]: Executing op: ComponentRegister(ComponentId={AED3F586-CAB1-4844-8742-A2321B60ABC5},KeyPath=C:\Program Files\Safari\PubSub.resources\ru.lproj\Localizable.strings,State=3,,Disk=1,SharedDllRefCo unt=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:220]: Executing op: ComponentRegister(ComponentId={02A52876-695B-4971-BCEA-83FDDD753C25},KeyPath=C:\Program Files\Safari\PubSub.resources\sv.lproj\ArticlesL10N.css,State=3,,Disk=1,SharedDllRefCount =0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:220]: Executing op: ComponentRegister(ComponentId={52BE3F58-F0BD-497E-A3E9-087993A37ABC},KeyPath=C:\Program Files\Safari\PubSub.resources\sv.lproj\Localizable.strings,State=3,,Disk=1,SharedDllRefCo unt=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:220]: Executing op: ComponentRegister(ComponentId={E0D4DF74-2481-4C73-A7FE-1743B3EB7436},KeyPath=C:\Program Files\Safari\PubSub.resources\zh_CN.lproj\ArticlesL10N.css,State=3,,Disk=1,SharedDllRefCo unt=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:220]: Executing op: ComponentRegister(ComponentId={1F0CA152-91D4-4990-8AC2-E502403F94CE},KeyPath=C:\Program Files\Safari\PubSub.resources\zh_CN.lproj\Localizable.strings,State=3,,Disk=1,SharedDllRe fCount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:220]: Executing op: ComponentRegister(ComponentId={F984E9C0-348F-4B81-9693-E41A1C69D37E},KeyPath=C:\Program Files\Safari\PubSub.resources\zh_TW.lproj\ArticlesL10N.css,State=3,,Disk=1,SharedDllRefCo unt=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:220]: Executing op: ComponentRegister(ComponentId={DA564798-F376-41E6-8578-9C274ABB05C8},KeyPath=C:\Program Files\Safari\PubSub.resources\zh_TW.lproj\Localizable.strings,State=3,,Disk=1,SharedDllRe fCount=0,BinaryType=0)
                MSI (s) (A4:F8) [11:14:59:220]: Executing op: ActionStart(Name=RemoveRegistryValues,Description=Removing system registry values,Template=Key: [1], Name: [2])
                MSI (s) (A4:F8) [11:14:59:220]: Executing op: ProgressTotal(Total=1,Type=1,ByteEquivalent=13200)
                MSI (s) (A4:F8) [11:14:59:220]: Executing op: RegOpenKey(Root=-2147483646,Key=SOFTWARE\Apple Computer, Inc.\Safari\ASUNewSoftware,,BinaryType=0,)
                MSI (s) (A4:F8) [11:14:59:220]: Executing op: RegRemoveKey()
                MSI (s) (A4:F8) [11:14:59:220]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE\SOFTWARE\Apple Computer, Inc.\Safari\ASUNewSoftware 3: 2
                MSI (s) (A4:F8) [11:14:59:220]: Executing op: ActionStart(Name=CreateFolders,Description=Creating folders,Template=Folder: [1])
                MSI (s) (A4:F8) [11:14:59:220]: Executing op: FolderCreate(Folder=C:\Program Files\Safari\,Foreign=0,)
                MSI (s) (A4:F8) [11:14:59:220]: Executing op: FolderCreate(Folder=C:\Users\Public\Desktop\,Foreign=0,)
                MSI (s) (A4:F8) [11:14:59:220]: Executing op: FolderCreate(Folder=C:\ProgramData\Apple Computer\Installer Cache\Safari 5.34.52.7\,Foreign=0,)
                MSI (s) (A4:F8) [11:14:59:220]: Executing op: ActionStart(Name=InstallFiles,Description=Copying new files,Template=File: [1],  Directory: [9],  Size: [6])
                MSI (s) (A4:F8) [11:14:59:220]: Executing op: SetTargetFolder(Folder=C:\Program Files\Safari\Plugins\)
                MSI (s) (A4:F8) [11:14:59:220]: Executing op: SetSourceFolder(Folder=1\Safari\Plugins\)
                MSI (s) (A4:F8) [11:14:59:220]: Executing op: ChangeMedia(,MediaPrompt=Please insert the disk: ,MediaCabinet=Safari.cab,BytesPerTick=32768,CopierType=2,ModuleFileName=1\Safari.msi,,,,, IsFirstPhysicalMedia=1)
                MSI (s) (A4:F8) [11:14:59:220]: Executing op: FileCopy(SourceName=u6ikv5wh.jar|JavaPlugin.jar,SourceCabKey=JavaPlugin.jar,DestName=Java Plugin.jar,Attributes=512,FileSize=56970,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,Ins tallMode=59113472,HashOptions=0,HashPart1=1594335644,HashPart2=1703122173,HashPart3=196455 1953,HashPart4=-860335580,,)
                MSI (s) (A4:F8) [11:14:59:235]: File: C:\Program Files\Safari\Plugins\JavaPlugin.jar;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:235]: Executing op: RegisterSharedComponentProvider(,,File=npJavaPlugin.dll,Component={C9D66122-C3EB-4234-85F D-F5A7561E03EC},ComponentVersion=5.34.51.13,ProductCode={F2AF3E5D-9697-485C-A5AC-E2B9468C4 46A},ProductVersion=5.34.52,PatchSize=0,PatchAttributes=0,PatchSequence=0,SharedComponent= 0,IsFullFile=0)
                MSI (s) (A4:F8) [11:14:59:235]: Executing op: FileCopy(SourceName=qsg2rc24.dll|npJavaPlugin.dll,SourceCabKey=npJavaPlugin.dll,DestName= npJavaPlugin.dll,Attributes=512,FileSize=63336,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0 ,Version=5.34.51.13,Language=1033,InstallMode=59113472,,,,,,,)
                MSI (s) (A4:F8) [11:14:59:235]: File: C:\Program Files\Safari\Plugins\npJavaPlugin.dll;          Won't Overwrite;          Won't patch;          Existing file is of an equal version
                MSI (s) (A4:F8) [11:14:59:235]: Executing op: SetTargetFolder(Folder=C:\Program Files\Safari\PubSub.resources\)
                MSI (s) (A4:F8) [11:14:59:235]: Executing op: SetSourceFolder(Folder=1\Safari\235bwbkb\|Safari\PubSub.resources\)
                MSI (s) (A4:F8) [11:14:59:235]: Executing op: FileCopy(SourceName=6ianbrns.tif|AlertBottom.tif,SourceCabKey=PubSub.resources_AlertBotto m.tif,DestName=AlertBottom.tif,Attributes=512,FileSize=380,PerTick=32768,,VerifyMedia=1,,, ,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=1878008692,HashPart2=874693411 ,HashPart3=1812127867,HashPart4=1549925146,,)
                MSI (s) (A4:F8) [11:14:59:235]: File: C:\Program Files\Safari\PubSub.resources\AlertBottom.tif;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:235]: Executing op: FileCopy(SourceName=baelfvkd.tif|AlertIcon.tif,SourceCabKey=PubSub.resources_AlertIcon.ti f,DestName=AlertIcon.tif,Attributes=512,FileSize=1940,PerTick=32768,,VerifyMedia=1,,,,,Che ckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=-321879992,HashPart2=922445406,Hash Part3=-2074780560,HashPart4=-508319693,,)
                MSI (s) (A4:F8) [11:14:59:235]: File: C:\Program Files\Safari\PubSub.resources\AlertIcon.tif;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:235]: Executing op: FileCopy(SourceName=AlertTop.tif,SourceCabKey=PubSub.resources_AlertTop.tif,DestName=Aler tTop.tif,Attributes=512,FileSize=316,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,Install Mode=59113472,HashOptions=0,HashPart1=-546191239,HashPart2=1293154909,HashPart3=-142895486 9,HashPart4=-1874090675,,)
                MSI (s) (A4:F8) [11:14:59:235]: File: C:\Program Files\Safari\PubSub.resources\AlertTop.tif;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:235]: Executing op: FileCopy(SourceName=Articles.js,SourceCabKey=PubSub.resources_Articles.js,DestName=Articl es.js,Attributes=512,FileSize=49016,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallM ode=59113472,HashOptions=0,HashPart1=-660441581,HashPart2=-1246100503,HashPart3=-101965979 2,HashPart4=951273375,,)
                MSI (s) (A4:F8) [11:14:59:235]: File: C:\Program Files\Safari\PubSub.resources\Articles.js;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:235]: Executing op: FileCopy(SourceName=Bigger.tif,SourceCabKey=PubSub.resources_Bigger.tif,DestName=Bigger.t if,Attributes=512,FileSize=286,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=5 9113472,HashOptions=0,HashPart1=347302072,HashPart2=-822286703,HashPart3=973703687,HashPar t4=521624858,,)
                MSI (s) (A4:F8) [11:14:59:235]: File: C:\Program Files\Safari\PubSub.resources\Bigger.tif;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:235]: Executing op: FileCopy(SourceName=-8lzmq68.tif|BlueBanner.tif,SourceCabKey=PubSub.resources_BlueBanner. tif,DestName=BlueBanner.tif,Attributes=512,FileSize=3536,PerTick=32768,,VerifyMedia=1,,,,, CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=-565534915,HashPart2=-1856859526 ,HashPart3=-1259182328,HashPart4=2130794403,,)
                MSI (s) (A4:F8) [11:14:59:235]: File: C:\Program Files\Safari\PubSub.resources\BlueBanner.tif;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:235]: Executing op: SetTargetFolder(Folder=C:\Program Files\Safari\PubSub.resources\da.lproj\)
                MSI (s) (A4:F8) [11:14:59:235]: Executing op: SetSourceFolder(Folder=1\Safari\235bwbkb\lz19wsb5\|Safari\PubSub.resources\da.lproj\)
                MSI (s) (A4:F8) [11:14:59:235]: Executing op: FileCopy(SourceName=nrghab_t.css|ArticlesL10N.css,SourceCabKey=PubSub.resources_da.lproj_ ArticlesL10N.css,DestName=ArticlesL10N.css,Attributes=512,FileSize=986,PerTick=32768,,Veri fyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=1501132326,HashPar t2=-640592964,HashPart3=1012314243,HashPart4=-1287968752,,)
                MSI (s) (A4:F8) [11:14:59:251]: File: C:\Program Files\Safari\PubSub.resources\da.lproj\ArticlesL10N.css;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:251]: Executing op: FileCopy(SourceName=5ogpzcvf.str|Localizable.strings,SourceCabKey=PubSub.resources_da.lpr oj_Localizable.strings,DestName=Localizable.strings,Attributes=512,FileSize=7786,PerTick=3 2768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=-2616035 58,HashPart2=-1986553843,HashPart3=-2045053807,HashPart4=-1408916786,,)
                MSI (s) (A4:F8) [11:14:59:251]: File: C:\Program Files\Safari\PubSub.resources\da.lproj\Localizable.strings;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:251]: Executing op: SetTargetFolder(Folder=C:\Program Files\Safari\PubSub.resources\de.lproj\)
                MSI (s) (A4:F8) [11:14:59:251]: Executing op: SetSourceFolder(Folder=1\Safari\235bwbkb\kbb8aw_t\|Safari\PubSub.resources\de.lproj\)
                MSI (s) (A4:F8) [11:14:59:251]: Executing op: FileCopy(SourceName=ztop5s6i.css|ArticlesL10N.css,SourceCabKey=PubSub.resources_de.lproj_ ArticlesL10N.css,DestName=ArticlesL10N.css,Attributes=512,FileSize=986,PerTick=32768,,Veri fyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=1086971035,HashPar t2=-294069943,HashPart3=1792926131,HashPart4=687714880,,)
                MSI (s) (A4:F8) [11:14:59:251]: File: C:\Program Files\Safari\PubSub.resources\de.lproj\ArticlesL10N.css;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:251]: Executing op: FileCopy(SourceName=gxbetcfm.str|Localizable.strings,SourceCabKey=PubSub.resources_de.lpr oj_Localizable.strings,DestName=Localizable.strings,Attributes=512,FileSize=8254,PerTick=3 2768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=-5402794 04,HashPart2=-1613470797,HashPart3=-90545537,HashPart4=1005870062,,)
                MSI (s) (A4:F8) [11:14:59:251]: File: C:\Program Files\Safari\PubSub.resources\de.lproj\Localizable.strings;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:251]: Executing op: SetTargetFolder(Folder=C:\Program Files\Safari\PubSub.resources\)
                MSI (s) (A4:F8) [11:14:59:251]: Executing op: SetSourceFolder(Folder=1\Safari\235bwbkb\|Safari\PubSub.resources\)
                MSI (s) (A4:F8) [11:14:59:251]: Executing op: FileCopy(SourceName=default.jpg,SourceCabKey=PubSub.resources_default.jpg,DestName=defaul t.jpg,Attributes=512,FileSize=73766,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallM ode=59113472,HashOptions=0,HashPart1=-1797821464,HashPart2=-570549276,HashPart3=1559678247 ,HashPart4=-543471182,,)
                MSI (s) (A4:F8) [11:14:59:251]: File: C:\Program Files\Safari\PubSub.resources\default.jpg;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:251]: Executing op: FileCopy(SourceName=jeuyzzab.htm|Enclosure.html,SourceCabKey=PubSub.resources_Enclosure.h tml,DestName=Enclosure.html,Attributes=512,FileSize=1119,PerTick=32768,,VerifyMedia=1,,,,, CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=1183246773,HashPart2=-1699744431 ,HashPart3=1531453754,HashPart4=-1194471197,,)
                MSI (s) (A4:F8) [11:14:59:251]: File: C:\Program Files\Safari\PubSub.resources\Enclosure.html;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:251]: Executing op: SetTargetFolder(Folder=C:\Program Files\Safari\PubSub.resources\English.lproj\)
                MSI (s) (A4:F8) [11:14:59:251]: Executing op: SetSourceFolder(Folder=1\Safari\235bwbkb\przoyjgq\|Safari\PubSub.resources\English.lproj\ )
                MSI (s) (A4:F8) [11:14:59:251]: Executing op: FileCopy(SourceName=tvp9-9l3.css|ArticlesL10N.css,SourceCabKey=PubSub.resources_English.l proj_ArticlesL10N.css,DestName=ArticlesL10N.css,Attributes=512,FileSize=990,PerTick=32768, ,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=1640133385,Ha shPart2=-766028874,HashPart3=-1787944362,HashPart4=-885963890,,)
                MSI (s) (A4:F8) [11:14:59:251]: File: C:\Program Files\Safari\PubSub.resources\English.lproj\ArticlesL10N.css;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:251]: Executing op: FileCopy(SourceName=9y_h_wm5.str|Localizable.strings,SourceCabKey=PubSub.resources_Englis h.lproj_Localizable.strings,DestName=Localizable.strings,Attributes=512,FileSize=7706,PerT ick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=194 3298016,HashPart2=778285212,HashPart3=258024000,HashPart4=198505983,,)
                MSI (s) (A4:F8) [11:14:59:251]: File: C:\Program Files\Safari\PubSub.resources\English.lproj\Localizable.strings;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:251]: Executing op: FileCopy(SourceName=lklnk-2g.htm|Entries.html,SourceCabKey=PubSub.resources_Entries.html, DestName=Entries.html,Attributes=512,FileSize=1480,PerTick=32768,,VerifyMedia=1,,,,,CheckC RC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=-955028985,HashPart2=-1390480637,HashP art3=1096598073,HashPart4=-479315023,,)
                MSI (s) (A4:F8) [11:14:59:251]: File: C:\Program Files\Safari\PubSub.resources\Entries.html;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:251]: Executing op: FileCopy(SourceName=zcf4bmaz.htm|Entry.html,SourceCabKey=PubSub.resources_Entry.html,Dest Name=Entry.html,Attributes=512,FileSize=3526,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,, ,InstallMode=59113472,HashOptions=0,HashPart1=620382690,HashPart2=543682327,HashPart3=-495 346332,HashPart4=-2025405974,,)
                MSI (s) (A4:F8) [11:14:59:251]: File: C:\Program Files\Safari\PubSub.resources\Entry.html;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:251]: Executing op: SetTargetFolder(Folder=C:\Program Files\Safari\PubSub.resources\es.lproj\)
                MSI (s) (A4:F8) [11:14:59:251]: Executing op: SetSourceFolder(Folder=1\Safari\235bwbkb\v2gdxgab\|Safari\PubSub.resources\es.lproj\)
                MSI (s) (A4:F8) [11:14:59:251]: Executing op: FileCopy(SourceName=risznkvf.css|ArticlesL10N.css,SourceCabKey=PubSub.resources_es.lproj_ ArticlesL10N.css,DestName=ArticlesL10N.css,Attributes=512,FileSize=985,PerTick=32768,,Veri fyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=-2108948396,HashPa rt2=-1841222828,HashPart3=1714738698,HashPart4=-956688745,,)
                MSI (s) (A4:F8) [11:14:59:251]: File: C:\Program Files\Safari\PubSub.resources\es.lproj\ArticlesL10N.css;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:251]: Executing op: FileCopy(SourceName=qkjkqjao.str|Localizable.strings,SourceCabKey=PubSub.resources_es.lpr oj_Localizable.strings,DestName=Localizable.strings,Attributes=512,FileSize=8166,PerTick=3 2768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=16284081 80,HashPart2=1005710401,HashPart3=1231007807,HashPart4=-2085362898,,)
                MSI (s) (A4:F8) [11:14:59:251]: File: C:\Program Files\Safari\PubSub.resources\es.lproj\Localizable.strings;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:251]: Executing op: FileCopy(SourceName=favicon.tif,SourceCabKey=PubSub.resources_favicon.tif,DestName=favico n.tif,Attributes=512,FileSize=806,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMod e=59113472,HashOptions=0,HashPart1=-1976098102,HashPart2=-2029004909,HashPart3=2078015334, HashPart4=1487540035,,)
                MSI (s) (A4:F8) [11:14:59:266]: File: C:\Program Files\Safari\PubSub.resources\favicon.tif;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:266]: Executing op: FileCopy(SourceName=exjxopme.htm|Feed.html,SourceCabKey=PubSub.resources_Feed.html,DestNa me=Feed.html,Attributes=512,FileSize=11156,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,I nstallMode=59113472,HashOptions=0,HashPart1=1059773077,HashPart2=-1164640626,HashPart3=814 178314,HashPart4=1910529519,,)
                MSI (s) (A4:F8) [11:14:59:266]: File: C:\Program Files\Safari\PubSub.resources\Feed.html;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:266]: Executing op: FileCopy(SourceName=auvrwszo.htm|FeedComplete.html,SourceCabKey=PubSub.resources_FeedComp lete.html,DestName=FeedComplete.html,Attributes=512,FileSize=1609,PerTick=32768,,VerifyMed ia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=1022642969,HashPart2=37 7943266,HashPart3=-123329076,HashPart4=1537618676,,)
                MSI (s) (A4:F8) [11:14:59:266]: File: C:\Program Files\Safari\PubSub.resources\FeedComplete.html;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:266]: Executing op: FileCopy(SourceName=ugiwq8hm.htm|FeedStatic.html,SourceCabKey=PubSub.resources_FeedStatic .html,DestName=FeedStatic.html,Attributes=512,FileSize=2301,PerTick=32768,,VerifyMedia=1,, ,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=-1787234086,HashPart2=2105474 827,HashPart3=1558352904,HashPart4=-1817727697,,)
                MSI (s) (A4:F8) [11:14:59:266]: File: C:\Program Files\Safari\PubSub.resources\FeedStatic.html;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:266]: Executing op: SetTargetFolder(Folder=C:\Program Files\Safari\PubSub.resources\fi.lproj\)
                MSI (s) (A4:F8) [11:14:59:266]: Executing op: SetSourceFolder(Folder=1\Safari\235bwbkb\gffelesw\|Safari\PubSub.resources\fi.lproj\)
                MSI (s) (A4:F8) [11:14:59:266]: Executing op: FileCopy(SourceName=xi9cx_x3.css|ArticlesL10N.css,SourceCabKey=PubSub.resources_fi.lproj_ ArticlesL10N.css,DestName=ArticlesL10N.css,Attributes=512,FileSize=985,PerTick=32768,,Veri fyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=-1868988328,HashPa rt2=-1202252219,HashPart3=-1394136102,HashPart4=193559469,,)
                MSI (s) (A4:F8) [11:14:59:266]: File: C:\Program Files\Safari\PubSub.resources\fi.lproj\ArticlesL10N.css;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:266]: Executing op: FileCopy(SourceName=uv2xfvhk.str|Localizable.strings,SourceCabKey=PubSub.resources_fi.lpr oj_Localizable.strings,DestName=Localizable.strings,Attributes=512,FileSize=7956,PerTick=3 2768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=-1063066 393,HashPart2=2116764205,HashPart3=-206086605,HashPart4=-1885132135,,)
                MSI (s) (A4:F8) [11:14:59:266]: File: C:\Program Files\Safari\PubSub.resources\fi.lproj\Localizable.strings;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:266]: Executing op: SetTargetFolder(Folder=C:\Program Files\Safari\PubSub.resources\fr.lproj\)
                MSI (s) (A4:F8) [11:14:59:266]: Executing op: SetSourceFolder(Folder=1\Safari\235bwbkb\p5lizcp8\|Safari\PubSub.resources\fr.lproj\)
                MSI (s) (A4:F8) [11:14:59:266]: Executing op: FileCopy(SourceName=tld39aeq.css|ArticlesL10N.css,SourceCabKey=PubSub.resources_fr.lproj_ ArticlesL10N.css,DestName=ArticlesL10N.css,Attributes=512,FileSize=987,PerTick=32768,,Veri fyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=-1772634056,HashPa rt2=-1860711653,HashPart3=-2039842518,HashPart4=-1952323186,,)
                MSI (s) (A4:F8) [11:14:59:266]: File: C:\Program Files\Safari\PubSub.resources\fr.lproj\ArticlesL10N.css;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:266]: Executing op: FileCopy(SourceName=rq1x0w8v.str|Localizable.strings,SourceCabKey=PubSub.resources_fr.lpr oj_Localizable.strings,DestName=Localizable.strings,Attributes=512,FileSize=8322,PerTick=3 2768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=-9735021 68,HashPart2=-272671983,HashPart3=1123347438,HashPart4=1903150711,,)
                MSI (s) (A4:F8) [11:14:59:266]: File: C:\Program Files\Safari\PubSub.resources\fr.lproj\Localizable.strings;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:266]: Executing op: SetTargetFolder(Folder=C:\Program Files\Safari\PubSub.resources\Framework\da.lproj\)
                MSI (s) (A4:F8) [11:14:59:266]: Executing op: SetSourceFolder(Folder=1\Safari\235bwbkb\ki6a7k6g\ab2knjqm\|Safari\PubSub.resources\Frame work\da.lproj\)
                MSI (s) (A4:F8) [11:14:59:266]: Executing op: FileCopy(SourceName=lhsgih96.str|Localizable.strings,SourceCabKey=PubSub.resources_Framew ork_da.lproj_Localizable.strings,DestName=Localizable.strings,Attributes=512,FileSize=6408 ,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart 1=-1030490136,HashPart2=-501801840,HashPart3=-1298258443,HashPart4=1928670851,,)
                MSI (s) (A4:F8) [11:14:59:266]: File: C:\Program Files\Safari\PubSub.resources\Framework\da.lproj\Localizable.strings;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:266]: Executing op: SetTargetFolder(Folder=C:\Program Files\Safari\PubSub.resources\Framework\de.lproj\)
                MSI (s) (A4:F8) [11:14:59:266]: Executing op: SetSourceFolder(Folder=1\Safari\235bwbkb\ki6a7k6g\vzwqf3k-\|Safari\PubSub.resources\Frame work\de.lproj\)
                MSI (s) (A4:F8) [11:14:59:266]: Executing op: FileCopy(SourceName=mofumq_n.str|Localizable.strings,SourceCabKey=PubSub.resources_Framew ork_de.lproj_Localizable.strings,DestName=Localizable.strings,Attributes=512,FileSize=6582 ,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart 1=-1133459307,HashPart2=-894175927,HashPart3=-970643899,HashPart4=-653581431,,)
                MSI (s) (A4:F8) [11:14:59:266]: File: C:\Program Files\Safari\PubSub.resources\Framework\de.lproj\Localizable.strings;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:266]: Executing op: SetTargetFolder(Folder=C:\Program Files\Safari\PubSub.resources\Framework\English.lproj\)
                MSI (s) (A4:F8) [11:14:59:266]: Executing op: SetSourceFolder(Folder=1\Safari\235bwbkb\ki6a7k6g\a-wznuxh\|Safari\PubSub.resources\Frame work\English.lproj\)
                MSI (s) (A4:F8) [11:14:59:266]: Executing op: FileCopy(SourceName=w2nbv5yf.str|Localizable.strings,SourceCabKey=PubSub.resources_Framew ork_English.lproj_Localizable.strings,DestName=Localizable.strings,Attributes=512,FileSize =6408,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,Has hPart1=-457955506,HashPart2=1032048932,HashPart3=1971242417,HashPart4=-928259844,,)
                MSI (s) (A4:F8) [11:14:59:266]: File: C:\Program Files\Safari\PubSub.resources\Framework\English.lproj\Localizable.strings;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:266]: Executing op: SetTargetFolder(Folder=C:\Program Files\Safari\PubSub.resources\Framework\es.lproj\)
                MSI (s) (A4:F8) [11:14:59:266]: Executing op: SetSourceFolder(Folder=1\Safari\235bwbkb\ki6a7k6g\buyn2lpm\|Safari\PubSub.resources\Frame work\es.lproj\)
                MSI (s) (A4:F8) [11:14:59:266]: Executing op: FileCopy(SourceName=eniocppy.str|Localizable.strings,SourceCabKey=PubSub.resources_Framew ork_es.lproj_Localizable.strings,DestName=Localizable.strings,Attributes=512,FileSize=6636 ,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart 1=177728891,HashPart2=1903347318,HashPart3=-979497907,HashPart4=-1711653800,,)
                MSI (s) (A4:F8) [11:14:59:266]: File: C:\Program Files\Safari\PubSub.resources\Framework\es.lproj\Localizable.strings;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:266]: Executing op: SetTargetFolder(Folder=C:\Program Files\Safari\PubSub.resources\Framework\fi.lproj\)
                MSI (s) (A4:F8) [11:14:59:266]: Executing op: SetSourceFolder(Folder=1\Safari\235bwbkb\ki6a7k6g\vegh3i3u\|Safari\PubSub.resources\Frame work\fi.lproj\)
                MSI (s) (A4:F8) [11:14:59:266]: Executing op: FileCopy(SourceName=azqi4mfv.str|Localizable.strings,SourceCabKey=PubSub.resources_Framew ork_fi.lproj_Localizable.strings,DestName=Localizable.strings,Attributes=512,FileSize=6408 ,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart 1=1833168126,HashPart2=-807790021,HashPart3=-1780273495,HashPart4=433957285,,)
                MSI (s) (A4:F8) [11:14:59:282]: File: C:\Program Files\Safari\PubSub.resources\Framework\fi.lproj\Localizable.strings;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:282]: Executing op: SetTargetFolder(Folder=C:\Program Files\Safari\PubSub.resources\Framework\fr.lproj\)
                MSI (s) (A4:F8) [11:14:59:282]: Executing op: SetSourceFolder(Folder=1\Safari\235bwbkb\ki6a7k6g\p8d7tsv8\|Safari\PubSub.resources\Frame work\fr.lproj\)
                MSI (s) (A4:F8) [11:14:59:282]: Executing op: FileCopy(SourceName=7gdk0uf7.str|Localizable.strings,SourceCabKey=PubSub.resources_Framew ork_fr.lproj_Localizable.strings,DestName=Localizable.strings,Attributes=512,FileSize=6636 ,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart 1=-1973716147,HashPart2=-1116183634,HashPart3=-1444639426,HashPart4=515473452,,)
                MSI (s) (A4:F8) [11:14:59:282]: File: C:\Program Files\Safari\PubSub.resources\Framework\fr.lproj\Localizable.strings;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:282]: Executing op: SetTargetFolder(Folder=C:\Program Files\Safari\PubSub.resources\Framework\it.lproj\)
                MSI (s) (A4:F8) [11:14:59:282]: Executing op: SetSourceFolder(Folder=1\Safari\235bwbkb\ki6a7k6g\pu6fmrrz\|Safari\PubSub.resources\Frame work\it.lproj\)
                MSI (s) (A4:F8) [11:14:59:282]: Executing op: FileCopy(SourceName=w9jq9-tb.str|Localizable.strings,SourceCabKey=PubSub.resources_Framew ork_it.lproj_Localizable.strings,DestName=Localizable.strings,Attributes=512,FileSize=6456 ,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart 1=-1956165192,HashPart2=1947260656,HashPart3=103988675,HashPart4=1439592953,,)
                MSI (s) (A4:F8) [11:14:59:282]: File: C:\Program Files\Safari\PubSub.resources\Framework\it.lproj\Localizable.strings;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:282]: Executing op: SetTargetFolder(Folder=C:\Program Files\Safari\PubSub.resources\Framework\ja.lproj\)
                MSI (s) (A4:F8) [11:14:59:282]: Executing op: SetSourceFolder(Folder=1\Safari\235bwbkb\ki6a7k6g\xx9jsvfe\|Safari\PubSub.resources\Frame work\ja.lproj\)
                MSI (s) (A4:F8) [11:14:59:282]: Executing op: FileCopy(SourceName=joowxgvt.str|Localizable.strings,SourceCabKey=PubSub.resources_Framew ork_ja.lproj_Localizable.strings,DestName=Localizable.strings,Attributes=512,FileSize=5844 ,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart 1=1811140079,HashPart2=1843695354,HashPart3=-18276403,HashPart4=548466694,,)
                MSI (s) (A4:F8) [11:14:59:282]: File: C:\Program Files\Safari\PubSub.resources\Framework\ja.lproj\Localizable.strings;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:282]: Executing op: SetTargetFolder(Folder=C:\Program Files\Safari\PubSub.resources\Framework\ko.lproj\)
                MSI (s) (A4:F8) [11:14:59:282]: Executing op: SetSourceFolder(Folder=1\Safari\235bwbkb\ki6a7k6g\6ebundrm\|Safari\PubSub.resources\Frame work\ko.lproj\)
                MSI (s) (A4:F8) [11:14:59:282]: Executing op: FileCopy(SourceName=zo-6vbos.str|Localizable.strings,SourceCabKey=PubSub.resources_Framew ork_ko.lproj_Localizable.strings,DestName=Localizable.strings,Attributes=512,FileSize=5746 ,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart 1=176084158,HashPart2=-830017211,HashPart3=289517710,HashPart4=-1281577630,,)
                MSI (s) (A4:F8) [11:14:59:282]: File: C:\Program Files\Safari\PubSub.resources\Framework\ko.lproj\Localizable.strings;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:282]: Executing op: SetTargetFolder(Folder=C:\Program Files\Safari\PubSub.resources\Framework\nb.lproj\)
                MSI (s) (A4:F8) [11:14:59:282]: Executing op: SetSourceFolder(Folder=1\Safari\235bwbkb\ki6a7k6g\1bi5rghz\|Safari\PubSub.resources\Frame work\nb.lproj\)
                MSI (s) (A4:F8) [11:14:59:282]: Executing op: FileCopy(SourceName=6gohldb4.str|Localizable.strings,SourceCabKey=PubSub.resources_Framew ork_nb.lproj_Localizable.strings,DestName=Localizable.strings,Attributes=512,FileSize=6364 ,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart 1=697907321,HashPart2=-1220688899,HashPart3=-599837337,HashPart4=1931241707,,)
                MSI (s) (A4:F8) [11:14:59:282]: File: C:\Program Files\Safari\PubSub.resources\Framework\nb.lproj\Localizable.strings;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:282]: Executing op: SetTargetFolder(Folder=C:\Program Files\Safari\PubSub.resources\Framework\nl.lproj\)
                MSI (s) (A4:F8) [11:14:59:282]: Executing op: SetSourceFolder(Folder=1\Safari\235bwbkb\ki6a7k6g\hyfvbw2h\|Safari\PubSub.resources\Frame work\nl.lproj\)
                MSI (s) (A4:F8) [11:14:59:282]: Executing op: FileCopy(SourceName=u91kw8l7.str|Localizable.strings,SourceCabKey=PubSub.resources_Framew ork_nl.lproj_Localizable.strings,DestName=Localizable.strings,Attributes=512,FileSize=6510 ,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart 1=-1795945395,HashPart2=128976042,HashPart3=-1311887831,HashPart4=1811716204,,)
                MSI (s) (A4:F8) [11:14:59:282]: File: C:\Program Files\Safari\PubSub.resources\Framework\nl.lproj\Localizable.strings;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:282]: Executing op: SetTargetFolder(Folder=C:\Program Files\Safari\PubSub.resources\Framework\pl.lproj\)
                MSI (s) (A4:F8) [11:14:59:282]: Executing op: SetSourceFolder(Folder=1\Safari\235bwbkb\ki6a7k6g\k78lb4cc\|Safari\PubSub.resources\Frame work\pl.lproj\)
                MSI (s) (A4:F8) [11:14:59:282]: Executing op: FileCopy(SourceName=5qqmzw3q.str|Localizable.strings,SourceCabKey=PubSub.resources_Framew ork_pl.lproj_Localizable.strings,DestName=Localizable.strings,Attributes=512,FileSize=6380 ,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart 1=1242033282,HashPart2=-55416829,HashPart3=1535791327,HashPart4=2095179445,,)
                MSI (s) (A4:F8) [11:14:59:282]: File: C:\Program Files\Safari\PubSub.resources\Framework\pl.lproj\Localizable.strings;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:282]: Executing op: SetTargetFolder(Folder=C:\Program Files\Safari\PubSub.resources\Framework\pt.lproj\)
                MSI (s) (A4:F8) [11:14:59:282]: Executing op: SetSourceFolder(Folder=1\Safari\235bwbkb\ki6a7k6g\isfjfbfz\|Safari\PubSub.resources\Frame work\pt.lproj\)
                MSI (s) (A4:F8) [11:14:59:282]: Executing op: FileCopy(SourceName=7ds3ppvq.str|Localizable.strings,SourceCabKey=PubSub.resources_Framew ork_pt.lproj_Localizable.strings,DestName=Localizable.strings,Attributes=512,FileSize=6564 ,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart 1=-1631090000,HashPart2=-1137511886,HashPart3=1943598358,HashPart4=1193530944,,)
                MSI (s) (A4:F8) [11:14:59:282]: File: C:\Program Files\Safari\PubSub.resources\Framework\pt.lproj\Localizable.strings;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:282]: Executing op: SetTargetFolder(Folder=C:\Program Files\Safari\PubSub.resources\Framework\pt_PT.lproj\)
                MSI (s) (A4:F8) [11:14:59:282]: Executing op: SetSourceFolder(Folder=1\Safari\235bwbkb\ki6a7k6g\yajlwrwc\|Safari\PubSub.resources\Frame work\pt_PT.lproj\)
                MSI (s) (A4:F8) [11:14:59:282]: Executing op: FileCopy(SourceName=jzifqwck.str|Localizable.strings,SourceCabKey=PubSub.resources_Framew ork_pt_PT.lproj_Localizable.strings,DestName=Localizable.strings,Attributes=512,FileSize=6 444,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashP art1=1878087369,HashPart2=1831027684,HashPart3=723640375,HashPart4=1997475209,,)
                MSI (s) (A4:F8) [11:14:59:282]: File: C:\Program Files\Safari\PubSub.resources\Framework\pt_PT.lproj\Localizable.strings;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:282]: Executing op: SetTargetFolder(Folder=C:\Program Files\Safari\PubSub.resources\Framework\ru.lproj\)
                MSI (s) (A4:F8) [11:14:59:282]: Executing op: SetSourceFolder(Folder=1\Safari\235bwbkb\ki6a7k6g\nosdnkab\|Safari\PubSub.resources\Frame work\ru.lproj\)
                MSI (s) (A4:F8) [11:14:59:282]: Executing op: FileCopy(SourceName=o-pho1s5.str|Localizable.strings,SourceCabKey=PubSub.resources_Framew ork_ru.lproj_Localizable.strings,DestName=Localizable.strings,Attributes=512,FileSize=6384 ,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart 1=114268063,HashPart2=-729149929,HashPart3=1047213801,HashPart4=-337800145,,)
                MSI (s) (A4:F8) [11:14:59:282]: File: C:\Program Files\Safari\PubSub.resources\Framework\ru.lproj\Localizable.strings;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:282]: Executing op: SetTargetFolder(Folder=C:\Program Files\Safari\PubSub.resources\Framework\sv.lproj\)
                MSI (s) (A4:F8) [11:14:59:282]: Executing op: SetSourceFolder(Folder=1\Safari\235bwbkb\ki6a7k6g\jkolvolv\|Safari\PubSub.resources\Frame work\sv.lproj\)
                MSI (s) (A4:F8) [11:14:59:282]: Executing op: FileCopy(SourceName=8-sdnrao.str|Localizable.strings,SourceCabKey=PubSub.resources_Framew ork_sv.lproj_Localizable.strings,DestName=Localizable.strings,Attributes=512,FileSize=6400 ,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart 1=-650081759,HashPart2=1543536639,HashPart3=1810543537,HashPart4=1299719670,,)
                MSI (s) (A4:F8) [11:14:59:298]: File: C:\Program Files\Safari\PubSub.resources\Framework\sv.lproj\Localizable.strings;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:298]: Executing op: SetTargetFolder(Folder=C:\Program Files\Safari\PubSub.resources\Framework\)
                MSI (s) (A4:F8) [11:14:59:298]: Executing op: SetSourceFolder(Folder=1\Safari\235bwbkb\ki6a7k6g\|Safari\PubSub.resources\Framework\)
                MSI (s) (A4:F8) [11:14:59:298]: Executing op: FileCopy(SourceName=tpyyyc8j.lua|templates.lua,SourceCabKey=PubSub.resources_Framework_te mplates.lua,DestName=templates.lua,Attributes=512,FileSize=3101,PerTick=32768,,VerifyMedia =1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=1364945433,HashPart2=-264 475475,HashPart3=130428999,HashPart4=1456482706,,)
                MSI (s) (A4:F8) [11:14:59:298]: File: C:\Program Files\Safari\PubSub.resources\Framework\templates.lua;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:298]: Executing op: SetTargetFolder(Folder=C:\Program Files\Safari\PubSub.resources\Framework\zh_CN.lproj\)
                MSI (s) (A4:F8) [11:14:59:298]: Executing op: SetSourceFolder(Folder=1\Safari\235bwbkb\ki6a7k6g\zjecxxdf\|Safari\PubSub.resources\Frame work\zh_CN.lproj\)
                MSI (s) (A4:F8) [11:14:59:298]: Executing op: FileCopy(SourceName=umzsz5hu.str|Localizable.strings,SourceCabKey=PubSub.resources_Framew ork_zh_CN.lproj_Localizable.strings,DestName=Localizable.strings,Attributes=512,FileSize=5 474,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashP art1=767456418,HashPart2=-9415635,HashPart3=202098525,HashPart4=-124625627,,)
                MSI (s) (A4:F8) [11:14:59:298]: File: C:\Program Files\Safari\PubSub.resources\Framework\zh_CN.lproj\Localizable.strings;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:298]: Executing op: SetTargetFolder(Folder=C:\Program Files\Safari\PubSub.resources\Framework\zh_TW.lproj\)
                MSI (s) (A4:F8) [11:14:59:298]: Executing op: SetSourceFolder(Folder=1\Safari\235bwbkb\ki6a7k6g\jt_fazch\|Safari\PubSub.resources\Frame work\zh_TW.lproj\)
                MSI (s) (A4:F8) [11:14:59:298]: Executing op: FileCopy(SourceName=xbqp0vzi.str|Localizable.strings,SourceCabKey=PubSub.resources_Framew ork_zh_TW.lproj_Localizable.strings,DestName=Localizable.strings,Attributes=512,FileSize=5 444,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashP art1=134640057,HashPart2=-658573405,HashPart3=-1510700708,HashPart4=1364018131,,)
                MSI (s) (A4:F8) [11:14:59:298]: File: C:\Program Files\Safari\PubSub.resources\Framework\zh_TW.lproj\Localizable.strings;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:298]: Executing op: SetTargetFolder(Folder=C:\Program Files\Safari\PubSub.resources\)
                MSI (s) (A4:F8) [11:14:59:298]: Executing op: SetSourceFolder(Folder=1\Safari\235bwbkb\|Safari\PubSub.resources\)
                MSI (s) (A4:F8) [11:14:59:298]: Executing op: FileCopy(SourceName=dh6vyokw.htm|Friends.html,SourceCabKey=PubSub.resources_Friends.html, DestName=Friends.html,Attributes=512,FileSize=1587,PerTick=32768,,VerifyMedia=1,,,,,CheckC RC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=245928751,HashPart2=-1356871940,HashPa rt3=-897686184,HashPart4=830201532,,)
                MSI (s) (A4:F8) [11:14:59:298]: File: C:\Program Files\Safari\PubSub.resources\Friends.html;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:298]: Executing op: SetTargetFolder(Folder=C:\Program Files\Safari\PubSub.resources\it.lproj\)
                MSI (s) (A4:F8) [11:14:59:298]: Executing op: SetSourceFolder(Folder=1\Safari\235bwbkb\wnl3kwxy\|Safari\PubSub.resources\it.lproj\)
                MSI (s) (A4:F8) [11:14:59:298]: Executing op: FileCopy(SourceName=mjtxt1wc.css|ArticlesL10N.css,SourceCabKey=PubSub.resources_it.lproj_ ArticlesL10N.css,DestName=ArticlesL10N.css,Attributes=512,FileSize=987,PerTick=32768,,Veri fyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=648707801,HashPart 2=-1779418238,HashPart3=1798877587,HashPart4=974288362,,)
                MSI (s) (A4:F8) [11:14:59:298]: File: C:\Program Files\Safari\PubSub.resources\it.lproj\ArticlesL10N.css;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:298]: Executing op: FileCopy(SourceName=jclsavmb.str|Localizable.strings,SourceCabKey=PubSub.resources_it.lpr oj_Localizable.strings,DestName=Localizable.strings,Attributes=512,FileSize=8178,PerTick=3 2768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=36005843 2,HashPart2=-563058787,HashPart3=-1157831055,HashPart4=995500362,,)
                MSI (s) (A4:F8) [11:14:59:298]: File: C:\Program Files\Safari\PubSub.resources\it.lproj\Localizable.strings;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:298]: Executing op: SetTargetFolder(Folder=C:\Program Files\Safari\PubSub.resources\ja.lproj\)
                MSI (s) (A4:F8) [11:14:59:298]: Executing op: SetSourceFolder(Folder=1\Safari\235bwbkb\m4oa78lt\|Safari\PubSub.resources\ja.lproj\)
                MSI (s) (A4:F8) [11:14:59:298]: Executing op: FileCopy(SourceName=utdbyvep.css|ArticlesL10N.css,SourceCabKey=PubSub.resources_ja.lproj_ ArticlesL10N.css,DestName=ArticlesL10N.css,Attributes=512,FileSize=992,PerTick=32768,,Veri fyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=-2115927736,HashPa rt2=-1529205612,HashPart3=1485648073,HashPart4=1077990380,,)
                MSI (s) (A4:F8) [11:14:59:298]: File: C:\Program Files\Safari\PubSub.resources\ja.lproj\ArticlesL10N.css;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:298]: Executing op: FileCopy(SourceName=ud65wmor.str|Localizable.strings,SourceCabKey=PubSub.resources_ja.lpr oj_Localizable.strings,DestName=Localizable.strings,Attributes=512,FileSize=6438,PerTick=3 2768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=11655971 04,HashPart2=354934421,HashPart3=1607443189,HashPart4=-1614113154,,)
                MSI (s) (A4:F8) [11:14:59:298]: File: C:\Program Files\Safari\PubSub.resources\ja.lproj\Localizable.strings;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:298]: Executing op: SetTargetFolder(Folder=C:\Program Files\Safari\PubSub.resources\ko.lproj\)
                MSI (s) (A4:F8) [11:14:59:298]: Executing op: SetSourceFolder(Folder=1\Safari\235bwbkb\jfkeqged\|Safari\PubSub.resources\ko.lproj\)
                MSI (s) (A4:F8) [11:14:59:298]: Executing op: FileCopy(SourceName=h1pcd-f9.css|ArticlesL10N.css,SourceCabKey=PubSub.resources_ko.lproj_ ArticlesL10N.css,DestName=ArticlesL10N.css,Attributes=512,FileSize=986,PerTick=32768,,Veri fyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=1568098834,HashPar t2=-1872359055,HashPart3=1309676080,HashPart4=1988645306,,)
                MSI (s) (A4:F8) [11:14:59:298]: File: C:\Program Files\Safari\PubSub.resources\ko.lproj\ArticlesL10N.css;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:298]: Executing op: FileCopy(SourceName=pmnw-6kv.str|Localizable.strings,SourceCabKey=PubSub.resources_ko.lpr oj_Localizable.strings,DestName=Localizable.strings,Attributes=512,FileSize=6664,PerTick=3 2768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=-4639264 68,HashPart2=-225755694,HashPart3=1978627353,HashPart4=1036403758,,)
                MSI (s) (A4:F8) [11:14:59:298]: File: C:\Program Files\Safari\PubSub.resources\ko.lproj\Localizable.strings;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:298]: Executing op: FileCopy(SourceName=Main.css,SourceCabKey=PubSub.resources_Main.css,DestName=Main.css,Att ributes=512,FileSize=14830,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113 472,HashOptions=0,HashPart1=261540181,HashPart2=1349902329,HashPart3=-1454276514,HashPart4 =-228268004,,)
                MSI (s) (A4:F8) [11:14:59:298]: File: C:\Program Files\Safari\PubSub.resources\Main.css;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:298]: Executing op: SetTargetFolder(Folder=C:\Program Files\Safari\PubSub.resources\nb.lproj\)
                MSI (s) (A4:F8) [11:14:59:298]: Executing op: SetSourceFolder(Folder=1\Safari\235bwbkb\azjyhgrx\|Safari\PubSub.resources\nb.lproj\)
                MSI (s) (A4:F8) [11:14:59:298]: Executing op: FileCopy(SourceName=eckbs2za.css|ArticlesL10N.css,SourceCabKey=PubSub.resources_nb.lproj_ ArticlesL10N.css,DestName=ArticlesL10N.css,Attributes=512,FileSize=985,PerTick=32768,,Veri fyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=-680633764,HashPar t2=-1116832313,HashPart3=1588993456,HashPart4=-127124777,,)
                MSI (s) (A4:F8) [11:14:59:313]: File: C:\Program Files\Safari\PubSub.resources\nb.lproj\ArticlesL10N.css;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:313]: Executing op: FileCopy(SourceName=fljjzmvy.str|Localizable.strings,SourceCabKey=PubSub.resources_nb.lpr oj_Localizable.strings,DestName=Localizable.strings,Attributes=512,FileSize=7828,PerTick=3 2768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=-1079148 228,HashPart2=-585167919,HashPart3=1037479145,HashPart4=-825925250,,)
                MSI (s) (A4:F8) [11:14:59:313]: File: C:\Program Files\Safari\PubSub.resources\nb.lproj\Localizable.strings;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:313]: Executing op: SetTargetFolder(Folder=C:\Program Files\Safari\PubSub.resources\)
                MSI (s) (A4:F8) [11:14:59:313]: Executing op: SetSourceFolder(Folder=1\Safari\235bwbkb\|Safari\PubSub.resources\)
                MSI (s) (A4:F8) [11:14:59:313]: Executing op: FileCopy(SourceName=NextPage.tif,SourceCabKey=PubSub.resources_NextPage.tif,DestName=Next Page.tif,Attributes=512,FileSize=518,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,Install Mode=59113472,HashOptions=0,HashPart1=2083923914,HashPart2=-214081726,HashPart3=-125012167 4,HashPart4=-1053249406,,)
                MSI (s) (A4:F8) [11:14:59:313]: File: C:\Program Files\Safari\PubSub.resources\NextPage.tif;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:313]: Executing op: FileCopy(SourceName=k_en0sxs.tif|NextPage_Disabled.tif,SourceCabKey=PubSub.resources_Next Page_Disabled.tif,DestName=NextPage_Disabled.tif,Attributes=512,FileSize=412,PerTick=32768 ,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=886948018,Ha shPart2=-739689754,HashPart3=-611352374,HashPart4=1581741546,,)
                MSI (s) (A4:F8) [11:14:59:313]: File: C:\Program Files\Safari\PubSub.resources\NextPage_Disabled.tif;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:313]: Executing op: SetTargetFolder(Folder=C:\Program Files\Safari\PubSub.resources\nl.lproj\)
                MSI (s) (A4:F8) [11:14:59:313]: Executing op: SetSourceFolder(Folder=1\Safari\235bwbkb\wcdz4vqq\|Safari\PubSub.resources\nl.lproj\)
                MSI (s) (A4:F8) [11:14:59:313]: Executing op: FileCopy(SourceName=-nreqaie.css|ArticlesL10N.css,SourceCabKey=PubSub.resources_nl.lproj_ ArticlesL10N.css,DestName=ArticlesL10N.css,Attributes=512,FileSize=987,PerTick=32768,,Veri fyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=-1584637638,HashPa rt2=971091564,HashPart3=773090490,HashPart4=1679000477,,)
