2 Replies Latest reply on Oct 29, 2012 10:01 AM by MichelBParis
    Batch Processing in Photoshop 10
    griz1995
      Is it possible to batch process .jpegs one stop lighter in Photoshop 10? My picture are of football, but all seem a 1/2 to 1 stop darker than I wanted.
        • 1. Re: Batch Processing in Photoshop 10
          99jon Adobe Community Professional & MVP
          The tweaks possible are limited in elements when using batch processing. You could try auto-levels to see if you like the results.
          From the menu in the Editor Use File >> Process Multiple Files.
          Select an new destination folder so as not to overwrite the originals in your source folder.
          • 2. Re: Batch Processing in Photoshop 10
            MichelBParis Adobe Community Professional & MVP
            If process multiple files with auto level is not satisfying, you could try the affordable Elements+ plugin which has more options for batch correction via scripts.
            For those who work from raw files, you can get the best result by editing the first picture in ACR, then using process multiple files with the 'last conversion' option. (Don't forget to set ACR output to 8 bits).
