Expand my Community achievements bar.
XSLT Tranformation - XSL in a separate file?
Avatar
Level 2
I'm using XSLT Tranformation service to transform an incoming XML document to a different format.  I've tested this successfully using a literal value for my XSL, but I'd like to store the XSL in a separate file rather than storing it as a literal string in the process properties.  However, I don't see any way to reference an XSL file in the process properties.  The only options are XPath expression, variable (string), literal value, and template.
Alternatively, maybe there is a way to read the contents of an XSL file into a string variable which can then be used in the XSLT Tranformation?