                MSI (s) (A4:F8) [11:14:59:313]: File: C:\Program Files\Safari\PubSub.resources\nl.lproj\ArticlesL10N.css;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:313]: Executing op: FileCopy(SourceName=ycr7vtvo.str|Localizable.strings,SourceCabKey=PubSub.resources_nl.lpr oj_Localizable.strings,DestName=Localizable.strings,Attributes=512,FileSize=8076,PerTick=3 2768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=-1090313 781,HashPart2=-1736414838,HashPart3=727804590,HashPart4=-622655150,,)
                MSI (s) (A4:F8) [11:14:59:313]: File: C:\Program Files\Safari\PubSub.resources\nl.lproj\Localizable.strings;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:313]: Executing op: SetTargetFolder(Folder=C:\Program Files\Safari\PubSub.resources\pl.lproj\)
                MSI (s) (A4:F8) [11:14:59:313]: Executing op: SetSourceFolder(Folder=1\Safari\235bwbkb\1fahngzt\|Safari\PubSub.resources\pl.lproj\)
                MSI (s) (A4:F8) [11:14:59:313]: Executing op: FileCopy(SourceName=i9ofd9-k.css|ArticlesL10N.css,SourceCabKey=PubSub.resources_pl.lproj_ ArticlesL10N.css,DestName=ArticlesL10N.css,Attributes=512,FileSize=987,PerTick=32768,,Veri fyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=1844905415,HashPar t2=1824054929,HashPart3=-1839488924,HashPart4=1081371796,,)
                MSI (s) (A4:F8) [11:14:59:313]: File: C:\Program Files\Safari\PubSub.resources\pl.lproj\ArticlesL10N.css;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:313]: Executing op: FileCopy(SourceName=ctnyvn19.str|Localizable.strings,SourceCabKey=PubSub.resources_pl.lpr oj_Localizable.strings,DestName=Localizable.strings,Attributes=512,FileSize=8092,PerTick=3 2768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=-9616584 30,HashPart2=1670707512,HashPart3=1344216628,HashPart4=-624087634,,)
                MSI (s) (A4:F8) [11:14:59:313]: File: C:\Program Files\Safari\PubSub.resources\pl.lproj\Localizable.strings;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:313]: Executing op: FileCopy(SourceName=nc-oj0rp.tif|PreviousPage.tif,SourceCabKey=PubSub.resources_PreviousP age.tif,DestName=PreviousPage.tif,Attributes=512,FileSize=528,PerTick=32768,,VerifyMedia=1 ,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=1088995,HashPart2=-60385245 5,HashPart3=-680359181,HashPart4=1137176267,,)
                MSI (s) (A4:F8) [11:14:59:313]: File: C:\Program Files\Safari\PubSub.resources\PreviousPage.tif;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:313]: Executing op: FileCopy(SourceName=0032boba.tif|PreviousPage_Disabled.tif,SourceCabKey=PubSub.resources_ PreviousPage_Disabled.tif,DestName=PreviousPage_Disabled.tif,Attributes=512,FileSize=422,P erTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1= 1249863262,HashPart2=-937611940,HashPart3=1154504684,HashPart4=1290357640,,)
                MSI (s) (A4:F8) [11:14:59:313]: File: C:\Program Files\Safari\PubSub.resources\PreviousPage_Disabled.tif;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:313]: Executing op: SetTargetFolder(Folder=C:\Program Files\Safari\PubSub.resources\pt.lproj\)
                MSI (s) (A4:F8) [11:14:59:313]: Executing op: SetSourceFolder(Folder=1\Safari\235bwbkb\iqfovw--\|Safari\PubSub.resources\pt.lproj\)
                MSI (s) (A4:F8) [11:14:59:313]: Executing op: FileCopy(SourceName=eqofrtsm.css|ArticlesL10N.css,SourceCabKey=PubSub.resources_pt.lproj_ ArticlesL10N.css,DestName=ArticlesL10N.css,Attributes=512,FileSize=986,PerTick=32768,,Veri fyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=-37205366,HashPart 2=-1607532416,HashPart3=924026554,HashPart4=2024196669,,)
                MSI (s) (A4:F8) [11:14:59:313]: File: C:\Program Files\Safari\PubSub.resources\pt.lproj\ArticlesL10N.css;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:313]: Executing op: FileCopy(SourceName=pyaz13nk.str|Localizable.strings,SourceCabKey=PubSub.resources_pt.lpr oj_Localizable.strings,DestName=Localizable.strings,Attributes=512,FileSize=8048,PerTick=3 2768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=73922385 ,HashPart2=908735553,HashPart3=1957818740,HashPart4=1527710177,,)
                MSI (s) (A4:F8) [11:14:59:313]: File: C:\Program Files\Safari\PubSub.resources\pt.lproj\Localizable.strings;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:313]: Executing op: SetTargetFolder(Folder=C:\Program Files\Safari\PubSub.resources\pt_PT.lproj\)
                MSI (s) (A4:F8) [11:14:59:313]: Executing op: SetSourceFolder(Folder=1\Safari\235bwbkb\vabriv-e\|Safari\PubSub.resources\pt_PT.lproj\)
                MSI (s) (A4:F8) [11:14:59:313]: Executing op: FileCopy(SourceName=of2tbbaa.css|ArticlesL10N.css,SourceCabKey=PubSub.resources_pt_PT.lpr oj_ArticlesL10N.css,DestName=ArticlesL10N.css,Attributes=512,FileSize=987,PerTick=32768,,V erifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=2041557420,Hash Part2=-1573633475,HashPart3=1100004814,HashPart4=-1076340140,,)
                MSI (s) (A4:F8) [11:14:59:313]: File: C:\Program Files\Safari\PubSub.resources\pt_PT.lproj\ArticlesL10N.css;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:313]: Executing op: FileCopy(SourceName=zlc5qyw3.str|Localizable.strings,SourceCabKey=PubSub.resources_pt_PT. lproj_Localizable.strings,DestName=Localizable.strings,Attributes=512,FileSize=7962,PerTic k=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=15494 10139,HashPart2=-1845931775,HashPart3=-648940435,HashPart4=-1054524560,,)
                MSI (s) (A4:F8) [11:14:59:329]: File: C:\Program Files\Safari\PubSub.resources\pt_PT.lproj\Localizable.strings;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:329]: Executing op: SetTargetFolder(Folder=C:\Program Files\Safari\PubSub.resources\ru.lproj\)
                MSI (s) (A4:F8) [11:14:59:329]: Executing op: SetSourceFolder(Folder=1\Safari\235bwbkb\74n4hctc\|Safari\PubSub.resources\ru.lproj\)
                MSI (s) (A4:F8) [11:14:59:329]: Executing op: FileCopy(SourceName=ifpawmp4.css|ArticlesL10N.css,SourceCabKey=PubSub.resources_ru.lproj_ ArticlesL10N.css,DestName=ArticlesL10N.css,Attributes=512,FileSize=990,PerTick=32768,,Veri fyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=1723004888,HashPar t2=-229558299,HashPart3=582463578,HashPart4=-1457603155,,)
                MSI (s) (A4:F8) [11:14:59:329]: File: C:\Program Files\Safari\PubSub.resources\ru.lproj\ArticlesL10N.css;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:329]: Executing op: FileCopy(SourceName=vgrc-xqj.str|Localizable.strings,SourceCabKey=PubSub.resources_ru.lpr oj_Localizable.strings,DestName=Localizable.strings,Attributes=512,FileSize=7882,PerTick=3 2768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=57905174 8,HashPart2=-1532016084,HashPart3=433284991,HashPart4=-952358852,,)
                MSI (s) (A4:F8) [11:14:59:329]: File: C:\Program Files\Safari\PubSub.resources\ru.lproj\Localizable.strings;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:329]: Executing op: SetTargetFolder(Folder=C:\Program Files\Safari\PubSub.resources\)
                MSI (s) (A4:F8) [11:14:59:329]: Executing op: SetSourceFolder(Folder=1\Safari\235bwbkb\|Safari\PubSub.resources\)
                MSI (s) (A4:F8) [11:14:59:329]: Executing op: FileCopy(SourceName=jfyq0hvj.tif|Separator.tif,SourceCabKey=PubSub.resources_Separator.ti f,DestName=Separator.tif,Attributes=512,FileSize=256,PerTick=32768,,VerifyMedia=1,,,,,Chec kCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=-1971693890,HashPart2=644335381,Hash Part3=-109551913,HashPart4=1760931721,,)
                MSI (s) (A4:F8) [11:14:59:329]: File: C:\Program Files\Safari\PubSub.resources\Separator.tif;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:329]: Executing op: FileCopy(SourceName=Smaller.tif,SourceCabKey=PubSub.resources_Smaller.tif,DestName=Smalle r.tif,Attributes=512,FileSize=278,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMod e=59113472,HashOptions=0,HashPart1=1630592840,HashPart2=1786810186,HashPart3=1095453978,Ha shPart4=-628997897,,)
                MSI (s) (A4:F8) [11:14:59:329]: File: C:\Program Files\Safari\PubSub.resources\Smaller.tif;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:329]: Executing op: SetTargetFolder(Folder=C:\Program Files\Safari\PubSub.resources\sv.lproj\)
                MSI (s) (A4:F8) [11:14:59:329]: Executing op: SetSourceFolder(Folder=1\Safari\235bwbkb\7thl1xei\|Safari\PubSub.resources\sv.lproj\)
                MSI (s) (A4:F8) [11:14:59:329]: Executing op: FileCopy(SourceName=c-isfrvb.css|ArticlesL10N.css,SourceCabKey=PubSub.resources_sv.lproj_ ArticlesL10N.css,DestName=ArticlesL10N.css,Attributes=512,FileSize=986,PerTick=32768,,Veri fyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=-1074509269,HashPa rt2=1137839006,HashPart3=-1282578913,HashPart4=2005943061,,)
                MSI (s) (A4:F8) [11:14:59:329]: File: C:\Program Files\Safari\PubSub.resources\sv.lproj\ArticlesL10N.css;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:329]: Executing op: FileCopy(SourceName=jp6p4n4l.str|Localizable.strings,SourceCabKey=PubSub.resources_sv.lpr oj_Localizable.strings,DestName=Localizable.strings,Attributes=512,FileSize=7810,PerTick=3 2768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=-1162013 114,HashPart2=-872330843,HashPart3=-1545583369,HashPart4=-605344165,,)
                MSI (s) (A4:F8) [11:14:59:329]: File: C:\Program Files\Safari\PubSub.resources\sv.lproj\Localizable.strings;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:329]: Executing op: FileCopy(SourceName=Template.png,SourceCabKey=PubSub.resources_Template.png,DestName=Temp late.png,Attributes=512,FileSize=43993,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,Insta llMode=59113472,HashOptions=0,HashPart1=-694626295,HashPart2=908869740,HashPart3=526025646 ,HashPart4=1440851587,,)
                MSI (s) (A4:F8) [11:14:59:329]: File: C:\Program Files\Safari\PubSub.resources\Template.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:329]: Executing op: FileCopy(SourceName=unread.tif,SourceCabKey=PubSub.resources_unread.tif,DestName=unread.t if,Attributes=512,FileSize=24668,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode =59113472,HashOptions=0,HashPart1=928277194,HashPart2=-2143333364,HashPart3=-2006665712,Ha shPart4=1025815944,,)
                MSI (s) (A4:F8) [11:14:59:329]: File: C:\Program Files\Safari\PubSub.resources\unread.tif;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:329]: Executing op: SetTargetFolder(Folder=C:\Program Files\Safari\PubSub.resources\zh_CN.lproj\)
                MSI (s) (A4:F8) [11:14:59:329]: Executing op: SetSourceFolder(Folder=1\Safari\235bwbkb\akakstti\|Safari\PubSub.resources\zh_CN.lproj\)
                MSI (s) (A4:F8) [11:14:59:329]: Executing op: FileCopy(SourceName=4hzceasm.css|ArticlesL10N.css,SourceCabKey=PubSub.resources_zh_CN.lpr oj_ArticlesL10N.css,DestName=ArticlesL10N.css,Attributes=512,FileSize=1003,PerTick=32768,, VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=120508991,Hash Part2=488975876,HashPart3=2056359812,HashPart4=-1542612779,,)
                MSI (s) (A4:F8) [11:14:59:329]: File: C:\Program Files\Safari\PubSub.resources\zh_CN.lproj\ArticlesL10N.css;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:329]: Executing op: FileCopy(SourceName=qjeycrt4.str|Localizable.strings,SourceCabKey=PubSub.resources_zh_CN. lproj_Localizable.strings,DestName=Localizable.strings,Attributes=512,FileSize=5990,PerTic k=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=25155 6632,HashPart2=-981201203,HashPart3=813636267,HashPart4=784745125,,)
                MSI (s) (A4:F8) [11:14:59:329]: File: C:\Program Files\Safari\PubSub.resources\zh_CN.lproj\Localizable.strings;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:329]: Executing op: SetTargetFolder(Folder=C:\Program Files\Safari\PubSub.resources\zh_TW.lproj\)
                MSI (s) (A4:F8) [11:14:59:329]: Executing op: SetSourceFolder(Folder=1\Safari\235bwbkb\mj21h02x\|Safari\PubSub.resources\zh_TW.lproj\)
                MSI (s) (A4:F8) [11:14:59:329]: Executing op: FileCopy(SourceName=rgxaeppo.css|ArticlesL10N.css,SourceCabKey=PubSub.resources_zh_TW.lpr oj_ArticlesL10N.css,DestName=ArticlesL10N.css,Attributes=512,FileSize=988,PerTick=32768,,V erifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=-99853440,HashP art2=402327704,HashPart3=-138068618,HashPart4=1577753239,,)
                MSI (s) (A4:F8) [11:14:59:329]: File: C:\Program Files\Safari\PubSub.resources\zh_TW.lproj\ArticlesL10N.css;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:329]: Executing op: FileCopy(SourceName=_ikfd20s.str|Localizable.strings,SourceCabKey=PubSub.resources_zh_TW. lproj_Localizable.strings,DestName=Localizable.strings,Attributes=512,FileSize=6084,PerTic k=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=15100 60844,HashPart2=940327191,HashPart3=-2143332988,HashPart4=1492203046,,)
                MSI (s) (A4:F8) [11:14:59:344]: File: C:\Program Files\Safari\PubSub.resources\zh_TW.lproj\Localizable.strings;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:344]: Executing op: SetTargetFolder(Folder=C:\Program Files\Safari\)
                MSI (s) (A4:F8) [11:14:59:344]: Executing op: SetSourceFolder(Folder=1\Safari\)
                MSI (s) (A4:F8) [11:14:59:344]: Executing op: RegisterSharedComponentProvider(,,File=PubSubDLL.dll,Component={FBE2E758-8DF0-405B-9614-8 36BB47604BF},ComponentVersion=65.28.0.178,ProductCode={F2AF3E5D-9697-485C-A5AC-E2B9468C446 A},ProductVersion=5.34.52,PatchSize=0,PatchAttributes=0,PatchSequence=0,SharedComponent=0, IsFullFile=0)
                MSI (s) (A4:F8) [11:14:59:344]: Executing op: FileCopy(SourceName=ezjljpk8.dll|PubSubDLL.dll,SourceCabKey=PubSubDLL.dll,DestName=PubSub DLL.dll,Attributes=512,FileSize=542568,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,Version =65.28.0.178,Language=0,InstallMode=59113472,,,,,,,)
                MSI (s) (A4:F8) [11:14:59:344]: File: C:\Program Files\Safari\PubSubDLL.dll;          Won't Overwrite;          Won't patch;          Existing file is of an equal version
                MSI (s) (A4:F8) [11:14:59:344]: Executing op: RegisterSharedComponentProvider(,,File=Safari.dll,Component={C7285A96-10C1-412B-9D6D-4287 BD4D1C7C},ComponentVersion=7534.52.7.4,ProductCode={F2AF3E5D-9697-485C-A5AC-E2B9468C446A}, ProductVersion=5.34.52,PatchSize=0,PatchAttributes=0,PatchSequence=0,SharedComponent=0,IsF ullFile=0)
                MSI (s) (A4:F8) [11:14:59:344]: Executing op: FileCopy(SourceName=Safari.dll,SourceCabKey=Safari.dll,DestName=Safari.dll,Attributes=512 ,FileSize=8321896,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,Version=7534.52.7.4,Language =0,InstallMode=59113472,,,,,,,)
                MSI (s) (A4:F8) [11:14:59:344]: File: C:\Program Files\Safari\Safari.dll;          Won't Overwrite;          Won't patch;          Existing file is of an equal version
                MSI (s) (A4:F8) [11:14:59:344]: Executing op: RegisterSharedComponentProvider(,,File=Safari.exe,Component={A67196C9-4725-4262-A2ED-41EA 9AC05929},ComponentVersion=5.34.52.7,ProductCode={F2AF3E5D-9697-485C-A5AC-E2B9468C446A},Pr oductVersion=5.34.52,PatchSize=0,PatchAttributes=0,PatchSequence=0,SharedComponent=0,IsFul lFile=0)
                MSI (s) (A4:F8) [11:14:59:344]: Executing op: FileCopy(SourceName=Safari.exe,SourceCabKey=Safari.exe,DestName=Safari.exe,Attributes=512 ,FileSize=2388848,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,Version=5.34.52.7,Language=1 033,InstallMode=59113472,,,,,,,)
                MSI (s) (A4:F8) [11:14:59:344]: File: C:\Program Files\Safari\Safari.exe;          Won't Overwrite;          Won't patch;          Existing file is of an equal version
                MSI (s) (A4:F8) [11:14:59:344]: Executing op: SetTargetFolder(Folder=C:\Program Files\Safari\Safari.resources\)
                MSI (s) (A4:F8) [11:14:59:344]: Executing op: SetSourceFolder(Folder=1\Safari\mymwmyms\|Safari\Safari.resources\)
                MSI (s) (A4:F8) [11:14:59:344]: Executing op: FileCopy(SourceName=cbo99pe5.pli|ABAddressFormats.plist,SourceCabKey=Safari.resources_ABA ddressFormats.plist,DestName=ABAddressFormats.plist,Attributes=512,FileSize=121826,PerTick =32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=312625 356,HashPart2=1511051496,HashPart3=-1408160582,HashPart4=-183454322,,)
                MSI (s) (A4:F8) [11:14:59:344]: File: C:\Program Files\Safari\Safari.resources\ABAddressFormats.plist;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:344]: Executing op: FileCopy(SourceName=ush_bgoo.htm|About.html,SourceCabKey=Safari.resources_About.html,Dest Name=About.html,Attributes=512,FileSize=1006,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,, ,InstallMode=59113472,HashOptions=0,HashPart1=1719349921,HashPart2=638876300,HashPart3=-69 5997652,HashPart4=1354732907,,)
                MSI (s) (A4:F8) [11:14:59:344]: File: C:\Program Files\Safari\Safari.resources\About.html;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:344]: Executing op: FileCopy(SourceName=esxb9a_1.png|AddButtonGlyph.png,SourceCabKey=Safari.resources_AddButt onGlyph.png,DestName=AddButtonGlyph.png,Attributes=512,FileSize=162,PerTick=32768,,VerifyM edia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=1649801489,HashPart2= -236651266,HashPart3=-533622986,HashPart4=-1142937082,,)
                MSI (s) (A4:F8) [11:14:59:344]: File: C:\Program Files\Safari\Safari.resources\AddButtonGlyph.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:344]: Executing op: FileCopy(SourceName=akitwv2f.htm|AddressBookEntryView.html,SourceCabKey=Safari.resources_ AddressBookEntryView.html,DestName=AddressBookEntryView.html,Attributes=512,FileSize=1503, PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1 =-2001197765,HashPart2=773830901,HashPart3=927877016,HashPart4=-184054139,,)
                MSI (s) (A4:F8) [11:14:59:344]: File: C:\Program Files\Safari\Safari.resources\AddressBookEntryView.html;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:344]: Executing op: FileCopy(SourceName=pgumjevn.png|AddressCard.png,SourceCabKey=Safari.resources_AddressCar d.png,DestName=AddressCard.png,Attributes=512,FileSize=4249,PerTick=32768,,VerifyMedia=1,, ,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=914115729,HashPart2=248589277 ,HashPart3=-1961285221,HashPart4=-2085783431,,)
                MSI (s) (A4:F8) [11:14:59:344]: File: C:\Program Files\Safari\Safari.resources\AddressCard.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:344]: Executing op: FileCopy(SourceName=fvzia1t9.htm|AdvancedPreferences.html,SourceCabKey=Safari.resources_A dvancedPreferences.html,DestName=AdvancedPreferences.html,Attributes=512,FileSize=5227,Per Tick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=-1 925201850,HashPart2=991353068,HashPart3=1372826939,HashPart4=-700149384,,)
                MSI (s) (A4:F8) [11:14:59:344]: File: C:\Program Files\Safari\Safari.resources\AdvancedPreferences.html;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:344]: Executing op: FileCopy(SourceName=7ze_qjl7.htm|AlertDialog.html,SourceCabKey=Safari.resources_AlertDial og.html,DestName=AlertDialog.html,Attributes=512,FileSize=2295,PerTick=32768,,VerifyMedia= 1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=540770148,HashPart2=154837 0989,HashPart3=-158035841,HashPart4=1776576744,,)
                MSI (s) (A4:F8) [11:14:59:344]: File: C:\Program Files\Safari\Safari.resources\AlertDialog.html;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:344]: Executing op: FileCopy(SourceName=enqannqy.plt|aol666.pltsuite,SourceCabKey=Safari.resources_aol666.plt suite,DestName=aol666.pltsuite,Attributes=512,FileSize=14488,PerTick=32768,,VerifyMedia=1, ,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=-653645717,HashPart2=-851300 203,HashPart3=-1069886412,HashPart4=1813273404,,)
                MSI (s) (A4:F8) [11:14:59:344]: File: C:\Program Files\Safari\Safari.resources\aol666.pltsuite;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:344]: Executing op: FileCopy(SourceName=gxxbg8uv.htm|AppearancePreferences.html,SourceCabKey=Safari.resources _AppearancePreferences.html,DestName=AppearancePreferences.html,Attributes=512,FileSize=37 37,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPa rt1=1427294037,HashPart2=1625441008,HashPart3=-668259536,HashPart4=-777117360,,)
                MSI (s) (A4:F8) [11:14:59:360]: File: C:\Program Files\Safari\Safari.resources\AppearancePreferences.html;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:360]: Executing op: FileCopy(SourceName=AutoFill.js,SourceCabKey=Safari.resources_AutoFill.js,DestName=AutoFi ll.js,Attributes=512,FileSize=27292,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallM ode=59113472,HashOptions=0,HashPart1=1327500221,HashPart2=-1052662897,HashPart3=205320539, HashPart4=-657937148,,)
                MSI (s) (A4:F8) [11:14:59:360]: File: C:\Program Files\Safari\Safari.resources\AutoFill.js;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:360]: Executing op: FileCopy(SourceName=_2lyor6c.htm|AutoFillPreferences.html,SourceCabKey=Safari.resources_A utoFillPreferences.html,DestName=AutoFillPreferences.html,Attributes=512,FileSize=2892,Per Tick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=-1 123827327,HashPart2=131432979,HashPart3=1978433971,HashPart4=-892599946,,)
                MSI (s) (A4:F8) [11:14:59:360]: File: C:\Program Files\Safari\Safari.resources\AutoFillPreferences.html;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:360]: Executing op: FileCopy(SourceName=a7wfydpx.png|badgeFill.png,SourceCabKey=Safari.resources_badgeFill.pn g,DestName=badgeFill.png,Attributes=512,FileSize=181,PerTick=32768,,VerifyMedia=1,,,,,Chec kCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=673959377,HashPart2=1134745521,HashP art3=928810347,HashPart4=1933969441,,)
                MSI (s) (A4:F8) [11:14:59:360]: File: C:\Program Files\Safari\Safari.resources\badgeFill.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:360]: Executing op: FileCopy(SourceName=n-rqfakt.png|badgeFillInactive.png,SourceCabKey=Safari.resources_badg eFillInactive.png,DestName=badgeFillInactive.png,Attributes=512,FileSize=185,PerTick=32768 ,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=-1933332204, HashPart2=-2117711454,HashPart3=-1845503413,HashPart4=1392290276,,)
                MSI (s) (A4:F8) [11:14:59:360]: File: C:\Program Files\Safari\Safari.resources\badgeFillInactive.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:360]: Executing op: FileCopy(SourceName=f8-f9pil.png|badgeLeftCap.png,SourceCabKey=Safari.resources_badgeLeft Cap.png,DestName=badgeLeftCap.png,Attributes=512,FileSize=358,PerTick=32768,,VerifyMedia=1 ,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=-1677864952,HashPart2=99402 466,HashPart3=1850129420,HashPart4=638023617,,)
                MSI (s) (A4:F8) [11:14:59:360]: File: C:\Program Files\Safari\Safari.resources\badgeLeftCap.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:360]: Executing op: FileCopy(SourceName=ekfmru3y.png|badgeLeftCapInactive.png,SourceCabKey=Safari.resources_b adgeLeftCapInactive.png,DestName=badgeLeftCapInactive.png,Attributes=512,FileSize=369,PerT ick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=160 521262,HashPart2=-1303106835,HashPart3=-2125777570,HashPart4=-896214430,,)
                MSI (s) (A4:F8) [11:14:59:360]: File: C:\Program Files\Safari\Safari.resources\badgeLeftCapInactive.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:360]: Executing op: FileCopy(SourceName=dor29axj.png|badgeRightCap.png,SourceCabKey=Safari.resources_badgeRig htCap.png,DestName=badgeRightCap.png,Attributes=512,FileSize=383,PerTick=32768,,VerifyMedi a=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=-524295849,HashPart2=-17 37510139,HashPart3=541865567,HashPart4=850115952,,)
                MSI (s) (A4:F8) [11:14:59:360]: File: C:\Program Files\Safari\Safari.resources\badgeRightCap.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:360]: Executing op: FileCopy(SourceName=ed5qt5hm.png|badgeRightCapInactive.png,SourceCabKey=Safari.resources_ badgeRightCapInactive.png,DestName=badgeRightCapInactive.png,Attributes=512,FileSize=388,P erTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1= 251856577,HashPart2=-1621393011,HashPart3=-129355680,HashPart4=-631715715,,)
                MSI (s) (A4:F8) [11:14:59:360]: File: C:\Program Files\Safari\Safari.resources\badgeRightCapInactive.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:360]: Executing op: FileCopy(SourceName=m--w090u.htm|BlackSearchField.html,SourceCabKey=Safari.resources_Blac kSearchField.html,DestName=BlackSearchField.html,Attributes=512,FileSize=4965,PerTick=3276 8,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=-137810954, HashPart2=1409198748,HashPart3=630541911,HashPart4=-133496547,,)
                MSI (s) (A4:F8) [11:14:59:360]: File: C:\Program Files\Safari\Safari.resources\BlackSearchField.html;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:360]: Executing op: FileCopy(SourceName=gryrc-_l.png|BlackSearchFieldCancel.png,SourceCabKey=Safari.resources _BlackSearchFieldCancel.png,DestName=BlackSearchFieldCancel.png,Attributes=512,FileSize=61 3,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPar t1=271242472,HashPart2=-2063710399,HashPart3=-754748831,HashPart4=1024545874,,)
                MSI (s) (A4:F8) [11:14:59:360]: File: C:\Program Files\Safari\Safari.resources\BlackSearchFieldCancel.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:360]: Executing op: FileCopy(SourceName=tivor2qh.png|BlackSearchFieldCancelPressed.png,SourceCabKey=Safari.re sources_BlackSearchFieldCancelPressed.png,DestName=BlackSearchFieldCancelPressed.png,Attri butes=512,FileSize=597,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472, HashOptions=0,HashPart1=491793407,HashPart2=2024484625,HashPart3=1526533511,HashPart4=-380 29796,,)
                MSI (s) (A4:F8) [11:14:59:360]: File: C:\Program Files\Safari\Safari.resources\BlackSearchFieldCancelPressed.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:360]: Executing op: FileCopy(SourceName=oi1bvi7n.png|BlackSearchFieldCell.png,SourceCabKey=Safari.resources_B lackSearchFieldCell.png,DestName=BlackSearchFieldCell.png,Attributes=512,FileSize=4026,Per Tick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=12 48823091,HashPart2=-897647970,HashPart3=1707247867,HashPart4=-1579158754,,)
                MSI (s) (A4:F8) [11:14:59:360]: File: C:\Program Files\Safari\Safari.resources\BlackSearchFieldCell.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:360]: Executing op: FileCopy(SourceName=bfqimkct.png|BonjourLarge~win.png,SourceCabKey=Safari.resources_Bonjo urLarge_win.png,DestName=BonjourLarge~win.png,Attributes=512,FileSize=166570,PerTick=32768 ,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=1323154368,H ashPart2=1870575545,HashPart3=1581820121,HashPart4=301596984,,)
                MSI (s) (A4:F8) [11:14:59:376]: File: C:\Program Files\Safari\Safari.resources\BonjourLarge~win.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:376]: Executing op: FileCopy(SourceName=lywra619.htm|BookmarkChooser.html,SourceCabKey=Safari.resources_Bookm arkChooser.html,DestName=BookmarkChooser.html,Attributes=512,FileSize=1863,PerTick=32768,, VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=-2095021040,Ha shPart2=1951397799,HashPart3=920048260,HashPart4=-183138406,,)
                MSI (s) (A4:F8) [11:14:59:376]: File: C:\Program Files\Safari\Safari.resources\BookmarkChooser.html;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:376]: Executing op: SetTargetFolder(Folder=C:\Program Files\Safari\Safari.resources\BookmarkChooser\)
                MSI (s) (A4:F8) [11:14:59:376]: Executing op: SetSourceFolder(Folder=1\Safari\mymwmyms\qu-i1nqr\|Safari\Safari.resources\BookmarkChoose r\)
                MSI (s) (A4:F8) [11:14:59:376]: Executing op: FileCopy(SourceName=qyy1g2cv.js|BookmarkChooser.js,SourceCabKey=Safari.resources_Bookmark Chooser_BookmarkChooser.js,DestName=BookmarkChooser.js,Attributes=512,FileSize=9819,PerTic k=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=-1550 081859,HashPart2=-1938756543,HashPart3=352057153,HashPart4=559752028,,)
                MSI (s) (A4:F8) [11:14:59:376]: File: C:\Program Files\Safari\Safari.resources\BookmarkChooser\BookmarkChooser.js;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:376]: Executing op: FileCopy(SourceName=px3md407.png|disclosureTriangleSmallDown.png,SourceCabKey=Safari.reso urces_BookmarkChooser_disclosureTriangleSmallDown.png,DestName=disclosureTriangleSmallDown .png,Attributes=512,FileSize=3919,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMod e=59113472,HashOptions=0,HashPart1=1442953073,HashPart2=-371430723,HashPart3=-310126290,Ha shPart4=979563937,,)
                MSI (s) (A4:F8) [11:14:59:376]: File: C:\Program Files\Safari\Safari.resources\BookmarkChooser\disclosureTriangleSmallDown.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:376]: Executing op: FileCopy(SourceName=k5sbq2uq.png|disclosureTriangleSmallRight.png,SourceCabKey=Safari.res ources_BookmarkChooser_disclosureTriangleSmallRight.png,DestName=disclosureTriangleSmallRi ght.png,Attributes=512,FileSize=3898,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,Install Mode=59113472,HashOptions=0,HashPart1=-1154146575,HashPart2=452375669,HashPart3=1374768974 ,HashPart4=1244963953,,)
                MSI (s) (A4:F8) [11:14:59:376]: File: C:\Program Files\Safari\Safari.resources\BookmarkChooser\disclosureTriangleSmallRight.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:376]: Executing op: FileCopy(SourceName=phz-v-rw.png|GenericFolderIcon_16.png,SourceCabKey=Safari.resources_B ookmarkChooser_GenericFolderIcon_16.png,DestName=GenericFolderIcon_16.png,Attributes=512,F ileSize=533,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions =0,HashPart1=405672479,HashPart2=-1369746333,HashPart3=-1062882265,HashPart4=892736064,,)
                MSI (s) (A4:F8) [11:14:59:376]: File: C:\Program Files\Safari\Safari.resources\BookmarkChooser\GenericFolderIcon_16.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:376]: Executing op: FileCopy(SourceName=TreeView.css,SourceCabKey=Safari.resources_BookmarkChooser_TreeView.c ss,DestName=TreeView.css,Attributes=512,FileSize=957,PerTick=32768,,VerifyMedia=1,,,,,Chec kCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=1166344009,HashPart2=421733932,HashP art3=-2140864670,HashPart4=37376735,,)
                MSI (s) (A4:F8) [11:14:59:376]: File: C:\Program Files\Safari\Safari.resources\BookmarkChooser\TreeView.css;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:376]: Executing op: FileCopy(SourceName=TreeView.js,SourceCabKey=Safari.resources_BookmarkChooser_TreeView.js ,DestName=TreeView.js,Attributes=512,FileSize=12891,PerTick=32768,,VerifyMedia=1,,,,,Check CRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=380885840,HashPart2=385884936,HashPar t3=1369338228,HashPart4=-880915634,,)
                MSI (s) (A4:F8) [11:14:59:376]: File: C:\Program Files\Safari\Safari.resources\BookmarkChooser\TreeView.js;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:376]: Executing op: SetTargetFolder(Folder=C:\Program Files\Safari\Safari.resources\)
                MSI (s) (A4:F8) [11:14:59:376]: Executing op: SetSourceFolder(Folder=1\Safari\mymwmyms\|Safari\Safari.resources\)
                MSI (s) (A4:F8) [11:14:59:376]: Executing op: FileCopy(SourceName=zi_ppfhr.htm|BookmarkPreferences.html,SourceCabKey=Safari.resources_B ookmarkPreferences.html,DestName=BookmarkPreferences.html,Attributes=512,FileSize=3750,Per Tick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=-1 091046633,HashPart2=-21198524,HashPart3=-597241407,HashPart4=15748214,,)
                MSI (s) (A4:F8) [11:14:59:376]: File: C:\Program Files\Safari\Safari.resources\BookmarkPreferences.html;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:376]: Executing op: FileCopy(SourceName=gxz6lp5b.htm|BookmarkTitleChange.html,SourceCabKey=Safari.resources_B ookmarkTitleChange.html,DestName=BookmarkTitleChange.html,Attributes=512,FileSize=1379,Per Tick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=91 074985,HashPart2=-2031215548,HashPart3=1150066487,HashPart4=1389583628,,)
                MSI (s) (A4:F8) [11:14:59:376]: File: C:\Program Files\Safari\Safari.resources\BookmarkTitleChange.html;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:376]: Executing op: FileCopy(SourceName=jilhd5zb.htm|BugReport.html,SourceCabKey=Safari.resources_BugReport.h tml,DestName=BugReport.html,Attributes=512,FileSize=2685,PerTick=32768,,VerifyMedia=1,,,,, CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=121660493,HashPart2=-287389620,H ashPart3=-604073503,HashPart4=1404457827,,)
                MSI (s) (A4:F8) [11:14:59:376]: File: C:\Program Files\Safari\Safari.resources\BugReport.html;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:376]: Executing op: FileCopy(SourceName=porerccp.htm|CachesWindow.html,SourceCabKey=Safari.resources_CachesWi ndow.html,DestName=CachesWindow.html,Attributes=512,FileSize=10102,PerTick=32768,,VerifyMe dia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=2081469886,HashPart2=5 90338813,HashPart3=-553336151,HashPart4=1175698219,,)
                MSI (s) (A4:F8) [11:14:59:376]: File: C:\Program Files\Safari\Safari.resources\CachesWindow.html;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:376]: Executing op: FileCopy(SourceName=zbogkztv.png|Certificate.png,SourceCabKey=Safari.resources_Certificat e.png,DestName=Certificate.png,Attributes=512,FileSize=811,PerTick=32768,,VerifyMedia=1,,, ,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=595593825,HashPart2=124624503, HashPart3=680181881,HashPart4=11221211,,)
                MSI (s) (A4:F8) [11:14:59:376]: File: C:\Program Files\Safari\Safari.resources\Certificate.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:376]: Executing op: FileCopy(SourceName=compass.png,SourceCabKey=Safari.resources_compass.png,DestName=compas s.png,Attributes=512,FileSize=24267,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallM ode=59113472,HashOptions=0,HashPart1=-441505242,HashPart2=1398904984,HashPart3=-502580647, HashPart4=1813845791,,)
                MSI (s) (A4:F8) [11:14:59:376]: File: C:\Program Files\Safari\Safari.resources\compass.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:391]: Executing op: FileCopy(SourceName=cm3thrvf.png|compass64.png,SourceCabKey=Safari.resources_compass64.pn g,DestName=compass64.png,Attributes=512,FileSize=8773,PerTick=32768,,VerifyMedia=1,,,,,Che ckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=-229966261,HashPart2=971760895,Hash Part3=-1643319399,HashPart4=401935695,,)
                MSI (s) (A4:F8) [11:14:59:391]: File: C:\Program Files\Safari\Safari.resources\compass64.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:391]: Executing op: FileCopy(SourceName=pnkda5f1.png|CoverflowScrollThumb-Pressed.png,SourceCabKey=Safari.res ources_CoverflowScrollThumb_Pressed.png,DestName=CoverflowScrollThumb-Pressed.png,Attribut es=512,FileSize=206,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,Has hOptions=0,HashPart1=-430113018,HashPart2=1673067498,HashPart3=-1130619443,HashPart4=96023 5448,,)
                MSI (s) (A4:F8) [11:14:59:391]: File: C:\Program Files\Safari\Safari.resources\CoverflowScrollThumb-Pressed.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:391]: Executing op: FileCopy(SourceName=x6ptqzhe.png|CoverflowScrollThumbFill.png,SourceCabKey=Safari.resourc es_CoverflowScrollThumbFill.png,DestName=CoverflowScrollThumbFill.png,Attributes=512,FileS ize=203,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,H ashPart1=-1619995748,HashPart2=1790090810,HashPart3=652173845,HashPart4=-2074407654,,)
                MSI (s) (A4:F8) [11:14:59:391]: File: C:\Program Files\Safari\Safari.resources\CoverflowScrollThumbFill.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:391]: Executing op: FileCopy(SourceName=8x2tp2gt.png|CoverflowScrollThumbLeft.png,SourceCabKey=Safari.resourc es_CoverflowScrollThumbLeft.png,DestName=CoverflowScrollThumbLeft.png,Attributes=512,FileS ize=478,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,H ashPart1=488581217,HashPart2=-2135171271,HashPart3=592593419,HashPart4=-81746139,,)
                MSI (s) (A4:F8) [11:14:59:391]: File: C:\Program Files\Safari\Safari.resources\CoverflowScrollThumbLeft.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:391]: Executing op: FileCopy(SourceName=9iwudnev.png|CoverflowScrollThumbLeft-Pressed.png,SourceCabKey=Safari .resources_CoverflowScrollThumbLeft_Pressed.png,DestName=CoverflowScrollThumbLeft-Pressed. png,Attributes=512,FileSize=485,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode= 59113472,HashOptions=0,HashPart1=-300547304,HashPart2=-18664980,HashPart3=-1180030084,Hash Part4=1450668746,,)
                MSI (s) (A4:F8) [11:14:59:391]: File: C:\Program Files\Safari\Safari.resources\CoverflowScrollThumbLeft-Pressed.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:391]: Executing op: FileCopy(SourceName=cngwkf9b.png|CoverflowScrollThumbRight.png,SourceCabKey=Safari.resour ces_CoverflowScrollThumbRight.png,DestName=CoverflowScrollThumbRight.png,Attributes=512,Fi leSize=523,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions= 0,HashPart1=1416235565,HashPart2=-657305786,HashPart3=-211265215,HashPart4=1594683295,,)
                MSI (s) (A4:F8) [11:14:59:391]: File: C:\Program Files\Safari\Safari.resources\CoverflowScrollThumbRight.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:391]: Executing op: FileCopy(SourceName=2rwia8jl.png|CoverflowScrollThumbRight-Pressed.png,SourceCabKey=Safar i.resources_CoverflowScrollThumbRight_Pressed.png,DestName=CoverflowScrollThumbRight-Press ed.png,Attributes=512,FileSize=530,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMo de=59113472,HashOptions=0,HashPart1=1373548782,HashPart2=-2046676858,HashPart3=1818387780, HashPart4=679533688,,)
                MSI (s) (A4:F8) [11:14:59:391]: File: C:\Program Files\Safari\Safari.resources\CoverflowScrollThumbRight-Pressed.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:391]: Executing op: FileCopy(SourceName=2b0d9grz.png|CoverflowScrollTrackFill.png,SourceCabKey=Safari.resourc es_CoverflowScrollTrackFill.png,DestName=CoverflowScrollTrackFill.png,Attributes=512,FileS ize=185,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,H ashPart1=-1708396039,HashPart2=-1727663198,HashPart3=162462175,HashPart4=-1448325165,,)
                MSI (s) (A4:F8) [11:14:59:391]: File: C:\Program Files\Safari\Safari.resources\CoverflowScrollTrackFill.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:391]: Executing op: FileCopy(SourceName=9ihtlbcq.png|CoverflowScrollTrackLeft.png,SourceCabKey=Safari.resourc es_CoverflowScrollTrackLeft.png,DestName=CoverflowScrollTrackLeft.png,Attributes=512,FileS ize=514,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,H ashPart1=-2075300284,HashPart2=664549461,HashPart3=-1684819915,HashPart4=-931305614,,)
                MSI (s) (A4:F8) [11:14:59:391]: File: C:\Program Files\Safari\Safari.resources\CoverflowScrollTrackLeft.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:391]: Executing op: FileCopy(SourceName=y6xynxzg.png|CoverflowScrollTrackRight.png,SourceCabKey=Safari.resour ces_CoverflowScrollTrackRight.png,DestName=CoverflowScrollTrackRight.png,Attributes=512,Fi leSize=571,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions= 0,HashPart1=-1843474311,HashPart2=1507169897,HashPart3=-1256095375,HashPart4=-65535356,,)
                MSI (s) (A4:F8) [11:14:59:391]: File: C:\Program Files\Safari\Safari.resources\CoverflowScrollTrackRight.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:391]: Executing op: FileCopy(SourceName=5_mnatmh.htm|CustomizeToolbar.html,SourceCabKey=Safari.resources_Cust omizeToolbar.html,DestName=CustomizeToolbar.html,Attributes=512,FileSize=7612,PerTick=3276 8,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=-60215007,H ashPart2=-475002894,HashPart3=1961939863,HashPart4=1841317207,,)
                MSI (s) (A4:F8) [11:14:59:391]: File: C:\Program Files\Safari\Safari.resources\CustomizeToolbar.html;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:391]: Executing op: FileCopy(SourceName=h3vkdog0.plt|cvs-base.pltsuite,SourceCabKey=Safari.resources_cvs_base .pltsuite,DestName=cvs-base.pltsuite,Attributes=512,FileSize=3253,PerTick=32768,,VerifyMed ia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=584859838,HashPart2=190 8829775,HashPart3=-55628668,HashPart4=68230751,,)
                MSI (s) (A4:F8) [11:14:59:391]: File: C:\Program Files\Safari\Safari.resources\cvs-base.pltsuite;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:391]: Executing op: FileCopy(SourceName=1eysva5c.plt|cvs-js-ibench.pltsuite,SourceCabKey=Safari.resources_cvs _js_ibench.pltsuite,DestName=cvs-js-ibench.pltsuite,Attributes=512,FileSize=370,PerTick=32 768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=149981451 3,HashPart2=1744912727,HashPart3=-1245573406,HashPart4=-172946269,,)
                MSI (s) (A4:F8) [11:14:59:391]: File: C:\Program Files\Safari\Safari.resources\cvs-js-ibench.pltsuite;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:391]: Executing op: FileCopy(SourceName=bol9efru.plt|cvs-js-performance.pltsuite,SourceCabKey=Safari.resource s_cvs_js_performance.pltsuite,DestName=cvs-js-performance.pltsuite,Attributes=512,FileSize =223,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,Hash Part1=-541885003,HashPart2=-2068133701,HashPart3=-1879193409,HashPart4=-1192765003,,)
                MSI (s) (A4:F8) [11:14:59:407]: File: C:\Program Files\Safari\Safari.resources\cvs-js-performance.pltsuite;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:469]: Executing op: FileCopy(SourceName=pgqkbe9i.plt|cvs-static-urls.pltsuite,SourceCabKey=Safari.resources_c vs_static_urls.pltsuite,DestName=cvs-static-urls.pltsuite,Attributes=512,FileSize=677,PerT ick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=507 47961,HashPart2=779305200,HashPart3=2018541923,HashPart4=619668293,,)
                MSI (s) (A4:F8) [11:14:59:469]: File: C:\Program Files\Safari\Safari.resources\cvs-static-urls.pltsuite;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:469]: Executing op: FileCopy(SourceName=c959s3ln.plt|cvs-torture-test.pltsuite,SourceCabKey=Safari.resources_ cvs_torture_test.pltsuite,DestName=cvs-torture-test.pltsuite,Attributes=512,FileSize=1158, PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1 =-574456580,HashPart2=666125632,HashPart3=-2060747902,HashPart4=-1250947176,,)
                MSI (s) (A4:F8) [11:14:59:469]: File: C:\Program Files\Safari\Safari.resources\cvs-torture-test.pltsuite;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:469]: Executing op: SetTargetFolder(Folder=C:\Program Files\Safari\Safari.resources\da.lproj\)
                MSI (s) (A4:F8) [11:14:59:469]: Executing op: SetSourceFolder(Folder=1\Safari\mymwmyms\bgge6o7q\|Safari\Safari.resources\da.lproj\)
                MSI (s) (A4:F8) [11:14:59:469]: Executing op: FileCopy(SourceName=soebvail.pli|ABAutoCompleteMappings.plist,SourceCabKey=Safari.resourc es_da.lproj_ABAutoCompleteMappings.plist,DestName=ABAutoCompleteMappings.plist,Attributes= 512,FileSize=12029,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,Hash Options=0,HashPart1=-1834581364,HashPart2=676956881,HashPart3=-1247329010,HashPart4=-21508 0481,,)
                MSI (s) (A4:F8) [11:14:59:469]: File: C:\Program Files\Safari\Safari.resources\da.lproj\ABAutoCompleteMappings.plist;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:469]: Executing op: FileCopy(SourceName=rx-cnly-.pli|BuiltInBookmarks.plist,SourceCabKey=Safari.resources_da. lproj_BuiltInBookmarks.plist,DestName=BuiltInBookmarks.plist,Attributes=512,FileSize=1195, PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1 =-1695332774,HashPart2=859144540,HashPart3=188211834,HashPart4=87122933,,)
                MSI (s) (A4:F8) [11:14:59:469]: File: C:\Program Files\Safari\Safari.resources\da.lproj\BuiltInBookmarks.plist;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:469]: Executing op: FileCopy(SourceName=smsipszk.str|Localizable.strings,SourceCabKey=Safari.resources_da.lpr oj_Localizable.strings,DestName=Localizable.strings,Attributes=512,FileSize=337936,PerTick =32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=-20194 53077,HashPart2=-348681349,HashPart3=-252409611,HashPart4=-13836522,,)
                MSI (s) (A4:F8) [11:14:59:469]: File: C:\Program Files\Safari\Safari.resources\da.lproj\Localizable.strings;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:469]: Executing op: FileCopy(SourceName=kpp8oqoz.js|localizedStrings.js,SourceCabKey=Safari.resources_da.lpro j_localizedStrings.js,DestName=localizedStrings.js,Attributes=512,FileSize=54304,PerTick=3 2768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=-5655720 06,HashPart2=594024873,HashPart3=530611915,HashPart4=-498034526,,)
