2 Replies Latest reply on Nov 1, 2012 5:15 PM by havefreetime
    How can I access object of NavigatorContent's child?
    havefreetime Level 1
      Hi, All.
      In this code, how can I access object 'lbl'?
      I'm very new to flex. Please help me.
      Thanks in advanced, and sorry for my English.
      Kevin.
        • 1. Re: How can I access object of NavigatorContent's child?
          Atul(Flex Dev) Level 1
          Pls use following code to access object
                xmlns:mx="library://ns.adobe.com/flex/mx" minWidth="955" minHeight="600">
          <fx:Script>
            <![CDATA[
             import mx.controls.Alert;
             import mx.controls.Label;
             import spark.components.NavigatorContent;
             private var num:Number=1
             private function perform():void
                 var nav:NavigatorContent=new NavigatorContent();
              var lbl:Label=new Label();
              lbl.text=num.toString();
              num++;
              nav.addElement(lbl);
              myTab.addChild(nav);
             private function changeText():void{
              for(var i:int=0; i<myTab.numElements; i++){
               var navContent:NavigatorContent = NavigatorContent(myTab.getElementAt(i));
               for(var i:int=0; i<navContent.numElements; i++){
                  navContent.getElementAt(i)
                 Alert.show(""+navContent.getElementAt(i))  ;
          </fx:Script>
          <fx:Declarations>
            <!-- Place non-visual elements (e.g., services, value objects) here -->
          </fx:Declarations>
          <s:VGroup>
            <mx:TabNavigator x="57" y="21" width="346" height="335" id="myTab">
            </mx:TabNavigator>
            <s:Button x="75" y="370" label="Button" click="perform()"/>
            <s:Button x="174" y="370" label="Button" click="changeText()"/>
          </s:VGroup>
          </s:Application>
          Atul(atagrawal@infocepts.com)
          • 2. Re: How can I access object of NavigatorContent's child?
            Thank you very much.  Atul.
            Finally I solved the problem.
            I use this code.
            val label:Label;
            for(var i:int=0; i<selectedChild.numElements; i++)
                  label = selectedChild.getElementAt(i) as Label;
            Thanks again.
            Kevin.
