2 Replies Latest reply on Oct 31, 2012 7:28 AM by _darwinjob_
    Why clipboard items are disabled?
    _darwinjob_
      Hi
      Here is a test case, simple setup which should work out of the box: AdvancedDataGrid with 3 colums and ContextMenu with clipboard menu enabled.
                     xmlns:mx="library://ns.adobe.com/flex/mx"
                     minWidth="800"
                     minHeight="600"
                     creationComplete="application1_creationCompleteHandler(event)">
          <fx:Script>
              <![CDATA[
                  import mx.collections.ArrayCollection;
                  import mx.controls.Alert;
                  import mx.events.FlexEvent;
                  [Bindable]
                  private var cm:ContextMenu;
                  [Bindable]
                  private var advancedDataGridDataProvider:ArrayCollection=new ArrayCollection();
                  protected function application1_creationCompleteHandler(event:FlexEvent):void
                      cm=new ContextMenu();
                      cm.hideBuiltInItems();
                      cm.clipboardMenu=true;
                      cm.clipboardItems.copy=true;
                      cm.clipboardItems.cut=true;
                      cm.clipboardItems.paste=true;
                      cm.clipboardItems.selectAll=true;
                      advancedDataGrid.addEventListener(Event.COPY, advancedDataGrid_onEvent);
                      advancedDataGrid.addEventListener(Event.CUT, advancedDataGrid_onEvent);
                      advancedDataGrid.addEventListener(Event.PASTE, advancedDataGrid_onEvent);
                      //Just filling with garbage
                      for (var i:int=0; i < 10000; i++)
                          var o:Object=new Object();
                          o.col1=Math.random();
                          o.col2=Math.random();
                          o.col3=Math.random();
                          advancedDataGridDataProvider.addItem(o);
                  private function advancedDataGrid_onEvent(evt:Event):void
                      Alert.show(evt.type);
          </fx:Script>
          <fx:Declarations>
              <!-- Place non-visual elements (e.g., services, value objects) here -->
          </fx:Declarations>
          <mx:AdvancedDataGrid contextMenu="{cm}"
                               dataProvider="{advancedDataGridDataProvider}"
                               id="advancedDataGrid"
                               designViewDataType="flat"
                               selectionMode="multipleCells"
                               left="10"
                               top="10"
                               right="10"
                               bottom="10">
              <mx:columns>
                  <mx:AdvancedDataGridColumn headerText="Column 1"
                                             dataField="col1"/>
                  <mx:AdvancedDataGridColumn headerText="Column 2"
                                             dataField="col2"/>
                  <mx:AdvancedDataGridColumn headerText="Column 3"
                                             dataField="col3"/>
              </mx:columns>
          </mx:AdvancedDataGrid>
      </s:Application>
      If I run this, select one or more cells and then right-clcik to get the context menu all clipboard context menu items (Copy, Paste etc.) are DISABLED. Why is that? More strangely, if I precisely right-click between the rows - then the items are suddenly enabled!
        • 1. Re: Why clipboard items are disabled?
          Flex harUI Adobe Employee
          There might be another ContextMenu defined for the actual renderers so the ADG’s contextMenu doesn’t take effect.
          • 2. Re: Why clipboard items are disabled?
            _darwinjob_ Level 1
            Thanks for the reply.
            I have experimented with itemRenderers with no success. The problem was that I was using Canvas. After your post I realized that there is a dedicated class for that. To make in work with 4.1 it is enough to have ADG like that:
                                     itemRenderer="ADGItemRenderer"
                                     left="10"
                                     top="10"
                                     right="10"
                                     bottom="10">
                    <mx:columns>
                                                   dataField="col1"/>
                                                   dataField="col2"/>
                                                   dataField="col3"/>
                    </mx:columns>
            ADGItemRenderer is defined like this:
            <s:MXAdvancedDataGridItemRenderer xmlns:fx="http://ns.adobe.com/mxml/2009"
                                              focusEnabled="true">
                <s:Label id="lblData"
                         left="0"
                         text="{listData.label}"
                         verticalCenter="0"/>
            </s:MXAdvancedDataGridItemRenderer>
            As you can see contex menu is still in ADG but clipboard items are enabled now.
            The same trick does not work in 3.5 though. It does not work with AdvancedDataGridItemRenderer. I have moved ContextMenu from ADG to AdvancedDataGridItemRenderer like this:
            <mx:AdvancedDataGridItemRenderer xmlns:mx="http://www.adobe.com/2006/mxml"
                                             xmlns:ui="flash.ui.*"
                                             copy="clipboardHandler(event)"
                                             paste="clipboardHandler(event)"
                                             cut="clipboardHandler(event)"
                                             selectAll="clipboardHandler(event)"
                                             clear="clipboardHandler(event)">
                <mx:Script>
                    <![CDATA[
                        protected function clipboardHandler(event:Event):void
                            Alert.show(event.type);
                </mx:Script>
                <mx:contextMenu>
                    <ui:ContextMenu clipboardMenu="true"
                                    id="adgContextMenu">
                        <ui:clipboardItems>
                            <ui:ContextMenuClipboardItems copy="true"
                                                          cut="true"
                                                          paste="true"
                                                          selectAll="true"
                                                          clear="true"/>
                        </ui:clipboardItems>
                    </ui:ContextMenu>
                </mx:contextMenu>
            </mx:AdvancedDataGridItemRenderer>
            The items are still disabled. WTH?
            Fortunately it works with AdvancedDataGridGroupItemRenderer (which, I guess, has a slightly different purpose). If I define ADG itemRenderer just like this (keeping ContextMenu in ADG):
            <mx:AdvancedDataGridGroupItemRenderer xmlns:mx="http://www.adobe.com/2006/mxml"/>
            then the clipboard items are enabled. Crazy.