                MSI (s) (A4:F8) [11:14:59:469]: File: C:\Program Files\Safari\Safari.resources\da.lproj\localizedStrings.js;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:469]: Executing op: SetTargetFolder(Folder=C:\Program Files\Safari\Safari.resources\de.lproj\)
                MSI (s) (A4:F8) [11:14:59:469]: Executing op: SetSourceFolder(Folder=1\Safari\mymwmyms\2vws9zxc\|Safari\Safari.resources\de.lproj\)
                MSI (s) (A4:F8) [11:14:59:469]: Executing op: FileCopy(SourceName=gjrpknh2.pli|ABAutoCompleteMappings.plist,SourceCabKey=Safari.resourc es_de.lproj_ABAutoCompleteMappings.plist,DestName=ABAutoCompleteMappings.plist,Attributes= 512,FileSize=11382,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,Hash Options=0,HashPart1=-524008101,HashPart2=-1955563123,HashPart3=-1416582097,HashPart4=-6793 02049,,)
                MSI (s) (A4:F8) [11:14:59:469]: File: C:\Program Files\Safari\Safari.resources\de.lproj\ABAutoCompleteMappings.plist;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:469]: Executing op: FileCopy(SourceName=bindict,SourceCabKey=Safari.resources_de.lproj_bindict,DestName=bindi ct,Attributes=512,FileSize=7848,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode= 59113472,HashOptions=0,HashPart1=-1429795000,HashPart2=-1641468851,HashPart3=-852981373,Ha shPart4=962946942,,)
                MSI (s) (A4:F8) [11:14:59:469]: File: C:\Program Files\Safari\Safari.resources\de.lproj\bindict;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:469]: Executing op: FileCopy(SourceName=ms5sumn_.pli|BuiltInBookmarks.plist,SourceCabKey=Safari.resources_de. lproj_BuiltInBookmarks.plist,DestName=BuiltInBookmarks.plist,Attributes=512,FileSize=12304 ,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart 1=523708431,HashPart2=1727526388,HashPart3=965590932,HashPart4=1432472075,,)
                MSI (s) (A4:F8) [11:14:59:469]: File: C:\Program Files\Safari\Safari.resources\de.lproj\BuiltInBookmarks.plist;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:469]: Executing op: FileCopy(SourceName=35q-rzf2.dat|Dictionary.dat,SourceCabKey=Safari.resources_de.lproj_Di ctionary.dat,DestName=Dictionary.dat,Attributes=512,FileSize=1344512,PerTick=32768,,Verify Media=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=815139238,HashPart2= -2071198798,HashPart3=-1362494504,HashPart4=-998120044,,)
                MSI (s) (A4:F8) [11:14:59:485]: File: C:\Program Files\Safari\Safari.resources\de.lproj\Dictionary.dat;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:485]: Executing op: FileCopy(SourceName=yei7le3n.str|Localizable.strings,SourceCabKey=Safari.resources_de.lpr oj_Localizable.strings,DestName=Localizable.strings,Attributes=512,FileSize=351750,PerTick =32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=777626 ,HashPart2=-1134473050,HashPart3=-1746308150,HashPart4=275214854,,)
                MSI (s) (A4:F8) [11:14:59:485]: File: C:\Program Files\Safari\Safari.resources\de.lproj\Localizable.strings;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:485]: Executing op: FileCopy(SourceName=k68ijtsz.js|localizedStrings.js,SourceCabKey=Safari.resources_de.lpro j_localizedStrings.js,DestName=localizedStrings.js,Attributes=512,FileSize=56232,PerTick=3 2768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=20416191 69,HashPart2=-1879600527,HashPart3=-1820675114,HashPart4=-443085423,,)
                MSI (s) (A4:F8) [11:14:59:485]: File: C:\Program Files\Safari\Safari.resources\de.lproj\localizedStrings.js;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:485]: Executing op: SetTargetFolder(Folder=C:\Program Files\Safari\Safari.resources\)
                MSI (s) (A4:F8) [11:14:59:485]: Executing op: SetSourceFolder(Folder=1\Safari\mymwmyms\|Safari\Safari.resources\)
                MSI (s) (A4:F8) [11:14:59:485]: Executing op: FileCopy(SourceName=zystwnu3.pli|Defaults.plist,SourceCabKey=Safari.resources_Defaults.pl ist,DestName=Defaults.plist,Attributes=512,FileSize=4190,PerTick=32768,,VerifyMedia=1,,,,, CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=-736028050,HashPart2=36239529,Ha shPart3=1656216274,HashPart4=-773979720,,)
                MSI (s) (A4:F8) [11:14:59:485]: File: C:\Program Files\Safari\Safari.resources\Defaults.plist;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:485]: Executing op: FileCopy(SourceName=Dialog.css,SourceCabKey=Safari.resources_Dialog.css,DestName=Dialog.c ss,Attributes=512,FileSize=775,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=5 9113472,HashOptions=0,HashPart1=729900602,HashPart2=-62517750,HashPart3=1699476018,HashPar t4=-186862631,,)
                MSI (s) (A4:F8) [11:14:59:485]: File: C:\Program Files\Safari\Safari.resources\Dialog.css;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:485]: Executing op: FileCopy(SourceName=3ru9x8hc.htm|DownloadPromptDialog.html,SourceCabKey=Safari.resources_ DownloadPromptDialog.html,DestName=DownloadPromptDialog.html,Attributes=512,FileSize=2723, PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1 =575363843,HashPart2=-74129672,HashPart3=1735074434,HashPart4=-1763118715,,)
                MSI (s) (A4:F8) [11:14:59:500]: File: C:\Program Files\Safari\Safari.resources\DownloadPromptDialog.html;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:500]: Executing op: SetTargetFolder(Folder=C:\Program Files\Safari\Safari.resources\en.lproj\)
                MSI (s) (A4:F8) [11:14:59:500]: Executing op: SetSourceFolder(Folder=1\Safari\mymwmyms\if03vd8p\|Safari\Safari.resources\en.lproj\)
                MSI (s) (A4:F8) [11:14:59:500]: Executing op: FileCopy(SourceName=8lelxebj.pli|ABAutoCompleteMappings.plist,SourceCabKey=Safari.resourc es_en.lproj_ABAutoCompleteMappings.plist,DestName=ABAutoCompleteMappings.plist,Attributes= 512,FileSize=12040,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,Hash Options=0,HashPart1=-1000663358,HashPart2=-79835401,HashPart3=-1914565426,HashPart4=-23955 1986,,)
                MSI (s) (A4:F8) [11:14:59:500]: File: C:\Program Files\Safari\Safari.resources\en.lproj\ABAutoCompleteMappings.plist;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:500]: Executing op: FileCopy(SourceName=bindict,SourceCabKey=Safari.resources_en.lproj_bindict,DestName=bindi ct,Attributes=512,FileSize=537504,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMod e=59113472,HashOptions=0,HashPart1=1082410389,HashPart2=1811467180,HashPart3=846258704,Has hPart4=1348708637,,)
                MSI (s) (A4:F8) [11:14:59:500]: File: C:\Program Files\Safari\Safari.resources\en.lproj\bindict;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:500]: Executing op: FileCopy(SourceName=bindict1,SourceCabKey=Safari.resources_en.lproj_bindict1,DestName=bin dict1,Attributes=512,FileSize=255544,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,Install Mode=59113472,HashOptions=0,HashPart1=-1200633843,HashPart2=593149731,HashPart3=-894176036 ,HashPart4=350161274,,)
                MSI (s) (A4:F8) [11:14:59:500]: File: C:\Program Files\Safari\Safari.resources\en.lproj\bindict1;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:500]: Executing op: FileCopy(SourceName=bindict2,SourceCabKey=Safari.resources_en.lproj_bindict2,DestName=bin dict2,Attributes=512,FileSize=132940,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,Install Mode=59113472,HashOptions=0,HashPart1=-1654639061,HashPart2=2125132825,HashPart3=-11732534 40,HashPart4=1551791181,,)
                MSI (s) (A4:F8) [11:14:59:500]: File: C:\Program Files\Safari\Safari.resources\en.lproj\bindict2;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:500]: Executing op: FileCopy(SourceName=bindict3,SourceCabKey=Safari.resources_en.lproj_bindict3,DestName=bin dict3,Attributes=512,FileSize=1151680,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,Instal lMode=59113472,HashOptions=0,HashPart1=-894592485,HashPart2=4905429,HashPart3=591530847,Ha shPart4=1095588085,,)
                MSI (s) (A4:F8) [11:14:59:500]: File: C:\Program Files\Safari\Safari.resources\en.lproj\bindict3;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:500]: Executing op: FileCopy(SourceName=9wk4ijia.pli|BuiltInBookmarks.plist,SourceCabKey=Safari.resources_en. lproj_BuiltInBookmarks.plist,DestName=BuiltInBookmarks.plist,Attributes=512,FileSize=1743, PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1 =-1769349550,HashPart2=1941158714,HashPart3=-872021646,HashPart4=-146046754,,)
                MSI (s) (A4:F8) [11:14:59:516]: File: C:\Program Files\Safari\Safari.resources\en.lproj\BuiltInBookmarks.plist;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:516]: Executing op: FileCopy(SourceName=blmvu-z8.dat|Dictionary.dat,SourceCabKey=Safari.resources_en.lproj_Di ctionary.dat,DestName=Dictionary.dat,Attributes=512,FileSize=926208,PerTick=32768,,VerifyM edia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=-559654292,HashPart2= -1430170237,HashPart3=-1140853508,HashPart4=1852344842,,)
                MSI (s) (A4:F8) [11:14:59:516]: File: C:\Program Files\Safari\Safari.resources\en.lproj\Dictionary.dat;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:516]: Executing op: FileCopy(SourceName=t2_wkufg.str|Localizable.strings,SourceCabKey=Safari.resources_en.lpr oj_Localizable.strings,DestName=Localizable.strings,Attributes=512,FileSize=334668,PerTick =32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=-10310 55144,HashPart2=-1776389241,HashPart3=2070048929,HashPart4=1187526501,,)
                MSI (s) (A4:F8) [11:14:59:516]: File: C:\Program Files\Safari\Safari.resources\en.lproj\Localizable.strings;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:516]: Executing op: FileCopy(SourceName=gh9vr03n.js|localizedStrings.js,SourceCabKey=Safari.resources_en.lpro j_localizedStrings.js,DestName=localizedStrings.js,Attributes=512,FileSize=53066,PerTick=3 2768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=17347401 41,HashPart2=-943332069,HashPart3=-2003591530,HashPart4=1144788744,,)
                MSI (s) (A4:F8) [11:14:59:516]: File: C:\Program Files\Safari\Safari.resources\en.lproj\localizedStrings.js;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:516]: Executing op: SetTargetFolder(Folder=C:\Program Files\Safari\Safari.resources\en_AU.lproj\)
                MSI (s) (A4:F8) [11:14:59:516]: Executing op: SetSourceFolder(Folder=1\Safari\mymwmyms\32cal1it\|Safari\Safari.resources\en_AU.lproj\)
                MSI (s) (A4:F8) [11:14:59:516]: Executing op: FileCopy(SourceName=bindict,SourceCabKey=Safari.resources_en_AU.lproj_bindict,DestName=bi ndict,Attributes=512,FileSize=537504,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,Install Mode=59113472,HashOptions=0,HashPart1=1082410389,HashPart2=1811467180,HashPart3=846258704, HashPart4=1348708637,,)
                MSI (s) (A4:F8) [11:14:59:516]: File: C:\Program Files\Safari\Safari.resources\en_AU.lproj\bindict;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:516]: Executing op: SetTargetFolder(Folder=C:\Program Files\Safari\Safari.resources\en_CA.lproj\)
                MSI (s) (A4:F8) [11:14:59:516]: Executing op: SetSourceFolder(Folder=1\Safari\mymwmyms\i3kip5wd\|Safari\Safari.resources\en_CA.lproj\)
                MSI (s) (A4:F8) [11:14:59:516]: Executing op: FileCopy(SourceName=bindict,SourceCabKey=Safari.resources_en_CA.lproj_bindict,DestName=bi ndict,Attributes=512,FileSize=537504,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,Install Mode=59113472,HashOptions=0,HashPart1=1082410389,HashPart2=1811467180,HashPart3=846258704, HashPart4=1348708637,,)
                MSI (s) (A4:F8) [11:14:59:532]: File: C:\Program Files\Safari\Safari.resources\en_CA.lproj\bindict;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:532]: Executing op: SetTargetFolder(Folder=C:\Program Files\Safari\Safari.resources\en_GB.lproj\)
                MSI (s) (A4:F8) [11:14:59:532]: Executing op: SetSourceFolder(Folder=1\Safari\mymwmyms\vdtgumuz\|Safari\Safari.resources\en_GB.lproj\)
                MSI (s) (A4:F8) [11:14:59:532]: Executing op: FileCopy(SourceName=bindict,SourceCabKey=Safari.resources_en_GB.lproj_bindict,DestName=bi ndict,Attributes=512,FileSize=537504,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,Install Mode=59113472,HashOptions=0,HashPart1=1082410389,HashPart2=1811467180,HashPart3=846258704, HashPart4=1348708637,,)
                MSI (s) (A4:F8) [11:14:59:532]: File: C:\Program Files\Safari\Safari.resources\en_GB.lproj\bindict;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:532]: Executing op: SetTargetFolder(Folder=C:\Program Files\Safari\Safari.resources\)
                MSI (s) (A4:F8) [11:14:59:532]: Executing op: SetSourceFolder(Folder=1\Safari\mymwmyms\|Safari\Safari.resources\)
                MSI (s) (A4:F8) [11:14:59:532]: Executing op: FileCopy(SourceName=l11ugdd1.plt|epoxy-base.pltsuite,SourceCabKey=Safari.resources_epoxy_ base.pltsuite,DestName=epoxy-base.pltsuite,Attributes=512,FileSize=2092,PerTick=32768,,Ver ifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=778313737,HashPar t2=-1730670511,HashPart3=498948945,HashPart4=-2003811781,,)
                MSI (s) (A4:F8) [11:14:59:532]: File: C:\Program Files\Safari\Safari.resources\epoxy-base.pltsuite;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:532]: Executing op: FileCopy(SourceName=Error.png,SourceCabKey=Safari.resources_Error.png,DestName=Error.png, Attributes=512,FileSize=4059,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=591 13472,HashOptions=0,HashPart1=-992458749,HashPart2=411629116,HashPart3=345483473,HashPart4 =703671159,,)
                MSI (s) (A4:F8) [11:14:59:532]: File: C:\Program Files\Safari\Safari.resources\Error.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:532]: Executing op: FileCopy(SourceName=n1pqttpi.png|ErrorPageBackgroundTile.png,SourceCabKey=Safari.resource s_ErrorPageBackgroundTile.png,DestName=ErrorPageBackgroundTile.png,Attributes=512,FileSize =7368,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,Has hPart1=-323621282,HashPart2=1129860041,HashPart3=-1969697587,HashPart4=-995047078,,)
                MSI (s) (A4:F8) [11:14:59:532]: File: C:\Program Files\Safari\Safari.resources\ErrorPageBackgroundTile.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:532]: Executing op: FileCopy(SourceName=bmqcvlrk.png|ErrorPageCompass.png,SourceCabKey=Safari.resources_Error PageCompass.png,DestName=ErrorPageCompass.png,Attributes=512,FileSize=19063,PerTick=32768, ,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=111704205,Has hPart2=1390884251,HashPart3=491605429,HashPart4=215935289,,)
                MSI (s) (A4:F8) [11:14:59:532]: File: C:\Program Files\Safari\Safari.resources\ErrorPageCompass.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:532]: Executing op: FileCopy(SourceName=ntvohwg7.png|ErrorPageDividerLine.png,SourceCabKey=Safari.resources_E rrorPageDividerLine.png,DestName=ErrorPageDividerLine.png,Attributes=512,FileSize=2861,Per Tick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=11 96266925,HashPart2=1647966995,HashPart3=867910466,HashPart4=-676196388,,)
                MSI (s) (A4:F8) [11:14:59:532]: File: C:\Program Files\Safari\Safari.resources\ErrorPageDividerLine.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:532]: Executing op: FileCopy(SourceName=t-nzmgyn.png|ErrorSmall.png,SourceCabKey=Safari.resources_ErrorSmall. png,DestName=ErrorSmall.png,Attributes=512,FileSize=4337,PerTick=32768,,VerifyMedia=1,,,,, CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=1852617951,HashPart2=1720960168, HashPart3=-163879364,HashPart4=2138079038,,)
                MSI (s) (A4:F8) [11:14:59:532]: File: C:\Program Files\Safari\Safari.resources\ErrorSmall.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:532]: Executing op: SetTargetFolder(Folder=C:\Program Files\Safari\Safari.resources\es.lproj\)
                MSI (s) (A4:F8) [11:14:59:532]: Executing op: SetSourceFolder(Folder=1\Safari\mymwmyms\wfggj__z\|Safari\Safari.resources\es.lproj\)
                MSI (s) (A4:F8) [11:14:59:532]: Executing op: FileCopy(SourceName=8pehebjy.pli|ABAutoCompleteMappings.plist,SourceCabKey=Safari.resourc es_es.lproj_ABAutoCompleteMappings.plist,DestName=ABAutoCompleteMappings.plist,Attributes= 512,FileSize=14201,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,Hash Options=0,HashPart1=-2088005396,HashPart2=71793113,HashPart3=1926124933,HashPart4=-1791125 782,,)
                MSI (s) (A4:F8) [11:14:59:532]: File: C:\Program Files\Safari\Safari.resources\es.lproj\ABAutoCompleteMappings.plist;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:532]: Executing op: FileCopy(SourceName=bindict,SourceCabKey=Safari.resources_es.lproj_bindict,DestName=bindi ct,Attributes=512,FileSize=1052,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode= 59113472,HashOptions=0,HashPart1=-1770469188,HashPart2=-1321566491,HashPart3=642985237,Has hPart4=-1163033169,,)
                MSI (s) (A4:F8) [11:14:59:532]: File: C:\Program Files\Safari\Safari.resources\es.lproj\bindict;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:532]: Executing op: FileCopy(SourceName=6vtjjilv.pli|BuiltInBookmarks.plist,SourceCabKey=Safari.resources_es. lproj_BuiltInBookmarks.plist,DestName=BuiltInBookmarks.plist,Attributes=512,FileSize=10094 ,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart 1=-1868798968,HashPart2=298200072,HashPart3=644043582,HashPart4=-1641123287,,)
                MSI (s) (A4:F8) [11:14:59:547]: File: C:\Program Files\Safari\Safari.resources\es.lproj\BuiltInBookmarks.plist;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:547]: Executing op: FileCopy(SourceName=xiaojrpz.dat|Dictionary.dat,SourceCabKey=Safari.resources_es.lproj_Di ctionary.dat,DestName=Dictionary.dat,Attributes=512,FileSize=689152,PerTick=32768,,VerifyM edia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=-57613090,HashPart2=1 716645832,HashPart3=-1717006051,HashPart4=1602771507,,)
                MSI (s) (A4:F8) [11:14:59:547]: File: C:\Program Files\Safari\Safari.resources\es.lproj\Dictionary.dat;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:547]: Executing op: FileCopy(SourceName=y_oahqqo.str|Localizable.strings,SourceCabKey=Safari.resources_es.lpr oj_Localizable.strings,DestName=Localizable.strings,Attributes=512,FileSize=350484,PerTick =32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=103873 1353,HashPart2=-885177660,HashPart3=2013632697,HashPart4=-362377641,,)
                MSI (s) (A4:F8) [11:14:59:547]: File: C:\Program Files\Safari\Safari.resources\es.lproj\Localizable.strings;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:547]: Executing op: FileCopy(SourceName=vmqut80a.js|localizedStrings.js,SourceCabKey=Safari.resources_es.lpro j_localizedStrings.js,DestName=localizedStrings.js,Attributes=512,FileSize=57608,PerTick=3 2768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=15600107 59,HashPart2=860622581,HashPart3=-466272304,HashPart4=329944382,,)
                MSI (s) (A4:F8) [11:14:59:547]: File: C:\Program Files\Safari\Safari.resources\es.lproj\localizedStrings.js;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:547]: Executing op: SetTargetFolder(Folder=C:\Program Files\Safari\Safari.resources\)
                MSI (s) (A4:F8) [11:14:59:547]: Executing op: SetSourceFolder(Folder=1\Safari\mymwmyms\|Safari\Safari.resources\)
                MSI (s) (A4:F8) [11:14:59:547]: Executing op: FileCopy(SourceName=k3aaznfi.pli|EVRoots.plist,SourceCabKey=Safari.resources_EVRoots.plis t,DestName=EVRoots.plist,Attributes=512,FileSize=5353,PerTick=32768,,VerifyMedia=1,,,,,Che ckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=132372203,HashPart2=980348680,HashP art3=-621691063,HashPart4=-1142984215,,)
                MSI (s) (A4:F8) [11:14:59:547]: File: C:\Program Files\Safari\Safari.resources\EVRoots.plist;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:547]: Executing op: FileCopy(SourceName=thknjgvb.css|ExtensionBar.css,SourceCabKey=Safari.resources_Extension Bar.css,DestName=ExtensionBar.css,Attributes=512,FileSize=436,PerTick=32768,,VerifyMedia=1 ,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=-1619275166,HashPart2=58383 4810,HashPart3=-956505895,HashPart4=-2109886568,,)
                MSI (s) (A4:F8) [11:14:59:547]: File: C:\Program Files\Safari\Safari.resources\ExtensionBar.css;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:547]: Executing op: FileCopy(SourceName=xufpcxqk.css|ExtensionBarWin.css,SourceCabKey=Safari.resources_Extens ionBarWin.css,DestName=ExtensionBarWin.css,Attributes=512,FileSize=637,PerTick=32768,,Veri fyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=857286768,HashPart 2=-166342035,HashPart3=1348124416,HashPart4=-342802187,,)
                MSI (s) (A4:F8) [11:14:59:547]: File: C:\Program Files\Safari\Safari.resources\ExtensionBarWin.css;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:547]: Executing op: FileCopy(SourceName=ask_9i18.css|ExtensionBuilder.css,SourceCabKey=Safari.resources_Exten sionBuilder.css,DestName=ExtensionBuilder.css,Attributes=512,FileSize=7929,PerTick=32768,, VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=1610551766,Has hPart2=521490941,HashPart3=1969109624,HashPart4=-39181962,,)
                MSI (s) (A4:F8) [11:14:59:547]: File: C:\Program Files\Safari\Safari.resources\ExtensionBuilder.css;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:547]: Executing op: FileCopy(SourceName=1nrkexmc.htm|ExtensionBuilder.html,SourceCabKey=Safari.resources_Exte nsionBuilder.html,DestName=ExtensionBuilder.html,Attributes=512,FileSize=1131,PerTick=3276 8,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=-489231611, HashPart2=-1565425209,HashPart3=-1777869050,HashPart4=1492345932,,)
                MSI (s) (A4:F8) [11:14:59:547]: File: C:\Program Files\Safari\Safari.resources\ExtensionBuilder.html;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:547]: Executing op: FileCopy(SourceName=kxvvfj4u.js|ExtensionBuilder.js,SourceCabKey=Safari.resources_Extensi onBuilder.js,DestName=ExtensionBuilder.js,Attributes=512,FileSize=54070,PerTick=32768,,Ver ifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=-552433637,HashPa rt2=-2084707568,HashPart3=-583362096,HashPart4=1040385990,,)
                MSI (s) (A4:F8) [11:14:59:563]: File: C:\Program Files\Safari\Safari.resources\ExtensionBuilder.js;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:563]: Executing op: FileCopy(SourceName=v9ga1jmh.png|ExtensionClose.png,SourceCabKey=Safari.resources_Extensi onClose.png,DestName=ExtensionClose.png,Attributes=512,FileSize=320,PerTick=32768,,VerifyM edia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=-1249392093,HashPart2 =-960336365,HashPart3=-1748899445,HashPart4=769579264,,)
                MSI (s) (A4:F8) [11:14:59:563]: File: C:\Program Files\Safari\Safari.resources\ExtensionClose.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:563]: Executing op: FileCopy(SourceName=0ckbnv2p.png|ExtensionCloseHovered.png,SourceCabKey=Safari.resources_ ExtensionCloseHovered.png,DestName=ExtensionCloseHovered.png,Attributes=512,FileSize=315,P erTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1= -1538258768,HashPart2=1666660534,HashPart3=-413811916,HashPart4=-635049257,,)
                MSI (s) (A4:F8) [11:14:59:563]: File: C:\Program Files\Safari\Safari.resources\ExtensionCloseHovered.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:563]: Executing op: FileCopy(SourceName=ou_--sxr.png|ExtensionClosePressed.png,SourceCabKey=Safari.resources_ ExtensionClosePressed.png,DestName=ExtensionClosePressed.png,Attributes=512,FileSize=377,P erTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1= 152417129,HashPart2=-1084856218,HashPart3=-2051723046,HashPart4=2069539858,,)
                MSI (s) (A4:F8) [11:14:59:563]: File: C:\Program Files\Safari\Safari.resources\ExtensionClosePressed.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:563]: Executing op: FileCopy(SourceName=jgtz2z2k.png|ExtensionDefaultIcon32.png,SourceCabKey=Safari.resources _ExtensionDefaultIcon32.png,DestName=ExtensionDefaultIcon32.png,Attributes=512,FileSize=24 44,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPa rt1=-580220707,HashPart2=-154669807,HashPart3=571761789,HashPart4=-1250950084,,)
                MSI (s) (A4:F8) [11:14:59:563]: File: C:\Program Files\Safari\Safari.resources\ExtensionDefaultIcon32.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:563]: Executing op: FileCopy(SourceName=yhyukbbe.png|ExtensionDefaultIcon48.png,SourceCabKey=Safari.resources _ExtensionDefaultIcon48.png,DestName=ExtensionDefaultIcon48.png,Attributes=512,FileSize=47 99,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPa rt1=2034699964,HashPart2=57436675,HashPart3=1627780363,HashPart4=-15756320,,)
                MSI (s) (A4:F8) [11:14:59:563]: File: C:\Program Files\Safari\Safari.resources\ExtensionDefaultIcon48.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:563]: Executing op: FileCopy(SourceName=ghsefivp.png|ExtensionDefaultIcon64.png,SourceCabKey=Safari.resources _ExtensionDefaultIcon64.png,DestName=ExtensionDefaultIcon64.png,Attributes=512,FileSize=74 15,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPa rt1=-711550437,HashPart2=2055385238,HashPart3=1209136931,HashPart4=-1709050398,,)
                MSI (s) (A4:F8) [11:14:59:563]: File: C:\Program Files\Safari\Safari.resources\ExtensionDefaultIcon64.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:563]: Executing op: FileCopy(SourceName=0ojp9swp.css|ExtensionSettings.css,SourceCabKey=Safari.resources_Exte nsionSettings.css,DestName=ExtensionSettings.css,Attributes=512,FileSize=4719,PerTick=3276 8,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=-355369981, HashPart2=1700659121,HashPart3=-2016796393,HashPart4=1323027316,,)
                MSI (s) (A4:F8) [11:14:59:563]: File: C:\Program Files\Safari\Safari.resources\ExtensionSettings.css;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:563]: Executing op: FileCopy(SourceName=71kkqdb7.js|ExtensionSettings.js,SourceCabKey=Safari.resources_Extens ionSettings.js,DestName=ExtensionSettings.js,Attributes=512,FileSize=29958,PerTick=32768,, VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=-180320073,Has hPart2=62541054,HashPart3=1596069969,HashPart4=-345284549,,)
                MSI (s) (A4:F8) [11:14:59:563]: File: C:\Program Files\Safari\Safari.resources\ExtensionSettings.js;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:563]: Executing op: FileCopy(SourceName=zznaeihs.css|ExtensionsView.css,SourceCabKey=Safari.resources_Extensi onsView.css,DestName=ExtensionsView.css,Attributes=512,FileSize=10611,PerTick=32768,,Verif yMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=860464372,HashPart2 =-553974969,HashPart3=-1505556013,HashPart4=-2102775053,,)
                MSI (s) (A4:F8) [11:14:59:563]: File: C:\Program Files\Safari\Safari.resources\ExtensionsView.css;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:563]: Executing op: FileCopy(SourceName=vpad6jxi.htm|ExtensionsView.html,SourceCabKey=Safari.resources_Extens ionsView.html,DestName=ExtensionsView.html,Attributes=512,FileSize=3750,PerTick=32768,,Ver ifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=-609073801,HashPa rt2=-1590868318,HashPart3=1039322063,HashPart4=2016800984,,)
                MSI (s) (A4:F8) [11:14:59:563]: File: C:\Program Files\Safari\Safari.resources\ExtensionsView.html;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:563]: Executing op: FileCopy(SourceName=s6nujcli.js|ExtensionsView.js,SourceCabKey=Safari.resources_Extension sView.js,DestName=ExtensionsView.js,Attributes=512,FileSize=30585,PerTick=32768,,VerifyMed ia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=-474270828,HashPart2=-5 75806010,HashPart3=379700697,HashPart4=660884804,,)
                MSI (s) (A4:F8) [11:14:59:563]: File: C:\Program Files\Safari\Safari.resources\ExtensionsView.js;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:563]: Executing op: SetTargetFolder(Folder=C:\Program Files\Safari\Safari.resources\fi.lproj\)
                MSI (s) (A4:F8) [11:14:59:563]: Executing op: SetSourceFolder(Folder=1\Safari\mymwmyms\wq0hbrgt\|Safari\Safari.resources\fi.lproj\)
                MSI (s) (A4:F8) [11:14:59:563]: Executing op: FileCopy(SourceName=_3c_w42d.pli|ABAutoCompleteMappings.plist,SourceCabKey=Safari.resourc es_fi.lproj_ABAutoCompleteMappings.plist,DestName=ABAutoCompleteMappings.plist,Attributes= 512,FileSize=11106,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,Hash Options=0,HashPart1=1406596467,HashPart2=-686513734,HashPart3=-368438446,HashPart4=8883425 11,,)
                MSI (s) (A4:F8) [11:14:59:563]: File: C:\Program Files\Safari\Safari.resources\fi.lproj\ABAutoCompleteMappings.plist;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:563]: Executing op: FileCopy(SourceName=-xtxvtgz.pli|BuiltInBookmarks.plist,SourceCabKey=Safari.resources_fi. lproj_BuiltInBookmarks.plist,DestName=BuiltInBookmarks.plist,Attributes=512,FileSize=1633, PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1 =727813243,HashPart2=1750293118,HashPart3=459620059,HashPart4=-1791967155,,)
                MSI (s) (A4:F8) [11:14:59:578]: File: C:\Program Files\Safari\Safari.resources\fi.lproj\BuiltInBookmarks.plist;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:578]: Executing op: FileCopy(SourceName=ewy32iyo.str|Localizable.strings,SourceCabKey=Safari.resources_fi.lpr oj_Localizable.strings,DestName=Localizable.strings,Attributes=512,FileSize=341678,PerTick =32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=633311 852,HashPart2=-1449274676,HashPart3=455347513,HashPart4=-939634738,,)
                MSI (s) (A4:F8) [11:14:59:578]: File: C:\Program Files\Safari\Safari.resources\fi.lproj\Localizable.strings;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:578]: Executing op: FileCopy(SourceName=o1mu3jpc.js|localizedStrings.js,SourceCabKey=Safari.resources_fi.lpro j_localizedStrings.js,DestName=localizedStrings.js,Attributes=512,FileSize=55406,PerTick=3 2768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=-9445988 58,HashPart2=-2034711927,HashPart3=-550391237,HashPart4=-1363281423,,)
                MSI (s) (A4:F8) [11:14:59:578]: File: C:\Program Files\Safari\Safari.resources\fi.lproj\localizedStrings.js;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:578]: Executing op: SetTargetFolder(Folder=C:\Program Files\Safari\Safari.resources\)
                MSI (s) (A4:F8) [11:14:59:578]: Executing op: SetSourceFolder(Folder=1\Safari\mymwmyms\|Safari\Safari.resources\)
                MSI (s) (A4:F8) [11:14:59:578]: Executing op: FileCopy(SourceName=hxm-khnj.htm|FindBanner.html,SourceCabKey=Safari.resources_FindBanner .html,DestName=FindBanner.html,Attributes=512,FileSize=11423,PerTick=32768,,VerifyMedia=1, ,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=-2037361292,HashPart2=112586 8559,HashPart3=2013983869,HashPart4=-444991296,,)
                MSI (s) (A4:F8) [11:14:59:578]: File: C:\Program Files\Safari\Safari.resources\FindBanner.html;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:578]: Executing op: FileCopy(SourceName=4vavstid.css|FlowViewFindBanner.css,SourceCabKey=Safari.resources_Flo wViewFindBanner.css,DestName=FlowViewFindBanner.css,Attributes=512,FileSize=2411,PerTick=3 2768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=-9953789 02,HashPart2=-2013763306,HashPart3=-579457337,HashPart4=1750174350,,)
                MSI (s) (A4:F8) [11:14:59:578]: File: C:\Program Files\Safari\Safari.resources\FlowViewFindBanner.css;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:578]: Executing op: FileCopy(SourceName=0d50ambw.htm|FlowViewFindBanner.html,SourceCabKey=Safari.resources_Fl owViewFindBanner.html,DestName=FlowViewFindBanner.html,Attributes=512,FileSize=6576,PerTic k=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=93572 3520,HashPart2=-897110374,HashPart3=-1018046915,HashPart4=-1812148492,,)
                MSI (s) (A4:F8) [11:14:59:578]: File: C:\Program Files\Safari\Safari.resources\FlowViewFindBanner.html;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:578]: Executing op: FileCopy(SourceName=eq0-cejx.png|FlowViewSearchField.png,SourceCabKey=Safari.resources_Fl owViewSearchField.png,DestName=FlowViewSearchField.png,Attributes=512,FileSize=1075,PerTic k=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=-1074 31778,HashPart2=-1471285167,HashPart3=958602529,HashPart4=-656659072,,)
                MSI (s) (A4:F8) [11:14:59:578]: File: C:\Program Files\Safari\Safari.resources\FlowViewSearchField.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:578]: Executing op: FileCopy(SourceName=hjry1lf9.png|FlowViewSplitter.png,SourceCabKey=Safari.resources_FlowV iewSplitter.png,DestName=FlowViewSplitter.png,Attributes=512,FileSize=159,PerTick=32768,,V erifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=-1289319975,Has hPart2=1740734807,HashPart3=-602332183,HashPart4=525124155,,)
                MSI (s) (A4:F8) [11:14:59:578]: File: C:\Program Files\Safari\Safari.resources\FlowViewSplitter.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:578]: Executing op: FileCopy(SourceName=o41nmgmv.htm|FontPicker.html,SourceCabKey=Safari.resources_FontPicker .html,DestName=FontPicker.html,Attributes=512,FileSize=6897,PerTick=32768,,VerifyMedia=1,, ,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=-603348710,HashPart2=18435476 76,HashPart3=45239802,HashPart4=1132041614,,)
                MSI (s) (A4:F8) [11:14:59:578]: File: C:\Program Files\Safari\Safari.resources\FontPicker.html;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:578]: Executing op: FileCopy(SourceName=me4swa-5.plt|forbes-top-150.pltsuite,SourceCabKey=Safari.resources_fo rbes_top_150.pltsuite,DestName=forbes-top-150.pltsuite,Attributes=512,FileSize=38170,PerTi ck=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=3452 44228,HashPart2=-109225667,HashPart3=854665668,HashPart4=-593099272,,)
                MSI (s) (A4:F8) [11:14:59:578]: File: C:\Program Files\Safari\Safari.resources\forbes-top-150.pltsuite;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:578]: Executing op: SetTargetFolder(Folder=C:\Program Files\Safari\Safari.resources\fr.lproj\)
                MSI (s) (A4:F8) [11:14:59:578]: Executing op: SetSourceFolder(Folder=1\Safari\mymwmyms\yf4pje2d\|Safari\Safari.resources\fr.lproj\)
                MSI (s) (A4:F8) [11:14:59:578]: Executing op: FileCopy(SourceName=ew9hm7cl.pli|ABAutoCompleteMappings.plist,SourceCabKey=Safari.resourc es_fr.lproj_ABAutoCompleteMappings.plist,DestName=ABAutoCompleteMappings.plist,Attributes= 512,FileSize=14651,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,Hash Options=0,HashPart1=1469301106,HashPart2=1577715324,HashPart3=-608457921,HashPart4=1203035 905,,)
                MSI (s) (A4:F8) [11:14:59:578]: File: C:\Program Files\Safari\Safari.resources\fr.lproj\ABAutoCompleteMappings.plist;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:578]: Executing op: FileCopy(SourceName=bindict,SourceCabKey=Safari.resources_fr.lproj_bindict,DestName=bindi ct,Attributes=512,FileSize=1128,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode= 59113472,HashOptions=0,HashPart1=2092053704,HashPart2=-1239573769,HashPart3=-713397766,Has hPart4=-1554745171,,)
                MSI (s) (A4:F8) [11:14:59:578]: File: C:\Program Files\Safari\Safari.resources\fr.lproj\bindict;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:578]: Executing op: FileCopy(SourceName=nds_yme9.pli|BuiltInBookmarks.plist,SourceCabKey=Safari.resources_fr. lproj_BuiltInBookmarks.plist,DestName=BuiltInBookmarks.plist,Attributes=512,FileSize=9346, PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1 =-401432142,HashPart2=-1288270925,HashPart3=517646504,HashPart4=-669224869,,)
                MSI (s) (A4:F8) [11:14:59:594]: File: C:\Program Files\Safari\Safari.resources\fr.lproj\BuiltInBookmarks.plist;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:594]: Executing op: FileCopy(SourceName=jd4s31nn.dat|Dictionary.dat,SourceCabKey=Safari.resources_fr.lproj_Di ctionary.dat,DestName=Dictionary.dat,Attributes=512,FileSize=957952,PerTick=32768,,VerifyM edia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=-986040814,HashPart2= -13600976,HashPart3=1941590051,HashPart4=1389274444,,)
                MSI (s) (A4:F8) [11:14:59:594]: File: C:\Program Files\Safari\Safari.resources\fr.lproj\Dictionary.dat;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:594]: Executing op: FileCopy(SourceName=5gbonjr8.str|Localizable.strings,SourceCabKey=Safari.resources_fr.lpr oj_Localizable.strings,DestName=Localizable.strings,Attributes=512,FileSize=357558,PerTick =32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=-40508 5773,HashPart2=527827597,HashPart3=1135210535,HashPart4=-101941821,,)
                MSI (s) (A4:F8) [11:14:59:594]: File: C:\Program Files\Safari\Safari.resources\fr.lproj\Localizable.strings;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:594]: Executing op: FileCopy(SourceName=v36jfo4n.js|localizedStrings.js,SourceCabKey=Safari.resources_fr.lpro j_localizedStrings.js,DestName=localizedStrings.js,Attributes=512,FileSize=58464,PerTick=3 2768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=11657323 54,HashPart2=-2036183912,HashPart3=2052142408,HashPart4=510479606,,)
                MSI (s) (A4:F8) [11:14:59:594]: File: C:\Program Files\Safari\Safari.resources\fr.lproj\localizedStrings.js;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:594]: Executing op: SetTargetFolder(Folder=C:\Program Files\Safari\Safari.resources\)
                MSI (s) (A4:F8) [11:14:59:594]: Executing op: SetSourceFolder(Folder=1\Safari\mymwmyms\|Safari\Safari.resources\)
                MSI (s) (A4:F8) [11:14:59:594]: Executing op: FileCopy(SourceName=lc71wyzt.htm|FTPDirectoryTemplate.html,SourceCabKey=Safari.resources_ FTPDirectoryTemplate.html,DestName=FTPDirectoryTemplate.html,Attributes=512,FileSize=6661, PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1 =1882745716,HashPart2=-810794963,HashPart3=1977319692,HashPart4=887171858,,)
                MSI (s) (A4:F8) [11:14:59:594]: File: C:\Program Files\Safari\Safari.resources\FTPDirectoryTemplate.html;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:594]: Executing op: FileCopy(SourceName=brysozdi.htm|GeneralPreferences.html,SourceCabKey=Safari.resources_Ge neralPreferences.html,DestName=GeneralPreferences.html,Attributes=512,FileSize=6260,PerTic k=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=93419 5739,HashPart2=-317331779,HashPart3=420004728,HashPart4=120798481,,)
                MSI (s) (A4:F8) [11:14:59:594]: File: C:\Program Files\Safari\Safari.resources\GeneralPreferences.html;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:594]: Executing op: FileCopy(SourceName=oa8s92oy.png|GenericFolderIcon.png,SourceCabKey=Safari.resources_Gene ricFolderIcon.png,DestName=GenericFolderIcon.png,Attributes=512,FileSize=1345,PerTick=3276 8,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=-143844699, HashPart2=8381104,HashPart3=-1535682565,HashPart4=-350718098,,)
                MSI (s) (A4:F8) [11:14:59:594]: File: C:\Program Files\Safari\Safari.resources\GenericFolderIcon.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:594]: Executing op: FileCopy(SourceName=1fskp1kp.png|glossyHeader.png,SourceCabKey=Safari.resources_glossyHea der.png,DestName=glossyHeader.png,Attributes=512,FileSize=3720,PerTick=32768,,VerifyMedia= 1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=527128383,HashPart2=-11464 83202,HashPart3=-38254840,HashPart4=867059561,,)
                MSI (s) (A4:F8) [11:14:59:610]: File: C:\Program Files\Safari\Safari.resources\glossyHeader.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:610]: Executing op: FileCopy(SourceName=ugnu8rln.png|glossyHeaderPressed.png,SourceCabKey=Safari.resources_gl ossyHeaderPressed.png,DestName=glossyHeaderPressed.png,Attributes=512,FileSize=3721,PerTic k=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=13981 52045,HashPart2=2145651321,HashPart3=1173791008,HashPart4=-1919440313,,)
                MSI (s) (A4:F8) [11:14:59:610]: File: C:\Program Files\Safari\Safari.resources\glossyHeaderPressed.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:610]: Executing op: FileCopy(SourceName=ip_fsvsg.png|glossyHeaderSelected.png,SourceCabKey=Safari.resources_g lossyHeaderSelected.png,DestName=glossyHeaderSelected.png,Attributes=512,FileSize=3738,Per Tick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=-2 51439372,HashPart2=1200862614,HashPart3=95925818,HashPart4=223801921,,)
                MSI (s) (A4:F8) [11:14:59:610]: File: C:\Program Files\Safari\Safari.resources\glossyHeaderSelected.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:610]: Executing op: FileCopy(SourceName=ua-qhrrk.png|glossyHeaderSelectedPressed.png,SourceCabKey=Safari.reso urces_glossyHeaderSelectedPressed.png,DestName=glossyHeaderSelectedPressed.png,Attributes= 512,FileSize=3739,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashO ptions=0,HashPart1=-1475493765,HashPart2=1544787220,HashPart3=-1401178607,HashPart4=-11274 93255,,)
                MSI (s) (A4:F8) [11:14:59:610]: File: C:\Program Files\Safari\Safari.resources\glossyHeaderSelectedPressed.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:610]: Executing op: SetTargetFolder(Folder=C:\Program Files\Safari\Safari.resources\Help\)
                MSI (s) (A4:F8) [11:14:59:610]: Executing op: SetSourceFolder(Folder=1\Safari\mymwmyms\Help\|Safari\Safari.resources\Help\)
                MSI (s) (A4:F8) [11:14:59:610]: Executing op: FileCopy(SourceName=hiokmkcm.htm|Acknowledgments.html,SourceCabKey=Safari.resources_Help_ Acknowledgments.html,DestName=Acknowledgments.html,Attributes=512,FileSize=103472,PerTick= 32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=1775195 428,HashPart2=1217792580,HashPart3=1811198446,HashPart4=-1246337997,,)
                MSI (s) (A4:F8) [11:14:59:610]: File: C:\Program Files\Safari\Safari.resources\Help\Acknowledgments.html;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:610]: Executing op: SetTargetFolder(Folder=C:\Program Files\Safari\Safari.resources\Help\da.lproj\)
                MSI (s) (A4:F8) [11:14:59:610]: Executing op: SetSourceFolder(Folder=1\Safari\mymwmyms\Help\jfgmhbjo\|Safari\Safari.resources\Help\da.l proj\)
                MSI (s) (A4:F8) [11:14:59:610]: Executing op: FileCopy(SourceName=m8doatbx.htm|Plug-ins.html,SourceCabKey=Safari.resources_Help_da.lpro j_Plug_ins.html,DestName=Plug-ins.html,Attributes=512,FileSize=4075,PerTick=32768,,VerifyM edia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=-584973128,HashPart2= 658985129,HashPart3=156631677,HashPart4=809552649,,)
                MSI (s) (A4:F8) [11:14:59:610]: File: C:\Program Files\Safari\Safari.resources\Help\da.lproj\Plug-ins.html;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:610]: Executing op: FileCopy(SourceName=Safari.chm,SourceCabKey=Safari.resources_Help_da.lproj_Safari.chm,Des tName=Safari.chm,Attributes=512,FileSize=166426,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC= 0,,,InstallMode=59113472,HashOptions=0,HashPart1=765044719,HashPart2=1732314291,HashPart3= -1005975317,HashPart4=-1824351685,,)
                MSI (s) (A4:F8) [11:14:59:610]: File: C:\Program Files\Safari\Safari.resources\Help\da.lproj\Safari.chm;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:610]: Executing op: SetTargetFolder(Folder=C:\Program Files\Safari\Safari.resources\Help\de.lproj\)
                MSI (s) (A4:F8) [11:14:59:610]: Executing op: SetSourceFolder(Folder=1\Safari\mymwmyms\Help\2s4ue9oh\|Safari\Safari.resources\Help\de.l proj\)
                MSI (s) (A4:F8) [11:14:59:610]: Executing op: FileCopy(SourceName=tpcz7eyy.htm|Plug-ins.html,SourceCabKey=Safari.resources_Help_de.lpro j_Plug_ins.html,DestName=Plug-ins.html,Attributes=512,FileSize=4074,PerTick=32768,,VerifyM edia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=390788859,HashPart2=1 610683125,HashPart3=75971165,HashPart4=114107202,,)
                MSI (s) (A4:F8) [11:14:59:610]: File: C:\Program Files\Safari\Safari.resources\Help\de.lproj\Plug-ins.html;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:610]: Executing op: FileCopy(SourceName=Safari.chm,SourceCabKey=Safari.resources_Help_de.lproj_Safari.chm,Des tName=Safari.chm,Attributes=512,FileSize=182327,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC= 0,,,InstallMode=59113472,HashOptions=0,HashPart1=140353990,HashPart2=-1565562378,HashPart3 =2003049257,HashPart4=23398199,,)
                MSI (s) (A4:F8) [11:14:59:610]: File: C:\Program Files\Safari\Safari.resources\Help\de.lproj\Safari.chm;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:610]: Executing op: SetTargetFolder(Folder=C:\Program Files\Safari\Safari.resources\Help\en.lproj\)
