6 Replies Latest reply on Nov 14, 2012 12:07 PM by Roberio Oliveira
    Sony XDCAM HD import error
    Roberio Oliveira
      Hello.
      I am testing Adobe CS6 and realized that it can't import the mxf clips I already have in my HDD, which I've been using with CS5 and CS5.5 without problem.
      I've been reading a lot about this issue here and on others sources out there. Nobody pointed any solution, as far as I am concerned. The best aproach was the convertion of MXF files into another format, such as MPEG2. This workaround wont actually work here because we are a station television and we shoot everything in XDCAM.
      We are working with CS5 and I would just update it to CS5.5 but it seems I can't do it anymore.
      Thank you in advance for any advice you can provide!
      Roberio
        • 1. Re: Sony XDCAM HD import error
          Jim_Simon Level 8
          What model camera does the media come from?
          • 2. Re: Sony XDCAM HD import error
            Roberio Oliveira Level 1
            Hi Jim,
            We use Sony PDW-700 and PDW-800.
            • 3. Re: Sony XDCAM HD import error
              ISDV
              Hi Roberio,
              Is the Professional Disc structure still intact on your HDD?
              Have you tried to ingest those MXF-files into Adobe Prelude, and from there sending them to Premiere Pro?
              Which machine (PDW-U1, PDW-U2, PDW-HD1500, PDW-F1600, PDW-HR1) do you use to ingest the discs onto your HDD?
              Greetings,
              Ivan
              • 4. Re: Sony XDCAM HD import error
                Hi Ivan,
                I don't have the entire folder structure from pro disc, but I can test this. Note that for XDCAM HD I don't need them as I do for XDCAM EX. I just need the MXF files from clip folder. At least they used to work fine this way on CS4, CS5 and CS5.5. We use PDW-U1 to copy the clips.
                I'll do more tests with new clips and will let you know. Btw, are you able to work with XDCAM HD successfully on CS6?
                Thank you.
                • 5. Re: Sony XDCAM HD import error
                  ISDV Level 1
                  Hello Roberio,
                  You are right about the disc structure. You only need the MXF-files. My fault!
                  So for I have no problems with XDCAM HD422 footage in Premiere Pro CS6.
                  Most of the time I'm still using MPEG-HD420 @ 35 Mbps footage from a PDW-F355. I'm only having audio problems with it in Prelude, but that's not an XDCAM HD problem. With AVCHD I have this problem too.
                  Are you using Windows or a Mac?
                  Greetings,
                  Ivan
                  • 6. Re: Sony XDCAM HD import error
                    Hi Ivan,
                    Sorry the delay, I was forced to stop the tests for a while.
                    I'm using Windows 7.
                    Today I tested XDCAM HD420 footages from the PDW and everything went well. Same for IMX.
                    Then I started testing other HD 422 clips, and was able to import them. Looking into the metadata I figured out that some clips were actually reencoded using MainConcept plug-in; those clips I could not import. Then I installed Rovi Totalcode plug-in and was able to import them all.
                    That's the problem I need to seek solution now, as we have a two years old archive entirely encoded by MainConcept. But now I have an enlighted path before me.
                    Thanks for the help, Ivan.
                    Greetings
                    Roberio
