1 Reply Latest reply on Oct 27, 2012 4:20 PM by jg716
    AIR for desktop and multiple swfs
    jbach2
      I know when packaging AIR for mobile devices, you can load external swfs as long as they contain no code, but I was wondering if the same limitation exists for AIR on the desktop.
      Building a kiosk application and would like to organize and load the various 'views' similar to how I would create and organize a flash based web application.
        • 1. Re: AIR for desktop and multiple swfs
          jg716 Level 1
          Hi jbach...
          In AIR for desktop, you can definitely load external swfs and they can contain code (works on Android also).
          There's a in-depth discussion of how to accomplish this here:
          http://blogs.adobe.com/cantrell/archives/2010/03/extending_air_applications_with_plugins.h tml
          This article talks about security considerations, etc - and is worth understanding.
          However, if you want to just test it out without worrying about security:
          var stream:FileStream = new FileStream();
          stream.open(_file, FileMode.READ);
          var bytes:ByteArray = new ByteArray();
          stream.readBytes(bytes);
          stream.close();
          var context:LoaderContext = new LoaderContext();
          context.allowCodeImport = true;
          var loader:Loader = new Loader();
          loader.contentLoaderInfo.addEventListener(Event.COMPLETE, loadHandler);
          loader.loadBytes(bytes, context);
          function loadHandler(e:Event):void
          _content = DisplayObject(e.target.content);
          So basically:
          1. Read the file as a byte array.
          2. Create a loader context and set allowCodeImport to true.
          3. Create a loader and use loadBytes to "convert" to a useable swf.
          4. On complete, e.target.content contains your swf (fully accessible with code, etc.)
          Hope this helps!  Good luck with your application.
