5 Replies Latest reply on Oct 31, 2012 11:33 AM by Peter Grainge
    Merged Webhelp
    Pam Harrison
      My TOC is not appearing when I generate merged webhelp (javascript void).  It did previously.  All looks good in parent and children output views.
        • 1. Re: Merged Webhelp
          @Pam
          Welcome aboard.
          Do you mean the TOC panel appears with nothing in it rather than you don't get the panel? I am guessing the answer to that is yes.
          Have you tried in more than one browser?
          Are you generating all the outputs to a local drive? (I emphasise Generating rather than Publishing)
          What version of Rh?
          You say "previously". Previous to what, an upgrade, a change of content?
          Kind regards.
          @petergrainge
          • 2. Re: Merged Webhelp
            Pam Harrison Level 1
            Hi Peter - it's actually Beth but I somehow logged on under Pam's name! Anyway, yes, I do not get the TOC panel, but the index, glossary and other customized tabs work find.  I have tried in more than one browser and I am generating (not publishing) the output to a general drive.  I am using RH 10.  When I say previously, I mean change of content.  It worked fine before when generating and now the TOC does not appear.
            • 3. Re: Merged Webhelp
              I knew you two were close but borrowing each other's dresses...
              I want to be clear. You don't get the panel or you get the panel and it is blank? Do you get the TOC button?
              Is it possible that the default language somehow got changed in one of the projects?
              Have you upgraded Rh since last time and what version are you using?
              If none of those get us anywhere, perhaps we can do a screenshare. What time zone are you in?
              @petergrainge
              • 4. Re: Merged Webhelp
                Hi Peter. I finally figured it out. To clarify, the webhelp appeared correctly with the all of the navigational buttons including the TOC, but the TOC did not populate. On the bottom left there was an error message Java Script Void.  However, after scrutinizing all of the children I realized that the first child had a TOC identified in the webhelp layout content categories that was not the default TOC.  I changed that, reran the webhelp and it the merged TOC then populated.  Thank you for your time!
                • 5. Re: Merged Webhelp
                  You should be able to select any TOC but if it is working to your satisfaction, that's good enough.
                  @petergrainge