                MSI (s) (A4:F8) [11:14:59:610]: Executing op: SetSourceFolder(Folder=1\Safari\mymwmyms\Help\kz14sb6w\|Safari\Safari.resources\Help\en.l proj\)
                MSI (s) (A4:F8) [11:14:59:610]: Executing op: FileCopy(SourceName=wbcbcn58.htm|Plug-ins.html,SourceCabKey=Safari.resources_Help_en.lpro j_Plug_ins.html,DestName=Plug-ins.html,Attributes=512,FileSize=4075,PerTick=32768,,VerifyM edia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=-584973128,HashPart2= 658985129,HashPart3=156631677,HashPart4=809552649,,)
                MSI (s) (A4:F8) [11:14:59:610]: File: C:\Program Files\Safari\Safari.resources\Help\en.lproj\Plug-ins.html;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:610]: Executing op: FileCopy(SourceName=Safari.chm,SourceCabKey=Safari.resources_Help_en.lproj_Safari.chm,Des tName=Safari.chm,Attributes=512,FileSize=163915,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC= 0,,,InstallMode=59113472,HashOptions=0,HashPart1=1356976291,HashPart2=1780446692,HashPart3 =855057661,HashPart4=-533645952,,)
                MSI (s) (A4:F8) [11:14:59:625]: File: C:\Program Files\Safari\Safari.resources\Help\en.lproj\Safari.chm;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:625]: Executing op: SetTargetFolder(Folder=C:\Program Files\Safari\Safari.resources\Help\es.lproj\)
                MSI (s) (A4:F8) [11:14:59:625]: Executing op: SetSourceFolder(Folder=1\Safari\mymwmyms\Help\xkrt-nt2\|Safari\Safari.resources\Help\es.l proj\)
                MSI (s) (A4:F8) [11:14:59:625]: Executing op: FileCopy(SourceName=fgl6dqqs.htm|Plug-ins.html,SourceCabKey=Safari.resources_Help_es.lpro j_Plug_ins.html,DestName=Plug-ins.html,Attributes=512,FileSize=4081,PerTick=32768,,VerifyM edia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=1378259424,HashPart2= 760754578,HashPart3=745672825,HashPart4=1991193826,,)
                MSI (s) (A4:F8) [11:14:59:625]: File: C:\Program Files\Safari\Safari.resources\Help\es.lproj\Plug-ins.html;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:625]: Executing op: FileCopy(SourceName=Safari.chm,SourceCabKey=Safari.resources_Help_es.lproj_Safari.chm,Des tName=Safari.chm,Attributes=512,FileSize=175828,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC= 0,,,InstallMode=59113472,HashOptions=0,HashPart1=107286329,HashPart2=97475905,HashPart3=20 21038609,HashPart4=2132481283,,)
                MSI (s) (A4:F8) [11:14:59:625]: File: C:\Program Files\Safari\Safari.resources\Help\es.lproj\Safari.chm;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:625]: Executing op: SetTargetFolder(Folder=C:\Program Files\Safari\Safari.resources\Help\fi.lproj\)
                MSI (s) (A4:F8) [11:14:59:625]: Executing op: SetSourceFolder(Folder=1\Safari\mymwmyms\Help\madji035\|Safari\Safari.resources\Help\fi.l proj\)
                MSI (s) (A4:F8) [11:14:59:625]: Executing op: FileCopy(SourceName=l7isjyox.htm|Plug-ins.html,SourceCabKey=Safari.resources_Help_fi.lpro j_Plug_ins.html,DestName=Plug-ins.html,Attributes=512,FileSize=4088,PerTick=32768,,VerifyM edia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=1005506702,HashPart2= 807411544,HashPart3=-270583283,HashPart4=-795717655,,)
                MSI (s) (A4:F8) [11:14:59:625]: File: C:\Program Files\Safari\Safari.resources\Help\fi.lproj\Plug-ins.html;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:625]: Executing op: FileCopy(SourceName=Safari.chm,SourceCabKey=Safari.resources_Help_fi.lproj_Safari.chm,Des tName=Safari.chm,Attributes=512,FileSize=173535,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC= 0,,,InstallMode=59113472,HashOptions=0,HashPart1=538955902,HashPart2=-1345970532,HashPart3 =1555001690,HashPart4=781707410,,)
                MSI (s) (A4:F8) [11:14:59:625]: File: C:\Program Files\Safari\Safari.resources\Help\fi.lproj\Safari.chm;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:625]: Executing op: SetTargetFolder(Folder=C:\Program Files\Safari\Safari.resources\Help\fr.lproj\)
                MSI (s) (A4:F8) [11:14:59:625]: Executing op: SetSourceFolder(Folder=1\Safari\mymwmyms\Help\erlfg1vt\|Safari\Safari.resources\Help\fr.l proj\)
                MSI (s) (A4:F8) [11:14:59:625]: Executing op: FileCopy(SourceName=eedjz6ja.htm|Plug-ins.html,SourceCabKey=Safari.resources_Help_fr.lpro j_Plug_ins.html,DestName=Plug-ins.html,Attributes=512,FileSize=4101,PerTick=32768,,VerifyM edia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=-755923233,HashPart2= -395888404,HashPart3=-475451685,HashPart4=1959075698,,)
                MSI (s) (A4:F8) [11:14:59:625]: File: C:\Program Files\Safari\Safari.resources\Help\fr.lproj\Plug-ins.html;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:625]: Executing op: FileCopy(SourceName=Safari.chm,SourceCabKey=Safari.resources_Help_fr.lproj_Safari.chm,Des tName=Safari.chm,Attributes=512,FileSize=184667,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC= 0,,,InstallMode=59113472,HashOptions=0,HashPart1=-182178615,HashPart2=-1985068467,HashPart 3=1456142086,HashPart4=-1384189296,,)
                MSI (s) (A4:F8) [11:14:59:625]: File: C:\Program Files\Safari\Safari.resources\Help\fr.lproj\Safari.chm;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:625]: Executing op: SetTargetFolder(Folder=C:\Program Files\Safari\Safari.resources\Help\it.lproj\)
                MSI (s) (A4:F8) [11:14:59:625]: Executing op: SetSourceFolder(Folder=1\Safari\mymwmyms\Help\ihb0a5uv\|Safari\Safari.resources\Help\it.l proj\)
                MSI (s) (A4:F8) [11:14:59:625]: Executing op: FileCopy(SourceName=jr-3uei8.htm|Plug-ins.html,SourceCabKey=Safari.resources_Help_it.lpro j_Plug_ins.html,DestName=Plug-ins.html,Attributes=512,FileSize=4077,PerTick=32768,,VerifyM edia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=-962477904,HashPart2= 1700366722,HashPart3=-751849054,HashPart4=-1244637677,,)
                MSI (s) (A4:F8) [11:14:59:625]: File: C:\Program Files\Safari\Safari.resources\Help\it.lproj\Plug-ins.html;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:625]: Executing op: FileCopy(SourceName=Safari.chm,SourceCabKey=Safari.resources_Help_it.lproj_Safari.chm,Des tName=Safari.chm,Attributes=512,FileSize=175914,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC= 0,,,InstallMode=59113472,HashOptions=0,HashPart1=248397884,HashPart2=-2129110536,HashPart3 =1005001798,HashPart4=1589306435,,)
                MSI (s) (A4:F8) [11:14:59:625]: File: C:\Program Files\Safari\Safari.resources\Help\it.lproj\Safari.chm;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:625]: Executing op: SetTargetFolder(Folder=C:\Program Files\Safari\Safari.resources\Help\ja.lproj\)
                MSI (s) (A4:F8) [11:14:59:625]: Executing op: SetSourceFolder(Folder=1\Safari\mymwmyms\Help\tf1oxuk-\|Safari\Safari.resources\Help\ja.l proj\)
                MSI (s) (A4:F8) [11:14:59:625]: Executing op: FileCopy(SourceName=kjdkiksy.htm|Plug-ins.html,SourceCabKey=Safari.resources_Help_ja.lpro j_Plug_ins.html,DestName=Plug-ins.html,Attributes=512,FileSize=4121,PerTick=32768,,VerifyM edia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=-62084817,HashPart2=- 1686419151,HashPart3=1159925481,HashPart4=-1640763220,,)
                MSI (s) (A4:F8) [11:14:59:625]: File: C:\Program Files\Safari\Safari.resources\Help\ja.lproj\Plug-ins.html;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:625]: Executing op: FileCopy(SourceName=Safari.chm,SourceCabKey=Safari.resources_Help_ja.lproj_Safari.chm,Des tName=Safari.chm,Attributes=512,FileSize=206747,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC= 0,,,InstallMode=59113472,HashOptions=0,HashPart1=591200681,HashPart2=-1130664312,HashPart3 =-32166985,HashPart4=604054740,,)
                MSI (s) (A4:F8) [11:14:59:641]: File: C:\Program Files\Safari\Safari.resources\Help\ja.lproj\Safari.chm;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:641]: Executing op: SetTargetFolder(Folder=C:\Program Files\Safari\Safari.resources\Help\ko.lproj\)
                MSI (s) (A4:F8) [11:14:59:641]: Executing op: SetSourceFolder(Folder=1\Safari\mymwmyms\Help\flwoaxes\|Safari\Safari.resources\Help\ko.l proj\)
                MSI (s) (A4:F8) [11:14:59:641]: Executing op: FileCopy(SourceName=duruaw65.htm|Plug-ins.html,SourceCabKey=Safari.resources_Help_ko.lpro j_Plug_ins.html,DestName=Plug-ins.html,Attributes=512,FileSize=4084,PerTick=32768,,VerifyM edia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=716411937,HashPart2=- 1863429593,HashPart3=-1177076651,HashPart4=-1721423677,,)
                MSI (s) (A4:F8) [11:14:59:641]: File: C:\Program Files\Safari\Safari.resources\Help\ko.lproj\Plug-ins.html;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:641]: Executing op: FileCopy(SourceName=Safari.chm,SourceCabKey=Safari.resources_Help_ko.lproj_Safari.chm,Des tName=Safari.chm,Attributes=512,FileSize=180105,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC= 0,,,InstallMode=59113472,HashOptions=0,HashPart1=-1423006799,HashPart2=-1431101305,HashPar t3=881500455,HashPart4=-211563038,,)
                MSI (s) (A4:F8) [11:14:59:641]: File: C:\Program Files\Safari\Safari.resources\Help\ko.lproj\Safari.chm;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:641]: Executing op: SetTargetFolder(Folder=C:\Program Files\Safari\Safari.resources\Help\nb.lproj\)
                MSI (s) (A4:F8) [11:14:59:641]: Executing op: SetSourceFolder(Folder=1\Safari\mymwmyms\Help\mczj6cnq\|Safari\Safari.resources\Help\nb.l proj\)
                MSI (s) (A4:F8) [11:14:59:641]: Executing op: FileCopy(SourceName=tzdjysrb.htm|Plug-ins.html,SourceCabKey=Safari.resources_Help_nb.lpro j_Plug_ins.html,DestName=Plug-ins.html,Attributes=512,FileSize=4088,PerTick=32768,,VerifyM edia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=1306761108,HashPart2= 780117109,HashPart3=-783174886,HashPart4=-835277351,,)
                MSI (s) (A4:F8) [11:14:59:641]: File: C:\Program Files\Safari\Safari.resources\Help\nb.lproj\Plug-ins.html;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:641]: Executing op: FileCopy(SourceName=Safari.chm,SourceCabKey=Safari.resources_Help_nb.lproj_Safari.chm,Des tName=Safari.chm,Attributes=512,FileSize=168516,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC= 0,,,InstallMode=59113472,HashOptions=0,HashPart1=-181509711,HashPart2=-2136823934,HashPart 3=-1614356312,HashPart4=-1403425959,,)
                MSI (s) (A4:F8) [11:14:59:641]: File: C:\Program Files\Safari\Safari.resources\Help\nb.lproj\Safari.chm;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:641]: Executing op: SetTargetFolder(Folder=C:\Program Files\Safari\Safari.resources\Help\nl.lproj\)
                MSI (s) (A4:F8) [11:14:59:641]: Executing op: SetSourceFolder(Folder=1\Safari\mymwmyms\Help\dowb7rvn\|Safari\Safari.resources\Help\nl.l proj\)
                MSI (s) (A4:F8) [11:14:59:641]: Executing op: FileCopy(SourceName=fi8gayf4.htm|Plug-ins.html,SourceCabKey=Safari.resources_Help_nl.lpro j_Plug_ins.html,DestName=Plug-ins.html,Attributes=512,FileSize=4085,PerTick=32768,,VerifyM edia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=-19946960,HashPart2=9 29753131,HashPart3=-1953150333,HashPart4=-1674963750,,)
                MSI (s) (A4:F8) [11:14:59:641]: File: C:\Program Files\Safari\Safari.resources\Help\nl.lproj\Plug-ins.html;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:641]: Executing op: FileCopy(SourceName=Safari.chm,SourceCabKey=Safari.resources_Help_nl.lproj_Safari.chm,Des tName=Safari.chm,Attributes=512,FileSize=170889,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC= 0,,,InstallMode=59113472,HashOptions=0,HashPart1=2115638756,HashPart2=-1618597238,HashPart 3=-1179157910,HashPart4=815640147,,)
                MSI (s) (A4:F8) [11:14:59:641]: File: C:\Program Files\Safari\Safari.resources\Help\nl.lproj\Safari.chm;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:641]: Executing op: SetTargetFolder(Folder=C:\Program Files\Safari\Safari.resources\Help\pl.lproj\)
                MSI (s) (A4:F8) [11:14:59:641]: Executing op: SetSourceFolder(Folder=1\Safari\mymwmyms\Help\aeaxbcpx\|Safari\Safari.resources\Help\pl.l proj\)
                MSI (s) (A4:F8) [11:14:59:641]: Executing op: FileCopy(SourceName=8m1xkyxf.htm|Plug-ins.html,SourceCabKey=Safari.resources_Help_pl.lpro j_Plug_ins.html,DestName=Plug-ins.html,Attributes=512,FileSize=4073,PerTick=32768,,VerifyM edia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=-701521479,HashPart2= 1421206965,HashPart3=1445246035,HashPart4=-23361957,,)
                MSI (s) (A4:F8) [11:14:59:641]: File: C:\Program Files\Safari\Safari.resources\Help\pl.lproj\Plug-ins.html;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:641]: Executing op: FileCopy(SourceName=Safari.chm,SourceCabKey=Safari.resources_Help_pl.lproj_Safari.chm,Des tName=Safari.chm,Attributes=512,FileSize=186644,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC= 0,,,InstallMode=59113472,HashOptions=0,HashPart1=1633459981,HashPart2=1632387677,HashPart3 =-1946640820,HashPart4=-722816399,,)
                MSI (s) (A4:F8) [11:14:59:641]: File: C:\Program Files\Safari\Safari.resources\Help\pl.lproj\Safari.chm;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:641]: Executing op: SetTargetFolder(Folder=C:\Program Files\Safari\Safari.resources\Help\pt.lproj\)
                MSI (s) (A4:F8) [11:14:59:641]: Executing op: SetSourceFolder(Folder=1\Safari\mymwmyms\Help\odds53r5\|Safari\Safari.resources\Help\pt.l proj\)
                MSI (s) (A4:F8) [11:14:59:641]: Executing op: FileCopy(SourceName=e-vnfntb.htm|Plug-ins.html,SourceCabKey=Safari.resources_Help_pt.lpro j_Plug_ins.html,DestName=Plug-ins.html,Attributes=512,FileSize=4078,PerTick=32768,,VerifyM edia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=420230131,HashPart2=- 1024983867,HashPart3=-1053233677,HashPart4=1156687006,,)
                MSI (s) (A4:F8) [11:14:59:656]: File: C:\Program Files\Safari\Safari.resources\Help\pt.lproj\Plug-ins.html;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:656]: Executing op: FileCopy(SourceName=Safari.chm,SourceCabKey=Safari.resources_Help_pt.lproj_Safari.chm,Des tName=Safari.chm,Attributes=512,FileSize=172380,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC= 0,,,InstallMode=59113472,HashOptions=0,HashPart1=1803365993,HashPart2=1809757817,HashPart3 =166934525,HashPart4=-1583899024,,)
                MSI (s) (A4:F8) [11:14:59:656]: File: C:\Program Files\Safari\Safari.resources\Help\pt.lproj\Safari.chm;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:656]: Executing op: SetTargetFolder(Folder=C:\Program Files\Safari\Safari.resources\Help\pt_PT.lproj\)
                MSI (s) (A4:F8) [11:14:59:656]: Executing op: SetSourceFolder(Folder=1\Safari\mymwmyms\Help\x479tr5_\|Safari\Safari.resources\Help\pt_P T.lproj\)
                MSI (s) (A4:F8) [11:14:59:656]: Executing op: FileCopy(SourceName=-xbkgfli.htm|Plug-ins.html,SourceCabKey=Safari.resources_Help_pt_PT.l proj_Plug_ins.html,DestName=Plug-ins.html,Attributes=512,FileSize=4083,PerTick=32768,,Veri fyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=712548313,HashPart 2=1408303417,HashPart3=197670581,HashPart4=-1852143609,,)
                MSI (s) (A4:F8) [11:14:59:656]: File: C:\Program Files\Safari\Safari.resources\Help\pt_PT.lproj\Plug-ins.html;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:656]: Executing op: FileCopy(SourceName=Safari.chm,SourceCabKey=Safari.resources_Help_pt_PT.lproj_Safari.chm, DestName=Safari.chm,Attributes=512,FileSize=175895,PerTick=32768,,VerifyMedia=1,,,,,CheckC RC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=1082871454,HashPart2=-1338403615,HashP art3=-1106266195,HashPart4=-1261976622,,)
                MSI (s) (A4:F8) [11:14:59:656]: File: C:\Program Files\Safari\Safari.resources\Help\pt_PT.lproj\Safari.chm;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:656]: Executing op: SetTargetFolder(Folder=C:\Program Files\Safari\Safari.resources\Help\ru.lproj\)
                MSI (s) (A4:F8) [11:14:59:656]: Executing op: SetSourceFolder(Folder=1\Safari\mymwmyms\Help\dxdsjxhs\|Safari\Safari.resources\Help\ru.l proj\)
                MSI (s) (A4:F8) [11:14:59:656]: Executing op: FileCopy(SourceName=is26uuwu.htm|Plug-ins.html,SourceCabKey=Safari.resources_Help_ru.lpro j_Plug_ins.html,DestName=Plug-ins.html,Attributes=512,FileSize=4144,PerTick=32768,,VerifyM edia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=137259540,HashPart2=- 912010849,HashPart3=-1622713443,HashPart4=-1256721843,,)
                MSI (s) (A4:F8) [11:14:59:656]: File: C:\Program Files\Safari\Safari.resources\Help\ru.lproj\Plug-ins.html;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:656]: Executing op: FileCopy(SourceName=Safari.chm,SourceCabKey=Safari.resources_Help_ru.lproj_Safari.chm,Des tName=Safari.chm,Attributes=512,FileSize=180654,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC= 0,,,InstallMode=59113472,HashOptions=0,HashPart1=1547874919,HashPart2=1705073518,HashPart3 =2097929844,HashPart4=756746394,,)
                MSI (s) (A4:F8) [11:14:59:656]: File: C:\Program Files\Safari\Safari.resources\Help\ru.lproj\Safari.chm;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:656]: Executing op: SetTargetFolder(Folder=C:\Program Files\Safari\Safari.resources\Help\sv.lproj\)
                MSI (s) (A4:F8) [11:14:59:656]: Executing op: SetSourceFolder(Folder=1\Safari\mymwmyms\Help\8d68hyly\|Safari\Safari.resources\Help\sv.l proj\)
                MSI (s) (A4:F8) [11:14:59:656]: Executing op: FileCopy(SourceName=p9aafzyz.htm|Plug-ins.html,SourceCabKey=Safari.resources_Help_sv.lpro j_Plug_ins.html,DestName=Plug-ins.html,Attributes=512,FileSize=4093,PerTick=32768,,VerifyM edia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=-508805977,HashPart2= -930147252,HashPart3=-2052690788,HashPart4=2000667885,,)
                MSI (s) (A4:F8) [11:14:59:656]: File: C:\Program Files\Safari\Safari.resources\Help\sv.lproj\Plug-ins.html;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:656]: Executing op: FileCopy(SourceName=Safari.chm,SourceCabKey=Safari.resources_Help_sv.lproj_Safari.chm,Des tName=Safari.chm,Attributes=512,FileSize=166276,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC= 0,,,InstallMode=59113472,HashOptions=0,HashPart1=-1051002794,HashPart2=-893767875,HashPart 3=-1016392437,HashPart4=208078838,,)
                MSI (s) (A4:F8) [11:14:59:656]: File: C:\Program Files\Safari\Safari.resources\Help\sv.lproj\Safari.chm;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:656]: Executing op: SetTargetFolder(Folder=C:\Program Files\Safari\Safari.resources\Help\zh_CN.lproj\)
                MSI (s) (A4:F8) [11:14:59:656]: Executing op: SetSourceFolder(Folder=1\Safari\mymwmyms\Help\6nmb3fx1\|Safari\Safari.resources\Help\zh_C N.lproj\)
                MSI (s) (A4:F8) [11:14:59:656]: Executing op: FileCopy(SourceName=kk_mak9h.htm|Plug-ins.html,SourceCabKey=Safari.resources_Help_zh_CN.l proj_Plug_ins.html,DestName=Plug-ins.html,Attributes=512,FileSize=4069,PerTick=32768,,Veri fyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=-1890154113,HashPa rt2=681121068,HashPart3=-935626951,HashPart4=1961035424,,)
                MSI (s) (A4:F8) [11:14:59:656]: File: C:\Program Files\Safari\Safari.resources\Help\zh_CN.lproj\Plug-ins.html;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:656]: Executing op: FileCopy(SourceName=Safari.chm,SourceCabKey=Safari.resources_Help_zh_CN.lproj_Safari.chm, DestName=Safari.chm,Attributes=512,FileSize=173544,PerTick=32768,,VerifyMedia=1,,,,,CheckC RC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=-1977940934,HashPart2=-389979061,HashP art3=-1141867810,HashPart4=-1376027784,,)
                MSI (s) (A4:F8) [11:14:59:672]: File: C:\Program Files\Safari\Safari.resources\Help\zh_CN.lproj\Safari.chm;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:672]: Executing op: SetTargetFolder(Folder=C:\Program Files\Safari\Safari.resources\Help\zh_TW.lproj\)
                MSI (s) (A4:F8) [11:14:59:672]: Executing op: SetSourceFolder(Folder=1\Safari\mymwmyms\Help\lzj_ysqv\|Safari\Safari.resources\Help\zh_T W.lproj\)
                MSI (s) (A4:F8) [11:14:59:672]: Executing op: FileCopy(SourceName=gldyax07.htm|Plug-ins.html,SourceCabKey=Safari.resources_Help_zh_TW.l proj_Plug_ins.html,DestName=Plug-ins.html,Attributes=512,FileSize=4084,PerTick=32768,,Veri fyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=-1747321538,HashPa rt2=398097422,HashPart3=266006498,HashPart4=-553196592,,)
                MSI (s) (A4:F8) [11:14:59:672]: File: C:\Program Files\Safari\Safari.resources\Help\zh_TW.lproj\Plug-ins.html;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:672]: Executing op: FileCopy(SourceName=Safari.chm,SourceCabKey=Safari.resources_Help_zh_TW.lproj_Safari.chm, DestName=Safari.chm,Attributes=512,FileSize=172860,PerTick=32768,,VerifyMedia=1,,,,,CheckC RC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=1876349668,HashPart2=1334487782,HashPa rt3=-1063331816,HashPart4=-1658419143,,)
                MSI (s) (A4:F8) [11:14:59:672]: File: C:\Program Files\Safari\Safari.resources\Help\zh_TW.lproj\Safari.chm;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:672]: Executing op: SetTargetFolder(Folder=C:\Program Files\Safari\Safari.resources\)
                MSI (s) (A4:F8) [11:14:59:672]: Executing op: SetSourceFolder(Folder=1\Safari\mymwmyms\|Safari\Safari.resources\)
                MSI (s) (A4:F8) [11:14:59:672]: Executing op: FileCopy(SourceName=40xor43v.png|HelpButton.png,SourceCabKey=Safari.resources_HelpButton. png,DestName=HelpButton.png,Attributes=512,FileSize=889,PerTick=32768,,VerifyMedia=1,,,,,C heckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=-235158967,HashPart2=1496029553,H ashPart3=-19022022,HashPart4=-1197571262,,)
                MSI (s) (A4:F8) [11:14:59:672]: File: C:\Program Files\Safari\Safari.resources\HelpButton.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:672]: Executing op: FileCopy(SourceName=1rc247go.png|HelpButtonPressed.png,SourceCabKey=Safari.resources_Help ButtonPressed.png,DestName=HelpButtonPressed.png,Attributes=512,FileSize=927,PerTick=32768 ,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=-1849905291, HashPart2=316026452,HashPart3=-381345966,HashPart4=2023723809,,)
                MSI (s) (A4:F8) [11:14:59:672]: File: C:\Program Files\Safari\Safari.resources\HelpButtonPressed.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:672]: Executing op: FileCopy(SourceName=h1t-xamt.png|HideReaderButtonCapLeft.png,SourceCabKey=Safari.resource s_HideReaderButtonCapLeft.png,DestName=HideReaderButtonCapLeft.png,Attributes=512,FileSize =255,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,Hash Part1=-543232004,HashPart2=1164995245,HashPart3=-1857316623,HashPart4=-1878237691,,)
                MSI (s) (A4:F8) [11:14:59:672]: File: C:\Program Files\Safari\Safari.resources\HideReaderButtonCapLeft.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:672]: Executing op: FileCopy(SourceName=iyp7nn1j.png|HideReaderButtonCapLeftPressed.png,SourceCabKey=Safari.r esources_HideReaderButtonCapLeftPressed.png,DestName=HideReaderButtonCapLeftPressed.png,At tributes=512,FileSize=240,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=591134 72,HashOptions=0,HashPart1=348664840,HashPart2=-366068283,HashPart3=90944270,HashPart4=-65 734371,,)
                MSI (s) (A4:F8) [11:14:59:672]: File: C:\Program Files\Safari\Safari.resources\HideReaderButtonCapLeftPressed.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:672]: Executing op: FileCopy(SourceName=ab3utmdm.png|HideReaderButtonCapRight.png,SourceCabKey=Safari.resourc es_HideReaderButtonCapRight.png,DestName=HideReaderButtonCapRight.png,Attributes=512,FileS ize=249,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,H ashPart1=-400361549,HashPart2=-2000566815,HashPart3=546571947,HashPart4=732511441,,)
                MSI (s) (A4:F8) [11:14:59:672]: File: C:\Program Files\Safari\Safari.resources\HideReaderButtonCapRight.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:672]: Executing op: FileCopy(SourceName=ncwydkrf.png|HideReaderButtonCapRightPressed.png,SourceCabKey=Safari. resources_HideReaderButtonCapRightPressed.png,DestName=HideReaderButtonCapRightPressed.png ,Attributes=512,FileSize=241,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=591 13472,HashOptions=0,HashPart1=1257347660,HashPart2=-2047168959,HashPart3=940585828,HashPar t4=362116114,,)
                MSI (s) (A4:F8) [11:14:59:672]: File: C:\Program Files\Safari\Safari.resources\HideReaderButtonCapRightPressed.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:672]: Executing op: FileCopy(SourceName=6vgeeoe2.png|HideReaderButtonStretch.png,SourceCabKey=Safari.resource s_HideReaderButtonStretch.png,DestName=HideReaderButtonStretch.png,Attributes=512,FileSize =193,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,Hash Part1=1235474228,HashPart2=1072126843,HashPart3=-952618177,HashPart4=492213899,,)
                MSI (s) (A4:F8) [11:14:59:672]: File: C:\Program Files\Safari\Safari.resources\HideReaderButtonStretch.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:672]: Executing op: FileCopy(SourceName=exaifvje.png|HideReaderButtonStretchPressed.png,SourceCabKey=Safari.r esources_HideReaderButtonStretchPressed.png,DestName=HideReaderButtonStretchPressed.png,At tributes=512,FileSize=185,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=591134 72,HashOptions=0,HashPart1=2024265093,HashPart2=-859370349,HashPart3=1743802437,HashPart4= 1418466774,,)
                MSI (s) (A4:F8) [11:14:59:672]: File: C:\Program Files\Safari\Safari.resources\HideReaderButtonStretchPressed.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:672]: Executing op: FileCopy(SourceName=s0lqsf42.png|HighContrastDarkButtonDiv-Selected.png,SourceCabKey=Safa ri.resources_HighContrastDarkButtonDiv_Selected.png,DestName=HighContrastDarkButtonDiv-Sel ected.png,Attributes=512,FileSize=217,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,Instal lMode=59113472,HashOptions=0,HashPart1=-1829182791,HashPart2=749982642,HashPart3=127378055 9,HashPart4=1762625511,,)
                MSI (s) (A4:F8) [11:14:59:672]: File: C:\Program Files\Safari\Safari.resources\HighContrastDarkButtonDiv-Selected.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:672]: Executing op: FileCopy(SourceName=sqm5liy9.png|HighContrastDarkButtonFill-Pressed.png,SourceCabKey=Safa ri.resources_HighContrastDarkButtonFill_Pressed.png,DestName=HighContrastDarkButtonFill-Pr essed.png,Attributes=512,FileSize=216,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,Instal lMode=59113472,HashOptions=0,HashPart1=-426651720,HashPart2=-1431720039,HashPart3=-1768992 382,HashPart4=-148401688,,)
                MSI (s) (A4:F8) [11:14:59:672]: File: C:\Program Files\Safari\Safari.resources\HighContrastDarkButtonFill-Pressed.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:672]: Executing op: FileCopy(SourceName=mt9nxldh.png|HighContrastDarkButtonFill-Selected.png,SourceCabKey=Saf ari.resources_HighContrastDarkButtonFill_Selected.png,DestName=HighContrastDarkButtonFill- Selected.png,Attributes=512,FileSize=219,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,Ins tallMode=59113472,HashOptions=0,HashPart1=245143073,HashPart2=-1219875751,HashPart3=119209 1380,HashPart4=711880554,,)
                MSI (s) (A4:F8) [11:14:59:672]: File: C:\Program Files\Safari\Safari.resources\HighContrastDarkButtonFill-Selected.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:672]: Executing op: FileCopy(SourceName=aerfyloh.png|HighContrastDarkButtonFill-SelectedPressed.png,SourceCab Key=Safari.resources_HighContrastDarkButtonFill_SelectedPressed.png,DestName=HighContrastD arkButtonFill-SelectedPressed.png,Attributes=512,FileSize=224,PerTick=32768,,VerifyMedia=1 ,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=-1115566434,HashPart2=-1996 067386,HashPart3=2141696977,HashPart4=42325482,,)
                MSI (s) (A4:F8) [11:14:59:688]: File: C:\Program Files\Safari\Safari.resources\HighContrastDarkButtonFill-SelectedPressed.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:688]: Executing op: FileCopy(SourceName=f6k18my4.png|HighContrastDarkButtonFill-Unselected.png,SourceCabKey=S afari.resources_HighContrastDarkButtonFill_Unselected.png,DestName=HighContrastDarkButtonF ill-Unselected.png,Attributes=512,FileSize=218,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0 ,,,InstallMode=59113472,HashOptions=0,HashPart1=-1829866694,HashPart2=883684295,HashPart3= 1755229759,HashPart4=978517172,,)
                MSI (s) (A4:F8) [11:14:59:688]: File: C:\Program Files\Safari\Safari.resources\HighContrastDarkButtonFill-Unselected.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:688]: Executing op: FileCopy(SourceName=6hzs2vob.png|HighContrastDarkButtonLeft-Pressed.png,SourceCabKey=Safa ri.resources_HighContrastDarkButtonLeft_Pressed.png,DestName=HighContrastDarkButtonLeft-Pr essed.png,Attributes=512,FileSize=685,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,Instal lMode=59113472,HashOptions=0,HashPart1=575021373,HashPart2=-917981479,HashPart3=325026837, HashPart4=-1622668310,,)
                MSI (s) (A4:F8) [11:14:59:688]: File: C:\Program Files\Safari\Safari.resources\HighContrastDarkButtonLeft-Pressed.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:688]: Executing op: FileCopy(SourceName=qwkgnku1.png|HighContrastDarkButtonLeft-Selected.png,SourceCabKey=Saf ari.resources_HighContrastDarkButtonLeft_Selected.png,DestName=HighContrastDarkButtonLeft- Selected.png,Attributes=512,FileSize=716,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,Ins tallMode=59113472,HashOptions=0,HashPart1=-995274359,HashPart2=-1106478380,HashPart3=-1628 000458,HashPart4=536920905,,)
                MSI (s) (A4:F8) [11:14:59:688]: File: C:\Program Files\Safari\Safari.resources\HighContrastDarkButtonLeft-Selected.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:688]: Executing op: FileCopy(SourceName=ssjjisnh.png|HighContrastDarkButtonLeft-SelectedPressed.png,SourceCab Key=Safari.resources_HighContrastDarkButtonLeft_SelectedPressed.png,DestName=HighContrastD arkButtonLeft-SelectedPressed.png,Attributes=512,FileSize=751,PerTick=32768,,VerifyMedia=1 ,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=-51362289,HashPart2=1744812 592,HashPart3=-1649184494,HashPart4=1014019623,,)
                MSI (s) (A4:F8) [11:14:59:688]: File: C:\Program Files\Safari\Safari.resources\HighContrastDarkButtonLeft-SelectedPressed.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:688]: Executing op: FileCopy(SourceName=ksr0ns2w.png|HighContrastDarkButtonLeft-Unselected.png,SourceCabKey=S afari.resources_HighContrastDarkButtonLeft_Unselected.png,DestName=HighContrastDarkButtonL eft-Unselected.png,Attributes=512,FileSize=670,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0 ,,,InstallMode=59113472,HashOptions=0,HashPart1=-686161627,HashPart2=-967185867,HashPart3= -1084146226,HashPart4=-139544494,,)
                MSI (s) (A4:F8) [11:14:59:688]: File: C:\Program Files\Safari\Safari.resources\HighContrastDarkButtonLeft-Unselected.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:688]: Executing op: FileCopy(SourceName=q5-zqrko.png|HighContrastDarkButtonRight-Pressed.png,SourceCabKey=Saf ari.resources_HighContrastDarkButtonRight_Pressed.png,DestName=HighContrastDarkButtonRight -Pressed.png,Attributes=512,FileSize=764,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,Ins tallMode=59113472,HashOptions=0,HashPart1=-1863902733,HashPart2=746792708,HashPart3=111421 2378,HashPart4=223901119,,)
                MSI (s) (A4:F8) [11:14:59:688]: File: C:\Program Files\Safari\Safari.resources\HighContrastDarkButtonRight-Pressed.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:688]: Executing op: FileCopy(SourceName=ony20nrl.png|HighContrastDarkButtonRight-Selected.png,SourceCabKey=Sa fari.resources_HighContrastDarkButtonRight_Selected.png,DestName=HighContrastDarkButtonRig ht-Selected.png,Attributes=512,FileSize=803,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,, InstallMode=59113472,HashOptions=0,HashPart1=365272426,HashPart2=1035579032,HashPart3=5081 87134,HashPart4=814419990,,)
                MSI (s) (A4:F8) [11:14:59:688]: File: C:\Program Files\Safari\Safari.resources\HighContrastDarkButtonRight-Selected.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:688]: Executing op: FileCopy(SourceName=qwg3hrag.png|HighContrastDarkButtonRight-SelectedPressed.png,SourceCa bKey=Safari.resources_HighContrastDarkButtonRight_SelectedPressed.png,DestName=HighContras tDarkButtonRight-SelectedPressed.png,Attributes=512,FileSize=826,PerTick=32768,,VerifyMedi a=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=-1706895690,HashPart2=13 16304850,HashPart3=-159664990,HashPart4=-841237774,,)
                MSI (s) (A4:F8) [11:14:59:688]: File: C:\Program Files\Safari\Safari.resources\HighContrastDarkButtonRight-SelectedPressed.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:688]: Executing op: FileCopy(SourceName=4c8pb2r3.png|HighContrastDarkButtonRight-Unselected.png,SourceCabKey= Safari.resources_HighContrastDarkButtonRight_Unselected.png,DestName=HighContrastDarkButto nRight-Unselected.png,Attributes=512,FileSize=734,PerTick=32768,,VerifyMedia=1,,,,,CheckCR C=0,,,InstallMode=59113472,HashOptions=0,HashPart1=1000362011,HashPart2=2032464963,HashPar t3=1046745079,HashPart4=1187650310,,)
                MSI (s) (A4:F8) [11:14:59:688]: File: C:\Program Files\Safari\Safari.resources\HighContrastDarkButtonRight-Unselected.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:688]: Executing op: FileCopy(SourceName=f8z2ejzv.js|HTMLViewController.js,SourceCabKey=Safari.resources_HTMLV iewController.js,DestName=HTMLViewController.js,Attributes=512,FileSize=12289,PerTick=3276 8,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=142574248,H ashPart2=-1602876602,HashPart3=1595409500,HashPart4=-97872287,,)
                MSI (s) (A4:F8) [11:14:59:688]: File: C:\Program Files\Safari\Safari.resources\HTMLViewController.js;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:688]: Executing op: FileCopy(SourceName=vh0uj_dg.plt|http-base.pltsuite,SourceCabKey=Safari.resources_http_ba se.pltsuite,DestName=http-base.pltsuite,Attributes=512,FileSize=2133,PerTick=32768,,Verify Media=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=1896910,HashPart2=64 2556047,HashPart3=-874750861,HashPart4=-627891742,,)
                MSI (s) (A4:F8) [11:14:59:688]: File: C:\Program Files\Safari\Safari.resources\http-base.pltsuite;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:688]: Executing op: FileCopy(SourceName=kbfduimf.plt|http-js-ibench.pltsuite,SourceCabKey=Safari.resources_ht tp_js_ibench.pltsuite,DestName=http-js-ibench.pltsuite,Attributes=512,FileSize=280,PerTick =32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=315091 585,HashPart2=-1088037240,HashPart3=496032690,HashPart4=750139602,,)
                MSI (s) (A4:F8) [11:14:59:688]: File: C:\Program Files\Safari\Safari.resources\http-js-ibench.pltsuite;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:688]: Executing op: FileCopy(SourceName=j2_ptjzp.plt|http-js-performance.pltsuite,SourceCabKey=Safari.resourc es_http_js_performance.pltsuite,DestName=http-js-performance.pltsuite,Attributes=512,FileS ize=169,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,H ashPart1=352486856,HashPart2=1283217021,HashPart3=-264010318,HashPart4=-999068970,,)
                MSI (s) (A4:F8) [11:14:59:688]: File: C:\Program Files\Safari\Safari.resources\http-js-performance.pltsuite;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:688]: Executing op: FileCopy(SourceName=cjls4zud.plt|http-static-urls.pltsuite,SourceCabKey=Safari.resources_ http_static_urls.pltsuite,DestName=http-static-urls.pltsuite,Attributes=512,FileSize=397,P erTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1= -331807754,HashPart2=-1381162620,HashPart3=21685492,HashPart4=310659492,,)
                MSI (s) (A4:F8) [11:14:59:703]: File: C:\Program Files\Safari\Safari.resources\http-static-urls.pltsuite;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:703]: Executing op: FileCopy(SourceName=olv21yi0.plt|http-torture-test.pltsuite,SourceCabKey=Safari.resources _http_torture_test.pltsuite,DestName=http-torture-test.pltsuite,Attributes=512,FileSize=68 2,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPar t1=865389207,HashPart2=868373295,HashPart3=-809365204,HashPart4=-2003048157,,)
                MSI (s) (A4:F8) [11:14:59:703]: File: C:\Program Files\Safari\Safari.resources\http-torture-test.pltsuite;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:703]: Executing op: FileCopy(SourceName=y717gsdc.plt|ibench5-html.pltsuite,SourceCabKey=Safari.resources_iben ch5_html.pltsuite,DestName=ibench5-html.pltsuite,Attributes=512,FileSize=2130,PerTick=3276 8,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=-1989782893 ,HashPart2=1151772248,HashPart3=-528830042,HashPart4=-377368611,,)
                MSI (s) (A4:F8) [11:14:59:703]: File: C:\Program Files\Safari\Safari.resources\ibench5-html.pltsuite;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:703]: Executing op: FileCopy(SourceName=qzcqjyzt.txt|IDNScriptWhiteList.txt,SourceCabKey=Safari.resources_IDN ScriptWhiteList.txt,DestName=IDNScriptWhiteList.txt,Attributes=512,FileSize=241,PerTick=32 768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=120835650 1,HashPart2=498104617,HashPart3=-571362405,HashPart4=-889069307,,)
                MSI (s) (A4:F8) [11:14:59:703]: File: C:\Program Files\Safari\Safari.resources\IDNScriptWhiteList.txt;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:703]: Executing op: FileCopy(SourceName=rolsf6e8.pli|Info.plist,SourceCabKey=Safari.resources_Info.plist,Dest Name=Info.plist,Attributes=512,FileSize=605,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,, InstallMode=59113472,HashOptions=0,HashPart1=-1351726029,HashPart2=1884308175,HashPart3=10 17239850,HashPart4=-915813291,,)
                MSI (s) (A4:F8) [11:14:59:703]: File: C:\Program Files\Safari\Safari.resources\Info.plist;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:703]: Executing op: SetTargetFolder(Folder=C:\Program Files\Safari\Safari.resources\it.lproj\)
                MSI (s) (A4:F8) [11:14:59:703]: Executing op: SetSourceFolder(Folder=1\Safari\mymwmyms\_v0yxsft\|Safari\Safari.resources\it.lproj\)
                MSI (s) (A4:F8) [11:14:59:703]: Executing op: FileCopy(SourceName=9naps-41.pli|ABAutoCompleteMappings.plist,SourceCabKey=Safari.resourc es_it.lproj_ABAutoCompleteMappings.plist,DestName=ABAutoCompleteMappings.plist,Attributes= 512,FileSize=11748,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,Hash Options=0,HashPart1=-323849421,HashPart2=733429695,HashPart3=-997761694,HashPart4=53635178 4,,)
                MSI (s) (A4:F8) [11:14:59:703]: File: C:\Program Files\Safari\Safari.resources\it.lproj\ABAutoCompleteMappings.plist;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:703]: Executing op: FileCopy(SourceName=bindict,SourceCabKey=Safari.resources_it.lproj_bindict,DestName=bindi ct,Attributes=512,FileSize=1292,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode= 59113472,HashOptions=0,HashPart1=1880335178,HashPart2=-1294972774,HashPart3=1600848932,Has hPart4=60859284,,)
                MSI (s) (A4:F8) [11:14:59:703]: File: C:\Program Files\Safari\Safari.resources\it.lproj\bindict;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:703]: Executing op: FileCopy(SourceName=ooteauyr.pli|BuiltInBookmarks.plist,SourceCabKey=Safari.resources_it. lproj_BuiltInBookmarks.plist,DestName=BuiltInBookmarks.plist,Attributes=512,FileSize=8628, PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1 =2086415852,HashPart2=441562661,HashPart3=-1597082942,HashPart4=1398058900,,)
                MSI (s) (A4:F8) [11:14:59:703]: File: C:\Program Files\Safari\Safari.resources\it.lproj\BuiltInBookmarks.plist;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:703]: Executing op: FileCopy(SourceName=xa79dfmz.dat|Dictionary.dat,SourceCabKey=Safari.resources_it.lproj_Di ctionary.dat,DestName=Dictionary.dat,Attributes=512,FileSize=899072,PerTick=32768,,VerifyM edia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=2064318765,HashPart2= -9415900,HashPart3=2085568739,HashPart4=23301575,,)
                MSI (s) (A4:F8) [11:14:59:703]: File: C:\Program Files\Safari\Safari.resources\it.lproj\Dictionary.dat;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:703]: Executing op: FileCopy(SourceName=ahfbjtkq.str|Localizable.strings,SourceCabKey=Safari.resources_it.lpr oj_Localizable.strings,DestName=Localizable.strings,Attributes=512,FileSize=349092,PerTick =32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=102428 0014,HashPart2=-528741964,HashPart3=-1999249683,HashPart4=834063072,,)
                MSI (s) (A4:F8) [11:14:59:719]: File: C:\Program Files\Safari\Safari.resources\it.lproj\Localizable.strings;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:719]: Executing op: FileCopy(SourceName=rrn9eszk.js|localizedStrings.js,SourceCabKey=Safari.resources_it.lpro j_localizedStrings.js,DestName=localizedStrings.js,Attributes=512,FileSize=56794,PerTick=3 2768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=-2694480 52,HashPart2=-876889548,HashPart3=1559743767,HashPart4=819760460,,)
                MSI (s) (A4:F8) [11:14:59:719]: File: C:\Program Files\Safari\Safari.resources\it.lproj\localizedStrings.js;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:719]: Executing op: SetTargetFolder(Folder=C:\Program Files\Safari\Safari.resources\ja.lproj\)
                MSI (s) (A4:F8) [11:14:59:719]: Executing op: SetSourceFolder(Folder=1\Safari\mymwmyms\njqtvtrr\|Safari\Safari.resources\ja.lproj\)
                MSI (s) (A4:F8) [11:14:59:719]: Executing op: FileCopy(SourceName=kp7yxlcf.pli|ABAutoCompleteMappings.plist,SourceCabKey=Safari.resourc es_ja.lproj_ABAutoCompleteMappings.plist,DestName=ABAutoCompleteMappings.plist,Attributes= 512,FileSize=19659,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,Hash Options=0,HashPart1=-527993476,HashPart2=-44170013,HashPart3=509522658,HashPart4=269050756 ,,)
                MSI (s) (A4:F8) [11:14:59:719]: File: C:\Program Files\Safari\Safari.resources\ja.lproj\ABAutoCompleteMappings.plist;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:719]: Executing op: FileCopy(SourceName=diwl_u2x.pli|BuiltInBookmarks.plist,SourceCabKey=Safari.resources_ja. lproj_BuiltInBookmarks.plist,DestName=BuiltInBookmarks.plist,Attributes=512,FileSize=1625, PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1 =-473310018,HashPart2=-1933363728,HashPart3=-50097842,HashPart4=1133060325,,)
                MSI (s) (A4:F8) [11:14:59:719]: File: C:\Program Files\Safari\Safari.resources\ja.lproj\BuiltInBookmarks.plist;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:719]: Executing op: FileCopy(SourceName=1wugrpun.str|Localizable.strings,SourceCabKey=Safari.resources_ja.lpr oj_Localizable.strings,DestName=Localizable.strings,Attributes=512,FileSize=300808,PerTick =32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=-15530 95771,HashPart2=1119795148,HashPart3=-2112708034,HashPart4=-1490114870,,)
                MSI (s) (A4:F8) [11:14:59:719]: File: C:\Program Files\Safari\Safari.resources\ja.lproj\Localizable.strings;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:719]: Executing op: FileCopy(SourceName=ppfc4rwj.js|localizedStrings.js,SourceCabKey=Safari.resources_ja.lpro j_localizedStrings.js,DestName=localizedStrings.js,Attributes=512,FileSize=46812,PerTick=3 2768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=-8159574 8,HashPart2=-363888638,HashPart3=-1622967928,HashPart4=-972964796,,)
                MSI (s) (A4:F8) [11:14:59:719]: File: C:\Program Files\Safari\Safari.resources\ja.lproj\localizedStrings.js;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:719]: Executing op: SetTargetFolder(Folder=C:\Program Files\Safari\Safari.resources\)
                MSI (s) (A4:F8) [11:14:59:719]: Executing op: SetSourceFolder(Folder=1\Safari\mymwmyms\|Safari\Safari.resources\)
                MSI (s) (A4:F8) [11:14:59:719]: Executing op: FileCopy(SourceName=jtozovsu.plt|java.pltsuite,SourceCabKey=Safari.resources_java.pltsuit e,DestName=java.pltsuite,Attributes=512,FileSize=1451,PerTick=32768,,VerifyMedia=1,,,,,Che ckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=444215831,HashPart2=1731592130,Hash Part3=2123707999,HashPart4=1102043845,,)
