2 Replies Latest reply on Oct 29, 2012 7:01 AM by Umami Design
    InDesign CS6 (8.0.1.406) crash at startup OS X
    Umami Design
      Just began experiencing constant crashes upon startup with InDesign CS6 (8.0.1.406) on OS X 10.8.2. The report can be found here (https://gist.github.com/3971663).
      I haven't added any new applications or fonts. So, any thoughts towards this issue would be much appreciated -as currently I'm stomped.
        • 1. Re: InDesign CS6 (8.0.1.406) crash at startup OS X
          John Hawkinson Level 5
          So...did you update 10.8.2 from a working install under 10.8.1? Or from 8.0.0 to 8.0.1?
          This kind of crash:
          Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
          0   ObjectModelLib.dylib               0x015e4eb3 0x15d6000 + 61107
          1   ObjectModelLib.dylib               0x0160564d ShuksanInit(IStartupScreen* (*)(), IPlugIn*) + 16765
          2   ObjectModelLib.dylib               0x016024ba ShuksanInit(IStartupScreen* (*)(), IPlugIn*) + 4074
          3   com.adobe.InDesign                 0x00001dc2 main + 82
          4   com.adobe.InDesign                 0x00001d55 start + 53
          suggests an installation failure of somesort -- the app has only barely started to run.
          Did you trash your preferences? Try a new user account?
          • 2. Re: InDesign CS6 (8.0.1.406) crash at startup OS X
            Umami Design Level 1
            Trashing the preference cured the issue. For those finding this issue you'll find that preference file located at:
            drive / library / preferences / com.adobe.InDesign.7.0/plist
            Note the "com.adobe.InDesign.7.0.plist" file may be different. However, locate "InDesign...plist" and you'll likely he fine.
            And to answer your questions, John...the update from OS 10.8.1 > OS 10.8.2 was performed via the App Store. The InDesign update from 8.0.0 > 8.0.1 was performed using Adobes "AdobeInDesign8Patch-All.dmg."
            Thank you, John! The preference reminder was much appreciated.
