I need some help hiding/showing content based on the user's login. I use a simple database with roles.
I need to hide some of the content unless the user is an admin. ARGG!!! I can't figure this out, I can find code
for PHP and ASP.NET but not for ASP.
Any help would be a life-saver at this point or at least make my weekend!
Crystal
You don't mention what language you are using but the concept is the same regardless. You test the variable to determine if the user is an admin and then display the appropriate html if they are. Psuedocode example
<If user = 'admin' >
<p> You are an admin</p>
<else>
<p> You are NOT an admin</p>
<end if>