                MSI (s) (A4:F8) [11:14:59:719]: File: C:\Program Files\Safari\Safari.resources\java.pltsuite;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:719]: Executing op: FileCopy(SourceName=tgzjzhx4.plt|j+euro.pltsuite,SourceCabKey=Safari.resources_jPeuro.plt suite,DestName=j+euro.pltsuite,Attributes=512,FileSize=5334,PerTick=32768,,VerifyMedia=1,, ,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=-936787427,HashPart2=36742946 6,HashPart3=-1852075077,HashPart4=717287918,,)
                MSI (s) (A4:F8) [11:14:59:719]: File: C:\Program Files\Safari\Safari.resources\j+euro.pltsuite;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:719]: Executing op: SetTargetFolder(Folder=C:\Program Files\Safari\Safari.resources\ko.lproj\)
                MSI (s) (A4:F8) [11:14:59:719]: Executing op: SetSourceFolder(Folder=1\Safari\mymwmyms\jqvtxr9c\|Safari\Safari.resources\ko.lproj\)
                MSI (s) (A4:F8) [11:14:59:719]: Executing op: FileCopy(SourceName=nmgukoxg.pli|ABAutoCompleteMappings.plist,SourceCabKey=Safari.resourc es_ko.lproj_ABAutoCompleteMappings.plist,DestName=ABAutoCompleteMappings.plist,Attributes= 512,FileSize=16116,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,Hash Options=0,HashPart1=-1614462442,HashPart2=-1653124018,HashPart3=1351187814,HashPart4=-4961 65922,,)
                MSI (s) (A4:F8) [11:14:59:719]: File: C:\Program Files\Safari\Safari.resources\ko.lproj\ABAutoCompleteMappings.plist;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:719]: Executing op: FileCopy(SourceName=wag-df3r.pli|BuiltInBookmarks.plist,SourceCabKey=Safari.resources_ko. lproj_BuiltInBookmarks.plist,DestName=BuiltInBookmarks.plist,Attributes=512,FileSize=8315, PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1 =-1847247309,HashPart2=-2016539319,HashPart3=-1676328233,HashPart4=1079129177,,)
                MSI (s) (A4:F8) [11:14:59:719]: File: C:\Program Files\Safari\Safari.resources\ko.lproj\BuiltInBookmarks.plist;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:719]: Executing op: FileCopy(SourceName=eylckumz.str|Localizable.strings,SourceCabKey=Safari.resources_ko.lpr oj_Localizable.strings,DestName=Localizable.strings,Attributes=512,FileSize=301654,PerTick =32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=-12059 40040,HashPart2=-1252422352,HashPart3=351602663,HashPart4=-1588574575,,)
                MSI (s) (A4:F8) [11:14:59:734]: File: C:\Program Files\Safari\Safari.resources\ko.lproj\Localizable.strings;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:734]: Executing op: FileCopy(SourceName=vjji0l9b.js|localizedStrings.js,SourceCabKey=Safari.resources_ko.lpro j_localizedStrings.js,DestName=localizedStrings.js,Attributes=512,FileSize=46108,PerTick=3 2768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=-9328693 08,HashPart2=-350716922,HashPart3=-2141319204,HashPart4=-682928356,,)
                MSI (s) (A4:F8) [11:14:59:734]: File: C:\Program Files\Safari\Safari.resources\ko.lproj\localizedStrings.js;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:734]: Executing op: SetTargetFolder(Folder=C:\Program Files\Safari\Safari.resources\)
                MSI (s) (A4:F8) [11:14:59:734]: Executing op: SetSourceFolder(Folder=1\Safari\mymwmyms\|Safari\Safari.resources\)
                MSI (s) (A4:F8) [11:14:59:734]: Executing op: FileCopy(SourceName=ioi_d52g.png|LoadingCornerInactive.png,SourceCabKey=Safari.resources_ LoadingCornerInactive.png,DestName=LoadingCornerInactive.png,Attributes=512,FileSize=316,P erTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1= -2046733215,HashPart2=-1140958756,HashPart3=1467208776,HashPart4=676628596,,)
                MSI (s) (A4:F8) [11:14:59:734]: File: C:\Program Files\Safari\Safari.resources\LoadingCornerInactive.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:734]: Executing op: FileCopy(SourceName=3usdggtk.png|LoadingCornerInactiveWhite.png,SourceCabKey=Safari.resou rces_LoadingCornerInactiveWhite.png,DestName=LoadingCornerInactiveWhite.png,Attributes=512 ,FileSize=291,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptio ns=0,HashPart1=221787480,HashPart2=-57500759,HashPart3=-1251233281,HashPart4=1257312734,,)
                MSI (s) (A4:F8) [11:14:59:734]: File: C:\Program Files\Safari\Safari.resources\LoadingCornerInactiveWhite.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:734]: Executing op: FileCopy(SourceName=qky0dd6i.png|LoadingCornerNormal.png,SourceCabKey=Safari.resources_Lo adingCornerNormal.png,DestName=LoadingCornerNormal.png,Attributes=512,FileSize=307,PerTick =32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=-85860 3792,HashPart2=1934095871,HashPart3=1069902930,HashPart4=970451541,,)
                MSI (s) (A4:F8) [11:14:59:734]: File: C:\Program Files\Safari\Safari.resources\LoadingCornerNormal.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:734]: Executing op: FileCopy(SourceName=s4so9xdq.png|LoadingCornerNormalWhite.png,SourceCabKey=Safari.resourc es_LoadingCornerNormalWhite.png,DestName=LoadingCornerNormalWhite.png,Attributes=512,FileS ize=291,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,H ashPart1=221787480,HashPart2=-57500759,HashPart3=-1251233281,HashPart4=1257312734,,)
                MSI (s) (A4:F8) [11:14:59:734]: File: C:\Program Files\Safari\Safari.resources\LoadingCornerNormalWhite.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:734]: Executing op: FileCopy(SourceName=ad7zsgrf.png|LoadingCornerPressed.png,SourceCabKey=Safari.resources_L oadingCornerPressed.png,DestName=LoadingCornerPressed.png,Attributes=512,FileSize=299,PerT ick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=488 856831,HashPart2=1527413076,HashPart3=-712651853,HashPart4=1488721132,,)
                MSI (s) (A4:F8) [11:14:59:734]: File: C:\Program Files\Safari\Safari.resources\LoadingCornerPressed.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:734]: Executing op: FileCopy(SourceName=yibleqyt.png|LoadingCornerPressedWhite.png,SourceCabKey=Safari.resour ces_LoadingCornerPressedWhite.png,DestName=LoadingCornerPressedWhite.png,Attributes=512,Fi leSize=288,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions= 0,HashPart1=-1066428278,HashPart2=-134261448,HashPart3=1699421630,HashPart4=1509461865,,)
                MSI (s) (A4:F8) [11:14:59:734]: File: C:\Program Files\Safari\Safari.resources\LoadingCornerPressedWhite.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:734]: Executing op: FileCopy(SourceName=trobb4n7.plt|macneilsen.pltsuite,SourceCabKey=Safari.resources_macnei lsen.pltsuite,DestName=macneilsen.pltsuite,Attributes=512,FileSize=430,PerTick=32768,,Veri fyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=1442793975,HashPar t2=1037818812,HashPart3=759739067,HashPart4=-762223694,,)
                MSI (s) (A4:F8) [11:14:59:734]: File: C:\Program Files\Safari\Safari.resources\macneilsen.pltsuite;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:734]: Executing op: FileCopy(SourceName=j9efrqqm.plt|macneilsen200.pltsuite,SourceCabKey=Safari.resources_mac neilsen200.pltsuite,DestName=macneilsen200.pltsuite,Attributes=512,FileSize=4722,PerTick=3 2768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=-1177711 639,HashPart2=1751434556,HashPart3=1715857398,HashPart4=1924814004,,)
                MSI (s) (A4:F8) [11:14:59:734]: File: C:\Program Files\Safari\Safari.resources\macneilsen200.pltsuite;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:734]: Executing op: FileCopy(SourceName=j9gp0-dr.png|MediumSiteIcon~snowleopard.png,SourceCabKey=Safari.resou rces_MediumSiteIcon_snowleopard.png,DestName=MediumSiteIcon~snowleopard.png,Attributes=512 ,FileSize=3245,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOpti ons=0,HashPart1=-964324645,HashPart2=-137080267,HashPart3=1300008916,HashPart4=-1887299073 ,,)
                MSI (s) (A4:F8) [11:14:59:734]: File: C:\Program Files\Safari\Safari.resources\MediumSiteIcon~snowleopard.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:734]: Executing op: FileCopy(SourceName=k6ed6wcj.css|MobileTest.css,SourceCabKey=Safari.resources_MobileTest. css,DestName=MobileTest.css,Attributes=512,FileSize=814,PerTick=32768,,VerifyMedia=1,,,,,C heckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=-881918285,HashPart2=1980257538,H ashPart3=-1350120712,HashPart4=1965419722,,)
                MSI (s) (A4:F8) [11:14:59:734]: File: C:\Program Files\Safari\Safari.resources\MobileTest.css;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:734]: Executing op: FileCopy(SourceName=wibryi8g.js|MobileTest.js,SourceCabKey=Safari.resources_MobileTest.js ,DestName=MobileTest.js,Attributes=512,FileSize=2275,PerTick=32768,,VerifyMedia=1,,,,,Chec kCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=415414838,HashPart2=1342103638,HashP art3=-521688691,HashPart4=901847271,,)
                MSI (s) (A4:F8) [11:14:59:734]: File: C:\Program Files\Safari\Safari.resources\MobileTest.js;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:734]: Executing op: FileCopy(SourceName=ixe0sedw.htm|MobileTestIPad.html,SourceCabKey=Safari.resources_Mobile TestIPad.html,DestName=MobileTestIPad.html,Attributes=512,FileSize=2327,PerTick=32768,,Ver ifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=-1495222613,HashP art2=-1243549209,HashPart3=-2132696863,HashPart4=-500557935,,)
                MSI (s) (A4:F8) [11:14:59:734]: File: C:\Program Files\Safari\Safari.resources\MobileTestIPad.html;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:734]: Executing op: FileCopy(SourceName=knr3_8ap.png|MobileTestIPadBack.png,SourceCabKey=Safari.resources_Mob ileTestIPadBack.png,DestName=MobileTestIPadBack.png,Attributes=512,FileSize=384,PerTick=32 768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=-16066069 01,HashPart2=928554418,HashPart3=809655462,HashPart4=17466963,,)
                MSI (s) (A4:F8) [11:14:59:750]: File: C:\Program Files\Safari\Safari.resources\MobileTestIPadBack.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:750]: Executing op: FileCopy(SourceName=oazke1yq.png|MobileTestIPadForward.png,SourceCabKey=Safari.resources_ MobileTestIPadForward.png,DestName=MobileTestIPadForward.png,Attributes=512,FileSize=397,P erTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1= -503746191,HashPart2=-2001710855,HashPart3=-877402593,HashPart4=-1280956935,,)
                MSI (s) (A4:F8) [11:14:59:750]: File: C:\Program Files\Safari\Safari.resources\MobileTestIPadForward.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:750]: Executing op: FileCopy(SourceName=33er8go-.png|MobileTestIPadRotate.png,SourceCabKey=Safari.resources_M obileTestIPadRotate.png,DestName=MobileTestIPadRotate.png,Attributes=512,FileSize=466,PerT ick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=-90 0348898,HashPart2=336495793,HashPart3=426965301,HashPart4=2092924471,,)
                MSI (s) (A4:F8) [11:14:59:750]: File: C:\Program Files\Safari\Safari.resources\MobileTestIPadRotate.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:750]: Executing op: FileCopy(SourceName=tgokri2b.htm|MobileTestIPhone.html,SourceCabKey=Safari.resources_Mobi leTestIPhone.html,DestName=MobileTestIPhone.html,Attributes=512,FileSize=2052,PerTick=3276 8,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=-658869801, HashPart2=-313060240,HashPart3=601222161,HashPart4=-1102874964,,)
                MSI (s) (A4:F8) [11:14:59:750]: File: C:\Program Files\Safari\Safari.resources\MobileTestIPhone.html;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:750]: Executing op: FileCopy(SourceName=4y-jz4tq.png|MobileTestIPhoneBack.png,SourceCabKey=Safari.resources_M obileTestIPhoneBack.png,DestName=MobileTestIPhoneBack.png,Attributes=512,FileSize=416,PerT ick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=138 6099035,HashPart2=-1846006010,HashPart3=-1461706581,HashPart4=1502555826,,)
                MSI (s) (A4:F8) [11:14:59:750]: File: C:\Program Files\Safari\Safari.resources\MobileTestIPhoneBack.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:750]: Executing op: FileCopy(SourceName=35aioylq.png|MobileTestIPhoneForward.png,SourceCabKey=Safari.resource s_MobileTestIPhoneForward.png,DestName=MobileTestIPhoneForward.png,Attributes=512,FileSize =399,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,Hash Part1=1583523075,HashPart2=1553305433,HashPart3=-589408602,HashPart4=539494227,,)
                MSI (s) (A4:F8) [11:14:59:750]: File: C:\Program Files\Safari\Safari.resources\MobileTestIPhoneForward.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:750]: Executing op: FileCopy(SourceName=n-du-yrg.htm|MobileTestIPhoneRetina.html,SourceCabKey=Safari.resource s_MobileTestIPhoneRetina.html,DestName=MobileTestIPhoneRetina.html,Attributes=512,FileSize =2154,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,Has hPart1=-2129882120,HashPart2=-299931794,HashPart3=-1920961949,HashPart4=-427457872,,)
                MSI (s) (A4:F8) [11:14:59:750]: File: C:\Program Files\Safari\Safari.resources\MobileTestIPhoneRetina.html;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:750]: Executing op: FileCopy(SourceName=o4_edxyw.png|MobileTestIPhoneRetinaBack.png,SourceCabKey=Safari.resou rces_MobileTestIPhoneRetinaBack.png,DestName=MobileTestIPhoneRetinaBack.png,Attributes=512 ,FileSize=700,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptio ns=0,HashPart1=-1342734146,HashPart2=635289580,HashPart3=-1500310078,HashPart4=332446048,, )
                MSI (s) (A4:F8) [11:14:59:750]: File: C:\Program Files\Safari\Safari.resources\MobileTestIPhoneRetinaBack.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:750]: Executing op: FileCopy(SourceName=kovxi7ah.png|MobileTestIPhoneRetinaForward.png,SourceCabKey=Safari.re sources_MobileTestIPhoneRetinaForward.png,DestName=MobileTestIPhoneRetinaForward.png,Attri butes=512,FileSize=675,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472, HashOptions=0,HashPart1=-1775725130,HashPart2=1393183585,HashPart3=670577553,HashPart4=-24 310783,,)
                MSI (s) (A4:F8) [11:14:59:750]: File: C:\Program Files\Safari\Safari.resources\MobileTestIPhoneRetinaForward.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:750]: Executing op: FileCopy(SourceName=kjsorxkt.png|MobileTestIPhoneRetinaRotate.png,SourceCabKey=Safari.res ources_MobileTestIPhoneRetinaRotate.png,DestName=MobileTestIPhoneRetinaRotate.png,Attribut es=512,FileSize=629,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,Has hOptions=0,HashPart1=-136040016,HashPart2=779857723,HashPart3=2091005604,HashPart4=3864124 34,,)
                MSI (s) (A4:F8) [11:14:59:750]: File: C:\Program Files\Safari\Safari.resources\MobileTestIPhoneRetinaRotate.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:750]: Executing op: FileCopy(SourceName=yhi7m3wt.png|MobileTestIPhoneRotate.png,SourceCabKey=Safari.resources _MobileTestIPhoneRotate.png,DestName=MobileTestIPhoneRotate.png,Attributes=512,FileSize=50 2,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPar t1=1420293352,HashPart2=254139651,HashPart3=-2100968158,HashPart4=301533235,,)
                MSI (s) (A4:F8) [11:14:59:750]: File: C:\Program Files\Safari\Safari.resources\MobileTestIPhoneRotate.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:750]: Executing op: SetTargetFolder(Folder=C:\Program Files\Safari\Safari.resources\nb.lproj\)
                MSI (s) (A4:F8) [11:14:59:750]: Executing op: SetSourceFolder(Folder=1\Safari\mymwmyms\lfo-ke9o\|Safari\Safari.resources\nb.lproj\)
                MSI (s) (A4:F8) [11:14:59:750]: Executing op: FileCopy(SourceName=kkir2gc-.pli|ABAutoCompleteMappings.plist,SourceCabKey=Safari.resourc es_nb.lproj_ABAutoCompleteMappings.plist,DestName=ABAutoCompleteMappings.plist,Attributes= 512,FileSize=11732,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,Hash Options=0,HashPart1=-483016939,HashPart2=-768349583,HashPart3=-1881327578,HashPart4=788445 629,,)
                MSI (s) (A4:F8) [11:14:59:750]: File: C:\Program Files\Safari\Safari.resources\nb.lproj\ABAutoCompleteMappings.plist;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:750]: Executing op: FileCopy(SourceName=dnuj7xom.pli|BuiltInBookmarks.plist,SourceCabKey=Safari.resources_nb. lproj_BuiltInBookmarks.plist,DestName=BuiltInBookmarks.plist,Attributes=512,FileSize=1657, PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1 =250856025,HashPart2=-1031963672,HashPart3=-1811486088,HashPart4=-918123417,,)
                MSI (s) (A4:F8) [11:14:59:750]: File: C:\Program Files\Safari\Safari.resources\nb.lproj\BuiltInBookmarks.plist;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:750]: Executing op: FileCopy(SourceName=hfbkkf8x.str|Localizable.strings,SourceCabKey=Safari.resources_nb.lpr oj_Localizable.strings,DestName=Localizable.strings,Attributes=512,FileSize=338948,PerTick =32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=159055 7248,HashPart2=1562394380,HashPart3=-224074214,HashPart4=-977654845,,)
                MSI (s) (A4:F8) [11:14:59:766]: File: C:\Program Files\Safari\Safari.resources\nb.lproj\Localizable.strings;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:766]: Executing op: FileCopy(SourceName=kqqenbm-.js|localizedStrings.js,SourceCabKey=Safari.resources_nb.lpro j_localizedStrings.js,DestName=localizedStrings.js,Attributes=512,FileSize=54564,PerTick=3 2768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=69181513 0,HashPart2=1004932989,HashPart3=-458581595,HashPart4=-720440217,,)
                MSI (s) (A4:F8) [11:14:59:766]: File: C:\Program Files\Safari\Safari.resources\nb.lproj\localizedStrings.js;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:766]: Executing op: SetTargetFolder(Folder=C:\Program Files\Safari\Safari.resources\)
                MSI (s) (A4:F8) [11:14:59:766]: Executing op: SetSourceFolder(Folder=1\Safari\mymwmyms\|Safari\Safari.resources\)
                MSI (s) (A4:F8) [11:14:59:766]: Executing op: FileCopy(SourceName=xd6nggva.plt|nesting.pltsuite,SourceCabKey=Safari.resources_nesting.p ltsuite,DestName=nesting.pltsuite,Attributes=512,FileSize=763,PerTick=32768,,VerifyMedia=1 ,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=596386522,HashPart2=1027890 369,HashPart3=459627239,HashPart4=-24899051,,)
                MSI (s) (A4:F8) [11:14:59:766]: File: C:\Program Files\Safari\Safari.resources\nesting.pltsuite;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:766]: Executing op: FileCopy(SourceName=cfgsmqac.htm|NetworkDiagnosticsErrorPage.html,SourceCabKey=Safari.res ources_NetworkDiagnosticsErrorPage.html,DestName=NetworkDiagnosticsErrorPage.html,Attribut es=512,FileSize=2444,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,Ha shOptions=0,HashPart1=-1280141347,HashPart2=-287707313,HashPart3=-226794933,HashPart4=-468 404304,,)
                MSI (s) (A4:F8) [11:14:59:766]: File: C:\Program Files\Safari\Safari.resources\NetworkDiagnosticsErrorPage.html;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:766]: Executing op: FileCopy(SourceName=kvcforxt.htm|NewBookmark.html,SourceCabKey=Safari.resources_NewBookma rk.html,DestName=NewBookmark.html,Attributes=512,FileSize=2011,PerTick=32768,,VerifyMedia= 1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=-2073873152,HashPart2=1423 902322,HashPart3=-1229433253,HashPart4=-1567635066,,)
                MSI (s) (A4:F8) [11:14:59:766]: File: C:\Program Files\Safari\Safari.resources\NewBookmark.html;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:766]: Executing op: SetTargetFolder(Folder=C:\Program Files\Safari\Safari.resources\nl.lproj\)
                MSI (s) (A4:F8) [11:14:59:766]: Executing op: SetSourceFolder(Folder=1\Safari\mymwmyms\uk1gwlo6\|Safari\Safari.resources\nl.lproj\)
                MSI (s) (A4:F8) [11:14:59:766]: Executing op: FileCopy(SourceName=z8nfjuzx.pli|ABAutoCompleteMappings.plist,SourceCabKey=Safari.resourc es_nl.lproj_ABAutoCompleteMappings.plist,DestName=ABAutoCompleteMappings.plist,Attributes= 512,FileSize=13029,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,Hash Options=0,HashPart1=-2002655571,HashPart2=-839589387,HashPart3=-51217206,HashPart4=-186475 8458,,)
                MSI (s) (A4:F8) [11:14:59:766]: File: C:\Program Files\Safari\Safari.resources\nl.lproj\ABAutoCompleteMappings.plist;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:766]: Executing op: FileCopy(SourceName=bindict,SourceCabKey=Safari.resources_nl.lproj_bindict,DestName=bindi ct,Attributes=512,FileSize=1052,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode= 59113472,HashOptions=0,HashPart1=-1770469188,HashPart2=-1321566491,HashPart3=642985237,Has hPart4=-1163033169,,)
                MSI (s) (A4:F8) [11:14:59:766]: File: C:\Program Files\Safari\Safari.resources\nl.lproj\bindict;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:766]: Executing op: FileCopy(SourceName=xamrssdq.pli|BuiltInBookmarks.plist,SourceCabKey=Safari.resources_nl. lproj_BuiltInBookmarks.plist,DestName=BuiltInBookmarks.plist,Attributes=512,FileSize=1334, PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1 =-928589637,HashPart2=-1136201611,HashPart3=-856991692,HashPart4=-1272377260,,)
                MSI (s) (A4:F8) [11:14:59:766]: File: C:\Program Files\Safari\Safari.resources\nl.lproj\BuiltInBookmarks.plist;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:766]: Executing op: FileCopy(SourceName=qamkmijy.dat|Dictionary.dat,SourceCabKey=Safari.resources_nl.lproj_Di ctionary.dat,DestName=Dictionary.dat,Attributes=512,FileSize=1010176,PerTick=32768,,Verify Media=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=-2123491374,HashPart 2=277864776,HashPart3=-271209150,HashPart4=-2070296920,,)
                MSI (s) (A4:F8) [11:14:59:766]: File: C:\Program Files\Safari\Safari.resources\nl.lproj\Dictionary.dat;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:781]: Executing op: FileCopy(SourceName=5h6op8ve.str|Localizable.strings,SourceCabKey=Safari.resources_nl.lpr oj_Localizable.strings,DestName=Localizable.strings,Attributes=512,FileSize=350020,PerTick =32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=-11828 28373,HashPart2=-974900306,HashPart3=313336058,HashPart4=812792988,,)
                MSI (s) (A4:F8) [11:14:59:781]: File: C:\Program Files\Safari\Safari.resources\nl.lproj\Localizable.strings;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:781]: Executing op: FileCopy(SourceName=i3-klp6g.js|localizedStrings.js,SourceCabKey=Safari.resources_nl.lpro j_localizedStrings.js,DestName=localizedStrings.js,Attributes=512,FileSize=56304,PerTick=3 2768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=-2915152 95,HashPart2=1558604509,HashPart3=-486197498,HashPart4=-1538383887,,)
                MSI (s) (A4:F8) [11:14:59:781]: File: C:\Program Files\Safari\Safari.resources\nl.lproj\localizedStrings.js;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:781]: Executing op: SetTargetFolder(Folder=C:\Program Files\Safari\Safari.resources\)
                MSI (s) (A4:F8) [11:14:59:781]: Executing op: SetSourceFolder(Folder=1\Safari\mymwmyms\|Safari\Safari.resources\)
                MSI (s) (A4:F8) [11:14:59:781]: Executing op: FileCopy(SourceName=ah0ilefz.css|page-load-errors.css,SourceCabKey=Safari.resources_page_ load_errors.css,DestName=page-load-errors.css,Attributes=512,FileSize=2911,PerTick=32768,, VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=169504963,Hash Part2=41112068,HashPart3=-1712315482,HashPart4=1149703989,,)
                MSI (s) (A4:F8) [11:14:59:781]: File: C:\Program Files\Safari\Safari.resources\page-load-errors.css;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:781]: Executing op: FileCopy(SourceName=PageIcon.png,SourceCabKey=Safari.resources_PageIcon.png,DestName=Page Icon.png,Attributes=512,FileSize=1831,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,Instal lMode=59113472,HashOptions=0,HashPart1=-1627700771,HashPart2=-755769414,HashPart3=-1692306 82,HashPart4=1741288446,,)
                MSI (s) (A4:F8) [11:14:59:781]: File: C:\Program Files\Safari\Safari.resources\PageIcon.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:781]: Executing op: FileCopy(SourceName=agog_k-v.htm|PhishingAlert.html,SourceCabKey=Safari.resources_Phishin gAlert.html,DestName=PhishingAlert.html,Attributes=512,FileSize=9923,PerTick=32768,,Verify Media=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=1334180947,HashPart2 =-479307343,HashPart3=-2142040444,HashPart4=-1086004537,,)
                MSI (s) (A4:F8) [11:14:59:781]: File: C:\Program Files\Safari\Safari.resources\PhishingAlert.html;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:781]: Executing op: FileCopy(SourceName=jfeqd1qi.png|PhishingAlertBase.png,SourceCabKey=Safari.resources_Phis hingAlertBase.png,DestName=PhishingAlertBase.png,Attributes=512,FileSize=4013,PerTick=3276 8,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=-1323098568 ,HashPart2=331241459,HashPart3=794113272,HashPart4=-1226422616,,)
                MSI (s) (A4:F8) [11:14:59:781]: File: C:\Program Files\Safari\Safari.resources\PhishingAlertBase.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:781]: Executing op: FileCopy(SourceName=rfirs3bo.png|PhishingAlertTitlebar.png,SourceCabKey=Safari.resources_ PhishingAlertTitlebar.png,DestName=PhishingAlertTitlebar.png,Attributes=512,FileSize=1207, PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1 =-649795371,HashPart2=-1356852486,HashPart3=-540978187,HashPart4=-1826961177,,)
                MSI (s) (A4:F8) [11:14:59:781]: File: C:\Program Files\Safari\Safari.resources\PhishingAlertTitlebar.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:781]: Executing op: SetTargetFolder(Folder=C:\Program Files\Safari\Safari.resources\pl.lproj\)
                MSI (s) (A4:F8) [11:14:59:781]: Executing op: SetSourceFolder(Folder=1\Safari\mymwmyms\lzkewmjd\|Safari\Safari.resources\pl.lproj\)
                MSI (s) (A4:F8) [11:14:59:781]: Executing op: FileCopy(SourceName=nfvehw_r.pli|ABAutoCompleteMappings.plist,SourceCabKey=Safari.resourc es_pl.lproj_ABAutoCompleteMappings.plist,DestName=ABAutoCompleteMappings.plist,Attributes= 512,FileSize=13653,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,Hash Options=0,HashPart1=-1816244413,HashPart2=414217794,HashPart3=-564983217,HashPart4=-155418 583,,)
                MSI (s) (A4:F8) [11:14:59:781]: File: C:\Program Files\Safari\Safari.resources\pl.lproj\ABAutoCompleteMappings.plist;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:781]: Executing op: FileCopy(SourceName=xq0rm7q9.pli|BuiltInBookmarks.plist,SourceCabKey=Safari.resources_pl. lproj_BuiltInBookmarks.plist,DestName=BuiltInBookmarks.plist,Attributes=512,FileSize=1510, PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1 =159224061,HashPart2=-958474253,HashPart3=1709860489,HashPart4=531636321,,)
                MSI (s) (A4:F8) [11:14:59:781]: File: C:\Program Files\Safari\Safari.resources\pl.lproj\BuiltInBookmarks.plist;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:781]: Executing op: FileCopy(SourceName=sqkpt0af.str|Localizable.strings,SourceCabKey=Safari.resources_pl.lpr oj_Localizable.strings,DestName=Localizable.strings,Attributes=512,FileSize=347092,PerTick =32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=-13174 35736,HashPart2=1255221607,HashPart3=904151537,HashPart4=637451716,,)
                MSI (s) (A4:F8) [11:14:59:781]: File: C:\Program Files\Safari\Safari.resources\pl.lproj\Localizable.strings;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:781]: Executing op: FileCopy(SourceName=5rs4w6xh.js|localizedStrings.js,SourceCabKey=Safari.resources_pl.lpro j_localizedStrings.js,DestName=localizedStrings.js,Attributes=512,FileSize=55816,PerTick=3 2768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=62317248 4,HashPart2=-2074757150,HashPart3=-288437786,HashPart4=2064721742,,)
                MSI (s) (A4:F8) [11:14:59:797]: File: C:\Program Files\Safari\Safari.resources\pl.lproj\localizedStrings.js;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:797]: Executing op: SetTargetFolder(Folder=C:\Program Files\Safari\Safari.resources\)
                MSI (s) (A4:F8) [11:14:59:797]: Executing op: SetSourceFolder(Folder=1\Safari\mymwmyms\|Safari\Safari.resources\)
                MSI (s) (A4:F8) [11:14:59:797]: Executing op: FileCopy(SourceName=wxpmvqss.plt|plugin-test.pltsuite,SourceCabKey=Safari.resources_plugi n_test.pltsuite,DestName=plugin-test.pltsuite,Attributes=512,FileSize=553,PerTick=32768,,V erifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=-248024286,Hash Part2=1943812420,HashPart3=156050031,HashPart4=1307706472,,)
                MSI (s) (A4:F8) [11:14:59:797]: File: C:\Program Files\Safari\Safari.resources\plugin-test.pltsuite;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:797]: Executing op: FileCopy(SourceName=ynh7rqzs.css|Preferences.win.css,SourceCabKey=Safari.resources_Prefer ences.win.css,DestName=Preferences.win.css,Attributes=512,FileSize=707,PerTick=32768,,Veri fyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=1417247944,HashPar t2=1149972637,HashPart3=1349718616,HashPart4=-2105241968,,)
                MSI (s) (A4:F8) [11:14:59:797]: File: C:\Program Files\Safari\Safari.resources\Preferences.win.css;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:797]: Executing op: FileCopy(SourceName=iiytdczf.css|PreferencesView.css,SourceCabKey=Safari.resources_Prefer encesView.css,DestName=PreferencesView.css,Attributes=512,FileSize=637,PerTick=32768,,Veri fyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=-921135150,HashPar t2=658630037,HashPart3=520967817,HashPart4=-699666100,,)
                MSI (s) (A4:F8) [11:14:59:797]: File: C:\Program Files\Safari\Safari.resources\PreferencesView.css;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:797]: Executing op: FileCopy(SourceName=c5leqftu.css|PrivacyView.css,SourceCabKey=Safari.resources_PrivacyVie w.css,DestName=PrivacyView.css,Attributes=512,FileSize=2091,PerTick=32768,,VerifyMedia=1,, ,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=-679062436,HashPart2=-1865859 535,HashPart3=-1156500489,HashPart4=36906051,,)
                MSI (s) (A4:F8) [11:14:59:797]: File: C:\Program Files\Safari\Safari.resources\PrivacyView.css;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:797]: Executing op: FileCopy(SourceName=3lwwijux.htm|PrivacyView.html,SourceCabKey=Safari.resources_PrivacyVi ew.html,DestName=PrivacyView.html,Attributes=512,FileSize=8599,PerTick=32768,,VerifyMedia= 1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=602541973,HashPart2=-11132 41881,HashPart3=-617439088,HashPart4=1694294439,,)
                MSI (s) (A4:F8) [11:14:59:797]: File: C:\Program Files\Safari\Safari.resources\PrivacyView.html;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:797]: Executing op: FileCopy(SourceName=-dvougpc.png|PrivateBrowsingButtonCapLeft.png,SourceCabKey=Safari.res ources_PrivateBrowsingButtonCapLeft.png,DestName=PrivateBrowsingButtonCapLeft.png,Attribut es=512,FileSize=239,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,Has hOptions=0,HashPart1=920171018,HashPart2=1201948129,HashPart3=591679668,HashPart4=14377986 ,,)
                MSI (s) (A4:F8) [11:14:59:797]: File: C:\Program Files\Safari\Safari.resources\PrivateBrowsingButtonCapLeft.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:797]: Executing op: FileCopy(SourceName=bj40wkij.png|PrivateBrowsingButtonCapLeftPressed.png,SourceCabKey=Saf ari.resources_PrivateBrowsingButtonCapLeftPressed.png,DestName=PrivateBrowsingButtonCapLef tPressed.png,Attributes=512,FileSize=228,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,Ins tallMode=59113472,HashOptions=0,HashPart1=-593990863,HashPart2=-121281867,HashPart3=162720 8005,HashPart4=-293581168,,)
                MSI (s) (A4:F8) [11:14:59:797]: File: C:\Program Files\Safari\Safari.resources\PrivateBrowsingButtonCapLeftPressed.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:797]: Executing op: FileCopy(SourceName=6cucktlp.png|PrivateBrowsingButtonCapRight.png,SourceCabKey=Safari.re sources_PrivateBrowsingButtonCapRight.png,DestName=PrivateBrowsingButtonCapRight.png,Attri butes=512,FileSize=233,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472, HashOptions=0,HashPart1=679091349,HashPart2=-424516229,HashPart3=2136759355,HashPart4=1242 0796,,)
                MSI (s) (A4:F8) [11:14:59:797]: File: C:\Program Files\Safari\Safari.resources\PrivateBrowsingButtonCapRight.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:797]: Executing op: FileCopy(SourceName=-nty63po.png|PrivateBrowsingButtonCapRightPressed.png,SourceCabKey=Sa fari.resources_PrivateBrowsingButtonCapRightPressed.png,DestName=PrivateBrowsingButtonCapR ightPressed.png,Attributes=512,FileSize=229,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,, InstallMode=59113472,HashOptions=0,HashPart1=213704942,HashPart2=-759053357,HashPart3=-123 8769274,HashPart4=-472648611,,)
                MSI (s) (A4:F8) [11:14:59:797]: File: C:\Program Files\Safari\Safari.resources\PrivateBrowsingButtonCapRightPressed.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:797]: Executing op: FileCopy(SourceName=va-oemtu.png|PrivateBrowsingButtonStretch.png,SourceCabKey=Safari.res ources_PrivateBrowsingButtonStretch.png,DestName=PrivateBrowsingButtonStretch.png,Attribut es=512,FileSize=176,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,Has hOptions=0,HashPart1=622252139,HashPart2=-881166661,HashPart3=1416432891,HashPart4=-174152 2548,,)
                MSI (s) (A4:F8) [11:14:59:797]: File: C:\Program Files\Safari\Safari.resources\PrivateBrowsingButtonStretch.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:797]: Executing op: FileCopy(SourceName=ezyuuxhs.png|PrivateBrowsingButtonStretchPressed.png,SourceCabKey=Saf ari.resources_PrivateBrowsingButtonStretchPressed.png,DestName=PrivateBrowsingButtonStretc hPressed.png,Attributes=512,FileSize=175,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,Ins tallMode=59113472,HashOptions=0,HashPart1=-48635583,HashPart2=566559059,HashPart3=-1880392 624,HashPart4=-1422450884,,)
                MSI (s) (A4:F8) [11:14:59:797]: File: C:\Program Files\Safari\Safari.resources\PrivateBrowsingButtonStretchPressed.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:797]: Executing op: SetTargetFolder(Folder=C:\Program Files\Safari\Safari.resources\pt.lproj\)
                MSI (s) (A4:F8) [11:14:59:797]: Executing op: SetSourceFolder(Folder=1\Safari\mymwmyms\av1maexj\|Safari\Safari.resources\pt.lproj\)
                MSI (s) (A4:F8) [11:14:59:797]: Executing op: FileCopy(SourceName=c3nxg84z.pli|ABAutoCompleteMappings.plist,SourceCabKey=Safari.resourc es_pt.lproj_ABAutoCompleteMappings.plist,DestName=ABAutoCompleteMappings.plist,Attributes= 512,FileSize=13463,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,Hash Options=0,HashPart1=-1158113670,HashPart2=1012469952,HashPart3=1600169449,HashPart4=-29172 579,,)
                MSI (s) (A4:F8) [11:14:59:797]: File: C:\Program Files\Safari\Safari.resources\pt.lproj\ABAutoCompleteMappings.plist;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:797]: Executing op: FileCopy(SourceName=bindict,SourceCabKey=Safari.resources_pt.lproj_bindict,DestName=bindi ct,Attributes=512,FileSize=1052,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode= 59113472,HashOptions=0,HashPart1=-1770469188,HashPart2=-1321566491,HashPart3=642985237,Has hPart4=-1163033169,,)
                MSI (s) (A4:F8) [11:14:59:797]: File: C:\Program Files\Safari\Safari.resources\pt.lproj\bindict;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:797]: Executing op: FileCopy(SourceName=px4-t4ex.pli|BuiltInBookmarks.plist,SourceCabKey=Safari.resources_pt. lproj_BuiltInBookmarks.plist,DestName=BuiltInBookmarks.plist,Attributes=512,FileSize=1854, PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1 =434359080,HashPart2=897327867,HashPart3=50650690,HashPart4=-101328783,,)
                MSI (s) (A4:F8) [11:14:59:812]: File: C:\Program Files\Safari\Safari.resources\pt.lproj\BuiltInBookmarks.plist;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:812]: Executing op: FileCopy(SourceName=67yl90pb.dat|Dictionary.dat,SourceCabKey=Safari.resources_pt.lproj_Di ctionary.dat,DestName=Dictionary.dat,Attributes=512,FileSize=858112,PerTick=32768,,VerifyM edia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=614263529,HashPart2=1 900393478,HashPart3=-1331227870,HashPart4=2083981068,,)
                MSI (s) (A4:F8) [11:14:59:812]: File: C:\Program Files\Safari\Safari.resources\pt.lproj\Dictionary.dat;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:812]: Executing op: FileCopy(SourceName=r0kfffi3.str|Localizable.strings,SourceCabKey=Safari.resources_pt.lpr oj_Localizable.strings,DestName=Localizable.strings,Attributes=512,FileSize=348964,PerTick =32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=-19311 61937,HashPart2=1639396701,HashPart3=1786372547,HashPart4=-167321914,,)
                MSI (s) (A4:F8) [11:14:59:812]: File: C:\Program Files\Safari\Safari.resources\pt.lproj\Localizable.strings;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:812]: Executing op: FileCopy(SourceName=jn_sus3u.js|localizedStrings.js,SourceCabKey=Safari.resources_pt.lpro j_localizedStrings.js,DestName=localizedStrings.js,Attributes=512,FileSize=56206,PerTick=3 2768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=79776323 0,HashPart2=260392142,HashPart3=1496382374,HashPart4=-1222760129,,)
                MSI (s) (A4:F8) [11:14:59:812]: File: C:\Program Files\Safari\Safari.resources\pt.lproj\localizedStrings.js;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:812]: Executing op: SetTargetFolder(Folder=C:\Program Files\Safari\Safari.resources\pt_PT.lproj\)
                MSI (s) (A4:F8) [11:14:59:812]: Executing op: SetSourceFolder(Folder=1\Safari\mymwmyms\ete7-cj1\|Safari\Safari.resources\pt_PT.lproj\)
                MSI (s) (A4:F8) [11:14:59:812]: Executing op: FileCopy(SourceName=hnet7eqg.pli|ABAutoCompleteMappings.plist,SourceCabKey=Safari.resourc es_pt_PT.lproj_ABAutoCompleteMappings.plist,DestName=ABAutoCompleteMappings.plist,Attribut es=512,FileSize=13431,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,H ashOptions=0,HashPart1=-1794426248,HashPart2=-1044152028,HashPart3=-538069014,HashPart4=-2 69969519,,)
                MSI (s) (A4:F8) [11:14:59:812]: File: C:\Program Files\Safari\Safari.resources\pt_PT.lproj\ABAutoCompleteMappings.plist;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:812]: Executing op: FileCopy(SourceName=q02rnnob.pli|BuiltInBookmarks.plist,SourceCabKey=Safari.resources_pt_ PT.lproj_BuiltInBookmarks.plist,DestName=BuiltInBookmarks.plist,Attributes=512,FileSize=93 31,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPa rt1=-842437414,HashPart2=-1883362367,HashPart3=-552140370,HashPart4=1681819824,,)
                MSI (s) (A4:F8) [11:14:59:812]: File: C:\Program Files\Safari\Safari.resources\pt_PT.lproj\BuiltInBookmarks.plist;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:812]: Executing op: FileCopy(SourceName=uw7ondwl.str|Localizable.strings,SourceCabKey=Safari.resources_pt_PT. lproj_Localizable.strings,DestName=Localizable.strings,Attributes=512,FileSize=347320,PerT ick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=-10 09244716,HashPart2=-77734380,HashPart3=-1669924894,HashPart4=-2104937918,,)
                MSI (s) (A4:F8) [11:14:59:812]: File: C:\Program Files\Safari\Safari.resources\pt_PT.lproj\Localizable.strings;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:812]: Executing op: FileCopy(SourceName=42q_mmmv.js|localizedStrings.js,SourceCabKey=Safari.resources_pt_PT.l proj_localizedStrings.js,DestName=localizedStrings.js,Attributes=512,FileSize=57176,PerTic k=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=23675 1343,HashPart2=-1492862478,HashPart3=-700572863,HashPart4=707012170,,)
                MSI (s) (A4:F8) [11:14:59:828]: File: C:\Program Files\Safari\Safari.resources\pt_PT.lproj\localizedStrings.js;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:828]: Executing op: SetTargetFolder(Folder=C:\Program Files\Safari\Safari.resources\)
                MSI (s) (A4:F8) [11:14:59:828]: Executing op: SetSourceFolder(Folder=1\Safari\mymwmyms\|Safari\Safari.resources\)
                MSI (s) (A4:F8) [11:14:59:828]: Executing op: FileCopy(SourceName=txtzbxjj.htm|Reader.html,SourceCabKey=Safari.resources_Reader.html,De stName=Reader.html,Attributes=512,FileSize=18057,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC =0,,,InstallMode=59113472,HashOptions=0,HashPart1=904743743,HashPart2=612166921,HashPart3= -570649923,HashPart4=141574417,,)
                MSI (s) (A4:F8) [11:14:59:828]: File: C:\Program Files\Safari\Safari.resources\Reader.html;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:828]: Executing op: FileCopy(SourceName=p8iqogcg.png|ReaderDropShadow.png,SourceCabKey=Safari.resources_Reade rDropShadow.png,DestName=ReaderDropShadow.png,Attributes=512,FileSize=1147,PerTick=32768,, VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=1890877442,Has hPart2=-1420521766,HashPart3=2104766881,HashPart4=2088053726,,)
                MSI (s) (A4:F8) [11:14:59:828]: File: C:\Program Files\Safari\Safari.resources\ReaderDropShadow.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:828]: Executing op: FileCopy(SourceName=nbyhjto4.png|ReaderDropShadow@2x.png,SourceCabKey=Safari.resources_Re aderDropShadow_at_2x.png,DestName=ReaderDropShadow@2x.png,Attributes=512,FileSize=2592,Per Tick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=-2 032815835,HashPart2=487943634,HashPart3=-627119448,HashPart4=-1337099079,,)
                MSI (s) (A4:F8) [11:14:59:828]: File: C:\Program Files\Safari\Safari.resources\ReaderDropShadow@2x.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:828]: Executing op: FileCopy(SourceName=ecdbqr0n.png|ReaderFadeBottom.png,SourceCabKey=Safari.resources_Reade rFadeBottom.png,DestName=ReaderFadeBottom.png,Attributes=512,FileSize=169,PerTick=32768,,V erifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=-511751508,Hash Part2=-866373187,HashPart3=-1151424146,HashPart4=1539795803,,)
                MSI (s) (A4:F8) [11:14:59:828]: File: C:\Program Files\Safari\Safari.resources\ReaderFadeBottom.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:828]: Executing op: FileCopy(SourceName=31ckbqdp.png|ReaderFadeBottom@2x.png,SourceCabKey=Safari.resources_Re aderFadeBottom_at_2x.png,DestName=ReaderFadeBottom@2x.png,Attributes=512,FileSize=185,PerT ick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=498 44330,HashPart2=-1413364693,HashPart3=-496538560,HashPart4=1825608656,,)
                MSI (s) (A4:F8) [11:14:59:828]: File: C:\Program Files\Safari\Safari.resources\ReaderFadeBottom@2x.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:828]: Executing op: FileCopy(SourceName=4-llr5zt.png|ReaderFadeTop.png,SourceCabKey=Safari.resources_ReaderFa deTop.png,DestName=ReaderFadeTop.png,Attributes=512,FileSize=175,PerTick=32768,,VerifyMedi a=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=-854041570,HashPart2=-12 79534849,HashPart3=173257708,HashPart4=743078942,,)
                MSI (s) (A4:F8) [11:14:59:828]: File: C:\Program Files\Safari\Safari.resources\ReaderFadeTop.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:828]: Executing op: FileCopy(SourceName=bvgz3wyb.png|ReaderFadeTop@2x.png,SourceCabKey=Safari.resources_Reade rFadeTop_at_2x.png,DestName=ReaderFadeTop@2x.png,Attributes=512,FileSize=199,PerTick=32768 ,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=-1060465299, HashPart2=-772373353,HashPart3=448623295,HashPart4=1535398756,,)
                MSI (s) (A4:F8) [11:14:59:828]: File: C:\Program Files\Safari\Safari.resources\ReaderFadeTop@2x.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:828]: Executing op: FileCopy(SourceName=fxtbfr2i.png|ReaderGrowBox.png,SourceCabKey=Safari.resources_ReaderGr owBox.png,DestName=ReaderGrowBox.png,Attributes=512,FileSize=1011,PerTick=32768,,VerifyMed ia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=934481107,HashPart2=-47 8095961,HashPart3=-1658115800,HashPart4=1468652995,,)
                MSI (s) (A4:F8) [11:14:59:828]: File: C:\Program Files\Safari\Safari.resources\ReaderGrowBox.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:828]: Executing op: FileCopy(SourceName=axi319gh.png|ReaderHUDCloseActive.png,SourceCabKey=Safari.resources_R eaderHUDCloseActive.png,DestName=ReaderHUDCloseActive.png,Attributes=512,FileSize=691,PerT ick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=-75 323200,HashPart2=816909610,HashPart3=-200591085,HashPart4=879938084,,)
                MSI (s) (A4:F8) [11:14:59:828]: File: C:\Program Files\Safari\Safari.resources\ReaderHUDCloseActive.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:828]: Executing op: FileCopy(SourceName=ir6xr2pb.png|ReaderHUDCloseActive@2x.png,SourceCabKey=Safari.resource s_ReaderHUDCloseActive_at_2x.png,DestName=ReaderHUDCloseActive@2x.png,Attributes=512,FileS ize=1525,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0, HashPart1=-1830088197,HashPart2=786881305,HashPart3=2108261437,HashPart4=1778595570,,)
