10 Replies Latest reply on Nov 10, 2012 1:58 AM by pixxxel schubser
    Uncaught exception when I update window
    Harsh V Sharma Level 1
      Hi All,
      I want to show a progress bar while executing script.
      and i am using the following code for that:
      var win = new Window("palette", "SnpCreateProgressBar", [150, 150, 600, 260]);
      win.pnl = win.add("panel", [10, 10, 440, 100], "Script Progress");
      win.pnl.progBar = win.pnl.add("progressbar", [20, 35, 410, 60], 0, 100);
      win.pnl.progBarLabel = win.pnl.add("statictext", [20, 20, 320, 35], "0%");
      win.show();
                          while(win.pnl.progBar.value < win.pnl.progBar.maxvalue)
                                    // this is what causes the progress bar increase its progress
                                    win.pnl.progBar.value++;
                  win.pnl.progBarLabel.text = win.pnl.progBar.value+"%";
                                    $.sleep(10);
          alert('Done!');
      win.close();
      But I am having following error when I run it:
      Can you please tell me why it is happening....
      Harsh S
        • 1. Re: Uncaught exception when I update window
          CarlosCanto Adobe Community Professional & MVP
          first, you're just showing 18 lines of code, your error is in Line 422
          next, all the code in "Red" in your sample needs to be enclosed in quotation marks
          • 2. Re: Uncaught exception when I update window
            pixxxel schubser MVP & Adobe Community Professional
            @Harsh V Sharma,
            please show your code for the progress bar completely. ( I can't find win.update() in your code). Also this call is only needed, if you work under MacOS. The palette works fine under Windows OS without win.update().
            • 3. Re: Uncaught exception when I update window
              Silly-V Adobe Community Professional
              I am having a similar problem too, but cannot find a way to replicate the problem outside my very convoluted current project..
              • 5. Re: Uncaught exception when I update window
                @Harsh V Sharma,
                you have now found a solution? Or you can answer my previous posting?
                • 6. Re: Uncaught exception when I update window
                  Hi follwing is the  code i am using:
                  function artboardToJPGs(size)
                  var win = new Window("palette", "SnpCreateProgressBar", undefined, {borderless: true});
                  win.pnl = win.add("panel", [10, 10, 440, 100], "Creating JPEG");
                          win.show ();
                  for(i=0; i<10; i++)
                  win.pnl.progBar.value+=10;
                          win.update();
                          var idx, j, sizes, jpegOpt, doc, docName, dF, artBds, abName, scale, jpgFile, destinationFolder, originalImage;
                          jpegOpt = new ExportOptionsJPEG();
                          jpegOpt.Optimization = true;
                          jpegOpt.QualitySetting = 100;
                          jpegOpt.blurAmount=0;
                          jpegOpt.artBoardClipping=false;
                          dF=new Folder(jpgImageFolder);
                          if ( !dF.exists ) dF.create();
                          doc = app.activeDocument;
                          docName=doc.name;
                          artBds = doc.artboards;
                          idx = artBds.getActiveArtboardIndex();
                          abName = artBds[ idx ].name;
                             var w= artBds[ idx ].artboardRect[2] - artBds[ idx ].artboardRect[0] ;
                             var h=artBds[ idx ].artboardRect[1] - artBds[ idx ].artboardRect[3];
                              var width=  100+ ( (size - w)/w ) * 100;
                              var height=  100+ ( ( size - h )/h ) * 100;
                              jpgFile = File( dF.fsName + '/' + fileName + size + 'x' + size + '.jpg' );
                              jpegOpt.horizontalScale =width;
                              jpegOpt.verticalScale = height;
                              doc.exportFile( jpgFile, ExportType.JPEG ,jpegOpt );
                              win.close();
                  • 7. Re: Uncaught exception when I update window
                    Sorry, but your code is terrible posted in forum.    …(like my English)
                    I think the counter i is not used in win.pnl
                    And because the steps are defined anyway : win.pnl.progBar.value + = 10;
                    try this:
                    while(win.pnl.progBar.value<100)
                    instead of:
                    for(i=0; i<10; i++)
                    • 8. Re: Uncaught exception when I update window
                      your English is great.
                      • 9. Re: Uncaught exception when I update window
                        Yaar I am posting my code again on this portal:
                        this is terrible because its not working:::
                        • function artboardToJPGs(size)
                        • var win = new Window("palette", "SnpCreateProgressBar", undefined, {borderless: true});
                        • win.pnl = win.add("panel", [10, 10, 440, 100], "Creating JPEG");
                        • win.pnl.progBar = win.pnl.add("progressbar", [20, 35, 410, 60], 0, 100);
                        • win.pnl.progBarLabel = win.pnl.add("statictext", [20, 20, 320, 35], "0%");
                        •         win.show ();
                        • for(i=0; i<10; i++)
                        •     win.pnl.progBar.value+=10;
                        •             win.pnl.progBarLabel.text = win.pnl.progBar.value+"%";
                        •             win.update();
                        •         var idx, j, sizes, jpegOpt, doc, docName, dF, artBds, abName, scale, jpgFile, destinationFolder, originalImage;
                        •         jpegOpt = new ExportOptionsJPEG();
                        •         jpegOpt.Optimization = true;
                        •         jpegOpt.QualitySetting = 100;
                        •         jpegOpt.blurAmount=0;
                        •         jpegOpt.artBoardClipping=false;
                        •         dF=new Folder(jpgImageFolder);
                        •         if ( !dF.exists ) dF.create();
                        •         doc = app.activeDocument;
                        •         docName=doc.name;
                        •         artBds = doc.artboards;
                        •         idx = artBds.getActiveArtboardIndex();
                        •         abName = artBds[ idx ].name;
                        •            var w= artBds[ idx ].artboardRect[2] - artBds[ idx ].artboardRect[0] ;
                        •            var h=artBds[ idx ].artboardRect[1] - artBds[ idx ].artboardRect[3];
                        •             var width=  100+ ( (size - w)/w ) * 100;
                        •             var height=  100+ ( ( size - h )/h ) * 100;
                        •             jpgFile = File( dF.fsName + '/' + fileName + size + 'x' + size + '.jpg' );
                        •             jpegOpt.horizontalScale =width;
                        •             jpegOpt.verticalScale = height;
                        •             doc.exportFile( jpgFile, ExportType.JPEG ,jpegOpt );
                        •             win.close();
                        • 10. Re: Uncaught exception when I update window
                          @Harsh V Sharma,
                          please read my last post again - carefully.
                          @CarlosCanto
