• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
ImageResize Off by 1px
New Here ,
Mar 05, 2008 Mar 05, 2008
When using ImageResize it can be off by 1px in height, width or both. If I specify the "interpolation" as "highestPerformance" it resizes correctly but with "highestQuality" (which is prefered) the image is off 1px.
This doesn't happen every time, it depends on the starting width and height if it is off.
Is there a hot fix for this, is there any way (other than highestPerformance) to get that to work and look good?
Thanks.
TOPICS
Advanced techniques
Views
572
Translate
Translate
Report
Report
Community guidelines
community guidelines
Valorous Hero ,
Can you give an example that reproduces this problem?
Votes
Translate
Translate
Report
Report
New Here ,
Mar 06, 2008 Mar 06, 2008
Sure, no problem.
The image I started with was 1280x960 at 72dpi.
<cfimage source="d:\projects\test.jpg" name="img">
<cfscript>
ImageSetAntialiasing(img, "on");
ImageCrop(img, 66, 270, 458, 229);
ImageResize(img, 100, 50);
</cfscript>
<cfimage source="#img#" action="write" destination="d:\projects\test-thumb.jpg" quality=".85" overwrite="yes">
The user would click on the image to come up with x, y, w and h values.
Thanks for the help
Votes
Translate
Translate
Report
Report
Valorous Hero ,
Yes, that seems like a rounding problem. Christian Küpers mentioned something about this on Ben Nadel's blog. I do not know if the math works out in every case, but notice how incrementing the value slightly produces a 100x50 image, instead of 99x49? That seems to support the theory it is a rounding problem.
ImageResize(img, 100.0001, 50.0001);
Votes
Translate
Translate
Report
Report
New Here ,
Yeah, I go to Ben's website to find answeres to most of my problems.
Thanks I just add ".0001" to my variables and it works perfectly. Thanks
Votes
Translate
Translate
Report
Report
Valorous Hero ,
Yes, I have read it occaisionally and there are some good entries. I just happened to remember seeing something about resizing problems in the comments when researching how to create transparent gif's. I re-checked google and sure enough, there it was ;-)
Btw, if you do not see any image function fixes in the latest hot fixes, you might consider submitting a bug report on this issue.
Votes
Translate
Translate
Report
Report
New Here ,
I did not see anything related to that so I'll submit it. Thanks again.
Votes
Translate
Translate
Report
Report
Valorous Hero ,
Apr 05, 2008 Apr 05, 2008
LATEST
Just an update. The issue is now included in the Known Issues section of the Release notes for the recent ColdFusion 8 Update 1.
70069
Sometimes the ImageResize function produces an image 1 pixel shorter or
narrower than the requested size. The image does resize properly if you
specify bicubic, bilinear, nearest, or highestPerformance as the
interpolation parameter value.
Votes
Translate
Translate
Report
Report
Resources
Documentation
