11 Replies Latest reply on Oct 29, 2012 2:02 AM by [Jongware]
    Can I use "no break" as a nested style?
    Cheryl Graham Level 2
      I have a long paragraph that's nothing but people's names, separated by commas. I don't want any of the names to break, so I've created a Character Style called "No Break" and I can select a name and apply it to that name. But I'd rather not go through the entire paragraph and select every name, then apply the style. So I am trying to figure out how to use a Nested Style. I have selected my No Break Character style through one "," (comma), and then I'm trying to use a Repeat Nested Style, but when I do that, the entire paragraph gets overset.
      What am I missing? Is there a better way to achieve this?
        • 1. Re: Can I use "no break" as a nested style?
          It's an interesting trick. I'm not using Nested styles to do the same, I use a GREP style, but the priciple is the same I guess.
          What I do is set the *entire* paragraph to No Break, as part of the Paragraph style. Then I create a Character style called "No No Break" (for obvious reasons; it has *not* "No Break" selected) and apply it to comma-space using a GREP style. I think you can use a Nested Style the same way, but if not, consider using the GREP style.
          • 2. Re: Can I use "no break" as a nested style?
            OK, I got that to work with a Nested Style. It seems backwards to do it that way, but it worked!
            • 3. Re: Can I use "no break" as a nested style?
              peter minneapolis Level 4
              If you temporarily include a character color in the no break character style while you're building the nested style, and have Preview checked, you'll probably quickly see the problem, and figure out the answer. But, here's what works for me (from Blatner Tools' Paragraph Style Report from dtptools.com):
              Nested Styles          [[None] up to 1 Characters], [nobreak up to 1 , ], [[None] through 1  ], repeat last 2 styles
              NOTE: None style up to 1 Characters, then nobreak style up to 1 comma, then None style through 1 space character, then repeat last 2 styles.
              This works whether the paragraph ends with a period or not, whether the text ends in a paragraph return or is the last line of the story.
              HTH
              Regards,
              Peter
              _______________________
              Peter Gold
              KnowHow ProServices
              • 4. Re: Can I use "no break" as a nested style?
                I prefer to use a different method. Instead of applying No Break, which is hard to detect, turn off hyphenation in the paragraph style and use a non-breaking space between parts of the name.
                Find (?<!,) <there's a space entered there after the close parenthesis>
                Change to ~S
                This finds all spaces not preceded by a comma and changes them to non-breaking.
                • 5. Re: Can I use "no break" as a nested style?
                  You could adapt this to be a GREP style by creating a No Break character style and applying it using that query, too, I think.
                  • 6. Re: Can I use "no break" as a nested style?
                    Wow, Peter(s) - thanks so much. I'm going to try all of these suggestions.
                    • 7. Re: Can I use "no break" as a nested style?
                      I just realized somethihng - What about names such as W. H. Auden, or other three-named people?
                      • 8. Re: Can I use "no break" as a nested style?
                        As I said, it finds all spaces not preceded by a comma. That includes sapces preceded bu other punctuation or some alphanumeric character. Essentially, this forces the breaks to happen only after a comma, so you have to be sure your culumn is wide enough to hold the longest name.
                        • 9. Re: Can I use "no break" as a nested style?
                          Of course. I need to take a break
                          • 10. Re: Can I use "no break" as a nested style?
                            Sometimes I wake up to seeing that I've focused attention on solving dependencies rather than prime causes. Looking back, I think it could have been interesting to ask how the name list is created, and if it's exported from a programmable application, perhaps a non-breaking space character could be inserted where needed, so InDesign wouldn't need to do anything special. IOW, consider change the input if you want different output. One effect of GREP or nested paragraph styles is the computation effort in addition to the composition engine's processing of other required composition properties. In large documents, there could be an overall ID performance hit. Just a thought.
                            HTH
                            Regards,
                            Peter
                            Peter Gold
                            KnowHow ProServices
                            • 11. Re: Can I use "no break" as a nested style?
                              You can test if Peter's suggestion works for you by selecting the entire paragraph and using GREP to replace the space with a hard space. Search for
                              (?<!,)\u{20}
                              and replace with
                              ~s
                              (Instead of "\u{20}" you can also type a single space, but it wouldn't show up in this post :-P)