                MSI (s) (A4:F8) [11:14:59:828]: File: C:\Program Files\Safari\Safari.resources\ReaderHUDCloseActive@2x.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:828]: Executing op: FileCopy(SourceName=fymjwybz.png|ReaderHUDCloseInactive.png,SourceCabKey=Safari.resources _ReaderHUDCloseInactive.png,DestName=ReaderHUDCloseInactive.png,Attributes=512,FileSize=75 1,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPar t1=1552206347,HashPart2=34539393,HashPart3=1062632225,HashPart4=-1896370792,,)
                MSI (s) (A4:F8) [11:14:59:828]: File: C:\Program Files\Safari\Safari.resources\ReaderHUDCloseInactive.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:828]: Executing op: FileCopy(SourceName=heb0swoy.png|ReaderHUDCloseInactive@2x.png,SourceCabKey=Safari.resour ces_ReaderHUDCloseInactive_at_2x.png,DestName=ReaderHUDCloseInactive@2x.png,Attributes=512 ,FileSize=1485,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOpti ons=0,HashPart1=-156260175,HashPart2=-2125889873,HashPart3=633157754,HashPart4=325578889,, )
                MSI (s) (A4:F8) [11:14:59:828]: File: C:\Program Files\Safari\Safari.resources\ReaderHUDCloseInactive@2x.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:828]: Executing op: FileCopy(SourceName=3dpjbnnv.png|ReaderHUDMailContentsActive.png,SourceCabKey=Safari.reso urces_ReaderHUDMailContentsActive.png,DestName=ReaderHUDMailContentsActive.png,Attributes= 512,FileSize=705,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOp tions=0,HashPart1=1254718151,HashPart2=-506074266,HashPart3=180920847,HashPart4=1747097046 ,,)
                MSI (s) (A4:F8) [11:14:59:844]: File: C:\Program Files\Safari\Safari.resources\ReaderHUDMailContentsActive.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:844]: Executing op: FileCopy(SourceName=4oouxvcl.png|ReaderHUDMailContentsActive@2x.png,SourceCabKey=Safari.r esources_ReaderHUDMailContentsActive_at_2x.png,DestName=ReaderHUDMailContentsActive@2x.png ,Attributes=512,FileSize=1444,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59 113472,HashOptions=0,HashPart1=-66559140,HashPart2=1221738973,HashPart3=839533199,HashPart 4=-2023579344,,)
                MSI (s) (A4:F8) [11:14:59:844]: File: C:\Program Files\Safari\Safari.resources\ReaderHUDMailContentsActive@2x.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:844]: Executing op: FileCopy(SourceName=hkb0sn-q.png|ReaderHUDMailContentsInactive.png,SourceCabKey=Safari.re sources_ReaderHUDMailContentsInactive.png,DestName=ReaderHUDMailContentsInactive.png,Attri butes=512,FileSize=756,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472, HashOptions=0,HashPart1=515958816,HashPart2=-2086247154,HashPart3=-1010631899,HashPart4=42 458080,,)
                MSI (s) (A4:F8) [11:14:59:844]: File: C:\Program Files\Safari\Safari.resources\ReaderHUDMailContentsInactive.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:844]: Executing op: FileCopy(SourceName=iodugrhk.png|ReaderHUDMailContentsInactive@2x.png,SourceCabKey=Safari .resources_ReaderHUDMailContentsInactive_at_2x.png,DestName=ReaderHUDMailContentsInactive@ 2x.png,Attributes=512,FileSize=1568,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallM ode=59113472,HashOptions=0,HashPart1=-485892490,HashPart2=1983718447,HashPart3=-1803448627 ,HashPart4=84288085,,)
                MSI (s) (A4:F8) [11:14:59:844]: File: C:\Program Files\Safari\Safari.resources\ReaderHUDMailContentsInactive@2x.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:844]: Executing op: FileCopy(SourceName=xckszuug.png|ReaderHUDPrintActive.png,SourceCabKey=Safari.resources_R eaderHUDPrintActive.png,DestName=ReaderHUDPrintActive.png,Attributes=512,FileSize=420,PerT ick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=181 6432444,HashPart2=1449402211,HashPart3=373457273,HashPart4=673786897,,)
                MSI (s) (A4:F8) [11:14:59:844]: File: C:\Program Files\Safari\Safari.resources\ReaderHUDPrintActive.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:844]: Executing op: FileCopy(SourceName=f4g1rb0x.png|ReaderHUDPrintActive@2x.png,SourceCabKey=Safari.resource s_ReaderHUDPrintActive_at_2x.png,DestName=ReaderHUDPrintActive@2x.png,Attributes=512,FileS ize=642,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,H ashPart1=109834353,HashPart2=-1347791178,HashPart3=249169395,HashPart4=-805040698,,)
                MSI (s) (A4:F8) [11:14:59:844]: File: C:\Program Files\Safari\Safari.resources\ReaderHUDPrintActive@2x.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:844]: Executing op: FileCopy(SourceName=vmu9dn76.png|ReaderHUDPrintInactive.png,SourceCabKey=Safari.resources _ReaderHUDPrintInactive.png,DestName=ReaderHUDPrintInactive.png,Attributes=512,FileSize=41 3,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPar t1=208630962,HashPart2=1683054896,HashPart3=-1749210678,HashPart4=1290870904,,)
                MSI (s) (A4:F8) [11:14:59:844]: File: C:\Program Files\Safari\Safari.resources\ReaderHUDPrintInactive.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:844]: Executing op: FileCopy(SourceName=vonaoazy.png|ReaderHUDPrintInactive@2x.png,SourceCabKey=Safari.resour ces_ReaderHUDPrintInactive_at_2x.png,DestName=ReaderHUDPrintInactive@2x.png,Attributes=512 ,FileSize=644,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptio ns=0,HashPart1=1814587521,HashPart2=1253837343,HashPart3=1086213318,HashPart4=-327557317,, )
                MSI (s) (A4:F8) [11:14:59:844]: File: C:\Program Files\Safari\Safari.resources\ReaderHUDPrintInactive@2x.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:844]: Executing op: FileCopy(SourceName=uw_it2yd.png|ReaderHUDZoomInActive.png,SourceCabKey=Safari.resources_ ReaderHUDZoomInActive.png,DestName=ReaderHUDZoomInActive.png,Attributes=512,FileSize=812,P erTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1= 1888215753,HashPart2=-19698355,HashPart3=-473589267,HashPart4=-351019907,,)
                MSI (s) (A4:F8) [11:14:59:844]: File: C:\Program Files\Safari\Safari.resources\ReaderHUDZoomInActive.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:844]: Executing op: FileCopy(SourceName=3wvukhao.png|ReaderHUDZoomInActive@2x.png,SourceCabKey=Safari.resourc es_ReaderHUDZoomInActive_at_2x.png,DestName=ReaderHUDZoomInActive@2x.png,Attributes=512,Fi leSize=1937,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions =0,HashPart1=-936408231,HashPart2=432619205,HashPart3=-693697957,HashPart4=211924779,,)
                MSI (s) (A4:F8) [11:14:59:844]: File: C:\Program Files\Safari\Safari.resources\ReaderHUDZoomInActive@2x.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:844]: Executing op: FileCopy(SourceName=o-xkbily.png|ReaderHUDZoomInInactive.png,SourceCabKey=Safari.resource s_ReaderHUDZoomInInactive.png,DestName=ReaderHUDZoomInInactive.png,Attributes=512,FileSize =881,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,Hash Part1=-746401182,HashPart2=491057358,HashPart3=-383926424,HashPart4=882165264,,)
                MSI (s) (A4:F8) [11:14:59:844]: File: C:\Program Files\Safari\Safari.resources\ReaderHUDZoomInInactive.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:844]: Executing op: FileCopy(SourceName=rtf6iikd.png|ReaderHUDZoomInInactive@2x.png,SourceCabKey=Safari.resou rces_ReaderHUDZoomInInactive_at_2x.png,DestName=ReaderHUDZoomInInactive@2x.png,Attributes= 512,FileSize=2007,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashO ptions=0,HashPart1=336067619,HashPart2=139627924,HashPart3=-1204189710,HashPart4=133986446 1,,)
                MSI (s) (A4:F8) [11:14:59:844]: File: C:\Program Files\Safari\Safari.resources\ReaderHUDZoomInInactive@2x.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:844]: Executing op: FileCopy(SourceName=igktgaky.png|ReaderHUDZoomOutActive.png,SourceCabKey=Safari.resources _ReaderHUDZoomOutActive.png,DestName=ReaderHUDZoomOutActive.png,Attributes=512,FileSize=79 8,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPar t1=-491452243,HashPart2=197398729,HashPart3=-425893274,HashPart4=-278753065,,)
                MSI (s) (A4:F8) [11:14:59:844]: File: C:\Program Files\Safari\Safari.resources\ReaderHUDZoomOutActive.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:844]: Executing op: FileCopy(SourceName=1hpms6ma.png|ReaderHUDZoomOutActive@2x.png,SourceCabKey=Safari.resour ces_ReaderHUDZoomOutActive_at_2x.png,DestName=ReaderHUDZoomOutActive@2x.png,Attributes=512 ,FileSize=1955,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOpti ons=0,HashPart1=1027109802,HashPart2=199318022,HashPart3=-449161555,HashPart4=-1127873246, ,)
                MSI (s) (A4:F8) [11:14:59:844]: File: C:\Program Files\Safari\Safari.resources\ReaderHUDZoomOutActive@2x.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:859]: Executing op: FileCopy(SourceName=d7wu_7tv.png|ReaderHUDZoomOutInactive.png,SourceCabKey=Safari.resourc es_ReaderHUDZoomOutInactive.png,DestName=ReaderHUDZoomOutInactive.png,Attributes=512,FileS ize=867,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,H ashPart1=1137045702,HashPart2=662757474,HashPart3=-1913796408,HashPart4=-637721524,,)
                MSI (s) (A4:F8) [11:14:59:859]: File: C:\Program Files\Safari\Safari.resources\ReaderHUDZoomOutInactive.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:859]: Executing op: FileCopy(SourceName=vzchest9.png|ReaderHUDZoomOutInactive@2x.png,SourceCabKey=Safari.reso urces_ReaderHUDZoomOutInactive_at_2x.png,DestName=ReaderHUDZoomOutInactive@2x.png,Attribut es=512,FileSize=1980,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,Ha shOptions=0,HashPart1=-557907518,HashPart2=-1375844818,HashPart3=1587154235,HashPart4=1854 110266,,)
                MSI (s) (A4:F8) [11:14:59:859]: File: C:\Program Files\Safari\Safari.resources\ReaderHUDZoomOutInactive@2x.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:859]: Executing op: FileCopy(SourceName=ylybx78q.png|ReaderSpinner.png,SourceCabKey=Safari.resources_ReaderSp inner.png,DestName=ReaderSpinner.png,Attributes=512,FileSize=1291,PerTick=32768,,VerifyMed ia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=-1138472532,HashPart2=1 142736679,HashPart3=1321810463,HashPart4=588681174,,)
                MSI (s) (A4:F8) [11:14:59:859]: File: C:\Program Files\Safari\Safari.resources\ReaderSpinner.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:859]: Executing op: FileCopy(SourceName=o2neks-s.png|ReaderThumb.png,SourceCabKey=Safari.resources_ReaderThum b.png,DestName=ReaderThumb.png,Attributes=512,FileSize=472,PerTick=32768,,VerifyMedia=1,,, ,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=50922993,HashPart2=203453980,H ashPart3=671736901,HashPart4=2073059296,,)
                MSI (s) (A4:F8) [11:14:59:859]: File: C:\Program Files\Safari\Safari.resources\ReaderThumb.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:859]: Executing op: FileCopy(SourceName=_8reqlvm.png|ReaderThumb@2x.png,SourceCabKey=Safari.resources_ReaderT humb_at_2x.png,DestName=ReaderThumb@2x.png,Attributes=512,FileSize=919,PerTick=32768,,Veri fyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=1679402231,HashPar t2=-487018528,HashPart3=-2035466311,HashPart4=28423932,,)
                MSI (s) (A4:F8) [11:14:59:859]: File: C:\Program Files\Safari\Safari.resources\ReaderThumb@2x.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:859]: Executing op: FileCopy(SourceName=gtfupf_g.png|ReaderThumbFaded.png,SourceCabKey=Safari.resources_Reade rThumbFaded.png,DestName=ReaderThumbFaded.png,Attributes=512,FileSize=558,PerTick=32768,,V erifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=-793043587,Hash Part2=-602994924,HashPart3=781323455,HashPart4=341741962,,)
                MSI (s) (A4:F8) [11:14:59:859]: File: C:\Program Files\Safari\Safari.resources\ReaderThumbFaded.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:859]: Executing op: FileCopy(SourceName=nwpauuuw.png|ReaderTrack.png,SourceCabKey=Safari.resources_ReaderTrac k.png,DestName=ReaderTrack.png,Attributes=512,FileSize=849,PerTick=32768,,VerifyMedia=1,,, ,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=-252406670,HashPart2=-24609709 0,HashPart3=25811565,HashPart4=-576919305,,)
                MSI (s) (A4:F8) [11:14:59:859]: File: C:\Program Files\Safari\Safari.resources\ReaderTrack.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:859]: Executing op: FileCopy(SourceName=rv4ynfm0.png|ReaderTrack@2x.png,SourceCabKey=Safari.resources_ReaderT rack_at_2x.png,DestName=ReaderTrack@2x.png,Attributes=512,FileSize=1695,PerTick=32768,,Ver ifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=933815070,HashPar t2=-1320582688,HashPart3=-1740335565,HashPart4=253012861,,)
                MSI (s) (A4:F8) [11:14:59:859]: File: C:\Program Files\Safari\Safari.resources\ReaderTrack@2x.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:859]: Executing op: FileCopy(SourceName=rsowskbx.htm|ReadingList.html,SourceCabKey=Safari.resources_ReadingLi st.html,DestName=ReadingList.html,Attributes=512,FileSize=12463,PerTick=32768,,VerifyMedia =1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=-215033790,HashPart2=-170 5094095,HashPart3=1473558435,HashPart4=-2102929898,,)
                MSI (s) (A4:F8) [11:14:59:859]: File: C:\Program Files\Safari\Safari.resources\ReadingList.html;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:859]: Executing op: FileCopy(SourceName=wgmliyce.js|ReadingList.js,SourceCabKey=Safari.resources_ReadingList. js,DestName=ReadingList.js,Attributes=512,FileSize=30475,PerTick=32768,,VerifyMedia=1,,,,, CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=6415622,HashPart2=-609048914,Has hPart3=117357347,HashPart4=-227005343,,)
                MSI (s) (A4:F8) [11:14:59:859]: File: C:\Program Files\Safari\Safari.resources\ReadingList.js;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:859]: Executing op: FileCopy(SourceName=o_pzvnt5.png|ReadingList-AddButtonGlyph.png,SourceCabKey=Safari.resou rces_ReadingList_AddButtonGlyph.png,DestName=ReadingList-AddButtonGlyph.png,Attributes=512 ,FileSize=2851,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOpti ons=0,HashPart1=-1215029994,HashPart2=-1151039475,HashPart3=1937039427,HashPart4=-12489067 7,,)
                MSI (s) (A4:F8) [11:14:59:859]: File: C:\Program Files\Safari\Safari.resources\ReadingList-AddButtonGlyph.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:859]: Executing op: FileCopy(SourceName=yuxyatri.png|ReadingList-BGLinen.png,SourceCabKey=Safari.resources_Re adingList_BGLinen.png,DestName=ReadingList-BGLinen.png,Attributes=512,FileSize=148109,PerT ick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=-10 48556465,HashPart2=-776056191,HashPart3=-2003133815,HashPart4=2093182436,,)
                MSI (s) (A4:F8) [11:14:59:859]: File: C:\Program Files\Safari\Safari.resources\ReadingList-BGLinen.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:859]: Executing op: FileCopy(SourceName=moy_gysg.png|ReadingList-BGSideShadow.png,SourceCabKey=Safari.resourc es_ReadingList_BGSideShadow.png,DestName=ReadingList-BGSideShadow.png,Attributes=512,FileS ize=2830,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0, HashPart1=-2117419628,HashPart2=-1318847981,HashPart3=2020704236,HashPart4=-1510207031,,)
                MSI (s) (A4:F8) [11:14:59:859]: File: C:\Program Files\Safari\Safari.resources\ReadingList-BGSideShadow.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:859]: Executing op: FileCopy(SourceName=rg6r8cbi.png|ReadingList-CompThumb.png,SourceCabKey=Safari.resources_ ReadingList_CompThumb.png,DestName=ReadingList-CompThumb.png,Attributes=512,FileSize=3283, PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1 =1417675371,HashPart2=-1056790449,HashPart3=396055012,HashPart4=447109882,,)
                MSI (s) (A4:F8) [11:14:59:875]: File: C:\Program Files\Safari\Safari.resources\ReadingList-CompThumb.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:875]: Executing op: FileCopy(SourceName=kqg35_pd.png|ReadingList-CompTrack.png,SourceCabKey=Safari.resources_ ReadingList_CompTrack.png,DestName=ReadingList-CompTrack.png,Attributes=512,FileSize=3827, PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1 =-7394157,HashPart2=124602342,HashPart3=-1283746558,HashPart4=-101283881,,)
                MSI (s) (A4:F8) [11:14:59:875]: File: C:\Program Files\Safari\Safari.resources\ReadingList-CompTrack.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:875]: Executing op: FileCopy(SourceName=stlin0gp.png|ReadingList-DeleteButton.png,SourceCabKey=Safari.resourc es_ReadingList_DeleteButton.png,DestName=ReadingList-DeleteButton.png,Attributes=512,FileS ize=3339,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0, HashPart1=-990973703,HashPart2=1537366028,HashPart3=-1812283659,HashPart4=-513491302,,)
                MSI (s) (A4:F8) [11:14:59:875]: File: C:\Program Files\Safari\Safari.resources\ReadingList-DeleteButton.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:875]: Executing op: FileCopy(SourceName=icdkhaab.png|ReadingList-DeleteButtonPressed.png,SourceCabKey=Safari. resources_ReadingList_DeleteButtonPressed.png,DestName=ReadingList-DeleteButtonPressed.png ,Attributes=512,FileSize=3289,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59 113472,HashOptions=0,HashPart1=-1588018484,HashPart2=-147458798,HashPart3=1268461955,HashP art4=-460334325,,)
                MSI (s) (A4:F8) [11:14:59:875]: File: C:\Program Files\Safari\Safari.resources\ReadingList-DeleteButtonPressed.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:875]: Executing op: FileCopy(SourceName=vaxkku9f.png|ReadingList-DeleteButtonSelection.png,SourceCabKey=Safar i.resources_ReadingList_DeleteButtonSelection.png,DestName=ReadingList-DeleteButtonSelecti on.png,Attributes=512,FileSize=3392,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallM ode=59113472,HashOptions=0,HashPart1=-1497825454,HashPart2=-703071035,HashPart3=-168711783 4,HashPart4=904155361,,)
                MSI (s) (A4:F8) [11:14:59:875]: File: C:\Program Files\Safari\Safari.resources\ReadingList-DeleteButtonSelection.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:875]: Executing op: FileCopy(SourceName=-ztytdie.png|ReadingList-DeleteButtonSelectionPressed.png,SourceCabKe y=Safari.resources_ReadingList_DeleteButtonSelectionPressed.png,DestName=ReadingList-Delet eButtonSelectionPressed.png,Attributes=512,FileSize=3348,PerTick=32768,,VerifyMedia=1,,,,, CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=-1240746545,HashPart2=596942127, HashPart3=-562373393,HashPart4=1801523335,,)
                MSI (s) (A4:F8) [11:14:59:875]: File: C:\Program Files\Safari\Safari.resources\ReadingList-DeleteButtonSelectionPressed.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:875]: Executing op: FileCopy(SourceName=dzg3krxn.png|ReadingList-FavIconMask.png,SourceCabKey=Safari.resource s_ReadingList_FavIconMask.png,DestName=ReadingList-FavIconMask.png,Attributes=512,FileSize =2871,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,Has hPart1=-627574560,HashPart2=-2125997982,HashPart3=-915364560,HashPart4=423512395,,)
                MSI (s) (A4:F8) [11:14:59:875]: File: C:\Program Files\Safari\Safari.resources\ReadingList-FavIconMask.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:875]: Executing op: FileCopy(SourceName=a01mtojh.png|ReadingList-FavIconMask-36.png,SourceCabKey=Safari.resou rces_ReadingList_FavIconMask_36.png,DestName=ReadingList-FavIconMask-36.png,Attributes=512 ,FileSize=2941,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOpti ons=0,HashPart1=178248959,HashPart2=1616489121,HashPart3=-1974606908,HashPart4=438903851,, )
                MSI (s) (A4:F8) [11:14:59:875]: File: C:\Program Files\Safari\Safari.resources\ReadingList-FavIconMask-36.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:875]: Executing op: FileCopy(SourceName=itssjyr-.png|ReadingList-FavIconShadow.png,SourceCabKey=Safari.resour ces_ReadingList_FavIconShadow.png,DestName=ReadingList-FavIconShadow.png,Attributes=512,Fi leSize=2985,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions =0,HashPart1=1595094105,HashPart2=-1269814085,HashPart3=-580893933,HashPart4=-1929303320,, )
                MSI (s) (A4:F8) [11:14:59:875]: File: C:\Program Files\Safari\Safari.resources\ReadingList-FavIconShadow.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:875]: Executing op: FileCopy(SourceName=mgallqaj.png|ReadingList-FavIconShadow-36.png,SourceCabKey=Safari.res ources_ReadingList_FavIconShadow_36.png,DestName=ReadingList-FavIconShadow-36.png,Attribut es=512,FileSize=3087,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,Ha shOptions=0,HashPart1=2117381728,HashPart2=626410957,HashPart3=-1873486478,HashPart4=-2233 73789,,)
                MSI (s) (A4:F8) [11:14:59:875]: File: C:\Program Files\Safari\Safari.resources\ReadingList-FavIconShadow-36.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:875]: Executing op: FileCopy(SourceName=vxmmms74.pdf|ReadingList-Glasses.pdf,SourceCabKey=Safari.resources_Re adingList_Glasses.pdf,DestName=ReadingList-Glasses.pdf,Attributes=512,FileSize=18591,PerTi ck=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=-151 4483370,HashPart2=-1885127419,HashPart3=132715869,HashPart4=1792744876,,)
                MSI (s) (A4:F8) [11:14:59:890]: File: C:\Program Files\Safari\Safari.resources\ReadingList-Glasses.pdf;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:890]: Executing op: FileCopy(SourceName=fljw0qku.png|ReadingList-IconLarge.png,SourceCabKey=Safari.resources_ ReadingList_IconLarge.png,DestName=ReadingList-IconLarge.png,Attributes=512,FileSize=7391, PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1 =1782328738,HashPart2=1507546169,HashPart3=-226708856,HashPart4=-1668719264,,)
                MSI (s) (A4:F8) [11:14:59:890]: File: C:\Program Files\Safari\Safari.resources\ReadingList-IconLarge.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:890]: Executing op: FileCopy(SourceName=v1bka6yh.png|ReadingList-PushButtonActiveBorderImage.png,SourceCabKey =Safari.resources_ReadingList_PushButtonActiveBorderImage.png,DestName=ReadingList-PushBut tonActiveBorderImage.png,Attributes=512,FileSize=3187,PerTick=32768,,VerifyMedia=1,,,,,Che ckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=431546076,HashPart2=-696980217,Hash Part3=818104389,HashPart4=-1165031988,,)
                MSI (s) (A4:F8) [11:14:59:890]: File: C:\Program Files\Safari\Safari.resources\ReadingList-PushButtonActiveBorderImage.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:890]: Executing op: FileCopy(SourceName=jxs0jpk-.png|ReadingList-PushButtonPressedBorderImage.png,SourceCabKe y=Safari.resources_ReadingList_PushButtonPressedBorderImage.png,DestName=ReadingList-PushB uttonPressedBorderImage.png,Attributes=512,FileSize=3306,PerTick=32768,,VerifyMedia=1,,,,, CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=-786548267,HashPart2=1546837878, HashPart3=682660003,HashPart4=-885933292,,)
                MSI (s) (A4:F8) [11:14:59:890]: File: C:\Program Files\Safari\Safari.resources\ReadingList-PushButtonPressedBorderImage.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:890]: Executing op: FileCopy(SourceName=ed4cnkdc.png|ReadingList-RowDividers.png,SourceCabKey=Safari.resource s_ReadingList_RowDividers.png,DestName=ReadingList-RowDividers.png,Attributes=512,FileSize =1316,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,Has hPart1=287819628,HashPart2=-1759599205,HashPart3=-518970811,HashPart4=-825103760,,)
                MSI (s) (A4:F8) [11:14:59:890]: File: C:\Program Files\Safari\Safari.resources\ReadingList-RowDividers.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:890]: Executing op: FileCopy(SourceName=6lu8dw2u.png|ReadingList-SegmentButtonSelectedBorderImage.png,SourceC abKey=Safari.resources_ReadingList_SegmentButtonSelectedBorderImage.png,DestName=ReadingLi st-SegmentButtonSelectedBorderImage.png,Attributes=512,FileSize=3294,PerTick=32768,,Verify Media=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=869396646,HashPart2= -1984886311,HashPart3=866670240,HashPart4=-829778830,,)
                MSI (s) (A4:F8) [11:14:59:890]: File: C:\Program Files\Safari\Safari.resources\ReadingList-SegmentButtonSelectedBorderImage.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:890]: Executing op: FileCopy(SourceName=i9qja-ty.png|ReadingList-SegmentButtonSelectedPressedBorderImage.png, SourceCabKey=Safari.resources_ReadingList_SegmentButtonSelectedPressedBorderImage.png,Dest Name=ReadingList-SegmentButtonSelectedPressedBorderImage.png,Attributes=512,FileSize=3274, PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1 =1654465157,HashPart2=-1434194017,HashPart3=2099981449,HashPart4=613665396,,)
                MSI (s) (A4:F8) [11:14:59:890]: File: C:\Program Files\Safari\Safari.resources\ReadingList-SegmentButtonSelectedPressedBorderImage.png;           Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:890]: Executing op: FileCopy(SourceName=rxdqohwe.png|ReadingList-SegmentButtonSeparator.png,SourceCabKey=Safa ri.resources_ReadingList_SegmentButtonSeparator.png,DestName=ReadingList-SegmentButtonSepa rator.png,Attributes=512,FileSize=2845,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,Insta llMode=59113472,HashOptions=0,HashPart1=-913148604,HashPart2=1644877312,HashPart3=34164572 4,HashPart4=-1257727463,,)
                MSI (s) (A4:F8) [11:14:59:890]: File: C:\Program Files\Safari\Safari.resources\ReadingList-SegmentButtonSeparator.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:890]: Executing op: FileCopy(SourceName=xulg_n4w.png|ReadingList-Selection.png,SourceCabKey=Safari.resources_ ReadingList_Selection.png,DestName=ReadingList-Selection.png,Attributes=512,FileSize=3277, PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1 =-1892822543,HashPart2=990987587,HashPart3=-329113332,HashPart4=514277178,,)
                MSI (s) (A4:F8) [11:14:59:890]: File: C:\Program Files\Safari\Safari.resources\ReadingList-Selection.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:890]: Executing op: FileCopy(SourceName=zn3x99i4.png|ReadingList-ShiftClickAnimatedIcon.png,SourceCabKey=Safa ri.resources_ReadingList_ShiftClickAnimatedIcon.png,DestName=ReadingList-ShiftClickAnimate dIcon.png,Attributes=512,FileSize=14900,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,Inst allMode=59113472,HashOptions=0,HashPart1=-1348597928,HashPart2=1213910617,HashPart3=142565 5436,HashPart4=-715026203,,)
                MSI (s) (A4:F8) [11:14:59:890]: File: C:\Program Files\Safari\Safari.resources\ReadingList-ShiftClickAnimatedIcon.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:890]: Executing op: FileCopy(SourceName=ipqbbj9m.png|ReadingList-TopBar.png,SourceCabKey=Safari.resources_Rea dingList_TopBar.png,DestName=ReadingList-TopBar.png,Attributes=512,FileSize=6391,PerTick=3 2768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=-1625839 297,HashPart2=403050728,HashPart3=1003311604,HashPart4=-251586195,,)
                MSI (s) (A4:F8) [11:14:59:890]: File: C:\Program Files\Safari\Safari.resources\ReadingList-TopBar.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:890]: Executing op: FileCopy(SourceName=fiqhfum7.htm|ResetDialog.html,SourceCabKey=Safari.resources_ResetDial og.html,DestName=ResetDialog.html,Attributes=512,FileSize=3855,PerTick=32768,,VerifyMedia= 1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=-509274754,HashPart2=-1906 202939,HashPart3=2113781697,HashPart4=-1765037525,,)
                MSI (s) (A4:F8) [11:14:59:890]: File: C:\Program Files\Safari\Safari.resources\ResetDialog.html;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:890]: Executing op: FileCopy(SourceName=jcm7g5mq.htm|RSSPreferences.html,SourceCabKey=Safari.resources_RSSPre ferences.html,DestName=RSSPreferences.html,Attributes=512,FileSize=3461,PerTick=32768,,Ver ifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=-583399013,HashPa rt2=-1881766387,HashPart3=1092292720,HashPart4=-1519710656,,)
                MSI (s) (A4:F8) [11:14:59:890]: File: C:\Program Files\Safari\Safari.resources\RSSPreferences.html;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:890]: Executing op: SetTargetFolder(Folder=C:\Program Files\Safari\Safari.resources\ru.lproj\)
                MSI (s) (A4:F8) [11:14:59:906]: Executing op: SetSourceFolder(Folder=1\Safari\mymwmyms\txcf4vh2\|Safari\Safari.resources\ru.lproj\)
                MSI (s) (A4:F8) [11:14:59:906]: Executing op: FileCopy(SourceName=3nln68rm.pli|ABAutoCompleteMappings.plist,SourceCabKey=Safari.resourc es_ru.lproj_ABAutoCompleteMappings.plist,DestName=ABAutoCompleteMappings.plist,Attributes= 512,FileSize=16792,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,Hash Options=0,HashPart1=1393872930,HashPart2=1941981883,HashPart3=2055527061,HashPart4=1854804 637,,)
                MSI (s) (A4:F8) [11:14:59:906]: File: C:\Program Files\Safari\Safari.resources\ru.lproj\ABAutoCompleteMappings.plist;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:906]: Executing op: FileCopy(SourceName=wv0rvsa-.pli|BuiltInBookmarks.plist,SourceCabKey=Safari.resources_ru. lproj_BuiltInBookmarks.plist,DestName=BuiltInBookmarks.plist,Attributes=512,FileSize=1831, PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1 =-1780088473,HashPart2=-746293529,HashPart3=1221579491,HashPart4=-1948815163,,)
                MSI (s) (A4:F8) [11:14:59:906]: File: C:\Program Files\Safari\Safari.resources\ru.lproj\BuiltInBookmarks.plist;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:906]: Executing op: FileCopy(SourceName=go8guy8b.str|Localizable.strings,SourceCabKey=Safari.resources_ru.lpr oj_Localizable.strings,DestName=Localizable.strings,Attributes=512,FileSize=345304,PerTick =32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=523901 965,HashPart2=-2117342917,HashPart3=-1786723104,HashPart4=-1674353756,,)
                MSI (s) (A4:F8) [11:14:59:906]: File: C:\Program Files\Safari\Safari.resources\ru.lproj\Localizable.strings;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:906]: Executing op: FileCopy(SourceName=4rlshvnm.js|localizedStrings.js,SourceCabKey=Safari.resources_ru.lpro j_localizedStrings.js,DestName=localizedStrings.js,Attributes=512,FileSize=56108,PerTick=3 2768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=-2843893 30,HashPart2=-344489274,HashPart3=1677940989,HashPart4=890082342,,)
                MSI (s) (A4:F8) [11:14:59:906]: File: C:\Program Files\Safari\Safari.resources\ru.lproj\localizedStrings.js;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:906]: Executing op: SetTargetFolder(Folder=C:\Program Files\Safari\Safari.resources\)
                MSI (s) (A4:F8) [11:14:59:906]: Executing op: SetSourceFolder(Folder=1\Safari\mymwmyms\|Safari\Safari.resources\)
                MSI (s) (A4:F8) [11:14:59:906]: Executing op: FileCopy(SourceName=Safari.css,SourceCabKey=Safari.resources_Safari.css,DestName=Safari.c ss,Attributes=512,FileSize=486,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=5 9113472,HashOptions=0,HashPart1=-913414246,HashPart2=-2099272126,HashPart3=1265282139,Hash Part4=411836403,,)
                MSI (s) (A4:F8) [11:14:59:906]: File: C:\Program Files\Safari\Safari.resources\Safari.css;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:906]: Executing op: FileCopy(SourceName=mau0elys.png|SafariAlert.png,SourceCabKey=Safari.resources_SafariAler t.png,DestName=SafariAlert.png,Attributes=512,FileSize=5071,PerTick=32768,,VerifyMedia=1,, ,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=-61419318,HashPart2=139213222 9,HashPart3=158949095,HashPart4=1875365144,,)
                MSI (s) (A4:F8) [11:14:59:906]: File: C:\Program Files\Safari\Safari.resources\SafariAlert.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:906]: Executing op: RegisterSharedComponentProvider(,,File=Safari.resources_SafariRegistry.dll,Component={AAD 0E0E4-D907-11DC-ADF1-5D7F55D89593},ComponentVersion=7534.52.7.4,ProductCode={F2AF3E5D-9697 -485C-A5AC-E2B9468C446A},ProductVersion=5.34.52,PatchSize=0,PatchAttributes=0,PatchSequenc e=0,SharedComponent=0,IsFullFile=0)
                MSI (s) (A4:F8) [11:14:59:906]: Executing op: FileCopy(SourceName=oxolo8ky.dll|SafariRegistry.dll,SourceCabKey=Safari.resources_SafariR egistry.dll,DestName=SafariRegistry.dll,Attributes=512,FileSize=13672,PerTick=32768,,Verif yMedia=1,,,,,CheckCRC=0,Version=7534.52.7.4,Language=0,InstallMode=59113472,,,,,,,)
                MSI (s) (A4:F8) [11:14:59:906]: File: C:\Program Files\Safari\Safari.resources\SafariRegistry.dll;          Won't Overwrite;          Won't patch;          Existing file is of an equal version
                MSI (s) (A4:F8) [11:14:59:906]: Executing op: FileCopy(SourceName=ebuqocg9.htm|SafeAutoFillConfirmationPopover.html,SourceCabKey=Safari .resources_SafeAutoFillConfirmationPopover.html,DestName=SafeAutoFillConfirmationPopover.h tml,Attributes=512,FileSize=5786,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode =59113472,HashOptions=0,HashPart1=1456074593,HashPart2=-342567264,HashPart3=1331259321,Has hPart4=-1114271445,,)
                MSI (s) (A4:F8) [11:14:59:906]: File: C:\Program Files\Safari\Safari.resources\SafeAutoFillConfirmationPopover.html;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:906]: Executing op: FileCopy(SourceName=snn5jlwv.png|SafeBrowsingUnavailable.png,SourceCabKey=Safari.resource s_SafeBrowsingUnavailable.png,DestName=SafeBrowsingUnavailable.png,Attributes=512,FileSize =1056,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,Has hPart1=1777345088,HashPart2=787823473,HashPart3=2019404825,HashPart4=-152105969,,)
                MSI (s) (A4:F8) [11:14:59:906]: File: C:\Program Files\Safari\Safari.resources\SafeBrowsingUnavailable.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:906]: Executing op: FileCopy(SourceName=gstwd7gg.png|ScopeSelectCombined.png,SourceCabKey=Safari.resources_Sc opeSelectCombined.png,DestName=ScopeSelectCombined.png,Attributes=512,FileSize=549,PerTick =32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=147431 0902,HashPart2=1794424067,HashPart3=328570225,HashPart4=-1197728128,,)
                MSI (s) (A4:F8) [11:14:59:906]: File: C:\Program Files\Safari\Safari.resources\ScopeSelectCombined.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:906]: Executing op: FileCopy(SourceName=dmrcao1g.png|ScopeSelectCombinedPressed.png,SourceCabKey=Safari.resou rces_ScopeSelectCombinedPressed.png,DestName=ScopeSelectCombinedPressed.png,Attributes=512 ,FileSize=556,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptio ns=0,HashPart1=-792592942,HashPart2=-403951633,HashPart3=2019255091,HashPart4=1393886873,, )
                MSI (s) (A4:F8) [11:14:59:906]: File: C:\Program Files\Safari\Safari.resources\ScopeSelectCombinedPressed.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:906]: Executing op: FileCopy(SourceName=kszlzvmu.htm|SearchField.html,SourceCabKey=Safari.resources_SearchFie ld.html,DestName=SearchField.html,Attributes=512,FileSize=1656,PerTick=32768,,VerifyMedia= 1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=893320636,HashPart2=-30807 5730,HashPart3=336619695,HashPart4=-765196730,,)
                MSI (s) (A4:F8) [11:14:59:922]: File: C:\Program Files\Safari\Safari.resources\SearchField.html;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:922]: Executing op: FileCopy(SourceName=zvvdh133.png|SecurityAlert.png,SourceCabKey=Safari.resources_Security Alert.png,DestName=SecurityAlert.png,Attributes=512,FileSize=6387,PerTick=32768,,VerifyMed ia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=-1482054400,HashPart2=- 1053240944,HashPart3=1077616454,HashPart4=-1479144436,,)
                MSI (s) (A4:F8) [11:14:59:922]: File: C:\Program Files\Safari\Safari.resources\SecurityAlert.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:922]: Executing op: FileCopy(SourceName=a7nnj3i5.htm|SecurityPreferences.html,SourceCabKey=Safari.resources_S ecurityPreferences.html,DestName=SecurityPreferences.html,Attributes=512,FileSize=4362,Per Tick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=-1 892493811,HashPart2=821101325,HashPart3=309055005,HashPart4=-1127248199,,)
                MSI (s) (A4:F8) [11:14:59:922]: File: C:\Program Files\Safari\Safari.resources\SecurityPreferences.html;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:922]: Executing op: FileCopy(SourceName=1bqb-8_h.htm|ServerNotFoundErrorPage.html,SourceCabKey=Safari.resourc es_ServerNotFoundErrorPage.html,DestName=ServerNotFoundErrorPage.html,Attributes=512,FileS ize=1746,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0, HashPart1=782403455,HashPart2=-1736446673,HashPart3=1257369365,HashPart4=-1930561876,,)
                MSI (s) (A4:F8) [11:14:59:922]: File: C:\Program Files\Safari\Safari.resources\ServerNotFoundErrorPage.html;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:922]: Executing op: FileCopy(SourceName=viyn1umx.png|ShowReaderButtonCapLeft.png,SourceCabKey=Safari.resource s_ShowReaderButtonCapLeft.png,DestName=ShowReaderButtonCapLeft.png,Attributes=512,FileSize =245,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,Hash Part1=588265457,HashPart2=2015847867,HashPart3=28386509,HashPart4=-1164005704,,)
                MSI (s) (A4:F8) [11:14:59:922]: File: C:\Program Files\Safari\Safari.resources\ShowReaderButtonCapLeft.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:922]: Executing op: FileCopy(SourceName=o6cr0cev.png|ShowReaderButtonCapLeftPressed.png,SourceCabKey=Safari.r esources_ShowReaderButtonCapLeftPressed.png,DestName=ShowReaderButtonCapLeftPressed.png,At tributes=512,FileSize=242,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=591134 72,HashOptions=0,HashPart1=-318561779,HashPart2=-1618963733,HashPart3=844982131,HashPart4= 976527758,,)
                MSI (s) (A4:F8) [11:14:59:922]: File: C:\Program Files\Safari\Safari.resources\ShowReaderButtonCapLeftPressed.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:922]: Executing op: FileCopy(SourceName=9gy4owk_.png|ShowReaderButtonCapRight.png,SourceCabKey=Safari.resourc es_ShowReaderButtonCapRight.png,DestName=ShowReaderButtonCapRight.png,Attributes=512,FileS ize=242,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,H ashPart1=-1640060790,HashPart2=488222049,HashPart3=1664392286,HashPart4=104559173,,)
                MSI (s) (A4:F8) [11:14:59:922]: File: C:\Program Files\Safari\Safari.resources\ShowReaderButtonCapRight.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:922]: Executing op: FileCopy(SourceName=r6rtyjwg.png|ShowReaderButtonCapRightPressed.png,SourceCabKey=Safari. resources_ShowReaderButtonCapRightPressed.png,DestName=ShowReaderButtonCapRightPressed.png ,Attributes=512,FileSize=242,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=591 13472,HashOptions=0,HashPart1=-124668700,HashPart2=-1140940799,HashPart3=-293010282,HashPa rt4=-1597739531,,)
                MSI (s) (A4:F8) [11:14:59:922]: File: C:\Program Files\Safari\Safari.resources\ShowReaderButtonCapRightPressed.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:922]: Executing op: FileCopy(SourceName=o3wkaxew.png|ShowReaderButtonStretch.png,SourceCabKey=Safari.resource s_ShowReaderButtonStretch.png,DestName=ShowReaderButtonStretch.png,Attributes=512,FileSize =186,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,Hash Part1=1223738798,HashPart2=-1225519356,HashPart3=2017296431,HashPart4=99353152,,)
                MSI (s) (A4:F8) [11:14:59:922]: File: C:\Program Files\Safari\Safari.resources\ShowReaderButtonStretch.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:922]: Executing op: FileCopy(SourceName=qm4mvl1t.png|ShowReaderButtonStretchPressed.png,SourceCabKey=Safari.r esources_ShowReaderButtonStretchPressed.png,DestName=ShowReaderButtonStretchPressed.png,At tributes=512,FileSize=183,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=591134 72,HashOptions=0,HashPart1=1106440474,HashPart2=-972240622,HashPart3=1906490262,HashPart4= 1234745452,,)
                MSI (s) (A4:F8) [11:14:59:922]: File: C:\Program Files\Safari\Safari.resources\ShowReaderButtonStretchPressed.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:922]: Executing op: FileCopy(SourceName=fgihgsdb.htm|SlidingAlert.html,SourceCabKey=Safari.resources_SlidingA lert.html,DestName=SlidingAlert.html,Attributes=512,FileSize=2162,PerTick=32768,,VerifyMed ia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=-521471193,HashPart2=35 0754318,HashPart3=-718477212,HashPart4=-2094771483,,)
                MSI (s) (A4:F8) [11:14:59:922]: File: C:\Program Files\Safari\Safari.resources\SlidingAlert.html;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:922]: Executing op: FileCopy(SourceName=kfguy1q4.png|SnapshotPlaceholderCompass.png,SourceCabKey=Safari.resou rces_SnapshotPlaceholderCompass.png,DestName=SnapshotPlaceholderCompass.png,Attributes=512 ,FileSize=31373,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOpt ions=0,HashPart1=-109061812,HashPart2=-342933196,HashPart3=101677454,HashPart4=204888530,, )
                MSI (s) (A4:F8) [11:14:59:922]: File: C:\Program Files\Safari\Safari.resources\SnapshotPlaceholderCompass.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:922]: Executing op: FileCopy(SourceName=tcym0diz.png|SnapshotPlaceholderGradient.png,SourceCabKey=Safari.reso urces_SnapshotPlaceholderGradient.png,DestName=SnapshotPlaceholderGradient.png,Attributes= 512,FileSize=55548,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,Hash Options=0,HashPart1=1545497807,HashPart2=-670726034,HashPart3=2124632155,HashPart4=-231251 230,,)
                MSI (s) (A4:F8) [11:14:59:922]: File: C:\Program Files\Safari\Safari.resources\SnapshotPlaceholderGradient.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:922]: Executing op: FileCopy(SourceName=crf8dmlx.png|SnapshotPlaceholderPadlock.png,SourceCabKey=Safari.resou rces_SnapshotPlaceholderPadlock.png,DestName=SnapshotPlaceholderPadlock.png,Attributes=512 ,FileSize=30555,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOpt ions=0,HashPart1=-435405470,HashPart2=1170763411,HashPart3=1087843620,HashPart4=-166166000 9,,)
                MSI (s) (A4:F8) [11:14:59:922]: File: C:\Program Files\Safari\Safari.resources\SnapshotPlaceholderPadlock.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:922]: Executing op: SetTargetFolder(Folder=C:\Program Files\Safari\Safari.resources\SnippetEditor\Images\)
                MSI (s) (A4:F8) [11:14:59:922]: Executing op: SetSourceFolder(Folder=1\Safari\mymwmyms\ysyiemyj\Images\|Safari\Safari.resources\Snippet Editor\Images\)
                MSI (s) (A4:F8) [11:14:59:922]: Executing op: FileCopy(SourceName=c6qhsi56.png|buttonBarBackground.png,SourceCabKey=Safari.resources_Sn ippetEditor_Images_buttonBarBackground.png,DestName=buttonBarBackground.png,Attributes=512 ,FileSize=587,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptio ns=0,HashPart1=-766786141,HashPart2=-516738299,HashPart3=1548145360,HashPart4=-207778026,, )
                MSI (s) (A4:F8) [11:14:59:937]: File: C:\Program Files\Safari\Safari.resources\SnippetEditor\Images\buttonBarBackground.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:937]: Executing op: FileCopy(SourceName=lpizoewl.png|buttonBarBackgroundInactive.png,SourceCabKey=Safari.reso urces_SnippetEditor_Images_buttonBarBackgroundInactive.png,DestName=buttonBarBackgroundIna ctive.png,Attributes=512,FileSize=578,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,Instal lMode=59113472,HashOptions=0,HashPart1=1098327664,HashPart2=189148016,HashPart3=1921179783 ,HashPart4=1275063340,,)
                MSI (s) (A4:F8) [11:14:59:937]: File: C:\Program Files\Safari\Safari.resources\SnippetEditor\Images\buttonBarBackgroundInactive.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:937]: Executing op: FileCopy(SourceName=xxpsptwk.png|splitterBar.png,SourceCabKey=Safari.resources_SnippetEdi tor_Images_splitterBar.png,DestName=splitterBar.png,Attributes=512,FileSize=583,PerTick=32 768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=-25614367 6,HashPart2=1085699019,HashPart3=764458020,HashPart4=1012636814,,)
                MSI (s) (A4:F8) [11:14:59:937]: File: C:\Program Files\Safari\Safari.resources\SnippetEditor\Images\splitterBar.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:937]: Executing op: FileCopy(SourceName=ogbyxdh-.png|splitterBarInactive.png,SourceCabKey=Safari.resources_Sn ippetEditor_Images_splitterBarInactive.png,DestName=splitterBarInactive.png,Attributes=512 ,FileSize=577,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptio ns=0,HashPart1=-525853183,HashPart2=1282571767,HashPart3=607903881,HashPart4=-1841128463,, )
