6 Replies Latest reply on Nov 28, 2012 1:56 PM by Nifty Styles
    Importing text data to a text field - What am I doing wrong ?
    Nifty Styles Level 1
      I've been pulling my hair out over this for half the weekend
      My ultimate objective is to read a date stored in a text file and display it in a text field on my PDF page.
      However, I am currently stuck at the point of simply importing the pure text (without reformatting it to the date format I would ultimately like).
      The text contained in my text file is simply a list of dates (of which I wish to print the first in the list). Read about the importTextdata function I have added a header line with the text fields name - so the contents of my text file looks like this:
      LastSyncDate
      09/10/2012 12:17:53.54
      04/10/2012 14:23:45.32
      23/07/2012 12:46:35.51
      Never
      I understand that the importTextData command is a priveleged function so I have written a folder level script to read the text file and store the text in a variable, which is then assigned to the text field.
      I have then called the trusted function at the Document Script level of the page concerned:
      Folder Level script:
      LastSyncCalc3 = app.trustedFunction( function()
      app.beginPriv();
      var LastSync3 = importTextData("/C/sync/bin/LastSyncTest.txt", 0);
      this.getField("LastSyncDate").value = Lastsync3;
      app.endPriv();
      Document Level Script:
      LastSyncCalc3();
      Running this gives the following errors in the console:
      importTextData is not defined
      4:Document-Level:SyncDate
      ReferenceError: importTextData is not defined
      Thinking I had my commands misplaced, I changed the folder level script and document level script to the following:
      app.beginPriv();
      app.endPriv();
      Lastsync3 is not defined
      1:Document-Level:SyncDate
      ReferenceError: Lastsync3 is not defined
      Where am I going wrong please ??
        • 1. Re: Importing text data to a text field - What am I doing wrong ?
          importTextData is a method belonging to a Doc object. You can use it
          implicitly in many cases, but not in the context of a folder-level script.
          You'll need to pass the current doc object as a parameter to the function,
          and then use it when calling the function (the same goes for the use of
          "this" as a reference to the document).
          There are other problems with your code, though. For example, you define a
          variable called "LastSync3", but then try to access one called "Lastsync3".
          JS is case-sensitive, so you have to use the exact same name.
          Also, are you aware that importTextData returns a number indicating if the
          process was successful or not, not a date?
          • 2. Re: Importing text data to a text field - What am I doing wrong ?
            Gilad,
            Sorry for the long delay in resuming this project.
            I am really stumped and slightly baffled by the technical speak in your last post - in particular:
            "You'll need to pass the current doc object as a parameter to the function,
            and then use it when calling the function "
            Would you be so kind as to put in more simple terms what code I need to put where please ?
            I've tried various combinations but with no success !!
            Thank you  in advance,
            Nifty.
            • 3. Re: Importing text data to a text field - What am I doing wrong ?
              Instead of this:
              app.beginPriv();
              app.endPriv();
              LastSyncCalc3();
              Use this:
              LastSyncCalc3 = app.trustedFunction( function(doc)
              app.beginPriv();
              var LastSync3 = doc.importTextData("/C/sync/bin/LastSyncTest.txt", 0);
              doc.getField("LastSyncDate").value = Lastsync3;
              app.endPriv();
              LastSyncCalc3(this);
              • 4. Re: Importing text data to a text field - What am I doing wrong ?
                Gilad,
                Superb .. that's exactly it ... so straight forward and obvious once you'd posted it up.
                I'm feeling suitably stupid and embarrassed for not cottoning on sooner !
                It's a long way to come but if you're ever in my neck of the woods there's a pint or two waiting for you.
                Thank you very much,
                Nifty.
                • 5. Re: Importing text data to a text field - What am I doing wrong ?
                  PS. I had forgotten to fix the variable name error in the code above. So this:
                  Should be:
                  doc.getField("LastSyncDate").value = LastSync3;
                  • 6. Re: Importing text data to a text field - What am I doing wrong ?
                    Thank you very much, I have it working.
                    (I had actually corrected the case error already).
                    Now all I need to do is get the system to read the text as a date (which is what it is) so I can format it in a more friendly fashion.
                    I've other things to worry about at present but may need some help with that a little later on !!
