1 Reply Latest reply on Oct 29, 2012 12:23 AM by Jump_Over
    Redundant page numbers in index?
    Matt J Kuhns Level 1
      I have just begun using the index feature in InDesign for the first time. Since I have been learning as I go (and made part use of the automated list all feature), I created somewhat "messy" page references. I was surprised, however, that InDesign doesn't seem to clean them up at all. For example, an index entry will list "4-25, 5, 8, 12, 14, 19, 20, 22, 24, 25." It seems like it would make more sense to recognize overlapping page ranges when it generates the index and simplify the listings considerably (i.e. just list "4-25").
      Is there some way to get this to happen? I've searched through help files and forum posts and not found anything. Right now the only options I can see are: clean up my page references manually (very tedious), start all over (worse still) or clean up the index manually. Any other thoughts are welcome.
      I've been using InDesign CS4 (in OS X), though I have access to CS6 (currently I'm making only limited use of it because my iMac is apparently too old to run it efficiently).
        • 1. Re: Redundant page numbers in index?
          Jump_Over Level 5
          Check your index entry type, which is a separate option for each entry.
          If your entry type is "current page" and is found on pages 1 and 2 - will be listed as 1,2
          If your entry type is "to the end of document" - will be listed as page range from-to.
          The same entry could have many occurrences. Each occurrence could have a separate option.
          Index shows a list of them as a summary of occurrences.
          To recognize overlapping page ranges would mean to ignore entries options.
          As far as I know, of course