                MSI (s) (A4:F8) [11:14:59:937]: File: C:\Program Files\Safari\Safari.resources\SnippetEditor\Images\splitterBarInactive.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:937]: Executing op: FileCopy(SourceName=wnwcrrev.png|splitterDimple.png,SourceCabKey=Safari.resources_Snippet Editor_Images_splitterDimple.png,DestName=splitterDimple.png,Attributes=512,FileSize=599,P erTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1= 1594013457,HashPart2=-579403038,HashPart3=568761822,HashPart4=-575098024,,)
                MSI (s) (A4:F8) [11:14:59:937]: File: C:\Program Files\Safari\Safari.resources\SnippetEditor\Images\splitterDimple.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:937]: Executing op: FileCopy(SourceName=xbg8sajj.png|splitterDimpleInactive.png,SourceCabKey=Safari.resources _SnippetEditor_Images_splitterDimpleInactive.png,DestName=splitterDimpleInactive.png,Attri butes=512,FileSize=596,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472, HashOptions=0,HashPart1=-206031713,HashPart2=1123961907,HashPart3=540820817,HashPart4=-640 088205,,)
                MSI (s) (A4:F8) [11:14:59:937]: File: C:\Program Files\Safari\Safari.resources\SnippetEditor\Images\splitterDimpleInactive.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:937]: Executing op: FileCopy(SourceName=iwwxt-d4.png|toolbarButton.png,SourceCabKey=Safari.resources_SnippetE ditor_Images_toolbarButton.png,DestName=toolbarButton.png,Attributes=512,FileSize=904,PerT ick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=477 698695,HashPart2=1962526596,HashPart3=-952408672,HashPart4=-86851419,,)
                MSI (s) (A4:F8) [11:14:59:937]: File: C:\Program Files\Safari\Safari.resources\SnippetEditor\Images\toolbarButton.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:937]: Executing op: FileCopy(SourceName=smjlvind.png|toolbarButtonInactive.png,SourceCabKey=Safari.resources_ SnippetEditor_Images_toolbarButtonInactive.png,DestName=toolbarButtonInactive.png,Attribut es=512,FileSize=895,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,Has hOptions=0,HashPart1=20824738,HashPart2=-17320152,HashPart3=-1739050969,HashPart4=-4565830 72,,)
                MSI (s) (A4:F8) [11:14:59:937]: File: C:\Program Files\Safari\Safari.resources\SnippetEditor\Images\toolbarButtonInactive.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:937]: Executing op: FileCopy(SourceName=lrhswynb.png|toolbarButtonPressed.png,SourceCabKey=Safari.resources_S nippetEditor_Images_toolbarButtonPressed.png,DestName=toolbarButtonPressed.png,Attributes= 512,FileSize=1063,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashO ptions=0,HashPart1=1841864950,HashPart2=1511576221,HashPart3=1119731080,HashPart4=-8438059 13,,)
                MSI (s) (A4:F8) [11:14:59:937]: File: C:\Program Files\Safari\Safari.resources\SnippetEditor\Images\toolbarButtonPressed.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:937]: Executing op: SetTargetFolder(Folder=C:\Program Files\Safari\Safari.resources\SnippetEditor\)
                MSI (s) (A4:F8) [11:14:59:937]: Executing op: SetSourceFolder(Folder=1\Safari\mymwmyms\ysyiemyj\|Safari\Safari.resources\SnippetEditor\ )
                MSI (s) (A4:F8) [11:14:59:937]: Executing op: FileCopy(SourceName=h6frpcmw.css|SnippetEditor.css,SourceCabKey=Safari.resources_SnippetE ditor_SnippetEditor.css,DestName=SnippetEditor.css,Attributes=512,FileSize=3625,PerTick=32 768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=185050631 3,HashPart2=1637748968,HashPart3=-513243123,HashPart4=-317139511,,)
                MSI (s) (A4:F8) [11:14:59:937]: File: C:\Program Files\Safari\Safari.resources\SnippetEditor\SnippetEditor.css;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:937]: Executing op: FileCopy(SourceName=b78k7-1y.htm|SnippetEditor.html,SourceCabKey=Safari.resources_Snippet Editor_SnippetEditor.html,DestName=SnippetEditor.html,Attributes=512,FileSize=569,PerTick= 32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=9803878 76,HashPart2=-1694484185,HashPart3=548247405,HashPart4=-1147163503,,)
                MSI (s) (A4:F8) [11:14:59:937]: File: C:\Program Files\Safari\Safari.resources\SnippetEditor\SnippetEditor.html;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:937]: Executing op: FileCopy(SourceName=msljiigr.js|SnippetEditor.js,SourceCabKey=Safari.resources_SnippetEdi tor_SnippetEditor.js,DestName=SnippetEditor.js,Attributes=512,FileSize=7432,PerTick=32768, ,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=869759008,Has hPart2=1455857898,HashPart3=-1878984214,HashPart4=-451962080,,)
                MSI (s) (A4:F8) [11:14:59:937]: File: C:\Program Files\Safari\Safari.resources\SnippetEditor\SnippetEditor.js;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:937]: Executing op: SetTargetFolder(Folder=C:\Program Files\Safari\Safari.resources\)
                MSI (s) (A4:F8) [11:14:59:937]: Executing op: SetSourceFolder(Folder=1\Safari\mymwmyms\|Safari\Safari.resources\)
                MSI (s) (A4:F8) [11:14:59:937]: Executing op: FileCopy(SourceName=k1tumrry.png|SoftwareUpdateIcon.png,SourceCabKey=Safari.resources_Sof twareUpdateIcon.png,DestName=SoftwareUpdateIcon.png,Attributes=512,FileSize=1761,PerTick=3 2768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=-1231895 612,HashPart2=1024997985,HashPart3=1350196775,HashPart4=-310474919,,)
                MSI (s) (A4:F8) [11:14:59:937]: File: C:\Program Files\Safari\Safari.resources\SoftwareUpdateIcon.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:937]: Executing op: FileCopy(SourceName=bm_sswmp.htm|Spelling.html,SourceCabKey=Safari.resources_Spelling.htm l,DestName=Spelling.html,Attributes=512,FileSize=3012,PerTick=32768,,VerifyMedia=1,,,,,Che ckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=801103664,HashPart2=-1141273384,Has hPart3=-786136957,HashPart4=-1219624799,,)
                MSI (s) (A4:F8) [11:14:59:953]: File: C:\Program Files\Safari\Safari.resources\Spelling.html;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:953]: Executing op: FileCopy(SourceName=plbge8e_.plt|ssl-base.pltsuite,SourceCabKey=Safari.resources_ssl_base .pltsuite,DestName=ssl-base.pltsuite,Attributes=512,FileSize=1893,PerTick=32768,,VerifyMed ia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=-346961088,HashPart2=-5 90247517,HashPart3=-1004890807,HashPart4=142210959,,)
                MSI (s) (A4:F8) [11:14:59:953]: File: C:\Program Files\Safari\Safari.resources\ssl-base.pltsuite;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:953]: Executing op: FileCopy(SourceName=kn02txsp.htm|StandardErrorPage.html,SourceCabKey=Safari.resources_Sta ndardErrorPage.html,DestName=StandardErrorPage.html,Attributes=512,FileSize=1736,PerTick=3 2768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=-6482257 52,HashPart2=624863887,HashPart3=-1462446994,HashPart4=197135743,,)
                MSI (s) (A4:F8) [11:14:59:953]: File: C:\Program Files\Safari\Safari.resources\StandardErrorPage.html;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:953]: Executing op: SetTargetFolder(Folder=C:\Program Files\Safari\Safari.resources\sv.lproj\)
                MSI (s) (A4:F8) [11:14:59:953]: Executing op: SetSourceFolder(Folder=1\Safari\mymwmyms\rjuljygq\|Safari\Safari.resources\sv.lproj\)
                MSI (s) (A4:F8) [11:14:59:953]: Executing op: FileCopy(SourceName=eekpze9k.pli|ABAutoCompleteMappings.plist,SourceCabKey=Safari.resourc es_sv.lproj_ABAutoCompleteMappings.plist,DestName=ABAutoCompleteMappings.plist,Attributes= 512,FileSize=11658,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,Hash Options=0,HashPart1=28184004,HashPart2=896409214,HashPart3=679929955,HashPart4=-1158571070 ,,)
                MSI (s) (A4:F8) [11:14:59:953]: File: C:\Program Files\Safari\Safari.resources\sv.lproj\ABAutoCompleteMappings.plist;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:953]: Executing op: FileCopy(SourceName=bindict,SourceCabKey=Safari.resources_sv.lproj_bindict,DestName=bindi ct,Attributes=512,FileSize=1052,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode= 59113472,HashOptions=0,HashPart1=-1770469188,HashPart2=-1321566491,HashPart3=642985237,Has hPart4=-1163033169,,)
                MSI (s) (A4:F8) [11:14:59:953]: File: C:\Program Files\Safari\Safari.resources\sv.lproj\bindict;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:953]: Executing op: FileCopy(SourceName=mucxlxtz.pli|BuiltInBookmarks.plist,SourceCabKey=Safari.resources_sv. lproj_BuiltInBookmarks.plist,DestName=BuiltInBookmarks.plist,Attributes=512,FileSize=9304, PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1 =1102936254,HashPart2=133078465,HashPart3=-221374523,HashPart4=748920530,,)
                MSI (s) (A4:F8) [11:14:59:953]: File: C:\Program Files\Safari\Safari.resources\sv.lproj\BuiltInBookmarks.plist;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:953]: Executing op: FileCopy(SourceName=l8ktuzpc.dat|Dictionary.dat,SourceCabKey=Safari.resources_sv.lproj_Di ctionary.dat,DestName=Dictionary.dat,Attributes=512,FileSize=874496,PerTick=32768,,VerifyM edia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=-1039316387,HashPart2 =-440449305,HashPart3=-1807641625,HashPart4=1782361807,,)
                MSI (s) (A4:F8) [11:14:59:953]: File: C:\Program Files\Safari\Safari.resources\sv.lproj\Dictionary.dat;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:953]: Executing op: FileCopy(SourceName=1ljco-is.str|Localizable.strings,SourceCabKey=Safari.resources_sv.lpr oj_Localizable.strings,DestName=Localizable.strings,Attributes=512,FileSize=338880,PerTick =32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=-17662 03866,HashPart2=-888959849,HashPart3=1357307530,HashPart4=-42259309,,)
                MSI (s) (A4:F8) [11:14:59:953]: File: C:\Program Files\Safari\Safari.resources\sv.lproj\Localizable.strings;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:953]: Executing op: FileCopy(SourceName=vlqd8yso.js|localizedStrings.js,SourceCabKey=Safari.resources_sv.lpro j_localizedStrings.js,DestName=localizedStrings.js,Attributes=512,FileSize=54546,PerTick=3 2768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=-1376449 779,HashPart2=-976526751,HashPart3=-166741230,HashPart4=779264027,,)
                MSI (s) (A4:F8) [11:14:59:968]: File: C:\Program Files\Safari\Safari.resources\sv.lproj\localizedStrings.js;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:968]: Executing op: SetTargetFolder(Folder=C:\Program Files\Safari\Safari.resources\)
                MSI (s) (A4:F8) [11:14:59:968]: Executing op: SetSourceFolder(Folder=1\Safari\mymwmyms\|Safari\Safari.resources\)
                MSI (s) (A4:F8) [11:14:59:968]: Executing op: FileCopy(SourceName=pmpby27k.js|Syndication.js,SourceCabKey=Safari.resources_Syndication. js,DestName=Syndication.js,Attributes=512,FileSize=1195,PerTick=32768,,VerifyMedia=1,,,,,C heckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=-150426497,HashPart2=-990791497,H ashPart3=-2091477243,HashPart4=-950490956,,)
                MSI (s) (A4:F8) [11:14:59:968]: File: C:\Program Files\Safari\Safari.resources\Syndication.js;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:968]: Executing op: FileCopy(SourceName=t46wmwfo.png|tabActiveFill.png,SourceCabKey=Safari.resources_tabActiv eFill.png,DestName=tabActiveFill.png,Attributes=512,FileSize=126,PerTick=32768,,VerifyMedi a=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=-152557902,HashPart2=-19 58913743,HashPart3=-399705120,HashPart4=-1183901622,,)
                MSI (s) (A4:F8) [11:14:59:968]: File: C:\Program Files\Safari\Safari.resources\tabActiveFill.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:968]: Executing op: FileCopy(SourceName=u6qmc4ln.png|tabActiveLeft.png,SourceCabKey=Safari.resources_tabActiv eLeft.png,DestName=tabActiveLeft.png,Attributes=512,FileSize=371,PerTick=32768,,VerifyMedi a=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=1905523392,HashPart2=-11 84906922,HashPart3=1615744394,HashPart4=-1922999138,,)
                MSI (s) (A4:F8) [11:14:59:968]: File: C:\Program Files\Safari\Safari.resources\tabActiveLeft.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:968]: Executing op: FileCopy(SourceName=etg6qeff.png|tabActiveMask.png,SourceCabKey=Safari.resources_tabActiv eMask.png,DestName=tabActiveMask.png,Attributes=512,FileSize=208,PerTick=32768,,VerifyMedi a=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=-928325659,HashPart2=-11 46133296,HashPart3=1082480109,HashPart4=-1408332591,,)
                MSI (s) (A4:F8) [11:14:59:968]: File: C:\Program Files\Safari\Safari.resources\tabActiveMask.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:968]: Executing op: FileCopy(SourceName=gg6oxn1n.png|tabActiveRight.png,SourceCabKey=Safari.resources_tabActi veRight.png,DestName=tabActiveRight.png,Attributes=512,FileSize=382,PerTick=32768,,VerifyM edia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=1868588919,HashPart2= -280940914,HashPart3=-319950104,HashPart4=153348798,,)
                MSI (s) (A4:F8) [11:14:59:968]: File: C:\Program Files\Safari\Safari.resources\tabActiveRight.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:968]: Executing op: FileCopy(SourceName=ogmvvjgk.png|tabBarFill.png,SourceCabKey=Safari.resources_tabBarFill. png,DestName=tabBarFill.png,Attributes=512,FileSize=138,PerTick=32768,,VerifyMedia=1,,,,,C heckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=-1349515298,HashPart2=110506282,H ashPart3=2073021812,HashPart4=-1638154481,,)
                MSI (s) (A4:F8) [11:14:59:968]: File: C:\Program Files\Safari\Safari.resources\tabBarFill.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:968]: Executing op: FileCopy(SourceName=x-du1c5t.png|tabDragLeft.png,SourceCabKey=Safari.resources_tabDragLef t.png,DestName=tabDragLeft.png,Attributes=512,FileSize=182,PerTick=32768,,VerifyMedia=1,,, ,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=-979766850,HashPart2=114825754 3,HashPart3=-1283798963,HashPart4=697462577,,)
                MSI (s) (A4:F8) [11:14:59:968]: File: C:\Program Files\Safari\Safari.resources\tabDragLeft.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:968]: Executing op: FileCopy(SourceName=4ijc31p6.png|tabDragRight.png,SourceCabKey=Safari.resources_tabDragRi ght.png,DestName=tabDragRight.png,Attributes=512,FileSize=181,PerTick=32768,,VerifyMedia=1 ,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=-508639524,HashPart2=205692 3346,HashPart3=-2074886374,HashPart4=-2054693590,,)
                MSI (s) (A4:F8) [11:14:59:968]: File: C:\Program Files\Safari\Safari.resources\tabDragRight.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:968]: Executing op: FileCopy(SourceName=oug6pady.png|tabInactiveLeft.png,SourceCabKey=Safari.resources_tabIna ctiveLeft.png,DestName=tabInactiveLeft.png,Attributes=512,FileSize=381,PerTick=32768,,Veri fyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=-1052872740,HashPa rt2=1849656908,HashPart3=-893164567,HashPart4=1662855112,,)
                MSI (s) (A4:F8) [11:14:59:968]: File: C:\Program Files\Safari\Safari.resources\tabInactiveLeft.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:968]: Executing op: FileCopy(SourceName=nuib6uvc.png|tabInactiveRight.png,SourceCabKey=Safari.resources_tabIn activeRight.png,DestName=tabInactiveRight.png,Attributes=512,FileSize=361,PerTick=32768,,V erifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=-1817861804,Has hPart2=-1562578842,HashPart3=1646407434,HashPart4=-1111993363,,)
                MSI (s) (A4:F8) [11:14:59:968]: File: C:\Program Files\Safari\Safari.resources\tabInactiveRight.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:968]: Executing op: FileCopy(SourceName=jemjwfo_.htm|TabsPreferences.html,SourceCabKey=Safari.resources_TabsP references.html,DestName=TabsPreferences.html,Attributes=512,FileSize=5597,PerTick=32768,, VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=-403696252,Has hPart2=-1909836907,HashPart3=371650693,HashPart4=2076593008,,)
                MSI (s) (A4:F8) [11:14:59:968]: File: C:\Program Files\Safari\Safari.resources\TabsPreferences.html;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:968]: Executing op: FileCopy(SourceName=adbdpr8j.pdf|ToolbarBookmarksBarTemplate.pdf,SourceCabKey=Safari.reso urces_ToolbarBookmarksBarTemplate.pdf,DestName=ToolbarBookmarksBarTemplate.pdf,Attributes= 512,FileSize=2481,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashO ptions=0,HashPart1=218134521,HashPart2=-816181529,HashPart3=-151348226,HashPart4=-21316517 15,,)
                MSI (s) (A4:F8) [11:14:59:968]: File: C:\Program Files\Safari\Safari.resources\ToolbarBookmarksBarTemplate.pdf;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:968]: Executing op: FileCopy(SourceName=jc2nhvhf.pdf|ToolbarBookmarksTemplate.pdf,SourceCabKey=Safari.resourc es_ToolbarBookmarksTemplate.pdf,DestName=ToolbarBookmarksTemplate.pdf,Attributes=512,FileS ize=4434,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0, HashPart1=1103661546,HashPart2=1361074175,HashPart3=549731957,HashPart4=1741363298,,)
                MSI (s) (A4:F8) [11:14:59:968]: File: C:\Program Files\Safari\Safari.resources\ToolbarBookmarksTemplate.pdf;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:968]: Executing op: FileCopy(SourceName=jpjpz48f.pdf|ToolbarDownloadsTemplate.pdf,SourceCabKey=Safari.resourc es_ToolbarDownloadsTemplate.pdf,DestName=ToolbarDownloadsTemplate.pdf,Attributes=512,FileS ize=2215,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0, HashPart1=-60057144,HashPart2=1869473794,HashPart3=780504967,HashPart4=1339780629,,)
                MSI (s) (A4:F8) [11:14:59:968]: File: C:\Program Files\Safari\Safari.resources\ToolbarDownloadsTemplate.pdf;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:968]: Executing op: FileCopy(SourceName=f29qgvss.pdf|ToolbarEmailTemplate.pdf,SourceCabKey=Safari.resources_T oolbarEmailTemplate.pdf,DestName=ToolbarEmailTemplate.pdf,Attributes=512,FileSize=1230,Per Tick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=-1 862707408,HashPart2=215496111,HashPart3=943892779,HashPart4=-508406838,,)
                MSI (s) (A4:F8) [11:14:59:984]: File: C:\Program Files\Safari\Safari.resources\ToolbarEmailTemplate.pdf;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:984]: Executing op: FileCopy(SourceName=ror3qfas.pdf|ToolbarHistoryTemplate.pdf,SourceCabKey=Safari.resources _ToolbarHistoryTemplate.pdf,DestName=ToolbarHistoryTemplate.pdf,Attributes=512,FileSize=43 95,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPa rt1=1178445004,HashPart2=-779889321,HashPart3=-1832931437,HashPart4=684568545,,)
                MSI (s) (A4:F8) [11:14:59:984]: File: C:\Program Files\Safari\Safari.resources\ToolbarHistoryTemplate.pdf;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:984]: Executing op: FileCopy(SourceName=gocqiumv.pdf|ToolbarNewTabTemplate.pdf,SourceCabKey=Safari.resources_ ToolbarNewTabTemplate.pdf,DestName=ToolbarNewTabTemplate.pdf,Attributes=512,FileSize=4359, PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1 =-1776059882,HashPart2=2022931456,HashPart3=-1237186184,HashPart4=-549447931,,)
                MSI (s) (A4:F8) [11:14:59:984]: File: C:\Program Files\Safari\Safari.resources\ToolbarNewTabTemplate.pdf;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:984]: Executing op: FileCopy(SourceName=ldalf57m.pdf|ToolbarTopSitesTemplate.pdf,SourceCabKey=Safari.resource s_ToolbarTopSitesTemplate.pdf,DestName=ToolbarTopSitesTemplate.pdf,Attributes=512,FileSize =4898,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,Has hPart1=-1181827458,HashPart2=-2026633901,HashPart3=-1149384550,HashPart4=1401887156,,)
                MSI (s) (A4:F8) [11:14:59:984]: File: C:\Program Files\Safari\Safari.resources\ToolbarTopSitesTemplate.pdf;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:984]: Executing op: FileCopy(SourceName=qdzttdig.pdf|ToolbarWebInspectorTemplate.pdf,SourceCabKey=Safari.reso urces_ToolbarWebInspectorTemplate.pdf,DestName=ToolbarWebInspectorTemplate.pdf,Attributes= 512,FileSize=4571,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashO ptions=0,HashPart1=-1666313136,HashPart2=1479700869,HashPart3=-502041491,HashPart4=8858879 89,,)
                MSI (s) (A4:F8) [11:14:59:984]: File: C:\Program Files\Safari\Safari.resources\ToolbarWebInspectorTemplate.pdf;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:984]: Executing op: FileCopy(SourceName=psmuizfc.pli|TopLevelDomains.plist,SourceCabKey=Safari.resources_TopL evelDomains.plist,DestName=TopLevelDomains.plist,Attributes=512,FileSize=126743,PerTick=32 768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=161125287 3,HashPart2=-554709273,HashPart3=-741176583,HashPart4=-72779412,,)
                MSI (s) (A4:F8) [11:14:59:984]: File: C:\Program Files\Safari\Safari.resources\TopLevelDomains.plist;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:984]: Executing op: FileCopy(SourceName=oo_z07fk.png|TopSitesDarkButtonDiv-N.png,SourceCabKey=Safari.resource s_TopSitesDarkButtonDiv_N.png,DestName=TopSitesDarkButtonDiv-N.png,Attributes=512,FileSize =212,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,Hash Part1=-1214675161,HashPart2=-1783099679,HashPart3=758965109,HashPart4=778261420,,)
                MSI (s) (A4:F8) [11:14:59:984]: File: C:\Program Files\Safari\Safari.resources\TopSitesDarkButtonDiv-N.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:984]: Executing op: FileCopy(SourceName=8fbq0r6k.png|TopSitesDarkButtonDiv-P.png,SourceCabKey=Safari.resource s_TopSitesDarkButtonDiv_P.png,DestName=TopSitesDarkButtonDiv-P.png,Attributes=512,FileSize =214,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,Hash Part1=-1491589212,HashPart2=-422014137,HashPart3=1793568935,HashPart4=1625669604,,)
                MSI (s) (A4:F8) [11:14:59:984]: File: C:\Program Files\Safari\Safari.resources\TopSitesDarkButtonDiv-P.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:984]: Executing op: FileCopy(SourceName=zsy0tf7e.png|TopSitesDarkButtonFill-N.png,SourceCabKey=Safari.resourc es_TopSitesDarkButtonFill_N.png,DestName=TopSitesDarkButtonFill-N.png,Attributes=512,FileS ize=214,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,H ashPart1=1533536064,HashPart2=1086182388,HashPart3=-1432085381,HashPart4=164308322,,)
                MSI (s) (A4:F8) [11:14:59:984]: File: C:\Program Files\Safari\Safari.resources\TopSitesDarkButtonFill-N.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:984]: Executing op: FileCopy(SourceName=viq2mm4u.png|TopSitesDarkButtonFill-P.png,SourceCabKey=Safari.resourc es_TopSitesDarkButtonFill_P.png,DestName=TopSitesDarkButtonFill-P.png,Attributes=512,FileS ize=216,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,H ashPart1=65292428,HashPart2=1332022704,HashPart3=1547046776,HashPart4=-2093711460,,)
                MSI (s) (A4:F8) [11:14:59:984]: File: C:\Program Files\Safari\Safari.resources\TopSitesDarkButtonFill-P.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:984]: Executing op: FileCopy(SourceName=g0lzdw3z.png|TopSitesDarkButtonFill-Pressed.png,SourceCabKey=Safari.r esources_TopSitesDarkButtonFill_Pressed.png,DestName=TopSitesDarkButtonFill-Pressed.png,At tributes=512,FileSize=211,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=591134 72,HashOptions=0,HashPart1=1580388460,HashPart2=2093039442,HashPart3=-606726,HashPart4=174 0956777,,)
                MSI (s) (A4:F8) [11:14:59:984]: File: C:\Program Files\Safari\Safari.resources\TopSitesDarkButtonFill-Pressed.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:984]: Executing op: FileCopy(SourceName=ixjtohti.png|TopSitesDarkButtonLeft-N.png,SourceCabKey=Safari.resourc es_TopSitesDarkButtonLeft_N.png,DestName=TopSitesDarkButtonLeft-N.png,Attributes=512,FileS ize=609,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,H ashPart1=1932858275,HashPart2=1845502064,HashPart3=2130868882,HashPart4=1944691136,,)
                MSI (s) (A4:F8) [11:14:59:984]: File: C:\Program Files\Safari\Safari.resources\TopSitesDarkButtonLeft-N.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:984]: Executing op: FileCopy(SourceName=rexr6yb_.png|TopSitesDarkButtonLeft-P.png,SourceCabKey=Safari.resourc es_TopSitesDarkButtonLeft_P.png,DestName=TopSitesDarkButtonLeft-P.png,Attributes=512,FileS ize=614,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,H ashPart1=-1671402609,HashPart2=-952887805,HashPart3=721386485,HashPart4=1188564361,,)
                MSI (s) (A4:F8) [11:14:59:984]: File: C:\Program Files\Safari\Safari.resources\TopSitesDarkButtonLeft-P.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:14:59:984]: Executing op: FileCopy(SourceName=iotmfvcp.png|TopSitesDarkButtonLeft-Pressed.png,SourceCabKey=Safari.r esources_TopSitesDarkButtonLeft_Pressed.png,DestName=TopSitesDarkButtonLeft-Pressed.png,At tributes=512,FileSize=623,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=591134 72,HashOptions=0,HashPart1=-201556971,HashPart2=-1513221872,HashPart3=-946670066,HashPart4 =-396419675,,)
                MSI (s) (A4:F8) [11:15:00:000]: File: C:\Program Files\Safari\Safari.resources\TopSitesDarkButtonLeft-Pressed.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:15:00:000]: Executing op: FileCopy(SourceName=-funhxgw.png|TopSitesDarkButtonRight-N.png,SourceCabKey=Safari.resour ces_TopSitesDarkButtonRight_N.png,DestName=TopSitesDarkButtonRight-N.png,Attributes=512,Fi leSize=678,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions= 0,HashPart1=-1931188904,HashPart2=-2015074113,HashPart3=-1546720449,HashPart4=-67410996,,)
                MSI (s) (A4:F8) [11:15:00:000]: File: C:\Program Files\Safari\Safari.resources\TopSitesDarkButtonRight-N.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:15:00:000]: Executing op: FileCopy(SourceName=0gzkz0qp.png|TopSitesDarkButtonRight-P.png,SourceCabKey=Safari.resour ces_TopSitesDarkButtonRight_P.png,DestName=TopSitesDarkButtonRight-P.png,Attributes=512,Fi leSize=700,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions= 0,HashPart1=-181443039,HashPart2=45792298,HashPart3=-1181022860,HashPart4=-57463177,,)
                MSI (s) (A4:F8) [11:15:00:000]: File: C:\Program Files\Safari\Safari.resources\TopSitesDarkButtonRight-P.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:15:00:000]: Executing op: FileCopy(SourceName=ua2yg0mw.png|TopSitesDarkButtonRight-Pressed.png,SourceCabKey=Safari. resources_TopSitesDarkButtonRight_Pressed.png,DestName=TopSitesDarkButtonRight-Pressed.png ,Attributes=512,FileSize=688,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=591 13472,HashOptions=0,HashPart1=598763288,HashPart2=1581618934,HashPart3=1282292562,HashPart 4=845757414,,)
                MSI (s) (A4:F8) [11:15:00:000]: File: C:\Program Files\Safari\Safari.resources\TopSitesDarkButtonRight-Pressed.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:15:00:000]: Executing op: FileCopy(SourceName=gcbwc2on.png|TopSitesKeepButtonOff.png,SourceCabKey=Safari.resources_ TopSitesKeepButtonOff.png,DestName=TopSitesKeepButtonOff.png,Attributes=512,FileSize=1459, PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1 =1461992369,HashPart2=-644028261,HashPart3=-192110765,HashPart4=-18919653,,)
                MSI (s) (A4:F8) [11:15:00:000]: File: C:\Program Files\Safari\Safari.resources\TopSitesKeepButtonOff.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:15:00:000]: Executing op: FileCopy(SourceName=xfo5eoyz.png|TopSitesKeepButtonOffPressed.png,SourceCabKey=Safari.res ources_TopSitesKeepButtonOffPressed.png,DestName=TopSitesKeepButtonOffPressed.png,Attribut es=512,FileSize=1597,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,Ha shOptions=0,HashPart1=-1648813951,HashPart2=-2044575361,HashPart3=332713616,HashPart4=1489 457935,,)
                MSI (s) (A4:F8) [11:15:00:000]: File: C:\Program Files\Safari\Safari.resources\TopSitesKeepButtonOffPressed.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:15:00:000]: Executing op: FileCopy(SourceName=yibeawvp.png|TopSitesKeepButtonOn.png,SourceCabKey=Safari.resources_T opSitesKeepButtonOn.png,DestName=TopSitesKeepButtonOn.png,Attributes=512,FileSize=1778,Per Tick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=-1 353311030,HashPart2=1915147520,HashPart3=-157075019,HashPart4=1193970314,,)
                MSI (s) (A4:F8) [11:15:00:000]: File: C:\Program Files\Safari\Safari.resources\TopSitesKeepButtonOn.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:15:00:000]: Executing op: FileCopy(SourceName=m_hrn4zq.png|TopSitesKeepButtonOnPressed.png,SourceCabKey=Safari.reso urces_TopSitesKeepButtonOnPressed.png,DestName=TopSitesKeepButtonOnPressed.png,Attributes= 512,FileSize=1760,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashO ptions=0,HashPart1=1268791211,HashPart2=-2069656082,HashPart3=-450441789,HashPart4=2113572 303,,)
                MSI (s) (A4:F8) [11:15:00:000]: File: C:\Program Files\Safari\Safari.resources\TopSitesKeepButtonOnPressed.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:15:00:000]: Executing op: FileCopy(SourceName=3ener1fx.png|TopSitesKeepRemoveDivider.png,SourceCabKey=Safari.resour ces_TopSitesKeepRemoveDivider.png,DestName=TopSitesKeepRemoveDivider.png,Attributes=512,Fi leSize=193,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions= 0,HashPart1=1275054101,HashPart2=91048422,HashPart3=642337572,HashPart4=-679540775,,)
                MSI (s) (A4:F8) [11:15:00:000]: File: C:\Program Files\Safari\Safari.resources\TopSitesKeepRemoveDivider.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:15:00:000]: Executing op: FileCopy(SourceName=lfy7ywnr.png|TopSitesRemoveButton.png,SourceCabKey=Safari.resources_T opSitesRemoveButton.png,DestName=TopSitesRemoveButton.png,Attributes=512,FileSize=1337,Per Tick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=66 9448094,HashPart2=237306493,HashPart3=1644096551,HashPart4=-873525868,,)
                MSI (s) (A4:F8) [11:15:00:000]: File: C:\Program Files\Safari\Safari.resources\TopSitesRemoveButton.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:15:00:000]: Executing op: FileCopy(SourceName=sume1tvd.png|TopSitesRemoveButtonPressed.png,SourceCabKey=Safari.reso urces_TopSitesRemoveButtonPressed.png,DestName=TopSitesRemoveButtonPressed.png,Attributes= 512,FileSize=1465,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashO ptions=0,HashPart1=1469312854,HashPart2=577073874,HashPart3=-1743686704,HashPart4=27416922 6,,)
                MSI (s) (A4:F8) [11:15:00:000]: File: C:\Program Files\Safari\Safari.resources\TopSitesRemoveButtonPressed.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:15:00:000]: Executing op: FileCopy(SourceName=ba8s0_cz.png|TopSitesUpdatedPageCurl.png,SourceCabKey=Safari.resource s_TopSitesUpdatedPageCurl.png,DestName=TopSitesUpdatedPageCurl.png,Attributes=512,FileSize =5085,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,Has hPart1=-492770992,HashPart2=80695407,HashPart3=-1233855030,HashPart4=1243663465,,)
                MSI (s) (A4:F8) [11:15:00:000]: File: C:\Program Files\Safari\Safari.resources\TopSitesUpdatedPageCurl.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:15:00:000]: Executing op: FileCopy(SourceName=sdz9fuzo.pli|Trackers.plist,SourceCabKey=Safari.resources_Trackers.pl ist,DestName=Trackers.plist,Attributes=512,FileSize=16703,PerTick=32768,,VerifyMedia=1,,,, ,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=135453082,HashPart2=238309846,H ashPart3=-965662227,HashPart4=-598418010,,)
                MSI (s) (A4:F8) [11:15:00:000]: File: C:\Program Files\Safari\Safari.resources\Trackers.plist;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:15:00:000]: Executing op: FileCopy(SourceName=amuof2lt.js|TrackingBlocker.js,SourceCabKey=Safari.resources_Tracking Blocker.js,DestName=TrackingBlocker.js,Attributes=512,FileSize=470,PerTick=32768,,VerifyMe dia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=449900359,HashPart2=-1 042192962,HashPart3=479458213,HashPart4=1120411672,,)
                MSI (s) (A4:F8) [11:15:00:000]: File: C:\Program Files\Safari\Safari.resources\TrackingBlocker.js;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:15:00:000]: Executing op: FileCopy(SourceName=ituybvwq.png|treeDownTriangleBlack.png,SourceCabKey=Safari.resources_ treeDownTriangleBlack.png,DestName=treeDownTriangleBlack.png,Attributes=512,FileSize=3570, PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1 =-1852521871,HashPart2=817648203,HashPart3=-1715760794,HashPart4=-272437478,,)
                MSI (s) (A4:F8) [11:15:00:015]: File: C:\Program Files\Safari\Safari.resources\treeDownTriangleBlack.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:15:00:015]: Executing op: FileCopy(SourceName=4bu0adcu.png|treeUpTriangleBlack.png,SourceCabKey=Safari.resources_tr eeUpTriangleBlack.png,DestName=treeUpTriangleBlack.png,Attributes=512,FileSize=3584,PerTic k=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=-1620 243097,HashPart2=-1792411749,HashPart3=1668713898,HashPart4=-2088302332,,)
                MSI (s) (A4:F8) [11:15:00:015]: File: C:\Program Files\Safari\Safari.resources\treeUpTriangleBlack.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:15:00:015]: Executing op: FileCopy(SourceName=sayi9tvu.png|URLFieldCapLeft.png,SourceCabKey=Safari.resources_URLFie ldCapLeft.png,DestName=URLFieldCapLeft.png,Attributes=512,FileSize=262,PerTick=32768,,Veri fyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=-766454270,HashPar t2=98281088,HashPart3=-2088553530,HashPart4=206562881,,)
                MSI (s) (A4:F8) [11:15:00:015]: File: C:\Program Files\Safari\Safari.resources\URLFieldCapLeft.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:15:00:015]: Executing op: FileCopy(SourceName=ypki3hkd.png|URLFieldCapLeftFocused.png,SourceCabKey=Safari.resources _URLFieldCapLeftFocused.png,DestName=URLFieldCapLeftFocused.png,Attributes=512,FileSize=28 3,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPar t1=27529578,HashPart2=683816091,HashPart3=-106270649,HashPart4=-894212001,,)
                MSI (s) (A4:F8) [11:15:00:015]: File: C:\Program Files\Safari\Safari.resources\URLFieldCapLeftFocused.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:15:00:015]: Executing op: FileCopy(SourceName=6jldekk0.png|URLFieldCapLeftHoveredButton.png,SourceCabKey=Safari.res ources_URLFieldCapLeftHoveredButton.png,DestName=URLFieldCapLeftHoveredButton.png,Attribut es=512,FileSize=307,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,Has hOptions=0,HashPart1=-505163022,HashPart2=1355637344,HashPart3=775705915,HashPart4=8648155 58,,)
                MSI (s) (A4:F8) [11:15:00:015]: File: C:\Program Files\Safari\Safari.resources\URLFieldCapLeftHoveredButton.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:15:00:015]: Executing op: FileCopy(SourceName=zj4zm_ld.png|URLFieldCapLeftHoveredButtonProgress.png,SourceCabKey=Sa fari.resources_URLFieldCapLeftHoveredButtonProgress.png,DestName=URLFieldCapLeftHoveredBut tonProgress.png,Attributes=512,FileSize=485,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,, InstallMode=59113472,HashOptions=0,HashPart1=366903510,HashPart2=788479552,HashPart3=-1868 299797,HashPart4=896654571,,)
                MSI (s) (A4:F8) [11:15:00:015]: File: C:\Program Files\Safari\Safari.resources\URLFieldCapLeftHoveredButtonProgress.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:15:00:015]: Executing op: FileCopy(SourceName=j3idntfd.png|URLFieldCapLeftPressedButton.png,SourceCabKey=Safari.res ources_URLFieldCapLeftPressedButton.png,DestName=URLFieldCapLeftPressedButton.png,Attribut es=512,FileSize=254,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,Has hOptions=0,HashPart1=1712303345,HashPart2=-790913340,HashPart3=131158079,HashPart4=-179983 5368,,)
                MSI (s) (A4:F8) [11:15:00:015]: File: C:\Program Files\Safari\Safari.resources\URLFieldCapLeftPressedButton.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:15:00:015]: Executing op: FileCopy(SourceName=ov3fiezr.png|URLFieldCapLeftPressedButtonProgress.png,SourceCabKey=Sa fari.resources_URLFieldCapLeftPressedButtonProgress.png,DestName=URLFieldCapLeftPressedBut tonProgress.png,Attributes=512,FileSize=485,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,, InstallMode=59113472,HashOptions=0,HashPart1=366903510,HashPart2=788479552,HashPart3=-1868 299797,HashPart4=896654571,,)
                MSI (s) (A4:F8) [11:15:00:015]: File: C:\Program Files\Safari\Safari.resources\URLFieldCapLeftPressedButtonProgress.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:15:00:015]: Executing op: FileCopy(SourceName=sacgg9-r.png|URLFieldCapLeftProgress.png,SourceCabKey=Safari.resource s_URLFieldCapLeftProgress.png,DestName=URLFieldCapLeftProgress.png,Attributes=512,FileSize =368,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,Hash Part1=1653223104,HashPart2=-225312454,HashPart3=-285903087,HashPart4=-1554768206,,)
                MSI (s) (A4:F8) [11:15:00:015]: File: C:\Program Files\Safari\Safari.resources\URLFieldCapLeftProgress.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:15:00:015]: Executing op: FileCopy(SourceName=8fmaqnsx.png|URLFieldCapLeftRounded.png,SourceCabKey=Safari.resources _URLFieldCapLeftRounded.png,DestName=URLFieldCapLeftRounded.png,Attributes=512,FileSize=37 4,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPar t1=-1516160105,HashPart2=1116272944,HashPart3=260878700,HashPart4=1084541005,,)
                MSI (s) (A4:F8) [11:15:00:015]: File: C:\Program Files\Safari\Safari.resources\URLFieldCapLeftRounded.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:15:00:015]: Executing op: FileCopy(SourceName=sexusos5.png|URLFieldCapLeftRoundedFocused.png,SourceCabKey=Safari.re sources_URLFieldCapLeftRoundedFocused.png,DestName=URLFieldCapLeftRoundedFocused.png,Attri butes=512,FileSize=422,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472, HashOptions=0,HashPart1=944585358,HashPart2=263587634,HashPart3=944573908,HashPart4=-18443 01286,,)
                MSI (s) (A4:F8) [11:15:00:015]: File: C:\Program Files\Safari\Safari.resources\URLFieldCapLeftRoundedFocused.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:15:00:015]: Executing op: FileCopy(SourceName=4tmpimtj.png|URLFieldCapLeftRoundedProgress.png,SourceCabKey=Safari.r esources_URLFieldCapLeftRoundedProgress.png,DestName=URLFieldCapLeftRoundedProgress.png,At tributes=512,FileSize=260,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=591134 72,HashOptions=0,HashPart1=492509314,HashPart2=1987277820,HashPart3=534133809,HashPart4=22 2234609,,)
                MSI (s) (A4:F8) [11:15:00:015]: File: C:\Program Files\Safari\Safari.resources\URLFieldCapLeftRoundedProgress.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:15:00:015]: Executing op: FileCopy(SourceName=q40emxwn.png|URLFieldCapRight.png,SourceCabKey=Safari.resources_URLFi eldCapRight.png,DestName=URLFieldCapRight.png,Attributes=512,FileSize=401,PerTick=32768,,V erifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=-1703413740,Has hPart2=559666751,HashPart3=761778912,HashPart4=392718330,,)
                MSI (s) (A4:F8) [11:15:00:015]: File: C:\Program Files\Safari\Safari.resources\URLFieldCapRight.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:15:00:015]: Executing op: FileCopy(SourceName=m2lvqewd.png|URLFieldCapRightFocused.png,SourceCabKey=Safari.resource s_URLFieldCapRightFocused.png,DestName=URLFieldCapRightFocused.png,Attributes=512,FileSize =456,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,Hash Part1=-381532409,HashPart2=206145971,HashPart3=37038056,HashPart4=-273269643,,)
                MSI (s) (A4:F8) [11:15:00:015]: File: C:\Program Files\Safari\Safari.resources\URLFieldCapRightFocused.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:15:00:031]: Executing op: FileCopy(SourceName=lz32ygxl.png|URLFieldCapRightProgress.png,SourceCabKey=Safari.resourc es_URLFieldCapRightProgress.png,DestName=URLFieldCapRightProgress.png,Attributes=512,FileS ize=323,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,H ashPart1=366593247,HashPart2=-220440789,HashPart3=1169230212,HashPart4=1738943529,,)
                MSI (s) (A4:F8) [11:15:00:031]: File: C:\Program Files\Safari\Safari.resources\URLFieldCapRightProgress.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:15:00:031]: Executing op: FileCopy(SourceName=vk_j_cau.png|URLFieldMiddle.png,SourceCabKey=Safari.resources_URLFiel dMiddle.png,DestName=URLFieldMiddle.png,Attributes=512,FileSize=216,PerTick=32768,,VerifyM edia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=1213347183,HashPart2= 1909484688,HashPart3=-649576667,HashPart4=1295803090,,)
                MSI (s) (A4:F8) [11:15:00:031]: File: C:\Program Files\Safari\Safari.resources\URLFieldMiddle.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:15:00:031]: Executing op: FileCopy(SourceName=qokdhqa7.png|URLFieldMiddleFocused.png,SourceCabKey=Safari.resources_ URLFieldMiddleFocused.png,DestName=URLFieldMiddleFocused.png,Attributes=512,FileSize=230,P erTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1= -233633960,HashPart2=-1155729095,HashPart3=339129769,HashPart4=397668066,,)
                MSI (s) (A4:F8) [11:15:00:031]: File: C:\Program Files\Safari\Safari.resources\URLFieldMiddleFocused.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:15:00:031]: Executing op: FileCopy(SourceName=gpc7-foe.png|URLFieldMiddleProgress.png,SourceCabKey=Safari.resources _URLFieldMiddleProgress.png,DestName=URLFieldMiddleProgress.png,Attributes=512,FileSize=20 3,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPar t1=1885333476,HashPart2=2101265269,HashPart3=-1857073101,HashPart4=-178380552,,)
                MSI (s) (A4:F8) [11:15:00:031]: File: C:\Program Files\Safari\Safari.resources\URLFieldMiddleProgress.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:15:00:031]: Executing op: FileCopy(SourceName=h_xwcd46.pli|UserAgents.plist,SourceCabKey=Safari.resources_UserAgent s.plist,DestName=UserAgents.plist,Attributes=512,FileSize=4393,PerTick=32768,,VerifyMedia= 1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=778206048,HashPart2=-80897 9555,HashPart3=-1550688542,HashPart4=965809278,,)
                MSI (s) (A4:F8) [11:15:00:031]: File: C:\Program Files\Safari\Safari.resources\UserAgents.plist;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:15:00:031]: Executing op: FileCopy(SourceName=ui1m2yvr.js|Utilities.js,SourceCabKey=Safari.resources_Utilities.js,D estName=Utilities.js,Attributes=512,FileSize=16571,PerTick=32768,,VerifyMedia=1,,,,,CheckC RC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=-1337511885,HashPart2=-1179060764,Hash Part3=2060310599,HashPart4=1208153401,,)
                MSI (s) (A4:F8) [11:15:00:031]: File: C:\Program Files\Safari\Safari.resources\Utilities.js;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:15:00:031]: Executing op: FileCopy(SourceName=7itpm8k4.htm|WebAuthenticationSheet.html,SourceCabKey=Safari.resource s_WebAuthenticationSheet.html,DestName=WebAuthenticationSheet.html,Attributes=512,FileSize =2289,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,Has hPart1=1150625424,HashPart2=447620260,HashPart3=-1133844894,HashPart4=687745964,,)
                MSI (s) (A4:F8) [11:15:00:031]: File: C:\Program Files\Safari\Safari.resources\WebAuthenticationSheet.html;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:15:00:031]: Executing op: FileCopy(SourceName=ojy3fgk_.png|WhiteSearchField.png,SourceCabKey=Safari.resources_White SearchField.png,DestName=WhiteSearchField.png,Attributes=512,FileSize=758,PerTick=32768,,V erifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=-915996609,Hash Part2=1719515903,HashPart3=766294892,HashPart4=202421768,,)
                MSI (s) (A4:F8) [11:15:00:031]: File: C:\Program Files\Safari\Safari.resources\WhiteSearchField.png;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:15:00:031]: Executing op: SetTargetFolder(Folder=C:\Program Files\Safari\Safari.resources\zh_CN.lproj\)
                MSI (s) (A4:F8) [11:15:00:031]: Executing op: SetSourceFolder(Folder=1\Safari\mymwmyms\xpzrz3xu\|Safari\Safari.resources\zh_CN.lproj\)
                MSI (s) (A4:F8) [11:15:00:031]: Executing op: FileCopy(SourceName=49oggcey.pli|ABAutoCompleteMappings.plist,SourceCabKey=Safari.resourc es_zh_CN.lproj_ABAutoCompleteMappings.plist,DestName=ABAutoCompleteMappings.plist,Attribut es=512,FileSize=14624,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,H ashOptions=0,HashPart1=824501135,HashPart2=1512278202,HashPart3=-176441411,HashPart4=-2089 426241,,)
                MSI (s) (A4:F8) [11:15:00:031]: File: C:\Program Files\Safari\Safari.resources\zh_CN.lproj\ABAutoCompleteMappings.plist;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:15:00:031]: Executing op: FileCopy(SourceName=ty9-y8fx.pli|BuiltInBookmarks.plist,SourceCabKey=Safari.resources_zh_ CN.lproj_BuiltInBookmarks.plist,DestName=BuiltInBookmarks.plist,Attributes=512,FileSize=83 33,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPa rt1=-248784043,HashPart2=1508827699,HashPart3=-1874125719,HashPart4=-716625364,,)
