5 Replies Latest reply on Jun 25, 2014 4:42 PM by CPBTenner
    how to pause an embedded video
    loxfear Level 1
      hello i got a code just like this:
      var youtubevid = $("<iframe/>");
           youtubevid.attr('src','http://www.youtube.com/embed/ykF1y2EJ2nI');  // url/Video_Id
           youtubevid.attr('frameborder','1');       // 1 | 0
           youtubevid.attr('allowfullscreen','0');   // 1 | 0
      and i want to pause this whith an button but how?
        • 1. Re: how to pause an embedded video
          loxfear Level 1
          i still havent figured it out yet .. anyone?
          • 2. Re: how to pause an embedded video
            Dam4222 Level 1
            Hey Loxfear,
            I am having the same issue except I am using a video locally. This is how I call it in compositionReady:
            var background = $("<video width='855' height='480'>" +
               "<source src='media/ATT_ADWORKS_INTRO2_FINAL.mp4'/>" +
               "This browser is not compatible with HTML 5" +
            // stage symbol lookup, and append the above vid object to it;
            // in other words, get the div called 'vcontainer' and attach the video control to it;
            // additional options for the video object
            I want to be able to have the video pause/stop if another button is clicked. I tried using some basic knowledge of Jquery to do this but only got so far. Basically if I place the following code in the the Click action of my button I can get my DIV to hide. However, I cannot get the video to stop playing.
            sym.$("vcontainer").stop("true", "true").fadeOut();
            It appears we need to some how tell the iframe or in my case the <video> to pause or remove itself.
            Anyone else know how to do this?
            • 3. Re: how to pause an embedded video
              I have not long been using edge.
              I have container that pop up that display the video but when you close the container the video carries on playing.
              The user needs to press a button to close the elements to then goto another one to open it up.
              I came up with an idea... What I done was put this on the button and it works...
              Yes it stopped the video playing as it deleated it and no I have no idea how to pause it. The only problem now is that the user will not be able to see the video again and I have no idea how to script it to create the symbol back. LOL (Anyone!!!)
              • 4. Re: how to pause an embedded video
                Dam4222 Level 1
                Hey Jake,
                So here is what I figured out. You need to use some Jquery to pause and play.  Check out my sample file:
                Essentially, the video Autoplays. Then upon the click of the "TRIGGER" is pauses, and then launch into another part of the timeline.
                • 5. Re: how to pause an embedded video
                  CPBTenner Level 1
                  Can you repost the sample file?  I am running into the same problem.  I have a youtube video in a div that I hide/show.  If the video is playing when the div is hidden it keeps playing. I would like it to pause, or ideally stop so that it is back at the beginning if someone clicks to show it again.  Is that what your sample does?