                MSI (s) (A4:F8) [11:15:00:031]: File: C:\Program Files\Safari\Safari.resources\zh_CN.lproj\BuiltInBookmarks.plist;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:15:00:031]: Executing op: FileCopy(SourceName=piqwntse.str|Localizable.strings,SourceCabKey=Safari.resources_zh_CN. lproj_Localizable.strings,DestName=Localizable.strings,Attributes=512,FileSize=286268,PerT ick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=-16 71968431,HashPart2=1316088328,HashPart3=369103530,HashPart4=157710054,,)
                MSI (s) (A4:F8) [11:15:00:031]: File: C:\Program Files\Safari\Safari.resources\zh_CN.lproj\Localizable.strings;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:15:00:031]: Executing op: FileCopy(SourceName=rfeisxzj.js|localizedStrings.js,SourceCabKey=Safari.resources_zh_CN.l proj_localizedStrings.js,DestName=localizedStrings.js,Attributes=512,FileSize=42954,PerTic k=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=-1826 652148,HashPart2=781302538,HashPart3=-1886004760,HashPart4=-985549747,,)
                MSI (s) (A4:F8) [11:15:00:046]: File: C:\Program Files\Safari\Safari.resources\zh_CN.lproj\localizedStrings.js;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:15:00:046]: Executing op: SetTargetFolder(Folder=C:\Program Files\Safari\Safari.resources\zh_TW.lproj\)
                MSI (s) (A4:F8) [11:15:00:046]: Executing op: SetSourceFolder(Folder=1\Safari\mymwmyms\4c-gpqad\|Safari\Safari.resources\zh_TW.lproj\)
                MSI (s) (A4:F8) [11:15:00:046]: Executing op: FileCopy(SourceName=olvypfl2.pli|ABAutoCompleteMappings.plist,SourceCabKey=Safari.resourc es_zh_TW.lproj_ABAutoCompleteMappings.plist,DestName=ABAutoCompleteMappings.plist,Attribut es=512,FileSize=14914,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,H ashOptions=0,HashPart1=-670989003,HashPart2=-1999093337,HashPart3=-1456675057,HashPart4=-6 95293465,,)
                MSI (s) (A4:F8) [11:15:00:046]: File: C:\Program Files\Safari\Safari.resources\zh_TW.lproj\ABAutoCompleteMappings.plist;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:15:00:046]: Executing op: FileCopy(SourceName=pcwfffre.pli|BuiltInBookmarks.plist,SourceCabKey=Safari.resources_zh_ TW.lproj_BuiltInBookmarks.plist,DestName=BuiltInBookmarks.plist,Attributes=512,FileSize=15 68,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPa rt1=967862595,HashPart2=-639530286,HashPart3=-1098595360,HashPart4=-1430767817,,)
                MSI (s) (A4:F8) [11:15:00:046]: File: C:\Program Files\Safari\Safari.resources\zh_TW.lproj\BuiltInBookmarks.plist;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:15:00:046]: Executing op: FileCopy(SourceName=leqcbkze.str|Localizable.strings,SourceCabKey=Safari.resources_zh_TW. lproj_Localizable.strings,DestName=Localizable.strings,Attributes=512,FileSize=286644,PerT ick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=-11 89782060,HashPart2=-1735293053,HashPart3=813218154,HashPart4=81433414,,)
                MSI (s) (A4:F8) [11:15:00:046]: File: C:\Program Files\Safari\Safari.resources\zh_TW.lproj\Localizable.strings;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:15:00:046]: Executing op: FileCopy(SourceName=doyugwbe.js|localizedStrings.js,SourceCabKey=Safari.resources_zh_TW.l proj_localizedStrings.js,DestName=localizedStrings.js,Attributes=512,FileSize=43362,PerTic k=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=59113472,HashOptions=0,HashPart1=-1452 521969,HashPart2=-276312055,HashPart3=398005140,HashPart4=718291056,,)
                MSI (s) (A4:F8) [11:15:00:046]: File: C:\Program Files\Safari\Safari.resources\zh_TW.lproj\localizedStrings.js;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:15:00:046]: Executing op: SetTargetFolder(Folder=C:\Program Files\Safari\)
                MSI (s) (A4:F8) [11:15:00:046]: Executing op: SetSourceFolder(Folder=1\Safari\)
                MSI (s) (A4:F8) [11:15:00:046]: Executing op: RegisterSharedComponentProvider(,,File=SafariTheme.dll,Component={3072EB84-3EAE-4522-8E44 -C130DBE669F2},ComponentVersion=7534.51.13.16,ProductCode={F2AF3E5D-9697-485C-A5AC-E2B9468 C446A},ProductVersion=5.34.52,PatchSize=0,PatchAttributes=0,PatchSequence=0,SharedComponen t=0,IsFullFile=0)
                MSI (s) (A4:F8) [11:15:00:046]: Executing op: FileCopy(SourceName=ddw_owp1.dll|SafariTheme.dll,SourceCabKey=SafariTheme.dll,DestName=Sa fariTheme.dll,Attributes=512,FileSize=292200,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,V ersion=7534.51.13.16,Language=0,InstallMode=59113472,,,,,,,)
                MSI (s) (A4:F8) [11:15:00:046]: File: C:\Program Files\Safari\SafariTheme.dll;          Won't Overwrite;          Won't patch;          Existing file is of an equal version
                MSI (s) (A4:F8) [11:15:00:046]: Executing op: SetTargetFolder(Folder=C:\Program Files\Safari\SafariTheme.resources\)
                MSI (s) (A4:F8) [11:15:00:046]: Executing op: SetSourceFolder(Folder=1\Safari\hvobnmbo\|Safari\SafariTheme.resources\)
                MSI (s) (A4:F8) [11:15:00:046]: Executing op: FileCopy(SourceName=ArtFile.bin,SourceCabKey=SafariTheme.resources_ArtFile.bin,DestName=A rtFile.bin,Attributes=512,FileSize=5836820,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,I nstallMode=59113472,HashOptions=0,HashPart1=988867657,HashPart2=1296272484,HashPart3=67571 6069,HashPart4=749807512,,)
                MSI (s) (A4:F8) [11:15:00:078]: File: C:\Program Files\Safari\SafariTheme.resources\ArtFile.bin;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:15:00:078]: Executing op: FileCopy(SourceName=42gbu3sq.pli|Info.plist,SourceCabKey=SafariTheme.resources_Info.plist ,DestName=Info.plist,Attributes=512,FileSize=567,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC =0,,,InstallMode=59113472,HashOptions=0,HashPart1=513368925,HashPart2=-1711160389,HashPart 3=-1104827565,HashPart4=-863764445,,)
                MSI (s) (A4:F8) [11:15:00:078]: File: C:\Program Files\Safari\SafariTheme.resources\Info.plist;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:15:00:078]: Executing op: FileCopy(SourceName=SArtFile.bin,SourceCabKey=SafariTheme.resources_SArtFile.bin,DestName =SArtFile.bin,Attributes=512,FileSize=1831880,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0, ,,InstallMode=59113472,HashOptions=0,HashPart1=1124286099,HashPart2=3452069,HashPart3=1460 985041,HashPart4=-1590362663,,)
                MSI (s) (A4:F8) [11:15:00:093]: File: C:\Program Files\Safari\SafariTheme.resources\SArtFile.bin;          Won't Overwrite;          Won't patch;          Existing file is unversioned and unmodified - hash matches source file
                MSI (s) (A4:F8) [11:15:00:093]: Executing op: SetTargetFolder(Folder=C:\Program Files\Safari\)
                MSI (s) (A4:F8) [11:15:00:093]: Executing op: SetSourceFolder(Folder=1\Safari\)
                MSI (s) (A4:F8) [11:15:00:093]: Executing op: RegisterSharedComponentProvider(,,File=Search.dll,Component={0366B5E2-3194-11DC-8314-0800 200C9A66},ComponentVersion=7534.51.13.19,ProductCode={F2AF3E5D-9697-485C-A5AC-E2B9468C446A },ProductVersion=5.34.52,PatchSize=0,PatchAttributes=0,PatchSequence=0,SharedComponent=0,I sFullFile=0)
                MSI (s) (A4:F8) [11:15:00:093]: Executing op: FileCopy(SourceName=Search.dll,SourceCabKey=Search.dll,DestName=Search.dll,Attributes=512 ,FileSize=344424,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,Version=7534.51.13.19,Languag e=0,InstallMode=59113472,,,,,,,)
                MSI (s) (A4:F8) [11:15:00:093]: File: C:\Program Files\Safari\Search.dll;          Won't Overwrite;          Won't patch;          Existing file is of an equal version
                MSI (s) (A4:F8) [11:15:00:093]: Executing op: RegisterSharedComponentProvider(,,File=SpellChecker.dll,Component={79693D8A-3193-11DC-831 4-0800200C9A66},ComponentVersion=7534.51.13.21,ProductCode={F2AF3E5D-9697-485C-A5AC-E2B946 8C446A},ProductVersion=5.34.52,PatchSize=0,PatchAttributes=0,PatchSequence=0,SharedCompone nt=0,IsFullFile=0)
                MSI (s) (A4:F8) [11:15:00:093]: Executing op: FileCopy(SourceName=awijsfit.dll|SpellChecker.dll,SourceCabKey=SpellChecker.dll,DestName= SpellChecker.dll,Attributes=512,FileSize=470888,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC= 0,Version=7534.51.13.21,Language=0,InstallMode=59113472,,,,,,,)
                MSI (s) (A4:F8) [11:15:00:093]: File: C:\Program Files\Safari\SpellChecker.dll;          Won't Overwrite;          Won't patch;          Existing file is of an equal version
                MSI (s) (A4:F8) [11:15:00:093]: Executing op: CacheSizeFlush(,)
                MSI (s) (A4:F8) [11:15:00:093]: Executing op: ActionStart(Name=CreateShortcuts,Description=Creating shortcuts,Template=Shortcut: [1])
                MSI (s) (A4:F8) [11:15:00:093]: Executing op: SetTargetFolder(Folder=23)
                MSI (s) (A4:F8) [11:15:00:093]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs
                MSI (s) (A4:F8) [11:15:00:093]: Executing op: ShortcutCreate(Name=Safari,Feature=Safari,Component={A67196C9-4725-4262-A2ED-41EA9AC05929 }[~]2,,,WorkingDir=C:\Program Files\Safari\,Icon=SafariIco.exe,,,,,,,,)
                MSI (s) (A4:F8) [11:15:00:124]: Verifying accessibility of file: Safari.lnk
                MSI (s) (A4:F8) [11:15:00:171]: Executing op: SetTargetFolder(Folder=25)
                MSI (s) (A4:F8) [11:15:00:187]: SHELL32::SHGetFolderPath returned: C:\Users\Public\Desktop
                MSI (s) (A4:F8) [11:15:00:187]: Executing op: ShortcutCreate(Name=Safari,Feature=Safari,Component={A67196C9-4725-4262-A2ED-41EA9AC05929 }[~]2,,,WorkingDir=C:\Program Files\Safari\,Icon=SafariIco.exe,,,,,,,,)
                MSI (s) (A4:F8) [11:15:00:187]: Verifying accessibility of file: Safari.lnk
                MSI (s) (A4:F8) [11:15:00:187]: Executing op: SetTargetFolder(Folder=C:\Users\Administrator\AppData\Roaming\Microsoft\Internet Explorer\Quick Launch\)
                MSI (s) (A4:F8) [11:15:00:187]: Executing op: ShortcutCreate(Name=Apple Safari,Feature=Safari,Component={A67196C9-4725-4262-A2ED-41EA9AC05929}[~]2,,,WorkingDir=C :\Program Files\Safari\,Icon=SafariIco.exe,,,,,,,,)
                MSI (s) (A4:F8) [11:15:00:202]: Executing op: SetTargetFolder(Folder=23)
                MSI (s) (A4:F8) [11:15:00:202]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs
                MSI (s) (A4:F8) [11:15:00:202]: Executing op: SetTargetFolder(Folder=25)
                MSI (s) (A4:F8) [11:15:00:202]: SHELL32::SHGetFolderPath returned: C:\Users\Public\Desktop
                MSI (s) (A4:F8) [11:15:00:202]: Executing op: SetTargetFolder(Folder=C:\Users\Administrator\AppData\Roaming\Microsoft\Internet Explorer\Quick Launch\)
                MSI (s) (A4:F8) [11:15:00:202]: Executing op: ActionStart(Name=WriteRegistryValues,Description=Writing system registry values,Template=Key: [1], Name: [2], Value: [3])
                MSI (s) (A4:F8) [11:15:00:202]: Executing op: ProgressTotal(Total=51,Type=1,ByteEquivalent=13200)
                MSI (s) (A4:F8) [11:15:00:202]: Executing op: RegOpenKey(Root=-2147483647,Key=SOFTWARE\Apple Computer, Inc.\Safari,,BinaryType=0,)
                MSI (s) (A4:F8) [11:15:00:202]: Executing op: RegAddValue(Name=Shortcuts,Value=1,)
                MSI (s) (A4:F8) [11:15:00:202]: Executing op: RegOpenKey(Root=-2147483646,Key=SOFTWARE\Apple Computer, Inc.\Safari,,BinaryType=0,)
                MSI (s) (A4:F8) [11:15:00:202]: Executing op: RegAddValue(Name=Version,Value=5.34.52.7,)
                MSI (s) (A4:F8) [11:15:00:202]: Executing op: RegAddValue(Name=DefaultBrowser,Value=0,)
                MSI (s) (A4:F8) [11:15:00:202]: Executing op: RegAddValue(Name=InstallDir,Value=C:\Program Files\Safari\,)
                MSI (s) (A4:F8) [11:15:00:202]: Executing op: RegAddValue(Name=BrowserExe,Value=C:\Program Files\Safari\Safari.exe,)
                MSI (s) (A4:F8) [11:15:00:202]: Executing op: RegOpenKey(Root=-2147483646,Key=SOFTWARE\Microsoft\Windows\CurrentVersion\App Paths\Safari.exe,,BinaryType=0,)
                MSI (s) (A4:F8) [11:15:00:202]: Executing op: RegAddValue(,Value=C:\Program Files\Safari\Safari.exe,)
                MSI (s) (A4:F8) [11:15:00:202]: Executing op: RegOpenKey(Root=-2147483646,Key=Software\Classes\SafariHTML,,BinaryType=0,)
                MSI (s) (A4:F8) [11:15:00:202]: Executing op: RegAddValue(,Value=Safari Document,)
                MSI (s) (A4:F8) [11:15:00:202]: Executing op: RegAddValue(Name=FriendlyTypeName,Value=@C:\Program Files\Safari\Safari.resources\SafariRegistry.dll,-10304,)
                MSI (s) (A4:F8) [11:15:00:202]: Executing op: RegOpenKey(Root=-2147483646,Key=Software\Classes\SafariHTML\DefaultIcon,,BinaryType=0,)
                MSI (s) (A4:F8) [11:15:00:202]: Executing op: RegAddValue(,Value=C:\Program Files\Safari\Safari.exe,1,)
                MSI (s) (A4:F8) [11:15:00:202]: Executing op: RegOpenKey(Root=-2147483646,Key=Software\Classes\SafariHTML\shell\open\command,,BinaryTyp e=0,)
                MSI (s) (A4:F8) [11:15:00:202]: Executing op: RegAddValue(,Value="C:\Program Files\Safari\Safari.exe" -url "%1",)
                MSI (s) (A4:F8) [11:15:00:202]: Executing op: RegOpenKey(Root=-2147483646,Key=Software\Classes\SafariURL,,BinaryType=0,)
                MSI (s) (A4:F8) [11:15:00:202]: Executing op: RegAddValue(,Value=Safari URL,)
                MSI (s) (A4:F8) [11:15:00:218]: Executing op: RegAddValue(Name=FriendlyTypeName,Value=@C:\Program Files\Safari\Safari.resources\SafariRegistry.dll,-10305,)
                MSI (s) (A4:F8) [11:15:00:218]: Executing op: RegOpenKey(Root=-2147483646,Key=Software\Classes\SafariURL\DefaultIcon,,BinaryType=0,)
                MSI (s) (A4:F8) [11:15:00:218]: Executing op: RegAddValue(,Value=C:\Program Files\Safari\Safari.exe,1,)
                MSI (s) (A4:F8) [11:15:00:218]: Executing op: RegOpenKey(Root=-2147483646,Key=Software\Classes\SafariURL\shell\open\command,,BinaryType =0,)
                MSI (s) (A4:F8) [11:15:00:218]: Executing op: RegAddValue(,Value="C:\Program Files\Safari\Safari.exe" -url "%1",)
                MSI (s) (A4:F8) [11:15:00:218]: Executing op: RegOpenKey(Root=-2147483646,Key=Software\Classes\SafariDownload,,BinaryType=0,)
                MSI (s) (A4:F8) [11:15:00:218]: Executing op: RegAddValue(,Value=Safari Download,)
                MSI (s) (A4:F8) [11:15:00:218]: Executing op: RegAddValue(Name=FriendlyTypeName,Value=@C:\Program Files\Safari\Safari.resources\SafariRegistry.dll,-10306,)
                MSI (s) (A4:F8) [11:15:00:218]: Executing op: RegOpenKey(Root=-2147483646,Key=Software\Classes\SafariDownload\DefaultIcon,,BinaryType=0 ,)
                MSI (s) (A4:F8) [11:15:00:218]: Executing op: RegOpenKey(Root=-2147483646,Key=Software\Classes\SafariDownload\shell\open\command,,Binar yType=0,)
                MSI (s) (A4:F8) [11:15:00:218]: Executing op: RegOpenKey(Root=-2147483646,Key=Software\Classes\SafariExtension,,BinaryType=0,)
                MSI (s) (A4:F8) [11:15:00:218]: Executing op: RegAddValue(,Value=Safari Extension,)
                MSI (s) (A4:F8) [11:15:00:218]: Executing op: RegOpenKey(Root=-2147483646,Key=Software\Classes\SafariExtension\DefaultIcon,,BinaryType= 0,)
                MSI (s) (A4:F8) [11:15:00:218]: Executing op: RegAddValue(,Value=C:\Program Files\Safari\Safari.exe,4,)
                MSI (s) (A4:F8) [11:15:00:218]: Executing op: RegOpenKey(Root=-2147483646,Key=Software\Classes\SafariExtension\shell\open\command,,Bina ryType=0,)
                MSI (s) (A4:F8) [11:15:00:218]: Executing op: RegOpenKey(Root=-2147483646,Key=Software\Classes\.download,,BinaryType=0,)
                MSI (s) (A4:F8) [11:15:00:218]: Executing op: RegOpenKey(Root=-2147483646,Key=Software\Classes\.safariextz,,BinaryType=0,)
                MSI (s) (A4:F8) [11:15:00:218]: Executing op: RegOpenKey(Root=-2147483646,Key=Software\Classes\.webarchive,,BinaryType=0,)
                MSI (s) (A4:F8) [11:15:00:218]: Executing op: RegAddValue(,Value=Safari Document,)
                MSI (s) (A4:F8) [11:15:00:218]: Executing op: RegOpenKey(Root=-2147483646,Key=Software\Clients\StartMenuInternet\Safari.exe,,BinaryType =0,)
                MSI (s) (A4:F8) [11:15:00:218]: Executing op: RegAddValue(,Value=Safari,)
                MSI (s) (A4:F8) [11:15:00:218]: Executing op: RegAddValue(Name=LocalizedString,Value=@C:\Program Files\Safari\Safari.resources\SafariRegistry.dll,-10307,)
                MSI (s) (A4:F8) [11:15:00:218]: Executing op: RegOpenKey(Root=-2147483646,Key=Software\Clients\StartMenuInternet\Safari.exe\DefaultIcon ,,BinaryType=0,)
                MSI (s) (A4:F8) [11:15:00:218]: Executing op: RegAddValue(,Value=C:\Program Files\Safari\Safari.exe,0,)
                MSI (s) (A4:F8) [11:15:00:218]: Executing op: RegOpenKey(Root=-2147483646,Key=Software\Clients\StartMenuInternet\Safari.exe\shell\open\ command,,BinaryType=0,)
                MSI (s) (A4:F8) [11:15:00:218]: Executing op: RegAddValue(,Value="C:\Program Files\Safari\Safari.exe",)
                MSI (s) (A4:F8) [11:15:00:218]: Executing op: RegOpenKey(Root=-2147483646,Key=Software\Clients\StartMenuInternet\Safari.exe\InstallInfo ,,BinaryType=0,)
                MSI (s) (A4:F8) [11:15:00:218]: Executing op: RegAddValue(Name=ReinstallCommand,Value="C:\Program Files\Safari\Safari.exe" /reinstall,)
                MSI (s) (A4:F8) [11:15:00:218]: Executing op: RegAddValue(Name=HideIconsCommand,Value="C:\Program Files\Safari\Safari.exe" /hideicons,)
                MSI (s) (A4:F8) [11:15:00:218]: Executing op: RegAddValue(Name=ShowIconsCommand,Value="C:\Program Files\Safari\Safari.exe" /showicons,)
                MSI (s) (A4:F8) [11:15:00:218]: Executing op: RegAddValue(Name=IconsVisible,Value=#1,)
                MSI (s) (A4:F8) [11:15:00:218]: Executing op: RegOpenKey(Root=-2147483646,Key=Software\Clients\StartMenuInternet\Safari.exe\Capabilitie s,,BinaryType=0,)
                MSI (s) (A4:F8) [11:15:00:218]: Executing op: RegAddValue(Name=ApplicationDescription,Value=@C:\Program Files\Safari\Safari.resources\SafariRegistry.dll,-10308,)
                MSI (s) (A4:F8) [11:15:00:218]: Executing op: RegAddValue(Name=ApplicationIcon,Value=C:\Program Files\Safari\Safari.exe,0,)
                MSI (s) (A4:F8) [11:15:00:218]: Executing op: RegAddValue(Name=ApplicationName,Value=Safari,)
                MSI (s) (A4:F8) [11:15:00:218]: Executing op: RegOpenKey(Root=-2147483646,Key=Software\Clients\StartMenuInternet\Safari.exe\Capabilitie s\FileAssociations,,BinaryType=0,)
                MSI (s) (A4:F8) [11:15:00:218]: Executing op: RegAddValue(Name=.htm,Value=SafariHTML,)
                MSI (s) (A4:F8) [11:15:00:234]: Executing op: RegAddValue(Name=.html,Value=SafariHTML,)
                MSI (s) (A4:F8) [11:15:00:234]: Executing op: RegAddValue(Name=.shtml,Value=SafariHTML,)
                MSI (s) (A4:F8) [11:15:00:234]: Executing op: RegAddValue(Name=.xht,Value=SafariHTML,)
                MSI (s) (A4:F8) [11:15:00:234]: Executing op: RegAddValue(Name=.xhtml,Value=SafariHTML,)
                MSI (s) (A4:F8) [11:15:00:234]: Executing op: RegAddValue(Name=.svg,Value=SafariHTML,)
                MSI (s) (A4:F8) [11:15:00:234]: Executing op: RegAddValue(Name=.xml,Value=SafariHTML,)
                MSI (s) (A4:F8) [11:15:00:234]: Executing op: RegAddValue(Name=.webarchive,Value=SafariHTML,)
                MSI (s) (A4:F8) [11:15:00:234]: Executing op: RegAddValue(Name=.download,Value=SafariDownload,)
                MSI (s) (A4:F8) [11:15:00:234]: Executing op: RegAddValue(Name=.safariextz,Value=SafariExtension,)
                MSI (s) (A4:F8) [11:15:00:234]: Executing op: RegOpenKey(Root=-2147483646,Key=Software\Clients\StartMenuInternet\Safari.exe\Capabilitie s\StartMenu,,BinaryType=0,)
                MSI (s) (A4:F8) [11:15:00:234]: Executing op: RegAddValue(Name=StartMenuInternet,Value=Safari.exe,)
                MSI (s) (A4:F8) [11:15:00:234]: Executing op: RegOpenKey(Root=-2147483646,Key=Software\Clients\StartMenuInternet\Safari.exe\Capabilitie s\URLAssociations,,BinaryType=0,)
                MSI (s) (A4:F8) [11:15:00:234]: Executing op: RegAddValue(Name=http,Value=SafariURL,)
                MSI (s) (A4:F8) [11:15:00:234]: Executing op: RegAddValue(Name=https,Value=SafariURL,)
                MSI (s) (A4:F8) [11:15:00:234]: Executing op: RegOpenKey(Root=-2147483646,Key=Software\RegisteredApplications,,BinaryType=0,)
                MSI (s) (A4:F8) [11:15:00:234]: Executing op: RegAddValue(Name=Safari,Value=Software\Clients\StartMenuInternet\Safari.exe\Capabilities, )
                MSI (s) (A4:F8) [11:15:00:234]: Executing op: ActionStart(Name=RegisterProduct,Description=Registering product,Template=[1])
                MSI (s) (A4:F8) [11:15:00:234]: Executing op: UpdateEstimatedSize(EstimatedSize=0)
                MSI (s) (A4:F8) [11:15:00:234]: Executing op: ProductCPDisplayInfoRegister()
                MSI (s) (A4:F8) [11:15:00:234]: Executing op: ActionStart(Name=PublishFeatures,Description=Publishing Product Features,Template=Feature: [1])
                MSI (s) (A4:F8) [11:15:00:234]: Executing op: FeaturePublish(Feature=Safari,,Absent=2,Component=_.j!igTCy8Rr.PSwsWtOb^Njrib9h(KhSFl+$wk RGl9zyB93c8mD,WJmgHIf%}v*$,-wg(s@r!!U.{{H!Mn$O+-wg(s@r!!U.{{HKx'R^5NUD96o`@t[O`@1yYv6!9@wg (s@r!!U.{{HJ7lcOxzw0A{XXaL{7ADt7RXX3~x`6=B2xa3G=PvvLt{riN]b?9I$S}^3BZqt}blNFTTpc=d=Y$yKMof G1)7$M%vdp?`]B_G=394=g)t%1s[Hh(9wL,_,lVnY8.=aTN)1_8Tq],PO,w]tG$&I*$sZB9LI^dU?POaTG5rXs,y6j =Jq5'&el7EuWFYt7s[Hh(l610_,lVnYMrm}b2Hc3=zu~wfvZNZ2s@Kd8?f-K=^bI,LOGdMubP?T=s[Hh(?+R0_,lVn Ya=0?Oj_~k?_N{,A]b4{%_l2fRc)uz?[+Im+D(X59hU[v&HLUx8ae')OsSg%@!)Rr%l&}f8[U4$wSRY7ep=J.wdpHj 8Pvk=I*?'IkM}GgkxHc`AH`4KsPd`MTuF~_NetbT?=^U_8yH=DH^,U~d{yzJ=PTi3^^*JcXl0D~f]4Au?$c(`i*}U& YbloyMkXVY=kMGB43Y5@Cm0o$ocRC@9ka$,sUOnFNeHllT5.,99=_Ae%WbxlBcVim9Z]8$@Gihdk3ck*,+~~4ZD~Jh (3SrmU,lVnYw)}hm=Xhl8-%38]Eso-+Jl5-tR2.b@,UK~X(n6U+B.rvXlJPd?*eQtsaYYVDSJ3AXYc(M@XV~qg7Fbw )1`g,{1'9a=XL,UqsoTP+u9z`u0L-t=0UARUQq{Xk)gecb+[Y2AHrUo6-rP)=]ok&yIE`HAZ!^zS$ecMK_11)8n$6N ==py]?7y&{?HFuad+GYg=H1uL!GsM&6qaRngj%4v8T]H%KuymtexpHtl^Z)k=InozEoxK6H2ELTU$`A9=QrII6^s^] Zl8{JloQx=93v0`b2`TVvF]8'4LxS9=@pYoyd$W@UNDQ=[t0z2=m7J]ATbCI&LY1
                MSI (s) (A4:F8) [11:15:00:234]: Executing op: ActionStart(Name=PublishProduct,Description=Publishing product information,)
                MSI (s) (A4:F8) [11:15:00:234]: Executing op: IconCreate(Icon=Installer.ico,Data=BinaryData)
                MSI (s) (A4:F8) [11:15:00:265]: Verifying accessibility of file: Installer.ico
                MSI (s) (A4:F8) [11:15:00:280]: Executing op: IconCreate(Icon=SafariIco.exe,Data=BinaryData)
                MSI (s) (A4:F8) [11:15:00:280]: Verifying accessibility of file: SafariIco.exe
                MSI (s) (A4:F8) [11:15:00:280]: Executing op: CleanupConfigData()
                MSI (s) (A4:F8) [11:15:00:280]: Executing op: RegisterPatchOrder(Continue=0,SequenceType=1,Remove=0)
                MSI (s) (A4:F8) [11:15:00:296]: Executing op: End(Checksum=0,ProgressTotalHDWord=0,ProgressTotalLDWord=13934400)
                MSI (s) (A4:F8) [11:15:00:296]: User policy value 'DisableRollback' is 0
                MSI (s) (A4:F8) [11:15:00:296]: Machine policy value 'DisableRollback' is 0
                MSI (s) (A4:F8) [11:15:00:374]: No System Restore sequence number for this installation.
                MSI (s) (A4:F8) [11:15:00:374]: Unlocking Server
                MSI (s) (A4:F8) [11:15:01:170]: PROPERTY CHANGE: Deleting UpdateStarted property. Its current value is '1'.
                MSI (c) (08:44) [11:15:00:889]: Machine policy value 'DisableUserInstalls' is 0
                MSI (s) (A4:F8) [11:15:04:680]: Doing action: RemoveExistingProducts
                Action ended 11:15:01: InstallFinalize. Return value 1.
                MSI (s) (A4:F8) [11:15:04:680]: Skipping RemoveExistingProducts action: current configuration is maintenance mode or an uninstall
                Action start 11:15:04: RemoveExistingProducts.
                Action ended 11:15:04: RemoveExistingProducts. Return value 0.
                Action ended 11:15:04: INSTALL. Return value 1.
                Property(S): UpgradeCode = {B1361399-30C9-4921-8890-C13474531EED}
                Property(S): EXISTINGINSTALLDIR = C:\Program Files\Safari\
                Property(S): REGSRCH_DESKTOP_SHORTCUTS = 1
                Property(S): REGSRCH_DEFAULT_BROWSER = 0
                Property(S): ChkOptShortcuts = 1
                Property(S): ChkOptBonjour = 1
                Property(S): ChkOptASU = 1
                Property(S): INSTALLDIR = C:\Program Files\Safari\
                Property(S): PluginsFolder = C:\Program Files\Safari\Plugins\
                Property(S): DesktopFolder = C:\Users\Public\Desktop\
                Property(S): INSTALLERCACHE = C:\ProgramData\Apple Computer\Installer Cache\Safari 5.34.52.7\
                Property(S): Safari.resources = C:\Program Files\Safari\Safari.resources\
                Property(S): Safari.resources_BookmarkChooser = C:\Program Files\Safari\Safari.resources\BookmarkChooser\
                Property(S): Safari.resources_da.lproj = C:\Program Files\Safari\Safari.resources\da.lproj\
                Property(S): Safari.resources_de.lproj = C:\Program Files\Safari\Safari.resources\de.lproj\
                Property(S): Safari.resources_en.lproj = C:\Program Files\Safari\Safari.resources\en.lproj\
                Property(S): Safari.resources_en_AU.lproj = C:\Program Files\Safari\Safari.resources\en_AU.lproj\
                Property(S): Safari.resources_en_CA.lproj = C:\Program Files\Safari\Safari.resources\en_CA.lproj\
                Property(S): Safari.resources_en_GB.lproj = C:\Program Files\Safari\Safari.resources\en_GB.lproj\
                Property(S): Safari.resources_es.lproj = C:\Program Files\Safari\Safari.resources\es.lproj\
                Property(S): Safari.resources_fi.lproj = C:\Program Files\Safari\Safari.resources\fi.lproj\
                Property(S): Safari.resources_fr.lproj = C:\Program Files\Safari\Safari.resources\fr.lproj\
                Property(S): Safari.resources_Help = C:\Program Files\Safari\Safari.resources\Help\
                Property(S): Safari.resources_Help_da.lproj = C:\Program Files\Safari\Safari.resources\Help\da.lproj\
                Property(S): Safari.resources_Help_de.lproj = C:\Program Files\Safari\Safari.resources\Help\de.lproj\
                Property(S): Safari.resources_Help_en.lproj = C:\Program Files\Safari\Safari.resources\Help\en.lproj\
                Property(S): Safari.resources_Help_es.lproj = C:\Program Files\Safari\Safari.resources\Help\es.lproj\
                Property(S): Safari.resources_Help_fi.lproj = C:\Program Files\Safari\Safari.resources\Help\fi.lproj\
                Property(S): Safari.resources_Help_fr.lproj = C:\Program Files\Safari\Safari.resources\Help\fr.lproj\
                Property(S): Safari.resources_Help_it.lproj = C:\Program Files\Safari\Safari.resources\Help\it.lproj\
                Property(S): Safari.resources_Help_ja.lproj = C:\Program Files\Safari\Safari.resources\Help\ja.lproj\
                Property(S): Safari.resources_Help_ko.lproj = C:\Program Files\Safari\Safari.resources\Help\ko.lproj\
                Property(S): Safari.resources_Help_nb.lproj = C:\Program Files\Safari\Safari.resources\Help\nb.lproj\
                Property(S): Safari.resources_Help_nl.lproj = C:\Program Files\Safari\Safari.resources\Help\nl.lproj\
                Property(S): Safari.resources_Help_pl.lproj = C:\Program Files\Safari\Safari.resources\Help\pl.lproj\
                Property(S): Safari.resources_Help_pt.lproj = C:\Program Files\Safari\Safari.resources\Help\pt.lproj\
                Property(S): Safari.resources_Help_pt_PT.lproj = C:\Program Files\Safari\Safari.resources\Help\pt_PT.lproj\
                Property(S): Safari.resources_Help_ru.lproj = C:\Program Files\Safari\Safari.resources\Help\ru.lproj\
                Property(S): Safari.resources_Help_sv.lproj = C:\Program Files\Safari\Safari.resources\Help\sv.lproj\
                Property(S): Safari.resources_Help_zh_CN.lproj = C:\Program Files\Safari\Safari.resources\Help\zh_CN.lproj\
                Property(S): Safari.resources_Help_zh_TW.lproj = C:\Program Files\Safari\Safari.resources\Help\zh_TW.lproj\
                Property(S): Safari.resources_it.lproj = C:\Program Files\Safari\Safari.resources\it.lproj\
                Property(S): Safari.resources_ja.lproj = C:\Program Files\Safari\Safari.resources\ja.lproj\
                Property(S): Safari.resources_ko.lproj = C:\Program Files\Safari\Safari.resources\ko.lproj\
                Property(S): Safari.resources_nb.lproj = C:\Program Files\Safari\Safari.resources\nb.lproj\
                Property(S): Safari.resources_nl.lproj = C:\Program Files\Safari\Safari.resources\nl.lproj\
                Property(S): Safari.resources_pl.lproj = C:\Program Files\Safari\Safari.resources\pl.lproj\
                Property(S): Safari.resources_pt.lproj = C:\Program Files\Safari\Safari.resources\pt.lproj\
                Property(S): Safari.resources_pt_PT.lproj = C:\Program Files\Safari\Safari.resources\pt_PT.lproj\
                Property(S): Safari.resources_ru.lproj = C:\Program Files\Safari\Safari.resources\ru.lproj\
                Property(S): Safari.resources_SnippetEditor = C:\Program Files\Safari\Safari.resources\SnippetEditor\
                Property(S): Safari.resources_SnippetEditor_Images = C:\Program Files\Safari\Safari.resources\SnippetEditor\Images\
                Property(S): Safari.resources_sv.lproj = C:\Program Files\Safari\Safari.resources\sv.lproj\
                Property(S): Safari.resources_zh_CN.lproj = C:\Program Files\Safari\Safari.resources\zh_CN.lproj\
                Property(S): Safari.resources_zh_TW.lproj = C:\Program Files\Safari\Safari.resources\zh_TW.lproj\
                Property(S): SafariTheme.resources = C:\Program Files\Safari\SafariTheme.resources\
                Property(S): PubSub.resources = C:\Program Files\Safari\PubSub.resources\
                Property(S): PubSub.resources_da.lproj = C:\Program Files\Safari\PubSub.resources\da.lproj\
                Property(S): PubSub.resources_de.lproj = C:\Program Files\Safari\PubSub.resources\de.lproj\
                Property(S): PubSub.resources_English.lproj = C:\Program Files\Safari\PubSub.resources\English.lproj\
                Property(S): PubSub.resources_es.lproj = C:\Program Files\Safari\PubSub.resources\es.lproj\
                Property(S): PubSub.resources_fi.lproj = C:\Program Files\Safari\PubSub.resources\fi.lproj\
                Property(S): PubSub.resources_fr.lproj = C:\Program Files\Safari\PubSub.resources\fr.lproj\
                Property(S): PubSub.resources_Framework = C:\Program Files\Safari\PubSub.resources\Framework\
                Property(S): PubSub.resources_Framework_da.lproj = C:\Program Files\Safari\PubSub.resources\Framework\da.lproj\
                Property(S): PubSub.resources_Framework_de.lproj = C:\Program Files\Safari\PubSub.resources\Framework\de.lproj\
                Property(S): PubSub.resources_Framework_English.lproj = C:\Program Files\Safari\PubSub.resources\Framework\English.lproj\
                Property(S): PubSub.resources_Framework_es.lproj = C:\Program Files\Safari\PubSub.resources\Framework\es.lproj\
                Property(S): PubSub.resources_Framework_fi.lproj = C:\Program Files\Safari\PubSub.resources\Framework\fi.lproj\
                Property(S): PubSub.resources_Framework_fr.lproj = C:\Program Files\Safari\PubSub.resources\Framework\fr.lproj\
                Property(S): PubSub.resources_Framework_it.lproj = C:\Program Files\Safari\PubSub.resources\Framework\it.lproj\
                Property(S): PubSub.resources_Framework_ja.lproj = C:\Program Files\Safari\PubSub.resources\Framework\ja.lproj\
                Property(S): PubSub.resources_Framework_ko.lproj = C:\Program Files\Safari\PubSub.resources\Framework\ko.lproj\
                Property(S): PubSub.resources_Framework_nb.lproj = C:\Program Files\Safari\PubSub.resources\Framework\nb.lproj\
                Property(S): PubSub.resources_Framework_nl.lproj = C:\Program Files\Safari\PubSub.resources\Framework\nl.lproj\
                Property(S): PubSub.resources_Framework_pl.lproj = C:\Program Files\Safari\PubSub.resources\Framework\pl.lproj\
                Property(S): PubSub.resources_Framework_pt.lproj = C:\Program Files\Safari\PubSub.resources\Framework\pt.lproj\
                Property(S): PubSub.resources_Framework_pt_PT.lproj = C:\Program Files\Safari\PubSub.resources\Framework\pt_PT.lproj\
                Property(S): PubSub.resources_Framework_ru.lproj = C:\Program Files\Safari\PubSub.resources\Framework\ru.lproj\
                Property(S): PubSub.resources_Framework_sv.lproj = C:\Program Files\Safari\PubSub.resources\Framework\sv.lproj\
                Property(S): PubSub.resources_Framework_zh_CN.lproj = C:\Program Files\Safari\PubSub.resources\Framework\zh_CN.lproj\
                Property(S): PubSub.resources_Framework_zh_TW.lproj = C:\Program Files\Safari\PubSub.resources\Framework\zh_TW.lproj\
                Property(S): PubSub.resources_it.lproj = C:\Program Files\Safari\PubSub.resources\it.lproj\
                Property(S): PubSub.resources_ja.lproj = C:\Program Files\Safari\PubSub.resources\ja.lproj\
                Property(S): PubSub.resources_ko.lproj = C:\Program Files\Safari\PubSub.resources\ko.lproj\
                Property(S): PubSub.resources_nb.lproj = C:\Program Files\Safari\PubSub.resources\nb.lproj\
                Property(S): PubSub.resources_nl.lproj = C:\Program Files\Safari\PubSub.resources\nl.lproj\
                Property(S): PubSub.resources_pl.lproj = C:\Program Files\Safari\PubSub.resources\pl.lproj\
                Property(S): PubSub.resources_pt.lproj = C:\Program Files\Safari\PubSub.resources\pt.lproj\
                Property(S): PubSub.resources_pt_PT.lproj = C:\Program Files\Safari\PubSub.resources\pt_PT.lproj\
                Property(S): PubSub.resources_ru.lproj = C:\Program Files\Safari\PubSub.resources\ru.lproj\
                Property(S): PubSub.resources_sv.lproj = C:\Program Files\Safari\PubSub.resources\sv.lproj\
                Property(S): PubSub.resources_zh_CN.lproj = C:\Program Files\Safari\PubSub.resources\zh_CN.lproj\
                Property(S): PubSub.resources_zh_TW.lproj = C:\Program Files\Safari\PubSub.resources\zh_TW.lproj\
                Property(S): IAcceptLicense = No
                Property(S): RestartManagerOption = 1
                Property(S): ARPNOCHANGE = 1
                Property(S): Installed = 00:00:00
                Property(S): DESKTOP_SHORTCUTS = 1
                Property(S): DEFAULT_BROWSER = 0
                Property(S): ProgressType = install
                Property(S): SafariFolder = C:\Program Files\Safari\
                Property(S): ProgramFilesFolder = C:\Program Files\
                Property(S): TARGETDIR = C:\
                Property(S): QuickLaunchFolder = C:\Users\Administrator\AppData\Roaming\Microsoft\Internet Explorer\Quick Launch\
                Property(S): InternetExplorerAppDataFolder = C:\Users\Administrator\AppData\Roaming\Microsoft\Internet Explorer\
                Property(S): MicrosoftAppDataFolder = C:\Users\Administrator\AppData\Roaming\Microsoft\
                Property(S): AppDataFolder = C:\Users\Administrator\AppData\Roaming\
                Property(S): CachedInstallationsFolder = C:\ProgramData\Apple Computer\Installer Cache\
                Property(S): AppleCommonAppDataFolder = C:\ProgramData\Apple Computer\
                Property(S): CommonAppDataFolder = C:\ProgramData\
                Property(S): SafariProgramMenuFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Safari\
                Property(S): ProgramMenuFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\
                Property(S): Privileged = 1
                Property(S): Manufacturer = Apple Inc.
                Property(S): ProductCode = {F2AF3E5D-9697-485C-A5AC-E2B9468C446A}
                Property(S): ProductLanguage = 1033
                Property(S): ProductName = Safari
                Property(S): ProductVersion = 5.34.52.7
                Property(S): ALLUSERS = 1
                Property(S): ARPCONTACT = AppleCare Support
                Property(S): ARPHELPLINK = http://www.apple.com/support/
                Property(S): ARPHELPTELEPHONE = 1-800-275-2273
                Property(S): ARPPRODUCTICON = Installer.ico
                Property(S): ARPURLINFOABOUT = http://www.apple.com/
                Property(S): ARPURLUPDATEINFO = http://www.apple.com/
                Property(S): PRIMARYFOLDER = INSTALLDIR
                Property(S): SCHEDULE_ASUW = 1
                Property(S): caPackageExeName = SetupAdmin.exe
                Property(S): ErrorDialog = SetupError
                Property(S): DefaultUIFont = Tahoma8
                Property(S): AdminProperties = DEFAULT_BROWSER;DESKTOP_SHORTCUTS
                Property(S): SecureCustomProperties = APPLEAPPLICATIONSUPPORTISINSTALLED;ARPNOCHANGE;ASUWISINSTALLED;ASUWISLATEST;BNEWERPRODUCT ISINSTALLED;BONJOURISINSTALLED;BONJOURISLATEST;DEFAULT_BROWSER;DESKTOP_SHORTCUTS;EXISTINGI NSTALLDIR;INSTALLDIR;REGSRCH_DEFAULT_BROWSER;REGSRCH_DESKTOP_SHORTCUTS;SCHEDULE_ASUW;UPGRA DEFOUND
                Property(S): MsiLogFileLocation = C:\Users\ADMINI~1\AppData\Local\Temp\MSI1f7c6.LOG
                Property(S): PackageCode = {5EAA9433-59D8-45B3-AA81-B816484562B1}
                Property(S): ProductState = 5
                Property(S): ProductToBeRegistered = 1
                Property(S): REINSTALL = Safari
                Property(S): REINSTALLMODE = pocmus
                Property(S): CURRENTDIRECTORY = C:\Windows\system32
                Property(S): CLIENTUILEVEL = 2
                Property(S): CLIENTPROCESSID = 3080
                Property(S): PRODUCTLANGUAGE = 1033
                Property(S): MsiSystemRebootPending = 1
                Property(S): VersionDatabase = 300
                Property(S): VersionMsi = 4.05
                Property(S): VersionNT = 600
                Property(S): WindowsBuild = 6002
                Property(S): ServicePackLevel = 2
                Property(S): ServicePackLevelMinor = 0
                Property(S): MsiNTProductType = 1
                Property(S): WindowsFolder = C:\Windows\
                Property(S): WindowsVolume = C:\
                Property(S): SystemFolder = C:\Windows\system32\
                Property(S): System16Folder = C:\Windows\system\
                Property(S): RemoteAdminTS = 1
                Property(S): TempFolder = C:\Users\ADMINI~1\AppData\Local\Temp\
                Property(S): CommonFilesFolder = C:\Program Files\Common Files\
                Property(S): FavoritesFolder = C:\Users\Administrator\Favorites\
                Property(S): NetHoodFolder = C:\Users\Administrator\AppData\Roaming\Microsoft\Windows\Network Shortcuts\
                Property(S): PersonalFolder = C:\Users\Administrator\Documents\
                Property(S): PrintHoodFolder = C:\Users\Administrator\AppData\Roaming\Microsoft\Windows\Printer Shortcuts\
                Property(S): RecentFolder = C:\Users\Administrator\AppData\Roaming\Microsoft\Windows\Recent\
                Property(S): SendToFolder = C:\Users\Administrator\AppData\Roaming\Microsoft\Windows\SendTo\
                Property(S): TemplateFolder = C:\ProgramData\Microsoft\Windows\Templates\
                Property(S): LocalAppDataFolder = C:\Users\Administrator\AppData\Local\
                Property(S): MyPicturesFolder = C:\Users\Administrator\Pictures\
                Property(S): AdminToolsFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools\
                Property(S): StartupFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup\
                Property(S): StartMenuFolder = C:\ProgramData\Microsoft\Windows\Start Menu\
                Property(S): FontsFolder = C:\Windows\Fonts\
                Property(S): GPTSupport = 1
                Property(S): OLEAdvtSupport = 1
                Property(S): ShellAdvtSupport = 1
                Property(S): Intel = 6
                Property(S): PhysicalMemory = 3326
                Property(S): VirtualMemory = 6149
                Property(S): AdminUser = 1
                Property(S): LogonUser = Administrator
                Property(S): UserSID = S-1-5-21-1259270178-3741367601-327141441-500
                Property(S): UserLanguageID = 1033
                Property(S): ComputerName = ADMIN-PC
                Property(S): SystemLanguageID = 1033
                Property(S): ScreenX = 1024
                Property(S): ScreenY = 768
                Property(S): CaptionHeight = 20
                Property(S): BorderTop = 1
                Property(S): BorderSide = 1
                Property(S): TextHeight = 16
                Property(S): TextInternalLeading = 3
                Property(S): ColorBits = 32
                Property(S): TTCSupport = 1
                Property(S): Time = 11:15:04
                Property(S): Date = 10/27/2012
                Property(S): MsiNetAssemblySupport = 4.0.30319.1
                Property(S): MsiWin32AssemblySupport = 6.0.6001.18000
                Property(S): RedirectedDllSupport = 2
                Property(S): MsiRunningElevated = 1
                Property(S): USERNAME = admin
                Property(S): DATABASE = C:\Windows\Installer\1ff4ad05.msi
                Property(S): UILevel = 3
                Property(S): OriginalDatabase = C:\Windows\Installer\1ff4ad05.msi
                Property(S): Preselected = 1
                Property(S): ACTION = INSTALL
                Property(S): ROOTDRIVE = C:\
                Property(S): CostingComplete = 1
                Property(S): OutOfDiskSpace = 0
                Property(S): OutOfNoRbDiskSpace = 0
                Property(S): PrimaryVolumeSpaceAvailable = 17291608
                Property(S): PrimaryVolumeSpaceRequired = 224
                Property(S): PrimaryVolumeSpaceRemaining = 17291384
                Property(S): INSTALLLEVEL = 1
                Property(S): PrimaryVolumePath = C:
                MSI (s) (A4:F8) [11:15:04:742]: Note: 1: 1728
                MSI (s) (A4:F8) [11:15:04:742]: Product: Safari -- Configuration completed successfully.
                MSI (s) (A4:F8) [11:15:05:538]: Windows Installer reconfigured the product. Product Name: Safari. Product Version: 5.34.52.7. Product Language: 1033. Reconfiguration success or error status: 0.
                MSI (s) (A4:F8) [11:15:05:538]: Deferring clean up of packages/files, if any exist
                MSI (s) (A4:F8) [11:15:05:538]: MainEngineThread is returning 0
                MSI (s) (A4:E4) [11:15:05:538]: RESTART MANAGER: Session closed.
                MSI (s) (A4:E4) [11:15:05:538]: No System Restore sequence number for this installation.
                === Logging stopped: 10/27/2012  11:15:04 ===
                MSI (s) (A4:E4) [11:15:05:538]: User policy value 'DisableRollback' is 0
                MSI (s) (A4:E4) [11:15:05:538]: Machine policy value 'DisableRollback' is 0
                MSI (s) (A4:E4) [11:15:05:538]: Incrementing counter to disable shutdown. Counter after increment: 0
                MSI (s) (A4:E4) [11:15:05:538]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Installer\Rollback\Scripts 3: 2
                MSI (s) (A4:E4) [11:15:05:538]: Decrementing counter to disable shutdown. If counter >= 0, shutdown will be denied.  Counter after decrement: -1
                MSI (s) (A4:E4) [11:15:05:538]: Restoring environment variables
                MSI (s) (A4:E4) [11:15:05:553]: Destroying RemoteAPI object.
                MSI (s) (A4:BC) [11:15:05:553]: Custom Action Manager thread ending.
                MSI (c) (08:4C) [11:15:05:553]: Decrementing counter to disable shutdown. If counter >= 0, shutdown will be denied.  Counter after decrement: -1
                MSI (c) (08:4C) [11:15:05:553]: MainEngineThread is returning 0
                === Verbose logging stopped: 10/27/2012  11:15:05 ===
                • 6. Re: Trouble Installing Edge Inspect on PC
                  Mark_Rausch Adobe Employee
                  Hi MoonTahoe1,
                  Based on a quick scan of this log file data, it looks like this log file is from installing Safari, not Edge Inspect:
                  MSI (s) (A4:F8) [11:13:54:558]: Package name retrieved from configuration data: 'Safari.msi'
